Home » Newcomers » Newcomers » split screen code editing
split screen code editing [message #94909] Mon, 15 August 2005 11:30 Go to next message
Originally posted by: keith.florance.gmail.com
I can't seem to figure out how to get multiple editing "panes" so I can see
multiple source files side by side. Is this possible in Eclipse? Thanks!
-Keith
Re: split screen code editing [message #94925 is a reply to message #94909] Mon, 15 August 2005 11:38 Go to previous messageGo to next message
Originally posted by: newsgroups.pellaton.li
AFAIK: Editors cannot be splitted. However, you can open a second window
and edit different files there). In the menu: Window > new Window
So you could create a user defined perspective without any views and so
on and use it as a separate editor pane.
Hope this helps
Michael
PS: If you find a better solution, please post it here!
> -Keith
Re: split screen code editing [message #94954 is a reply to message #94925] Mon, 15 August 2005 12:41 Go to previous messageGo to next message
it's the most wanted feature these days:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=8009
add your vote
/adam
Michael Pellaton wrote:
> Hi
> Hope this helps
> Michael
>>-Keith
Re: split screen code editing [message #94963 is a reply to message #94954] Mon, 15 August 2005 12:57 Go to previous messageGo to next message
By looking through that bug tracker, I found that *my* problem can be solved
by dragging the tab with the file name to any side (top, bottom, left,
right) and it splits that file into a different editor "pane". It seems as
if you can't do this with two copies of the same file though.
-Keith
"Adam Kiezun" <akiezun@mit.edu> wrote in message
news:ddqgkc$t0o$1@news.eclipse.org...
> add your vote
> /adam
> > Hi
> > Hope this helps
> > Michael
see
Thanks!
> >>-Keith
Re: split screen code editing [message #94977 is a reply to message #94925] Mon, 15 August 2005 13:04 Go to previous messageGo to next message
> Hi
> Hope this helps
> Michael
>> -Keith
If you are wanting to display different files, grab the editor tab of one
of the files. Drag it till the cursor becomes an arrow instead of a
folder. You can place the editor on any side of other editors.
If you want to have 2 displays of the same file, Go to Window->New
Editor. This will open a second instance of the file. You can then drag
as above to get 2 views.
Re: split screen code editing [message #95020 is a reply to message #94963] Mon, 15 August 2005 13:37 Go to previous messageGo to next message
Yes you can. Try it.
What you can't do is have 1 editor that is split.
You can have 2+ editors open on the same file and arranged any way you want.
/adam
Re: split screen code editing [message #95050 is a reply to message #95020] Mon, 15 August 2005 15:06 Go to previous messageGo to next message
> want.
What's the difference between two editors on the same file (sharing the
same editor buffer), and having one editor that is split? That seems to
be the same thing to me. Is it just a cosmetic difference that a split
is usually represented with a thin sash rather than a separate editor tab?
Re: split screen code editing [message #95063 is a reply to message #95050] Mon, 15 August 2005 15:45 Go to previous messageGo to next message
>> want.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=8009#c58
i don't use in any editor it so no big deal for me anyway
but apparently important for those accustomed to the feature.
/adam
Re: split screen code editing [message #95150 is a reply to message #94963] Mon, 15 August 2005 16:38 Go to previous messageGo to next message
Window > New Editor will open a second editor on the same file that is
currently being edited. Then you can drag that second editor
above/below/next-to the first one.
HTH,
Eric
Re: split screen code editing [message #95210 is a reply to message #94977] Tue, 16 August 2005 05:19 Go to previous messageGo to next message
I understood that he has two screens and wants to have two editors
on different screens (not in the same window). You can drag views
outside of the workspace window and handle them as individual win-
dows, but this behaviour is not available fo editors.
Michael
Re: split screen code editing [message #95241 is a reply to message #95210] Tue, 16 August 2005 11:24 Go to previous messageGo to next message
> Hi
> Michael
You have been able to have multiple editors open in the same window since
at least version 3.0. With 3.1 you can now have the same file open in
multiple editors in the same window.
You get multiple editors in the same window by dragging the editor tabs
within the window. Grab a tab and move the cursor to the top of the
editor area in the same window. The cursor will turn into a small arrow
and there will be a frame outline where the editor will be placed.
To get the second editor on the same file, use the Window->New Editor.
This will open up a second tab with the same file. You can drag this new
editor tab as above to have 2 views of the same file in the same window at
the same time. In fact, you can continue to use Window->New Editor to get
additional tabs for the file.
Essentially, you can have as many editors open on the same file as you
have space on the screen to display them.
Re: split screen code editing [message #95412 is a reply to message #95210] Wed, 17 August 2005 11:20 Go to previous message
> Hi
Right, Editors (as opposed to Views) are considered the "central"
component of an Eclipse window, so they can't be detached.
In that case the only option is to use Window > New Window to open a
second Workbench window, which you then move to the secondary screen.
HTH,
Eric
Previous Topic:Update Manager crashing
Next Topic:How to enable local history?
Current Time: Sun Jul 27 03:17:58 EDT 2025
Powered by FUDForum. Page generated in 0.15979 seconds
