Font Family in GEF? [message #97632] |
Tue, 07 October 2003 01:25  |
Originally posted by: temp.XX.com
I wonder if there's any font family such as Veranda, New Times Roman etc
in GEF? Hope that someone can enlighten me. Thanks!
regards,
June
Re: Font Family in GEF? [message #98581 is a reply to message #97823] |
Fri, 10 October 2003 22:54   |
Originally posted by: felix.mayer.comcast.net
I might not understand what your issue is.
For a 10 pt "Times New Roman" font with normal face, you could do this in
your org.eclipse.draw2d.Shape.outlineShape( Graphics ):
Font font = new Font( Display.getDefault(), "Times New Roman", 10,
SWT.NORMAL )
graphics.setFont( font );
graphics.drawString( "whatever", 10, 10 );
"June" <temp@xx.com> wrote in message news:bm00js$qen$1@eclipse.org...
> But the Font class allow any specification of font family. How do i
> create, for example, a New times Roman Font? I need it so that when the
> user specifies a particular font, i can display my text according...
> Thanks!
> regards,
> June
> Felix Mayer wrote:
> > Just call Graphics.setFont() with a Font that you created.
> > "June" <temp@XX.com> wrote in message news:bltios$e45$1@eclipse.org...
> > > Hi,
etc
> > > regards,
> > > June
Re: Font Family in GEF? [message #113343 is a reply to message #112948] |
Thu, 22 January 2004 17:31   |
> Hi!
in
> > SWT.NORMAL )
> Can anyone explain what happens when calling Display.getDefault() or
> when passing "null" instead of Display.getDefault() to the Font()
> constructor?
> I think in both cases the current SWT UI display device will be used to
> create the font on. This is ok as long as you're painting onto a draw2D
> grpaphics that will map its output to this SWT display device.
In the PrinterGraphics class, we map every font from its Display version to
its Printer version. Make sure you dispose() the graphics, since that will
throw out the cache of PrinterFonts.
> But what happens e.g. while printing? Then you're painting onto a draw2d
> graphics that will not map the graphical output to the current SWT
> display device. Then the output is mapped to a diffrent (e.g. printer)
> device. But the font object then will be created for the UI display
> device, won't it?
> Holger
Re: Font Family in GEF? [message #114447 is a reply to message #113343] |
Wed, 28 January 2004 12:09  |
A ok, thank you. Now I got it ... it was a bit hidden via zoomFont() and
getCachedFont().
FUDForum. Page generated in 0.08158 seconds
