Home » Archived » BIRT » tutorials or examples for using XML data source
tutorials or examples for using XML data source [message #97118] Wed, 07 December 2005 12:36 Go to next message
I played with the BIRT 2.0 M3 milestone build, and noticed that XML data
source showed up as a possible selection for creating a new data source.
Are there any tutorials or examples available for this?
With my toy XML file, I was able to set up a new data source, but was unable
to set up a data set (the row and column mappings) properly to produce
correct preview results in the Edit Data Set dialog.
-- Cheng-Yee
Re: tutorials or examples for using XML data source [message #97578 is a reply to message #97118] Thu, 08 December 2005 13:11 Go to previous messageGo to next message
Cheng-Yee,
We will be updating the web site with examples showing the 2.0 features
closer to final date.
Here is an example report the development team sent me for the XML driver.
Jason Weathersby
BIRT PMC
"Cheng-Yee Lin" <clin@us.ibm.com> wrote in message
news:dn76j3$sus$1@news.eclipse.org...
> unable
> -- Cheng-Yee
  • Attachment: xmlfiles.zip
    (Size: 3.00KB, Downloaded 99 times)
Re: tutorials or examples for using XML data source [message #97995 is a reply to message #97578] Fri, 09 December 2005 11:51 Go to previous messageGo to next message
Thanks, Jason.
-- Cheng-Yee
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:dn9t11$kij$1@news.eclipse.org...
> Cheng-Yee,
> Jason Weathersby
> BIRT PMC
> > unable
> > Thanks,
> > -- Cheng-Yee
Re: tutorials or examples for using XML data source [message #98040 is a reply to message #97118] Fri, 09 December 2005 13:26 Go to previous messageGo to next message
Do you know if it is possible to design a report using a xml file and then
at runtime stream in xml into the report for it to render?
Marty
> unable
> -- Cheng-Yee
Re: tutorials or examples for using XML data source [message #104734 is a reply to message #98040] Thu, 05 January 2006 05:28 Go to previous message
> Marty
>>unable
>>Thanks,
>>-- Cheng-Yee
Hi Marty,
At this moment it is not possible to stream xml into it. I've looked at
it and it does not accept URLs as file argument. I've made a sample
reports on plants.xml. I can send that one to you if you like. Contact
me outside the newsgroup for it.
Greetings, Jan.
Previous Topic:ERROR- to view the report
Next Topic:How to implement Stacked Area Charts?
Current Time: Thu Jul 17 20:47:41 EDT 2025
Powered by FUDForum. Page generated in 0.27099 seconds
