Re: Defina a Content Type so it opens up my specific MultiPageEditor ? [message #95740 is a reply to message #95659] |
Thu, 28 April 2005 04:12   |
Hi Amy,
I think it helped I will at least work through it and see if it does what
i want ,)
The biggest issue with the filetype association is that is not ready for
the 21th century
since it assumes all files only have one . in it ;)
so you can bind .xml, .jsp, .xxx but not .cfg.xml, .hbm.xml, .ant.xml,
..reveng.xml etc.
And what I would like is to have .reveng.xml bound to my editor but that
is not possible.
But what I can do is specify the content type for .reveng.xml so the xml
editor
is initialized correctly - but I didnt find a way to say: "Hey, yes I know
how the
xml editor should be enhanced BUT I would also like eclipse to use THIS
specific multipage
editor instead of the xml editor"
Did that make more sense ? ;)
/max
> I'm not sure what you mean and perhaps this question is more suited for
> the
> general eclipse.platform newsgroup.
> From a user's perspective:
> The Content Types preference page allows you to associate content types
> with
> certain file types.
> The File Associations preference page allows you to associate certain
> file
> types with different editors. In this preference page, you can also
> specify
> the default editor to use on a file type.
> From a developer's perspective:
> When you define your editor in your plugin.xml, you can associate your
> editor to a file type or content type. Here's what the JSP Source page
> editor's definition looks like:
> <extension point="org.eclipse.ui.editors">
> <editor name="%JSP_Source_Page_Editor.name"
> icon="icons/sourceEditor.gif" extensions="jsp, jsf, jspf, jspx, tag,
> tagf"
> contributorClass="org.eclipse.jst.jsp.ui.internal.editor.ActionContributorJS
> P"
> class=" org.eclipse.jst.jsp.ui.internal.editor.StructuredTextEditorJ SP "
> symbolicFontName="org.eclipse.wst.sse.ui.textfont"
> id="org.eclipse.jst.jsp.core.jspsource.source">
> <contentTypeBinding contentTypeId="org.eclipse.jst.jsp.core.jspsource" />
> </editor>
> </extension>
> Hope that helped.
> -amy
> "Max Rydahl Andersen" <max.andersen@jboss.com> wrote in message
> news:op.spud31qrsj49yt@xam.intranet.jboss.com...
>> I know how to override/configure the xml editors source configuration
>> based on contentypes.
>> Can anyone tell me how via content-types to open a specific editor and
>> not
>> just reconfigure
>> the xml editor ?
>> -max
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: Defina a Content Type so it opens up my specific MultiPageEditor ? [message #98041 is a reply to message #95740] |
Tue, 03 May 2005 13:31  |
Originally posted by: amywu.us.DELETETHISPART.ibm.com
The one . limitation sounds like it could be a bug. Like I said, you might
want to ask your question in the general eclipse.platform newsgroup. But it
sounds like if you want to associate your editor with a particular
extension, you should add something like the following in your plugin.xml.
===> extensions="reveng.xml"
P"
</editor>
</extension>
news:op.spxnqeg8sj49yt@xam.intranet.jboss.com...
> Hi Amy,
> i want ,)
> the 21th century
> .reveng.xml etc.
> is not possible.
> editor
> how the
> specific multipage
> /max
> > the
> > with
> > certain file types.
> > file
> > specify
> > tagf"
> > P"
> > </editor>
> > </extension>
> > Hope that helped.
> > -amy
> >> Hi,
> >> not
> >> just reconfigure
> >> the xml editor ?
> >> -max
FUDForum. Page generated in 0.21192 seconds
