Home » Eclipse Projects » Equinox » Using Extension Registry without OSGi
Using Extension Registry without OSGi [message #95291] |
Mon, 20 August 2007 10:52  |
Originally posted by: kaputin.uk.ibm.com
I'm looking at using the Eclipse Extension Registry within my application to
configure extensions, but I'd like to use it 'stand alone' - independently
of OSGi and the Eclipse Platform. I have a question about a dependency on an
OSGi jar file.
I have some code that instantiates an IExtensionRegistry via RegistryFactory
and calls IExtensionRegistry.addContribution to load my plugin.xml. This
code works, but it requires the following jar files on the classpath:
* org.eclipse.equinox.common_3.2.0.v20060603.jar
* org.eclipse.equinox.registry_3.2.1.R32x_v20060814.jar
* org.eclipse.osgi_3.2.1.R32x_v20060919.jar
The two equinox jars are fine. The osgi jar is required for the NLS.class
file loaded by the addContribution method. If I remove this jar from the
classpath I get an exception:
Exception in thread "main" java.lang.NoClassDefFoundError:
org/eclipse/osgi/util/NLS
The osgi jar is large (830K) compared to the equinonx jars (78K and 141K).
Is there any way I can avoid this dependency on the osgi jar? Perhaps there
is a different programming model I should be using?
Here's the relevant fragment from my code:
RegistryStrategy s = new RegistryStrategy(null, null);
IExtensionRegistry registry = RegistryFactory.createRegistry(s,
null, null);
InputStream is;
try {
is = new
FileInputStream(" C:\\workspace\\woden\\jktest\\src\\org\\apache\\woden\\inter nal\\wsdl20\\extensions\\plugin.xml ");
} catch (FileNotFoundException e) {
System.out.println(" plugin.xml can not be found.");
return;
IContributor c = new RegistryContributor("1","org.apache.woden",
null, null);
if (registry.addContribution(is, c, false, null, null, null)) {
System.out.println(" plugin added");
thanks,
John Kaputin.
Re: Using Extension Registry without OSGi [message #95493 is a reply to message #95291] |
Tue, 21 August 2007 05:46   |
You need to get hold of org.eclipse.equinox.supplement bundle:
http://www.eclipse.org/equinox/bundles/
This will enable you to use the Registry outside of OSGi or on another
OSGi implementation.
> OSGi jar file.
> null, null);
> InputStream is;
> try {
> is = new
> return;
> null, null);
> thanks,
> John Kaputin.
Re: Using Extension Registry without OSGi [message #95849 is a reply to message #95493] |
Fri, 24 August 2007 09:26  |
Danail is 100% correct, the additional code is located in the
org.eclipse.equinox.supplement bundle. There is a code in the equinox
incubator that does this for testing purposes:
http://wiki.eclipse.org/Equinox_Testing_-_3.3#Part_IV._Stand alone_registry_run
The test plugin org.eclipse.equinox.test.standalone checks standalone
(non-OSGi) registry and can be found in the CVS
:pserver:anonymous@dev.eclipse.org:/cvsroot/eclipse
under equinox-incubator/tests.
Sincerely,
Oleg Besedin
"Danail Nachev" <d_nachev@prosyst.bg> wrote in message
news:faecaf$phr$1@build.eclipse.org...
>> to
>> independently
>> an
>> OSGi jar file.
>> RegistryFactory
>> 141K).
>> there
>> null, null);
>> InputStream is;
>> try {
>> is = new
>> return;
>> null, null);
>> thanks,
>> John Kaputin.
Current Time: Sun Aug 31 01:21:57 EDT 2025
Powered by FUDForum. Page generated in 0.04005 seconds
