Home » Eclipse Projects » Equinox » Problem with http.jetty and static content...
Problem with http.jetty and static content... [message #96804] |
Mon, 10 September 2007 03:18 |
Originally posted by: kitplummer.gmail.com
I'm following the instructions for embedded HTTP into Equinox for static
content here:
http://www.eclipse.org/equinox/server/http_in_equinox.php
http://www.eclipse.org/equinox/server/http_writing_applicati on.php
A couple of problems. Jetty by defaults tries to use port 80. I've changed
this by setting a VM argument in the Run configuration:
-Dorg.eclipse.equinox.http.jetty.http.port=8080
Now, the framework seems to launch the server successfully:
osgi> Sep 9, 2007 7:56:15 AM org.mortbay.http.HttpServer doStart
INFO:
Version Jetty/5.1.x
Sep 9, 2007 7:56:15 AM org.mortbay.util.Container
start
INFO: Started org.mortbay.jetty.servlet.ServletHandler@def14f
Sep 9,
2007 7:56:15 AM org.mortbay.util.Container start
INFO: Started
HttpContext[/,/]
Sep 9, 2007 7:56:15 AM org.mortbay.http.SocketListener
start
INFO: Started SocketListener on 0.0.0.0:8080
INFO: Started
org.mortbay.http.HttpServer@aca5e2
But, my test bundle doesn't work. I get:
HTTP ERROR: 404
ProxyServlet: /files/index.html
RequestURI=/files/index.html
Powered by Jetty://
Here's the 'ss':
osgi> ss
Framework is launched.
id State Bundle
0 ACTIVE
org.eclipse.osgi_3.3.0.v20070530
977 ACTIVE
org.mortbay.jetty_5.1.11.v200706111724
978 ACTIVE
org.eclipse.equinox.http.jetty_1.0.0.v20070607
979 ACTIVE
org.apache.commons.logging_1.0.4.v200706111724
980 ACTIVE
org.eclipse.osgi.services_3.1.200.v20070605
981 ACTIVE
org.eclipse.equinox.http.servlet_1.0.0.v20070606
982 ACTIVE
javax.servlet_2.4.0.v200706111738
983 ACTIVE
org.eclipse.equinox.registry_3.3.0.v20070522
984 ACTIVE
org.eclipse.equinox.common_3.3.0.v20070426
986 ACTIVE
org.eclipse.equinox.http.registry_1.0.0.v20070608
991 ACTIVE
org.rvooz.http.testapp_0.1.0
osgi>
Any ideas? I'm following the directions verbatim, save for the package name
of the bundle - which probably shouldn't matter.
TIA,
Kit
Re: Problem with http.jetty and static content... [message #96820 is a reply to message #96804] |
Mon, 10 September 2007 05:32 |
Simon Kaegi Messages: 381 Registered: July 2009 |
Hmm... that looks fine.
Can you zip up your project and attach it. (e.g. export->archive).
-Simon
"Kit Plummer" <kitplummer@gmail.com> wrote in message
news:C30A0589.565%kitplummer@gmail.com...
> content here:
> changed
> INFO:
> Version Jetty/5.1.x
> start
> Sep 9,
> INFO: Started
> HttpContext[/,/]
> start
> INFO: Started
> HTTP ERROR: 404
> Powered by Jetty://
> Here's the 'ss':
> osgi> ss
> id State Bundle
> 0 ACTIVE
> 977 ACTIVE
> 978 ACTIVE
> 979 ACTIVE
> 980 ACTIVE
> 981 ACTIVE
> 982 ACTIVE
> 983 ACTIVE
> 984 ACTIVE
> 986 ACTIVE
> 991 ACTIVE
> osgi>
> name
> TIA,
> Kit
Re: Problem with http.jetty and static content... [message #96892 is a reply to message #96820] |
Mon, 10 September 2007 13:18 |
> This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
--B_3272249925_3686509
Content-type: text/plain;
charset="US-ASCII"
Content-transfer-encoding: 7bit
Attached. Thanks Simon...I'm just not seeing anything that doesn't make
sense. Maybe Jetty version?
