Home » Language IDEs » PHP Development Tools (PDT) » Use the org.eclipse.php.ui.phpWizardPages extesion point.
Use the org.eclipse.php.ui.phpWizardPages extesion point. [message #97294] Wed, 13 May 2009 14:26 Go to next message
Hi, I'm sorry if this isn't a good place to post this or ask this question
but I am having a really hard time using this extension point. The only
documentation I found is this one sentence:
PHP Wizard page must extend class org.eclipse.jface.wizard.IWizardPage.
Wizard must use PHPWizardPagesRegistry in order to retrieve all
contributed pages.
Not only is this flawed (should be implements?) but I tried this 10
different ways and I get no new wizard page showing up.
Does this feature still exist in PDT 2.0? Are there any more docs to
explain how this works? I guess I just need a push in the right direction.
Use Case: (if you care)
I want add a new page to the PHP new project wizard to allow the
configuring and setup for a php web framework. It seems like the most
simple solution to me. If you have any other recommendations on how to
achieve this I would be grateful.
Thank you for your time.
Peter
Re: Use the org.eclipse.php.ui.phpWizardPages extesion point. [message #97311 is a reply to message #97294] Thu, 14 May 2009 00:41 Go to previous messageGo to next message
Originally posted by: michael.zend.com
Hi Peter,
I don't think this extension point is used in PHP new project wizard in PDT
2.0.
"Peter D." <peterdi@gmail.com> wrote in message
news:5203f136d8753f47cd5a199f65f5e9a2$1@www.eclipse.org...
> contributed pages.
> Peter
Re: Use the org.eclipse.php.ui.phpWizardPages extesion point. [message #97326 is a reply to message #97311] Thu, 14 May 2009 08:12 Go to previous message
Thanks for the response. It's a shame. :)
Previous Topic:PDT for the Visual Editor
Next Topic:Syntax highlighting color collisions
Current Time: Fri Jul 25 01:51:06 EDT 2025
Powered by FUDForum. Page generated in 0.06851 seconds
