Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Persist EObject from BPEL20.XSD
Persist EObject from BPEL20.XSD [message #94853] Wed, 29 August 2007 04:10 Go to next message
--------------040600040208030303090305
i want to persist an Object of the following XML-Schema:
http://docs.oasis-open.org/wsbpel/2.0/OS/process/executable/ ws-bpel_executable.xsd
So, i generated the Ecore-model. Then i loaded an BPEL-XML(the xml file
is added) into EMF and i want to persist this file in my database with
Teneo.
I use the newest Teneo 0.8 build, eclipse3.3, Java 1.6u2 and hibernate
3.2.4SP1.
The generation of the hibernate-mapping and the database schema was
successful.
But if i want to persist an Object of the loaded BPEL-file, especially
the TProcess-object because it comes right after the DocumentRoot. But i
always get an hibernate-error. I have tried to change the mapping-file
manually but it didn't work.
My Code:
package org.teneo.test;
import java.io.File;
import java.io.FileWriter;
import java.io.IOException;
import java.util.Properties;
import org.eclipse.emf.common.util.EList;
import org.eclipse.emf.common.util.TreeIterator;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.teneo.PersistenceOptions;
import org.eclipse.emf.teneo.hibernate.HbDataStore;
import org.eclipse.emf.teneo.hibernate.HbHelper;
import org.hibernate.Session;
import org.hibernate.SessionFactory;
import org.hibernate.cfg.Environment;
import org.open.oasis.docs.wsbpel._2._0.process.executable.Document Root;
import
org.open.oasis.docs.wsbpel._2._0.process.executable.Executab lePackage;
import org.open.oasis.docs.wsbpel._2._0.process.executable.TFlow;
import org.open.oasis.docs.wsbpel._2._0.process.executable.TProcess ;
import
org.open.oasis.docs.wsbpel._2._0.process.executable.util.Exe cutableResourceFactoryImpl;
import org.w3.xml._1998.namespace.NamespacePackage;
public class Test2 {
// initDB();
// createDatabase();
persistResource();
// persistRootFromXML();
// loadBPELFileFromDB();
public static void createDatabase() {
HbDataStore dataStore = initDB();
dataStore.initialize();
public static HbDataStore initDB() {
final String dataStoreName = "bpel20";
final HbDataStore dataStore = (HbDataStore) HbHelper.INSTANCE
.createRegisterDataStore(dataStoreName);
Properties hibernateProperties = new Properties();
hibernateProperties.setProperty(Environment.DRIVER,
"org.postgresql.Driver");
hibernateProperties.setProperty(Environment.USER, "postgres");
hibernateProperties.setProperty(Environment.URL,
"jdbc:postgresql://127.0.0.1:5432/bpel20");
hibernateProperties.setProperty(Environment.PASS, "XXXXX");
hibernateProperties.setProperty(Environment.DIALECT,
"org.hibernate.dialect.PostgreSQLDialect");
dataStore.setHibernateProperties(hibernateProperties);
Properties persistenceOptions = new Properties();
persistenceOptions.setProperty(PersistenceOptions.INHERITANC E_MAPPING,
"JOINED");
PersistenceOptions.FETCH_CONTAINMENT_EAGERLY, "true");
PersistenceOptions.SET_CASCADE_ALL_ON_CONTAINMENT, "true");
persistenceOptions.setProperty(PersistenceOptions.USE_MAPPIN G_FILE,
"true");
dataStore.setPersistenceProperties(persistenceOptions);
dataStore.setEPackages(new EPackage[] { ExecutablePackage.eINSTANCE,
NamespacePackage.eINSTANCE });
return dataStore;
public static void persistResource() {
TProcess process = loadProcessFromFile();
// init Session
final SessionFactory sessionFactory = dataStore.getSessionFactory();
final Session session = sessionFactory.openSession();
// start Transaction
session.beginTransaction();
session.save(process);
session.getTransaction().commit();
session.close();
public static TProcess loadProcessFromFile() {
TProcess process = null;
// Create a resource set to hold the resources.
ResourceSet resourceSet = new ResourceSetImpl();
// Register the appropriate resource factory to handle all file
// extensions.
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap()
.put(Resource.Factory.Registry.DEFAULT_EXTENSION,
new ExecutableResourceFactoryImpl());
// Register the package to ensure it is available during loading.
resourceSet.getPackageRegistry().put(ExecutablePackage.eNS_U RI,
ExecutablePackage.eINSTANCE);
// Demand load resource for this file.
File file = new File(
"c:\\eclipse\\workspace\\BPEL20\\bpel20Example.bpel");
URI uri = URI.createFileURI(file.getAbsolutePath());
Resource resource = resourceSet.getResource(uri, true);
System.out.println("Loaded " + uri);
// Validate the contents of the loaded resource.
for (EObject eObject : resource.getContents()) {
System.out.println("Klasse des EObjects: " + eObject.getClass());
DocumentRoot docuRoot = (DocumentRoot) eObject;
for (TreeIterator<EObject> it = docuRoot.eAllContents(); it
.hasNext();) {
EObject eObject2 = it.next();
// System.out.println("Alle Klassen des rootObjekts: "
// + eObject2.getClass());
if (eObject2 instanceof TProcess) {
process = (TProcess) eObject2;
return process;
The following error occurs:
15548 [main] DEBUG org.hibernate.type.LongType - binding '91' to
parameter: 3
15548 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - Executing batch
15579 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - about to close
PreparedStatement (open PreparedStatements: 1, globally: 1)
15579 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - closing statement
15579 [main] ERROR org.hibernate.util.JDBCExceptionReporter -
Batch-Eintrag 0 update "texpression_mixed" set
"texpression_mixed_e_id"=87, "texpression_mixed_idx"=0 where id=88 wurde
abgebrochen. Rufen Sie 'getNextException' auf, um die Ursache zu erfahren.
15579 [main] ERROR org.hibernate.util.JDBCExceptionReporter - ERROR:
insert or update on table "texpression_mixed" violates foreign key
constraint "fk987fc8082ce0ea45"
Detail: Key (texpression_mixed_e_id)=(87) is not present in table
"texpression_any".
15579 [main] ERROR org.hibernate.event.def.AbstractFlushingEventListener
- Could not synchronize database state with session
org.hibernate.exception.ConstraintViolationException: Could not execute
JDBC batch update
org.hibernate.exception.SQLStateConverter.convert(SQLStateCo nverter.java:71)
org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExce ptionHelper.java:43)
org.hibernate.jdbc.AbstractBatcher.executeBatch(AbstractBatc her.java:253)
org.hibernate.jdbc.AbstractBatcher.prepareStatement(Abstract Batcher.java:92)
org.hibernate.jdbc.AbstractBatcher.prepareStatement(Abstract Batcher.java:87)
org.hibernate.jdbc.AbstractBatcher.prepareBatchStatement(Abs tractBatcher.java:222)
org.hibernate.persister.collection.AbstractCollectionPersist er.recreate(AbstractCollectionPersister.java:1119)
org.hibernate.action.CollectionRecreateAction.execute(Collec tionRecreateAction.java:26)
at org.hibernate.engine.ActionQueue.execute(ActionQueue.java:25 0)
at org.hibernate.engine.ActionQueue.executeActions(ActionQueue. java:234)
at org.hibernate.engine.ActionQueue.executeActions(ActionQueue. java:145)
org.hibernate.event.def.AbstractFlushingEventListener.perfor mExecutions(AbstractFlushingEventListener.java:298)
org.hibernate.event.def.DefaultFlushEventListener.onFlush(De faultFlushEventListener.java:27)
at org.hibernate.impl.SessionImpl.flush(SessionImpl.java:1000)
at org.hibernate.impl.SessionImpl.managedFlush(SessionImpl.java :338)
org.hibernate.transaction.JDBCTransaction.commit(JDBCTransac tion.java:106)
at org.teneo.test.MainTest.persistResource(MainTest.java:171)
at org.teneo.test.MainTest.main(MainTest.java:38)
Caused by: java.sql.BatchUpdateException: Batch-Eintrag 0 update
"texpression_mixed" set "texpression_mixed_e_id"=87,
"texpression_mixed_idx"=0 where id=88 wurde abgebrochen. Rufen Sie
org.postgresql.jdbc2.AbstractJdbc2Statement$BatchResultHandl er.handleError(AbstractJdbc2Statement.java:2534)
org.postgresql.core.v3.QueryExecutorImpl.processResults(Quer yExecutorImpl.java:1317)
org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecut orImpl.java:350)
org.postgresql.jdbc2.AbstractJdbc2Statement.executeBatch(Abs tractJdbc2Statement.java:2596)
org.hibernate.jdbc.BatchingBatcher.doExecuteBatch(BatchingBa tcher.java:48)
org.hibernate.jdbc.AbstractBatcher.executeBatch(AbstractBatc her.java:246)
... 15 more
15579 [main] DEBUG org.hibernate.jdbc.ConnectionManager - registering
flush end
With kind regards
Daniel Gerlach
Content-Type: text/xml;
name="bpel20Example.bpel"
Content-Disposition: inline;
filename="bpel20Example.bpel"
<bpel:process
xmlns:bpel="http://docs.oasis-open.org/wsbpel/2.0/process/executable"
xmlns:lns="http://loans.org/wsdl/loanapproval"
xmlns:xsd="http://www.w3.org/2001/XMLSchema" name="loanapproval"
suppressJoinFailure="yes" targetNamespace="http://loanapproval">
<bpel:import importType="http://schemas.xmlsoap.org/wsdl/"
location="loanapproval.wsdl"
namespace="http://loans.org/wsdl/loanapproval" />
<bpel:partnerLinks>
<bpel:partnerLink myRole="loanService" name="customer"
partnerLinkType="lns:loanServicePartnerLinkType" />
<bpel:partnerLink name="assessor"
partnerLinkType="lns:riskAssessmentPartnerLinkType"
partnerRole="assessor" />
<bpel:partnerLink name="approver"
partnerLinkType="lns:loanApprovalPartnerLinkType"
partnerRole="approver" />
</bpel:partnerLinks>
<bpel:variables>
<bpel:variable messageType="lns:creditInformationMessage"
name="request" />
<bpel:variable messageType="lns:approvalMessage"
name="approval" />
<bpel:variable messageType="lns:riskAssessmentMesssage"
name="risk" />
</bpel:variables>
<bpel:flow>
<bpel:links>
<bpel:link name="receive-to-assess" />
<bpel:link name="receive-to-approve" />
<bpel:link name="assess-to-approve" />
<bpel:link name="assess-to-assign" />
<bpel:link name="approve-to-reply" />
<bpel:link name="assign-to-reply" />
</bpel:links>
<bpel:receive createInstance="yes"
name="ReceiveCustomerRequestforLoanAmt" operation="request"
partnerLink="customer" portType="lns:loanServicePT"
variable="request">
<bpel:sources>
<bpel:source linkName="receive-to-assess">
<bpel:transitionCondition
expressionLanguage="urn:oasis:names:tc:wsbpel:2.0:sublang:xpath1.0 ">
$request.amount &lt;10000
</bpel:transitionCondition>
</bpel:source>
<bpel:source linkName="receive-to-approve">
$request.amount &gt;= 10000
</bpel:source>
</bpel:sources>
</bpel:receive>
<bpel:reply name="AcceptMessageToCustomer" operation="request"
variable="approval">
<bpel:targets>
<bpel:target linkName="assign-to-reply" />
<bpel:target linkName="approve-to-reply" />
</bpel:targets>
</bpel:reply>
<bpel:invoke inputVariable="request" name="InvokeLoanAssessor"
operation="check" outputVariable="risk" partnerLink="assessor"
portType="lns:riskAssessmentPT">
<bpel:targets>
<bpel:target linkName="receive-to-assess" />
</bpel:targets>
<bpel:sources>
<bpel:source linkName="assess-to-approve">
$risk.level != 'low'
</bpel:source>
<bpel:source linkName="assess-to-assign">
$risk.level = 'low'
</bpel:source>
</bpel:sources>
</bpel:invoke>
<bpel:invoke inputVariable="request" name="InvokeLoanApprover"
operation="approve" outputVariable="approval" partnerLink="approver"
portType="lns:loanApprovalPT">
<bpel:targets>
<bpel:target linkName="receive-to-approve" />
<bpel:target linkName="assess-to-approve" />
</bpel:targets>
<bpel:sources>
<bpel:source linkName="approve-to-reply" />
</bpel:sources>
</bpel:invoke>
<bpel:assign name="AssignYestoAccept">
<bpel:targets>
<bpel:target linkName="assess-to-assign" />
</bpel:targets>
<bpel:sources>
<bpel:source linkName="assign-to-reply" />
</bpel:sources>
<bpel:copy>
<bpel:from>
<bpel:literal>yes</bpel:literal>
</bpel:from>
<bpel:to part="accept" variable="approval" />
</bpel:copy>
</bpel:assign>
</bpel:flow>
</bpel:process>
--------------040600040208030303090305--
Re: Persist EObject from BPEL20.XSD [message #94995 is a reply to message #94853] Thu, 30 August 2007 08:12 Go to previous messageGo to next message
Hi Daniel,
It will take a few days (in/after the weekend) before I can look at this further.
gr. Martin
Daniel Gerlach wrote:
> Teneo.
> 3.2.4SP1.
> successful.
> My Code:
> import
> import
> public static void main(String[] args) {
> // initDB();
> persistResource();
> "JOINED");
> "true");
> return dataStore;
> // init Session
> session.close();
> // extensions.
> .hasNext();) {
> return process;
> parameter: 3
> "texpression_any".
> JDBC batch update
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 15 more
> flush end
> With kind regards
> Daniel Gerlach
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Persist EObject from BPEL20.XSD [message #95085 is a reply to message #94995] Thu, 30 August 2007 12:03 Go to previous messageGo to next message
thank you for looking at it. I hope you can help me:)
Daniel Gerlach
Martin Taal schrieb:
> Hi Daniel,
> further.
> gr. Martin
>> file is added) into EMF and i want to persist this file in my database
>> with Teneo.
>> 3.2.4SP1.
>> successful.
>> i always get an hibernate-error. I have tried to change the
>> mapping-file manually but it didn't work.
>> My Code:
>> import
>> import
>> // initDB();
>> persistResource();
>> "JOINED");
>> "true");
>> "true");
>> return dataStore;
>> // init Session
>> session.close();
>> // extensions.
>> .hasNext();) {
>> return process;
>> parameter: 3
>> batch size: 2
>> close PreparedStatement (open PreparedStatements: 1, globally: 1)
>> statement
>> wurde abgebrochen. Rufen Sie 'getNextException' auf, um die Ursache
>> zu erfahren.
>> "texpression_any".
>> 15579 [main] ERROR
>> org.hibernate.event.def.AbstractFlushingEventListener - Could not
>> execute JDBC batch update
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 15 more
>> flush end
>> With kind regards
>> Daniel Gerlach
Re: Persist EObject from BPEL20.XSD [message #95438 is a reply to message #94853] Sun, 02 September 2007 06:02 Go to previous messageGo to next message
Hi Daniel,
In the test code you use the org.w3.xml._1998.namespace.NamespacePackage, where
Where can I find the ecore/xsd for this epackage?
Or can you provide the generated java code.
gr. Martin
> Teneo.
> 3.2.4SP1.
> successful.
> My Code:
> import
> import
> // initDB();
> persistResource();
> "JOINED");
> "true");
> return dataStore;
> // init Session
> session.close();
> // extensions.
> .hasNext();) {
> return process;
> parameter: 3
> "texpression_any".
> JDBC batch update
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 15 more
> flush end
> With kind regards
> Daniel Gerlach
The Netherlands
Re: Persist EObject from BPEL20.XSD [message #95487 is a reply to message #95438] Sun, 02 September 2007 08:50 Go to previous messageGo to next message
--------------090208090303020303020103
Martin,
I would have expected the Ecore plugin's XMLNamespacePackage to be
reused for this and in any case, for the generated package will look the
same as it. The schema is here:
<http://www.w3.org/2001/xml.xsd>
Martin Taal wrote:
> Hi Daniel,
> gr. Martin
>> database with Teneo.
>> hibernate 3.2.4SP1.
>> successful.
>> especially the TProcess-object because it comes right after the
>> DocumentRoot. But i always get an hibernate-error. I have tried to
>> change the mapping-file manually but it didn't work.
>> My Code:
>> import
>> import
>> // initDB();
>> persistResource();
>> "JOINED");
>> "true");
>> "true");
>> return dataStore;
>> // init Session
>> session.close();
>> // extensions.
>> loading.
>> .hasNext();) {
>> return process;
>> parameter: 3
>> batch size: 2
>> statement
>> zu erfahren.
>> "texpression_any".
>> 15579 [main] ERROR
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 15 more
>> registering flush end
>> With kind regards
>> Daniel Gerlach
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Martin,<br>