On 9/9/07 10:32 PM, in article fc2kte$vpb$1@build.eclipse.org, "Simon Kaegi"
> -Simon
>> content here:
>> changed
>> INFO:
>> Version Jetty/5.1.x
>> start
>> Sep 9,
>> INFO: Started
>> HttpContext[/,/]
>> start
>> INFO: Started
>> HTTP ERROR: 404
>> Powered by Jetty://
>> Here's the 'ss':
>> osgi> ss
>> id State Bundle
>> 0 ACTIVE
>> 977 ACTIVE
>> 978 ACTIVE
>> 979 ACTIVE
>> 980 ACTIVE
>> 981 ACTIVE
>> 982 ACTIVE
>> 983 ACTIVE
>> 984 ACTIVE
>> 986 ACTIVE
>> 991 ACTIVE
>> osgi>
>> name
>> TIA,
>> Kit
Content-type: application/octet-stream; name="http.testapp.zip"
Content-disposition: attachment;
filename="http.testapp.zip"
Content-transfer-encoding: base64
UEsDBBQACAAIAOsxKjcAAAAAAAAAAAAAAAAhAAAAb3JnLnJ2b296Lmh0dHAu dGVzdGFwcC8u
Y2xhc3NwYXRolY/LCsIwEEXX9itC9qa6c9EHIhV0UaXUtdRkaKNxEvMQ/Xst UnSj4G7u5XAu
k+S3syJXsE5qTOmUTSgB5FpIbFO6q5fjGc2zKOGqcc40vsui0TsAensnJ4ki pc5ySvrydcZf
Qa5xALVtGXAljQN2FJ6pJiDvntNsXRX7xaas56uyqP6XGQGMawvMwiVIC2Kr QivR/TDp4E3w
g+wgsWeT+OPxB1BLBwg/HFeoowAAACwBAABQSwMEFAAIAAgA6zEqNwAAAAAA AAAAAAAAAB8A
AABvcmcucnZvb3ouaHR0cC50ZXN0YXBwLy5wcm9qZWN0vZLdSgMxEIWv7VOU vTexd71It6Di
XUWoPkBMxm3K5ofJ7FL69J39aelWBEHw7pyZM/lIJmp98PW8BcwuhlWxEA/F HIKJ1oVqVXy8
v9wvi3U5UwnjHgw9QzboEnG4nN2poD2UESuBbYxHsSNKgiCTTknJvskhE72H QKWSZ8XF8bzc
aXltPhtX220Cw2Z0Tzymg+0KV0gwtUsZxN6SMBFZ6Fb3ecALnAc0Vk1HzYOV E6/kLeE3yGRB
bHRwX3zVx38jbs0OvP4zbyyMT8woahCG6KC/gd/qpnLhtW923D70Q36yjXA7 cpaMu2x98qVO
UEsHCLMyXMftAAAAjwIAAFBLAwQUAAgACADrMSo3AAAAAAAAAAAAAAAAOwAA AG9yZy5ydm9v
ei5odHRwLnRlc3RhcHAvLnNldHRpbmdzL29yZy5lY2xpcHNlLnBkZS5jb3Jl LnByZWZzFclB
CsIwEAXQfU4RcB9isSiFHEEQ0gvU+CuRYRJnkuLxW5ePd4pLsxHV+psd/DRe pmG09zgf8FeD
RLkqXBWsEHCCug2iuXA4m0r9nfkh5YPUHH4N/B8NTTqMQAttcIJvz4Jn5xch rAspzA5QSwcI
hfofj2sAAAB2AAAAUEsDBBQACAAIAOsxKjcAAAAAAAAAAAAAAAArAAAAb3Jn LnJ2b296Lmh0
dHAudGVzdGFwcC9NRVRBLUlORi9NQU5JRkVTVC5NRnWOvQ6CMBSFd56CuPcG dMMwaOJgIoYE
