Home » Eclipse Projects » Mylyn » How do I update the list of milestones
How do I update the list of milestones [message #8734] Tue, 10 July 2007 06:47 Go to next message
Someone creates a ticket, and it is assigned to me. I then want to
assign it to a milestone, but I need to create a new one (in Trac)
so I create it, and then come to the ticket only to discover that the
list of available milestones does not contain the new one I have
just created.
I tried Synchronize, but that does not seem to update the list.
So how should I update the list of available milestones for the dropdown?
David
Re: How do I update the list of milestones [message #8746 is a reply to message #8734] Tue, 10 July 2007 10:14 Go to previous messageGo to next message
Is this the same issue as David Whiteman had? Did you try updating the
attributes in the Task Repository View?
"David Goodenough" <david.goodenough@btconnect.com> wrote in message
news:f6vo49$v2u$1@build.eclipse.org...
> just created.
> David
Re: How do I update the list of milestones [message #8760 is a reply to message #8746] Tue, 10 July 2007 11:38 Go to previous messageGo to next message
>> just created.
>> David
Yes, thats the one. In my circumstances creating new milestones is
something that happens quite often. So it would be useful if this could
be done from the place where I want to use it, i.e. next to the drop down
with the Milestone lists a refresh button would be nice. The same would
be good for any other attributes that might need to be refreshed such
as the list of components, priorities and types.
David
Re: How do I update the list of milestones [message #10864 is a reply to message #8760] Tue, 10 July 2007 16:49 Go to previous messageGo to next message
Originally posted by: beatmik.acm.org
I agree and think this could be improved by having an "Update
Attributes" button in the Attributes section of the task editor. Please
file a bug:
http://www.eclipse.org/mylyn/bugs/
Mik
> David
Re: How do I update the list of milestones [message #23652 is a reply to message #10864] Fri, 24 August 2007 03:20 Go to previous messageGo to next message
The "Update Attributes" trick only works for some of my tasks (maybe the
newer ones?). Most of them are stubbornly showing the old milestone list.
The FAQ seems to imply that all I have to do is open them up to refresh
("reopen a task editor"), but that doesn't seem to work. What am I missing?
Dave.
"Mik Kersten" <beatmik@acm.org> wrote in message
news:f70reu$pha$3@build.eclipse.org...
>I agree and think this could be improved by having an "Update Attributes"
>button in the Attributes section of the task editor. Please file a bug:
> Mik
>> David
Re: How do I update the list of milestones [message #25823 is a reply to message #23652] Thu, 06 September 2007 17:25 Go to previous message
I haven't been able to reproduce this. If Update Attributes is still
failing for you please open a bug. Note that if you do the update via
the Task Repositories view you'll need to close any open editors to see
the updated attributes. If you do it via the button on the Attributes
section of the task editor the attribute settings will be reloaded
without needing to reopen.
Added this note to:
http://wiki.eclipse.org/Mylyn_FAQ#Why_are_my_updated_reposit ory_attributes_not_showing_up.3F
> Dave.
Re: How do I update the list of milestones [message #570469 is a reply to message #8734] Tue, 10 July 2007 10:14 Go to previous message
> just created.
> David
Re: How do I update the list of milestones [message #570482 is a reply to message #8746] Tue, 10 July 2007 11:38 Go to previous message
>> just created.
>> David
David
Re: How do I update the list of milestones [message #570745 is a reply to message #8760] Tue, 10 July 2007 16:49 Go to previous message
file a bug:
Mik
> David
Re: How do I update the list of milestones [message #578224 is a reply to message #10864] Fri, 24 August 2007 03:20 Go to previous message
Dave.
> Mik
>> David
Re: How do I update the list of milestones [message #579747 is a reply to message #23652] Thu, 06 September 2007 17:25 Go to previous message
Added this note to:
> Dave.
Previous Topic:Choice lists not updating for Target Milestone
Next Topic:Webinar on Eclipse 3.3 and Mylyn 2.0
Current Time: Fri May 09 04:02:11 EDT 2025
Powered by FUDForum. Page generated in 0.31990 seconds
