Home » Language IDEs » Java Development Tools (JDT) » clearcase plugin
clearcase plugin [message #97405] Fri, 19 September 2003 14:12 Go to next message
Originally posted by: mkz100.msn.com
Are there clearcase plugins available for Eclipse 2.1?
Thanks.
Mike
Re: clearcase plugin [message #97420 is a reply to message #97405] Fri, 19 September 2003 14:40 Go to previous messageGo to next message
Originally posted by: robert.varga.fathomtechnology.com
The one from Rational is working with 2.1.1
Robert Varga
"Mike" <mkz100@msn.com> wrote in message news:bkfgv5$gqk$1@eclipse.org...
> Thanks.
> Mike
Re: clearcase plugin [message #98038 is a reply to message #97405] Mon, 22 September 2003 14:28 Go to previous messageGo to next message
Originally posted by: matt_conway.nospam.i2.com
If you need something that will work (mostly =) under unix, you can try
my plugin as well. It also works under windows - which is where I use
it, but it was easy enough to add unix support, so I did.
http://sf.net/projects/eclipse-ccase
Matt
> Thanks.
> Mike
Re: clearcase plugin [message #98655 is a reply to message #98038] Wed, 24 September 2003 11:17 Go to previous messageGo to next message
Originally posted by: linnet.nospam.users.sourceforge.net
And if you want to hear an "independent" user's opinion, Matt's plugin
is much better than Rational's.
Jesper
> Matt
>> Thanks.
>> Mike
Re: clearcase plugin [message #98730 is a reply to message #98655] Thu, 25 September 2003 02:52 Go to previous messageGo to next message
Originally posted by: zsolt.koppany.intland.com
and where can I find Matt's plugin?
Zsolt
"Jesper Kamstrup Linnet" <linnet@nospam.users.sourceforge.net> schrieb im
Newsbeitrag news:bkscfn$sbg$1@eclipse.org...
> Best regards,
> Jesper
> > Matt
> >> Thanks.
> >> Mike
Re: clearcase plugin [message #98772 is a reply to message #98730] Thu, 25 September 2003 04:25 Go to previous messageGo to next message
From the link contained in your post?
Darins
"Zsolt Koppany" <zsolt.koppany@intland.com> wrote in message
news:bku386$cps$1@eclipse.org...
> Zsolt
> > Best regards,
> > Jesper
try
> > > Matt
> > >> Thanks.
> > >> Mike
Re: clearcase plugin [message #99057 is a reply to message #98772] Fri, 26 September 2003 03:19 Go to previous message
Sorry and thank you,
Zsolt
"Darin Swanson" <Darin_Swanson@us.ibm.com> schrieb im Newsbeitrag
news:bku8kn$i5h$1@eclipse.org...
> Darins
> > Hi,
> > Zsolt
im
> > > Best regards,
> > > Jesper
> try
use
> > > > Matt
> > > >> Thanks.
> > > >> Mike
Previous Topic:how to disable annoying "feature" when typing in Java string?
Next Topic:This file is unreadable using UTF-8 encoding
Current Time: Sun Aug 31 05:49:24 EDT 2025
Powered by FUDForum. Page generated in 0.04911 seconds
