Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare]Comparing own model (Dynamic Emf)
[EMF Compare]Comparing own model (Dynamic Emf) [message #96633] Wed, 12 September 2007 20:12 Go to next message
Originally posted by: the_chris_2002.web.de
i want to compare my own datastructure with EMF Compare. Therefore i`ve
written a converter which converts my own datastructure to an EObject. Here
is a snippet:
EPackage pack = EcoreFactory.eINSTANCE.createEPackage();
xdmPackage.setName(model.getRoot().getName());
EPackage firstChild = EcoreFactory.eINSTANCE.createEPackage();
firstChild.setName(model.getRoot().getfirstChild().getName() );
pack.getESubpackages().add(firstChild);
return pack;
Then i call the matching engine.
final MatchModel match = new DifferencesServices().modelMatch(model1,
model2, new NullProgressMonitor());
That will result in an NullpointerException, because their is no resource
binded to the EObject. I didnt find a way to add a resource to an EObject.
How do I do this? And a more important question is, will this work in the
end or do I have an fatal mistake in my logic?
regards,
ChrisW
Re: [EMF Compare]Comparing own model (Dynamic Emf) [message #96663 is a reply to message #96633] Thu, 13 September 2007 07:37 Go to previous messageGo to next message
--------------060600030307000503010203
ChrisW,
Probably you should read some of the introductory material on the EMF
documentation page.
The Eclipse Modeling Framework Overview
< http://dev.eclipse.org/viewcvs/indextools.cgi/*checkout*/org .eclipse.emf/doc/org.eclipse.emf.doc/references/overview/EMF .html>
I have a hard time imaging how mapping your data structure to an
instance of Ecore would really be a good solution. I think you'd want
to create an Ecore metamodel of your data structure and then convert
your data to an instance of that metamodel. This article will probably
help you understand the idea better:
Discover the Eclipse Modeling Framework (EMF) and Its Dynamic
Capabilities <http://www.devx.com/Java/Article/29093/0/page/1>
ChrisW wrote:
> is a snippet:
> return pack;
> regards,
> ChrisW
<html>
<head>
</head>
ChrisW,<br>
<br>
documentation page.&nbsp;&nbsp; <br>
<blockquote><a
href=" http://dev.eclipse.org/viewcvs/indextools.cgi/*checkout*/org .eclipse.emf/doc/org.eclipse.emf.doc/references/overview/EMF .html">The
Eclipse Modeling Framework Overview</a><br>
</blockquote>
instance of Ecore would really be a good solution.&nbsp; I think you'd want
your data to an instance of that metamodel.&nbsp; This article will probably
help you understand the idea better:<br>
<blockquote><a target="_out"
href="http://www.devx.com/Java/Article/29093/0/page/1">Discover the
Eclipse Modeling Framework (EMF) and Its Dynamic Capabilities</a><br>
</blockquote>
<br>
<br>
ChrisW wrote:
<blockquote cite="mid:fc9v9h$gv7$1@build.eclipse.org" type="cite">
<pre wrap="">Hi,
is a snippet:
return pack;
regards,
ChrisW
</pre>
</blockquote>
<br>
</body>
</html>
--------------060600030307000503010203--
Re: [EMF Compare]Comparing own model (Dynamic Emf) [message #96677 is a reply to message #96663] Thu, 13 September 2007 11:11 Go to previous messageGo to next message
Thanks Ed, I will read those immediately
Ed Merks <merks@ca.ibm.com> wrote in
news:fcb7bb$sck$1@build.eclipse.org:
> ChrisW,
> documentation page.
> <http://dev.eclipse.org/viewcvs/indextools.cgi/
*checkout*/org.eclip
> se.emf/doc/org.eclipse.emf.doc/references/overview/EMF.html>
> probably help you understand the idea better:
> ChrisW wrote:
>> i`ve written a converter which converts my own datastructure to an
>> EObject. Here is a snippet:
>> return pack;
>> resource binded to the EObject. I didnt find a way to add a resource
>> to an EObject. How do I do this? And a more important question is,
>> will this work in the end or do I have an fatal mistake in my logic?
