tutorials or examples for using XML data source [message #97118] |
Wed, 07 December 2005 12:36  |
I played with the BIRT 2.0 M3 milestone build, and noticed that XML data
source showed up as a possible selection for creating a new data source.
Are there any tutorials or examples available for this?
With my toy XML file, I was able to set up a new data source, but was unable
to set up a data set (the row and column mappings) properly to produce
correct preview results in the Edit Data Set dialog.
-- Cheng-Yee
Re: tutorials or examples for using XML data source [message #104734 is a reply to message #98040] |
Thu, 05 January 2006 05:28  |
Originally posted by: jan.tanis.coas.com
Marty Jones wrote:
> Do you know if it is possible to design a report using a xml file and then
> at runtime stream in xml into the report for it to render?
> Marty
> "Cheng-Yee Lin" <clin@us.ibm.com> wrote in message
> news:dn76j3$sus$1@news.eclipse.org...
>>unable
>>Thanks,
>>-- Cheng-Yee
Hi Marty,
At this moment it is not possible to stream xml into it. I've looked at
it and it does not accept URLs as file argument. I've made a sample
reports on plants.xml. I can send that one to you if you like. Contact
me outside the newsgroup for it.
Greetings, Jan.
FUDForum. Page generated in 0.08902 seconds