416x1IbS29xeMPr0EhE21/Odv0I606jA4qooGHRZnEIS7Xt3t0oUP7iw9UzO slNZfBmZ9D4u
ba+FcTOsXt0NraknE5IGGhDf8GD2wFNmG4zTVvHYmjP1as4uUwmks7ar2QyS kf6VweKIjp1H
YlHKupX6t45BG2hofPNEarfDNJGvUthAsooOtTU+KHGS71fFkjiLv48+UEsH CHnJhfetAAAA
GwEAAFBLAwQUAAgACADrMSo3AAAAAAAAAAAAAAAAQQAAAG9yZy5ydm9vei5o dHRwLnRlc3Rh
cHAvYmluL29yZy9ydm9vei9odHRwL3Rlc3RhcHAvQWN0aXZhdG9yLmNsYXNz lVE9TwJBEH0L
x50iiAJ+VmpighZuLKwwJkq0Ilpo6JdjhcXj9rK3IPFfWZlY+AP8Uca5AzEx UWKx8z1v3sy+
f7y+ATjGtocMw442XW5GWj/xnrURtzK2Ior4uW/VSFhtPDgMK30xEjwQYZff tPvStx5chr2k
V8ddxe+NGMhHbR74xTDsBHLWzeCeqlDZM4Zs7aDF4DR0R+aRxVIBHhYYSk0V yuvhoC3NnWgH
kqHc1L4IWsKoxJ8GHdtTMY1szuNbZ8hRyFiG/VrzV4YNHVo5tvWEU/5y7MvI Kh3GHqoMle9t
ZxkGz5+0fJH4E5YIx1ZHhH2rh8aXVypZYnnG8igZgV3QWejl6EMSTQchuUge J81I5w5fkH8m
I4MCSTcNuiiSLEwKsIwSafojrFJVmWyHvEoKc5J2UvYnRDGFWJ8kpxCJtUax ZPLGf8Cqc8A2
0/qtT1BLBwidaHoXUQEAAHoCAABQSwMEFAAIAAgA6zEqNwAAAAAAAAAAAAAA AC8AAABvcmcu
cnZvb3ouaHR0cC50ZXN0YXBwL2Jpbi93ZWJfZmlsZXMvaW5kZXguaHRtbCtJ LS7JzEtXyM9L
1VEoKc8HEhlFqal6AFBLBwjHePnyGAAAABgAAABQSwMEFAAIAAgA6zEqNwAA AAAAAAAAAAAA
ACcAAABvcmcucnZvb3ouaHR0cC50ZXN0YXBwL2J1aWxkLnByb3BlcnRpZXMr zi8tSk7V01Ow
VSguStbnyi8tKSgtAfOTMvP0uYCEXmZeck5pSmoxUMzXNcRR19PPTV8nhksB FehhChXklKYD
9Vfk5mDKgWwrT02KT8vMSS3W5wIAUEsHCL2ed9pVAAAAiAAAAFBLAwQUAAgA CADrMSo3AAAA
AAAAAAAAAAAAIQAAAG9yZy5ydm9vei5odHRwLnRlc3RhcHAvcGx1Z2luLnht bEWOvRLCIBCE
+zwFQx/iT2MBSecTaO2QeOLNkAOBaHx7SUz0qr399m5WNmNv2RNCREeKb8WG M6DOXZGM4ufT
sTzwpi5kA51FH+Ef3YvdTLwdDFIWMCagiTHvkJLiLhixnAl4DEhuFPeUvAhg MKbwziK6IXQQ
eV2wPHI15o0xbVFHxasb2pxZzFZHKEn3kMEL2ssXVtMHWf1K5ELVWu0DUEsH CF7a8xKeAAAA
5QAAAFBLAwQUAAgACADrMSo3AAAAAAAAAAAAAAAAQAAAAG9yZy5ydm9vei5o dHRwLnRlc3Rh
cHAvc3JjL29yZy9ydm9vei9odHRwL3Rlc3RhcHAvQWN0aXZhdG9yLmphdmGt j00OgjAQhdf0
FJO4URLLAdj4EzfeopYRGqDTtAMYjXe3QWOiG9S4nffel2+c0rUqEciX0vdE Z1kxO8kYWDmX
C2FaR57HnEJp5NGrFgfytdx0tmhwrdn0isnnk9UtWcYTR6jrDo3RoBsVAjwJ EAENtmg5wBsc