<br>
the same as it.
Re: Persist EObject from BPEL20.XSD [message #95532 is a reply to message #95487] Sun, 02 September 2007 17:46 Go to previous messageGo to next message
the namespace-XSD is an import in the
http://docs.oasis-open.org/wsbpel/2.0/OS/process/executable/ ws-bpel_executable.xsd.
In line 19 you can find the imported XML-Schema:
<xsd:import namespace="http://www.w3.org/XML/1998/namespace"
schemaLocation="http://www.w3.org/2001/xml.xsd"/>
So i created a normal EMF-project with eclipse3.3 and generated the
EClasses from the XML-schema mentioned above:
This generated all needed packages, including the EClasses for the
namespace-XML-schema: http://www.w3.org/2001/xml.xsd.
With kind regards and
Thanks in advance for looking at my problem
Daniel Gerlach
Re: Persist EObject from BPEL20.XSD [message #95545 is a reply to message #95532] Sun, 02 September 2007 18:18 Go to previous messageGo to next message
--------------090700050606070407020503
Daniel,
On the last page of the import wizard, there is the option to reuse the
XMLNamespace package that already exists in the Ecore plugin. It would
seem better to reuse that rather than generate a duplicate of it.
Aren't you getting a warning in the Error log indicating more than one
package is registered for the namespace
"http://www.w3.org/XML/1998/namespace" because of you duplicate
registration for the following registration in the Ecore plugin.xml?
<extension point="org.eclipse.emf.ecore.generated_package">
<package uri="http://www.w3.org/XML/1998/namespace"
class="org.eclipse.emf.ecore.xml.namespace.XMLNamespacePackage "
genModel="model/XMLNamespace.genmodel" />
</extension>
> With kind regards and Thanks in advance for looking at my problem
> Daniel Gerlach
Content-Type: multipart/related;
boundary="------------070002080408090805080902"
--------------070002080408090805080902
<html>
<head>
</head>
Daniel,<br>
<br>
Re: Persist EObject from BPEL20.XSD [message #95599 is a reply to message #95545] Mon, 03 September 2007 03:42 Go to previous messageGo to next message
--------------050106090405080900020509
i don't have any warning or any error. I added a few screenshots of how
i generated the Ecore-model. But i didn't see an option to reference an
existing generator model at the last step of the wizard.
But I don't think that's the problem. The Ecore model seems fine because
i am able to load and parse instances of the XML-Schema. I can write
them in a normal file, too. Only the database doesn't work.
For me, the problem lies in the generated hibernate-mapping-xml, because
i get a "foreign constraint violation error"(see my first posting) when
i want to persist an EObject of the
and the error is thrown for an EObject of the BPEL-XSD and not of the
Namespace-XSD.
Daniel Gerlach
Ed Merks schrieb:
> Daniel,
> </extension>
Content-Type: application/octet-stream;
name="pics.rar"
Content-Disposition: attachment;
filename="pics.rar"
UmFyIRoHAM+QcwAADQAAAAAAAAD8MXQgkDUA61IAAGZ2AAACqOBb0HtKIzcd MxAAIAAAAHNj
cmVlbnNob3QwNC5qcGcA8Py0bBAdkNEM1VFYDVnstoosIsoko2WUegkXkWEe jbPQll9FFhFl
HoGz06i+i0j0Cikj0AmCykSiSvY0tazOb1pJWmNbze85mcjmexnN8jkbu7gV VASJEyBIkTIE
1f8p4JZEuR5+limIA+FfAVHlCK+Of8fQAGEtHSkcAGBgD/XC/QHx0gCJ+5ig qLivXGBcWFxo
ZGBsfLCAfHR0fNCcpIiw9Nj8+PDY7Ou8krif3kVYRjo7UWxSWF9iZ2hnQE5w 8DeyOy4ys7H9
hIGDI0ND/ZHzMgIDNjQztDY/+t8+NyAGesGsYaeBwYTAA0ZDA7/W+N6AAhSk Df3EMAf6dA0P
/exASEQtIoDH76HBoZ1v6US64gH/YG+wWH/QkQGxztqUZG5BohKark9kmVGE JN1hqxuLm+1v
pJzY3ODlEYnByjhEoQ5yrRWR+uh2dKrv2FL+FGO0Gfj5/ZZgZ+wIBaIuGQo6 +dYcHfez/+l/
OlSGzVC7Zp7A5hfbommydTyA9w+OiAFf4CFM99QACCA5z6VjaPYnomcoCpQM MXsFSFBgHR8D
NvLp/Acv9lk+xbwWcq8NJO8/je+sudFD3dTQYwGprhpBrNl06UzLMumdr7pH SEC8KeAssStS
75cvB3gM5jBrFbKZSwER6w3qEGzJa9hbLrZWevYqviAKMQnj/aeZ4IkA02z5 rlcHPG1Relr6
JlsJ103FMyVqPuLm35jmSpWU0dmKULWlR6klXlq5nx3j+KPm9ZHtguRFJinK 5H67Sbmb7JaO
ck77Y0B4EZiIgo0wCNcZZxTMw8KTCdN+pV0x3hUCrI7/2FRitGxf4ELfYKE0 7odMk656z1BP
cUPW6Zc6YWnKjxxzPA8ulSM+WACdd+JmDFrs+tI7Zk+kc9x0jC94OWu4Uq/a iV9XPwTdzN1F
Mg+n0ovPBHturnRwaFFqHaK7Fc1cJRXQj5lpAcOWy9YPpqiiDYmX90LPVdM4 X3fO2MfqWHLd
+zrzKQx/7xYoGJ+/lmQkG27emUSpraWy3qTdMSK78/lo0Mho1ZKHWakkvJut TMmG8D3iFMqw
BgIQlqkLJB5dKWjR9e4XQecaD0WITwIENZqjet4KtSYQ1f4CJ8xCcJ7bOcII IYQnZuwq1JJZ
iGWfWCleol6PHP5ao0Ve0Z9xj5GAR1/NN2BySrWBSrCdUMF7Uy0yjadHZGOv ONBZax5mIeOP
atHx0XkadTRamjEjauyc35tyst5xV9lzkbzEGSfqS2hBb3PGO8KmODhFhSP1 PTDJxg4un9Mt
P6/OL7CZ9VyjhehJxnwpN+SLm4ugFZ392I/lfY+U5+AErSemGxEE59f70BTE BsFZqf2RgdqP
j0AarhHot+Ae/fwpP3b5KBQ58DCFtHHOZAgfw+5+QIxX6AcFZRjQRZV9DnQp GCPCs49F8Jcz
DPp5AeK97Ue9C8bZ5Ps7WCbnqftfxJnKbZhChNCiT3qc/knH9Nzu/IlpDjTU KTahxzevqK+a
iWhwsN9yFTmQc+YEcjCA99yDxn35VYBtB12IVw0f8+Up+aaqhIM2Luf8+DQO Lv2uOS7sqJcS
l2/1pK+vpl9zkYRsYZlbomUT712YUPxeErjIUlp3B4z/8hJH8qCkCPeyvH93 2ynFcbtvER9s
FPEmoex/pF/8p3SPW/I1ZV/By/75xl/QX/AQyppkreOXQtNp+1vJ816jf9FL uMqHO/Omwalt
SygDKS6JVvD5G6u7959f6U/cHm44yN2IWpzpQ4mO590fNa2MHEsfv1eXgLPn VrTAp2cUGq/+
Qivy1FR62k1FzA5Q5BNtzQ7yEmKJraM3ynnZ/pKl3vcj3RlGMwtmD0ax78QE RRwDXRT05EZB
qYS6PzFPhHYJHzYoIn1vi38+lviIoyetqzvkrD7jOKyujeVgWpE+0GCONOFm 1FwF1rjBb95A
r5wRQBJDclbytaD26g0WWonot8tfh0poJqRKLf6Xm+IZPnjBFWn4LHcrMflU xMhN0tdRYrEN
gnippAwhihtKB1UPJ5fYx4udtrJZa6KsDbO3ly3nsVemZtJsHHePlM5OjtSU 7J8SWh9lOnCT
aHsAyPEmY3zAc9eKhZtbJpz1SmxEsxu95zrM263yp/e8gNYY4+HnjeBmGe8K 5cvw3zweGlGD
NsVyT6y/wqQ8trU5nO76yz1SDFkFEOfZCmKef3C3np53qHIZp7s+FSPSJOdK TdIfwuu0O9fK
ac/+e2Y/Bh0KPJOsrGtO1guKUQtcKzYJaDzzHH9yyBc4YUM5LhvPgyvXhThf tC3vqXlUmerA
qTi05GPJKeJy6NkjpwnzJVlJ6XkHxF1mqEyJHNqbAlfK+WnmSO3BEqEWDxpk nFyR2vc7LckU
vrGG8i1gUMwk6AQkMf1DtDg17FSLXmUi/wo2l4jrOBx+jIHe6TGiXpppQNGb a/vfSWyjVW/N
tSULnvxCKpq0VzwvhDvG0g2z1MQLZm56io8kqfamOvWEyP2s/JeBRPDKIy3F TScFlfkxiZK2
3T4mGHhpIz6bbzHrVFwtWnVb3QZ2L+2m2R7MH2kt3N0rooElwWe8lm8KXcBB WYPtIEnXt1G2
+CsP8+YA928XGsQw27xbod+45G78L0hEnbKR/wXqx3Pn6xzU9D3q11hEfhzA 6PZJscPV13Pj
ruPy3wp3LU5z6mDmTixuzjfs1TIpP7Kwu6ybdQjDkX/PB7Tk3GDY5At6X72j 8+/YOEicoE+y
5xglJ55PGjtVsw2etzvSkO8xDK2oS+i1v5QxWHZ/fvWQM3YWDmdKQF/fJeOQ e6qwzDKtvWLM
b++NpfptR7UALbkpU2bn4lnws3xs5kuYm9Ws3SgMvs3upLup6kQeT7W2s4+7 a/Qwe/TuO9IK
yaTosaeH6FrXPjUUFPic2Epzm7QZWnAVpBz+ZftEhDUN/4Y9H3yMzEKimisN 07DfPN5YW7wy
9tBAKm56ApKyqGDMSUtEX6hm1Xndgs/Tbbof6ouKeNq9YjWQy0yyJz6UxGpP ueicO0vjQrrv
xB0/rTVimA/yGOj+TQ0R67+K+E56lg46VIpDgGvwEG6X+CD3UKer6YxlCL8h v5sDcKUwWdtC
JQoflKsgTHyGnxkGGl/unZ+WS7881l/cr1A/qX4Li6pq4m/Yd/uWzR2SP+Ql RLmCj2zj8eX5
NWg9gMlLy2bzO/B/c4vwWPsFdatnPxOUH5wlCjWqhj3+TYr//WD1kp8sfJCf 7w+hU0MXkHyh
8+VhUwq75oFn8bX/xN/hNZqbBGswjBo/vTjoMcGWk0TELAUUd2/lDj8VDYKU wS/wZ00wrnlI
4tHn6FDgq9B9w07SHAR1PjQguWBu72/tEgzUODYRKf5o4vHueBPNpfv5ykVw n9cg35zihUy2
rHm+BQ6b2YKPz1KbX80ad+RkFFIJNmQ+HciKYclwwQqKNWeWQuCnJ86zM/CT eUv1RX4KFU00
nl6UUKOcvqLwKRWTMaW+F7C06Vr4S/M9WyoDVnOZn4NWGVvuHTOBAYtmq8LK W8fxAaeHqrPC
rFWDFUWWkvfTH2xBRPeX9kQ0W+Uz0uJUH+AXWob3zsbNqlJxDKQw7GiAs/yC wbcijmZla9Sx
GTj4W1pDA0b56yBGkHj8c+1amPtL25zYeWxdMmz5cF5qi9CGpZ5iiKBj9yub R3nm4uES9ZG+
Br5aPsWqv82b0krdBQ3QnQIMy726wVp41qZms35kMI0rvCtEOK5RS9Ndeyt1 eVK87Ye/Zspc
/GR2Xx8ESJm8Cm7Sbj5r8KCIwQa1EvbNzMR6gWsvjqyJAV8I3rxbI2wZsGRN 3kUVUMLb5G00
u7X+kLwEe9Vmbg+n5sdtkq7RZp5ZjXBSTemLWpN5+3aTCxK2Qab9TdA83Gb5 9xWRlnRsUhpm
DA6WWjzfLUGcc1FoUpuZJwFQhVa/sT3Z7SGcv2fftXofG0A4ZkHpnPP629/9 Yy8zCxhLStmc
zLXdk8sqxs7pGkSmkNYB7z5/Q9B1PKn7UnYVfoIdhICx5Zn8Vghtnw1cQSn0 Wca1xKHrZRc+
O9KZnCTuHZq9KV/OqC0peP4c4gfzb0MiGkMBVcsfEJVKwFuomv9YXy81Vycu F2jjywM/7arV
iPLcmHe8IaCITNiELQYBTJeyaLTLiyOoz0Cr9FAlGwL051MNfT+NMBzLWm0E JsFRNnA3b2Ew
zW50/v/DENb/v2MrnZWbMKcvzI78/lNhUHo3G9pSAlt6tY4mGTd+poz4RAvU 7/RpE2oE8nYD
hv9Blt2yJbxd6r5UXtTGG1mmkaqU1mfenu+cFbTuvVe5F2bOorWx4rozHONK o6SLrnhmYbEL
aNcmubXkAqyw/IRa+xY6PHa1KXsBd3dzqcp+WIGQDlHZgupiQO+KKFWY6DIT AmhTjmVPm0QW
jhX+wl0bjatC0lL22PkhCzDF/IRR76O6u+Xnga393cXpOXk/ysxdPHnxAe0j iioqqtVp5kid
Uj2pbJSnpxLUJvfo4lbHScaa4yqyrck0F+IM5UHoSrkQbPYPdYdtZXQvMxlI a+QNacpdVyU6
+n3GTzEOAnsTSDw/ZqbOdYqCFb28YyEjRBwfWg3z/qyQyrmdy5E5BHsLvl3t N/ai4WqGxj4n
NxhyVd4WFAbbkzzXvjoFos+mtQ91mMmDbsuGRdyKzXP3UJUuD33my45a6ywr lJqBcnmj45wO
bQUqjCVeGSIc5ZsRhySds9rzFTyGm7vlmmwxu8LHNSO7/VIA68dBulatIjWh hCd7BKg1wJ3I
sSz3SoQP4zQvC00rTgTp1TmN9csK1zztIe4197XPgZacfHqsQHO3/gG76H6N 0uLxkHCTKKYV
CjrFxh0hrdPnV/sbAPM7XOH+dLbojDwsyZaHKJ3Ojw6k2Pb+GgTyBwOrJEBL /b12NewH7OOL
v03PG/DxGZ6Eg9JL1o8Bhht8O4VhZpELWFzzkGbXLJuLvgbSoCVg15setUPM pRvUcygEHbPA
pVrtrZQASjkOp2mfpaCmh8FKUhzfEb7IPjsOrPSy0FHWJ6dMiLwV5KVKsDGa XeVATs0KRCJl
2JAlsW5ptOqVTQjiN/YwgBiztmZSgtOqdBSO7JVgnhy89rf+cRU2PsPgCieO xL4ZHHYU6ldj
JuYH+3Q0GDTQpCsrR+MR9Pb3BuJHXYqWq00cJYPSqwoBrcfXPvHy8hV9qkcK 3juPC6oU7PeS
u0DV21v4kKSvlH28yKAjW7nqdbJk2HjGUh5/z/iR+V4VoCiAj3kAWBYarOu0 uRHnCITJQraD
y0jPfq7mKyrLxNykNXooybXYQEkFtEdOyQFZUP0TYiMmlCCOKenGvySB6Tm4 4RRrcTVo0ihQ
B5/pdbOg9ERNT39P3k1uB3JTPV2pegRh+DQkkeiXXdn2hEKqWDuFghlq1OGr Lr60qx0hVap2
coGVCKdDNvcf4TEa8L67hV0GXXH7ylKpdPfo9d7t6Gci5PwiX/9FZ+jdss85 pJ8cWeqfL4/H
fikNK0dB8EhS3VtkjIw6HIoGB+sOswuLWf7rR/yiEdHDjkz1tdFoKDBd2F7j lJeFPMbDdtKr
+9PmFNT+MR9woclm/flzaAgDkJWdYm9GmOdpGEyhkTr4n0b/TFLLPXJXsO6A s6zkQe6vn9oU
Qjm9bHgWtH1CN1EIjoumpn9M2XNrEQGDVe6jmiYmDSbMFkU4DL8TnY40vokw b3SWPUKxBC1F
97Or+vBpyFQjaRMi1+x3poI8FinSGWHoveRVFrh3iYzbaochaWDLNpr+Tfy0 MTnAopJSb+sh
ctJZZxrRQYCF7XDT3JLCsfUTYhFfE3XvZim+tH9oRr6fOqLvCtd3cINXOTOz dVY8QSHjnvgj
963NegwArjp2K2p31f0QpcCaNXdaLHiXECZyoa9xK8GD26RqaCLhlxPqYC6P rVTwqHcY7C1g
c9rVhdVqQi1xORpTRKQbht1l2kmZWCXLSork59tnWdfcZaR1SNBcc2rG1sc9 PNlmNwPWYGyI
nmnM3e20U8ZjPvpiCiQlVp6V3RhyoE3s7/FaLMv8a3v2zMwUUSk3MRwODQAz +Mt1S6nPh+Do
40Yj9oZHtsiRHGss2MRVif+c5cNl63890KoVxoRZXv6bZH/nN+MjBfrTDni/ hX6K1IpKvhGl
4cqHzan9iLQDoTIxaqsNHC9GDH690Ptj13WLsmMJyeyvsiPE0opduSa8XfJ7 oDj3kZGLy4oo
XjDfX5N1mzNb4yp0f6fmtJalXNFqUcLPnYVIwhBkqWtD72UzeC+iW2rcsczB wxlAHDlsYS1S
U02Q9gMk6R2w+5lhtymPrfawHqPslAS+CnU/KOGUJWd0Tj/ePmCd5mJsshwk OI2IdF1EpNBX
4lXolRS5MWYa3rhYwbaoP9rMbcZQ+vZYiH6a3OXbjcXxDr4tsNP5/L2fcXnH CanqwPZaBLHd
e/I4BcEyUUXBnJ722tksBHew1H4CSuSAN/jKBzN5NhZnDs77fCPlC3Sh9oPo /5bbqu74Pjzf
iv+XLGxXmQ3aHOwINeRHjR91q66PmXQe4M9it2izhlq3rhi3HOZoUnzicZrG 5wUbtHPqD2rM
olnmwxwaVcrLRfvXEd2lxcR0c6L1OW29XmsLFYBc6L9NzOYw1pHamubPkQsh VHCV8Eb7hvJs
lrfjLhUcpBA20hm1XRSqmx72nQ7gNwg9ihctJ4ksOoAwXZqW47tM6yrOCwj4 inelkyxkA5v0
hWfSh5Rm5RkcLLV7ehJkotpskGbRcmWeq/2V+XbpVgNBZ38eq7jZZsQsG4ub bC3AspDR/n4Y
/m2c0vF46dhBPL1AhntOZnSIpIcLsezsqq+LEGytePVx03EHefq4ifmmeb6W 9rMa9Ck0+25K
+n8KjOUJhjV9VimwJZEPZai4po3IGRGWPIy+66HiCl0bJGqyexMej7U/uQLE RB/NZWjpx0tE
djWJuhXZqPcp2imEhmn21v2dNdYG5iyPE/5DeZ9ELUoCk8prGx4XvH9FR5+/ onTSprnmuCv5
xyhhpEQPcyBIzL1bBUExL2svrlSYSteVoUJv3I3J3n1xAWejZZOw78SYoQNo WSXMztNJH4sB
QilNdOOAGODkDXNKhbsrLu+bVuiJNrvVbe29IFDh4n0j2CAuSdujWg9Gxhaz MvBayyVZleal
FIkM5lf79qiykfrFxbrDKPmyWoRk99tDLifaqEHvVJa8NgojbKTA/3pzMJkW NIyzv/SJCj+K
GeWLYcGS8bXz1yGSGy/HNVGXUZKytJr4U7JE0wDL9h6iR2BXc0e2zGwqJdqr WrdLDV5xH7xs
Z4ho6bzTF+zEC5wifb8R0M2FZknG7Wc/GhYEhaJNxeRFGEoDryd5t8PaIFpx 3hJjMbxsoRa0
dC5VVpNDslK8oZLDvkc8YgZGuvvALEsg+47u3w2+vpcGgIdwXJypGY0aCLYe z7p3n3gHqYdf
ujGaZ0l4qNaN6nQy1FGlkIEJITci5vfb3w33wjdK9W92K90GSh5tmVGa+Mau jenxlRKFXFBA
Vs8bHN/o3GSGWPtL02mpoGqU7SbymCoGWN4BEPKPpm+1gNzeAGXCS8zTSeZa jJjaZRkpWpAV
2DQVrzatp8zxAOBIWJZ3kVsrt5vaLFNOViiJgU0Vkq+b9A6ceZDzg+Yn8pF9 r7wrSBWmgRxZ
DLCv5QOG62PEjp1ScfSRnHSFwn0t5HOop05dYPiA7CIpRRsp8QwZXWRCcAli n5BFIe+TTuzP
U1Rw6VFLxxNAQ5ixrZhDsgSurl300BtB6cw/CF9T2Es6K0cedgoRhYGSxKym S5962RhngxmY
jSydI1iMmzJt74cWMVVZRWa0WudUcKQtTViY0QBi1x5TGXhMCjPXIt0fD1CW p+kqKUIEl7NX
JihrvspUPTyEu1phhgA8PxXO7n7vnZJMT7TS4z1eIwSbUjhjITB4QI4judgr xmzT7CPToi/L
T8a4wDJzOLRQ0lCDWyiHyE2aSSDsSiJ3BIGOnV6jRSP5ZpGeYqTi8tTxZAqf qjve5WubqEh+
3N6FXWsNjrU7XKWlAQcxKeIV27T0RF5R5D2yJ1m0rl1g/Ms3SDIKdn3oaLQ7 aAqUcUSB00+o
GzU8hKijEzyV1E3o0gLEqDl16or3GYrKZkLrN9yS6jxMRhMc7tscsBbz3kF4 DORfbAcUjgrC
rb0JXiE+F6qOgiMdJ3YGD6MBnELrt2TWIS4NcW1qrrPPL0T9SWlJMVVoc5ip XVxxPJpDn6KU
c57b3NLgX02Fu0BS5lssE6yMOI722g6oQMl5NPWb3+AuoCR3RHYvRh3OXTeZ piKJmdOTIeYb
TzTv+aIcoErWRRqD+PfznoHRV+KBn4TEZKmAwJvfARnRUdb3Fvo4eaErK9ba drEZRFM/hGgM
UvgYw5ZYxezb2FtsWq3GjjkdE9L35rn8GuzKUV0V/Wohd8NUdJ9C/k6vmYIG GzxZ6HV3dICp
SNe8UBFjC4v/Ako5XaztEGY4DLEkOuf9oXU6bwr+IFNEwS7IjdFE3UR8/NBM 2QGtZx71bBJC
Pox54r2Ar/QGlS3/wIeUIVEAj7WJSQiHQe9bQEJnUzUvrkGgLaVISDzUk5eu FLnVndfdQR0B
fw6eDc6tQibZ1le13lvSW1YyZi55nNxhCVSLo2FX4razsTt87121pCSR1E5b wgwwsoyGDIx2
TCobI2e6mz3v1pZ6DtZMkJhiGp3IzgEKTnxCj4FzGNMp4zHugmpgI58fH6iC xo7Ri+kTasHJ
7RMcJVwhDvAzIxQHKJrO/TbkXyxVYsUEyll4/BCgJsPFWZKXuVZm2oZuvCLi 4QNjccY3xAZP
zd4T8VGDiJkcYxHjsKroZ6dYopCYnEt18YlVHwQhyUjyONSsCqeM2kKdzsZF WfRJjxIwLcl5
bWYNN/cU9g6UFKTeREn8Vpse4KKquGSqJkJNsjeZnyOfYrguwFrh2K8FJ5cs f3ycxrSD+n6Y
DRwYxKkzU8nkBUg/PROnY/crCPhnsfc55N+FpAXRm6DuA2y7KlN7qrQ6+Vp3 HQe/T8dO70y/
S0HOqPLavKsbwCqQ59SC3KUNyssypkjrapkN+XG10N5L4GvsmcELsDNKXbTz GrU7reVmJH86
eVmqlQXm764CpCCwOapIQFF165zijI2grnU6cDbMQPNbEHOPPaVFVpmJ9Eb+ OkgCw4RAkN+b
7brKFybGSjzqGgu24t9C6jOn93Vzshtn6LAPpNTlraPxqJlB6fD7OjDWoD0+ J7oM0x286xBc
4sVIGJ4yvhTv0RfZzNTQD1512o5CkBP3vTaq0mFEO8VOUQR5fTws9k13o88i xlEmIqNMD45M
QwfKmS4N0suabiuJ0F7DdQKi3iY0kZl4b5ir9CXThk//Ppj5brVNmbXtJpys vpQQl+Exvsgy
hVT7VGAwciFSlM4UCszBpFd/Du++UoybPjl+1JVH6caSZDJyRH9tFEne6gcR 1EswtCBe1NKd
3RWZLPJlPWHt4nBvpgUOnKA9BWFfXjmNHG+mJIes3ONfLJ65wLUlLIHfJtlb kNZkM+w0xF7o
Z2bbz1I3qajlJUs/Q9/1Q6c+3PxAXdUykUI7J+vXg2ZxU61ZvZ5XHE2dqzMT 05A2mboL0je5
lJv9cvNsrkXgOWOmBys8t9P/BmItEyVHt+8+UOcgy5IeirSkMjAyMhn/dSKc VyPP01++w2rF
Kkc9u9/dyrL57lvI7v+XW5eQfuGbtcnb9wOes8jw4htuonqzkZiXe2vO/Oet MqK8jejF/BAR
UWcY1vT96lFNqs8bkmRwMFd5QZOw6fiB9tiXvw9J1l964UrTEs0tEBfNNcIP R774/LBYmdvI
0mWaaEciDEbwXt6/tsvH1rIZzctOBMXZxhu08BO9E4LDvh+2mchwx8pyb27I pipOl8v6TejO
TBZKCLLTLIR2ntl1cFVy6NZ7y0MPUH7f65zmuo9kZT9U0o43kr1w6lqyIO3G Y1WPVYAWRdMa
EcyDNZb1z1Bk8L+0zjxsA6TRWmIFvHFlLaZ7fYvshtJTJ9uVJyPar6kHLXjO AbQTY9PBx2Sn
ix1W3PrVXwE1ioXPEPMcgcqjFrMTkX6FYUFaPd2utVig4buy2GjDCcEXIeTb INqL31kFj9Yg
8h3TtjJNc8cvmZkrUrWN7JfoGBjSNaHR7FMLMMOe7F1AWnmpPek52XY30czd k3h5UtRipx7o
jk4IH2kh76m8xD7C5Btle/0nkQIAdlCvaLJrwvB/CnMtskJ3yOelSfAd15lD +z7Ui/+7IQ0R
bO0lLHYfikAms6ml71KV4tHRzWmOOI1tMF3qKiomkmGsvFHHCwz5kwb64kjc lviZUka+enlE
pv8ps3ZusD4/Crp9L8QG29mzYCrK6rOItOKVxVrPpmWT0jrsVWOnRPRTFUot sEVfUAhcTTfj
/EGkJNBwUUdLt4777v3WfMZFo9j/QOn4QRliiDnP4Z1iXQuLtu45fIpNNKcc UHs0F4Yn4q3Q
lYGGD7ERl9f+gavHCiAhuVtNvis0OklO2Q9kZVEgpTkpzyT7uLh9oWUtnC3f Ks3ObY4k72nH
gLxxIga97L6oz3t/qRPliqS/16IRAxe8C90CYut50ETsoVz0r7SQvmKMxzcy WWEn7wRNCmA7
JDvnHzIPl+/X2ANS8mZTz31aFcAtkvLJwyzxNucGcJwtrvIDzqcQ5cfIOInw ShWajbSQscDd
57dDYuZj/Tjyo9KlmEuk6zN5MEU6wv2qKKVE+1Ola5QNDqAt5EYZdcrRacmG BAjAcOX7bDgF
jTeo48RxbvymVglR0LTTeRUI71lDCXYRJ6kguU7Yq2mTXCu00dJJXzKeKznq eGXpPtp2nmJN
0TklC7WnksTOsqgWpaceNnA6+Q9bHvBuM0z9fUusWoo9K6qdIXer90hUk4YS KMPuiYW9tl9k
FiEBk9ye4XOCpr82q11V0mFDaPA8+/i3uM68CuUkSJ7ZRKI6QBLq+z9VURsf OlLmjC6FHOTD
uPVhA7ylU5XsCbipBqCYN8ELvOJX97XchfSptS9yX4RvwFmCnIQ24JSglhdp DtDl9C7VVvQQ
iqzKZOslf7U6WYA09aSd1NtrwY1qhE6jm6QMSVo8s4Y9dZQPHSURGmxdnjnP eXxutp7K7IBR
IV6z1U7TtdbntuvFWip7JXBNy5A3FC7biniq9h5mgZdwHHdmSNzNYfyGksdX aJ3IIHVHV6hW
+3l5dYzKKfp124s6MZE95irRNjryQ6V8MiuMElehyOyxi/ZJCYj4ciMnNsAP VIaokaw9G+bw
/EmePZN2oiK+YUqHVZojZMEB+gCT9R4wlYa5GzEIfvgyIobVykpKMrnGCTn6 1GRFYciHSo6w
sQcFKs1fwUmI/b+dYug82ybeYOUdc4cljDJu8Dom1c94MXFUFw8ApmEvwsaX BMMCmLUjntPy
suzJ3pXUHJldZx+vmS9TcH6pnA4N1S/lZhynOmS+/DEQt7YhpMWTmQupRE6E NdWWfBEq/pcG
OGXfGY7b9TlShAxmfOPSJEkKDH0QRCbtfaGKcmJSxNwEobksFfG4pEzwwn5l wZ9Soi9miotJ
HwH0oCW6RI4JR4mJw290A5gDgXn2X/rL/XFBMRZFfKvlvXRg8BBqLrgwJCJb I+sv0qsis1KI
ukbY9iced/cr+pMRufndRag816hX75bj8qBY4uudLg+4sx6ZZE/MtM53ZKUX ViDiYbQCc9T1
RU/ZNmZmopDGG9pUjJEPVpTyL/SSJjfpURVIq2qTznKyW4VSdO7jaBdHSMEi hOMqW9SEbfwX
pY/dEjJCikTn8x2g9u2kzOkCqdedbgfMusiFfSXlPnYPbQ+vu7oIDKbDcMWi vwdzPOFzd3Vd
H3GjaiH71PLa0EdYO66F5KSJLrsiKpLDXHy6N3W30yIvHMe8ToY5avNC52MJ 6/mgwL1DVUGe
aGRWLwfMDmNEBPYUeyohSXaZ0fBdhp2VD05TLmNu7Qsf5eXAlPoSvSm7egZh qh19ucF3lkwV
IADKK0jXto9OjcMgLymF7EyfibruHVUTO4ne2z8CHyO30wWFD7trs22vU3jd 2h9vwd45frN/
7bfFkLnvuGXQ+2qPNVpjeJrhb+Bn/hpoThxGQByI2cKFvCTVoTiDbeWz+ic8 chKHnnfQ1bTK
m0K0nKypJOh3AyknW2dZ3JFA2LmuOztbVHRqPcKF29uK9bl6meAN0j3WfuNr uqcYjutTHQ+F
