Home » Archived » BIRT » RCP + BIRT Chart
RCP + BIRT Chart [message #96948] Wed, 07 December 2005 05:40 Go to next message
Originally posted by: alfileres.gmail.com
Hi All,
I'm writing an RCP application where one ViewPart will show a BIRT Chart
containing time series for the selected data. The data the application is
handling is in the form (datetime, real value)
As X axis I'm using DATE_TIME_LITERAL (with DateTimeDataSet)
As Y axis I'm using LINEAR_LITERAL (with NumberDataSet)
I need to create the chart once and get it updated everytime the data
changes. By this way the performance of the application can be improved.
I got a ChartException in rendering the Chart (see it at the end of the
message). Do you know what may be going wrong?
Maybe it is easier if you can point me to a snippet with a similar
fuctionality.
Thank you in advance,
Jose.
SEVERE: Exception
org.eclipse.birt.chart.exception.ChartException: Lines may not be rendered
on a value scale
at org.eclipse.birt.chart.render.Line.renderSeries(Line.java:10 0)
org.eclipse.birt.chart.render.AxesRenderer.renderPlot(AxesRe nderer.java:1196)
org.eclipse.birt.chart.render.AxesRenderer.render(AxesRender er.java:256)
at org.eclipse.birt.chart.factory.Generator.render(Generator.ja va:522)
rcptest.view.BIRTView$BIRTViewPaintListener.paintControl(BIR TView.java:93)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:83)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:852)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:11 53)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3090 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3706 )
at org.eclipse.swt.internal.win32.OS.UpdateWindow(Native Method)
at org.eclipse.swt.widgets.Decorations.setVisible(Decorations.j ava:1391)
at org.eclipse.swt.widgets.Shell.setVisible(Shell.java:1300)
at org.eclipse.swt.widgets.Shell.open(Shell.java:827)
at org.eclipse.jface.window.Window.open(Window.java:783)
at org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow .java:700)
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:677)
org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1282)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1223)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:190)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:706)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1034)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1636)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at rcptest.Application.run(Application.java:18)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: RCP + BIRT Chart [message #97088 is a reply to message #96948] Wed, 07 December 2005 10:58 Go to previous message
Hi Jose,
Did you set your X Axis as a category Axis?
David
"Jose" <alfileres@gmail.com> wrote in message
news:26a5cd3cb65091b7379180546842a127$1@www.eclipse.org...
> Hi All,
> As X axis I'm using DATE_TIME_LITERAL (with DateTimeDataSet) As Y axis I'm
> fuctionality.
> Jose.
> SEVERE: Exception
> on a value scale
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:bi-lingual reports?
Next Topic:Report outputs from BIRT
Current Time: Sun Aug 31 13:45:25 EDT 2025
Powered by FUDForum. Page generated in 0.04906 seconds
