Home » Archived » Test and Performance Tools Platform (TPTP) » Can't make TPTP work on my eclipse
Can't make TPTP work on my eclipse [message #97486] Tue, 01 May 2007 12:05 Go to next message
Originally posted by: Guillaume.Bertrand.sd-partners.com
Hi!
I can't get the Profiler to run on my eclipse platform, even when I follow
the tutorial:
- I create a profiling configuration
- I add a set of classes to include in the profiling
- I run the profiler
- I can see the status bar being updated with events counts and bytes
processed...
and there, nothing appears in the log view or the graphs or anywhere else.
I can't even seem to find the view described in "select your monitor,
right-click and select Open With > Execution Flow"
am I doing something wrong here?
Thanks for your help!
Guillaume.
Re: Can't make TPTP work on my eclipse [message #97502 is a reply to message #97486] Wed, 02 May 2007 02:28 Go to previous messageGo to next message
Guillaume Bertrand wrote:
> Hi!
> follow the tutorial:
> processed...
> else. I can't even seem to find the view described in "select your
> monitor, right-click and select Open With > Execution Flow"
> Guillaume.
Guillaume,
Please provide us with the following information:
- Operating System type and version
- Architecture (32 bit, 64 bit)?
- Eclipse version
- TPTP version
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Re: Can't make TPTP work on my eclipse [message #97512 is a reply to message #97502] Wed, 02 May 2007 06:27 Go to previous messageGo to next message
Sorry, here we go:
- Windows XP 32bits
- Eclipse
** Version: 3.2.2
** Build id: M20070212-1330
- TPTP
** Monitoring Tools Project v4.2.3
** Platform Project v4.2.4
** Profiling for Web application v4.2.1
** Reporting with BIRT v4.2.0
** Testing Tools Project v4.2.4
Also, I discovered that when right-clicking on the log view, I had the
following error log generated twice:
Invalid Menu Extension (Path is invalid):
org.eclipse.tptp.symptom.internal.actions.ConfigureAnalysisA ctionDelegate
An exception stack trace is not available.
I don't know if it is related, but I though I'd mention it.
Hope this helps!
Guillaume.
Re: Can't make TPTP work on my eclipse [message #97773 is a reply to message #97512] Fri, 04 May 2007 13:36 Go to previous messageGo to next message
Originally posted by: guillaume.bertrand.wanadoo.fr
Hi there!
Anyone with an idea for my issue?
Thanks in advance.
Guillaume.
Re: Can't make TPTP work on my eclipse [message #97849 is a reply to message #97486] Sun, 06 May 2007 03:29 Go to previous messageGo to next message
> Hi!
> processed...
Is the Profiling and Logging perspective available (can be selected from
the menu: Window > Open Perspective > Other...)?
If so, switch to this perspective and open the Profiling Monitor view
(Window > Show View > Other... Profiling and Logging > Profiling Monitor).
If this view is available, you should see a node describing the
application you profile, and you can use it to open any of the relevant
analysis views as described in the documentation.
Probably not :) If the views are not available, you may have a
configuration problem. One common reason is that you didn't install the
EMF plugin. Please make sure that all prerequisites (as described in the
TPTP download page) are properly installed.
HTH,
Asaf
Asaf Yaffe
Re: Can't make TPTP work on my eclipse [message #98253 is a reply to message #97849] Tue, 08 May 2007 09:14 Go to previous message
Hi Asaf!
Unfortunately, all the views are present, but they stay empty whatever I
do (oh and EMF is present too)... however, I successfully ran TPTP on
another machine with a brand new installation of Eclipse!
I don't know what is happening with my current version of Eclipse, but I
can see what I need to do next: reinstall everything from scratch!
Thanks anyway!
Guillaume.
Previous Topic:dangling link "Analyzing logs and trace"
Next Topic:AGR - The references for two different Edit Boxes set to the same value
Current Time: Thu Jul 17 22:01:18 EDT 2025
Powered by FUDForum. Page generated in 0.72170 seconds
