Home » Archived » Visual Editor (VE) » VE I20050630 & Eclipse 3.1
VE I20050630 & Eclipse 3.1 [message #95603] Fri, 01 July 2005 08:37 Go to next message
I'm testing VE I20050630 with Eclipse 3.1 final and it seems there are
several problems with GDI+. Tipically "Unable to load graphics library
[GDI+ is required] (java.lang.NoClassDefFoundError)" and a suite of
"Unhandled event loop exception".
I'm unable to see a new created JFrame.
I use a clean Elcipse installation with a new and clean workspace. I'm
testing VE SDK.
So, I thing the previous nightly build (N20050621) works better with 3.1
final.
Francesc Rosés
Re: VE I20050630 & Eclipse 3.1 [message #95618 is a reply to message #95603] Fri, 01 July 2005 09:03 Go to previous messageGo to next message
Francesc,
I tried the same using VE I20050630, Eclipse 3.1, EMF 2.1RC0, and GEF I20050630.
I am also using JDK 1.4.2_7 as my JRE. I created a new class extending JFrame
and it showed successfully in the graph viewer although I did get some
exceptions in the log file (which I am investigating). But the exceptions are
not the same as yours. It was a problem with osgi.. an error while loading class
"org.eclipse.jdt.internal.debug.ui.DebugUIMessages". I didn't see this last
night when I tested this driver before publishing the driver. Somehow slipped
through the cracks.
Are you working with the same VE pre-reqs (i.e. GEF, EMF)?
Could also post the log file (if it's not too big) so I can examine your stack
trace.
Thanks...
Peter Walker
VE Development
Francesc Rosés wrote:
> Hello,
> testing VE SDK.
> final.
> Francesc Rosés
Re: VE I20050630 & Eclipse 3.1 [message #95632 is a reply to message #95618] Fri, 01 July 2005 09:18 Go to previous messageGo to next message
FYI... I open bug 102474 (https://bugs.eclipse.org/bugs/show_bug.cgi?id=102474)
to track the exceptions I got. Seems to occur only once... for the first time
creating a class.
Regards...
Peter Walker
VE Development
Peter Walker wrote:
> Francesc,
> I20050630. I am also using JDK 1.4.2_7 as my JRE. I created a new class
> extending JFrame and it showed successfully in the graph viewer although
> I did get some exceptions in the log file (which I am investigating).
> But the exceptions are not the same as yours. It was a problem with
> last night when I tested this driver before publishing the driver.
> Somehow slipped through the cracks.
> stack trace.
> Thanks...
> Peter Walker
> VE Development
>> Hello,
>> testing VE SDK.
>> 3.1 final.
>> Regards,
>> Francesc Rosés
Re: VE I20050630 & Eclipse 3.1 [message #95661 is a reply to message #95603] Fri, 01 July 2005 10:00 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
What os are you on? We are now using the advanced graphics (alpha
blending) and that requires some new libraries. It may be that your os
doesn't have the necessary libraries. Please append the .log so we can
see where it occurred. We may have to put tests in or work Eclipse such
that we don't get the error if the library is not found. We ourselves
are not directly referencing GDI+.
> Hello,
> testing VE SDK.
> final.
> Francesc Rosés
Rich Kulp
Re: VE I20050630 & Eclipse 3.1 [message #95674 is a reply to message #95661] Fri, 01 July 2005 10:50 Go to previous messageGo to next message
I just looked it up. GDI+ is for Windows. It is automatically included
with WinXP.
See
http://fullmoon.rtp.raleigh.ibm.com/downloads/drops/R-3.1-20 0506271435/eclipse-news-part1c.html
Go to the AdvancedGraphics section.
However, we need to be more graceful about it, so the .log file would
still be useful.
Rich Kulp
Re: VE I20050630 & Eclipse 3.1 [message #95688 is a reply to message #95674] Fri, 01 July 2005 11:41 Go to previous messageGo to next message
Correct the link:
http://download.eclipse.org/downloads/drops/R-3.1-2005062714 35/eclipse-news-part1c.html
We have some internal mirroring that happens automatically. :-)
Rich Kulp
Re: VE I20050630 & Eclipse 3.1 [message #95720 is a reply to message #95661] Sat, 02 July 2005 02:56 Go to previous messageGo to next message
I use W2K.
Francesc
Re: VE I20050630 & Eclipse 3.1 [message #95736 is a reply to message #95674] Sat, 02 July 2005 03:07 Go to previous messageGo to next message
Rich Kulp wrote:
> See
It seems the URL don't works for me.
