Home » Eclipse Projects » GEF » Prevent Child Selection with policy?
Prevent Child Selection with policy? [message #97509] Mon, 06 October 2003 16:52 Go to next message
Originally posted by: ThisisFake.Fakeness.xyz
I have a component that contains other parts. I prevent its children from
being selected if I drag a box around this compomnent, or a box that just
contains its children by returning false to isSelectable if this
components parents parent is not a RootEditPart.
Is this the architecturally correct way to do this? Is their a selection
policy or anything for the container? Anyway I can use a policy for this?
Carl
Re: Prevent Child Selection with policy? [message #97549 is a reply to message #97509] Mon, 06 October 2003 21:30 Go to previous messageGo to next message
Is this related to "grouping" above?
"CL [dnoyeB] Gilbert" <ThisisFake@Fakeness.xyz> wrote in message
news:pan.2003.10.06.20.52.22.823555@Fakeness.xyz...
> Carl
Re: Prevent Child Selection with policy? [message #97618 is a reply to message #97549] Mon, 06 October 2003 22:23 Go to previous message
Well it wasn't. This was my first method. where you basically have a
component and when you duble click it, you can edit its contents. But I
have changed to a more dynamic method of giving the user a blank slate and
letting them make the component from scratch. Then group it as a form of
'making' the component. Then double clicking will open a window that will
temporarily explode the component for editing.
So the grouping technique is a replacement of this one. But I learned a
lot about the arch with this one.
CL
>> Carl
Previous Topic:Received wrong transfer of data
Next Topic:is it impossible to create different type of connection?
Current Time: Thu Jul 17 20:09:20 EDT 2025
Powered by FUDForum. Page generated in 0.45537 seconds
