Home » Archived » Service Component Architecture (SCA) Tools » Extending the SCA Meta Model
Extending the SCA Meta Model [message #8826] Thu, 04 June 2009 11:25 Go to next message
Hi All,
I'm trying to extend the SCA meta model by adding a new implementation
type (currently an implementation.osgi element specific for the OW2
FraSCAti platform).
My extension integrates with the core sca metal model, but I still have
an issue with meta object id, when generating java code for this model.
The meta object id value for my OsgiPackage.OSGI_IMPLEMENTATION is set
to "1" which is in conflict with existing
FrascatiPackage.FRACTAL_IMPLEMENTATION
Following FraSCAti and Tuscany model extension, meta objects ids seem
to be unique
Thus, does anyone knows how to generate java code from a model extension
without having conflict with meta object ids
Damien
Re: Extending the SCA Meta Model [message #8831 is a reply to message #8826] Fri, 05 June 2009 05:42 Go to previous messageGo to next message
Hi Damien,
Meta object Id values can be the same for different meta models.
Could you clarify how are you doing to add the OSGi type?
If your OSGi type is defined in a new meta model (plugin), this meta
model can't reuse the FraSCAti namespace.
If you want to use the FraSCAti namespace, you must add the OSGi
implementation type directly in the FraSCAti meta model and then
regenerate the code.
Stéphane
Damien Fournier a écrit :
> Hi All,
> FraSCAti platform).
> to be unique
> Thanks
> Damien
Re: Extending the SCA Meta Model [message #8976 is a reply to message #8831] Tue, 09 June 2009 04:57 Go to previous messageGo to next message
Hi Stéphane,
Stephane Drapeau a écrit :
> Hi Damien,
Following the sca model extension guide, I've extended the SCA model
with an osgi implementation in a new Ecore model.
This implementation has an EAttribute named "bundle". I've also added a
DocumentRoot (EObject) which
has an EReference on the "OsgiImplmentation" (as explained in the
extension guide)
Ecore and genmodel files are accessible at
http://svn.forge.objectweb.org/cgi-bin/viewcvs.cgi/frascati/ trunk/assembly-factory/model/org.ow2.frascati.model.osgi/mod el/
This metal model has a different namespace of existing FraSCAti meta
model (http://frascati.ow2.org/osgi).
If Meta object Id values can be the same for different SCA model
extensions, then how to make distinction between
two different implementations or bindings ? For instance when calling
getImplementation() on a SCA Component, how
to know if this component is implemented with java, spring, bpel, etc ?
Damien
> Stéphane
>> Hi All,
>> implementation type (currently an implementation.osgi element
>> specific for the OW2 FraSCAti platform).
>> set to "1" which is in conflict with existing
>> to be unique
>> extension without having conflict with meta object ids
>> Thanks
>> Damien
Re: Extending the SCA Meta Model [message #8995 is a reply to message #8976] Tue, 09 June 2009 05:07 Go to previous messageGo to next message
> Hi Stéphane,
>> Hi Damien,
> extension guide)
You can use instanceof
if(component.getImplementation() instanceof JavaImplementation) {
} else if (component.getImplementation() instanceof OSGiImplementation) {
cheers!
Stephane Drapeau
Obeo
Re: Extending the SCA Meta Model [message #9015 is a reply to message #8995] Tue, 09 June 2009 10:54 Go to previous messageGo to next message
>> Hi Stéphane,
>>> Hi Damien,
>> a DocumentRoot (EObject) which
>> extension guide)
Hi Stephane,
Right
> cheers!
> Stephane Drapeau
> Obeo
But
What about the doSwitch() method provided by FrascatiSwitch or
TuscanySwitch class (Obtained when generating model code)?
Since the generated doSwitch() call the caseXXX method according to meta
object id.
Does this means that the doSwitch() cannot be used when having ecore
model extensions ?
Whatever, I can use class name instead of meta object ids
Thanks for help
Damien
Re: Extending the SCA Meta Model [message #9034 is a reply to message #9015] Tue, 09 June 2009 13:56 Go to previous message
> But
> object id.
If you have a look to the public and the first protected doSwitch()
methods, you can see that
the EContainer of
the EClass of
the theEObject parameter
(of the doSwitch() method that contains the switch statement)
is the model package of the Switch class.
> model extensions ?
No. For example, the public doSwitch method is used in the
FrascatiItemProvider.
> Thanks for help
> Damien
Stephane Drapeau
Obeo
Re: Extending the SCA Meta Model [message #575203 is a reply to message #8826] Fri, 05 June 2009 05:42 Go to previous message
Hi Damien,
Stéphane
> Hi All,
> FraSCAti platform).
> to be unique
> Thanks
> Damien
Re: Extending the SCA Meta Model [message #575307 is a reply to message #8831] Tue, 09 June 2009 04:57 Go to previous message
Hi Stéphane,
> Hi Damien,
extension guide)
Damien
> Stéphane
>> Hi All,
>> to be unique
>> Thanks
>> Damien
Re: Extending the SCA Meta Model [message #575326 is a reply to message #8976] Tue, 09 June 2009 05:07 Go to previous message
> Hi Stéphane,
>> Hi Damien,
> extension guide)
cheers!
Stephane Drapeau
Obeo
Re: Extending the SCA Meta Model [message #575341 is a reply to message #8995] Tue, 09 June 2009 10:54 Go to previous message
>> Hi Stéphane,
>>> Hi Damien,
>> extension guide)
Hi Stephane,
Right
> cheers!
> Stephane Drapeau
> Obeo
But
object id.
model extensions ?
Thanks for help
Damien
Re: Extending the SCA Meta Model [message #575354 is a reply to message #9015] Tue, 09 June 2009 13:56 Go to previous message
> But
> object id.
the EContainer of
the EClass of
> model extensions ?
> Thanks for help
> Damien
Stephane Drapeau
Obeo
Previous Topic:How to instal SOA Tool
Next Topic:[Announce] SCA Tools 2.0.0 releases with Galileo!
Current Time: Sat Aug 30 19:27:52 EDT 2025
Powered by FUDForum. Page generated in 0.06679 seconds
