Home » Language IDEs » Java Development Tools (JDT) » fabulous tool
fabulous tool [message #96923] Thu, 18 September 2003 17:48 Go to next message
Originally posted by: paul.moore06.ca.com
Can I just say what a great tool eclipse is! So many cool little nice
things in it - I suspect it will be the vi of 21st century - everytime you
watch somebody use it you learn something new. Glad that there is a tips
and tricks section in the help
After having used it for a bit I have a few requests
- square cut copy and paste (alt drag in vs.net)
- a decent regex aware search and replace (like vs.net)
- a simple find in files (I cant understand the current search at all)
- file>open (the whole project based, dont worry about the file system
thing gets a lot of getting used to)
- shortcut key for last ant build
- quick fix (cool or what) on the right click menu when pointing at an
error
For the regex replace and 'find in files' I run with vs.net open as well
as eclipse
Re: fabulous tool [message #96939 is a reply to message #96923] Thu, 18 September 2003 19:31 Go to previous messageGo to next message
Do you actually use this a lot? Are you using it for copying data values or
what? I'm an old slick edit user so I do understand it has its uses, but it
always seems so spreadsheet to me.
There's always grep from the shell. What do you find confusing about it?
There's a semantically aware search which allows you to search on refs,
declarations, etc. Are you having issues with the scoping choices?
There are a couple of plugins which add a file->open option if that's your
bag. What do you want this for? Are you doing scratch work ... just use a
Scrapbook page.
I thought you could put a key combo on Run Last Launched External Tool in
the prefs... someone correct me if I'm wrong.
> error
Clicking on the lightbulb doesn't do it for you, eh?
Randy
Re: fabulous tool [message #96946 is a reply to message #96939] Thu, 18 September 2003 19:37 Go to previous messageGo to next message
You can but you cannot assign for the last Ant build.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=40803
HTH
Darins
Re: fabulous tool [message #96952 is a reply to message #96939] Thu, 18 September 2003 20:09 Go to previous messageGo to next message
I use it once a month or so for miscellaneous things - when I use it its
really useful, given the number of little twiddles in the eclipse editor
this doesnt seem like a big ask. I just want to dump vs.net
no grep in windows. The current search has the same fixation on files in
the workspace as the whol UI has, I cant just say ' look in c:\foo\bar'
Say I know that I saw something somewhere is the source of xx, I want to
find it, look at it, and then cut and paste from it. THis seems like a
reasonable thing to ask. And you cant do it in eclipse
> > error
The vi effect in action for these 2 (although I dont think of ant as an
'external tool' so this is why I didnt find the option), you know things
that I dont :-) Thanks
Re: fabulous tool [message #97099 is a reply to message #96923] Fri, 19 September 2003 00:23 Go to previous messageGo to next message
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
"Paul Moore" <paul.moore06@ca.com> wrote in message
news:bkd97u$e8b$1@eclipse.org...
Select Search > File Search (or press Ctrl-H and make sure the File Search
tab is selected). This can do a textual search of every file in your
workspace or project or working set. It will be slower than the Java indexed
searches of course. BTW, newer 3.0 builds have a regular expression checkbox
you can turn on.
Also look at www.cygwin.com if you need a grep on Windows. Also Windows
Exporer has a find in files capability.
For global replaces, honestly I think once you get hooked on Eclipse's
refactoring you will rarely want to do that. Still it would be good to have
just in case so open a bugzilla or vote for one if it's already there..
Navigate > Open Resource (or Ctrl-Shift-R). Start typing a filename to
narrow down the list.
Window > Preferences > Workbench > Keys. Pick category: Run, name: Run Last
Launched External Tool. Under Key Sequence click in the Name field, and
press the key sequence of your choice (I suggest Ctrl-Shift-F11). Click Add.
OK.
> error
Save the file. Open the Problems view (Tasks in 2.1), right click on the
error message, and there should be a Quick Fix menu item. If it's grayed out
then no Quick Fix is available, thanks for playing.
Or click on the offending code in the editor and press Ctrl-1 (that's a
number one).
Or double-click on the lightbulb.
> as eclipse
Ed Burnette, co-author Eclipse in Action (www.manning.com/gallardo)
Re: fabulous tool [message #97290 is a reply to message #96952] Fri, 19 September 2003 10:58 Go to previous messageGo to next message
In article <bkdhgc$l8r$1@eclipse.org>, paul.moore06@ca.com says...
Two notes here:
1) see cygwin tools if you like *nix-like command-line tools.
2) In eclipse you can narrow the search to a "working set" which can be
a subproject (directory) or several subprojects/projects together.
Hope this helps,
-- Scott
Scott Stanchfield scott@javadude.com http://javadude.com
I haven't gotten *any* spam since joining http://knowspam.net!
Lead author of "Effective VisualAge for Java, Version 3"
http://javadude.com/evaj
Visit for Java Enlightenment! http://www.jguru.com
Re: fabulous tool [message #99955 is a reply to message #96923] Tue, 30 September 2003 08:21 Go to previous message
Originally posted by: tim.tt1lock.org
> things in it - I suspect it will be the vi of 21st century [...]
Yes - that sounds about right to me ;-)
__________
|im |yler http://timtyler.org/ tim@tt1lock.org Remove lock to reply.
Previous Topic:Ctrl+TAB
Next Topic:Getting the real object out of IStructuredSelection resp. IJavaVariable
Current Time: Mon Nov 17 04:47:59 EST 2025
Powered by FUDForum. Page generated in 0.06316 seconds