Voila the log file:
============================ cut here ============================
!SESSION 2005-07-02 08:56:02.375
eclipse.buildId=I20050627-1435
java.version=1.5.0_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=es_ES
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.resources 2 1 2005-07-02 08:57:21.312
!MESSAGE Skipping builder com.omondo.uml.std.Builder for project JFTF2.
Either the builder is missing from the install, or it belongs to a project
nature that is missing or disabled.
!ENTRY org.eclipse.ve.java.core 2 0 2005-07-02 08:57:45.93
!MESSAGE
+++ Warning +++: Sat Jul 02 08:57:45 CEST 2005 Bad Object: int:
=JDK5_TESTS/<jdk5.tests.gui{MyFrame.java[MyFrame~calculateAge^currDay
!ENTRY org.eclipse.ve.java.core 2 0 2005-07-02 08:57:45.125
!MESSAGE
=JDK5_TESTS/<jdk5.tests.gui{MyFrame.java[MyFrame~calculateAge^dow
!ENTRY org.eclipse.ve.java.core 2 0 2005-07-02 08:57:45.140
!MESSAGE
=JDK5_TESTS/<jdk5.tests.gui{MyFrame.java[MyFrame~calculateAge^bdDay
!ENTRY org.eclipse.ve.java.core 2 0 2005-07-02 08:57:45.156
!MESSAGE
=JDK5_TESTS/<jdk5.tests.gui{MyFrame.java[MyFrame~calculateAge^currYear
!ENTRY org.eclipse.ve.java.core 2 0 2005-07-02 08:57:45.203
!MESSAGE
=JDK5_TESTS/<jdk5.tests.gui{MyFrame.java[MyFrame~calculateAge^bdMonth
!ENTRY org.eclipse.ve.java.core 2 0 2005-07-02 08:57:45.218
!MESSAGE
=JDK5_TESTS/<jdk5.tests.gui{MyFrame.java[MyFrame~calculateAge^currMonth
!ENTRY org.eclipse.ve.java.core 2 0 2005-07-02 08:57:45.234
!MESSAGE
=JDK5_TESTS/<jdk5.tests.gui{MyFrame.java[MyFrame~calculateAge^years
!ENTRY org.eclipse.ve.java.core 2 0 2005-07-02 08:57:45.281
!MESSAGE
=JDK5_TESTS/<jdk5.tests.gui{MyFrame.java[MyFrame~calculateAge^bdYear
!ENTRY org.eclipse.ui 4 4 2005-07-02 08:57:59.171
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-07-02 08:57:59.171
!MESSAGE Unable to load graphics library [GDI+ is required]
(java.lang.UnsatisfiedLinkError:
C:\Aplic\ECLIPSE31\eclipse\configuration\org.eclipse.osgi\bu ndles\100\1\.cp\swt-gdip-win32-3138.dll:
Can't find dependent libraries)
!STACK 0
org.eclipse.swt.SWTException: Unable to load graphics library [GDI+ is
required] (java.lang.UnsatisfiedLinkError:
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.graphics.Device.checkGDIP(Device.java:175)
at org.eclipse.swt.graphics.GC.initGdip(GC.java:3193)
at org.eclipse.swt.graphics.GC.setAlpha(GC.java:3442)
at org.eclipse.draw2d.SWTGraphics.setAlpha(SWTGraphics.java:912 )
org.eclipse.ve.internal.cde.core.OutlineBorder.paint(Outline Border.java:68)
at org.eclipse.draw2d.Figure.paintBorder(Figure.java:1070)
at org.eclipse.draw2d.Figure.paint(Figure.java:1056)
at org.eclipse.draw2d.Figure.paintChildren(Figure.java:1091)
at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1123)
at org.eclipse.draw2d.Figure.paint(Figure.java:1055)
org.eclipse.ve.internal.cde.core.ImageFigure.paintClientArea (ImageFigure.java:112)
org.eclipse.draw2d.ScalableFreeformLayeredPane.paintClientAr ea(ScalableFreeformLayeredPane.java:61)
at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1118)
at org.eclipse.draw2d.Viewport.paintClientArea(Viewport.java:15 6)
org.eclipse.draw2d.DeferredUpdateManager.repairDamage(Deferr edUpdateManager.java:225)
org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager.java:145)
org.eclipse.draw2d.DeferredUpdateManager$UpdateRequest.run(D eferredUpdateManager.java:40)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.msgFilterProc(Display.java:2 505)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:1651 )
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:203)
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:2389)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3706 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:16 56)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2711)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.UnsatisfiedLinkError:
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:12 3)