0CJXC4IvoyWx4YrADnkSwrNTjiAjaenr7ttdXWjc43sIu7NN3vAPVG46WKO5 P8NP4SfpThnp
9T1ieynU2WFO9zjftxNOic7zyPZ3dw6Dtf6SDyRTlWGOdxQkwjEROtdGAZbH XWslshQNbThf
zX9tg+r3IGy7KiK9vEy5HxeM7BctNUum4Hj8mSjcTaLFDm+bzCUNYjzxN8zj CEv/gELfwd/s
sYwmoQg9fi2aD8CZWh0I0D+zx/g0Sn4JtX/cb0YWMgk1NrT8vXaPweSzejf/ 4wtQOXJ+1HVw
ZgxD8FwoU7/fYyQYMqRkZmTd6Nolo6bnWeTmHOrwXjAfbPB3Y7zx2nhSTEyV aZCzdWgirLZI
UHcUHPzhlveNwL/dhvTKewXAsCzqj/1GI9ZxGKLgQSTWwVMuGTG4793Klp6s 6zXVCcuoUWhw
MJOvW8X3raw8Xc3Wj+5DucNY4NdpqL8mgyBwtqt7Cc2z/TwPKJK3qpa3oRI1 ex9lOJ7yVhLJ
g8BmRMs12D3zOu3vVgzu1/5Sx+T8zeipRdPO2Fz0l6JorQGWDlBElu9xIWi2 Z1Wuf4u/9/94
WqdFCpI/nQsmu7VctXVgS2Qdjn4N3gHDxmPVOoBzRzVCPbuh1R3nAyMcZrMN yNf4be8HN2tD
8KP0sv1mJ8ox1yylnv35Qkr+IK/DjrMBhAdBzOiDmEgcrwhqun2gqJ8wdz7k xgyfsQ41d5w3
BjeRlepb3JOJS5k7isLkehGn5pmW79qEhddKjK2TXFhAWfM0mkNeeABeQXWe uQ6qLlznaw+C
Ml5Gs1HEcdPck4aTEJBnBzOQguQUXAyvdOJBO/X3yker6awLSKpy+x1fQ+yr 7MRS8J29ASkK
8ACRAQ+u9+/lAySPa2Lzl+dj1yxlYxdxgmkpeGaY7RHi9nNH0xtcrgqzW5Hr XTUviSfjdDoH
M+59rr5NVBi9eprDxzWu1HLSOlyHXWDj1vHtIGGYENHyYy/Oa/I5tS79Zmfa IvVryf4L1dMv
x2M3hcNT1JI8mf20ghk/W/mwHizKvvNvrnafcESv1kl/+hV2LnwOFB51rE6N a205AVdW8f81
R8DwlqSk5cixCVonQkD+SbMqGF7X4gNb1q0yEf95OQpVSohv03lYfDtt1aVR If2WOLq6R5OD
BRYHrqemdguVUEUtG5GJ2QHX0TqtGCCOmzEakmDyESicpBulb2jodt6tnGcH 8YZFH3tuLcOi
EeaLCzk4DVHx5YwPCKGwuMfDdbl2nybHJZLYChdFgYjQkicLZC+90493mQOT I+9VjTbiifc4
oV0Sem/N8o7PZBYvBRhdY1LKA830x3mua7eP2elYvWum3+1jR/k/uuqS//iX rf9nVy/NJPJY
88P79Gwp3SHvOtxQnROnrZpNWe/Ty/SlyB9sxsbUqrH5JqWdGL7M4tfZxSS5 QnUqBeOuPTPQ
v/lG7UKq/Ww/6ZinqEFIbvctSdVF7yCzrOsi0J5KMxX5G3ZN41nPeknovot/ OuJPq0auqwHV
lCo/gNj0bQok2sISbndVYdnzATipGskXEQ41jSbrEY6IxeIZV/B0R+nWk85O x++LmTWoE4nV
kRB1Y0eWemOShDWiIy9dBGyl1lJDteIpXRVJpuS+ZSYmLmU4N6tCQ+ww+2Ko 6JrrT5pMW+It
3Xv83PznEfyKauQJYl5ZNymNqriIeLPtphADdMLM61nctJcdHhkQMsxFAwIj ZfwUnR04c5zr
O1QBOvAsbJA64pu7df9ej2p8M/cUbRY1rrXLY+p+FYo2OVDqKdyYfVGrpBk6 eAus+q1M0Cgk
NiXpu7JLc3XKmKo7faKu/jWqJUJjZkOsqD06dGjaMmGYG/4WONPSH3WeMZ1b ZglW0pWFx0lw
cUW2gzHstiKN4Q1EjizCRI2T8gIQZTW2CUL2w4sT1IA6yWy+QavlBL0PEMQl AZSIhKJVU2zr
lszEqLxANM4cucaYYsvKOaCHKAqGMRMECELWFqxZpkfrG2t+aM4XiTGxXsC0 I/dwCT3LkJc6
6x7XYVKnJdadw15KJU6OlohDP2GSMr6l2IwYIRKuMa61lbb8WXzPtG6vMkFH ybZbpFo0tawy
y+tyf+sHvxkQqCPTyLQX7NFRhd25k6o/q6xX9MaRaO8+vSHgYuacfEAa1m/H ou1jb+nNJ5CU
MbLFmmfAQl2LgZf6zAtAxECjymQQmXAV/G99z/eJWynhqlHVcIlaKcXoxPtO YtI93aYmy+w2
yiXaGmmIhL8b3qiZQ2J/XPmYlwDTEcvYf1DgP1CyLQFS6wQo6VD+atgEuiER idTVMplzVudb
JRDPxDdSsj2aFNhkdx9Z5UXQ0IinaTGY73ox20Ad1AC47yEtcy1iOYRGDmeN NByRhZvywcEe
Xeri7Y7Zt7YFRpwTV9Zk1lVFoh8saKLOfP3uAeXoYz6U5tUHnYhWRRx/6aph Fn5/tSC/R3zE
oijsDxxtTPecFdYKqVFaOwHa6BY0ByqYCejKj3W2Cdbn1tF3ntJdQXUll5wD 0mx6dCncPgHP
nwRIkPdGAfUErnuMvMcLKwmN+IEcgwO0HTrznrOmHiRChT0uyLawvqeman4C E9sHPcWoUGeN
cEfcMYYi9oc2LFpG8K6N+iFMNOIGRpZ2UnlPhvK2g0hbs6pXwXWvI4ojS3BS ihSRR84HktE8
9ENAtM5Mc4G/8pi47EDfKZK5lYxMm+93dewxa3nPTLlirHLsUr+IlTzFR9ak sjDDwWKTyhAj
RD6ciPmYr5LTZf6zT7l6bWgh0Xi74aCPRKl5oh4i1aCMEBqkifESBxUrRtkk FPJ+GpdP4tLN
YYTeiGpFpBMMvK13YopKHA6k7KNNkHaId+/ODVmPG6dIFq5mV5RFsufKchhu z4Ktrh7xC0Ps
P03FRhS1mLyB9MqggONrIEVLfrcQQ/xWAnmg1PGXhe8xynq5/0qMqZJScOY1 HOXROs4F7fpK
8vEe+SgTn0eegueeoq0xfP2ZTnDVGKT/Wlj02hxIYWmNnOJ7j5H3Np0YIWSq cUGcJ5RqvnE1
ueImofBM6AETFm2KnIhNvEdiPBnh8kIteUSJYzsO24pWcwVMdAWcoRCmjtSB u/98SWX3o548
hhc5mKnYIz5VuptPFjOUu/XlPo+Qq11+i8UpCzk8gTFA0EiH7ATEyGbH7OQV YfiAw6UFnmrm
M3+QMx1udM5O58OCZD3pJSQ8zq+EzHQRlqDOVVhTye0ywpXgFESaJOyNLfiD HBj6pzw33WrJ
are4ItB68Hil+h2dHrNpNq5D1L99biA+PbLyO2IlrKvbKO3nDG2cF6rhTrrb zOWiZTCP7Ksb
SYq2MfmlGHcDg4jImFtia4g80furPpDJyKSzgNFQ17NlsUvKthuO9n0I6rx/ EcY0+DaSQ2mm
ucW7gbbRMxsUbRd8Hby6YKqV7YqLRGvWJu25anuO7fPbUool0fRyT6XSCJao 2RPGh4eWwMMi
RSY/t35yvTVJv1peasdY/7gGSdmF8OUPauBkMspQDSzzmxIE+Istnp6LzsAW DGPq/1y/riH6
9DGLbuijzqPbsatXv0qbGMUXakQcuC42J8NHteac5W23xYvXtEg0h/BSPCzv 95AoFgOyMrv+
C8WEKyQ1jLIuHS5aSJwXMzBv80UHaT2JbgYkTv8nJL+ZLzaCQAdYAsks3H8N bWPMXeCxtSFU
ceXU0fPgEH0QNlyRNK75tCy6elQjWTbQPWTkV8tVmJzmmvt1I6Hd2rzsh4zH NVzKA6TdA0v0
8Sv/df7PnocZpEcBizTVlGCiSXNVwYjNyllwhAdvOPb58y3UWg6Rv+rGxCTW OeR40kk8JFGb
GROsiuWe+05ZA3M0xT0rzzKaWwqpVQtrjKRaqdmqY/PPrNwIv5U605xzSCNE AeP2YLxPpxb5
SJ4brbd2mVHnqvFRYI4cGANmZPKGn2h0V0i5Op358b4NsISOh24z7GyYTin+ Q2UbacGGV09Q
LJA0filfPSbOzc9mjk1eoqKSBS2piI+VVOPYgLBpIg5QySmzl0eC3t32nc9f Bc1O0WD08MzI
hWWR4dLDNJsBSHSC/tksX8mWIRlidF7k7Ya5gzwOBJhTx+hupoiiPMAxkEwx bRNd+cZKYPg0
8+4/xd24Xa98T6h/x7QY2ENxTczMN8lEkhdyk4C5ixDkYgaV8O8tr8aWL4Gd +lVztyomG6uK
0lM011Z+TgjYqyTcBspRjKcvhBJGDs2mfBSyddVSNwz4itzCzKCwdJqRQ/Hc lw8ppnNLphzF
/LoVBytO7o2GXsJdEve/SSCGKfhk47w3FkAtydz08UVKO7fyGNPgm6HLXTVB JDfs6tFGX33j
tPPQ8SzLoVr7WfsODH3FzDKdTzRWdtRX201pxDpuZ0yOvZiBkWMBgxrhGmTH ugZCH7c9pY2d
kujUIL2DXuKvk7TLQufYFzExb2/4I5VXaXM+BMdTS8KBShcqyxjcEbZkABnI MsORVtdA/Hqz
WuEnLaWpwpPML+4aUW5Ghope17Lk9SFHLIWVMC+Ha/7ia7IXaBjXz7ptrNQS A8H8uje1Y8Zb
bx3yJAzVG7bVHr/RHRmYLpjpC6t65mWtjkz0M37MxO8ZJq/W036Zq1YwO7EE m0XXFIgCNJ6q
eZAvhhzJ4DreuiO4nHz6ZS6nGl+zMf1820XDI3jxlINmR2MXi5sjJ180iHlo zJq26mzXPCP6
Jn7Immp9cy2l4lZbgB4zHmQ2MPMotexGOY7xzbWzVHihbuX3ZPhq/4cDwZ64 LYw8uesuxld8
Vcm3KxHQ33JCdssXpXjk6YW/OUHn1pa1L2QJ7Q3NrgIni8/Sv4Pf1o+ruiiN SQJD+7bVpdTm
dmpfMiRhW5hBUciBdgDM/FtOc4c+oUuFJFanFjmqEZsRWHeWwmxDsUSW2oqT nUCsw1QfkRjU
0FKvKc3kQCfKp0k4EqZLto0kK3rbZ2zSVhTII1PLpryvwZDHZouQ0Qun5BnH lmazgKS3WdrF
Y1LG7c5O7Oa62GIQgbtTXH2HW0Fel0TEYhjnIfBlMtJTMKjvxGnnOli1bePW 9suikaN7/OkK
AoaMcgc+klPfUG3vGHdHq+vM+vnBCaqAf3PKOEsn9Ex450d8RG3JtnEhXzFe hKMvN8mAq4Io
ixb6ok9tDxAkJtnO+uB7yiAnWKy5XNcBj5KB35E/zEdIErv3ETbFYtvNgwbd 3kLQc8irxQeu
DXPYmAtUMOdzTruZLggK1QZWq94La6WLrNOgPPQupGVMLwIFaWI7Tp7YEY8J UgrxeI8YzkUw
TsewIe8jVKk+H3S8iJy29jza6M0olEWCytriAzep6STK1Lu9wDOXkpCoRIuh TOHk6zTd7TnD
efX43fMwAmaeXU/rikDDLnPX1CpWLmopHAs5sMDVKoLZ5Rj0H66de4x4MIXg zXrweu6MwwRS
lDHXq4kNwmAd+eNucwjV5AEcn8c+KqUo87qi8zWZZO8E9AtXm8v3t8Enr0df E87OC7obCm7K
MtXDiQ7F+c6xkAHFK80c0WBG0sQH/ONTU/JtKp6zMNNGSTgd2npupEPXtG0d ONzMTV7gl7dZ
lQ5O3nlskxRK3hJvdVc7gYzxDvVki1ySOQ7itUz4RNL1Vab7VnEN8h67UEJl Mhl+ZjXefSpQ
VqfuhSbXhcXTUB6q+VKH2e1OXc0mOzci2sRfZsHOLAyxwEPNFEXHKpYRHIsg WejYC1zE6ju4
qOl0lK2Le6btfSjAKG1bvEg4xXPL4vV2Y0RH5rHKzRaJp6jVMnfmmk2WivOx 9Y3g9NxgCwGA
Mipm0JrjX18FNdEitlSvAzi0P++biz+exOlEDG0h81Vqa8skL1qWqLIzqfMd DbB8QBem++Z8
TnZ57pEL07bCXz00UldFGWkgImVVULJAMnP3XdIQ7nCHEbh7iuqSN73oyzv/ N4pUA6budRt+
h1ElHDqeqM43aTCEaNkyQGO5G0zCRt+djpCxTmsuRKqqcJzkwthfswx0GR3k ydbuFErXDr+9
xricrdPruvRPoU5uAmw5ink8095vX2X1g6NMXUrrQeGrB7E3YsikiKDsWNDR uOvg6CGj4ZL3
MAo4oLDFVbsMBiK3Yi4U4vbXJ+G9Iob9o5rSs9k8g5mGIt0A+b4Tyy7gRtyv Fqe49iLQRriJ
HzMpAo8umooDMFR5zQvRbTrSRH7G76llZoJRhpUdMl+foE5rgk5Tkz1lepVg 1Z5nTQ3nzbVJ
8H8772hecxuGqUf7db8OWQboMtaLk4Vu5c9ayNfGdM3n2TqmQLQIeMUJyKJy lV9/eEoh8QHk
dKdWHEdr+o6miCnbiUeL9Urai1Pyh1s4i6LhCPXLu+mAZyhiRlh7uiQbJ76u LvVvqAWBlDOZ
QL5VZHhxHsoFhJ1DAZOSbTiE0BGnTkIkoqUpyFk48aV1SsEzg1WEvHznsneO yhn0TynokMi2
gvlKpE4++67u5xStmryvbVV4rrQ72Jh5i9eT+hVYgjHFJGbgwuAMHyE1qZVM 6yeWA5G85Vzo
DJMgZityd5N0jru0hwmRhk/1VxG+VS/SXtd50I/Pb5l9hDhwq5Z4hYjW3qZA lGlXW2ia24ue
BPJzNsUk94KZfnQbi6PMXbq7Rx8I/9eoeBSDc8iDo6b2zSb2swFrCcPan+Pp s+2Km8W6SfwJ
0dhY/zViN+eBtKMiFuKmk3gESpIlh+WOX3JR5yzHLMusINUxRtgkGiXONYIz +muib55ZZ6RF
AWuDs1ThTdYwSldZwWOQR0tuWCc2bRYO1wyA6R4P0BJTd7Rq8BPEu8GxPNBk V/rFjPugD8/L
aBT3EeVSoJJaL1ivzR9sPMcrkLTRq0qLBEq4kCzoAjgG7ZSSAi/CZ0PoV6cS 6foby345VVaQ
dELsipl7SYz9g8uV9yp7Crr+B5XQBNzL0UWqOGKbMLYS/t7kDZ8EfP05XNDb 0ul5jUzrnkIe
jZCtZYkLWNCqg245nTO+carkesK+BbzcdVpKKYCsRsYpiyPt6EBH7AKNWlUq sSlRzLRl1Ucr
LLHhNPMSu0wgOxFhgPnDM5lVLyug4X8xrt/ukpV/mkPiAUpkCqxwP+usGLvD 2hyv34Mhi5Dn
qgDr78WXfZPmqthe5ubDymPpl/vxYVZr33wPQvqHS6ymPptJ1JMylQ5Ei5zG a8zrZXnejYWP
t4NLDQGB+8ZIWaZRhiCy/sZqkI/s9RYo/tj96amoX5mz4KKX/xgf6v1WpHYC 4y2e/zDgg+ID
E++1XTz/MefH+8EXLNsnXE394XBVudi1nixb+Fx48+4Z1r7cS/prM08ONW/b kblpMdm2iyV8
8VG5LQBGlPeUW3a/8skKVMFjSpYNSU/ct4sfyD/w7gXwrIP9nu6Ve/SonTko 6Lu7FjwIRi8C
PHnVTctIo/+wnfsuSOQoj9vhKdvzSHnyQuSeUiHvZW+lHeWxTQvL/VqvL1B/ XCO0W7AhpfOg
nju1/y1RLjtFfEBFffBlh/QYKKOz6dv3kFNqgUOnSObCqd2KfaTJvE1i/pgv 7CJb/t1xV8kY
Tgr/jpgsCGlis7yoo9/DbtF+WYHHkv1QXCyDbBP9UKFj+P/szfp/wCI7n9Xt Cqrcv5ebJnOl
D+6qSPvorkFECgQOB1jv7HCelS6cr/oXTS4QrgzWsddTG+EYLPAW/0E1/juv 21/cwvIp8Kqc
tPKCE5y+icmQ7qWK/s16+Z8QEm3cna9telIdxxGOc94X2TwLuShzfl2UqU4H cdvudR54TozN
f6uypUg5ZhzyXwr9FcaP48o/dO+y/KMj8uvddSZPhcaFW/ey4Lfwdd3r3ib8 7sa7kf6AV/xv
X7qYlOzz1VK4tKi5JqUMFzfLXKqmsL9WtP/trHy/5HmV+j7vgeu+8wnFe3DC pshOOCPoPXJM
Azv9jZsV0rCqV0HGeySxoEjngPtF1BfEEm6OhXxGjv0bcLZhB++Kz2qvIsrx 4L+e2QIP/VA/
v/A1FDf/twy0hK9xxfh+0LM7qZfvpaFBCznXD9F9aR1nHiTDNNQZON3PsYsp vNue4VLz0bG4
4dU192ETC1vqC+/Kjn2bi+WBXAijsvusfekCG/Lsw/0wX9+wM1RV+q/U/x0w WRZpYqP68o9z
Jfsv1PE1if6r9Y/Zm/T7sGjuf4f1wQiSLkfxfjj3nuQ/HdC/+V/V3rYHwQPu sagJV2c6mOaT
OWo7GfJA5Wl3hH2EqBdmSSrDvUzrgYMouuijcWgmKY8NLjol+gdmBkK/gAxq 9kWat5cx36zt
gXcnz1KF2B/3qILOrm1OC1pYQVbb7esSddn3bYPPmP0oQMKFHH8Sj1zpWJqC h3ktmaTjGPbF
QAhT/qtf9RWcuRefiM09lB+B8ODv+fD35XsDby2Zp7zx7z+KIvEWoIhYiJS7 QWltv/3Ta/03
gN/qz/ZBpRS9ODnISdG0omQ3QSDsiCy7Ga2PiAycPj2ArcxdO8F0mFwnr8Rh 4ecmOt5HvG1t
GaZDcr191dopFD2/8Pt7uQOWMDva6KjQPi/C0z/uJELEJJzF+5E2zu+dI03U IXQ82N6ftWHC
tuLikZ++/nP5gfySnXW7x04ak/eiI3xYF3siaP5bvA8hBtL6vNK0BxaC8eT+ EcU7C0vmRflb
MGr2yxPXsld0lX6LzI2gh0DXVMELadYl4g9Oc6cXj4lo4pQUFydxbGcFrLOl FCyZcCvsxiFh
jwgid199EiN65v7bX1bzHOis5rQ8UX3ZY/z6xGwARQ2GWOCWtweOdxX2qmpb EBRomVMXZM0N
Jt8ZtEhzR5BHRprMkk9vrRCROxOI3Fl5hxXqE++2aeakehDUFA5FJWJsvj3w C/jIO5t8m8p0
GE4qpAYmVkpHIJ212kfEXrX5sW1fdvMogfFF9/LRYc1H7zShwGrpbwDjAvUA 86zjQKOTvPeI
qa0Me9pJ3BFBOfekxQBwtn23Juse2yuam+JMmCqgHvAeWhuvx9a8KGZsvg0f pXH31J54nGO2
i1EH6jxxNI8qamwN0lckUFSavKI6+9bz6vKl2x2mjXjMzL1WcfuoM/qXkyNT ieHWBpaKsnWi
udXwSRRoEVS/Ut0j+TLjFDrUoekK+fEJt9TXN4PutYPgjiVX+wv6NgiL6p38 ExZnUsLL3GyG
8+SW32t++e8gZjgLLQoxVAfR7yWFQ7xicUp6mGnZe/ouRbnRzfkzpagBJaJ5 pz0lqrXeu782
vhduBrOIggr/nMDHolmLle0ft0RvpypCvVT/44aIUFRVQbusWEpT3C4iTdx/ hgQcngYYAg7O
7XpugjjK01znCwT3Z72zJ0+o6aWRwvPn2qmfHuxOfXqHYWh40cnigJqVYj85 AwvpTo5nytdo
pcVL0CdrN3YE5YnbsXWrg+O1WSUVPefNkcy0eaNLzs1jk4+paZ67EWsR8Zvx r6zV2ZydZcJr
Gc7/u96AZxkLb1FZCbNJSS/qNUNdDmUQ9vdPdJ+0xYxIgWHaV9RAICi5Um1C ps/3zlmhr/tF
DYIcorlmhxgTWrbWiEhvRFr/9bJqIAqeIjOPI8a7FSOM3Kj4DiIrRDaylVgK YluqT4eDb7FB
NRQu4zEfJSxBpqVcuTD4ftHOCH8/awU5NvzddxnNsAC1Cp6uxCT9LSm/tU8N AYibev1nuJPr
CPO0Lvgn8FZco4+ZVkIyPafs1M4ZNayhY3jghI6WbOvtBCJtZzAtdvzp0brM DxubgLJ716xt
BByCB/+I0iecZSqHjTYQlN3KxoDi2qij+yknBzX6DV9Gkp8FqX5Ncd2iiHIv i5qGbgcbThCO
n4VS8EEY2moSMHkkFvi144Pt/f+Y9uVfMOkqWkI6Jh+DAquRwEjfwwh1lBWa Lh2N0n4zy3jr
gDIyJlIcEEXe7y4y9I/yqeC/xK/L+m+WtwtnYU9zHPXhJcv16QX76SyqtMBl PQG1oEPcK+IM
u3NBkJfYHAVrXUypQ7/LTb9QA7sgy5mo5hc0DKJK2EVYSbOHWgrVr+sd1a9/ F/7//8itSoj5
Aemob2SRdRlxDAcBwZ2T2Y5CvZQJMeBNinRvcNwVdEQR9LAO+9EJYNHxSWuc x7AL8bhEy+i/
84v2v02PGBGsTDTY9TlOuXeH1w9ud5x2yb93OuM8/LnhT/l/jMf6udxl/NzB kfL9b9ovcz1P
UA1MhJazzw+XqYkcRPjcRgdLXf80XzK38RCL/s1pJdp/bE3VKkv1R/bFoZdk ktL/dEq9dBl3
90X005N1/8+Eny/AcDKUHtjtRx+o8CEsBYhR8Pw7NsTBY6olBoyS/HVFylec c+38xJhrFFBP
qV3N7AC+hDZy62f86UYXlKN7Y66Gix5yH9Sq5vQjSncUw6mwvRXFHr+YFb/Z +BjL14F/cVE+
f37NKGEgZ3+7pyX2AFCEQpFV63FiP4J4jowPcCO8tsGD5SL1KaKM/58G/LS9 kHCG+tik/DGc
fSc0f+2MTgLmGnKmwTp1pGUBr08QCxhge/7M6l3h19D7/+ZpWHQu/KcyHGXK UqOIlsJChjtV
bES9B61bb+IA8VulS9hwCWWkha+A6d2NnabXLCkLW13m3PsHgpaX+Nld+gOX WVtv0A91O1JL
Q0W3k/T/Pg35aVXs8U31b0kwkjHe4ikTOz8QE7FbqR7YCOIap7w07jn/u4c9 /pN/0xFj5Zt0
R/21kfmKfacujnztFzc940S/t3GcLVyc2uiXixRCnYjnPCN3Bao5YUTJokMr 9TITQ4HbTj8k
zr42d+uVAGj62iaCFnoArvAOfaviz/Pqj5eob/znLVQcoIHe50a70V/bh0R/ xAJxn9mYLi7O
5/RceT0/bdTu58uTJByxX7rv36ybfLi3Uv68a8qz1u40F72MKJjOgWV2vqyu /4ftjmcvbTa3
A5W/BO83vCkLodNB6uhT8vAdd/VCk8z8sra+1MQa7zecKXERM6Lb674w+1fl n+fVb5Pv7EI6
to1df7KHkGIpEk8OujxTv3X4wXdsuO2W/nfc//6ASJYdvJwh0JHV3ioIHEBE bQGmUBNPEANw
IAmyI1wowKia11xpcBSXimlNKuiFEC4fQMKJqW0qCm1AjcFuUKIBooIwIQrK iyszBs+V2Z5n
RdXDQBVUfw+gfd+KIakCAAxP+y9+dHnUdebmO8fEkSXWty0gZoWHa/t+9IU9 KeGv3JbpLlnn
AbTSBg7CjJW4n2wd085XPthTbzvfrh8NS/Xu/35t1vs1zeqaCV1OgeRK3HDb KqKVMQ4yB4G4
fV3zJpLb1af8s/7h/89I1V4TP3e1jqc4y3KwXf41vL7LGd0GtnLdGuvZgUKi p4E/NeM8ir5H
NYZy6NYyyUOFnbl3CecSc2rLdJBPqd1hUgwR9Z70wHBNtvE/9+YtbF7qmznP VVSHJnJ0aNnG
uKq7w9c+8+sayale8934OBHUNK7W8f5tpuG/7PUvLDWgTW1RPL9qlbjJazXf 8ME73UkajR2w
U2q1nijw+o4dBn8t5PmjaR395fEypHgv+cobMhHbe1r2FGlr/+0BbaJrVgT3 CP++UTLbnLJP
to28QSkZk43huYn8/gDhiXflAZiu2m0y/qaM7DrGa9cPMjKxu2X4rNsAPidB zZJBH4k/qU/+
TeUTL+/MWtnLFlpOBVdCgB2h+QoEE/6EbUEGBl1AOFudLWtYIr8QtBtnaHxk I9qG1V8MtBWZ
fKK49VLnRfBHbU870kBvCBPpMddvk6qRjlBTP3QWfEuotbYX6uYXYsYJKMsj 9msUxzfzHMP3
+UthqnJNH9V8E8uxP2D1WaAgKulL+TQ3jf2QzA+dSbFj1z5k1d60Wh1TVU+Q 4OEQE5UXNWji
xWnJetrtMLOdgV5WVm57A3wkItwTDF84yC+D8qeKJok1wwOEsxolxO+OxLHj NHYPzckRmKhw
b9bCKyiipw2rz6YalxPNx0Vscx6XCZWHhxTH2IOQ0xCVyBoVDjMxCwKmyOm+ fyUc76GDQMhR
BfzedLkOpkzS3cVEr9KIY11Khd8/9pUlSvzWnvOV1vuX00gOxH1hjONsBtFw r8ZSSKJnH99Z
UPBzYwdfF69Blz+PeoLfnXT2wqK5z3dtcTGlkny4r3TEDTy9zcKZcnN9jKjS smdEdOruz4Hm
hfDf3NzjUd1NGB2N8j/HR1T2eCwp82l8pDcr6sRJDyHZVeihqfMa1dKv9aAG 427mfV8AYcrh
yzecLfJG9mmCJPF2o/CCHGihIoz3b3pfdibPBH7sgXLHft6G26ZMQZNU40e5 fdM7REB4nfUb
pkpiMSbeaK1hxoWQyqb8yCvflDuGouSiTl9W4It3dM9KhBcQtH1n8vZ6BJyO mgTfqHY4NLyX
cFCuo/8V3UfRoFHaDk1LJS8bHWs8Md1qK4WE4pyRKsWgNwpiYcKXYOBOmpF1 VlXG228KxKFz
NWZVd7i1EXxmNG/RjHvfv4h80bCMKxeA4zTdleuzuvlusjUTcbSAjQoXrdME UcOih2yd+pub
YkROhLVELlq/rakuIYISfIFukdxDXpuOAnQtB2owV8Fjge+gD9MW6Jy939LS U+LIRqEcrJW2
e5cFR6TGmODgjkF7gUBHvOkXN0RZhdV0zJ5xaZfSAy4oLUpGmzf++45F51PT /kQk7Crv+irL
irAp+pPPNNdEd/oTsQqhG0wXjqLmkskL9ZjLLnNF9u90VbieDqJBSEqQv1kH 17T+qlT/RFRS
XJsC6pLxi5M80VtbwEgxpj/W4PEp8ufP2IIZgfbp6Uw8U7eN78GYH33TfbHr omuL840xUgCe
eiByF/PPMAtaSs+/GwAzSzsSzRfx03lfZvrNmcXaw7aIshP3ZttYeXlAv5sW SbltrXFiPw+T
QdWcxreyNVBsZZc/hOB2a+qpt8jm1NDoI3lg5WAQklhe2u+kQr/c2hvBPcCc hi6rpZqK/Kcf
o9+/n9vJlqT0z3kDWdVsTIPOLmH298bxTfgOTpu2O4SZ+3OqkzNZIoRH1sv/ BUTuWt140eY0
ONT+CKFqBgaaPCVrF0imI2xYU/cnZ7XjteVlEFxXRnbONjBM2E5ZsI2D1zP1 RRewOiMmviAl
Zh00ynr9NUm7wEjBecs1/jX3Xv3X4SrN4TiYMThw4Xr96wgZA1UrKTKmXWCy o4Y7rkvGQKKO
rjSZsaBHt4VVp1MEk5JlXeXg83Laep1+AxuntWLBajoCD62+SYZcCH5qmOqL 0FnvQzMIzUbS
gzEZaONq252eMpC6QkYKC7amVF9huky+uxVft2Qp8EtnITnZdreZv+gsKfOM FdBx+OBoEGRE
tApQvK+R98lT05w6GRlg5cQ2wrcjk7OmtrbBobz782sKBrF8a7HuqlMhjSlg otQrCdXfVCSq
zmNPLFvoVbqk4zeRsJOn2U95/J8dSUmRtqN7/Xuz+kb3oTer7mRMDj0dz4Jz VIMg1cIcnqau
qfSxRw+fi8K3o+21BsQEw7H+nIzEC1aXM9VTbiJ+n9vISD1mibPyPwg6SuuZ pL7C8Be9DLCF
Ih383uxzaOyQzBR/wd3jZ3V7mNsKdKlbepB8l5GACw92FFSAx+DosY8wL6WT qtDL0e5kKd6W
T0TS8InuEoaFc7A9lHVShBAmNVeNGPW/yM7F5fTY+xMrUjUtX3sNROybllHw yEh6bKpPJgBA
R6JvHpq9FB3B2NPU1uJmx74ww4g28SWp/+RgimFGiscAVNS3bhTxSTB5jWZ5 vIp6T1qbFgaE
o3pXQGbbk/fHSGIg6bi3aK8qVvR+V/dZktNCGSbg7ohFsDO/x36QXdtXxYHl P4RtiYOlW4cI
Jn59znn8QiolKxXthx75GRLlo7qHo+ImMqrdv3BXC/PGT/8gsM/GtyxOeLFx HWFqbXMYrqhb
7AhTHLZh0j9Zjts8ZkPuAaS7xHOJRqTJWCxzhTvQD7LP+ZMweR9bFjAuwrIS dsUmruuk/8rJ
7QugEmiHk1RNvXw01EJ1wnfev3+Dd3U1j4Wv0TLeteS4owKTQ00KOkt8fere uVpU5ix1OB3i
hJSu0MbYsM2lvTKoO0or/pt6IV+xXOp1+Ff6LrRea8KagbazWlqEK3dDrs67 wAqMFHWgMsju
R31PmIL0yGd84bCGGC5+/+BK6sStvbxsgOv0PF4kPY8Qfz4eqOm4RRThVd2S RKSrrnzUe+c/
BfEprnZfnyPf363z+YT3DNM4JP2aGgC3DiiL2P08IXuiV1Cf6UVENKKSVuJi UMV0+sImFO94
xf4dKn6A+KbnHUuAZzOMTdEg95+k+q4Tax7Jpn+PF2xsWknMU4xXa0hEsxxK 7Sibf4B8aGNG
QMVapoLHelzC/kUvfMhVv1PninpptgJsOgK3iuS6RNItglIcSaAbpL32R5cA VWriYMjqzzcS
yh+EvBpuS54ziYeoXJReY1E8Y7xZOJXA9AXw2w/q9Xe+qGLT9RqT+PkdC2oN D15nBguojBVD
Q8QHQ1MLJHWilWI1tzCDubfd8ZZDnJb2Uj72es2TIxlG67wtLJCyPd1Dg9Xw V/6adNRbdea3
csc7Fei+wPAbpkQsiQnBJtG1YUd9aPrY0JVllx/tBGVlDtWdZuWw6jQzW7WY fwsi38H+OA80
bEBW3GI9DadevIN8NOPF+dvOUBbBuFMywnLZQPR5effmqixylwvokm1gDfxI f5420LgjPdmr
Oxw0OdgqUiDE1dF2qgRAAkdc7MnF5rpp44DZPo4ySvi0l5/qpXozsobVgqBJ amxmXbi+TH4u
QFYKV5AHc0s1pcTECPTJznmUBkB3UOB24BnxN/2tp5RVa3lc4gcytRB5EAfT yxTuuSNbJrB7
rQiS4nZUzvXmf4rvB7xhXf1VmFf8+lckXKrTqW/UN+uy2cRnc3NDevPeaR6W TkOJXLoDT4F7
IItvnGSu2WiIkN8RszdjKh/V8pftNwKYHBIET84MjtX/4z2DsFVdXOTN3hJ/ OXRO4HlYwTk4
LtP/v+5N7jjTy7gZ4Wm5ZGeRqFXfZ7P2EZGiK9LVaKalph42iCol8kNaooDg qv8NyciPxO5k
aqYB2hEeQtagBsdgDIWB7Bv5m1El1oZAflOtpEPCoSMBGtMvtkNLCdGT2vLJ gVmxtkCPTtuK
MK7atxG0EagUWPzsJIWrErnZhGX0RrqisdIShMElyG5W9bKVcXTxtGkVOI8u BWKo1t2Trn8z
o7T6Jwv1esiJNQgEv4+P48wb6RGn08mjJaTuiPSMnG8rikDpTEttUqagZKJ/ U7mcEdOCyPKL
CfIhVmrPMP1fHpG2Ml25gcw3zJvxsEyyBgp2ecVV9Sx92JBUFnib+tgRZ6iw vl5DFVmpnEAi
