Home » Eclipse Projects » GEF » How to delete a figure?
How to delete a figure? [message #8758] Mon, 10 June 2002 02:05 Go to next message
i'm trying to allow the users of my editorpart to delete editparts from
the canvas, i've installed an editpolicy to these editparts (the
editpolicy extends ComponentEditPolicy, and implements the method
createDeleteCommand, that returns a command that i created for that
matter), the role of the editpolicy is EditPolicy.COMPONENT_ROLE. i also
added the delete action to the cotext menu contributor and to the action
registry (and also added a key listener to the DEL key). when the context
menu opens the delete action apears there, but it is disabled. moreover,
when i press the DEL key after i select an editpart nothing happends. do
you have any ideas?
thanks
yoav
Re: How to delete a figure? [message #8769 is a reply to message #8758] Mon, 10 June 2002 03:21 Go to previous messageGo to next message
ok, got it, i needed to add the line
getSite().setSelectionProvider(getPrimaryViewer()); to the init method at
my editor.
Yoav Rubin wrote:
> Hi
> you have any ideas?
> thanks
> yoav
Re: How to delete a figure? [message #9249 is a reply to message #8758] Mon, 10 June 2002 09:56 Go to previous messageGo to next message
You shouldn't add any key listeners like this. The reason is that you will
be able to delete an object while it is being dragged. In general,
everything should be "locked" during a drag, such as Undo, Redo, Delete. No
menu accelerators function during a drag, so we're safe there. But the
canvas still gets key events.
To get this for *free*, create a GraphicalViewerKeyHandler for your
GraphicalViewer. Then, do a:
sharedKeyHandler.put(
KeyStroke.getPressed(SWT.DEL, 0),
getActionRegistry().getAction(DeleteAction.ID));
KeyHandler's will only get KeyEvents at the appropriate time. In this case,
the SelectionTool will forward the key's for you.
You can also create a common keyhandler to be used by more than one
EditPartViewer, and then 1 or more specific handler customized for each
viewer. User KeyHandler.setNext() to delegate to the common one.
Re: How to delete a figure? [message #9362 is a reply to message #9249] Mon, 10 June 2002 11:04 Go to previous messageGo to next message
what is KeyHandler, or GraphicalViewerKeyHandler for that matter. i can\'t
find any reference for it in the documentation of gef.
thanks
yoav
> You shouldn\'t add any key listeners like this. The reason is that you will
> everything should be \"locked\" during a drag, such as Undo, Redo, Delete.
No
> menu accelerators function during a drag, so we\'re safe there. But the
> KeyHandler\'s will only get KeyEvents at the appropriate time. In this case,
> the SelectionTool will forward the key\'s for you.
Re: How to delete a figure? [message #9409 is a reply to message #9362] Mon, 10 June 2002 13:19 Go to previous message
It is new and undocumented.
See its usage in LogicEditor.
"Yoav Rubin" <yoav@il.ibm.com> wrote in message
news:ae2f6e$4ej$1@rogue.oti.com...
> Hi
> thanks
> yoav
moreover,
do
will
Delete.
> No
case,
Previous Topic:Overview causing a SWTError: No more handles
Next Topic:swt widgets above the editparts
Current Time: Sun Aug 31 23:06:59 EDT 2025
Powered by FUDForum. Page generated in 0.03605 seconds