at org.eclipse.swt.internal.gdip.Gdip.<clinit>(Gdip.java:17)
at org.eclipse.swt.graphics.Device.checkGDIP(Device.java:171)
... 82 more
!ENTRY org.eclipse.ui 4 4 2005-07-02 08:58:41.187
!ENTRY org.eclipse.ui 4 0 2005-07-02 08:58:41.187
!STACK 0
org.eclipse.draw2d.LightweightSystem.controlResized(Lightwei ghtSystem.java:147)
org.eclipse.draw2d.LightweightSystem$3.controlResized(Lightw eightSystem.java:123)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:149)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:848)
at org.eclipse.swt.widgets.Control.WM_SIZE(Control.java:3650)
at org.eclipse.swt.widgets.Scrollable.WM_SIZE(Scrollable.java:3 19)
at org.eclipse.swt.widgets.Composite.WM_SIZE(Composite.java:123 7)
at org.eclipse.swt.widgets.Canvas.WM_SIZE(Canvas.java:253)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3107 )
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable .java:77)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3123 )
at org.eclipse.swt.internal.win32.OS.EndDeferWindowPos(Native Method)
at org.eclipse.swt.widgets.Composite.resizeChildren(Composite.j ava:653)
at org.eclipse.swt.widgets.Composite.resizeChildren(Composite.j ava:619)
org.eclipse.swt.widgets.Composite.setResizeChildren(Composit e.java:786)
at org.eclipse.swt.widgets.Composite.WM_SIZE(Composite.java:125 2)
at org.eclipse.swt.internal.win32.OS.SetWindowPos(Native Method)
at org.eclipse.swt.widgets.Widget.SetWindowPos(Widget.java:1140 )
at org.eclipse.swt.widgets.Control.setBounds(Control.java:1952)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:1933)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:1929)
at org.eclipse.swt.layout.FillLayout.layout(FillLayout.java:198 )
at org.eclipse.swt.widgets.Composite.updateLayout(Composite.jav a:869)
at org.eclipse.swt.widgets.Composite.WM_SIZE(Composite.java:124 8)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:1999)
org.eclipse.ui.internal.PartSashContainer.setBounds(PartSash Container.java:795)
at org.eclipse.ui.internal.LayoutTree.doSetBounds(LayoutTree.ja va:543)
at org.eclipse.ui.internal.LayoutTree.setBounds(LayoutTree.java :534)
org.eclipse.ui.internal.LayoutTreeNode.doSetBounds(LayoutTre eNode.java:477)
org.eclipse.ui.internal.LayoutTreeNode.doSetBounds(LayoutTre eNode.java:513)
org.eclipse.ui.internal.LayoutTreeNode.doSetBounds(LayoutTre eNode.java:514)
org.eclipse.ui.internal.LayoutTreeNode.doSetBounds(LayoutTre eNode.java:482)
org.eclipse.ui.internal.PartSashContainer.resizeSashes(PartS ashContainer.java:753)
org.eclipse.ui.internal.PartSashContainer.access$1(PartSashC ontainer.java:744)
org.eclipse.ui.internal.PartSashContainer$1.controlResized(P artSashContainer.java:166)
at org.eclipse.swt.custom.StackLayout.layout(StackLayout.java:1 16)
at org.eclipse.swt.widgets.Decorations.WM_SIZE(Decorations.java :1761)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1582)
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:410)
Caused by: java.lang.NoClassDefFoundError
... 247 more
!ENTRY org.eclipse.ui 4 4 2005-07-02 08:58:41.218
!ENTRY org.eclipse.ui 4 0 2005-07-02 08:58:41.218
!STACK 0
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
... 69 more
Re: VE I20050630 & Eclipse 3.1 [message #95750 is a reply to message #95688] Sat, 02 July 2005 04:25 Go to previous messageGo to next message
Hello Rich,
I know VE team only uses SWT and is SWT who
needs GDI+. I know Eclipse 3.1 only supports
Windows XP but, there are a lot of developpers
using W2K because they (I) think XP is not
reliable. So, I think my be useful to
explain how to obtain and install,
if possible, GDI+.
I think is important to explain in "New and Noteworthy"
or in the VE I20050630 notes W2K is not supported
and may be 3.1 or related products (like VE) don't
works on W2K.
Francesc Rosés
Re: VE I20050630 & Eclipse 3.1 [message #95789 is a reply to message #95736] Sat, 02 July 2005 12:46 Go to previous messageGo to next message
I appended again with a corrected URL.