CfEPXu0CtV7ilJpk8izNlM8nL+JQF5aNCXqUeCHo90JR6P8N+GW+IluuAWxI eJEJtQI5ED5o
fzWfyM6wsCTVZaym7nMVd+jznYs9t+rpoat5eFqwX0j4Q0NKLJYlOJ48dqoc TkdfredhPl/s
SZTgsxiTsTw/LScCghbIUOhOr9LMwg3OrfDyLV8U2OtOI+UAtk+IeD28ztqM 7To4Tvrydyes
yN7sdPqkuAtH6dN29wXtevwMMSvkXnqKxBuceOWf/ndiPLr7QI5oQnySIWq1 3feqaI45R2hb
wIGgh3qq09n0JRbEpWBVr47L6jd3sYluVZXUS1SAmijh+sAXqzWVaeogDwgo LRyuxD9fYFW0
p0PI2KFgPM3UiLq32kRh4hPjmEdirlBkAvfsEqTvQHazFoWJRyF+nD7ysKw1 aa+1yvCUqd6R
B/Zg92zULQGg2+JD1bKXObQ7rkegJscqrqv97XrtiD3lIGIho1sW/u4DckxN oDQZkAPZb34N
mD/Bd3YVW+v4AD8n00ANTQlQtUrvADo/oPx0fe4n1MmyIDr9Yub9WJf1VfyJ L9o6/XMsAUcd
HaL2RSz5+ILG4cd7WeVda89qJDi3lNriUR+dHSRHKvKTvViZSQ+n/7iiUxd7 EjpR6eJxKPDT
XbLHrnyDEjeKUhBaEKzYMv/B0Ymc8GRLnelPbKJbtGU2Y61kxgKidtAxEDNI ercobpPB68Q3
v+p8MH+S8alyiJwdxE6riaktf33vgwZt0a2Myr/cD5861NEH48NSf9v+JGxU h7/2G/aSx9pF
UQOjFsu1IkAsgJA8Eaabn9N/MRSpwSQGXXDoVrNHysJqbizSnSEnwbOoAE4j 0PZRpshZIlCP
GgP5a+ZN3WgN2O/q1EL2q66WIx2VLrcl55/3/7QFsZCivYN6+PplRJX/ivp5 bXCzVy7SgwdT
geImzm5jMyp+gIzFD53XMqlRwQXzuv+kMpp0IJA1AIVfAAAldgAAAuCZ+dcr SiM3HTMQACAA
AABzY3JlZW5zaG90MDEuanBnAPCs85EQAVEVCNVZFBEd5LiRdRakwAixJZQS X0W0IEjB0mAE
iwgQJGAJMAowegRhdGAECLisebq73v3e8SXBLi52qr1ebzVXa+r8vgGjczEO 0biw8O+n08H8
rp4sO+nttq08Ptm3vf7b2zfPL+emAGfAkJaQADAwB/x9n6A+ecARf2MUFRcV 7YyLiwuNjQyO
EHdIiAeHiA2Kiwk7p73kA/PO8dnSGlLSchoyqjnR342pPVV1gZWZlQU1u8ra xeRaY2Vh/F3g
waGxsgHSA0IiI0Ye+d99h/978+dmAGhMNYQ08DgwpABo0GB3/F87cAB7MXg3 9hDAH99BwgGB
oeJCPZaeIZ/bQ4NDRIN7Ql2xAPDfyjf4A/7klAgOdw2UInERE8dKe8oqS+3U +Kbt7g4+eIqB
EqODkGisAWWpivvvcVLo1pqe4emCwtYXzitey8EIZ/H5/3erDP7EQ7LIwGuy +Q37XB/59fDv
7z7Up5QbogcOG3u89oUr8tiKBU3U3zzQAr9RdmRP3AAIQDqQAMxPa8zCy82W +IywBgtRH8A4
f1FgWZGnmjCJNa1ZL4MH8VNJ5fJ8cOg5JLhdmODDnaHEwkJZadfkm+FfVXUe v1O+xoXRglTa
3DTv/V51L9O+BLFsGF9MtwGyBqUbPCpjLGhGmk5Mt5e2QaveiS3gQxCZLg16 Zn21w5Skz7Sf
Wk3/U4T4zPHbkfsNAz2aqeBonbhXiSQrHAmXhaK/aemzc88jsKNJddubxgvr hJv0+7vAVjbJ
ISiAPjAbU0zIvQnWdL6EIfTbVFpUrnpTbxsR3yYnfsZG/QggM16yfmNVGOk/ PhRFG6QhNCMj
2CzTPzXC9p0JVBWnIgviZ9XI3ueBiWUONZxHIdn8kawtPq/GRfujaYnJ9jUz 6HFgHwzW3t+w
57ygtqREP4SE743ypo9M2Ky5x3P4T0I+wX5QTflpU/VKDWPXvHh9Q6aFliPW r2+fmwpoP1Q9
A+AvWTIm0peuM5PEJYbr+bdG9Ir6TVjpHza/ONID7ek30cRDFjIkqxaKy2X3 f7uCA/r27Kre
P15gRSvlt9/jClNS4n5uIzdqmJWhZCPCf5/Z7JR9ADIkL87GbSObCLHhUyf+ q0wQkX6NW8KJ
HuG84yj8mXbKjZe2gC8bD4MC5ei3IYo+JC6WxeMhxGFhmeQ9XEU9L8TsuAzM THIYf5jqC9I6
P/nAzXT9tgFb5PREf85MV/vNY/RQKGqac2T3/q/X2gKVP/OGh/vlv7JXc3b/ jVdp/Wn3DgH/
vGbw9/xpmUGJfs9BMdTP0fjCehBfv1Wy300ifzo15P1a141/KSz/SkX0nf1x Ls1QI/R7hN+V
z+0jfu19VHv0ov/SK+wEahPk7/XBj6RXURSNOv2VA+nXbRrSNEEiGlmnHq5i bAXqJUpt+veX
g5RD6+5Hn1YvZoozzJmDYBaiB/MAEJRLlMA6GVhV7Vae6LT256VmpdcltpjO kEtr9s/N1Qsu
9vSRnJ6iHUK9ej3EMKD738YD6G5SquY7S40ndkK/ChDWr1ulIc/q4Co9sLLh YE6RrupcgOtF
9CwSAVhBSzySLrCucLgkK8UT1ZjDpz/gCMbOXb1nUGddT2ndYdbI9dbUjTyF 1M14aBMg6CTt
ZCqgUvwfa24X4gkfq2bE3FMTUQzgHhF7rPHLYZ5P3IreJssr0Sp4dK1KdQ1k rjFdqpiwtxLM
UJbvd6ynEFzmyn4iPr8NXEc1y7PASNnu8qzmHMrJ4sn6gDOjtPUK16Smbzx/ 3oR6gvts26qE
na50jmH4B8WaBmA8Q3nPm5WcwObyMfUBu0BvYDndGJClM4sf4T74iJVjQHH8 KFDsael+u9Do
mqjj3dzqdfarf5hIbNIVIJWaeEOHrffj01Lyx0zUXS6h2LIUmjcBcelzSIIV UyvLQPqh1uff
G+Jk/cI6SMbCl9YKd5ncwAqhlUqy4aC81etWV3e6fSa5Vcraw9T1aUDz3B59 Ybzr71mkVD1G
smt5krbIqV3cnzSguuD0300cFZ6ka12wPIyPqKfdr+GM+AQv3GEbRKrvxBy3 uXzRAkUaRFjr
PaIfdLYi6Fx+oHQqaYfT5Y2Xdg2vvVvt9HNQp6/wahWDnaD4LObvZ8YzYkKH 7V46jxknFRI5
Z2ZROzmsfe1MWWyJG4VoIvBAycuzEXT4Ugb9ubbesl5Zx72tBJLCuDjFYrqy 37La2hX5cAVb
y2fHK7Mol26XMj+vNRHLlEvzM5OTspL918LJUXprb4ZI8TYng8GMy0HI/ngv 0YzJ9JkX5aWR
fozJ/4lIui2RxmNH0Zy5vg3a2uDfKe2Mt63xTf0zDCGQ79uLkLO9mLES8+0l Vl7lj9XJn1tm
izHPYDMrTf8/f/G7/AjjXdnqS2nfA1eUd5yQfN+a6f/o0cIjT+gQpWYxeIGc wrTsuaopsfqR
vwm+sivlSnvjNqtc5jn+zDZn95f58+Q5iliafCXwNUZQYpPrWHtTQv0ir5E0 swSlZBnxfV+C
kSnwLwwgP6VAuziKCdtNhf72FnP6tR8i2xkVrGsM97/d+MqXCjs6f4tdPJ8c vGsH/nWUJfzE
UqhCRZpETSckv5yd0f3qDf7GG+jubRP/lITw2sEGylx/L0fjFf83P7ghOYl9 NkOv4y0EPixV
mfxp/kbShpYI+Bfr6Av9msp/68/rp//8qtEoYIxA/2V3/a3f0dPAU+R2a2Pz uz1Cn+fLQ1CN
PemTTkfwtn+uf3OYPWH/6VVke/uldNTs1+30qA/eQqLBe4GO58wHAV9EVnIH 6Qf3s2vW8tly
2rK/G3lRsiICSJg9k+2U8ut5vM3P0rH+tvyCKWe4fqP2ErYnVTYElL/8jPS+ Ivq3X2JT5D9m
5P973hEswC2Ge0g8hco8ox4nx0uO+TGTPe22R32fv/YN7/6uo5fE1Uedwn7O HSj0ULUTC6EI
qH2O+HZh1j6Im0ivZ/kIXXHoJZmfznv/G6/R/DyLWdGlz4X+KV+oXA0t6bTn 07bhp3HSnn/O
msqoUxjq/CwMmbMIivlw7+w5Ps74VV8B69DfhO7rMJERZNyhsw8AWW/jctyt 0AQrRvFMGFSb
6fPTFXyvr1UouIXcuCV9dikGmZGPCV5iKvUojzX9RuIvuyIWKaRjEU4Sgdpi ccRgbsbDNvy3
WYnZATDfbFl7FzQc2yW3imS8ti9IsiL/KO+bWDFuC1uAvZzjuOVr2/iS7bPm JJwie67vDWSF
3BLKLXJ3wOCjuGFNuNtmTRgz6RU5+DKRSBu88VaUTgjyi4i8CIfQvGCY4t4f C59S5n0hbnbY
KumhG0zY/ePkkaoGkBinvfeB9b6VtX8CwWwagIxopm79s7OtHYessmu7PmNv NpKOLwzwikKt
tHMukRPyVoa7QNmpbBNBlh+7yT2fXbxuP+pqy9zkcNZyP4i3FX5UI21WDQUc hGJVltKnNwcd
h/JHxlI9STu2Qyy32H5Yv7GhBOzXonTZvojj+6biqBcYW+34tF1FWrOMUMeU QwD6OIxMNB6n
Mt53xVVHzKm28F0tPlDwBYpQwrZMPbqp897hnr7xvNw44MnNmCWL4j84w69o gGF9LfhOXenk
wt/efuehE0VINbx2pkJTJaVuCcu9VWIce2Suw7SkUeEpwW9b2UDNut58wBfM S/qo4uhfwbRS
q4GYYToTuoJ/PM73ttLfrtKaRDunfdd1YD14BTLO0AajDyWgOJPTMFNmiNYa nMWzBumW1reM
zginA73Sh82R9i33Eit8KesIFtrrkp3tBpVK08Ds72GIz1JOEKuCSKa/22vn hZI9Mj62RpPm
mZXRzxFiNpRTz9oMfbElKydWcsNjyhETfao0q1EUlt9nawHinDSknKSn/Zo1 aLFDQqeQww7n
O2rTi+OprhE2dj2eO8QsdX/+K/J6pHWR6LyZEGTdPpsN1bMdDxDIrGZlbYaz 5nbvyvfDbu9C
kLdm9mYmUL1c2nO/iadTspycqHlL1nyTyrcKPj+8oRkEOEDRsjdUrmIpQC49 5vOdYMjpN/HV
bkH8Q1skzqy19dowrc2JMbo+Nj3/0viwUqb+mLf1gudnCdCTcfUKO11JTG2X ju21VGSR4yPY
WJUjan257uz0r4xNz7NqrL2t1jSRb3uLXEqYqb4+ryT8sF8nyWmqHHzrNOvT GSJF4GDbz2fV
LfUI37aMYIAEyumvGBFjwds9MnYkK+50b8EpkDIYtdjYzTiUi6wtgURJKAoW BkBKI9Ff3ZDF
SXKz5S/1PZEzLIsfp9sOeZMKmYIktaGXjQkKuo+jo5UxQyQn028UYDgvMwIq bhG+n2YolRH6
47AkECOzRcfFrddbuWe+rD6d7ugK0teFDu5hXRUKsIpoWWs5yT6y1zR8fteW eOf/pH8oB+CL
Y4mcB0BzelWM5qhhmJPr0sjyTb1Rp5c2Yvx+NvwpdxavDgyEwk/vGY2Sjrem jbt6/h5t77By
mC5IH3bHxGquQYjnnCv6s6tYj6K++RmLWiuiXQjAYlTjA2h4JksVouk0hR6q tqgpDd5GQ0ZY
STJvqa8uqtMbxVhsYBZ/68Nrf38TpW8fMUQ/LZVmG7lftoZXf/8Gk8ZKIUmQ aJ1p0IMYYNN4
sXIbGFKFvwsT+OFRzRWADSbnehfKLuJ076Yrq574Cvi1xQmYZV8Nlu92FiJY d78VkqMC+BEZ
ja+873KrXi8z+fZKisPueb1hqwmJu8iUwmdI8wxMOfzVW+4RzTpi18m0kq5o wLDGhr7WDP9v
ZtU2bcaM2n283VWLnzso1mqrrQ0MGmTOXlCnnIAfsoZkrwRgBhtqFHKNmcEY xsDpPNwbW2cp
i3DiRp1VAffMAlR8t3Y7dqqcO5PSndQnJko9nnbvGrmvOesyXlA1Ypqgw4Ll RU0U9D66vp0t
b9t5gzc5qONI4xCv3iCGDxkrlQ2aUWZwWHu30ZWwI76dpfvCbaHHfbsec0Ml yc/18kvofSqv
eSasnbjrN8KeGLZV8EZ/Ld+rxqU37YPw/EhUr1gRsGAtIwGdVaoYVXUneevH m6YZPTUYyigX
8B6mH7fye/o5xL7qQaY6Mm7yytrqat+JOcfQbd5SzA+LNzco70FCZ3GJgx4e EJxA2XXYpMUd
OYbFccTIPlBnnxGgHCQqFDIyWCHVfJTj1USyTN3EGz1BVHguUSPkiFHbPXPG 3FjmTT+/XpLV
J4J9Gd1WFDip2fZYVnHKpWAijgFNT52KpuM4rt8It+gYHwZ3W7PGj0kovrku lkg7IeBogz1A
h05eORx9QMBmLcsjb60qpTB1oi+ZKnuU7yv3CpZP2yfj99/O6bmZiumwA+Ck VZczBqueFgn6
dnb8F3MgneDcF4FOx+8AqbVDIQLXXeUSeI6vOPRwfMBq+8irKqox7PYqpuzj a0jMg77qNlMt
S41it/TXOPp8T7qS77QKWc/ro5JWum5MWqEbVzKq2PJrSm+dNtYfvGmn2u4n r7V9oTtcMtMw
zBM20GzXx8RwF3SSyN3FLN789pBchya4+knYCJX4urbTtuXz56Pn1zAc5moz M/Bjm9mpSlDX
64vXKwXV6HlGqs6OYGI0bJ9o5OLcYlRSloh7xHdD3CAgmKZYUUgIjoMYuNB8 zRuRwTWetsS7
WqFBovh2DflFSitlG+u0d7OXjXg0a7dcaJ2WQKOtKV+4/tPevea3xPPzBG4e O2v2MeBWc/xP
4Q0hMAJoEJTab9Vnbo+HvGokpPhvfA52t0eZJZcYR5XW4VL5gqepp6olp61t GBxIs7Fa4gqn
jyw2qwuDjTiNFNHJ1MBnllsxeSuYOKotZ/bBGOodkYld3bxH7Mh7EZHFgcTP z1BCULpsNEkW
ejUHxoH0WXWddOQlyCXpz07PUTnVzCK/Cd2vDYFB5h6yWeNAsckU3xoeLu3J kJZ4XLjxcLxs
rNOQqoFuaztFln51+wuB6xwqGfrqnAXMqZOR0qDi/cI8vP2DziQIwBGPoqgV YfX+2ueFAr5U
ran8Snx6xKwE1PUNx93CqOHzaitVpaEx4OMvTSOG6YS1Uh7WAdeEJPdr5gB5 HNSaTJe9UFw9
w8lJQo0XCwwXFGrHNJaBHroXHxrPqg0ZiV/RGA/lOLu8y0SttTePJl65tbHp pe0VXN0jJkNs
R9dlvRM3Kr/RqNrBJmQqXSms1GRHK6YkGAcHtTmXLfSNpHtfj5lz0lpUx2qx 5FSZKLFFlI33
VsC2CbtfLiGG5IBdPs3M0Hgb7tJJHvgSMb5VNiQzw10IoobtYpJb75rq9bRN O/Ytp0lKaIki
i9QwInNTs8Zz0XvwE1aoq+6G1mua2ba813SU6Mjp3pcJVTmVzZNsFxpgrCdM 57NtaBe5n6ZW
//5QPgc54K/E4pvy4FtoEg3NiS0C92aFPbkfaQdZaxypX8Op8qA93fmAieqb v9zBHYcypSV2
WV/fWRxtbIdQylagD2WQhNjXZyvmiQGg+/uuveBVv6GnVBvnR8iNMmDqPf4e xCZDB8Vv+Hvk
zKv7AfTnF1usGu1Bl1Q/wOXGe/a49lx37UoE2bQSHy+LaqDOHj+4feF3N+OV xAcd0MeuhS97
No4vjEwr65zk/Sde2Lx75t7r69eUbNYdSNivk/lv/XkH0/SWLVRA2Pm7qMxx yHUQzW0Lf8It
NU1D6uKPUT4j686KNhU183rQinwXWqA4xt+unRHhJaSN+OTxE1eZufIeYiIh mfxn1qH/LZ6q
OJPvIx659L2kn6xvst1tevodEUNtu8CsIUWrRvqMQ7piw97yFn9zj3p3+fDA NUyssR6SH/d9
xVsl5/qli/KSD2Kqb75vnz/XPOtCebWZCsJ5WQTzJ/bcL5ih/4JW639w2/Qh YLRQXMvyqgTP
tDGMeKH/uPtifqHUffeNuOJdMQvvPY0WlWwzR29hA3mJPvC93YF0ezDiHDDo qyfNa09H2AfE
cU3Fa9rZ5/czxW2amEyWqkedjtsQf2AlUb/laES4Jtzp+Tjo9cbFUipDcrv8 wB62PH9wqpe+
/d3h/WQ976Oj+mKhZi9w9XJuLkFyTpKKZhK4HNU6dc10tMoFcOPHS8zzen1U X41K08SemH9F
IFA4USfYUGaweRwqze9TolETUyyshavNPc1LamXzojlUvZO+GlI7t7cO1IWU om8D0PyQSSb6
Yj406eS1yqU6p85J2oBW6ihP8XTWnOvL+ESDHDNV4lvslt7tb3rWOzZywlwn ZsmscUT3trNP
Udn8SQrVJuML9aFSGCP2RiDM3AtujpZyaFxTTKHryothoWVFCsItX5lainp8 7Clj4OxtN7es
YuU/OCEbJhe15Wva9HK1wSazacbGcEBREY3x6GII7VT/FjIYloaAtAZ/69bf T7EEyVp2tLu+
PIkV+F2CNP+VHK7Kbw13l8HKzfMAq+L88rJpxlX9whdv4ebRmh/etkGZQhZW n9r2MhDylHQ0
XDAs+g5kO/IpChIQM8HFRucvQURZLap+NlZqqK0bcqMxcWNHpvp4fu9yIXGK 7Yt+322do5Hb
VfBGlSrqsIScjMwlClCOdYRpkNb5E0d+6udphqag2fhlp5rYJ1PrnzEuQb0H dMZ4wJdhEUw+
kCIslkpRGhn0BWMCOtpKAfbL7P9pfhejWYnqqqx86KigL06A/L7NJhxWB5Hu UBQHEkdF4Zt0
OKRooKNef2q7gVSIlgVhK1sq3+wn3QWs2uLrhf+DBv8wpM8l3svni7XIs0Gb euBLPpaxc463
rHAcwGus4YTxT6TlkJs2zNDFPQlUNVWPZKnC2QJl2j7nFMuJze3p+b0TznCz c4MQRGpG+Md5
+cOPiGVAswdqlR+n5A92pDafC5xUKbNujjVXmWBaTMMtOPz1tlrqbJoFXf2E bmyVGMv2oD6K
KowN+M8uwhrEIXJTjI8jnXPc1BjAIzAwnHVcLaIfH0GZ6SD5kcxWQMQJ3ysC 0is7vrRq9TW/
uF9iLq4fEqMhTU15xan2fiWVwgoUtJiK3FGQ/a+KuRn5pIu/AzIcIMZ/6goj 2ljdiI/PdjPu
KR6sQSUpeIQBIzfZBodS2M3q2eercGDo5Ck4kiljvoldCpmVnmK1N+CnDKGS nd2By4L4BUlo
qJabnnuro1dZE4X1VXyKrwE2sKwj0sHT6TzTJ68/wP6IZv92jukmuSb/zAU8 mh8Pd4Wz4w6/
+AnwSI3mgnOnGduBc8diuIWRjfD8QtndWf+5Yaw+k6PYx5n0VoyLL0NmjCEo fa6Db2QEJ/VC
KSl6t2AtiqQAWuNWkyxGsD9ZNbh1TtFTWEAbf8QSmRdI6PPipOFslpo0FZyx hEmeT+PjTYTP
S/6JnpqNrZq96McPupzJRuQxMfvBjlVwokcHlHFdhIGT6f2ZTKWB1RPaC4vz dDg89Goq05FT
VOb1Sc9l867ratfGHqwzsLTEJZVl6jnXVQwTwyfXy/ha9Xs/lje8fPgYLypZ ctwyMl8p0Hc8
BX9AWUdwMO+fs8vYZ09Ndhbj40/9eSP6fTzLIXFdvBc/+KT3ZgKFLQxhM2XC Qp/KZIKyXHDq
9UePnHuqwZzvOMtab2kY4POGVsqsbaJdD+5mfwC2NFaC5Wn+l5k7Opg/mArk l2nv/ol6f1W7
9r9vhJJEZ/zGaoNc9MWEIvU+SYz2jcWqnzKFBtpNbkY8vAyFjp/LxqF0as8E pJgdCq3v+srW
uWsipNVVGKpOsprBaNwSDNFpvgTBtie/jx9seSCZTE3quuQemdrm7CZO+Q6z t2+pkuSqCD2D
JIXZVEAb9MzMfURqCk1OZNqod6OqnIaAsjqFIYqPEJFKvIqOAim3x3hW1UbZ F+e3CCsjn6p1
IyXE8T82LFyAcksA+ynqSEY1H7nnOO0HSbD6a1Mk192zMCrWcrLKc7xSDmFk Mje90z30qU7X
mqwSk1XTST6lgutND1wX3yTLECdz2J7v3rMbbLE3GWrYah1L7gvHIp8h+/v7 1/xCf/xUPZfz
nWbQNErMwjT34zu3B93ojCbfXHtZJZunP1VmWpoQcrskaN7oA6kooRZax4P3 zfbFLt0hOb1k
MSru60R7emHzH9h8XFyrptark+sYKiEitdoDBB/G3sTSKTDd+qSc2D8mtVdC w+yOfD8biOK7
UQf9Gifl/jJfmHtUwWpP1Uxxxa74EC5o5q+Sdcwsop2hFtMBCmyhF9TGYSiL GMFbllbokDSt
ydE80zwRUOL1FlekqZUtZOENcSZnQEy6DNZt36PXwMhXF5wtuE8VLxNIle72 qYrGsxr+YBdn
9D2JWW/zeQgcDdbMGmlIS/ooPX1ZB8cAk1NaXIiTlZcYToNB7G6111LeLdjL bzgLb2owsCJ1
3OvI5Ndfu97r+9xPWCbjUa1ApzRVHHhn5BXaBcpFzHN0wruudbra7XuwFM+5 JKotbwnfVQ3E
aa3rY0RVlYH06tdoo+8GKg0zQJAz6AcUHtZbTrabnehH67e2fJgqC2BmIrAh SlG3xaIr7pWz
ckHY+ceIYPj0YnjO5jGOXAgKYJJ85/L99GxUEG9Z55B+G3RLi17xM0as1i5B EhcfmkJtm5o/
ZX4/f713zjQSNAEDSgK5wtMshYvyTjWfRo4hjKkDaEmY/jGSQJBVsoMy8ai+ NMD/Ggj/2Ag7
nDzFzSGeFnpr9iNzpPE6DXnaCIh0O2DysGrkxQE84IXqFgMskZsKEWW5Lbkm JJNI4e3ViYDn
5WZbZK1hmlhrRowsbvueDWfHQTTBxQAX7S1k1+YKpojg9aIrTGJj46c3TY2a k3GEXFbP4dWp
kTreDBgXqf4gyP9+gjyFxUkdsYr9cQVNOcn+Op0kp4yu6YVgeRxHm9+cMapi cq4/woFL8imo
RP3aw5v8vnytYpvslv4hyaZxrGk8VbLzcfJl+xlV/w+IzFK46z38GhapfA/d oLGJ0+CkmiX2
qqhr/6WPxnpDtyXaYaDJiGMunZ6xNHwSajtq9uc+KE4BUcRsl+PxU8H13zJP kvsrmoICV8+E
mK5tORdyrrWBLoZKIlIv5Ej451Fot99V8cnwBRFA0w3Ud4Vd6/mArDCEC2vR zMxhJe7TWCl/
SZPrABxY5AS5qMx/wYyBDQqy2jDJ38qszHlQWIlZTZy9VGBgKLYejWEvYpSl PKJi47qBO1z3
EV0NOisBYjqREMkxnoJrK/ZsuSEV6RM6fHhr8zgU1N5iX2fi4evly4mwY85p WFndsC+zc9cL
xHmPMsdz9AgArtTuwoqAaLOs2QT8Sdfu1pe9dWjaMJoL3YN7St5azClxZLnm JzsUg4VfVMZn
PbpUSaM44HtonmfNuUhFznwdkk4pGLzCKLFMluQ6fC0KomXicYiq9F0Lhu6N tx3n6rdZMfiR
Jee2pmQZPvNOyCTY4wnZ+UXczIr4Qd9wIk7jRQu9nkeV0jFG2j32iPZAGaUz NV2PkOboQTZ2
sYSQUVTAywzT+MitU2SSg8astZWAGjy0eeQKWjyd30glkhQDItI29FgKRnqv h49Rhc4XItzg
+MU1NNckGPIvcBBWZvdsvnO5IrFU2uH6tI2LgdaHGqIPSFYI26bmaDQ/eWXP zADeX7Jxm4Va
WxW7JycjGBl6sz54GAxK6WzA7NAAed4sI04WCVobhWKp09Rwh426Z/v5cEth Huz69HfIdBzU
MS88Syo/f6FY0QJBHLEM6eHnaPXQnSzvozn+REv+9QLtFJ+43I/aDe90Dao5 HlWGyZQd2KHV
l7F0r2eXffuIdkKGC55TLeRpX9VI2bSj+j+5N/6Xnr1mrI6DSQvK6tLzUUP4 asNM+wfGT+jY
wWpX/TuFhRLY2IyF4jJEMBmB75WGfFKWaNNLQyX8hugeqHzzIWLe/w9w6uQ9 kSiboRLiY5Le
JyFNJURmAiD81GRi9NAQdWeZb0LLIbbJMSK7BpIkc2IJVJwkyLCSpqpiGQSD T2rLgKPgmbms
3MTW4K2zD9oWaqPh8dklFMzPsa02O6/Zm6TctzpVW5NvTi6XzJwmuSRCtKyU N0RjYDJuQWq7
aDm9rraIQFc1ugbcK9O9+pVXjZ8S39Sz4jXamkHweyE83IWNtAvYw1gKRQcY 1zleDoV+97tN
2znbzso2dEmm1rS7E446cVTkOeJOXhxIv02pTWeHH2C1IcyOpnLCdZVJZo2n ZcJTMpwW8OLc
doFZ56c5ScPY7zsl6VcIWuGgXKhgLL4hh6EYkyp2crU7I97czMqjh7WxgS+c pXeq2ykcvHUU
+5myNCwMBBaOr0gi3E5QpvLxEKZydSpb/kCWhmGpIXOsCptE79W5tZPXVKXh fJNRitl7tkPi
PrVtZKEusZsvMgD216pwJUuSOmlRIWmB56AD8BV7SiKT4UPgXyOcrzQfqai2 LpIrxgxo8CZh
isWkYPPefCcLanbrriElTFwlA72p3rCsBsIDDQh12DB4PSNNNnymcX74hmLa vusBwav/wKCu
nNRF6YeK2az5HgkeM5M0GyM5Pzp+pH1QxEctbI9N3gb2B0QqPL26sv8oeXcP V1CGAuqmaRKq
d0aROLhEUqqyla08QJDnUpypKL0oAEDMZyijkLNNuDQ+P7a4fBaO6jiovasv FgZV7LL0DzrU
SAVaoXwRgMjaWl6O9RwS6ij71KeaA/e6Moq4Ay7w6WHQ3SVgit5Lyrqoph2l MVb+xxPEMqyf
8+sncqKno5/1n0t6p1hKRJavYDN57+/Q9y8ud3iZHYFXXCSWwc6LwHWL2Spj 3/NAB7ZAUTjG
26I2k+carLefImfAajwSKJaAs8rwaDDMOHpfQ3FRLHfzQUXj7uyzciZtzMJE dmohI7bDhmPQ
lco0clU1krPVN2zBqElFNS04vlmkdF5YKX6JKGG4znnRV3ggEj3pV5uLpVxq NbsiYTgSYCsv
hJv6vWaaWdvKZ6LlqTNtGd9Y2uTjIwqdM9NYdCWTdbfC+rFuLmlQQwtxqQZa Pg7lVxbQxJZJ
NBVH8v8XA9sgyYJJkgWysWf70USGtmH7sCYP/IUDiT3p4gY3JpuVUCN7S3C2 fPU6FkacigoM
22wfALIeeKYO2+J3RfCIZQ+YCwVoPC9eXzznphpIyZql6oIjiPZRo8qtk+wP rWvsmlJqFPhh
o23a+TAEJhC4Msq+Jv0Wt5quekk2uFoDiqIp9X9rZsLRTOxyWVZ90/AT4coT IyDHKkd35pxM
VUTV2psovDqsii7JNviooeWRoMrbN5L+QUeasU1sEbyJRz1SaXIiz6ZA/Y8U nNQpMyjVQ3bC
xxxtFL7fJagDOmq2Ij84l8wB4aSsii5EmQXZZiZ3hsAD6VULLsFdNZe+L4O8 1c6trV+C+uwg
4S8zCU6aoh2bsPr3sVNytytSd/XHyoNdjdEtSva3R6LZ6YoaD1eEI/oWYnWS pWIqn4cu3pUw
yDXV+Pe7VGbpB9dNkhd/QeVb2VTwcnyYX6rPdNtmL0r3+xVd78rg/K/hM/+q aGYCnrs9lD9d
H41Nr7br+mtc85NIVSQH1WSmmFZg0hMwAPSr/u5iB/8gXqxaMvgQoE0t1RKM c7q7ml+IIa+H
56s5C+y/AtyMM4zffjDnwtFckR/e3fxHzrJhHfyBcTPI10TN8JpVxYZuoJ5v +nLbv5H71ES1
7V4evaRLPQama6l0W0PRVlvTr7nCqFXe9EfbUXLSm0tcXR9rIgjZrUiS2Y+i rRHh7EOsI9oB
gZe3/ykjukbX2oHp4R6++okrSaufeVOSOc0r3PZ+tcAv8tD9nWqv5KJD0BCQ pWEWZnTACVeq
im4umFVAe8GUIi/vYYzXxRMp088d4zjkyBvzeHfcAZB7YJISyNgOo09Q9h8d FoUWRfe55LKa
epb5Ll1dFKmiQk9bjUiwG1gAbg6pWrBBuMokbQvUWTGvCnRtSOywuNtSONKR lUvDdjvv3sVw
sPAikuiKw1A7qCgvNmxlh3u5mAfpTou+9NhuGFBMPAnHxHf22htPKZLoRdrE iTXl8yG27HxE
I9BQJfyMZyw7ZRGBTCPJID3U2AEz9U0b9DWzFTaaK/KvJjQUVTbuGMxmnBMI sO6OhCiX3n3g
dH5gGTXo8BPV5px9Bk0gnpTtirXNDvNWLkCc1dW5hvPvnhjC+zyk3fqTe5LG lH3xs7G8kcjw
7yh2+KbOktqmWK1CrXkC6slZpGhwB7Bxucbgo8WH3K5eNvUPea1thTmiZ2ed 2UB8PkG54v+7
vsY/Pvbye3ZQxMI/HyZqhM4gkmTRfJimwEYp6BVEpeZ2dBOn/Jq9YAZi1G11 7NBIXSWm0zoH
zHMQd04Ek3TPG+yQWd5lv45Pa1z9j835hdqp2AlRHdVJ5RjwIp04XXpyd7/f qQhe8SFh/4zW
RjLezw/E8Pcn/qXJ/9egSOVWLm+pF4K5uTfDkn/sWfHq7I+rX+6KSdm6Geb/ 2A3ES8Ia6K+Y
DuLr/Q5DEu+vmtuiBwBB2ee/I/k1VYOUH8vT/Euu3GLoUuuudPXfY3+gJviG vrjl5uzoHlao
aIGg/8438ZcZ6d0xqG7yGATayHQuClxVMQTSs5BNsQ+DTWM8US/UtFqRdPUx H3EqJB0qecdv
lM06H5I6RQqYl/pO6zyngUT0GzcqAm2Qq1HoEM5iUqNfJRzg75oPknSMM6D6 +ejqzaIqTmEF
mbPIjIdWQmtBnAkgpD8ARJvzGR1hIXj+WhP3JfmHBFlwDg4VaM13zdzGWTyy V//gXzA0lZiP
mLTIixihCrGkBAlp7GBcVtHmCqehG3OqjvOL9xhUtnXfGcONaLhw7xVhA4Wy PfRwh8F5vMyW
qxiUhV+hCHXAwm5+UalczgS5fFYOICQRwORBUbulHkJYOTjJQup1hC4mqdGW j2u0yzlkdwud
LX5PyJPmAdQoLvGQVfcjFfYS+3469nFDVk1Ag9pOzpIsTY1249tdgAsEcuNS 6QHJgtTXRb4h
pn7RJcPvOZvOrIW45BMUj6leVSKsvirQeqaDcqW5FqQIKbK/65O+mv/Dfb/4 FJ0RTrS/c9dE
dYpM5XvborQSK/0oaqI/XhNKE/0OGq/6Z4NFH/QnpbBZwup8Mr67EwNMf8zb pvnmH49/Cnoa
2VfAs2zkE/QmZRTSWrPyCCcBH20/YN55vH+mgVLju8uOXN3LGTcf0WmlxCNq gPPBjwY3ZLNz
qSlVs2wKnaKmLV+h5YUX4tF5nG/fCSHM/HD3jRxQiH/CONEvaibM3OHp5woA N9tbzdhQcH8l
