Home » Archived » Test and Performance Tools Platform (TPTP) » NoClassDefFoundError while using probe through plugin
NoClassDefFoundError while using probe through plugin [message #95399] Wed, 11 April 2007 11:44 Go to next message
Hi there,
i am still working on using ProbeKit to create a dynamic callgraph
(remember?). Meanwhile i succeeded in creating the callgraph by using the
probe directly in my plugin development project (probing a little
testclass). Now i would like it buid this into my plugin.
First i had to learn, that i have to register the probe with every new
eclipse instance (right? are there other possibilities?). I accomplished
that by exporting the probe to a probekit file and importing it
programmatically while starting my plugin in the new eclipse instance (using
ProbekitRegistry). Now the probe is present in the profile launch
configuration (marked as imported).
So far so good ... if i start profiling i unfortuantely get a
NoClassDefFoundError. My generated probe looks like this:
<codeExample>
// generated source from Probekit compiler
// "imports" specifications for probes (if any):
import java.util.HashMap; // from unnamed_probe
import java.util.Stack; // from unnamed_probe
import java.util.EmptyStackException; // from unnamed_probe
import org.projectory.ezunit.internal.callgraph.CallgraphElement; // from
unnamed_probe
import org.projectory.ezunit.internal.callgraph.CallgraphManager; // from
unnamed_probe
public static void _entry(String /* className */className,
String /* methodName */methodName, String /* methodSig */methodSig,
Object /* thisObject */thisObject, Object[] /* args */args,
String /* classSourceFile */classSourceFile,
String /* methodNames */methodNames,
String /* methodLineTables */methodLineTables,
int /* methodNumber */methodNumber)
// Internal signature for this method:
(Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava /lang/Object;[Ljava/lang/Object;Ljava/lang/String;Ljava/lang /String;Ljava/lang/String;I)V
// ------------------ begin user-written fragment
code ----------------
Stack<CallgraphElement> stack = map.get(Long.valueOf(Thread
.currentThread().getId()));
if (stack == null)
stack = new Stack<CallgraphElement>();
map.put(Long.valueOf(Thread.currentThread().getId()), stack);
CallgraphElement parentElement = null;
CallgraphElement currentElement = new CallgraphElement(className,
methodName, methodSig, thisObject, args, classSourceFile,
methodNames, methodLineTables, methodNumber);
if (!stack.empty())
parentElement = stack.peek();
synchronized (stack)
CallgraphManager.getInstance().getCallgraph().enter(currentE lement,
parentElement);
stack.push(currentElement);
// ------------------- end user-written fragment
code -----------------
</codeExample>
And as you could image the classes "CallgraphElement" and "CallgraphManager"
could not be found.
Furthermore i exported the specific package of my plugin to a jar and put a
reference to any location that might make sense to me (e.g. buildPath,
ClassPath in Profiling launch configuration).
No success. Probably you could give a hint where to put the classes to.
Thanks in advance,
Thomas E.-E.
Re: NoClassDefFoundError while using probe through plugin [message #95567 is a reply to message #95399] Thu, 12 April 2007 10:25 Go to previous messageGo to next message
Originally posted by: nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 004F3958852572BB_=
Content-Type: text/plain; charset="US-ASCII"
Hi Thomas,
The Probekit classes are loaded by the boot classloader in order to allow
Probekit to instrument java.* classes. If your probe class references any
other classes, it won't be able to "see" them unless they're also loaded
in the boot class loader. Thus, specifying the external classes under
your system classpath is not sufficient. They have to be loaded by the
boot classloader. You can load your external classes in the boot
classloader by specifying the following VM argument:
-Xbootclasspath/a:<path>
Navid Mehregani
nmehrega@ca.ibm.com
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Hi Thomas,</font>
<br>
<br><font size=2 face="sans-serif">The Probekit classes are loaded by the
boot classloader in order to allow Probekit to instrument java.* classes.
&nbsp;If your probe class references any other classes, it won't be able
to &quot;see&quot; them unless they're also loaded in the boot class loader.
&nbsp;Thus, specifying the external classes under your system classpath
is not sufficient. &nbsp;They have to be loaded by the boot classloader.
&nbsp;You can load your external classes in the boot classloader by specifying
the following VM argument: -Xbootclasspath/a:&lt;path&gt;</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
<br><font size=2 face="sans-serif">nmehrega@ca.ibm.com</font>
--=_alternative 004F3958852572BB_=--
Re: NoClassDefFoundError while using probe through plugin [message #95625 is a reply to message #95567] Thu, 12 April 2007 11:26 Go to previous message
------=_NextPart_000_015B_01C77D27.C28EBF40
charset="iso-8859-1"
Hi Navid,
that did the job! Thanks a lot!
Thomas E.-E.
"Navid_Mehregani" <nmehrega@ca.ibm.com> schrieb im Newsbeitrag =
news:evlfgg$riv$1@build.eclipse.org...
Hi Thomas,=20
The Probekit classes are loaded by the boot classloader in order to =
allow Probekit to instrument java.* classes. If your probe class =
references any other classes, it won't be able to "see" them unless =
they're also loaded in the boot class loader. Thus, specifying the =
external classes under your system classpath is not sufficient. They =
have to be loaded by the boot classloader. You can load your external =
classes in the boot classloader by specifying the following VM argument: =
-Xbootclasspath/a:<path>=20
Navid Mehregani=20
nmehrega@ca.ibm.com
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.6000.16414" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Hi Navid,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>that did the job! Thanks a =
lot!</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Cheers,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thomas E.-E.</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Navid_Mehregani" &lt;<A=20
href=3D"mailto:nmehrega@ca.ibm.com">nmehrega@ca.ibm.com</A>&gt; =
schrieb im=20
Newsbeitrag <A=20
href=3D"news:evlfgg$riv$1@build.eclipse.org">news:evlfgg$riv$1@build.ecli=
pse.org</A>...</DIV><BR><FONT=20
face=3Dsans-serif size=3D2>Hi Thomas,</FONT> <BR><BR><FONT =
face=3Dsans-serif=20
size=3D2>The Probekit classes are loaded by the boot classloader in =
order to=20
allow Probekit to instrument java.* classes. &nbsp;If your probe class =
they're=20
also loaded in the boot class loader. &nbsp;Thus, specifying the =
external=20
classes under your system classpath is not sufficient. &nbsp;They have =
to be=20
loaded by the boot classloader. &nbsp;You can load your external =
classes in=20
the boot classloader by specifying the following VM argument:=20
-Xbootclasspath/a:&lt;path&gt;</FONT> <BR><BR><FONT face=3Dsans-serif=20
size=3D2>Navid Mehregani</FONT> <BR><FONT face=3Dsans-serif=20
size=3D2>nmehrega@ca.ibm.com</FONT></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_015B_01C77D27.C28EBF40--
Previous Topic:Location of Trace Metamodel
Next Topic:ProbekitPlugin does not register it's debug tracing options to eclipses' generic tracing facility
Current Time: Sat Jul 26 00:05:13 EDT 2025
Powered by FUDForum. Page generated in 0.03377 seconds