Rich Kulp
Re: VE I20050630 & Eclipse 3.1 [message #95802 is a reply to message #95736] Sat, 02 July 2005 12:56 Go to previous messageGo to next message
It is not that we require WinXP. It is just we used the new advanced
graphics (alphas in images) but we didn't know that SWT didn't
gracefully handle not having the advanced graphics. It throws an
unexpected exception which we didn't know about.
We want to be graceful about this and not just crash like this, but you
were the first one to have this problem and so we didn't know about it.
We'll see what we can do to make it fail gracefully, but you can get
GDI+ from Microsoft(R) using the correct link that just appended, and
not the bad one. :-)
Rich Kulp
Re: VE I20050630 & Eclipse 3.1 [message #95831 is a reply to message #95603] Sat, 02 July 2005 20:21 Go to previous messageGo to next message
> Hello,
> testing VE SDK.
> final.
> Francesc Rosés
I got a similar problem under Linux, (Cairo required/not found), the
solution was to add the eclipse directory, which includes libcairo, in
my LD_LIBRARY_PATH in my run_eclipse script.
Re: VE I20050630 & Eclipse 3.1 [message #95846 is a reply to message #95802] Sat, 02 July 2005 20:29 Go to previous message
Hi Rich,
I think the strategy you propose is OK.
Thanks a lot,
Francesc
P.S.: I downloaded a copy of GDI+ and VE works.
Re: VE I20050630 & Eclipse 3.1 [message #608894 is a reply to message #95603] Fri, 01 July 2005 09:03 Go to previous message
Francesc,
through the cracks.
trace.
Thanks...
Peter Walker
VE Development
> Hello,
> testing VE SDK.
> final.
> Francesc Rosés
Re: VE I20050630 & Eclipse 3.1 [message #608898 is a reply to message #95618] Fri, 01 July 2005 09:18 Go to previous message
creating a class.
Regards...
Peter Walker
VE Development
Peter Walker wrote:
> Francesc,
> stack trace.
> Thanks...
> Peter Walker
> VE Development
>> Hello,
>> testing VE SDK.
>> 3.1 final.
>> Regards,
>> Francesc Rosés
Re: VE I20050630 & Eclipse 3.1 [message #608906 is a reply to message #95603] Fri, 01 July 2005 10:00 Go to previous message
> Hello,
> testing VE SDK.
> final.
> Francesc Rosés
Rich Kulp
Re: VE I20050630 & Eclipse 3.1 [message #608908 is a reply to message #95661] Fri, 01 July 2005 10:50 Go to previous message
with WinXP.
See
still be useful.
Rich Kulp
Re: VE I20050630 & Eclipse 3.1 [message #608910 is a reply to message #95674] Fri, 01 July 2005 11:41 Go to previous message
Correct the link:
Rich Kulp
Re: VE I20050630 & Eclipse 3.1 [message #608914 is a reply to message #95661] Sat, 02 July 2005 02:56 Go to previous message
I use W2K.
Francesc
Re: VE I20050630 & Eclipse 3.1 [message #608915 is a reply to message #95674] Sat, 02 July 2005 03:07 Go to previous message
Rich Kulp wrote:
> See
Voila the log file:
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!STACK 0
... 82 more
!STACK 0
... 247 more
!STACK 0
... 69 more
Re: VE I20050630 & Eclipse 3.1 [message #608917 is a reply to message #95688] Sat, 02 July 2005 04:25 Go to previous message
Hello Rich,
if possible, GDI+.
works on W2K.
Francesc Rosés
Re: VE I20050630 & Eclipse 3.1 [message #608922 is a reply to message #95736] Sat, 02 July 2005 12:46 Go to previous message
Rich Kulp
Re: VE I20050630 & Eclipse 3.1 [message #608923 is a reply to message #95736] Sat, 02 July 2005 12:56 Go to previous message
Rich Kulp
Re: VE I20050630 & Eclipse 3.1 [message #608927 is a reply to message #95603] Sat, 02 July 2005 20:21 Go to previous message
> Hello,
> testing VE SDK.
> final.
> Francesc Rosés
Re: VE I20050630 & Eclipse 3.1 [message #608929 is a reply to message #95802] Sat, 02 July 2005 20:29 Go to previous message
Hi Rich,
Thanks a lot,
Francesc
Previous Topic:Ask for explanations VE
Next Topic:Installing VE for Eclipse 3.1 final?
Current Time: Fri Sep 12 15:30:03 EDT 2025
Powered by FUDForum. Page generated in 0.06711 seconds