>> regards,
>> ChrisW
> Attachment decoded: untitled-2.txt
> <html>
> <head>
> </head>
> ChrisW,<br>
> <br>
> <blockquote><a
> href="http://dev.eclipse.org/viewcvs/indextools.cgi/
*checkout*/org.ecl
> ipse.emf/doc/org.eclipse.emf.doc/references/overview/EMF.htm l ">The
> </blockquote>
> want to create an Ecore metamodel of your data structure and then
> convert your data to an instance of that metamodel.&nbsp; This article
> will probably help you understand the idea better:<br>
> </blockquote>
> <br>
> <br>
> <pre wrap="">Hi,
> return pack;
> regards,
> ChrisW
> </pre>
> </blockquote>
> <br>
> </body>
> </html>
> Attachment decoded: untitled-3.htm
Re: [EMF Compare]Comparing own model (Dynamic Emf) [message #96692 is a reply to message #96633] Thu, 13 September 2007 11:49 Go to previous messageGo to next message
Concerning the resource issue we really need this information during the
comparison in order to handle references going to external models. Imagine
you've got an Ecore model with EType references going to the Ecore
metamodel, we need to know that EString or EInt are from the same model to
get a good comparison.
Once you got your eObject structure you only need to add these structure in
a Resource itself in a resourceset, you can create it in memory without
serializing it, it doesn't mater. It will probably look like the following
code :
final EObject model1 = xxx // create your model
final EObject model2 = xxx // create your model
final ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.createResource(URI.createURI("http:///model1")).getContents().add(model1);
resourceSet.createResource(URI.createURI("http:///model2")).getContents().add(model2);
// Creates the match then the diff model for those two models
final DiffModel diff = new DiffMaker().doDiff(match);
Then you get all the delta in the diff model.
Cédric
ChrisW wrote:
> Here is a snippet:
> return pack;
> regards,
> ChrisW
Re: [EMF Compare]Comparing own model (Dynamic Emf) [message #96708 is a reply to message #96692] Thu, 13 September 2007 17:53 Go to previous messageGo to next message
first i want to thank for your help.
().add(model1);
leads to an NullPointerException [.getContents() returns null ]
=?UTF-8?B?Q8OpZHJpYw==?= Brun <cedric.brun@obeo.fr> wrote in
news:fcbm62$a5k$1@build.eclipse.org:
> the comparison in order to handle references going to external models.
> Imagine you've got an Ecore model with EType references going to the
> Ecore metamodel, we need to know that EString or EInt are from the
> same model to get a good comparison.
> structure in a Resource itself in a resourceset, you can create it in
> memory without serializing it, it doesn't mater. It will probably
> look like the following code :
> ().add(model1);
> ().add(model2);
> Cheers,
> Cédric
> ChrisW wrote:
>> return pack;
>> regards,
>> ChrisW
Re: [EMF Compare]Comparing own model (Dynamic Emf) [message #96722 is a reply to message #96708] Thu, 13 September 2007 17:58 Go to previous messageGo to next message
--------------070500090107030305070300
ChrisW,
While createResource might return null because your don't have any
registered factory to handle this URI, getContents cannot return null.
Maybe you should use "http:///model1.xml", but you still need to be sure
a resource factory is registered to handle that extension...
ChrisW wrote:
> ().add(model1);
>> ().add(model1);
>> ().add(model2);
>> Cheers,
>> Cédric
>> ChrisW wrote:
>>> Hi,
>>> return pack;
>>> regards,
>>> ChrisW
<html>
<head>
</head>
ChrisW,<br>
<br>
registered factory to handle this URI, getContents cannot return null.&nbsp;
Maybe you should use <a class="moz-txt-link-rfc2396E" href="http:///model1.xml">"http:///model1.xml"</a>, but you still need to be
sure a resource factory is registered to handle that extension...<br>
<br>
<br>
ChrisW wrote:
<blockquote cite="mid:fccbg8$44e$1@build.eclipse.org" type="cite">
<pre wrap="">Hi,
resourceSet.createResource(URI.createURI(<a class="moz-txt-link-rfc2396E" href="http:///model1">"http:///model1"</a>)).getContents
().add(model1);
=?UTF-8?B?Q8OpZHJpYw==?= Brun <a class="moz-txt-link-rfc2396E" href="mailto:cedric.brun@obeo.fr">&lt;cedric.brun@obeo.fr&gt;</a> wrote in
<a class="moz-txt-link-freetext" href="news:fcbm62$a5k$1@build.eclipse.org:">news:fcbm62$a5k$1@build.eclipse.org:</a>
</pre>
<blockquote type="cite">
<pre wrap="">Hi,
</pre>
</blockquote>
<pre wrap=""><!---->(<a class="moz-txt-link-rfc2396E" href="http:///model1">"http:///model1"</a>)).getContents
</pre>
<pre wrap="">().add(model1);
</pre>
</blockquote>
<pre wrap=""><!---->(<a class="moz-txt-link-rfc2396E" href="http:///model2">"http:///model2"</a>)).getContents
</pre>
<pre wrap="">().add(model2);
C&Atilde;&copy;dric
ChrisW wrote:
</pre>
<pre wrap="">Hi,
return pack;
regards,
ChrisW
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------070500090107030305070300--
Re: [EMF Compare]Comparing own model (Dynamic Emf) [message #96738 is a reply to message #96677] Thu, 13 September 2007 18:02 Go to previous messageGo to next message
So.. i ve read all those papers and i think i am on a good way. But now i
have a new problem:
Like here explained:
http://dev.eclipse.org/viewcvs/indextools.cgi/org.eclipse.em f/doc/org.eclip
se.emf.doc/references/overview/EMF.html Section Saving and loading
resources
i save my resources. the saving is no problem, but if I want to edit the
resources in the "Sample Reflector Ecore Model Editor" i get this
exception: PackageNotFoundException: Package with uri
'http:///model.ecore' not found.
