| 3.0 code formatter question [message #97654] |
Sat, 20 September 2003 16:47   |
Eclipse User  |
Originally posted by: rmaker.cs.brandeis.edu
I am experimenting with 3.0M3, and I can't figure out one code formatting
customization.
| = cursor position
When I have
if(someBoolean)|
and I hit enter, the cursor position changes to:
if(someBoolean)
And I would like it to change to:
if(someBoolean)
What setting do I need to change to get this to happen?
Thanks in advance,
Reid
| Re: 3.0 code formatter question [message #99402 is a reply to message #97741] |
Sat, 27 September 2003 12:56    |
Eclipse User  |
Tom,
When I type:
someMethod() and hit enter, it will put me
    here.  If I hit {, it will make it look like:
someMethod()
Which is not what I want...
Reid
Tom Eicher wrote:
> You can't change that at the moment. Code formatting is being reworked
> in several areas for 3.0, and the current preferences have very limited
> coverage. If you hit Insert, you can leave the smart mode, however, no
> autoindentation what so ever will happen then - probably not what you want.
> Just out of curiosity: can you explain why you want the conditional
> statement on the same indentation level? Note that if you enter an
> opening brace at in the situation you describe, it will automatically
> move back to the correct position.
> if (someBoolean)
>      someMethod();
> but:
> if (someBoolean)
>      someMethod();
> -tom
> > customization.
> > | = cursor position
> > When I have
> > if(someBoolean)|
> > if(someBoolean)
> > if(someBoolean)
> > Thanks in advance,
> > Reid
| Re: 3.0 code formatter question [message #99417 is a reply to message #99402] |
Sat, 27 September 2003 13:43   |
Eclipse User  |
this is fixed in a newer build.
johan
Reid Maker wrote:
> Tom,
> When I type:
> someMethod()
> Reid
>>if (someBoolean)
>>     someMethod();
>>but:
>>if (someBoolean)
>>     someMethod();
>>-tom
>>>customization.
>>>| = cursor position
>>>When I have
>>>if(someBoolean)|
>>>if(someBoolean)
>>>if(someBoolean)
>>>Thanks in advance,
>>>Reid
FUDForum. Page generated in 0.03896 seconds