LkIkWSoSSGFuyS73qlcF6cV4WQXEDwxn8SfP8ym/kZmJ5CHZkyngvnypgX7U gStPQ4DdSaNj
QzbKJtf/+JL7UTcOv7O9ihtQSwcIa4OZkL0AAAALAgAAUEsDBBQACAAIAOsx KjcAAAAAAAAA
AAAAAAAvAAAAb3JnLnJ2b296Lmh0dHAudGVzdGFwcC9zcmMvd2ViX2ZpbGVz L2luZGV4Lmh0
bWwrSS0uycxLV8jPS9VRKCnPBxIZRampegBQSwcIx3j58hgAAAAYAAAAUEsB AhQAFAAIAAgA
6zEqNz8cV6ijAAAALAEAACEAAAAAAAAAAAAAAAAAAAAAAG9yZy5ydm9vei5o dHRwLnRlc3Rh
cHAvLmNsYXNzcGF0aFBLAQIUABQACAAIAOsxKjezMlzH7QAAAI8CAAAfAAAA AAAAAAAAAAAA
APIAAABvcmcucnZvb3ouaHR0cC50ZXN0YXBwLy5wcm9qZWN0UEsBAhQAFAAI AAgA6zEqN4X6
H49rAAAAdgAAADsAAAAAAAAAAAAAAAAALAIAAG9yZy5ydm9vei5odHRwLnRl c3RhcHAvLnNl
dHRpbmdzL29yZy5lY2xpcHNlLnBkZS5jb3JlLnByZWZzUEsBAhQAFAAIAAgA 6zEqN3nJhfet
AAAAGwEAACsAAAAAAAAAAAAAAAAAAAMAAG9yZy5ydm9vei5odHRwLnRlc3Rh cHAvTUVUQS1J
TkYvTUFOSUZFU1QuTUZQSwECFAAUAAgACADrMSo3nWh6F1EBAAB6AgAAQQAA AAAAAAAAAAAA
AAAGBAAAb3JnLnJ2b296Lmh0dHAudGVzdGFwcC9iaW4vb3JnL3J2b296L2h0 dHAvdGVzdGFw
cC9BY3RpdmF0b3IuY2xhc3NQSwECFAAUAAgACADrMSo3x3j58hgAAAAYAAAA LwAAAAAAAAAA
AAAAAADGBQAAb3JnLnJ2b296Lmh0dHAudGVzdGFwcC9iaW4vd2ViX2ZpbGVz L2luZGV4Lmh0
bWxQSwECFAAUAAgACADrMSo3vZ532lUAAACIAAAAJwAAAAAAAAAAAAAAAAA7 BgAAb3JnLnJ2
b296Lmh0dHAudGVzdGFwcC9idWlsZC5wcm9wZXJ0aWVzUEsBAhQAFAAIAAgA 6zEqN17a8xKe
AAAA5QAAACEAAAAAAAAAAAAAAAAA5QYAAG9yZy5ydm9vei5odHRwLnRlc3Rh cHAvcGx1Z2lu
LnhtbFBLAQIUABQACAAIAOsxKjdrg5mQvQAAAAsCAABAAAAAAAAAAAAAAAAA ANIHAABvcmcu
cnZvb3ouaHR0cC50ZXN0YXBwL3NyYy9vcmcvcnZvb3ovaHR0cC90ZXN0YXBw L0FjdGl2YXRv
ci5qYXZhUEsBAhQAFAAIAAgA6zEqN8d4+fIYAAAAGAAAAC8AAAAAAAAAAAAA AAAA/QgAAG9y
Zy5ydm9vei5odHRwLnRlc3RhcHAvc3JjL3dlYl9maWxlcy9pbmRleC5odG1s UEsFBgAAAAAK
AAoAmQMAAHIJAAAAAA==
--B_3272249925_3686509--
Re: Problem with http.jetty and static content... [message #96902 is a reply to message #96892] |
Mon, 10 September 2007 14:51 |
Hi Kit,
The web_files directory should just sit at the root of the directory instead
of inside /src.