h6Tlat+RD0CY2bRvHqr/fFYOplawap+AIsXL7UiNSKABB6FIuqo2ZmkB97Wg L+Pal/lknPvk
3StsT12j57ioFGeR2pzfMtN21Pnc+jb0JaYH2fWaFzEa3hKI21F2U1PvE65K AMI4EjuUkng4
ffXK7XhCi0thRsZNgR0x6p72UqAzCwtCQymBxgMm6J7WemUi87NT9kebIjGe fEqtJ7UkBAkh
Q3QlmeUWjsBT9eQn34wU5bdouxIqLIsBiSONKLDMJn5QkAAE742tIKLh2a98 I2c4ldqpVUaG
6VsxpvrZYVs+TDKcpBjOp/bGU235KO/ELi1tacDZx8he3ZITF+a2pNOZBgLa pquyTXVfqljS
rI7vym/meq/PTCFDcW70VrMOZbCi8Isy23PCpZ4BZLBVGsWKlY8M40DGFU0I UO0kIb7oAM8/
jwdCglIbw3Sy9VncJtVbESFfeYZpVKYnVuis36v2yAopKe9jKQw0wo4dgwZ7 3/aBenBZscAr
8lm8i3X3Md178hXYTUfZ+yahqLHbGs6DTaZi0I/3gkoGHgai5W3LvluZPDTV MEfK13duzawV
EBbonSeax1Ry053SQPcDdLXLw0fA8bPMEAtQ+HnQ5n3qqwGflGd2eLMZf5cV H8RiQpo6Z4e3
+8vSRIgjbjS+vCHW2Vqs915DNR140XCIQFMXEXVBCYLhwXNgWwQVwPn3Te8A fI3VOjFeYgTp
K57vD1H0f+y7ZxwlDoXRU1X1N/yfD5NfSSdsUvgU00XZf+COyUBUPZK05/lq W4eLo/XD/SJo
T2Gxr8jx45zQ3/1w1LUL6GO+gcZ6Y+iGLZVMPptQx6rhgcR6WiPFDAeeiJ6f /WKqWTikSxvs
RaD016Bx0O40+pVrnF7i2mSefclw7YXDVd1+js9MjMvF5QPD63QmaKjx4Hjy 5ID6LHmsh6Ih
+E6J3nhnaF1i4JVG8hkYHUwke/s1p1aX8L8wGy7KyH1hlfVzk5CyknS3J+kc /NpOuKe5vlMg
+/CXlWJHYku1965SqdF0lrm5MrFvBYIJpaQEKpdJ/eLbnaeTvJ5jolMVZ3zs 6sqnA6RPAzYB
lVQjj4Zx4Px6BuPPa5Td7INDDnKw82DVs5sYwUtMz0YGOydh54uVVo+wIGVV WLngFeLyU2Mi
+PV31qmIfOG8y8AC+b3G++Y0CCnqbNCS6qhLr8OFDHSrt57CZ5a+FQhbBDp6 b3oGKjbKDLVF
VUd8rXijzxjg2e0UWuZzdDHt+B+xza58CvPSQxeRotd8Nglk2Q4lPfnxYfQD Kmvkw5Mi5UKo
uEmyk6AJZAsEmrKkHNJ7WAM813nqYsbG89ygmaFurkX+tLLy+x4fddofy9Z9 U0cMkYsXNeWq
NlKCiOwWeoErdK5Jwyv0PYyu5wsT+ypbppAiKK+55Zc8/ZMieRbZnx7fEdRx Es4wIUqTziGd
psaeuMj3lZL0WqNz/UyP8hKdsoTFS58SZ2n4jh9UJmtTz3DtW0JiqWSntyoa cIieOFxOmpBe
17GfDRftdfkqb0U5PMTvTw2PpY5JMrFgNOHAELcQMclnbAnXaIKNb69GHTZm gCqdmoinULXL
R5Ivnr9H9qEPl0Q/IFuS5DT/vHCnbjDneCLmHqPFutolPjdR+u3Y/4euR31g n2ZQ79r3iU1C
IpXySqzpza/uHK4jPBX5utSuzBD+FvddGv2FtV46osojN4x7Y3Sb/es0cT2L 4ldlChs7GKv5
XjIIX6cfJr1nSp/ID/VMwjJarWW6rVcUjc/gv9DOF+ZOKKIplhM4eJEv/Pl9 rf+YDSaKPFOV
k58ofVSF3I+nCvK4fXUHOWmPd/e9rqQqt9gi9cyRTN4AatymNSwnbRUQCfuy JsEKqMKq6ohQ
r6+VvjdmbnM6UEcVRSiI+ItPBM7khCKom1wRZBED1oazYJBlZykv+whl6FRm +9KWKnA3iH9W
PP9wirmAsyAikZVuLWBrw79W0ER72vU8MlfH09rckE97a09u7wzKj9992cSj rCmTPdoCPYxV
O0Po/j9CgJDW/TKCYnipKsM3t4kz1ugZqwmzlmY+qEawSmD+jaqVsPsqM49w f+fhXqvyvbfZ
ajg2bVDGBn3KAvdO9QSuS3cw4hTyhYUQzcIR6JNaiJE8UL+XhjAdqBglZaDm rs7Y9MPpGjpI
LWz56qa2RREB27U7DFb6tAeCpV3IwKTVQlaPt1LXAybIKow8WFsczfd2mcEd UwjbvG0dI3jx
8jGT7krn52BERxe21wiNOwQ4xLCKcOFvmL8QFSNRzsYUPGtwoa/4UZgki7uq 7fCZuya5lmBj
JFdQd5/WfV/7hXOJzmfpNGI2IOx1qj+UT/GVbZVz5s348jyjXJEde+ok824P JyUflpScU/Jb
azF08fXwLjJX51WRhPwVurTzO/mfqa6ik9Xn7OlfaNUatTFsv5NvVQ4lId+S E9Bn/VJArsMs
bfgFDj+ZQPS4sxxtiX4ppmm52dFSaVBLy9dg8A+63AuOQS1qmHOuaz/I+gOl GPKDs5f53WLC
7M7Lzk7DpZiLmpq/HNxN6GUHrbDj0OabCyowF0/TYMghElExL9GMIWqutXOe LGZs89AzFbvU
77vEbklpu6zo6F73eR4OGwJbLiYm3Jetajyvg1tMJZMErSc02M0q/Xu1JlhW 8xPhx8rF8HRL
wY9b6X7XGhmD5LdsX5TUrktbU6DIUsVnFqbExFM8ix9hqCA7Q2tcuOS+DLS1 3yeCzizNZaA2
QG/prjiaQ8UcSDh6aaGQHrZM88bFHlCZ71cQxLcEc9aqlUxTRx6IyFOA2IC2 Bnp0jigpv+s6
HFoC3twdX9OxZPfbVERARsAzM53yO3nzxNma11e7bijhkosQ14gE/TP+qfbX 3xlb6nk5V2ru
HyYLrAby0e986sEXIZqw2zZDyEye/wcEahbnSx934wfLSUSMrSSC3ppR4726 RjFyUKbiN+2f
gj3mGc6wNn/hc156NdnNl3hhnMXHhAtQR39G7JpaPQnjFfIz6DvcQl5TWSZu DQ5ckxIPQ9BR
S3loKCcdoOHPMffiiEoc66sEPPCAiSPjWshoBPcoJ/c1ZxqCaYu8eMzYmktv 4cR87akIfO5L
vff6SJncZTQRdi4aTuBd4N8kgVM+VeMLxp6OSQi2VhFjPNcuKLdxfiIOLyCd +QPTZkizzvST
zrbl1ITYRVxhOMQuPBSD3Pt2fIhZNZnBd+nLNx5T7lUOqbaqY4SfXGGbmGnB Yho4YW40D4NV
Km29+Mpne7E2yLqfUkTpGGC3UZY6L4ssBVHucGzyYlu9gxo2U13CZATFVczC 9dLPrz7A6804
sgMBp4fWfFDuud2yc+UQvpjksXD1BZ+Xq5PNpcwunGmEcYgVVPIZWYohh/CZ nQcg/MBQIxMe
nEZE5GDh36jcDm4imq5vgvW1UvKFPsEQIcU5AnGcSxWcQ+QBO2dt58GHOcDi QxIzvlpdyR/G
KRiSmpBWOPipn8WLwo53jTvPjZ3uXwhj8YinDdinMrvBF/7x1CBeMDmoh738 DZVMz2RUhSgh
UJ4n2MWVYgmSyayyDftvaEbGmF+G9hzt5P34Fv4+Y7k6FL7fxEcYvt+KH+W+ e3KIWZ/ERlXr
H7wdP8g6ltMjIa9U3ju85FXxhF2BaEVTiyvSNtLM8MtQYMYqPZseegUkVrML TdBdWjERwQQI
IlsAir5sjH61BVmWLXEvlWXW6UEmB7kGElPgCEcAVXyvyeoH0yqouUXTwUVD NSjfzoiegHkR
qcAs7Anc7diMYXt+snllQQKF67RHk1tdc3FsY1spcNn35ZAQ1kSGlb3tXQEc rFV8wSNNNVie
eHjoiDNY2y4G25zuAkfm97fkrATKzd0dumwC+bF24rrUpXenWyR7GcrljxJK OnqRgulWcasz
X3dxdJLMrekVaDL+T3V9LQzXyU0mtUcfWOW973aV3FEbx80mPk5ogp3b3CZd WNPq9XEIIkJg
goj1DbdWFEoq76pm+XIMnvz1LYFPE1DqG6VJb/y2vtd7QnXXXfgZB9IZEy8g dmriJcunre+D
RxQ0KqY3h2pMqjvaOcVLq1UmwGnONx0VmoXxUVLbEshnTQII4wmoqYgzUm7V JPTo9ussAD+R
oobUMnIXjzZCB8Pc47Pb1DKNHJLDDKj0+mAD2srdcphZ+6Qf8GXIEJjNtUm2 Eejs/JHSReFx
If2ioRMXLW1yr1ayanhCIhWcEuovw/hS45VvJpond0wmqGcBApx+Dxq9Ymdw lNM6B8+g7HEl
T2XgaFjp3TiLGgpeX8JHqYkkvHb3fATyiLnlmJJ9zZqIeu9dkI2BUET+8PpR KEfabpY8XGeu
f9yp8aCdVaSecT8I16XoFAZk2TWXegtFpbNglSuox8J5+Ydp4H/s54/5t0eo PmAmo3ZvuwkI
e+UY6lfzO9l1xsbR/yX1xo/vdf0S0YeT2MuZ/TU+hsv/5mJ199CMhrVUoRwe FfWEyXgdjT11
fuLSwiQwUhy7R0sikiPsEIpsmCdbYlTz1MQvJ7xOd0Eq8zmzsd0iHZzL9owJ i9tLOBeDrnyU
1w03PvznlfvkG9QARHQ5GOmdzDHqmEYVjtdKbSlZG+stS50CAL5lUwKr9GWR B7rHJsKct68L
yLFZNEMEjVA/twBhySURtzeJ2709ZCDL9xazmkPGnavZHfYu8dfGzxPdpM22 Vi+U48XDd2bN
2RTra8b4j3HiZHkSsjGx0az2s4DmFZZzgImIFx7pW7hH02SJIXGj4mV3m8Cr B12XSkyn7vjo
1RrUGvtZJWgcXGw8PIcDEXjP1e5xpwPHYDE9tYf9fWOzcPQT0BFNM2FGixGl +8VZa1nL7hRg
G3g4U9RZqgQWS7JjV5xucsE8ML5YdYLmnnF9hoZK3t+TonduTKEydg58+CgC Yd/2ZcdtMvNi
w3hSOj1NSjRJ5jpEA0bYIS+JPRWrHMBhXayuKbGUm9FNn2YDGJrh0D3eztM2 jscFyJe6V4Kt
yFHOf8qsHt1oOao1VVY85kmhk2s/P8jjj5pzhnqrjiNn1NCokpzWbCgqxDmW A9kCdTY8Wj6C
OTY6CnDc7u2ntDVgJla0G7qsOZ6b7yTdkKTxYyInbcuxYxzTm0a0m6+dOVGS Pt1WOlRVIZwV
LMzCKzV3uKMrs3NaW84ehKB64M8DMtwWRYdUdPffmiDuCUWRMcjTbXTSDQDc 54iqeEr8GiXP
1jDD4Zflxqib2j25NwRIICi3ZmKnb+PD99TOM8xzr/BAv9vo8hTKuDxQI/r/ I719oLuGmYbS
aI9FU9ZJxUnhqvC90vmgjr8NscfLuB3Il2X/xL0p6d0TEHZLxq9oV88bF6p4 EyLVLkn8EB8w
GXQExSPqRtM1uKGDOENDwPhph4mZ9CxZArNONzDLv5+A4R7BHiclwmzO9brW +2NEPC+nSQrc
8HxCnMR1jcS/K4xJgmFJ9oAp2wPCJr0PumBsPskTMcVHVbgOYhUuAU1VI3Lr I3Ebwfdc2ODB
pBFZpYb0SQwv5/b3se42Mz4SylkYyZqcSnT/dAemwdVhpxAHPkknFEJWvrDS 0bJtGShdFdTC
OGgsmM2Zk+r6cu7Ej/NS2e2+J1QDhXk9j4PJ7P4u+kEnhaFtOIsAIrEqy/OC WTk20q4F4izs
/LzcqkkU7I1Q8oiQPLFM1ZiX9qeiopb+vuYbMUl33bMRTWl2JImq1LgUjVwd bV0PQHSt5gd5
CLaXqBKS41St6OpWN3PakHyUlzE+VTdQmLWxcpls/htmd8/NmOLM1MXJg0cn CNOQDQTPTwzL
DQFnC6otTHoWfZPSxlEvQQrJXhvvOUN2Fx+pkiohtocubfDgpT/qNi2to6KL H9OkwlUNgzv3
GoGNa0G4gfBW7mzERG10rI4S9F/gjWmWTdzbDwL21yrfS7RftcMHLV75Spq7 ouS+JWyq2VXg
DzOZNg4p0KcYUozuWBF++908Y+gjWu1nx96EhU3q9GkLkhc4x97d4X8yvIkb ebl2CHHLU4PR
OTAR/perGwU5CcZIF3zVCnaIBj7nBJhTcZWXvv5IO314IuFsoDWGaTtP1WG8 /jq3dTp0w/Om
rZg43UIZECwC9MhZCPdDHqNG2LoRqtqXtMuKFAST7smx+4r+l+8eO/IqaJ5k 08HKfAR3wf3C
P9C011lAUZlcwSKNfDoyzS084sDJZNCW5ucA+jZ/47442EQ7oncoEsSA1Tkz nBf4bvZtswxP
0SlPxkSk3QvItS06gqU25MBhWgJAa1o//hJcND4myuW//ouXtETS6b7/xGOV zq//EXbJM0st
fXvpqwX72x9/PGzVx1oP6CXDT+nYes0kZ/PWxq79RiJ/wS+oMQOrirWI3Zjo ApcVjmQt0ON3
g5qVcym6nxZBVTB4uFrm0tnCxX27IwSmkcuBKgK1DPNhbbUCrJnSeYObJN8h hN6YI+SBH+JQ
NC46lRuOJ0b4QqFm3y/MAN9f793uThIVisohVrzgTWhlLZDtXR5uBXnKDs5N 4+ReEipA0Dts
Ps/GKvfNkro2BITJKOm0I1sb5Lb7ZQpF6axoOG6I9E196L51zrjb/EVbfhvO 0X6UyzTURjyE
76oIvIvvuHeKDa07ftGRXbWc9r2XxB0BPzjndiWzKIrDgTfX6aN3XLaO0T5h oyCNyikpfEUC
KwkPTTW+HnNuyBmkw8wxXMDMwTsBieIcLITSL4ZmbftepP74AAGQg9K/6l94 cL/3UZy2FIM4
yjLnmqRI9zqN2Up1//+m0zXeyWwPx1FuqdYn+ZJw0bbXlt9I7/HX227zYX4/ yJbWcguZ4+io
+5WPu7r0RNFT/Un8By4oEJEemkZnBO9yqgfqqTD+FhTLwgLAZADjVrDHXQnE S564gjjqAjPa
WrN3n9B5RggfBWlO4lMbTRFa0MtOxJ76BcN+QmfIoxLLv3eYQeZOBaKcxPZ0 s9VCuMBVQKeC
6lcMk4yRzes51qnPYIvBH+YcY8efWV0rX/UecZwdhot3uJfsvL1P3Nvqif4b zUG0ZLZ60P+v
gLWYnFUyIUDml16jLpUnMrzrWzGEqfQOYE6Iy6wF+HklMNMSO81fG2ddzFPe /Ly8ZEUyVtMc
CraCnQA6bJEV77SQW82UTndLRr1f1CF+3nLhkbvtxQ8h2GSwCNsLaawAiJm5 fjbwDGpz09G5
hACtUNnzNGG1FJ8YDJ9fnXtV2EeXtLMv0yZUccFHGE7RNMmjctHqjrnV0Efe Fy3LXUDUccrE
qFeYMuracqgT0cCnQ23cz2lp61zTZfNgbVPYo6vOLxKITzsxSh1aB2kBmJPe J32RWns05tBo
vJNHBDvcGq9bdiQqmZCWt6kVOsDKLtdrRliXlmzXHL4wF7klYDbcviXeN372 CZPXQnNnrRLy
lcg0S/dmhtQRryWkVMocdlStHo7O/YIWdMHA4PDWynp2t3cYKLFU+8apRCVt qHcqVbV8AtS1
T0Pmdc5stQfGc5tusYeUp7AoE7glBkOdEfS1p8PAc227HXZQ1wMbbKadES0U KmTwi7cw3SmU
7NzIkEciySXvQZixZ1HpQ+g4dmgGqV/j2wJWGcDcQdoXBWts3Rnv9DIZ98Ux 1IlG583ypB/k
NzyT6+xKxaCbbh7yqhIXDnBZbBzCT4IEZRNTvUXcpJPDN1tshoCsHwVX399A meC8EJ8wPXg+
TzI2vfiSochH5AzVnjdXZbU5xD8aRQIJ8ekxBEykEL0ajx88KJvqiVI9gZoZ 1wj3Yfh/51oi
j/mUkglyXJRArtqwj7DyqNW3L9denrf5A4Uf5aNCgP3aDv+upkz03DLJKKo9 d2F5rC89fd/l
o75WJp8Jo5bwmQinCDVmaFB29ncigCt3Th2/fZZOHARIyiao2QnaUsS8nChY 1c51WA7dhfln
vxn1SjpAVSevh5wd11r13gAMbs92eeKC3Tb4SFGwOpO1w0dW9poWNhzfUhY8 Wc/5joc0QRFW
A5YEHoNsxC9zco4OE0UtDMWtxRt2GkX6+aG+FHUV3gRyns4nmpCMxNxOe4M7 itmQa4CjuqAI
8nUJ4IN9rTZ5835oaZ81f7qv3pWYVlOnXYFWOcy/27BFZ5OjiIsdU8dvITUO JD9k4jzOfIUu
WT+oDjnPcaIqRjM0iQ+3EUue8wc4L7osWuy5YLoKUAu/k8D9bNIK1I+c/gon 2nefK+uZ7nEo
02BAVqLKbMlecUk1+LRVQNTsQw3XoDhBSGyb/tOxwtfNBCuhGakq0X1TkBzD 6erZiDVuhKKA
4HClkTtfDeckl8rSz1Ihc36XcRZ/p1kGmszbJ6nY4p9tkVRFX8b14hSMZObT hzNCFN+kj1fq
GuK8/WTuW7OPWsqXou7ZKzWbYaYQPjWBw9L95tReEOBSiz1HshKfopuuNbfn Eb26OH44HGDG
YEKXdzS/r9l9PX8re2TVhUiMO1zKD1aiW0wUmoVVN+GEhWFNwU0HW/LzqCZN /Ur7KTZ7IGGn
02xWcbxOcy3pwSYFonL98h9ja4oKCL0VMTslBPJPpypHo9VVcVfNqITpRFg3 cSzMUM4QobhI
BxTTtQkDccCkk9ID4WFfUbxjw1mxi5UYxEqvezH/UtpQbN6Uha1p5iepOTSw BGeDNL5RWI9p
nzmVG8TD63D4veAIxxvv9ayskH2GvkxE4pgJJZ34hIjaSw1LUVS8gVCdoeCG mN94AASXJ6Hq
qsK1gGFKCBpay087Jb1EYLc8QTWlnR4BZfmAY7ZEm+FDvHGCcnIXCpDR6oTj Jh23I5DtXxjJ
3v25nC+eZmKMIUYKROiaSR2zV5IMzKm0u9cFLEZ8BRPDnj0FreHbzv/ySJYB ncAgGVDNVdEE
BlKmgSkLUAtYAXglIEIHAaWQtgIBUgEuShKEqE4HhUBFQShL4UKUs4BEglrB i6EhAmSiZujf
sDoydR06/8gvzMyUDr+0hn38UeBCMdbk9zonX51+ZJLI6Px4ybPg0PypTsV0 68tNaI2Lxuga
zNk1BayN09ftGs6kANZ5tR0C3HQ2YP3T3J6XJQoHls5TK/eN5N0U9b243cl2 E0AN/R1CkTdd
I1dmZ1mO/AyjrDoV3VaxAQjjDQw94NAqBogixEUTlJUUpVZ1oB5Hv3Bgx7Sn uq2tXzeQlsNZ
joGju1sG6G7GCgnMBEinHZzMgtwRzUrWJlh8SqUYa/G/Ef9xrpttdFEwhE7E MDp1+i4/vQOE
aXg/KDhql5IoJQirPMiqXDx+m2YJziy8tLQEOaKZV7Kc162qbNxfSw6YiM+P O3t9fXVZpsWq
6tjCTEbyk1Vw40DB8IauQrCBbDFhljD5D5+sT4AsVwwEXyRX8Mng6x2NjuDb 7Q+jVSF3gO0W
z+Xhic1ZJft1htHuQUh41MeBzBioualsUlkAlDi4fMULWfTExNJu6GTq9EXZ zFlB+GiDUVFR
6UNBTBaUAB+hZdJt7+pamr1LZ/oY82G1fVPwR+YgxpGHa/yYJLqxdBRdGANT A6li1RBEtBDn
nZskvjJQvQFq7VMIHGfPFwIDHEAEnoxndn1xFqOewtHpdqOsgaP6IxYVtTvY LZpDN6MvDeuR
AIL33Q1Zv+CJ0IH3NJ5bMbpP0qN//lSOFVIRLj6cR4Una6fPqrddn9T9upfB szUKokqzUoAW
H4SyLjWSsSzokWPL9BEjRe4toT/p/3eu4wfv8nU0TV3bniLo+y3KR9qsOr1e fwuYcSqQKuDJ
R5nV0Y8CP4Sr6Ny2iJw2MzCpkvh4hl9iSaQ6J+2w2oat3rJu2Zw7G78cf/ZU JuM0ZAMjHddv
F+HdgLKaVwrcaKrIXyc1Smro9OpLZ6vC5BfJ0qEBOM/gIwQovwSxPfoJcBkl 6IPKoR84oC7B
Jccmd9EwDOyInBdtaWWXLTx19myQ0qgMnRkZgjgCMbmDMJGHjy3SGSZeKUkk VMUDPpRs2YHZ
V4iG9xLf16OJMEMAl0IEj+FI36r0mDL/G4M0YkwpHrOHHHiq1cM6q+/ACxbf o8FEYhmadJJK
5XlRV3ZKIriBEIXhkQuGWsi6EnPvVSaYgWiKWzY3XrabWeBcFLFXPTkmCt7q jf9ibPK0DUCy
Xt2YG2C2BRoDyo38KdZGhzkHOJLjEmRYJNHEq4/Qdh+YQal0IhfUe+7rw9wK 3ZU2xfbsuN9n
Ar37N2Z/b+K8AW87EIyvLhAvw0AJa8KksuI5gYF01CntGQH2oOYqKQ2gxuN0 GUKRrbhb6vKp
jzJeIt9GLIlv4AKj6NiyjekjEvEBciZUSarUarRr/MNSYImUOU84Kuf1+uwz EP3t85s8HDRS
cwKY6SVU07WUkZ/Xjtpgp+LE5tZB5tMzVM1O188ZKUdI/Q5GLJ0JNFDhZwKd qiyjxkXcY71A
sJmHZVimscBAIBTQrSirDTymOTbDOLyWKBYKDox/CYEsnz08+QT0Wfo0jAHZ otEaAvHHqhck
G0wlgkPT53vHIcPuJd0ZUk7bMGhxULUFSWsIZsfrXbgjgSgixvBsmRJAWNeo EvQMC2KS8YsW
bVlfMAjhpKCIUW2a6eaIUNUHLruMnmO53CJ1tZzWiaR8oGJdIe2iJvFKHMqi y7aSQkNCXcW3
HuNC0ZJD8EaUfxHlt0xmhWznPHyZ3tCYm7WqN/gVwY/HPCsKbP/r2SbAT88e tEZYUu4vzs6/
8KC1g4ToXMPj6WpkunwvpN3emx7xlu383nJcCote4UFiWJeDy1FfCkz6dtb8 hu/StKdHG7fq
m7+Wj23pTFe5HG29SWSuWEhmZDimSfWcLmZY1IAosrTpt0BpCqV4nn4qxTA7 MCx7PwKxnDai
Bfmnz06+TDPK279Z6+OteJdyUm+pc4dPApIWNHqo7vGDoEyh4CDSC6VWGH/X OeXsvlpKYrON
QZSe76Kd2GaExMlkC/MEpt6TnGRUNsV4CeVlvx1vaH3WRPOgi7ONVBuo4mc9 KPkuU49ork91
p45P9T8ZIXdOIQSoWTZX7kEIlQSNue0osNJdAk3rY4fOoLs5U3+O6LCvtOxu v6PJ2KWQ0Qhx
W1wQGF0/fVDhMWrKaz4CTg/PIM4TsXmv3jXXfn1ZwmLpTyvJlP9pQKqF4rwW vLB/U09jm5cB
1XIa87WtsrJvfr4l0zdU2Tef1Kuqgr0yR/0lNqrf+gkCP9RHP9OQVliU/tvt R8hbymSfcDNq
73C/YF+8X0/6CXHlVpd+03+V+YZoK2shRC7KXHXeam6LnXRUqrxMYeMKWdFc 2aKjCYb6fu4L
Im7jrJU+0+6dhKpMXn4gonvyQ45ZMs5hYs/3oRQ7hGgxmUU/JtIFEL7LcdBi o82pTP77mYz9
HXPlpaQ+odUsTbO8JMG9uRSn0KDlk6BgrkiL9EefTD1OavfZIe7uyAupY5+f nucSLpU3QtiV
mzSGEvzzcWvd2q5KmPYo1a79z0tKwoceqiqJUUH/HRCiDb73Tzxkuv9KEnZj ql+0XJOTiPEQ
6ai4sOu5KOydEzo5KG0gF6cVfkIG6woaLbDypJvXjN1o4Xuc/lU2+TVLkUmn eoWswEN+gEz3
q1YGOcs1jaEpYlNCVi2CZl/PlPqZNOi26eMDsrWkuM0le5vX2Gm6GRNalKax sk8lamrB05FF
COMei3GScBPlMl12qXl/n/k9lTDmzEzBRWhG2n5Uw0tWJ8N2twlOMXflZq55 axKs34ZJhVO8
pK0xev7ckujMW94Etbbs7QzQSahApI6cRIhFxuTaCe61QZrWVjvLO79Im+5A Lg+q2ZLZzQHt
w3c28uZDHTV2OmZ6NLDhKmrnUjgnErOgPOVzuEdN3ohEsqZn5DQK4atPBZxW YOUlnjId/9Ut
8XjVwSEWUOL29TrHSvzh87i+DHfA19MVd+uKvXA1y8Wjpe5Ns/fZI2Qkxev6 1iXBZM33gGXU
4GrTtabnQy35YtxOfTeqbAsoJ30p6GzJwAnBYxdRcaBKUWiEhpini27sXY/3 Zo7t35GAK+dm
hBNtCP4qdQOqA1lyG7t4jqO7GTXeYtWtPloiHXKl1TL0pfzT1a3uZPrYMsye 3CJkJi8scNMD
panB7QwbLA4Z5qCuW4kPim+tKeCZmLJAOghX5KnHirb4ukHrFfyuPrl4dbLD wTARPC64jI+S
FEGSkcYgD70/cU6aElkFyvUytzf8BqGYXUMVXWuBGJN8/LJgFvu3FpBAjSCh UzoIhBhDy/JQ
Xb3VPtOuTsNTDnyjsuId++Mj+D+h1osLCNJOv5NuyJn/h9KYmya9S3Vazqr8 vj59RHr6MNx9
LQe8ZuTEaRbBXdrqPERGocu8l3YphtSZ40V2gftu2y31dI+y4bGrF3mznf2m fag3QfJRRYyg
T/0Epfmorf+ZJXw+gRult7BFGgLCJX7U8W+soNr77m4Gas1RpVfiUOec9I+D hESzsvp1q9Ff
lXC8qlf9XmsCOgJDRGoSfbuq6UDf2gXtE7nsaPj06HerO3Zf6ZKVok8syXb8 z0g8hKkJ/plg
yykHx1G7r4/CXRuLDSjRcGXBrVB2jQsu9i7rKAc8JoeEUsEe+DyYTiZ7rgFd 2Pkr65/TQTNt
XduhHS060lWsHNekytm695O3nqLxqg1qjGXStxGXBiglWFeMjQU14dPtwPum CDVodReRYGcG
Si0MfSBgXkmqodyShpq6hXc+W+1SLG1BncHliPeSvr/5lS3/hys2X/XiM8zw Sh3R+c2BU+Z1
Re: Persist EObject from BPEL20.XSD [message #95633 is a reply to message #95599] Mon, 03 September 2007 05:20 Go to previous messageGo to next message
Hi Daniel,
After some testing: the issue is related to that multiple types/join relations are stored in the
same table (check the hbm for all the types ending on _mixed). It is somehow related to the fact
that the model has multiple types with both a mixed and an any typed element. This goes wrong.
Although I know what goes wrong I do not yet have an easy workaround or solution. I will look at a
solution further today.
gr. Martin
Daniel Gerlach wrote:
> Hello,
> http://docs.oasis-open.org/wsbpel/2.0/OS/process/executable/ ws-bpel_executable.xsd
> Namespace-XSD.
> Daniel Gerlach
> Ed Merks schrieb:
>> Daniel,
>> the XMLNamespace package that already exists in the Ecore plugin. It
>> would seem better to reuse that rather than generate a duplicate of it.
>> one package is registered for the namespace
>> </extension>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Persist EObject from BPEL20.XSD [message #95685 is a reply to message #95633] Mon, 03 September 2007 08:06 Go to previous messageGo to next message
--------------070701090607040704090106
Hi Daniel,
I have solved this issue. This will be available in the next release (late this week). In the mean
time I have attached the hbm which I created using the new mapping logic for mixed/any typed
elements. You can use this hbm to workaround this issue.
gr. Martin
Martin Taal wrote:
> Hi Daniel,
> relations are stored in the same table (check the hbm for all the types
> ending on _mixed). It is somehow related to the fact that the model has
> wrong. Although I know what goes wrong I do not yet have an easy
> workaround or solution. I will look at a solution further today.
> gr. Martin
>> Hello,
>> how i generated the Ecore-model. But i didn't see an option to
>> reference an existing generator model at the last step of the wizard.
>> because i am able to load and parse instances of the XML-Schema. I can
>> write them in a normal file, too. Only the database doesn't work.
>> because i get a "foreign constraint violation error"(see my first
>> posting) when i want to persist an EObject of the
>> Namespace-XSD.
>> Daniel Gerlach
>> Ed Merks schrieb:
>>> Daniel,
>>> On the last page of the import wizard, there is the option to reuse
>>> Aren't you getting a warning in the Error log indicating more than
>>> "http://www.w3.org/XML/1998/namespace" because of you duplicate
>>> registration for the following registration in the Ecore plugin.xml?
