Home » Eclipse Projects » GEF » DnD: UI freezes when after drop
DnD: UI freezes when after drop [message #95128] Tue, 23 September 2003 17:47 Go to next message
Originally posted by: dlemmermann.rcn.com
Hi there,
I have a problem with drag and drop in GEF. I am just getting started on GEF
and I managed to create a graphical viewer with some edit parts and figures
inside of it. All I am trying to do now is add a drop listener to the viewer
and print out some message that tells me that a drop has occurred.
Unfortunately I don't even get this to work. After dragging a file (or
anything else) from the Navigator to the editor the UI just hangs and I need
to kill the runtime workbench process in order to continue working. My code
is nothing more than this:
protected void initializeGraphicalViewer() {
GraphicalViewer viewer = getGraphicalViewer();
viewer.setContents(myModel); // PSEUDO
viewer.addDropTargetListener(new MyDropListener(viewer));
class MyDropListener extends AbstractTransferDropListener {
public MyDropListener(GraphicalViewer viewer) {
super(viewer);
protected void updateTargetRequest() {
System.out.println("Updating request....");
Am I missing something? Any help much appreciated.....
Dirk
P.S.: the main thread seems to be hanging in a native method call to
COM.DoDragDrop. All other threads are either in sleep() or in wait().
Re: UI freezes when after drop [message #95143 is a reply to message #95128] Tue, 23 September 2003 21:46 Go to previous messageGo to next message
Which version of Eclpise/SWT are you using?
"Dirk Lemmermann" <dlemmermann@rcn.com> wrote in message
news:BB968C1B.1645%dlemmermann@rcn.com...
> Hi there,
GEF
figures
viewer
need
code
> super(viewer);
> Dirk
Re: UI freezes when after drop [message #95233 is a reply to message #95143] Wed, 24 September 2003 13:24 Go to previous messageGo to next message
Yes, version information would help, I guess :-) .... Sorry about that!
Eclipse 2.1.1
SWT 2.1.1
GEF 2.1.1
Dirk
On 9/24/03 3:46 AM, in article bkqsvc$g1a$1@eclipse.org, "Randy Hudson"
>> Hi there,
> GEF
> figures
> viewer
> need
> code
>> super(viewer);
>> Dirk
Re: UI freezes when after drop [message #95289 is a reply to message #95233] Wed, 24 September 2003 16:19 Go to previous messageGo to next message
Actually, I was hoping you were using something less stable, like 3.0. We
have not seen this problem before. Are any plugins being activated during
the DND process?
Can you open a bugzilla with steps to reproduce. Platform/window manager is
also important info.
"Dirk Lemmermann" <dirk@dlsc.com> wrote in message
news:BB979FD9.18BB%dirk@dlsc.com...
> Eclipse 2.1.1
> SWT 2.1.1
> GEF 2.1.1
> Dirk
> >> Hi there,
on
> > GEF
> > figures
> > viewer
> > need
> > code
> >> super(viewer);
> >> Dirk
Re: UI freezes when after drop [message #95303 is a reply to message #95289] Wed, 24 September 2003 16:51 Go to previous messageGo to next message
How can I find out which plugins get activated? I tried activating the
GEF.debug methods but it doesn't even get to the point where those debug
infos get printed.
I'll invest this problem a little bit more. I don't think that I can provide
any meaningful input to bugzilla (at this point in time) that would allow
you to recreate this problem.
I'll be back!
Dirk
On 9/24/03 10:19 PM, in article bksu6b$g62$1@eclipse.org, "Randy Hudson"
> the DND process?
>> Eclipse 2.1.1
>> SWT 2.1.1
>> GEF 2.1.1
>> Dirk
>>>> Hi there,
> on
>>> GEF
>>> figures
>>> viewer
>>> need
>>> code
>>>> super(viewer);
>>>> Dirk
Re: DnD: UI freezes when after drop [message #95348 is a reply to message #95128] Thu, 25 September 2003 03:48 Go to previous messageGo to next message
I'm not sure, if my problem is really related, but ...