Then I edit the file via the TextEditor and replace http://... with
file://...model.ecore. Then i can look at the file and even can compare
them.
But how do i do this automatically? I`ve taken a look into the EMF Faq
(there is an entry concerning this exception) but it doesnt help me.
thanks and regards,
ChrisW
ChrisW <the_chris_2002@web.de> wrote in news:fcbjv8$t7o$1
@build.eclipse.org:
>> ChrisW,
>> documentation page.
>> ChrisW wrote:
>>> Hi,
>>> return pack;
>>> regards,
>>> ChrisW
>> <html>
>> <head>
>> </head>
>> ChrisW,<br>
>> <br>
>> <blockquote><a
> *checkout*/org.ecl
>> </blockquote>
>> </blockquote>
>> <br>
>> <br>
>> <pre wrap="">Hi,
>> return pack;
>> regards,
>> ChrisW
>> </pre>
>> </blockquote>
>> <br>
>> </body>
>> </html>
Re: [EMF Compare]Comparing own model (Dynamic Emf) [message #96754 is a reply to message #96738] Thu, 13 September 2007 18:37 Go to previous messageGo to next message
--------------050506020305070702090606
ChrisW,
You can use XMLResource.OPTION_SCHEMA_LOCATION as a save option so that
the physical location of your Ecore model will be saved in the
resource. It should have the URI of the resource containing your Ecore
model as the xsi:schemaLocation's physical location.
> have a new problem:
> resources
> them.
> thanks and regards,
> ChrisW
> @build.eclipse.org:
>>> ChrisW,
>>> documentation page.
>>> ChrisW wrote:
>>>> Hi,
>>>> return pack;
>>>> regards,
>>>> ChrisW
>>> <html>
>>> <head>
>>> </head>
>>> ChrisW,<br>
>>> <br>
>>> <blockquote><a
>> *checkout*/org.ecl
>>> </blockquote>
>>> </blockquote>
>>> <br>
>>> <br>
>>> <pre wrap="">Hi,
>>> return pack;
>>> regards,
>>> ChrisW
>>> </pre>
>>> </blockquote>
>>> <br>
>>> </body>
>>> </html>
<html>
<head>
</head>
ChrisW,<br>
<br>
the physical location of your&nbsp; Ecore model will be saved in the
resource.&nbsp;&nbsp; It should have the URI of the resource containing your
Ecore model as the xsi:schemaLocation's physical location.<br>
<br>
<br>
ChrisW wrote:
<blockquote cite="mid:fccc2a$44e$2@build.eclipse.org" type="cite">
<pre wrap="">So.. i ve read all those papers and i think i am on a good way. But now i
have a new problem:
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/viewcvs/indextools.cgi/org.eclipse.em f/doc/org.eclip"> http://dev.eclipse.org/viewcvs/indextools.cgi/org.eclipse.em f/doc/org.eclip</a>
resources
'<a class="moz-txt-link-freetext" href="http:///model.ecore">http:///model.ecore</a>' not found.
Then I edit the file via the TextEditor and replace <a class="moz-txt-link-freetext" href="http://">http://</a>... with
<a class="moz-txt-link-freetext" href="file://...model.ecore">file://...model.ecore</a>. Then i can look at the file and even can compare
them.
thanks and regards,
ChrisW
ChrisW <a class="moz-txt-link-rfc2396E" href="mailto:the_chris_2002@web.de">&lt;the_chris_2002@web.de&gt;</a> wrote in <a class="moz-txt-link-freetext" href="news:fcbjv8$t7o$1">news:fcbjv8$t7o$1</a>
@build.eclipse.org:
</pre>
<pre wrap="">Thanks Ed, I will read those immediately
Ed Merks <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in
<a class="moz-txt-link-freetext" href="news:fcb7bb$sck$1@build.eclipse.org:">news:fcb7bb$sck$1@build.eclipse.org:</a>
</pre>
<pre wrap="">ChrisW,
documentation page.
