Home » Eclipse Projects » Equinox » jsp compile issue when running in tomcat6
jsp compile issue when running in tomcat6 [message #97558] Mon, 17 September 2007 19:28 Go to next message
Originally posted by: dkrebs.tibco.com
I'm using the core server osgi equinox framework but handling my jsp pages
within my own framework. I can get the jsp pages to load and compile
without any problems in my development environment but when trying to run
my osgi app inside tomcat6 I'm getting the following error. Seems like a
classpath issue but I'm a little hazy on how to track this down, trying to
figure out what has changed in the two environments, I have jasper wrapped
in a plugin, should I not include that when deploying to a servlet
container? Also if anyone could offer some high level concepts of what to
look through to troubleshoot something like this it would be much
appreciated. - Duncan
java.lang.NoClassDefFoundError:
org/apache/commons/el/ExpressionEvaluatorImpl
at org.apache.jasper.compiler.JspUtil.<clinit>(JspUtil.java:61)
org.apache.jasper.JspCompilationContext.getDerivedPackageNam e(JspCompilationContext.java:414)
org.apache.jasper.JspCompilationContext.getServletPackageNam e(JspCompilationContext.java:403)
Re: jsp compile issue when running in tomcat6 [message #97665 is a reply to message #97558] Wed, 19 September 2007 15:55 Go to previous message
Hi Duncan,
Have you looked at org.eclipse.equinox.jsp.jasper ?
The JSPServlet should be able to do what you're asking for and if not should
help considerably when trying to sort out setting up the various class
loaders.
This is based around the Jasper 2 engine in 5.5 however I'm guessing a port
to what's in TC 6 should be straight-forward.
HTH
-Simon
"Duncan Krebs" <dkrebs@tibco.com> wrote in message
news:d571c621113a35265837a84b5d6b2ad3$1@www.eclipse.org...
> Hi, I'm using the core server osgi equinox framework but handling my jsp
> pages within my own framework. I can get the jsp pages to load and compile
> at
> at
Previous Topic:NullPointerException in launcher.WebStartMain.findBundle()
Next Topic:lifecycle, sequence and retrieve of a event with equinox Event Admin Service
Current Time: Sun Aug 31 02:42:07 EDT 2025
Powered by FUDForum. Page generated in 0.03214 seconds
