Home » Archived » M2M (model-to-model transformation) » problem with am3
problem with am3 [message #96091] Wed, 26 November 2008 23:04 Go to next message
The images on this url are not working, so I can not install am3.
http://wiki.eclipse.org/AM3/How_Install_AM3_From_SVN
There is another way to run the build.xml to launch my atl transformation?
regards
gab
Re: problem with am3 [message #96120 is a reply to message #96091] Thu, 27 November 2008 04:22 Go to previous messageGo to next message
The repository URL is:
https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.am3
You need the AM3 Ant tasks plugin, contained in the repository, to launch
your ATL transformation using the build.xml file.
Or you can try without the build.xml file, using Eclipse menu "Run
Configurations > ATL Transformation". But this option does not provide a
way to chain transformations nor to use a xml extractor for example.
Adrien
Re: problem with am3 [message #96156 is a reply to message #96120] Fri, 28 November 2008 10:16 Go to previous message
you also use the ATLFlow plugin! it's a graphical way to launch ATL
transformation chains.
Previous Topic:[ATL] Problem when copying association
Next Topic:[ATL] Fresh install
Current Time: Mon Sep 01 03:29:57 EDT 2025
Powered by FUDForum. Page generated in 0.11243 seconds