>>> <extension point="org.eclipse.emf.ecore.generated_package">
>>> <package uri="http://www.w3.org/XML/1998/namespace"
>>> class="org.eclipse.emf.ecore.xml.namespace.XMLNamespacePackage "
>>> genModel="model/XMLNamespace.genmodel" />
>>> </extension>
The Netherlands
Content-Type: text/xml;
name="bpel.hbm.xml"
Content-Disposition: inline;
filename="bpel.hbm.xml"
<!DOCTYPE hibernate-mapping PUBLIC "-//Hibernate/Hibernate Mapping DTD 3.0//EN" "http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd">
<!-- Generated by Teneo on Mon Sep 03 14:02:00 CEST 2007 -->
<hibernate-mapping auto-import="false">
<typedef name="executable.BPELVariableNames" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="epackage">http://docs.oasis-open.org/wsbpel/2.0/process/executable</param>
<param name="edatatype">BPELVariableNames</param>
</typedef>
<typedef name="executable.BPELVariableNamesBase" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">BPELVariableNamesBase</param>
</typedef>
<typedef name="executable.QNames" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">QNames</param>
</typedef>
<typedef name="executable.QNamesBase" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">QNamesBase</param>
</typedef>
<typedef name="executable.TBooleanObject" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">TBooleanObject</param>
</typedef>
<typedef name="executable.TInitiateObject" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">TInitiateObject</param>
</typedef>
<typedef name="executable.TPatternObject" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">TPatternObject</param>
</typedef>
<typedef name="executable.TRolesObject" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">TRolesObject</param>
</typedef>
<typedef name="namespace.LangTypeMember1Object" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="epackage">http://www.w3.org/XML/1998/namespace</param>
<param name="edatatype">LangTypeMember1Object</param>
</typedef>
<typedef name="namespace.SpaceTypeObject" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">SpaceTypeObject</param>
</typedef>
<class name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TEx tensibleElementsImpl " entity-name="TExtensibleElements" abstract="false" lazy="false" table="`textensibleelements`">
<meta attribute="eclassName">TExtensibleElements</meta>
<meta attribute="epackage">http://docs.oasis-open.org/wsbpel/2.0/process/executable</meta>
<id type="long" name="e_id" column="e_id" access=" org.eclipse.emf.teneo.hibernate.mapping.identifier.Identifie rPropertyHandler ">
<meta attribute="syntheticId">true</meta>
<generator class="native"/>
</id>
<version name="e_version" column="e_version" access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler ">
<meta attribute="syntheticVersion">true</meta>
</version>
<list name="documentation" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`textensibleelements_documentation_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`textensibleelements_documentation_idx`"/>
<one-to-many entity-name="TDocumentation"/>
</list>
<list name="any" table="`textensibleelements_any`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`textensibleelements_any_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`textensibleelements_any_idx`"/>
<one-to-many entity-name="TExtensibleElements_any"/>
</list>
<list name="anyAttribute" table="`textensibleelements_anyattribute`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`textensibleelements_anyattribute_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`textensibleelements_anyattribute_idx`"/>
<one-to-many entity-name="TExtensibleElements_anyAttribute"/>
</list>
</class>
<class entity-name="TExtensibleElements_any" lazy="false" table="`textensibleelements_any`">
<meta attribute="featureMap">TExtensibleElements</meta>
<id type="long">
</id>
<version name="e_version" access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler ">
</version>
<property name="fme_feature" type="java.lang.String"/>
<key update="true">
<column name="`any_textensibleelements_documentation_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`any_textensibleelements_documentation_idx`"/>
</list>
<list name="anyAttribute" table="`any_textensibleelements_anyattribute`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`any_textensibleelements_anyattribute_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`any_textensibleelements_anyattribute_idx`"/>
</list>
<property name="fme_mixed_text" type="java.lang.String"/>
<property name="fme_mixed_cdata" type="java.lang.String"/>
<property name="fme_mixed_comment" type="java.lang.String"/>
</class>
<class entity-name="TExtensibleElements_anyAttribute" lazy="false" table="`textensibleelements_anyattribute`">
<id type="long">
</id>
</version>
</class>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TAc tivityImpl " entity-name="TActivity" abstract="false" lazy="false" extends="TExtensibleElements" table="`tactivity`">
<meta attribute="eclassName">TActivity</meta>
<key>
<column name="`textensibleelements_e_id`"/>
</key>
<many-to-one name="targets" entity-name="TTargets" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`ttargets_targets_e_id`"/>
</many-to-one>
<many-to-one name="sources" entity-name="TSources" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tsources_sources_e_id`"/>
</many-to-one>
<property name="name" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`name`"/>
</property>
<property name="suppressJoinFailure" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`suppressjoinfailure`"/>
<type name="org.eclipse.emf.teneo.hibernate.mapping.ENumUserType" >
<param name="enumClass"> org.open.oasis.docs.wsbpel._2._0.process.executable.TBoolean </param>
</type>
</property>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TAc tivityContainerImpl " entity-name="TActivityContainer" abstract="false" lazy="false" extends="TExtensibleElements" table="`tactivitycontainer`">
<meta attribute="eclassName">TActivityContainer</meta>
<key>
</key>
<many-to-one name="assign" entity-name="TAssign" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tassign_assign_e_id`"/>
</many-to-one>
<many-to-one name="compensate" entity-name="TCompensate" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tcompensate_compensate_e_id`"/>
</many-to-one>
<many-to-one name="compensateScope" entity-name="TCompensateScope" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tcompensatescope_compensatescope_e_id`"/>
</many-to-one>
<many-to-one name="empty" entity-name="TEmpty" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tempty_empty_e_id`"/>
</many-to-one>
<many-to-one name="exit" entity-name="TExit" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`texit_exit_e_id`"/>
</many-to-one>
<many-to-one name="extensionActivity" entity-name="TExtensionActivity" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`textensionactivity_extensionactivity_e_id`"/>
</many-to-one>
<many-to-one name="flow" entity-name="TFlow" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tflow_flow_e_id`"/>
</many-to-one>
<many-to-one name="forEach" entity-name="TForEach" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tforeach_foreach_e_id`"/>
</many-to-one>
<many-to-one name="if" entity-name="TIf" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tif_if_e_id`"/>
</many-to-one>
<many-to-one name="invoke" entity-name="TInvoke" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tinvoke_invoke_e_id`"/>
</many-to-one>
<many-to-one name="pick" entity-name="TPick" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tpick_pick_e_id`"/>
</many-to-one>
<many-to-one name="receive" entity-name="TReceive" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`treceive_receive_e_id`"/>
</many-to-one>
<many-to-one name="repeatUntil" entity-name="TRepeatUntil" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`trepeatuntil_repeatuntil_e_id`"/>
</many-to-one>
<many-to-one name="reply" entity-name="TReply" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`treply_reply_e_id`"/>
</many-to-one>
<many-to-one name="rethrow" entity-name="TRethrow" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`trethrow_rethrow_e_id`"/>
</many-to-one>
<many-to-one name="scope" entity-name="TScope" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tscope_scope_e_id`"/>
</many-to-one>
<many-to-one name="sequence" entity-name="TSequence" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tsequence_sequence_e_id`"/>
</many-to-one>
<many-to-one name="throw" entity-name="TThrow" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tthrow_throw_e_id`"/>
</many-to-one>
<many-to-one name="validate" entity-name="TValidate" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tvalidate_validate_e_id`"/>
</many-to-one>
<many-to-one name="wait" entity-name="TWait" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`twait_wait_e_id`"/>
</many-to-one>
<many-to-one name="while" entity-name="TWhile" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`twhile_while_e_id`"/>
</many-to-one>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TAs signImpl " entity-name="TAssign" abstract="false" lazy="false" extends="TActivity" table="`tassign`">
<meta attribute="eclassName">TAssign</meta>
<key>
<column name="`tactivity_e_id`"/>
</key>
<list name="group" table="`tassign_group`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`tassign_group_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`tassign_group_idx`"/>
<one-to-many entity-name="TAssign_group"/>
</list>
<property name="validate" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`validate`"/>
</type>
</property>
</joined-subclass>
<class entity-name="TAssign_group" lazy="false" table="`tassign_group`">
<meta attribute="featureMap">TAssign</meta>
<id type="long">
</id>
</version>
<many-to-one name="copy" entity-name="TCopy" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`group_tcopy_copy_e_id`"/>
</many-to-one>
<many-to-one name="extensionAssignOperation" entity-name="TExtensionAssignOperation" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name=" `group_textensionassignoperation_extensionassignoperation_e_ id` "/>
</many-to-one>
</class>
<class name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TEx pressionImpl " entity-name="TExpression" abstract="false" lazy="false" table="`texpression`">
<meta attribute="eclassName">TExpression</meta>
</id>
</version>
<list name="mixed" table="`texp_mixed`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`texpression_mixed_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`texpression_mixed_idx`"/>
<one-to-many entity-name="TExpression_mixed"/>
</list>
<property name="expressionLanguage" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`expressionlanguage`"/>
</property>
<list name="anyAttribute" table="`texpression_anyattribute`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`texpression_anyattribute_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`texpression_anyattribute_idx`"/>
<one-to-many entity-name="TExpression_anyAttribute"/>
</list>
</class>
<class entity-name="TExpression_mixed" lazy="false" table="`texpression_mixed`">
<meta attribute="featureMap">TExpression</meta>
<id type="long">
</id>
</version>
<list name="any" table="`mixed_texpression_any`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`mixed_texpression_any_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`mixed_texpression_any_idx`"/>
<one-to-many entity-name="TExpression_any"/>
</list>
<column not-null="false" unique="false" name="`mixed_expressionlanguage`"/>
</property>
<list name="anyAttribute" table="`mixed_texpression_anyattribute`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`mixed_texpression_anyattribute_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`mixed_texpression_anyattribute_idx`"/>
</list>
</class>
<class entity-name="TExpression_anyAttribute" lazy="false" table="`texpression_anyattribute`">
<id type="long">
</id>
</version>
</class>
<class entity-name="TExpression_any" lazy="false" table="`texpression_any`">
<id type="long">
</id>
</version>
<list name="mixed" table="`any_texp_mixed`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`any_texpression_mixed_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`any_texpression_mixed_idx`"/>
</list>
<column not-null="false" unique="false" name="`any_expressionlanguage`"/>
</property>
<list name="anyAttribute" table="`any_texpression_anyattribute`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`any_texpression_anyattribute_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`any_texpression_anyattribute_idx`"/>
</list>
</class>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TBo oleanExprImpl " entity-name="TBooleanExpr" abstract="false" lazy="false" extends="TExpression" table="`tbooleanexpr`">
<meta attribute="eclassName">TBooleanExpr</meta>
<key>
<column name="`texpression_e_id`"/>
</key>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TBr anchesImpl " entity-name="TBranches" abstract="false" lazy="false" extends="TExpression" table="`tbranches`">
<meta attribute="eclassName">TBranches</meta>
<key>
</key>
<property name="successfulBranchesOnly" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`successfulbranchesonly`"/>
</type>
</property>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCa tchImpl " entity-name="TCatch" abstract="false" lazy="false" extends="TActivityContainer" table="`tcatch`">
<meta attribute="eclassName">TCatch</meta>
<key>
<column name="`tactivitycontainer_e_id`"/>
</key>
<property name="faultElement" lazy="false" insert="true" update="true" not-null="false" unique="false" type="javax.xml.namespace.QName">
<column not-null="false" unique="false" name="`faultelement`"/>
</property>
<property name="faultMessageType" lazy="false" insert="true" update="true" not-null="false" unique="false" type="javax.xml.namespace.QName">
<column not-null="false" unique="false" name="`faultmessagetype`"/>
</property>
<property name="faultName" lazy="false" insert="true" update="true" not-null="false" unique="false" type="javax.xml.namespace.QName">
<column not-null="false" unique="false" name="`faultname`"/>
</property>
<property name="faultVariable" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`faultvariable`"/>
</property>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo mpensateImpl " entity-name="TCompensate" abstract="false" lazy="false" extends="TActivity" table="`tcompensate`">
<meta attribute="eclassName">TCompensate</meta>
<key>
</key>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo mpensateScopeImpl " entity-name="TCompensateScope" abstract="false" lazy="false" extends="TActivity" table="`tcompensatescope`">
<meta attribute="eclassName">TCompensateScope</meta>
<key>
</key>
<property name="target" lazy="false" insert="true" update="true" not-null="true" unique="false" type="java.lang.String">
<column not-null="true" unique="false" name="`target`"/>
</property>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo mpletionConditionImpl " entity-name="TCompletionCondition" abstract="false" lazy="false" extends="TExtensibleElements" table="`tcompletioncondition`">
<meta attribute="eclassName">TCompletionCondition</meta>
<key>
</key>
<many-to-one name="branches" entity-name="TBranches" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tbranches_branches_e_id`"/>
</many-to-one>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo nditionImpl " entity-name="TCondition" abstract="false" lazy="false" extends="TExpression" table="`tcondition`">
<meta attribute="eclassName">TCondition</meta>
<key>
</key>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo pyImpl " entity-name="TCopy" abstract="false" lazy="false" extends="TExtensibleElements" table="`tcopy`">
<meta attribute="eclassName">TCopy</meta>
<key>
</key>
<many-to-one name="from" entity-name="TFrom" cascade="all" lazy="false" insert="true" update="true" not-null="true">
<column not-null="true" unique="false" name="`tfrom_from_e_id`"/>
</many-to-one>
<many-to-one name="to" entity-name="TTo" cascade="all" lazy="false" insert="true" update="true" not-null="true">
<column not-null="true" unique="false" name="`tto_to_e_id`"/>
</many-to-one>
<property name="ignoreMissingFromData" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`ignoremissingfromdata`"/>
</type>
</property>
<property name="keepSrcElementName" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`keepsrcelementname`"/>
</type>
</property>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo rrelationImpl " entity-name="TCorrelation" abstract="false" lazy="false" extends="TExtensibleElements" table="`tcorrelation`">
<meta attribute="eclassName">TCorrelation</meta>
<key>
</key>
<property name="initiate" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`initiate`"/>
<param name="enumClass"> org.open.oasis.docs.wsbpel._2._0.process.executable.TInitiat e </param>
</type>
</property>
<property name="set" lazy="false" insert="true" update="true" not-null="true" unique="false" type="java.lang.String">
<column not-null="true" unique="false" name="`set`"/>
</property>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo rrelationsImpl " entity-name="TCorrelations" abstract="false" lazy="false" extends="TExtensibleElements" table="`tcorrelations`">
<meta attribute="eclassName">TCorrelations</meta>
<key>
</key>
<list name="correlation" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`tcorrelations_correlation_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`tcorrelations_correlation_idx`"/>
<one-to-many entity-name="TCorrelation"/>
</list>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo rrelationSetImpl " entity-name="TCorrelationSet" abstract="false" lazy="false" extends="TExtensibleElements" table="`tcorrelationset`">
<meta attribute="eclassName">TCorrelationSet</meta>
<key>
</key>
<property name="name" lazy="false" insert="true" update="true" not-null="true" unique="false" type="java.lang.String">
<column not-null="true" unique="false" name="`name`"/>
</property>
<property name="properties" lazy="false" insert="true" update="true" not-null="true" unique="false" type="executable.QNames">
<column not-null="true" unique="false" name="`properties`"/>
</property>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo rrelationSetsImpl " entity-name="TCorrelationSets" abstract="false" lazy="false" extends="TExtensibleElements" table="`tcorrelationsets`">
<meta attribute="eclassName">TCorrelationSets</meta>
<key>
</key>
<list name="correlationSet" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`tcorrelationsets_correlationset_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`tcorrelationsets_correlationset_idx`"/>
<one-to-many entity-name="TCorrelationSet"/>
</list>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo rrelationsWithPatternImpl " entity-name="TCorrelationsWithPattern" abstract="false" lazy="false" extends="TExtensibleElements" table="`tcorrelationswithpattern`">
<meta attribute="eclassName">TCorrelationsWithPattern</meta>
<key>
</key>
<key update="true">
<column name="`tcorrelationswithpattern_correlation_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`tcorrelationswithpattern_correlation_idx`"/>
<one-to-many entity-name="TCorrelationWithPattern"/>
</list>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo rrelationWithPatternImpl " entity-name="TCorrelationWithPattern" abstract="false" lazy="false" extends="TCorrelation" table="`tcorrelationwithpattern`">
<meta attribute="eclassName">TCorrelationWithPattern</meta>
<key>
<column name="`tcorrelation_e_id`"/>
</key>
<property name="pattern" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`pattern`"/>
<param name="enumClass"> org.open.oasis.docs.wsbpel._2._0.process.executable.TPattern </param>
</type>
</property>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TDe adlineExprImpl " entity-name="TDeadlineExpr" abstract="false" lazy="false" extends="TExpression" table="`tdeadlineexpr`">
<meta attribute="eclassName">TDeadlineExpr</meta>
<key>
</key>
</joined-subclass>
<class name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TDo cumentationImpl " entity-name="TDocumentation" abstract="false" lazy="false" table="`tdocumentation`">
<meta attribute="eclassName">TDocumentation</meta>
