Choice lists not updating for Target Milestone [message #8696] |
Mon, 09 July 2007 19:25  |
Originally posted by: david_whiteman.us.ibm.com
How do I sync the choice lists for various fields in the Bugzilla bug
editor? Is the following a bug, or is there something I need to do to
get the choice lists to update?
1. Use Mylyn for a long time, creating and updating bug reports,
assuming you have Target Milestones i1, i2, i3, i4.
2. Your PMC adds two new milestones to the project in Bugzilla: i5 and i6.
3. Open a bug report in Mylyn and it still does not show i5 and i6 in
the list, even after those target milestones have been in the system for
several days
I'm using eclipse 3.3 with the GA version of Mylyn for Europa.
David
Re: Choice lists not updating for Target Milestone [message #570360 is a reply to message #8696] |
Tue, 10 July 2007 03:30  |
You can right click on the repository and choose "Update Attributes". Does
that work?
"David Whiteman" <david_whiteman@us.ibm.com> wrote in message
news:f6ug5u$vf$1@build.eclipse.org...
> editor? Is the following a bug, or is there something I need to do to get
> 1. Use Mylyn for a long time, creating and updating bug reports, assuming
> 3. Open a bug report in Mylyn and it still does not show i5 and i6 in the
> several days
> David
Re: Choice lists not updating for Target Milestone [message #570437 is a reply to message #8696] |
Tue, 10 July 2007 04:17  |
If you right click on a repository in the Task Repositories view there is an option to called Update Attributes. I think this will do what you want.
I've no idea if there is a way get Mylyn to regularly do this (e.g. once a week) - possibly worth raising a bug for it?
Richard
FUDForum. Page generated in 0.03122 seconds