&lt;<a class="moz-txt-link-freetext" href="http://dev.eclipse.org/viewcvs/indextools.cgi/">http://dev.eclipse.org/viewcvs/indextools.cgi/</a>
</pre>
</blockquote>
<pre wrap="">*checkout*/org.eclip
</pre>
<pre wrap=""> se.emf/doc/org.eclipse.emf.doc/references/overview/EMF.html& amp;gt;
Capabilities <a class="moz-txt-link-rfc2396E" href="http://www.devx.com/Java/Article/29093/0/page/1">&lt;http://www.devx.com/Java/Article/29093/0/page/1&gt;</a>
ChrisW wrote:
</pre>
<pre wrap="">Hi,
return pack;
regards,
ChrisW
</pre>
</blockquote>
<pre wrap="">
&lt;!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"&gt;
&lt;html&gt;
&lt;head&gt;
&lt;meta content="text/html;charset=ISO-8859-1"
http-equiv="Content-Type"&gt;
&lt;/head&gt;
&lt;body bgcolor="#ffffff" text="#000000"&gt;
ChrisW,&lt;br&gt;
&lt;br&gt;
documentation page.&amp;nbsp;&amp;nbsp; &lt;br&gt;
&lt;blockquote&gt;&lt;a
href="<a class="moz-txt-link-freetext" href="http://dev.eclipse.org/viewcvs/indextools.cgi/">http://dev.eclipse.org/viewcvs/indextools.cgi/</a>
</pre>
</blockquote>
</pre>
<pre wrap=""> ipse.emf/doc/org.eclipse.emf.doc/references/overview/EMF.htm l "&gt;The
Eclipse Modeling Framework Overview&lt;/a&gt;&lt;br&gt;
&lt;/blockquote&gt;
instance of Ecore would really be a good solution.&amp;nbsp; I think you'd
convert your data to an instance of that metamodel.&amp;nbsp; This article
will probably help you understand the idea better:&lt;br&gt;
&lt;blockquote&gt;&lt;a target="_out"
href=<a class="moz-txt-link-rfc2396E" href="http://www.devx.com/Java/Article/29093/0/page/1">"http://www.devx.com/Java/Article/29093/0/page/1"</a>&gt;Discover the
Eclipse Modeling Framework (EMF) and Its Dynamic Capabilities&lt;/a&gt;&lt;br&gt;
&lt;/blockquote&gt;
&lt;br&gt;
&lt;br&gt;
ChrisW wrote:
&lt;blockquote cite=<a class="moz-txt-link-rfc2396E" href="mailto:mid:fc9v9h$gv7$1@build.eclipse.org">"mid:fc9v9h$gv7$1@build.eclipse.org"</a> type="cite"&gt;
&lt;pre wrap=""&gt;Hi,
return pack;
regards,
ChrisW
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;br&gt;
&lt;/body&gt;
&lt;/html&gt;
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------050506020305070702090606--
Re: [EMF Compare]Comparing own model (Dynamic Emf) [message #96768 is a reply to message #96754] Thu, 13 September 2007 19:27 Go to previous message
Thanks for your help, now it is working currectly :)
Re: [EMF Compare]Comparing own model (Dynamic Emf) [message #609707 is a reply to message #96633] Thu, 13 September 2007 07:37 Go to previous message
ChrisW,
documentation page.
ChrisW wrote:
> is a snippet:
> return pack;
> regards,
> ChrisW
<html>
<head>
</head>
ChrisW,<br>
<br>
<blockquote><a
</blockquote>
</blockquote>
<br>
<br>
<pre wrap="">Hi,
is a snippet:
return pack;
regards,
ChrisW
</pre>
</blockquote>
<br>
</body>
</html>
Re: [EMF Compare]Comparing own model (Dynamic Emf) [message #609708 is a reply to message #96663] Thu, 13 September 2007 11:11 Go to previous message
> ChrisW,
> documentation page.
