Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Teneo support for QName
Teneo support for QName [message #97463] |
Tue, 25 September 2007 17:03  |
Hi Martin,
I asked about QName in a previous posting, but it seem to have disappeared
from the newsgroup as it was an older posting.
Is there any chance that Teneo will support QName in it's schema
transformation? My xsd will convert to a schema without error if I change
my element to use string instead of Qname. But QName is not really just a
string. We are following a common specification in our development that
requires us to use QName. We can't use "string"
Here's an example of what the xml may look like:
<events:name
xmlns:x="http://com.bookstore.org/pages">x:switchPage</events:name>
Where xmlns:x="http://com.bookstore.org/pages" and x:switchPage would
probably need to be stored in database or something like this.
Is there around this?
Julia
Re: Teneo support for QName [message #98457 is a reply to message #98391] |
Thu, 04 October 2007 12:57   |
--------------060204020609060703090402
Martin,
EMF will generally uses org.eclipse.emf.ecore.xml.type.internal.QName to
construct an instance corresponding to a QName value. In EMF 2.3, this
implementation extends the native QName implementation from the JDK
available only for Java 5.0 and higher:
public final class QName extends javax.xml.namespace.QName
In 2.2, it does not extend anything. As the package name implies,
this class is internal and generally should not be used outside of the
EMF implementation. XMLTypeUtil provides accessor methods for
inspecting QName instances. In EMF 2.2, such instances were surfaced in
the API as java.lang.Object since we anticipated switching to the javax
version in the future. Now its surfaced as javax.xml.Qname.
Unfortunately QName itself is immutable and our implementation relied on
being able to set the prefix during serialization (when the mapping to
the namespace is used to deduce the right prefix). So our internal
implementation still provides that support. But minus that caveat,
clients can generally just use Java QName instances...
Martin Taal wrote:
> Hi Julia,
> What I mean is when you load an xml/xmi document using an emf resource
> what class/object does EMF then use to set this efeature (is it the
> javax.xml.namespace.QName you mention below)?
> gr. Martin
> Julia wrote:
>> Hi Martin,
>> I'm not sure what you mean by what object QName is. The jdk docs
>> ( http://ws.apache.org/commons/ws-commons-java5/apidocs/javax/ xml/namespace/QName.html)
>> show that you can extract QName as a string of different parts.
>> Julia
>> <?xml version="1.0" encoding="UTF-8"?>
>> <xs:schema targetNamespace="test.xsd"
>> elementFormDefault="qualified"
>> attributeFormDefault="unqualified"
>> version="x.x.x.x"
>> xml:lang="en"
>> xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
>> xmlns:test="test.xsd"
>> xmlns:xs="http://www.w3.org/2001/XMLSchema"
>> xmlns:xlink="http://www.w3.org/1999/xlink">
>> <xs:element name="atest" type="test:mytest"/>
>> <xs:complexType name="mytest">
>> <xs:sequence>
>> <xs:element name="description" type="xs:string" />
>> <xs:element name="name" type="xs:QName" />
>> </xs:sequence>
>> </xs:complexType>
>> </schema>
>> Sample 1
>> <test:atest xmlns:test="test.xsd">
>> <test:mytest>
>> <test:description>mytestsample</test:description>
>> <test:name xmlns:x="http://com.bookstore.org">x:pages</test:name>
>> </test:mytest>
>> </test:atest>
>> Sample 2
>> <test:atest xmlns:test="test.xsd" xmlns:xx="http://ca.chapters.books">
>> <test:mytest>
>> <test:description>mytestsample2</test:description>
>> <test:name>xx:livres</test:name>
>> </test:mytest>
>> </test:atest>
<html>
<head>
http-equiv="Content-Type">
</head>
Martin,<br>
<br>
to construct an instance corresponding to a QName value.
Re: Teneo support for QName [message #98472 is a reply to message #98457] |
Thu, 04 October 2007 13:17   |
Hi Ed, thanks,
To solve this I probably need to make a specific mapping to jpox for Qname.
