Home » Modeling » GMF (Graphical Modeling Framework) » Unwanted Horizontal Rule Above a Compartment
Unwanted Horizontal Rule Above a Compartment [message #96356] Wed, 24 January 2007 18:00 Go to next message
Originally posted by: webwhysguy.gmail.com
Greetings,
I'm having trouble getting rid of an unwanted horizontal rule above a
compartment. I've put together a graphic (see below), but here is a text
description of the layout as well:
- Within a "Files" compartment I have a "Files" rectangle (no fill,
line width=0).
- The files rectangle is composed of a "Files" label (w/icon and fixed
text of "Files") and a "File" compartment that
is actually a Diagram Label.
- Within the File compartment is a list of "File" nodes which are
feature labels.
For some reason I am getting a horizontal rule just above the first file in
the "File" compartment. The rule grows as the compartment grows. The
horizontal rule is just visual clutter for my purposes, so I want to get rid
of it. I've tried working with all of the properties I can think of for the
Rectangle and labels, but no success. Any suggestions would be greatly
appreciated.
Thanks in advance!
- Billy
Re: Unwanted Horizontal Rule Above a Compartment (Correction!) [message #96376 is a reply to message #96356] Wed, 24 January 2007 18:54 Go to previous messageGo to next message
Sorry, but I was just a bit off on the description of my figure and it's
compartments. The "Files" Rectangle is the "File" compartment. I've
updated my description and image. Sorry for the confusion!
(no fill, line width=0).
- The files rectangle is also the "File" compartment and is
composed of a "Files" label (w/icon and fixed text of "Files")
- Within the "File" compartment is a list of "File" feature labels.
Take Care,
- Billy
"webwhysguy" <webwhysguy@gmail.com> wrote in message
news:ep8of0$8ua$1@utils.eclipse.org...
> Greetings,
> line width=0).
> feature labels.
> in
> rid
> the
> appreciated.
> Thanks in advance!
> - Billy
Re: Unwanted Horizontal Rule Above a Compartment (Correction!) [message #96590 is a reply to message #96376] Thu, 25 January 2007 05:23 Go to previous messageGo to next message
Originally posted by: christian.bartels.gmx.de
Hi Billy,
I had the same problem and solved it this way:
Go to the createFigure Method of your CompartmentEditPart where the
ruler is painted and add the following line to it:
result.setBorder(null);
This horizonztal rule is set since the M4 release in the constructor of
the ResizableCompartmentFigure at the last line (113):
setBorder(new OneLineBorder());
By setting it back to null it disappears.
Hope that will help,
Christian.
webwhysguy schrieb:
> Take Care,
> - Billy
>> Greetings,
>> line width=0).
>> feature labels.
>> in
>> rid
>> the
>> appreciated.
>> Thanks in advance!
>> - Billy
Re: Unwanted Horizontal Rule Above a Compartment (Correction!) [message #97090 is a reply to message #96590] Thu, 25 January 2007 21:38 Go to previous message
Worked like a charm ... thanks!
"Christian Bartels" <christian.bartels@gmx.de> wrote in message
news:epa0ge$6f6$1@utils.eclipse.org...
> Hi Billy,
> Go to the createFigure Method of your CompartmentEditPart where the ruler
> Christian.
> webwhysguy schrieb:
>> Take Care,
>> - Billy
>>> Greetings,
>>> text
>>> line width=0).
>>> fixed
>>> feature labels.
>>> in
>>> rid
>>> the
>>> appreciated.
>>> Thanks in advance!
>>> - Billy
Previous Topic:Property sheet
Next Topic:Adding SpecializationTypes dynamically
Current Time: Sun Aug 31 06:08:57 EDT 2025
Powered by FUDForum. Page generated in 0.03432 seconds
