| revealing names generation in Auto Code Generation [message #94939] |
Fri, 12 September 2003 00:30  |
Originally posted by: sunilvi.noida.hcltech.com
Here I am trying to create a new Wizard , but the constructor and the
method comes with arg0 , arg1 as their input argument . How can do the
settings so that revealing names are generated.
for eg
public void handleEvent(Event arg0) {
// TODO Auto-generated method stub
It should be like
public void handleEvent(Event event) {
here i have event instead of arg0
* Created on Sep 9, 2003
* To change the template for this generated file go to
* Window>Preferences>Java>Code Generation>Code and Comments
package com.example.MyWizard;
import org.eclipse.jface.resource.ImageDescriptor;
import org.eclipse.jface.wizard.WizardPage;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Listener;
* @author sunilvi
* To change the template for this generated type comment go to
public class MyWizardMainPage extends WizardPage implements Listener {
* @param arg0
public MyWizardMainPage(String arg0) {
super(arg0);
// TODO Auto-generated constructor stub
* @param arg0
* @param arg1
* @param arg2
public MyWizardMainPage(String arg0, String arg1, ImageDescriptor
arg2) {
super(arg0, arg1, arg2);
/* (non-Javadoc)
* @see
org.eclipse.jface.dialogs.IDialogPage#createControl(org.ecli pse.swt.widgets.Composite)
public void createControl(Composite arg0) {
/* (non-Javadoc)
* @see
org.eclipse.swt.widgets.Listener#handleEvent(org.eclipse.swt .widgets.Event)
| Re: revealing names generation in Auto Code Generation [message #95132 is a reply to message #94939] |
Fri, 12 September 2003 05:47  |
Originally posted by: daniel.megert.gmx.net
This works for me. Do you see the source for WizardPage? If not it
cannot detect the names.
Dani
>for eg
>It should be like
> * @author sunilvi
> * @param arg0
> super(arg0);
> * @param arg0
> * @param arg1
> * @param arg2
>arg2) {
> /* (non-Javadoc)
> * @see
> /* (non-Javadoc)
> * @see
> public static void main(String[] args) {
FUDForum. Page generated in 0.03316 seconds
