Home » Newcomers » Newcomers » Hovering is not wroking anymore
Hovering is not wroking anymore [message #95195] Tue, 16 August 2005 03:56 Go to next message
Originally posted by: iftaeclipse.robf.de
Somewhere during the transition from 3.0 to 3.1 hovering stopped to
work for me, i.e. the mouse pointer over an error does not display
the error message anymore, nor the java doc for a method etc...
I am using Version: 3.1.0, Build id: I20050627-1435 on Windows XP.
When opening the same workspace as another user hovering works fine.
Therefore, I have reset all my preferences to the defaults, but this
does not help. Also deleting and unpacking the eclipse ZIP does not
change anything. I also killed all other programs, e.g. LogiTray for
the mouse, autohotkey, ... nothing helped.
Where does eclipse store my preferences? I want to nuke them!
Robert.
Re: Hovering is not wroking anymore [message #95804 is a reply to message #95195] Thu, 18 August 2005 12:34 Go to previous messageGo to next message
I don't think the prefs are a problem here. Try the following: start a
fresh workspace by using -data c:\testWorkspace and check whether the
hovers work. Do the native hovers work?
Dani
> Robert.
Re: Hovering is not wroking anymore [message #96989 is a reply to message #95804] Wed, 24 August 2005 02:13 Go to previous messageGo to next message
> fresh workspace by using -data c:testWorkspace and check whether the
> hovers work.
No, they do not work with a new workspace,
but it works when I open the same workspace
with the same eclipse, but loggeding as another
user.
What are the native ones?
Preferences > Java > Editor > Hovers?
Robert.
Re: Hovering is not wroking anymore [message #97006 is a reply to message #96989] Wed, 24 August 2005 03:02 Go to previous message
I finally found the source of my problem.
Tweak UI > Mouse > Hover > Hover sensitivity: 0
Setting it to values greater than 0 helps a lot :-/
Unfortunately hovering was working for other programs
also when it was set to 0 ... but those probably use
their own mechanism.
Sorry for the noise.
Previous Topic:Any plugin or tool to test Eclipse Plugins developed
Next Topic:Hidden tag
Current Time: Wed Jul 16 18:20:47 EDT 2025
Powered by FUDForum. Page generated in 0.09324 seconds
