Home » Archived » M2M (model-to-model transformation) » [ATL]Specification attribute not set in uml:Activity
[ATL]Specification attribute not set in uml:Activity [message #97666] Thu, 15 January 2009 05:25 Go to next message
I am doing an ATL transformation for an UML Activity diagram.
This model transformation contains a reference to another UML class file,
that is the attribute "Specification" of the UML Activity element is
referencing a method of a UML class.
Unfortunately, after the ATL transformation is finished, the
"Specification" attribute is not set in the target model.
I am using Eclipse 3.4.1 and ATL 2.0.2 and I tried the EMF-specific VM and
the regular ATL VM.
I also set the check mark " Allow inter-Model references" but it doesn't
help.
My ATL rule:
rule Act2Act {
from s : UML2!"uml::Activity"
to out: UML2!"uml::Activity"(
name <- s.name,
node<-s.node,
edge<-s.edge,
partition<-s.partition,
--this will be ignored by the ATL:
specification<-s.specification)
Thomas
Re: [ATL]Specification attribute not set in uml:Activity [message #97698 is a reply to message #97666] Thu, 15 January 2009 08:25 Go to previous messageGo to next message
hi thomas
specification is a reference but not a containment
check you have a rule which transforms the element targeted by
s.specification and which affects the object in other in a containment
reference
Thomas Winkler a écrit :
> Hello,
> file, that is the attribute "Specification" of the UML Activity element
> is referencing a method of a UML class.
> and the regular ATL VM.
> help.
> My ATL rule:
> rule Act2Act {
> name <- s.name,
> node<-s.node,
> edge<-s.edge,
> Cheers,
> Thomas
Re: [ATL]Specification attribute not set in uml:Activity [message #97712 is a reply to message #97698] Thu, 15 January 2009 18:45 Go to previous messageGo to next message
Hi Tristan,
Thanks for your reply but the the s.specification element (method from a
class) won't be transformed so I have no rule for it.
And there are no other rules affecting that method in my ATL rules.
Thomas
Tristan FAURE wrote:
> hi thomas
> reference
Re: [ATL]Specification attribute not set in uml:Activity [message #97847 is a reply to message #97712] Tue, 20 January 2009 04:20 Go to previous messageGo to next message
Okay that's why it doesn't work you have to create a rule transforming
this element (or just copying it) to contain it
how atl works (approximatively)
-----> i apply this rule for each activity
rule Act2Act {
name <- s.name,
node<-s.node,
edge<-s.edge,
-----> okay i have to affect s.specification to my attribute specification
-----> is s.specification needs to be contain by Activity ?
-> no it is contained by other element not by an activity
-----> where this element is transformed ?
-> anywhere so i can't affect it
If you don't tell ATL to keep trace of operations you will not be able
to reference it
so you have to write a rule Operation2Operation (or using High Level
Type) and Rules ton contain them (Class2Class, Package2Package ...)
When ATL will match your s.specification it will we able to search in
its registry that it already (or will) transform the object and can
affect it
> Hi Tristan,
> Thomas
>> hi thomas
>> reference
Re: [ATL]Specification attribute not set in uml:Activity [message #97967 is a reply to message #97847] Wed, 21 January 2009 06:38 Go to previous message
Thanks Tristan for your explanation !
Since I don't need any transformation for that element (it must be
referenced only) I will try using the initialization that is applying the
entrypoint rule for it.
Thomas
> rule Act2Act {
> name <- s.name,
> node<-s.node,
> edge<-s.edge,
> to reference it
> affect it
>> Hi Tristan,
>> Regards,
>> Thomas
>>> hi thomas
>>> reference
Previous Topic:[QVTO] A Problem Enumeration Literals based conditions
Next Topic:[Declarative QVT] Transformation problem , beginer
Current Time: Sun Aug 31 21:15:11 EDT 2025
Powered by FUDForum. Page generated in 0.03760 seconds