> ChrisW wrote:
>> return pack;
>> regards,
>> ChrisW
> <html>
> <head>
> </head>
> ChrisW,<br>
> <br>
> <blockquote><a
*checkout*/org.ecl
> </blockquote>
> </blockquote>
> <br>
> <br>
> <pre wrap="">Hi,
> return pack;
> regards,
> ChrisW
> </pre>
> </blockquote>
> <br>
> </body>
> </html>
Re: [EMF Compare]Comparing own model (Dynamic Emf) [message #609709 is a reply to message #96633] Thu, 13 September 2007 11:49 Go to previous message
code :
Cédric
ChrisW wrote:
> Here is a snippet:
> return pack;
> regards,
> ChrisW
Re: [EMF Compare]Comparing own model (Dynamic Emf) [message #609710 is a reply to message #96692] Thu, 13 September 2007 17:53 Go to previous message
().add(model1);
> ().add(model1);
> ().add(model2);
> Cheers,
> Cédric
> ChrisW wrote:
>> return pack;
>> regards,
>> ChrisW
Re: [EMF Compare]Comparing own model (Dynamic Emf) [message #609711 is a reply to message #96708] Thu, 13 September 2007 17:58 Go to previous message
ChrisW,
ChrisW wrote:
> ().add(model1);
>> ().add(model1);
>> ().add(model2);
>> Cheers,
>> Cédric
>> ChrisW wrote:
>>> Hi,
>>> return pack;
>>> regards,
>>> ChrisW
<html>
<head>
</head>
ChrisW,<br>
<br>
<br>
<br>
<pre wrap="">Hi,
().add(model1);
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
C&Atilde;&copy;dric
ChrisW wrote:
</pre>
<pre wrap="">Hi,
return pack;
regards,
ChrisW
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: [EMF Compare]Comparing own model (Dynamic Emf) [message #609712 is a reply to message #96677] Thu, 13 September 2007 18:02 Go to previous message
have a new problem:
resources
Then I edit the file via the TextEditor and replace http://.. with
file://...model.ecore Then i can look at the file and even can compare
them.
thanks and regards,
ChrisW
@build.eclipse.org:
>> ChrisW,
>> documentation page.
>> ChrisW wrote:
>>> Hi,
>>> return pack;
>>> regards,
>>> ChrisW
>> <html>
>> <head>
>> </head>
>> ChrisW,<br>
>> <br>
>> <blockquote><a
> *checkout*/org.ecl
>> </blockquote>
>> </blockquote>
>> <br>
>> <br>
>> <pre wrap="">Hi,
>> return pack;
>> regards,
>> ChrisW
>> </pre>
>> </blockquote>
>> <br>
>> </body>
>> </html>
Re: [EMF Compare]Comparing own model (Dynamic Emf) [message #609713 is a reply to message #96738] Thu, 13 September 2007 18:37 Go to previous message
ChrisW,
> have a new problem:
> resources
> them.
> thanks and regards,
> ChrisW
> @build.eclipse.org:
>>> ChrisW,
>>> documentation page.
>>> ChrisW wrote:
>>>> Hi,
>>>> return pack;
>>>> regards,
>>>> ChrisW
>>> <html>
>>> <head>
>>> </head>
>>> ChrisW,<br>
>>> <br>
>>> <blockquote><a
>> *checkout*/org.ecl
>>> </blockquote>
>>> </blockquote>
>>> <br>
>>> <br>
>>> <pre wrap="">Hi,
>>> return pack;
>>> regards,
>>> ChrisW
>>> </pre>
>>> </blockquote>
>>> <br>
>>> </body>
>>> </html>
<html>
<head>
</head>
ChrisW,<br>
<br>
<br>
<br>
have a new problem:
resources
them.
thanks and regards,
ChrisW
@build.eclipse.org:
</pre>
</pre>
documentation page.
</pre>
</blockquote>
</pre>
ChrisW wrote:
</pre>
<pre wrap="">Hi,
return pack;
regards,
ChrisW
</pre>
</blockquote>
<pre wrap="">
&lt;html&gt;
&lt;head&gt;
&lt;/head&gt;
ChrisW,&lt;br&gt;
&lt;br&gt;
</pre>
</blockquote>
</pre>
&lt;/blockquote&gt;
&lt;/blockquote&gt;
&lt;br&gt;
&lt;br&gt;
return pack;
regards,
ChrisW
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;br&gt;
&lt;/body&gt;
&lt;/html&gt;
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: [EMF Compare]Comparing own model (Dynamic Emf) [message #609714 is a reply to message #96754] Thu, 13 September 2007 19:27 Go to previous message
Previous Topic:[CDO][0.8.0] Accessing more directly the data
Next Topic:[Search] Development Plan
Current Time: Sun Aug 31 12:41:28 EDT 2025
Powered by FUDForum. Page generated in 0.11830 seconds