Julia, are you using EMF 2.2 or EMF 2.3?
gr. Martin
Ed Merks wrote:
> Martin,
> Martin Taal wrote:
>> Hi Julia,
>> gr. Martin
>> Julia wrote:
>>> Hi Martin,
>>> Julia
>>> version="x.x.x.x"
>>> xml:lang="en"
>>> <xs:sequence>
>>> </xs:sequence>
>>> </xs:complexType>
>>> </schema>
>>> Sample 1
>>> <test:mytest>
>>> </test:mytest>
>>> </test:atest>
>>> Sample 2
>>> <test:mytest>
>>> </test:mytest>
>>> </test:atest>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo support for QName [message #609818 is a reply to message #97463] |
Wed, 26 September 2007 03:49  |
Hi Julia,
Here is the old post:
http://dev.eclipse.org/newslists/news.eclipse.technology.emf t/msg02938.html
When you look at it at runtime what type of objects are used for QName, is it a String or another type?
If you have a small example (xsd plus small xml with testdata) then I can use this to solve this.
Based on this I can change the mapping logic so that Teneo will create a more precise mapping.
gr. Martin
Julia wrote:
> Hi Martin,
> disappeared from the newsgroup as it was an older posting.
> change my element to use string instead of Qname. But QName is not
> really just a string. We are following a common specification in our
> development that requires us to use QName. We can't use "string"
> <events:name
> Julia
The Netherlands
Re: Teneo support for QName [message #609876 is a reply to message #97503] |
Thu, 04 October 2007 02:43  |
Hi Martin,
Julia
version="x.x.x.x"
xml:lang="en"
<xs:sequence>
</xs:sequence>
</xs:complexType>
</schema>
Sample 1
<test:mytest>
</test:mytest>
</test:atest>
Sample 2
<test:mytest>
</test:mytest>
</test:atest>
Re: Teneo support for QName [message #609877 is a reply to message #98376] |
Thu, 04 October 2007 03:16  |
Hi Julia,
What I mean is when you load an xml/xmi document using an emf resource what class/object does EMF
then use to set this efeature (is it the javax.xml.namespace.QName you mention below)?
gr. Martin
Julia wrote:
> Hi Martin,
> Julia
> version="x.x.x.x"
> xml:lang="en"
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </schema>
> Sample 1
> <test:mytest>
> </test:mytest>
> </test:atest>
> Sample 2
> <test:mytest>
> </test:mytest>
> </test:atest>
The Netherlands
Re: Teneo support for QName [message #609886 is a reply to message #98391] |
Martin,
Martin Taal wrote:
> Hi Julia,
> gr. Martin
> Julia wrote:
>> Hi Martin,
>> Julia
>> version="x.x.x.x"
>> xml:lang="en"
>> <xs:sequence>
>> </xs:sequence>
>> </xs:complexType>
>> </schema>
>> Sample 1
>> <test:mytest>
>> </test:mytest>
>> </test:atest>
>> Sample 2
>> <test:mytest>
>> </test:mytest>
>> </test:atest>
<html>
<head>
</head>
Martin,<br>
<br>
Re: Teneo support for QName [message #609888 is a reply to message #98457] |
Hi Ed, thanks,
gr. Martin
Ed Merks wrote:
> Martin,
> Martin Taal wrote:
>> Hi Julia,
>> gr. Martin
>> Julia wrote:
>>> Hi Martin,
>>> Julia
>>> version="x.x.x.x"
>>> xml:lang="en"
>>> <xs:sequence>
>>> </xs:sequence>
>>> </xs:complexType>
>>> </schema>
>>> Sample 1
>>> <test:mytest>
>>> </test:mytest>
>>> </test:atest>
>>> Sample 2
>>> <test:mytest>
>>> </test:mytest>
>>> </test:atest>
The Netherlands
Current Time: Sun Aug 31 09:14:22 EDT 2025
Powered by FUDForum. Page generated in 0.06275 seconds
