Home » Archived » Test and Performance Tools Platform (TPTP) » Error: EC JPIAgent received message (FATAL ERROR): Internal error (see log file)
Error: EC JPIAgent received message (FATAL ERROR): Internal error (see log file) [message #97231] Fri, 27 April 2007 18:26 Go to next message
Originally posted by: smalunjk.stanford.edu
Hi all
1> I have eclipse 3.3M6, TPTP 4.4.0, java 1_5_09, new technology agent
controller 4.3.1, JVMTI 4.2 installed. I am trying to investigate a memory
leak of a standalone java application from within eclipse.
clicking on "test availability" button from the monitor tab(with "Java
profiling(Java 5.0 +)..." highlighted returns success.
But when i run memory analysis on the application, it seems to freeze and
after a few minutes i get this in the eclipse console:
log file).]
2> tptpParserError.log has following 2 lines added to it:
(04/27/07 14:46:10 C:\Java\newAC\bin\tptpProcessController.exe) XML Error:
Expected comment or processing instruction (error detected at line:1,
col:177, in "parseApplication()")
(04/27/07 14:46:18 C:\Java\newAC\bin\tptpProcessController.exe) XML Error:
col:1535, in "parseApplication()")
3>servicelog.log has:
<CommonBaseEvent creationTime="2007-04-27T21:50:49.828000Z"
globalInstanceId="AF4DFEEC70CD4E718142B30FA4EA428B" msg="PC
handleProcessEvents: Process has exited with status 4294967295."
severity="50" version="1.0.1">
<sourceComponentId component="ProcessController"
componentIdType="TPTPComponent" componentType="Eclipse_TPTP"
executionEnvironment=" D:\cygwin\home\build\TPTP\4.3.1\TPTP-4.3.1-200702221346\agnt ctrl\src\agents\tptpProcessController\ProcessController_md.c pp,
line 284" instanceId="101" location="LENOVO-0418C407.stanford.edu"
locationType="IPV4" processId="12144" subComponent="ProcessController"
threadId="10744"/>
<situation categoryName="ReportSituation">
<situationType reasoningScope="INTERNAL" reportCategory="LOG"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:type="ReportSituation"/>
</situation>
</CommonBaseEvent>
4>and org.eclipse.tptp.javaprofiler/log has:
Process ID: 10320
Process command line: "c:\java\jdk1.5.0_09\jre\bin\java.exe" -Xms256m
-Xmx512m
-Dlog4j.configuration=file:c:/java/workspace3.3/gateway/tran scriber-log4j.xml
-agentlib:JPIBootLoader=JPIAgent:server=controlled;HeapProf: allocsites=true
edu.stanford.irt.gateway.hl7v2.client.Hl7FileTranscriber
<PRORAMARGS_REMOVED>
Machine name: LENOVO-0418C407
Informative 04/27/07 21:50:49 5720 5 CDataManager Updated instrumentation
information for class
'sun/reflect/GeneratedSerializationConstructorAccessor1' (id = 1210)
Error 04/27/07 21:50:49 5720 0 CHeapAdaptor Found unexpected sequence of
'new' and 'invokespecial' instructions. Method
sun/reflect/GeneratedSerializationConstructorAccessor1.newIn stance(([Ljava/lang/Object;)Ljava/lang/Object;)
5> I noticed that Asaf,Guru and all have been very helpful. I would appreciate
any help on this issue. Let me know what I missed here.
Thanks in advance and let me know for additional info.
Sanjay Malunjkar
Re: Error: EC JPIAgent received message (FATAL ERROR): Internal error (see log file) [message #97289 is a reply to message #97231] Sun, 29 April 2007 02:04 Go to previous messageGo to next message
Sanjay,
Thanks for the report. It seems that you have found a new
instrumentation issue with the Heap Profiler. Is it possible for you to
post a small Java application that can be used for reproducing this
behavior?
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
sanjay malunjkar wrote:
> Hi all
> memory leak of a standalone java application from within eclipse.
> and after a few minutes i get this in the eclipse console:
> log file).]
> Error: Expected comment or processing instruction (error detected at
> line:1, col:177, in "parseApplication()")
> line:1, col:1535, in "parseApplication()")
> threadId="10744"/>
> </situation>
> </CommonBaseEvent>
> Process ID: 10320
> -Xmx512m
> Updated instrumentation information for class
> unexpected sequence of 'new' and 'invokespecial' instructions. Method
> appreciate any help on this issue. Let me know what I missed here.
> Sanjay Malunjkar
Re: Error: EC JPIAgent received message (FATAL ERROR): Internal error (see log file) [message #97304 is a reply to message #97289] Sun, 29 April 2007 04:44 Go to previous messageGo to next message
I was able to reproduce this problem. I will open a Bugzilla and add
your in the CC list so you can track our progress.
Thanks again for reporting this issue.
Asaf
Asaf Yaffe
Re: Error: EC JPIAgent received message (FATAL ERROR): Internal error (see log file) [message #97317 is a reply to message #97304] Sun, 29 April 2007 04:56 Go to previous messageGo to next message
Please see here for more details:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=184618
Feel free to add yourself to the CC list.
Asaf
Asaf Yaffe
Re: Error: EC JPIAgent received message (FATAL ERROR): Internal error (see log file) [message #97374 is a reply to message #97317] Mon, 30 April 2007 12:23 Go to previous messageGo to next message
Asaf
thanks for the response. I was unable to add myself to the cc list.can u
help?
also, when is the i4 release going to be available?
thanks
sanjay
Re: Error: EC JPIAgent received message (FATAL ERROR): Internal error (see log file) [message #97417 is a reply to message #97374] Tue, 01 May 2007 02:29 Go to previous message
Sanjay,
I tried to add you to the CC list and failed. I think you must create a
Bugzilla account in bugs.eclipse.org before you can add yourself to the
CC list of a bug.
The bug you reported was fixed. The fix will be included in the next
"dev" build of the Agent Controller as well as in the 4.4.i3 candidate
build (expected by end of this week). If you can't wait, you can
check-out the source code of the org.eclipse.tptp.platform.jvmti.runtime
component and build the Profiler Runtime files. CVS access procedures
are available here:
http://dev.eclipse.org/viewcvs/index.cgi/?root=TPTP_Project
TPTP 4.4 GA is expected in June, as part of Eclipse 3.3.
HTH,
Asaf
Asaf Yaffe
Previous Topic:who can tell me how to monitor the HPUX machine, thanks!
Next Topic:determining target vm vendor + version before launching an application
Current Time: Sun Aug 31 06:10:57 EDT 2025
Powered by FUDForum. Page generated in 0.03462 seconds
