Home » Archived » BIRT » Reports Global Properties
Reports Global Properties [message #97242] Wed, 07 December 2005 19:17 Go to next message
I would very much like to know the following about the global report
properties (Properties at report level)
I General
1 Units are used for?
2 Resource files are used for?
3 Is there an example or explanation somewhere?
4 What are User Properties for?
5 Is there an example or explanation somewhere?
6 What are Named Expresions for?
6 Is there an example or explanation somewhere?
7 What is the Event Handler for?
8 Is there an example or explanation somewhere?
Thanks in advance for any help
Re: Reports Global Properties [message #98144 is a reply to message #97242] Fri, 09 December 2005 17:27 Go to previous message
Answers inline.
"Antonio Gurisatti" <maguri@epm.net.co> wrote in message
news:54d0d898187c399066d383c08bd6c8a4$1@www.eclipse.org...
> I General
Changes the units displayed by the ruler in the layout editor. If you set to
different units, notice that the ruler changes.
Resource files are used to localize text in a label or text element, so that
you can display the text in different languages, depending on your report
user's locale setting. The resource file contains resource key=value name
pairs. Read the "Localizing text" chapter in the BIRT online help for more
information.
User Properties are custom ROM properties that you define. You can read more
about it in the ROM spec or the "Report Object Model reference" chapter in
the BIRT online help.
I don't know much about this, but I believe Named Expressions and Event
Handler are for supporting scripting in Java (instead of JavaScript).
Previous Topic:Birt Viewer issues deployed in JBoss on Linux
Next Topic:M2 report not working in M3: visibility, formatting date with <value-of>
Current Time: Tue Jul 15 18:34:48 EDT 2025
Powered by FUDForum. Page generated in 0.03420 seconds
