Home » Eclipse Projects » Remote Application Platform (RAP) » preWindowShellClose is not called
preWindowShellClose is not called [message #95815] Wed, 02 July 2008 09:39 Go to next message
Originally posted by: diman.tetracom.com
Hi All,
I am working on a RAP application and I want to do some cleanup when the
application (in the browser) is closed. I've overrided the method
preWindowShellClose in ApplicationWorkbenchWindowAdvisor (extends
WorkbenchWindowAdvisor) and set a breakpoint there.
However, the browser was closed, but the code in the method was not
executed.
Can you give me a hint how and when it is suitable to make the cleanup?
greetings
Diman
Re: preWindowShellClose is not called [message #95830 is a reply to message #95815] Wed, 02 July 2008 09:56 Go to previous messageGo to next message
Hello Diman
This is because a session never ends. You may have to adjust your timeout.
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.rap.help/help/html/getting-started/launcher.html
Diman Karagiozov wrote:
> Hi All,
> executed.
> greetings
> Diman
Re: preWindowShellClose is not called [message #95936 is a reply to message #95830] Wed, 02 July 2008 13:31 Go to previous messageGo to next message
<br><font size=2 face="sans-serif">By the way - is it planned to have the
browser send a last event when it is closed ?</font>
<br>
<br><font size=2 face="sans-serif">We usually have long running sessions
and most user just don't care about closing the Shell but just close the
browser.</font>
<br><font size=2 face="sans-serif">Then they restart the app because they
forgot something and the memory consumptions increases unnecessarily.</font>
<br>
<br>
<br>
Re: preWindowShellClose is not called [message #95950 is a reply to message #95936] Wed, 02 July 2008 16:01 Go to previous messageGo to next message
stefan.hansel@tolina.de wrote:
> By the way - is it planned to have the browser send a last event when it
> is closed ?
My guess, it's impossible.
Re: preWindowShellClose is not called [message #95994 is a reply to message #95936] Wed, 02 July 2008 16:35 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
I share Dmitrys doubts, it is at least hard to achieve and likely to
not work reliably in all situations.
As this topic was raised before, please also see this newsgroup
(session, timeout, invalidate, free, memory, etc) for discussions
about ideas and thoughts on this.
Cheers
Rüdiger
> is closed ?
> We usually have long running sessions and most user just don't care
> about closing the Shell but just close the browser.
> Then they restart the app because they forgot something and the memory
Re: preWindowShellClose is not called [message #96217 is a reply to message #95994] Thu, 03 July 2008 04:30 Go to previous messageGo to next message
<br><font size=2 face="sans-serif">Searched a while but indeed found no
suitable solution.</font>
<br>
<br><font size=2 face="sans-serif">Let's think a different way about those
two competing requirements:</font>
<br><font size=2 face="sans-serif">- we want to have long (maybe even neverending)
sessions ... users need to have time to get their coffee and beeing disturbed
by long telephone calls and then go on working in the app</font>
<br><font size=2 face="sans-serif">- if the users kill their browser we
want the session to die as soon as possible</font>
<br>
<br><font size=2 face="sans-serif">Wouldn't it be possible to write an
invisible 'keep alive' widget - this just pings the server say every &nbsp;10
minutes ?</font>
<br><font size=2 face="sans-serif">We could then configure the servers
timeout to say 15minutes.</font>
<br>
<br><font size=2 face="sans-serif">Nevertheless - as long as the user keeps
his browser window open, the session would not die at all. </font>
<br><font size=2 face="sans-serif">If he closes the browser or gets disconnected
from the network server resources are not held too long.</font>
<br>
<br><font size=2 face="sans-serif">This could even be done as a feature
of the shell, having an extra widget would just be a workaround.</font>
Re: preWindowShellClose is not called [message #96232 is a reply to message #96217] Thu, 03 July 2008 05:05 Go to previous messageGo to next message
Hi Stefan,
sorry to point you to nowhere. I cannot recall anymore where this
discussion happened, maybe on a bug or the mailing list.
Anyway, the keep-alive widget was discussed there and sounds like a
reasonable approach. Though I would consider this as an application
requirement and therefore should not be provided by RAP.
Note that implementing the keep-alive as a widget will likely cause
layouting issues. You might be better off using a similar approach
as the ExternalBrowser does. See also the 'custom widgets: life
cycle adapters and frequent client side activities' thread.
Rüdiger
> Searched a while but indeed found no suitable solution.
> Let's think a different way about those two competing requirements:
> - we want to have long (maybe even neverending) sessions ... users need
> to have time to get their coffee and beeing disturbed by long telephone
> - if the users kill their browser we want the session to die as soon as
> possible
> Wouldn't it be possible to write an invisible 'keep alive' widget - this
> just pings the server say every 10 minutes ?
> We could then configure the servers timeout to say 15minutes.
> Nevertheless - as long as the user keeps his browser window open, the
> If he closes the browser or gets disconnected from the network server
> This could even be done as a feature of the shell, having an extra
Re: preWindowShellClose is not called [message #96384 is a reply to message #96232] Thu, 03 July 2008 09:01 Go to previous messageGo to next message
<br><font size=2 face="sans-serif">Hhmm - sound's not tooo complicated:
</font>
<br>
<br><font size=2 face="sans-serif">1) writing and configuration a dummy-servlet
(working as 'ping-destination'), so that I don't interfere with RAP</font>
<br><font size=2 face="sans-serif">2) registering a PhaseListener that
(once) sends a javascript to the browser, which regularly pings the dummy-servlet
</font>
<br>
<br><font size=2 face="sans-serif">I'll give that a try in the near future.</font>
Re: preWindowShellClose is not called [message #96456 is a reply to message #96384] Thu, 03 July 2008 09:31 Go to previous messageGo to next message
Stefan,
it should work this way. You're welcome to share your results here.
Cheers
Rüdiger
> 1) writing and configuration a dummy-servlet (working as
> 2) registering a PhaseListener that (once) sends a javascript to the
Re: preWindowShellClose is not called [message #96656 is a reply to message #95830] Fri, 04 July 2008 02:01 Go to previous message
Hi all,
Dmitry Pryadkin schrieb:
> Hello Diman
Just one remark. When deploying your RAP app in an application
container, you can set a reasonable time-out for your session, e.g. one
hour. You still have the problem of a closed browser window but it
would'n manifest itself that dramatic as it sounds when reading this
thread...
Stefan.
Previous Topic:Change actionSet button state programatically
Next Topic:[ANN] Upcoming CVS Structure Reorganization
Current Time: Tue Jul 15 15:31:28 EDT 2025
Powered by FUDForum. Page generated in 0.06738 seconds