</id>
</version>
<list name="mixed" table="`tdocumentation_mixed`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`tdocumentation_mixed_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`tdocumentation_mixed_idx`"/>
<one-to-many entity-name="TDocumentation_mixed"/>
</list>
<property name="lang" lazy="false" insert="true" update="true" not-null="false" unique="false">
<column not-null="false" unique="false" name="`lang`"/>
<type name=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">AnySimpleType</param>
<param name="epackage">http://www.eclipse.org/emf/2003/XMLType</param>
</type>
</property>
<property name="source" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`source`"/>
</property>
</class>
<class entity-name="TDocumentation_mixed" lazy="false" table="`tdocumentation_mixed`">
<meta attribute="featureMap">TDocumentation</meta>
<id type="long">
</id>
</version>
<list name="any" table="`mixed_tdocumentation_any`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`mixed_tdocumentation_any_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`mixed_tdocumentation_any_idx`"/>
<one-to-many entity-name="TDocumentation_any"/>
</list>
<column not-null="false" unique="false" name="`mixed_lang`"/>
</type>
</property>
<column not-null="false" unique="false" name="`mixed_source`"/>
</property>
</class>
<class entity-name="TDocumentation_any" lazy="false" table="`tdocumentation_any`">
<id type="long">
</id>
</version>
<list name="mixed" table="`any_tdocumentation_mixed`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`any_tdocumentation_mixed_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`any_tdocumentation_mixed_idx`"/>
</list>
<column not-null="false" unique="false" name="`any_lang`"/>
</type>
</property>
<column not-null="false" unique="false" name="`any_source`"/>
</property>
</class>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TDu rationExprImpl " entity-name="TDurationExpr" abstract="false" lazy="false" extends="TExpression" table="`tdurationexpr`">
<meta attribute="eclassName">TDurationExpr</meta>
<key>
</key>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TEl seifImpl " entity-name="TElseif" abstract="false" lazy="false" extends="TExtensibleElements" table="`telseif`">
<meta attribute="eclassName">TElseif</meta>
<key>
</key>
<many-to-one name="condition" entity-name="TBooleanExpr" cascade="all" lazy="false" insert="true" update="true" not-null="true">
<column not-null="true" unique="false" name="`tbooleanexpr_condition_e_id`"/>
</many-to-one>
Re: Persist EObject from BPEL20.XSD [message #95716 is a reply to message #95599] Mon, 03 September 2007 08:56 Go to previous messageGo to next message
Daniel,
I can't find a tool that will view the *.rar file. Posting a GIF or
JPEG would be easier to use. I guess I should have asked what version
of EMF you are using. The registration of .genmodel files was added in
EMF 2.1. The complaints about duplicate nsURI registrations was added
in 2.2. You might find the code you're using isn't actually even using
the XML namespace package you generated... Does your generated model
have a generated_package extension with the same namespace as I showed
below? That's definitely something to avoid long term...
> Hello,
> i don't have any warning or any error. I added a few screenshots of
> But I don't think that's the problem. The Ecore model seems fine
> For me, the problem lies in the generated hibernate-mapping-xml,
> and the error is thrown for an EObject of the BPEL-XSD and not of the
> Namespace-XSD.
> Daniel Gerlach
> Ed Merks schrieb:
>> Daniel,
>> </extension>
Re: Persist EObject from BPEL20.XSD [message #95767 is a reply to message #95716] Mon, 03 September 2007 13:43 Go to previous messageGo to next message
--------------050202070407040201020302
Hi Ed,
i added for you the pics again. I use Eclipse3.3, so i suppose it is EMF
2.3.
In my plugin.xml there isn't the
org.eclipse.emf.ecore.xml.namespace.XMLNamespacePackage, only the one i
have generated:
<package
uri = "http://www.w3.org/XML/1998/namespace"
class = "org.w3.xml._1998.namespace.NamespacePackage"
genModel = "model/ws-bpel_executable.genmodel" />
</extension>
For now, i work with the solution from Martin.
Daniel Gerlach
Ed Merks wrote:
> Daniel,
>> Hello,
>> Namespace-XSD.
>> Daniel Gerlach
>> Ed Merks schrieb:
>>> Daniel,
>>> </extension>
Content-Type: image/jpeg;
name="screenshot01.jpg"
filename="screenshot01.jpg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDABALDA4MChAODQ4SERATGCgaGBYW GDEjJR0oOjM9
PDkzODdASFxOQERXRTc4UG1RV19iZ2hnPk1xeXBkeFxlZ2P/2wBDARESEhgV GC8aGi9jQjhC
Y2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2Nj Y2NjY2P/wAAR
CAJjAjkDASIAAhEBAxEB/8QAGwABAAIDAQEAAAAAAAAAAAAAAAMFAQIEBwb/ xABPEAABAwIC
BwIJBwoFBAICAwEBAAIDBBESIQUTFDFSk9FBURUiM1NUYXGy0jJyc3SBkbMG IzQ1NkNikqGx
JEKClKJEweHwFqMlJmOD8cL/xAAZAQEBAQEBAQAAAAAAAAAAAAAAAQIDBAX/ xAAqEQEAAgIB
AwQCAwEBAAMAAAAAAQIRElEhMkEDEzHwgcEiYaHRUiNxsf/aAAwDAQACEQMR AD8A+j0bo6nl
pI6ipiZPLM0PJkGIAHMAA7sl1eDaD0Gl5Leizoz9VUf1eP3Qq/Sc73tljAN7 kAhrjb7gutYy
z8u1+jqHsoaXkt6LVujqL0Kl5Dei+e0bJV02koWh7jE94a5pjktnl2tsr/TY f4JmEcr4nOwt
D43Wc27gLgpeNUhL4NovQqbkt6LPg2h9CpuS3oqp2lZKaqjFWZMdJBNr2M/e YcGFwHbcHLuu
R3rpptOSvI2mhfAzG1rpHY2tAINiMbGkm4AIt/mGaxmFw7PBtF6FTclvRYOj qH0Kl5Leii0b
pbwg9jBTmJ2Bz5Gud40fjWaCLdoufsVg4Kwji8H0PoNLyW9E8H0PoVLyW9F1 FarWEc/g+i9C
peS3osHR9F6FS8lvRdKJgy5dgofQqXkt6JsFD6FS8lvRTv3LVt75pgyiNBRe hUvJb0WNhovQ
qXkt6KZ5sFHiITCZYFDQ+hUvJb0WwoKD0Kl5LeixjKCQq4MtvB9B6FS8lvRP B9B6FS8lvRZE
hQyFMGWvg+h9CpeS3ong+h9CpeS3opGPJWZHWCYModgofQqXkt6LGwUPoVLy W9FnWFC82WtU
y12Gh9CpeS3osbDRehUvJb0QyFbRuJKamWuw0foVLyG9FjYaP0Kl5Dei6EUx BmXPsVH6FS8h
vRY2Kj9DpeQ3ouhYTEGZc+x0nodLyGdE2Ok9DpeQzop1hMQZlDsdJ6HS8hnR Y2Ok9DpeQzop
0TEGZRCjo/QqXkN6LYUVF6FS8lvRbrIKYgzLUUFF6FS8lvRZ2Ci9CpeS3opA VuCmIMyg2Ci9
CpeS3omwUXoVLyW9F0ImIMy59govQqXkt6JsFF6FS8lvRdCJiDMufYKL0Kl5 LeieD6L0Kl5L
ei6ETEGZc/g+h9CpeS3ong+h9CpeS3ouhExBmUHg+h9CpeS3ong+h9CpeS3o uhFMQZlz+D6H
0Gl5LeieD6H0Gl5Lei6ETELlB4PofQaXkt6J4OofQaXkt6LoRMQZc/g6h9Bp eS3ong6h9Bpe
S3oulExBlz+DqH0Gl5LeieDqD0Gl5Lei6FlTC5c3g6g9BpeS3ong6g9BpeS3 oulEwZcFRo+h
bNS2o6YAykG0Tcxgee71BT+D9H+g0vJb0WmkLjZiDa02/wBrHgf1KgOPWAyC V7LHJjrG+Vu0
etZwsS6vB+j/AEGl5LeijqKCgEbbUVMDrGDKFvEPUoZC0xuEcVS19jhJlyB7 P8ySazC25PlG
dv8AG1MKkqKSijdEyLR1G+SV+FodG1o+STmcJ7u5c8UdJNII4qPQsjzua2Vp J+zAsy65ssEo
Y+TVvLi0EX+S4dp9aggY+B0J1Vc9sPyGuMVhkR2HuKYIdEtNQS6JfUMoaZhd AXi0Tbjxb77K
B7KQSOGyUuRI8gzotJWSxaFkjcSCymc0i/cxVU8c+0y2kfbGe31rl6kzV6fQ pFs5WzxSNjc4
UVK4gEhogZn/AEWzKcPax7NH6PdG9heJg1uraBvxEtuD6rf2NqbV1OE2e4ns zXbHKxlIaQ08
z4ZPGleXAPL8rEC9srD/AN34pbPy6+r6euNY/wAdMWySRh5oqQXv+4b9+bR/ ZbFtJ6JS8hnR
VGrqLfLf9pstDFUk2D3/AHrG85dPZphdN0bTz6LkkjjZFM2SUtewW3PdYG28 WFl8x4YfxlfX
6NDhoN+K98U5/wDsevNbr1Y6RL5uf5zD1bRf6qovq8fuhculNCQ6RuTIYn8Q F1NRyGHQEEoF
zHSNcAe2zAV17PV+kQch3xrUWwkZ8KHRX5LU+jasVUs7qiVvyLtwhvrtcq6l jjqIjFK3EwkE
i9txv/2W5pqs/wDUU/Id8a1FJVj/AKin5DvjS1tvkxKOahpKip2iaBr5TEYS 49rDvB71p4Lo
3UclJIyWWCS2Jks75N262Ikj7F07NV+kQch3xps1X6RByHfGs5herWGkp6eo nqIogyWfDrHD
/NYWH9FKStNnq/SIOQ7402ar9Ig5DvjVzCYllYTZqv0iDkO+NNlq/SIOQ741 doMSwsLOy1Xp
EHJd8abLVekQcl3xptBrLBWMlsaSqP8A1EHJd8a12Oq9Ig5LvjTaDWWpzWhY ptjqvSIOS740
2Op8/ByXfGm0JrKDAmBT7HU+fg5LvjTYqnz8HJd8au8GsoQFsGgrfYqnz8HJ d8azsdT6RByX
fGm8GstWsssubcLbZar0iDku+NNlqvSIOS7403g1lFqlgx5KbZar0iDku+NN kqvSIOS741d4
TSXOIls2Oym2Sq9Ig5LvjTZKr0iDku+NPcg0lGsKTY6r0iDku+NNjqfSIOS7 41N4XWUawpdj
qfPwcl3xpsVT5+Dku+NN4NZQopdiqfPwcl3xpsVT5+Dku+NN4NZQrCn2Gp8/ ByXfGmw1Hn4O
S7403g1lAin2Go8/ByXfGsbBUefg5LvjTeDWUQK3BW+w1Hn4OS7402Kp8/By XfGm8GsgKymx
1XpEHJd8azslV6RByXfGm8GssIs7LVekQcl3xpstV6RByXfGm8GssIs7LVek Qcl3xpstV6RB
yXfGm8GssIs7LVekQcl3xpstV6RByXfGm8GssLKbLVekQcl3xpstV6RByXfG m8GsiJstV6RB
yXfGmy1XpEHJd8abQayLKxstV6RByHfGmy1XpEHId8abQayyibLV+kQch3xp s1X6RByHfGpt
BrLKLGzVfpEHId8abNV+kQch3xptBrLZFrs1X6RByHfGmzVfpEHId8abQusk sbJozHKwPYd4
IyUOxQ8U/wDuJPiU2z1fpEHId8abPV+kQch3xqZgxKHYoeKf/cSfEhoYHZOM 5zvnUSfEptnq
/SIOQ7402er9Ig5DvjTMGJRbFDxT/wC4k+JNih4p/wDcSfEptnq/SIOQ7402 er9Ig5DvjTMG
Jc0mj4JGOY7XOa4WINRJmP5lH4Lpb5if/cy/Eu3Z6v0iDkO+NYNNVn/qIOQ7 41P4rG0fDj8G
Uv8A/P8A7mX4k8GUv/8AP/uZPiXZstX6RByHfGmy1XpEHId8afx4XNuXJ4Mp T5//AHMvxLHg
qk7pj6jUSH//AKXXs1UP+og5LvjWpiqRuqID/wD0O+NMV4M25azMayjkYxoa 1sZAaBYAW3Ly
deq43S0Mrn2xASNNhYGxI/7Lylat8Q517p+8vUYv2ZZ9SH4aulSRfsyz6kPw 1Y6UbA/RVY2r
e6OndA8SvbvazCbkZHs9SzLpDWDS2jamZsNPpCkmld8lkczXOPbkAV2L5O4p aTQUdcIK/R7p
adlHNEHwyMkwnA5zSSHC1u0bzkVzz6Z0w9mlKmnfI3ZK10MYcYGUwa1zRZ5e Q+5BO47yLWWV
fYMnhkmkhZLG6WK2sY1wLmXzFx2XUi+J0jpCfRdd+V1ZSlomjFIGlwva7cN7 eq67vCWlKKor
xKZHRQ6PfUMZWOg1okaT/liPyD3ntG8IPqEXyNY6ql/JcTz6bdjq9HPkdTyR xAyHVhxwWAIt
mD8rI9hsVaaMmND+RdNUOkc4w0AlxOaHWsy9rC17bt43b+1BdIvkdFaS0w3S Og2Vs7ZYdJQP
eQXNO5gcCAI24fZd2/1XU35W6X0noaohfRtkniq4nQRxtYPzc9xhfexxE3Nm 9tkH0k88NNC6
aoljhib8p8jg1o7MyVIvPx+Umm59CaRrsUlI6giigLXRNOOcyAPfm0WNsi3s xL6KpnrJ/wAp
o6KgrpWsiDZqsFkbo2M3CMeLiDnb83CwzF+wL5F8TpLTemI6fS2kaWobs9DW agMdhaMiwEFu
Ak5k54x32G5d02ktIs0z+UD21f8AhtGU7ZI6YxtwucYi7N1sVrg5A9u/KxD6 R88Mc0cL5Y2y
y31bHOAc+2ZsO2ykXxNPJUTflH+S09TpB1S+emklMTmsBjLorkjCBkdwvwnN fbICIiAiIgIi
ICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIi ICIiAiLirdIC
klEZjxXbe+KyDtRVXhpvmf8AmE8NN8z/AMwgtUVbFpXWmzYf+YW7610r3U8Q DJbZuLvkg9vr
/spMxHysRl3Agi4IIWC5cDXt0eC0505OVjmw+ztH9V2OFxfsUpaLExhq5xK1 WSsLqw4WfoE3
zpvfcvK16oz9Am+dN77l5WrPxDEd0/j9vUIv2ZZ9SH4au1Sxfsyz6kPw1dLM tw44NE6Nppmz
U+j6SGVvyXxwta4dmRAWz9G0ElUKqSipn1AIdrXRNL7jcb2vlYLqXPFW0k1Q +niqoZJ4/lxt
kBc32jeFlpsaSmLp3GniJqAGzHAPzgAtZ3fllmtaSgo6LHsdJBT47YtVGGYr br29pXQiDlpd
G0FHIZKSipoHkYS6KJrSR3XA9SmgghpoWw08UcMTfksjaGtHbkApEQcMehdF RSNkj0ZRsewh
zXNgaC0jcQbLqmghnwa6KOTVvD2Y2g4XDcRfcfWpEQc7qCjdDLC6kgMUz8cj DGML3b7kdpyG
Z7lq/RtBJVCqkoqZ9QCHa10TS+43G9r5WC6lrI9kUbpJHNYxoJc5xsAO8lBy z6J0bUzOmqNH
0k0rvlPkha5x7MyQpoKSmpnOdT08URcGtcY2Btw0WaDbuGQ7lKCCLg3BWUHH BonRtNM2an0f
SQyt+S+OFrXDsyIC7ERARFpHLHK0uie14BLSWm9iDYj70G6IiAiwchcrQTwm n2gSxmHDj1mI
YcPffdZBIiwCCLg3BWUBEXINJ0BlkiFdTGSIEyM1rbsA33F8rIOtFE6ohZT6 98sbYQ3FrC4B
tu++6yiOkaEVQpTWU4qDa0RlbjN8xle6DqREQERaRyMkBMb2vAJaS03sQbEI N0WjZGPc9rXt
c5hs4A3LTa+fdkQt0BERAREQEREBERAREQEREBERAREQEREBERAREQEREBER AXBVaOpq2rLp
2uJaxoFnEdpXeqysjEuk2NcLgRg2v6ykJM4PANBwP5hTwDQcD+YVIKaMbm/1 K3ETRuC1qzv/
AEiZoSiY67WyA/SFTvoInR4W3Dh8l17lp7wsYFIwZKWr0Iv1Q00LhIZ6hjdc 7cN+Aer2rpcc
lj/MfYsPOWa5VjFsQ6TOYyjLlriKFYXoYckf6BN86b33Lyxepx/oE3zpvfcv LEn4hiO6fx+3
qMX7Ms+pD8NXSpYv2ZZ9SH4aulmXSHLpNkz9GVTKYkTOicGWNje2Viq1+k6B uhZxo2aFs9NT
PcyJoGOEhp3t3tse8K8RZa4fM1tdX01dT050hDEzVNkElTIyITOLjdvyCDYW FgWnPed65q/S
FTWP0nTR1TtSaaoGqxMdIwssLFoZ4oOe8uJBvkvr0RI6PlZ9J1Mc9JFT6Tp2 0+pa9k08zGCc
4iCLhhDrWAs0tOe/u7fyn0jNQxMbTVGolLHyNLnta12EDxc2OLjn8kWvnmFe okkdFZpKaow6
PZBOYDUThj3NaCbYHHK4I7Aqeq0ppCOCnjNZFCNbPG+qme2IOLH2aCSxzQSL m1he2RG5fVog
+efpSsikLXyMc2AtqJnsALTCQBkbbrl5B32YujSE7v8A4vMat7Wz1MDmtabA l7gcLAO052+x
XKIR0nL5uXSFT4bhooarVNuIXxOcwuB1ZOJrcF7XtmXWuCLLd+lah1BNO+V0 Ooa2CQjC0CYu
Ac4ucDZoyzscicivoUQUVNpCqd+S1XVuma+oiZNhlbZwOHFhO4A7hnYA9y5T pKqME+zaSFSP
zF5gxlonukDXMFh3dhuR3r6Grp2VdJNTSFwZMxzHFu8Ai2SkY0MYGjcBZPI+ fmrqmGvkgOkH
CeKSNkNM5jL1DCG4nnK53uzbYDDu3rnrdK17WxtFXFTMdPUMM8r2xNGB9mtx Fjhuv2XNt/f9
PI0vjc1r3Rkiwe212+sXBH3hR0dMykp2wsc51iXFzzm5xJJJ9pJRVVFWSVFc 6Co0m2lkwtEM
URZacFgONpc0lwve1uHNaaFdK38kozS1JmnjiyvhOBwHyMh9meeav0RFDTaT qqmrjax35mqc
JYThFxE2+L77N/nVSZpJ4Kmoqa12tqNDhwjIYBIbPvYWvlvyPb3WC+0RFicK nRklTHXy0s9Q
Z2injlaSxrcJJcCBYbvFFr3PrKq5tM1e16Q1FSMDKeoc2NzmOfE9lgCWhgw9 tgS647l9UiT1
SOiq0bLUt0jNTVFS6obqI5gXMa3CXFwIFgMsha9z6yqhtUDozTdMa6kJ/wAW RTAfnR4zsycW
7/SvrESVjo+S0hG92h6rRbmO1NPA+oxEZFmEljb+p1/sZ61Y6KbUnSle6OaF sAkjxsdES4/m
mbnYgB9xV4iuU8KLS9VWx1Vbs9WYWUtGKgMEbXYnXfkSRuOHO2fcR2xVFbXU m1RmrdINVDLr
XRtvCHvLXkAC1gBfO9rZ3X0SKK+cOkpG0/60vRmpEfhDCzJuC5ztg+VZuK1s 7b1wN0hVQUcL
YKyKCKWoqS6ple2JpcJDYXcxwF7k2sL2yK+yREVOhXOfVaRe5zHOdLGSYzdp OqZuPcrZEQER
EBERAREQEREBERAREQEREBERAREQEREBERAREQEREBcb230kT3RN/u5dagcC 2pMmG4LAP6nq
mcGMt8KYVrrv4f6rOuv/AJP6pszqzhWQLLAee1th7VsTcG+QUtdYqwRnmo3m 5Wkk9pMA3Ybr
XWBKV8ysslYS90XVlyxi+jpvnTe+5eVr1WL9XTfOm99y8qSfiGI7p/H7eoxf syz6kPw1dKli
/Zln1Ifhq02mPhl5T+izLpCZFDtMfDLyn9E2mPhl5T+iyqZFDtMfDLyn9E2m Phl5T+iCZFDt
MfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+ iCZFDtMfDLyn
9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDt MfDLyn9E2mPh
l5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn 9E2mPhl5T+iC
ZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPh l5T+iCZFDtMf
DLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iC ZFDtMfDLyn9E
2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMf DLyn9E2mPhl5
T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E 2mPhl5T+iCZF
DtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5 T+iCZFDtMfDL
yn9E2mPhl5T+iCVcs4q9fihEZZhAs49ual2mPhl5T+ixtLOGXlP6INGGf95E z7HLclwGUYv7
VjaWcMvKd0WNoZwy8p3RTWBo99V/kZGPaVA7wgT+5/qukzt4ZeU7osGdvBLy ndFdYMuQQVLp
cUpYBa3iroZEGesrYzN4JeU7otTKOCXlO6LUYhGxWFqZRwS8p3RY1n8EvKd0 WswiGL9XTfOm
99y8qXqsOejZjmM5t4t/ncvKkn4hiO6fx+3qMX7Ms+pD8NWSrYv2YZ9SH4as lmXSBFyz6Qig
FUXtfemYHuAFy4G9rd+4j2oK5j3sZFHJKXxiXxbZNJABNyPWfsKyrqREQEUL 6ljKuKmIdjlY
57SN1m2vf+YKZAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQERE BERAREQEREBE
RAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQcUf6vn+dN77l5Sv Vo/1fP8AOm99
y8pXSe2HKO+fx+3qMX7MM+pD8NWSrov2YZ9SH4asViXSFDpeppWaXp2vraSN uTalsk7GuaGk
PbkTffl/qXJRtZVQVMFPUUs8rZohEyGdjjqI5AQcjlvK+ndIGm1nn5rCf7LG tHBLy3dFI6K+
fNBIRXvj0MIZZyGmzYSHRh2dhisXEXd4wtewN7LbR+iJWPohUU/5uDXlokwH AXPaWZNyvl2C
wsr7Wjgl5buia0cEvLd0QfNwaKmuwP0dJFamlinkjkZimecPjC5zJsc3W9as dE0skLojJo+O
nwska1zMLMILhYFjSRc2vcHs7L2VnrRwS8t3RNaOCXlu6IT1botNaOCXlu6J rRwS8t3RBui0
1o4JeW7omtHBLy3dEG6LTWjgl5buia0cEvLd0QbotNaOCXlu6JrRwS8t3RBu i01o4JeW7omt
HBLy3dEG6LTWjgl5buia0cEvLd0QbotNaOCXlu6JrRwS8t3RBui01o4JeW7o mtHBLy3dEG6L
TWjgl5buia0cEvLd0QbotNaOCXlu6JrRwS8t3RBui01o4JeW7omtHBLy3dEG 6LTWjgl5buia
0cEvLd0QbotNaOCXlu6JrRwS8t3RBui01o4JeW7omtHBLy3dEG6LTWjgl5bu ia0cEvLd0Qbo
tNaOCXlu6JrRwS8t3RBui01o4JeW7omtHBLy3dEG6LTWjgl5buia0cEvLd0Q botNaOCXlu6J
rRwS8t3RBui01o4JeW7omtHBLy3dEG6LTWjgl5buia0cEvLd0QbotNaOCXlu 6JrRwS8t3RBu
i01o4JeW7omtHBLy3dEG6LTWjgl5buia0cEvLd0QbotNaOCXlu6JrRwS8t3R Bui01o4JeW7o
mtHBLy3dEG6LTWjgl5buia0cEvLd0QbotNaOCXlu6JrRwS8t3RBui01o4JeW 7otmuDhcX+0W
QZREQEREHFH+rp/nTe+5eUr1aP8AV0/zpvfcvKV0n4hzjun8ft6lF+zDPqQ/ DViq6L9mGfUh
+GrFYluENZpCm0ZSmoqpAyMyNYCSBmbDtP2+wFdDaumfEJWVEToy4NDw8EEn K1+9cukKaWr0
e+KDBrBIx7cZIBwua6xIBtu7lywR7RpqQsfG6GO0szGHEGz2w2v6hnb2HtUy qygrqSoe5kFV
BK9rQ5zWSBxAO4m3YkVdRz0754aqCWGO+ORkgLW2FzcjIZL53Rei56/QlM14 gp4tifFG+Mku
cZALlwsLbtwJue5XGh6KWkjk18TWSODQXNq5J8Vh/GLt9guk9Mjng08J9Fur 2spzHqpJWsbU
XeQ0A2Iw5HPPfbLfddVNpmhqZKmNtRG11L5W72+KLAk79wvYk9oK4H6EqXaO pqcPixxUMtM4
3NsTg0AjLdkVtVaHqpo66Jrogyd0UrHaxzTiYGeKbC4BwfKBuL7lVWbdI0Lm RPbWU5bMbRuE
rbPN7ZZ55kBajSdIdJv0drmCpYwPLS4bjfK173AF/YQuOh0XLDWU1Q+KOPVi XENpfOSXYLHE
8A7mlbaQ0bPVVVVgdG2GqpNnc4uOJh8axAtmPG7xuUSHbBpCiqQDBWU8oJIG CVrrkZncey4U
VDpai0hUTwUtRHK+AgOwvabiwNxY7s7e1VR0HVTUhgfHDC4kOdJtcs5OEEAe OMgb2Iv8kkdq
s6GmqYK2rllbCI6gtf4jyS1wY1pFsIyy33+xUWCIigIiICIiAiIgIiICIiAi IgIiICIiAiIg
IiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICgd5R3t /wCynUDvKO9v
/ZBhERAREQccf6un+dN77l5QvV4/1dP86b33Lyhbn4hzjun8ft6lF+y7PqQ/ DViq+L9l2fUh
+GrBZluAEi9ja6zjdxKCGBk8tQZHSeLIAMMjmgDC07gfWpdih75uc/qorbG7 iTG7iWuxQ983
Of1Uc8NJTRGSaSVjB2md/VBNjdxJjdxLhbPo57bslnP/APZIMhmTmewBdbaO BzQ5rpSCLgid
+f8AVSJiekHjLfG7iTG7iXN/+OFXshqxtNr6nanY91/k4rqWOlppY2yRSSPY 4Xa5tQ8gj1G6
okxu4kxu4lrsUPfNzn9U2KHvm5z+qDbG7iTG7iWuxQ983Of1TYoe+bnP6oNs buJMbuJa7FD3
zc5/VNih75uc/qg2xu4kxu4lrsUPfNzn9U2KHvm5z+qDbG7iTG7iWuxQ983O f1TYoe+bnP6o
NsbuJMbuJa7FD3zc5/VNih75uc/qg2xu4kxu4lrsUPfNzn9U2KHvm5z+qDbG 7iTG7iWuxQ98
3Of1TYoe+bnP6oNsbuJMbuJa7FD3zc5/VNih75uc/qg2xu4kxu4lrsUPfNzn 9U2KHvm5z+qD
bG7iTG7iWuxQ983Of1TYoe+bnP6oNsbuJMbuJa7FD3zc5/VNih75uc/qg2xu 4kxu4lrsUPfN
zn9U2KHvm5z+qDbG7iTG7iWuxQ983Of1TYoe+bnP6oNsbuJMbuJa7FD3zc5/ VNih75uc/qg2
xu4kxu4lrsUPfNzn9U2KHvm5z+qDbG7iTG7iWuxQ983Of1TYoe+bnP6oNsbu JMbuJa7FD3zc
5/VNih75uc/qg2xu4kxu4lrsUPfNzn9U2KHvm5z+qDbG7iTG7iWuxQ983Of1 TYoe+bnP6oNs
buJMbuJa7FD3zc5/VNih75uc/qg2xu4kxu4lrsUPfNzn9U2KHvm5z+qDbG7i TG7iWuxQ983O
f1TYoe+bnP6oNsbuJMbuJa7FD3zc5/VNih75uc/qg2xu4kxu4lrsUPfNzn9U 2KHvm5z+qDbG
7iTG7iWuxQ983Of1TYoe+bnP6oNsbuJMbuJa7FD3zc5/VNih75uc/qg2xu4l jtJ7SsbFD3zc
5/VNih75uc/qgyijkpImAWMuZ88/qtdmi75ec/qgmRc08LY2Nex0ocHs3yvO 9wG4n1rpQccX
6tn+dN77l5QvWIv1bP8AOm99y8nW5+HOO6fx+3qcX7LM+pD8NWCq4nH/AONM HZsQ/DVoszDc
S1o/KVX0o9xq6ly0flKr6Ue41dSiipq94P5QUscwaYtUSwOOWPP/AMK5XNW0 MFdEI523sbtc
Mi0+pSYyzaMx0fPy1OkWRh9VCIC5xjbgOF7rjdbtGeR7CvpmxiOLBGLWGXtX BTaHpKSZs5c+
R7TZplcDhPqyGaslmKxGZK7RHVS6Gq6JlHBQySRtrm+VgcRrDJvc4jebnPF9 qqYNJz01HomG
nqBGRDAXxvc0CQOdY4W4S51he9nNtlvX2CLbT5p2kprV7PCkQkieCX62LVRt x2wg4btfbKz7
i/8AS70bOKnR8EwdK8PYCHShuI+s4cvuyXUieDyIiICIiAiIgIiICIiAiIgI iICIiAiIgIiI
CIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgin3 N9qrap+kjWxC
lijFOzORz3C8mW4dwHf3+rfYVT8DWWaXEusAN5yUBme3fTyD7W9UCq8gMreP Hl/raplySztl
iIDS0tfHcG3GO72LrQckX6sqPnTe+5eTr1RjyKCcdmKb33LytbmOkOcT/Kfx +3p0X7OM+pD8
NWqqov2cZ9SH4atVLeGqtaPylV9KPcaupctH5Sq+lHuNXUstC+c/KbSWz1MN K4vEJbjeGGxd
na1/sX0arNL6JbpHVSNc1s8R8UvbiaR3ELfpzEW6ipq5KTRdc6kjYB+bJOsJ sSQR2W7/AF+q
3b9I2Iim1T3uccNi4Eg/Yd4++/rVOzQtTU1sdRpOWF5jNwI25utuubDJXb2h 7HMN7OFjYkH7
xuWb1rnMfMrl83Q6YqaXRMIbTmq1NEyqmllqDiIOK9rgknxe+3rC6PDNVTv0 nLPCySCGVjIG
scS4lwZYWDb54rneRewBVhFoihhp3QMhOrfDqHAyON2Z5XJv/mKzJoqjlM2O IkTtDZG6x1ja
1ja9gRYZjPLek/I4o9M1cxgii0eBPKJCRNI+NoDcOYxMxEHFwjMfauKl0tUa P/J+mqZo9pnn
YZntM8j3EWuXABhsPVk0XGeavYdH08D43tErnxhwa6SZ8hAda4u4nhCil0NQ SwRQPhdq4ozG
0Nle3xDvabHMZDI3UQir5airkZBAwwQkNlkfIWuBLQ6zWgG+RG8hQ6H0w/Sj nE0ckMRYHxvc
19nD1lzQL7vklw9a6/B9MKoVLWyMlAAOCVzWutkMTQbO+0FYo9HU1E5xphIw H/JrXljc7+K0
mzfsAQ8OtERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQEREBE RAREQEREBERA
REQEREBERAREQEREBERAREQc1V5Wm+kPuuUFVuCnqvK030h91ygqtwQckX7z 2w/iKzVZF+89
sP4is0Fe39Cm+dN77l5YvU2/oU3zpvfcvLF0t2w5V75+8vTYv2dZ9SH4atlU xfs6z6kPw1bL
NvDdWtH5Sq+lHuNXUuWj8pVfSj3GrqWWhQPqomyPjB8Zlsd7gNHeSp1T6VnE NU+N7gwTRNaH
PAw5F19+R3jL1/ariZ+Bz0tZMaeVxllczaJAHgYiDnhG/dut3nLLtvKd7pIG PeAC4XyOX/v/
ALcqjZLC+PZoKpzw4FoiiEed+wADJXUbJ20uF0rTPY+OW3APZkLXt9l/UlqT W02nylZiYiHD
FpdjKWSesDmtZPLHijhe8BrHEXdYG2Q3mwXWK6mLbiS/53U/JN8fd/3vutnu VVV/k4aqlZC6
oicfzpk1sGNpe83L2txeKQb2OdgV3N0YG1+0644MAGrAt+cthx378OSiynpq 6CqlkiiMgkjs
XNkidGbG9iA4C4yOYVbTaTrHVkeuNO6Caqlp2sZGQ9uDFZxOIg/JzyG9S6H0 N4MmklMsT3SR
tYTHDgLrEnE43OJxvmVPQaKp6KSaZscRqJpHvdMIwHkOdiwk7zbL7kGo05QO gjmZJK9kl8GC
CRznAC5IaG3IFxna3YtvCdMHPkNVG6EQslAawk2cSAQRvuRYAC9/aoGaImp4 KIUtWxk9LCYc
ckOJr2m1/FDhY3aO1cQ0OytNTTDWNhZDFC2SaHJ72Pc4nCQMTbkXtkbmxRVq dLUYhZJil8dx
aIxA8yXG/wAS2L+naO9YodJx1tbV0zYpWGncG4nRuaHZA9oAG/d9u5c0Wh5q cQyUslFTzxYx
+apC2Itda4LA+97tGd12UtHJT1tTOZmOZUFrizVkEODQ2977rDdb7UR2IiIC IiAiIgIiICIi
AiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIi AiIgIiIOaq8r
TfSH3XKCq3BT1Xlab6Q+65QVW4IOSL957YfxFZqsi/ee2H8RWaCvb+hTfOm9 9y8sXqbf0Kb5
03vuXli6W7Ycq98/eXpsf7Os+pD8NWyqYv2dZ9SH4atlLeG6taPylV9KPcau pctH5Sq+lHuN
XUsNC0llZCwOkdYFzWg27SQB/Uhbrk0mAaJ4Mj2gkNwsDSZC7xQ3xgRmSB/4 QcWj9MST1VVH
UxCJkTwwEA/KLy0Dt35d3b7VcL5LRrnOr5MT5otXIGukDQdW4ktAGJpsCb7u IfxL6uRxZG5z
WOeQCQ1tru9QvkgipKplXG98YcAyR8Zxd7XEH+ynXymkNE11Ro5sWyFxkdPN ZuqL4nvddoJf
cAWJuW53AsVZsoKgV2Axg0mIVNyR5W1sNu6/jX70JXCrYNMRzVQhNNPG10r4 WTPw4Hvbe4Fn
Ejcd4G5cX5PUFTS1dRNPTmATRsxNtE1pkBdiwhnZmLF1z3qfR2iXsmfPVSyn DUzSxQktwNxO
dZ2Qvex7Sd+5BcLQPcZSzVuDQAQ/Kx9W+/8ATtXzcWhnU9Do5s2i21TI4nCe mGA3lIbZ5xEN
NgCL3uL5LSbR9ZIyopGOLp20VO14a8EuAkeS27sjcAjMWPbkUV9Uoo54pZZY 2Ou+Fwa8WORI
B/sQvn49Fuigp2u0dUVNIx0mKjmEAIcbWcGtIjsLOy3+Ndd+jKBtJpWvlFA2 ETlr2StawZYW
gtyN73BO63rRHbSVjat8wjjkDInmPWOsA8g2Ns75EWzA9S6V85FoJrYoYjQw iPwhJLIwBoBj
8cNuO0WLRZb02jZmaSD3UeGZtQ+R9bib+cjN7M34jkWixFhh9QQn7/r6Bc1f VtoaV0743yAO
a0MjtiJc4NFrkDee9UdD+T0bG6PbU0UZaKZzaoOIcHP8XDiz8a3jW327LLpn oqt/5K09I+KS
SpY2HGxsgDjhc0mzrjOwOd0Xyt6eV80QfJBJA4/5JC0kfykj+q2je57SXRuj IJFnWzz35E71
Q1FFPPs7oaCoYyIHXMqJ2vfMzEDqycbr8WZ7LbnFRyaMqA6J+w6+VtTM9okE b4mtdJfEQXAg
2zBbcjtB3InhfR1TJgDA10rdY6NzhYYC0kG97dotldTr52j0S+mkjZFQNhEd e+Zz2YAHxkSY
SLG+WICxCiptB1NNSU4poWwVDqGSKd4eATIQ3DcjM2sbHOyff8XHV9OuXb4f CIofG1uDHe3i
+y/f2+xVOg4mR6Zq2xUOwtbTRAw3abG7+Ekf+3KOoNLFxrA+ASbTrxBq/Hwj xcOPHb5Hq7U8
ov1zOr4Box2kGF0kDYjKC0ZuaBfIGyqI9CETRzOpGGV1bMZXGxLoXY7A97Td vi/0UlJo6WL8
kpqBlGIKg074ywYBrH4bYrg2z7zY96eFj5wsaLSAq5HxOp5qeVjWvwS4blpv YjCSOw9q6XvL
SwCNzw42Jbbxct5uf7X3r51ujqs0tRqqWeNv5lwiqJhJI9zHhxs7E6wsLAF1 r3yHbNHSVk1f
tL6V0LXVrZcL3tJDBCWXNiRv7En+khZt0jC7RHhINfqdSZsNhiw2v32v9qxH pES1EsMNNPJq
sON4wgAusbZkHIEH/wA5L5+bQ9WdGMgl0dtMuwCGI6xn5iSxvvOV7jNt91jk us6GewVzoqSN
sk1TA9rmhoLmtMZdn7Q4/wD+q+Vld0lUyrje+MOAZI+M4u9riD/ZTr5Wt0NV TNjEsEssAnqH
