Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [CDO][0.8.0] Accessing more directly the data
[CDO][0.8.0] Accessing more directly the data [message #96617] Wed, 12 September 2007 18:43 Go to next message
In our processing our services runs on the same machine than the CDOServer.
We would like to access the data more directly.. and we really do not need
to go through the transport layer.
Also in this specific case, we do not need to have a cache in
RevisionManager and another one in the CDORevisionImpl.
Could we replace CDORevisionImpl by the RevisionManager ?
I know right now we cannot... but if all the operation are hidden behind an
interface... We should be able to it.
Request for a view will need to be hidden behind and interface.
P.S. This should be easy to do ... once we can have mutliple server for the
same repository.
Re: [CDO][0.8.0] Accessing more directly the data [message #96647 is a reply to message #96617] Thu, 13 September 2007 05:08 Go to previous message
There is another solution in Net4j to bypass the socket laye:
You could use JVMConnectors instead of the TCPConnectors you are
currently using.
JVMConnectors don't bypass the complete transport layer but they pass
IBuffers from
one IChannel peer to the other through direct method calls. This way the
threading model
of the receiver is the same as with any other IConnector implementation
but a bit of your
performance is lost (compared to no transport layer at all, which is not
the business of Net4j)
due to buffer multiplexing.
Note: Currently the JVM connector implementation could be broken since
I'm only using
the TCP connectors for my current tests.
If you think we should add a configuration option to bypass caching
please file a feature request.
I guess you mean something different from what you actually typed ;-)
You certainly don't mean CDORevisionImpl here. Maybe CDORevisionManagerImpl?
> same repository.
I'm not that sure that it's very simple.
Chances are much higher that I will be able to look at this soon if you
attach patch with a proposal to your respective feature request.
Cheers
/Eike
Re: [CDO][0.8.0] Accessing more directly the data [message #609706 is a reply to message #96617] Thu, 13 September 2007 05:08 Go to previous message
currently using.
IBuffers from
threading model
but a bit of your
I'm only using
> same repository.
Cheers
/Eike
Previous Topic:[EMF Compare]Comparing own model (Dynamic Emf)
Next Topic:[EMF Compare]Comparing own model (Dynamic Emf)
Current Time: Thu Jul 17 19:28:07 EDT 2025
Powered by FUDForum. Page generated in 0.06269 seconds
