M2 Report doesnt work under M3 [message #96800] |
Tue, 06 December 2005 07:36  |
I have 4 reports designed under Birt M2. All working with my scrpited
data sources and scripted java objects which were put into reports by
webapp. I've upgraded or libraries to M3 and reports stop working.
-------------------Exception:---------------------------
java.lang.Exception: org.eclipse.birt.report.engine.api.EngineException:
The output format pdf is not supported.
at (...)
Caused by: org.eclipse.birt.report.engine.api.EngineException: The
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:159)
--------------Birt log-------------------------
SEVERE: Message:The extension point
[org.eclipse.birt.report.model.reportItemModel] is not found. Error
code:EXTENSION_POINT_NOT_FOUND
When I try open these reports with M3 designer in eclipse I get :
java.lang.ClassCastException
org.eclipse.birt.report.designer.internal.ui.editors.parts.A bstractMultiPageLayoutEditor.superSetInput(AbstractMultiPage LayoutEditor.java:553)
org.eclipse.birt.report.designer.ui.editors.IDEReportEditor. superSetInput(IDEReportEditor.java:250)
--------------Eclipse log-------------------------
Unable to create editor ID
org.eclipse.birt.report.designer.ui.editors.ReportEditor: An exception
was thrown during initialization
Any ideas ?
Michael
FUDForum. Page generated in 0.04332 seconds
