EventAdmin Problem [message #95919] |
Mon, 27 August 2007 11:03 |
Originally posted by: beat.schaller.postfinance.ch
In a simple program i have a problem to use the EventAdmin service. As
described i put the org.eclipse.equinox.event bundle in my worbench.
In a simple application i tried to get the service in the Activator with
the following statements:
ServiceTracker eaTracker = new ServiceTracker(context,
EventAdmin.class.getName(), null);
eaTracker.open();
EventAdmin ea = (EventAdmin) eaTracker.getService();
and all i get is:
!ENTRY org.eclipse.osgi 4 0 2007-08-27 11:28:16.917
!MESSAGE An error occurred while automatically activating bundle
ch.post.pf.sample.simpleeas (19).
!STACK 0
org.osgi.framework.BundleException: Exception in
ch.post.pf.sample.simpleeas.Activator.start() of bundle
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1018)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:149)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
Caused by: java.lang.NoClassDefFoundError: org/osgi/service/event/EventAdmin
at ch.post.pf.sample.simpleeas.Activator.start(Activator.java:3 7)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
... 33 more
my manifest:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Simpleeas Plug-in
Bundle-SymbolicName: ch.post.pf.sample.simpleeas; singleton:=true
Bundle-Version: 1.0.0
Bundle-Activator: ch.post.pf.sample.simpleeas.Activator
Require-Bundle: org.eclipse.core.runtime,
org.apache.log4j,
org.eclipse.osgi.services
Eclipse-LazyStart: true
any hints?
Beat
Re: EventAdmin Problem [message #96038 is a reply to message #95919] |
Tue, 28 August 2007 09:22 |
> eaTracker.open();
> and all i get is:
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> ... 33 more
> my manifest:
> org.apache.log4j,
> any hints?
> Thanks
> Beat
I resolved the problem. The import of the bundle as "Projects with
source folder" doesn't work. The result is an invalid Activator...????
I added the jars in Runtime/Classpath and no errors are shown. But it
doesn't work. Strange behaviour!!!
Found it by starting the bundles by hand over the console.
I imported the projects as binary projects and all worked.
Beat
FUDForum. Page generated in 0.03134 seconds