I've got a quite similiar situation. Dragging from my own view to
a GraphicalEditor will not only hang the main thread, but crash the
whole VM.
The error message looks like this:
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION occurred at PC=0x77B13E23
Function=DllDebugObjectRPCHook+0x421
Library=C:\WINNT\system32\ole32.dll
Andreas
P.S. I'm still at Version 2.1.0 ...
+ Andreas Rummler +
+ Technical University of Ilmenau, Germany (__) +
+ Department Of Electronic Circuits & Systems (oo) +
+ MAIL: mailto:arummler@acm.org || | \ +
+ MAIL: mailto:andreas.rummler@tu-ilmenau.de ||----|| * +
+ WEB : http://www.inf-technik.tu-ilmenau.de/~rummler ~~ ~~ +
+ PGP : http://www.inf-technik.tu-ilmenau.de/~rummler/public.pgp +
"Programming today is a race between software engineers striving to
build bigger and better idiot-proof programs and the universe trying
to produce bigger and better idiots. So far, the universe is winning."
Richard Cook
Re: DnD: UI freezes when after drop [message #95377 is a reply to message #95348] Thu, 25 September 2003 04:31 Go to previous messageGo to next message
> whole VM.
I have prepared a small plugin to reproduce the problem, you can
get it at http://www.evolvica.org/dragdrop.zip
Instructions: Create a file with the extension .drag - an editor will
open. Now open the "Drag Drop View" from "Show View"-Menu, Category Other.
Drag one of the items from the View to the Editor and the whole VM
will hang and (after 15 seconds) crash.
The plugin "works" with Eclipse/GEF 2.1.0 and 2.1.1. I'm using JDK 1.4.1
(build 1.4.1_03-b02) under Win2K SP 4.
Andreas
+ Andreas Rummler +
Richard Cook
Re: DnD: UI freezes when after drop [message #95422 is a reply to message #95377] Thu, 25 September 2003 11:05 Go to previous messageGo to next message
You never set the Transfer on your OperatorDropTargetListener. This is
required. I just changed the javadoc on
AbstractTransferDropTargetListener(EditPartViewer) to clearly state that
if you use that constructor, you must set the transfer yourself using
setTransfer(Transfer).
>> whole VM.
> Andreas
Re: DnD: UI freezes when after drop [message #95437 is a reply to message #95128] Thu, 25 September 2003 11:12 Go to previous messageGo to next message
You seem to have the same problem as Andreas. You must set the Transfer
on your listener (either by implementing and calling the constructor
with a Transfer parameter, or explicitly calling setTransfer(Transfer)
after creating the listener).
Dirk Lemmermann wrote:
> Hi there,
> super(viewer);
> Dirk
Re: DnD: UI freezes when after drop [message #95449 is a reply to message #95422] Thu, 25 September 2003 11:15 Go to previous messageGo to next message
Thank you for that hint, Eric. But one question is still open for me:
In which category does that error/bug fall?
1.) User (bad use)
2.) SWT/GEF
3.) Java/VM
A mistake made by the user (in this case myself) should NEVER cause
the VM to crash.
Andreas
+ Andreas Rummler +
Richard Cook
Re: DnD: UI freezes when after drop [message #95494 is a reply to message #95449] Thu, 25 September 2003 17:48 Go to previous messageGo to next message
From what I've found, this could be construed as jointly SWT and GEF's
fault. I'm looking into it. I'll let you know.
Eric
>> is required. I just changed the javadoc on
>> that if you use that constructor, you must set the transfer yourself
>> using setTransfer(Transfer).
> 1.) User (bad use)
> 2.) SWT/GEF
> 3.) Java/VM
> the VM to crash.
> Andreas
Re: DnD: UI freezes when after drop [message #95509 is a reply to message #95128] Fri, 26 September 2003 10:57 Go to previous message
I opened a bug for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=43746
> Hi there,
> super(viewer);
> Dirk
Previous Topic:getting the Figure from Model
Next Topic:Redistributing GEF
Current Time: Fri Jul 18 22:41:11 EDT 2025
Powered by FUDForum. Page generated in 0.27579 seconds