I've done a quick update to a structure I would suggest.
-Simon
news:C30A9244.579%kitplummer@gmail.com...
> Kaegi"
>> -Simon
>>> content here:
>>> changed
>>> INFO:
>>> Version Jetty/5.1.x
>>> start
>>> Sep 9,
>>> INFO: Started
>>> HttpContext[/,/]
>>> start
>>> INFO: Started
>>> HTTP ERROR: 404
>>> Powered by Jetty://
>>> Here's the 'ss':
>>> osgi> ss
>>> id State Bundle
>>> 0 ACTIVE
>>> 977 ACTIVE
>>> 978 ACTIVE
>>> 979 ACTIVE
>>> 980 ACTIVE
>>> 981 ACTIVE
>>> 982 ACTIVE
>>> 983 ACTIVE
>>> 984 ACTIVE
>>> 986 ACTIVE
>>> 991 ACTIVE
>>> osgi>
>>> name
>>> TIA,
>>> Kit
Re: Problem with http.jetty and static content... [message #96929 is a reply to message #96902] |
Mon, 10 September 2007 16:37 |
Originally posted by: jacek.pospychala.pl.ibm.com
it seems that a lot of people starting with Equinox follow this Jetty
tutorial. Wouldn't it be cool to attach some ready made project directly
on that page, so everyone could download it and compare with his own
work in case of any problems?
Simon Kaegi wrote:
> Hi Kit,
> of inside /src.
> -Simon
>> Kaegi"
>>> -Simon
>>>> content here:
>>>> changed
>>>> INFO:
>>>> Version Jetty/5.1.x
>>>> start
>>>> Sep 9,
>>>> INFO: Started
>>>> HttpContext[/,/]
>>>> start
>>>> INFO: Started
>>>> HTTP ERROR: 404
>>>> Powered by Jetty://
>>>> Here's the 'ss':
>>>> osgi> ss
>>>> id State Bundle
>>>> 0 ACTIVE
>>>> 977 ACTIVE
>>>> 978 ACTIVE
>>>> 979 ACTIVE
>>>> 980 ACTIVE
>>>> 981 ACTIVE
>>>> 982 ACTIVE
>>>> 983 ACTIVE
>>>> 984 ACTIVE
>>>> 986 ACTIVE
>>>> 991 ACTIVE
>>>> osgi>
>>>> name
>>>> TIA,
>>>> Kit
Re: Problem with http.jetty and static content... [message #97023 is a reply to message #96929] |
Mon, 10 September 2007 17:38 |
I think some basic updating to the "Writing a bundle-based server
application" page would probably help. But, you might be right - having the
directory structure/project to look at and start with would be useful.
Kit
On 9/10/07 9:37 AM, in article fc3rv7$hdb$1@build.eclipse.org, "Jacek
Pospychala" <jacek.pospychala@pl.ibm.com> wrote:
> Hello,
> Simon Kaegi wrote:
>> Hi Kit,
>> of inside /src.
>> -Simon
>>> Kaegi"
>>>> -Simon
>>>>> content here:
>>>>> changed
>>>>> INFO:
>>>>> Version Jetty/5.1.x
>>>>> start
>>>>> Sep 9,
>>>>> INFO: Started
>>>>> HttpContext[/,/]
>>>>> start
>>>>> INFO: Started
>>>>> HTTP ERROR: 404
>>>>> Powered by Jetty://
>>>>> Here's the 'ss':
>>>>> osgi> ss
>>>>> id State Bundle
>>>>> 0 ACTIVE
>>>>> 977 ACTIVE
>>>>> 978 ACTIVE
>>>>> 979 ACTIVE
>>>>> 980 ACTIVE
>>>>> 981 ACTIVE
>>>>> 982 ACTIVE
>>>>> 983 ACTIVE
>>>>> 984 ACTIVE
>>>>> 986 ACTIVE
>>>>> 991 ACTIVE
>>>>> osgi>
>>>>> name
>>>>> TIA,
>>>>> Kit
Current Time: Wed Sep 25 22:35:34 GMT 2024
Powered by FUDForum. Page generated in 0.04704 seconds
