Home » Eclipse Projects » Eclipse Platform » Attaching CVS to previously checked-out files
Attaching CVS to previously checked-out files [message #96176] Fri, 18 July 2003 02:25 Go to next message
Originally posted by: eclipse.zemsys.com
I have recently moved to Eclipse for my work. I already had a lot of
stuff checked out onto my machine and I wanted to try and import it
into Eclipse. Unfortunately, although I can import a project, there
doesn't seem to be anyway to tell Eclipse that the files in it have
already been checked out and not to do it all over again. My link to
the CVS repository is slow and as a novice it took a while to get the
rest of my Eclipse setup right, so I ended up checking everything out
several times before I got it right.
Is there an easy way to get Eclipse to "adopt" existing CVS files?
Thanks in advance,
Paul.
Re: Attaching CVS to previously checked-out files [message #96205 is a reply to message #96176] Fri, 18 July 2003 02:43 Go to previous message
Yes - if you do "Team -> Share..." on them, Eclipse will notice that there
already is CVS information available and ask you wether to use those.
Regards, Ilja
Previous Topic:How-to extend JDT Package Explorer View for a new plugin
Next Topic:Re: eclipse 3 M1 on osx Panther does not work ?
Current Time: Mon Jul 14 19:40:49 EDT 2025
Powered by FUDForum. Page generated in 0.03354 seconds