Oii1LneM+7HWku3df1i/tX01O0sp4mnHcMAOsILt3bbK/sU8JPykREQEREBE RAREQEREBERA
REQEREBERAREQEREBERAREQEREBERAREQc1V5Wm+kPuuUFVuCnqvK030h91y qXVsklQ9hlhI
bI5oAhkuADbfuv8A0QSRfvPbD+IrNVrBZ0o/ii/EVkgr2/oU3zpvfcvLF6m3 9Cm+dN77l5Yu
lu2HKvfP3l6bF+zrPqQ/DVsqmL9nWfUh+GrZS3hurWj8pVfSj3GrqXLR+Uqv pR7jV1LDQtXv
axpc42AWyq9JOjZVMOHHJqz4tib55ervViMzhJnDrfWwMaHFxzvkQQbAXJse wBdDXBzQ5pBa
RcEbiqLEHNBGKBxuCYr57xbLO+RI32337Fb0mHZI8II8XO4O/t3571y2/lMZ +GsdIlpDpKgq
GyOgraaVsQxSFkrXBg7zY5bl0ggi4NwV8jT01RJ+TO1zNhjji0ZJHGI3lzpA 5oN3XAtbDuz3
nNds+l30xnp3VLGTa6nEEZtiMbsAcQO0XLs+xdcdcJL6JaPljjcxr3taXnC0 E2xG17DvyBXz
7NJzu0pDHt4Mj6t8UlJgb+bYA/D2YhewNyc75LvqKqujfQiZkULpanA5sUms Dm4HHeWi2Y/p
vU8ZFouKKfRlNWPpIZaSKpkdifCxzWvc4i9y3eTZVuhqutfJo91TVunFZSul c0sa0Mc3Ba1h
f/Mb3v8AZuWuzVFZpXSELGwtgFXDI+UvONpaxhs1trZ2AvftOSuOv3kfQrQy xiVsRe0SOBLW
E5kDeQPtC+ffXVbYDLNXuhhfWyQvlwMAgjaX2zItmQ0XdcZ96eE69sLDC/aT qKl8ZwD8/gLc
DrDvv2WB7OxRcdcPo0Xy9NpSpNEHS6UpnQvma2SpilZIYGlpPjeI1rbkAC4N rm66aIs/+SYx
pN07ZaOMx3MdprF97WaL235d/dYJ5TxlfoiICIiAtXsbIxzHtDmuFi0i4I7l siCClpKajjMd
JTxQMJuWxMDQT32CnREBERAREQEREBERAREQEREBERAREQEREBERAREQEREB ERAREQEREBER
AREQEREBERAREQc1V5Wm+kPuuXFNTNY8v1tQ4ucXWMzrC53Ady7arytN9Ifd coKrcEHJGbmU
/wAUX4is1WRfvPbD+IrNBXt/QpvnTe+5eWL1Nv6FN86b33LyxdLdsOVe+fvL 02L9nWfUh+Gr
ZU8R/wD19n1Ifhq4Ut4bq1o/KVX0o9xq6ly0flKr6Ue41SzyOjixMALsQABN t5A/7rDSVQVN
JDUtcJGDEW4Q8ZOHsK3hlbK0kXBBs5p3tPcVy1Uv+IdG+QsjZGH5OLd5OZII 3W/qs2vpGViu
3Rmn0bBEy0g1zu0vFx35D2k+vPeutjGRtDWNDWjcGiwVW2vkjDQHPkaHAEGm fiw3zz9Q/t2q
xinZNBrYiXNztkRuy3H2LNb1nMws1mEqL5+jmaPB1ZUPrJJa3xsbJjqWktJw FmK1gAbEN7Mz
dIfykklpX1A0dLgOAxXxtxhzw0XLmAX8YHIuHrXTHhlZ+D8Vcyqmqp5tWS6K J2EMjJFrizQT
kSMyd67VSTadlp4nslo/8W2oEGrje6RpJZjvdrC61v4d/wB6ki0zLJJhdSth YynE8rppCzBm
4WsW33t3m2RvbsQW6L5+PS01dLR3ifTObW6t7QXgPGqc7/M1ptu3jsX0CAuZ tGBXGrfLI92A
sYx1sMYNr2sL52G8nculEBERAREQEREBERAREQEREBERAREQEREBERAREQER EBERAREQEREB
ERAREQEREBERAREQEREBERAREQEREBERBzVXlab6Q+65QVW4Keq8rTfSH3XK Cq3BByRfvPbD
+IrNVkX7z2w/iKzQV7f0Kb503vuXli9Tb+hTfOm99y8sXS3bDlXvn7y9Ki/U LPqQ/DVyqWP9
Qs+pj8NXSlvDdWtH5Sq+lHuNU00etjwYi3MG47LG/wD2UNH5Sq+lHuNU8sjY mF7r2BAyF95s
sNEcbYmBjBYBcdZo91RUtmjmDDhDS1zMQNiSDvHef6dy7Wua9oc0gtOYIUE8 7xNqosIIaHFz
hfeSAALjuPb/AOMX1mP5NVzE9EDdHzFwEtS1zO0MjLSftxGy7mtaxoa0BrQL AAWAC5W1rmho
mheCXBuIFuHM2B337R/5XWSACTuClIpEfxW02n5cceiqOKpE7I3BzXFzW6x2 BrjvIZfCDmcw
O0961j0PRRscxkcgjJDtXrnljSHBwwtvZuYG4Ba0M9dWNiq7wR0soxNiLHGT CdxLr2B7bYfV
ftWWaaoHtkcJnBsbHSFxjcA5rd7mkjxgP4b9i6fDCSfRlJUazWRG8kglLmvc 1wcAACCDcGwt
lZBoykwSNdG54ki1LzJI55cy5NiSb/5jnvUY03o8wyymctZFhxl0bm5ONmkX GYJ7Rkthpeid
TmYPksJNWWal+sxWvbBbFe2e7dmgzDoqjgLSyN5c2TWhz5XPJdhw3JJJORtm u1cR0pSfmQHy
PdMMTWshe5wF7XcALtzyzt2rno9Mx1uAtxQf4l0GGWF/j2xWsSBY+LfttuOa C1RV7NNUD2yO
Ezg2NjpC4xuAc1u9zSR4wH8N+xTUekKauc9tO9znMAJDmObkdxFwLg2NiMkH UipKbSdY6sj1
xp3QTVUtO1jIyHtwYrOJxEH5OeQ3rqGnKB0EczJJXskvgwQSOc4AXJDQ25Au M7W7EP6WKKkl
02H10kVPKxlNFS7Q6Z1O+RpBBsQRYWAF+2+4WIK6GaWYyWrFQRgilZHHq43O c+7GuyaLknM7
huCCzRccek6WWaOKN0j3yNDhhheQ0G/yjazdxyNty7EBERAREQEREBERAREQ EREBERAREQER
EBERAREQEREBERAREQEREBERAREQEREBERAREQEREBERBzVXlab6Q+65QVW4 Keq8pTfSH3XK
Cp3DIoOSL957YfxFZqsjFtZcdsP4is0Fc0/4Kb503vuXlq9Na78xMP45ffcv Ml0t2w5V75+8
vSY/1Cz6mPw1dKmj/ULPqQ/DVypbw3VrR+UqvpR7jVLUte+K0YBcHNIBNtxB UVH5Sq+lHuNX
SSALk2WGkcEWpYQTdziXO7Bc9w7Fw6QgqnVeOGNz4nxhrsDgHCxPeRvvvHcf arNQzVDYnBuE
vfa+FpGQ7zcgf++orHqVi1cS1WZieiqbQue4N8HMjv8A53tYQPsBuranp46e nbDGPEb39t96
0jraeSwEzGvJtgc4B1+6ynWfTpWvwtrWn5V9JQVNJhgZVsdRMybG6H841vY3 HitYfNvbt7Vz
N0FKaM0stY10TKd9PBaKxYHC13G/jEADdbt+zrZpMSuLoaSplgF7TtDcDiO4 F2I917W9ds0k
0vSx00NQ4u1csRmBAvZgAJJ+8DLtK6s+UVVojaJXP1+HEyFlsF/Jvx9/bu9S jrtAsrHzPdJE
5z6hs7WzQiRgIYGWc2/jC1z2dncrCkqH1DHGSlmpnA/Jlw3I77tJH9V0IkKq DRc9LLHLSzUs
J1YjlY2mIjcASRhaHeKfGPad6M0Q9sjcVQ0xMqn1LWiOx8YOu0m+eb99huVq iClboKU0ZpZa
xromU76eC0ViwOFruN/GIAG63b9nfDRaqudU6y+KBkOG3CXG9/8AV/RdaIOC g0VT0Uk0zY4j
UTSPe6YRgPIc7FhJ3m2X3KBmiJqeCiFLVsZPSwmHHJDia9ptfxQ4WN2jtVsi Cp8CNEFREycg
TUYpbubcj5Xjev5W7JR1f5PsqRIXSROcZ2TNbNCJGXEYZZzb5gi53i2XcrpE FTFoiSOopZGy
UsLYRZwpqcxF4z8XJ5GHPcQe1WyIgIiICIiAiIgIiICIiAiIgIiICIiAiIgI iICIiAiIgIiI
CIiAiIgIiICIiAiIgIiICIiAiIgIiIIKljXsa17Q4X3EXUGy0/o8X8gXTPub 7Vog554444LR
sawGSP5It/nauhQ1XkR9JH77VMgqQPzEx/jl99y8yXpDnkRyD+OX33LzW66T 2w5Vn+c/j9vT
I/1Cz6kPw1cqmj/ULPqQ/DVypbw3VrR+UqvpR7jVtWgGnOJuJuJtxa9xiC1o /KVX0o9xq6lh
pDStkbFaS+/xQcyB2Ant/wDfaq7SNVs1eQS1msibhc/JuRdfPttcZese1W60 kljibile1gva
7jZY9Su0Yzhqs4lR65sxayOuklfiBaxhYSSDcdnq9nermCOUUwZPJjkIOJwF lK1wc0OaQQRc
EdqLPp+nr8zlbWz4VmjDV0kMNBLRPLYWiMVDXs1bmgZG18QNuzDv7bZqGjoJ oH1mupmywsYY
qeO4OsjJLiM8hvDbHhVjS6Qoqxzm0lXBO5nyhFIHEe2xUktRDB5aaOPxS7x3 AeKN59guF1Yc
Wh4qiETiSOaGnxDUxTyB72C2eYJyvuFzb+islgEEXBuCsoCLWR7Io3SSOaxj QS5zjYAd5K0d
UQsp9e+WNsIbi1hcA23ffdZBKiwCCLg3BWr5GMLA97Wl5wtBNsRtew+4oN0W kkjIm4pHtY24
F3GwuTYf1SOWOVpdE9rwCWktN7EGxH3oN0RQ1NXTUcYkqqiKBhNg6V4aL91y gmRaQzRzxNlh
kZJG4Xa9jgQR6iFugIiICIiAi0bIx7nta9rnMNnAG5abXz7siFugIiICIiAi IgIiICIiAiIg
IiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiIIp9zfatFvPub7Vogh qvIj6SP32qZQ
1XkR9JH77VMgpnN/NSH+OX33LzSy9MPkZPny++5eZrrbthxr3z95elx/qBn1 Ifhq5VNH+oGf
Uh+GrlZt4dK+WtH5Sq+lHuNWNJ6Qh0ZRPqqgnC3IAb3E7gs0flKr6Ue41dSw 0qPyb0lPpWim
qKgMH58tYGDINs07+3MnNS1c4ir3XuSIm4QDnmXXA9th93qVkueooqeokEkr DjAwhzXFpt3X
BF1j1KzaMQ1WYieqsc6aPx2tZGGuDz/iX233OVrZ5/eraCR8tO18keqc4Hxb 3t3KKPR9NG9r
w15LTcYpXOF/YTZdSx6dLVidpW9on4fK6J0lJH+TTNTX0kr4oowWxN8enZcB znjEb2Ge4blJ
XVWr1VTSaQ2x0dFVOZUXY7MYOEBuXsX0ywHBwu0gi9sl2merMT1y+bk0pUDS E0Y0gGysmhbD
S4GXlDmsLuy5GZNxa3bktZ9LVUUWkdVVieaJwzY6N0ULC+28NxNcG3JxA7r5 5r6CClZBPUTN
Li6oeHuB3Ahobl9gCnRFAZ5aj8k9IPmqoKpwhlAkhlEgIwnIkNaL+wDsXDpC N7tD1Wi3Mdqa
eB9RiIyLMJLG39Tr/Yz1r61EWJw+ck0hUMrHRCt1UrHxMgo8LTr2ENu7MYjv dmCAMOfaon1j
p9LUjZKzHMyue00mFo1QDHhp3XzFjcmxvkvqERPGHx0WkKutoXmrq6d7jJA5 1O2UGSF2ubcF
gY0tHZmXbhmrCOqrqurip21r4A59UC5kbCbMkAaBcEZA93VfQoivk6jTVT4O ZO+vFJLsAnia
I2nXyWN94N7WGQ3XzyVppfXSDRRhkYyV1SCHPYXAHVv3gEf3XXX6P28auSqn ZA4Wkhjwhsg7
QSWl2e7IhdgyFlUUtRVVcFbUa6peY6ajbM5kETRjcS8EjFcjcMr9ntvw0eka +oZHCK9ji+tE
WvjLJbsMRcbOwNaTcb8P3r6lFB89S1de2SlfJWOma6rlpXRmNgDg0Ps7IXxe KL529QXLo/S9
c6CSqqK2ndqw2SenbI10kQxWeCzAC0AE7y43Az7/AKtEHzo0lpPVztDMU8UT 6kMwXu0tvG2w
9ZI7zgUZ0jUbNNselNsZeACowMOBzpA1zfFABy7LXF/WF9MiD5ylmlg0/VU8 lQ6OEzMvM4Nv
M/VMAYcrC+/IC/ZZfRoiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIi AiIgIiICIiAi
IgIiICIiAiIgin3N9q0W8+5vtWiCGq8iPpI/faplDVeRH0kfvtUyCoI/MS/P l99y8zXp1v8A
DS/Pl99y8xXW3bDjXvn7y9Lj/UDPqQ/DVwqeP9n2fUh+GrhZt4dK+WtH5Sq+ lHuNXUuWj8pV
fSj3GrqWGhERAUNVlSTfMd/ZTKGrzpZWgjE5hAubXNkmMj56atFFLWtrBiaJ Q2ExRDxci7fY
DcWi1777d6udGxSMa578LQbNDGEkeKA2+Z9WXq357q2spZ5y90FRPTmR4e4N ey18OHscD2Dt
t6lbUj2sgAkc1ri5xsXDK7iexW/p1mYtEdWa38TKtqscn5S6ox1ssbYI3AQV BjYwl77ucMbb
7h2HcoKHSM1Lt+ve6bHNKaYOcSS4SFmAer5Fvae5Wk9HRVFUKl8j2zBobijq Xx3AJIBDXAHM
nethSUAweLGdXK6Zt3Xs83uf6lMS1NofO05qi6jp6h9fWuD6oPEFQY3OLZGg EnG3IZ5X7Vba
edUsgoG0b5I5TUCzcZ8ezHnC43zBIF967YqahhmbLHgD2l5Bxne8gu7e0gKS VtNM6J0jmOMT
8bDitZ1iL/cSmJTaP/1TVOkH1WlNGy00z20jZAHhpsJHOjc6x9gANv4vUuiP Tj9Q2pqKTBTy
wOnhLJcTnNABs4WFiQRuJHrXY2koGBgY2JoZK6ZtnW8c3uf+RUcOjtGQ4wxr S17CwtfKXNa0
72tBJDQe4WGQTEmYV8mlaqjrKqWspy0tp4cEEcpkaXOe4Dc29917NJyyvkpq WvnrNJURkikp
7xzh0ZxgOILLGzmtJ39oHap2aK0WyOVmHGJWBjzJO55IBuMySRYnLuU8FLRQ Pje2Rznxhwa6
Sd0hAda+bieEJg2h2otWua4Xa4H2FbKKIiICIiAiIgIiICIiAiIgIiICIiAi IgIiICIiAiIg
IiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiCKfc32rRbz7m+1aIIaryI+kj 99qmUNV5EfSR
++1TIKv/AKWX58vvuXmC9Q/6WX58vvuXl66W7Ycq98/eXpcX7Ps+pD8NXCp4 v2fZ9SH4auFL
eG6+WtH5Sq+lHuNXUuWj8pVfSj3GrqWGhERAXLVSmASShmMsYDa9srm66lxa QY+SGdjBd74i
GjvOa1VmzjfpB7KpsRl/OvF2x2u22fbb1HeRe3Yp6CofKXAl7mADxnixxWzG 89t/Ycs+yj0t
HKzV1EsU0Ba0jWNaCflNsCQchme0dqs9Dtm1YleHlr4Y8L3Wu7Im+894Wrel GYtEsxfpiSr0
nJHpptEKyjpmGNjwJmkvkJc4Wb447h2HelBpkyiv2sNYKZ7y0tB8aNrnC/tu 0/0W8tHVeEjV
09REwOjbG9kkJfcAk5EOFvldxUXgZpMZdK7xZ3ymzbY2udiwH1Xw/d61MLMw 42afq3R0u0z0
NA+V04e6dpc0FjgA0eO3PPv7FaaQq6mJlGymkhElRKIzI9hc22FzrgBw7u9R U2izBVsn1pdg
dMbYLX1jg7v7LfapdIaPj0js7Z2tfHFLrCx7A4P8Ui1j7b/YmOhn9tKPTEb4 oG1TrVEr3xgR
Mc5ryx2EuFr2G457vsWx01RyQzGGowFkbpA98L8JaN7m7sYH8J/utnULdqp5 WARxwRPiEbW2
FnYd3dbCqqr0dNTaNdA6V9QGwPpqVkdObjELDGQT2AC/ijemFiYXPhOmFS2n MjjIbAkRuwgk
XALrWBPcTfMd65qvT9NBTumiZNM1sjGXbDJhN3WuHYbHt3eztUA0I1ukjVht M/GWudrabHI0
gAeK+4w5AdhzWw0VU+Dth2qMxR4NQdQcTcLgRi8bxtwGVkwkSt4nh72PFwHM JzBB7N4KnXNB
ixtDyC4MOIgWF8uxdKllqIiLLQiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgI iICIiAiIgIiI
CIiAiIgIiICIiAiIgIiICIiAiIgin3N9q0W8+5vtWiCGq8iPpI/faplDVeRH 0kfvtUyCsH6L
N8+X33Ly9eoD9Em+fL77l5eulu2HKvfP3l6XF+z7PqQ/DVwqeL9n2fUh+Grh S3huvlrR+Uqv
pR7jV1Llo/KVX0o9xq6lhoREQFFO+KOMvmAwgj/LfebKVc2kDbR1Ue6J/wDY qx8iF1QxpLjS
ARDPERY277EWH2ndvWaSaKdxY6KIPADvFs4WIB7Pb9u8erjjlwVMhjdGWPeM 8Qv2HLdxHv7F
0aMfC6pqG07mFgYw+IbgG7v/AB9llJi2cxPRI14bTVccdfscdBLO8Ma9zoxG GsBJAvicD2Hc
CuzUxebZ/KFU1dNL4fFVslXNFqY2tdBOGAODnE4hjbiGY7CuZugsUscktI1z 3Vsrpi4g4oXY
yAc82klpw/03qxMk1j7/APS/1MXm2fyhRh1Mal1OGs1rWB5bh3NJIB/oV83J Q6iqoqafRxqo
m7UWUwc22AvaW5OIbYAjInL7FNBoIicbTSsL5KJkRqW4SYpG4s7k4t2EA5/J zTM/JrD6LVRe
bZ/KFUjTFONGO0hJo6ojprNLXObGS8OIAsA49/bZdGhtZPTOrp2NbNU2Pi7g 0CzQPVvP+pVV
Fo6qZoVlIaKrjma6AvM1QHsOF7ScIxnDkCdwTM5IiOFvXV1FQw08skeNtRI2 OPAwG5duPsWK
Srjq55GR6PlbEx74zM4R4CWmxsMWLeO5V8uiasxujwNcynkjbSgOHk9Y17if YAB/p9a7dE6O
NM+eaXXNlfPK4NM7izC55IOG+EZW7LpEmsYZdpaGCskp9lmbHHIyJ84DNW1z gCAfGxf5gL27
VZqnZop82lKyaollFO6dkjIQW4JC1jbE5YsnDdcbty5H6Ie2AvdQtnxVsks8 N23njJfhGZsb
Yg6xP9VFxw+gL3CVrBG4tIJLxaw9Rzv/AE7FuvmHUNSHQ00I2aV9NVGJmPyI c5mEXG63qyHZ
uWKbRMsVEGihqXRiZr5qSXZ2iYYSPFDLNOZBOK18IQfRieI1LqcO/OtYHltj k0kgH+hUqpaT
R8cOm21cei2wMfTNY1wbGDC4F1wbHtBA8W+5XSAiIgIiICIiAiIgIiICIiAi IgIiICIiAiIg
++1TIK0fok3z5ffcvLl6iP0Ob50vvuXly6W7Ycq98/eXpcX7Ps+pD8NXCp4v 2fZ9SH4auFLe
G6+WtH5Sq+lHuNXUuWj8pVfSj3GqSqLhD4ri0lzRcdl3ALDSZaSSxxNxSvaw XtdxstKaV0sW
Jw3GwcNzvWFx1c4ir3XuSIm4QDnmXXA9th93qWL21jLVYzKxa4OaHNIIIuCO 1FSudNH47Wsj
DXB5/wAS+2+5ytbPP71bQSPlp2vkj1TnA+Le9u5Zp6sWzhbU1ckdVoqre+aG qpZXQjFI+OYH
CB2usd2Xb3Kc6QohVClNZT7Qd0WtbjOV9177l8zRV8TvyQkp36RopZHUmqig iyka4tIDT4xu
Tu3BZllwaTq6Z08DiaqndsgH555DY82m+4WufF7DmN47Y64Yl9ciIoNDGwyN kLGl7QQ1xGYB
32P2D7liaGKoidFPEyWN3ymPaHA+0FSIgwAALAWAWURAREQEREETKeCOaSaO GNsslsb2tAc6
2657VKiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICI iAiIgIiICIiA
iIgIiICIiCKfc32rRbz7m+1aIIaryI+kj99qmUNV5EfSR++1TIK5v6HN86b3 3Ly1epN/Qpvn
Te+5eWrpbthyr3z95elxfs+z6kPw1cKni/Z9n1Ifhq4Ut4br5a0flKr6Ue41 dD2NkYWvaHNO
8Fc9H5Sq+lHuNUs8jo4sTAC7EAATbeQP+6w0k3blBUUVPUSCSVhxgYQ5ri02 7rgi6khlbK0k
XBBs5p3tPcVy1Uv+IdG+QsjZGH5OLd5OZII3W/qsXmIjq1XOeiSPR9NG9rw1 5LTcYpXOF/YT
ZdSqW18kYaA58jQ4Ag0z8WG+efqH9u1WUUzJ4RJESWm4BII3G24rNLVmP4ra J8pEXyNOZ3/k
w2VrtIQTzagGolqS/Hie0EtGM239w3rq0jpCoqKWkbFI6GWKWN1Vqzax1gZg 9hOL7G+tdsdc
MPpEXz+iojVz1evj0gQZ5ma7a3COweQAGh9xYZfJG5dOgIAyKokMtRI7aJYx rZ3yANa8gWDi
ewb1CVui+Z0jNO6uliBqpWbexmqgmMbi3UXsDibYXz3hdNfRs1mjLProdbMI 3s2yQHDq3Gxs
+17gZ37N6LK9RVmnYB4FqXtknjfBA98bo53sIIabXIIv9t1qyZ1FLRUUEbpd ex0jpJqhxLQM
N83XJ+VuRFqioW/lE8sqDsYeYjHqyx7sMoe/CCC5jfbcXB71JJpqoiilElJE yaGbVSF051TB
gDg4vwXAsQM2jNBdIvno6+pirdJVMzBIGSRwQMZUuLbuDbC1gBcuuXZnszsu p+l6ljmwOoo9
qM4hLBP4mbC4OxYb2sO7/wAhboqXw1VOkaGUDCx9Q+mjcZ7Xe3FmRhybZpzz PqO9aVP5QPg0
e2o2VrpQ6RskAe5xGAkOLcLDcZbzhGYuQgvUVB4SqjLXmoia6niqYWRYJi1w xYLXs0ZeNc5n
u3Zrqi0tLJO07K0Ur53QMl1vj4m3Fy22Qu09pO7JBaoqOn07USwxyv0eQJqZ 1RC2OXG52G12
kYcvlC1r/fkrLR9UaylErtTckgiGUyNFuy5AN+8WyQdSIiAiIgIiICIiAiIg IiICIiAiIgIi
ICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgin3N9q0W8+5vtWiCGq8iPp I/faplDVeRH0
kfvtUyCub+hTfOm99y8tXqIeBSTDtxze+5eXXXW3bDlXvn7y9Li/Z9n1Ifhq 4VPF+z7PqQ/D
Vws28N18taPylV9KPcappo9bHgxFuYNx2WN/+yho/KVX0o9xqnlkbEwvdewI GQvvNlhojjbE
wMYLALjrNHuqKls0cwYcIaWuZiBsSQd47z/TuXa1zXtDmkFpzBCgnneJtVFh BDQ4ucL7yQAB
cdx7f/GL6zH8mq5ieiBuj5i4CWpa5naGRlpP24jZdzWta0NaA1oFgALABcra 1zQ0TQvBLg3E
C3DmbA779o/8rrO5SkUiP4rabT8uCHQ1FBDqWNmMXi2Y+okc1uEgiwLjbMDc pn6PpH668Lbz
SNkkIuC5zbYT9mEKu0Npna6RlRVV1HIZMAMdPGbxOduDjidbPLMDNdx0rSNE Li+TBMQGSal+
A3Nhd1rC53XOdwurDoggip2ubC3CHPc8i5PjONyfvKQU8VOxzYm4Q57nnMnx nG5P3lcbtOaP
Ero9c4ua5zLNiebvbvaLDN2W4Z9qy7TVA2OF+ueRMHGNrYnuc7CbOGEC9x2i 19/cVBl2h6J0
DYiyWzZNaHCd4fjta+O+I5G2/cp9jhwQNcHv2d2OMvkc4g2IuSTc5E71yDS8 W1SEyMNI2mjm
bI0El2JzhYd+4WAF7lSVOkW+B6qtprkwxPcGysc0hzQTYtNiP6J8L8y654Y6 iCSCZuKORpY4
XtcEWK1dSwuljlcy742OY03OTTa4/oFSS6bnhoaepjqaKuD5wyQ07CA1oYXO Hy3eNYf+F2Vu
lJItKUNLTtY+OZ3515v4oLXFtvbhP3etJRLFoWghaWshcQcA8aV7rBhxNAuc gD2DJST6MpZ9
bjErda4Pk1cz2Yjhw54SMrAZblx/k/pOTSUAlkraKZ5YHOhp22dET2O8c/2C zQaYMu37W1sY
pXvLS0Hxo2uc2/tu0/0SR2O0bSOimiMIwTkF4BIzAABHdYAWtbckWjaSIRhs biY5NaHPkc5x
fYtuSTc5G2f/AGXDQabvQMl0i3V1DpJGaqCN8h8VxByaCcsrncpNJacpqWhk lhlEkhp3TR2Y
57bWNi4jcCe8i6EcOxtBTNwWi+RM6dvjHJ7r3P8AyP3qCbQ1BO3DJC6xLycM r24sZu4GxzBP
YcluNJ02vZTue7XOAvaNxa0kXALrWB9RN8x3qGHSch0FT1z4mvmmYy0bcgXu IAF87C59aHyn
doujfJI90bryFhcNY7CS0gtNr2uMIz9SM0ZSR1ZqWxuEhcXW1ji0OO9wbfCC c8wL5nvWm0T0
MD59KVFOYhhAMULm4STYDe6+ZGeS3bpSkdUMgDpMbrb4XgNJFwHG1mm3YbHM d6ANGUjY4o2R
uYIYjFGWyOaWtNrgEG/YM96mpaWKki1UIcG3LiXvL3EntJJJP2rgrNPU1NC9 7WTvfG9jHRmC
RrrOda9i25G/PcSLbypjpSniEzpZrhsjWNY2B+MEtDg3DmXGxvkMh7Cg70Ve /TVAyOJ5leda
HFjWxPc44SA4YQLgi+YIuM+5b1NaG0cNXTlkkL3x3d3scQLj7wUHaipnaXmx 1rGxsuyRjKck
HxsTsGfscHbuyy6DpemgZeeR77yujDoqaQtBDsOE2Bzvl6+xBYouKTSlJFJN HK+SN0LHSOxx
PaC1u8tJFnWuN11zaQ07TU9BLNE5zpdS6WNroX2yvYuy8UEjIm1+xFwtkXJB XwzzGBuMytAL
yInYAbA2xWw3zGV7rrRBERAREQEREBERAREQEREBERAREQEREBERAREQEREB ERAREQEREBER
BFPub7Vot59zfatEENV5EfSR++1TKGq8iPpI/fapkFIcWrk7tZL+I5eaZr1I NBpZj/HL77l5
hZdrT/GHKvfP3l6XF+z7PqQ/DVwqeL9n2fUh+GrhYt4br5a0flKr6Ue41S1L XvitGAXBzSAT
bcQVFR+UqvpR7jV0kgC5NlhpHBFqWEE3c4lzuwXPcOxcOkIKp1Xjhjc+J8Ya 7A4BwsT3kb77
x3H2qzUM1Q2JwbhL32vhaRkO83IH/vqKx6lYtXEtVmYnoqm0LnuDfBzI7/53 tYQPsBurangZ
TQNhjFmt/wD9K0jraeSwEzGvJtgc4B1+6ynWfT9OtfhbWmflTw6Hqhotujai shkpQxsZDKcs
c5g3gnGd4yuAo59ASVEsD5qqKTUhgBfT3c3A692nF4pIsDYZ27Ny74NJComa 2KkqHQOcWtqb
N1Zt/qxWyte1l3Lr/bEq1misGp/PX1VW+p+TvxY/F39mPf6lxyaOq4NJU2yT BpO0yGV8Je1u
N7XYSAR67Z9ivlBS1TKqN742uAZI+Mg2zLXEH+oRVXL+TsctM+Ez3aYIohjY HZscXYiNxBJz
C6Y9F4dD1FB/hYtcx7b01PqmDELXw4jn9q743F8bXOjdGSLljrXb6jYkf1Wl XUMpKSapkDiy
FjnuDd5AF8kI+XGNH1MuzbXUwyGnlEjdXAWXGFzbG7jxb1pBoRkAgDZ3HVVG uu5tyW4S1rPY
AR93rXRW6SgoY6eSYPwzyNjaQB4pIJufVks1WkYKWtpKSQPMtU5wZhFwLC5J 7kTw30dS7Do+
npcePUsDMVrXt22XH4EYTGXTO8SokmdZtsbXOxYD6r4fu9atVA2qY6tfSAO1 jI2yE9liSB7p
Tzk8OAaImhkbNS1bGTtfMbyQ42lsjsRFg4ZggZ3+xRz6ClNO+ClrdVHLTbPL jixlwF7OGYsf
GN949isaisbDURwCKSSWSN8jWstnhtcZkZ+MF0DMbrepFz5VDdBMZpQ1rNke XFrna6lD5GkA
DxH3GHIDsOa6I9FsGhotHPlcdUxrWytFiHNsQ4A3zBAKsFwz6RMdfskdHUTv DGyOdGWBrQSQ
L4nA9h3XT+kRyUFZU0xhrKyJ/jxuaY4Cz5Lg7O7je9vUon6Db4XfXM2UmRzX uMtMHyNIAHiP
uMOQHYc1bog+fg/Jt0MMzRUwiSQR+Oynw3cx+IOf413EnebhdUmiJXTPqGVT G1JnbO1xiuwE
R4CC3Fcgi/aLZfbbIgrabRZhqYah8+ORglx+JYPc8tJIzyAw7s/at4tGtZoR ujXSYgIdUXgW
7LXsu9YTwKuPQobJo95qC40gOPxANcTnc93jZrXwTVRyRugrIQxk0k2CWnLg XPcTfJ43AkD2
37rWFHUsraOGpiDgyVge0O3gHvU6Chd+ThdNVSOqIsU8c0eMQfnCH8TsXjYd wGWS6K/RM1SJ
mwVjYWz0+olDosZIF7EZix8Y9/2K2RDKug0dJFpLatdG2PDhLI4y0vNgLvOI h1rZZA+tWKIg
IiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiIIp9zfat FvPub7Voghqv
Ij6SP32qZQ1XkR9JH77VMgqwf8NN86X33LzBenf9NL8+X33LzFdLdsOVe+fv L0uL9n2fUh+G
rhU8X6gZ9SH4auFLeG6+WtH5Sq+lHuNW1aAac4m4m4m3Fr3GILWj8pVfSj3G rqWGkNK2RsVp
L7/FBzIHYCe3/wB9qrtI1WzV5BLWayJuFz8m5F18+21xl6x7VbrSSWOJuKV7 WC9ruNlj1K7R
jOGqziVHrmzFrI66SV+IFrGFhJINx2er2d6uYI5RTBk8mOQg4nAWUrXBzQ5p BBFwR2rKz6fp
6/M5W1s+FDS0lcx+jqcwzRij8R8zZgIpWBpA8UOuSThObcrHPvr6nQdT4Do6 OOgaXiFxkMYi
L2zWABLn3sN+bc8hZfSyV9HFg1tXAzG8sbikAxOBsQM8zfsQ6Qom1eyOrKcV J/cmRuPdf5N7
7l1ZfPmjfU6VrA2jL521EJbVFzbQ2ZGXbze5HcDfccl00+iJIaqGqbThs+3T PfJiF9U7HYXv
uzabd+dla0dZo+qkl2Koppnkh0mpe1x7gTb2W+xdaJ/T5yj0bNAKAVujtsbH TxxtbdjtnkBz
dZxAzuMxc+KoJtFV0tXpCYUhY+enqIyW6prJCbYLW8Y5DMvOR3WX1SIueuVZ pGhdWR0ETo8c
bJfzwuMmmN7T/Uhccejq501LPU2fNHUAFwcMomse0O9pLr29fqV+iJ4w+Ypd E1bIHMipNkqR
TPjlqNY0bTIQLOu0knO5u6xF/atH6IqZIqzZNHGgjkghaIg+O78LyXjIluYN s8jfPtX1SIZf
LnRFQKMx09NOxuzVMYZMYWkOeG4QBH4oBIP9bqaXQ0j5qmp2ZpqdogfDJcYm taIw+xvludfv
t25L6JFcj5d1M6HTVGJaPDUPrZHmqxtOtZheQN+LIECxAAtkrSTRxn06+qk1 zYhBG1jo53MB
cHOJBDSL7xvyXZFQ0kNS+pipYGTvvjlbGA53tO8roUjwT1fNz6Il2KVmwtkd PWSPmwtie8sx
OLCNZ4vaN+4E5XUXgKolo3iop8c7NHMihLnglszce43yIuLO9eXavqURc9c/ eXzdZoadsdZH
QwiKOaGEuawtGse15LxncXLbC5FjfNYh0PM2CKKGCeOKXFDOyYxNLYyQSQI/ FtkRYZ+MSvpU
RHzj9G1j6aN9XT7VhmaJafE062NjC0bzhPjHHYn+oUlLol+00L5qVohhEzmx OIcIcTmljfss
d2Qtl2K/RBR/k5o+poImMrYMU2qaBPdpwtFvze/sOeWR371eIiAiIgIiICIi AiIgIiICIiAi
IgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiCKfc32rRbz7m+1aIIaryI+ kj99qmUNV5Ef
SR++1TIKr/ppfny++5eYr0//AKaX58vvuXmC6W7Ycq98/eXpcf6gZ9SH4auF TR/qBn1Ifhq5
Ut4br5a0flKr6Ue41SVRcIfFcWkuaLjsu4BR0flKr6Ue41dD2NkYWvaHNO8F YaR00rpYsThu
Ng4bnesLjq5xFXuvckRNwgHPMuuB7bD7vUrHduUFRRU9RIJJWHGBhDmuLTbu uCLrHqVm0Yhq
sxE9VY500fjtayMNcHn/ABL7b7nK1s8/vVpFOTSa+oaIAAXOxOyaB2km1ss8 9y0j0fTRva8N
eS03GKVzhf2E2XUs+nS1fmVvaJ+Hyjq2jGj30c09NFt8s7tZM8NGpMh8YE77 g5ffuC66KqZH
+UFdCK+kY18rLQPzkk/NNsWnFu+w7l9Ai6sKH8kqoTaLgh26kndHC20UIs+P 1O8Y3+4K+RFZ
nIIiKAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgI iICIiAiIgIiI
CIiAiIgIiICIiAiIgIiIIp9zfatFvPub7VoghqvIj6SP32qZQ1XkR9JH77VM gqb/AJiUfxy+
+5eZL0235iU/xy++5eZLrbthyr3z95elR/qBn1Ifhq5VNH+oGfUh+GrlZt4b r5a0flKr6Ue4
1TyyxwROlle1kbBdznGwAUFH5Sq+lHuNW1dRU+kKcwVTC+MkGwcW5jdmCsNI NE6Ui0tDNNCx
7WRymMYt7sgb+res1Uv+IdG+QsjZGH5OLd5OZII3W/qpaGgptHQGGkj1bC7E RiLrnvuc+wKG
s0e6oqWzRzBhwhpa5mIGxJB3jvP9O5c/Ui01/i1XGeqBtfJGGgOfI0OAINM/ Fhvnn6h/btVl
DMyeISRElpuLkEbjY5FcbdHzFwEtS1zO0MjLSftxGy7TEwwmIAtYW4bMJbYb siN32LPpReO5
q+vhQHTMtBQyyFm0vFRUeIXPLgxrzuDWuyGQzsBlmrFulMUmqEIEuuDMJfbx MOLHu3W/rldZ
l0LQSwxxPhdgY1zBhleCQ75QcQbuucze66BRU4qdp1Q1ur1WK5+Te9rLs5y4 9FaWOkKmeF0I
YI2teyRpcWyNJIuC5rb7t4uM96tFx0WjKWgc51MxzSWhl3SOfZo3AYibAXOQ XYgIiICIiAiI
gIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiI gIiICIiAiIgI
iICIiAiIgin3N9q0W8+5vtVfPpWjpqrZpXyCawIaIXm4PrAsgnqvIj6SP32q ZQ1JvA0i+b4z
mLf52qZBV/8ASy/Pl99y8wXqA/RZfny++5eXrpbthyr3z95elR/qBn1Ifhq5 VNH+oGfUh+Gr
lS3huvlrR+UqvpR7jV1LidTsL3PvI0uNzhkc0HK24H1LGzM45+e/qsNO5Fw7 Mzjn57+qbMzj
n57+qDuUFZUClpnzFpcW2AaO0k2A+8hQbMzjn57+qbMzjn57+qDj2qp2jBtc hf4xAbGwRkt+
UATnl6yPb2rs0bNLM1xJc6Ows94scVhcDM9t/Ycs+xszOOfnv6pszOOfnv6q WjMxJHSMNNK6
QkotUIWNec5JAb5RttiI9eYst6vS9DRy6ueZwcGCQ4Y3ODWkkYiQDYZHM7k2 ZnHPz39U2ZnH
Pz39VQfpehjqzTOmdrQ9rHWjcWtc4AtBdawvcWuc0Ol6ITvh1jy9pc3KJ5a5 wFy0OtZzsjkC
TkU2ZnHPz39U2ZnHPz39UENNp2ml0VDXzRzxMkbdw1EjgzK5uQ3d/FuWo01F JNVxDFDs0zI9
Y+F7mvxYd2QzJdYZnv3Lo2ZnHPz39U2ZnHPz39VfI2ZpSjfV7M2V2sxFgOrc GFw3tDrYSRnk
DfI9y1otLUVfIGU0rnlzNY28bmhzcrkEgA2uL23JszOOfnv6pszOOfnv6qDu RcOzM45+e/qm
zM45+e/qg7kXDszOOfnv6pszOOfnv6oO5Fw7Mzjn57+qbMzjn57+qDuRcOzM 45+e/qmzM45+
e/qg7kXDszOOfnv6pszOOfnv6oO5Fw7Mzjn57+qbMzjn57+qDuRcOzM45+e/ qmzM45+e/qg7
kXDszOOfnv6pszOOfnv6oO5Fw7Mzjn57+qbMzjn57+qDuRcOzM45+e/qmzM4 5+e/qg7kXDsz
OOfnv6pszOOfnv6oO5Fw7Mzjn57+qbMzjn57+qDuRcOzM45+e/qmzM45+e/q g7kXDszOOfnv
6pszOOfnv6oO5Fw7Mzjn57+qbMzjn57+qDuRcOzM45+e/qmzM45+e/qg7kXD szOOfnv6pszO
Ofnv6oO5Fw7Mzjn57+qbMzjn57+qDuRcOzM45+e/qmzM45+e/qg7kXDszOOf nv6pszOOfnv6
oO5Fw7Mzjn57+qbMzjn57+qDuRcOzM45+e/qmzM45+e/qg7kXDszOOfnv6ps zOOfnv6oO5Fw
7Mzjn57+qbMzjn57+qDpm3N9qidHG57XuDS5nySd4UezM45+e/qmzM45+e/q gVfkR9JH77VM
odmjJF3SusQbOlcRcG4yJUyCsH6LL8+X33Ly9eoD9Em+fL77l5eulu2HKvfP 3l6VH+oWfUh+
GrlU0f6hZ9SH4auVLeG6iIiw0IiICIiAiIgIiICIiAiIgIiICIiAiIgIiICI iAiIgIiICIiA
iIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiA iIgrR+iTfPl9
9y8uXqI/Q5vnS++5eXLpbthyr3z95elR/qFn1Ifhq5VNH+oWfUh+GrlS3huo iIsNCIiAiIgI
iICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgI iICIiAiIgIiI
CIiAiIgIiICIiAiIgIiICIiAiIgIiIK0H/CTD+OX33Ly5emtJ2eb58vvuXmS 627Yca98/eXp
Uf6hZ9SH4auVTR/qFn1Ifhq5WbeHSoiIsNCIiAiIgIiICIiAiIgIiICIiAiI gIiICIiAiIgI
K1rf8JMf4pvfcvLl6m39Cm+dN77l5Yulu2HKvfP3l6VH+oWfUh+GrXXN4JeU 7oqmP9Qs+pD8
NXSlvDdUeubwS8p3RNc3gl5TuikRYaR65vBLyndE1zeCXlO6KREEeubwS8p3 RNc3gl5TuikR
BHrm8EvKd0TXN4JeU7opEQR65vBLyndE1zeCXlO6KREEeubwS8p3RNc3gl5T uikRBHrm8EvK
d0TXN4JeU7opEQR65vBLyndE1zeCXlO6KREEeubwS8p3RNc3gl5TuikRBHrm 8EvKd0TXN4Je
U7opEQR65vBLyndE1zeCXlO6KREEeubwS8p3RNc3gl5TuikRBHrm8EvKd0TX N4JeU7opEQR6
5vBLyndE1zeCXlO6KREEeubwS8p3RNc3gl5TuikRBHrm8EvKd0TXN4JeU7op EQR65vBLyndE
1zeCXlO6KREEeubwS8p3RNc3gl5TuikRBHrm8EvKd0TXN4JeU7opEQR65vBL yndE1zeCXlO6
KREEeubwS8p3RNc3gl5TuikRBHrm8EvKd0TXN4JeU7opEQR65vBLyndE1zeC XlO6KREEeubw
S8p3RNc3gl5TuikRBHrm8EvKd0TXN4JeU7opEQR65vBLyndE1zeCXlO6KREE eubwS8p3RNc3
gl5TuikRBHrm8EvKd0TXN4JeU7opEQR65vBLyndE1zeCXlO6KREEeubwS8p3 RNc3gl5TuikR
d0TXN4JeU7opEQVzDehmOebpd4t/ncvLV6ew/wCFmH8U3vuXmC6W7Ycq98/e XpMf6hZ9TH4a
ulSx/qJn1Mfhq6Ut4bqItXvEcbnuNmtBJ9irampqm+OW1DWiPWuEbWAMb6y7 efUFmIy1laIu
alnc8tY848cYkY8C2Jp9XYRkulQEREBERAREQEREBERAREQEREBaOka1wabl xF7AEn+i3WrP
LyfNb/dyDGtHDJy3dE1o4ZOW7opUQRa0cMnLd0TWjhk5builWLjFa4vvsgj1 o4ZOW7omtHDJ
y3dFo6ra2VzDG/C1waX5WBNrdt+0di6EEWtHDJy3dE1o4ZOW7otpJWxuYCD4 7sIt7Cf+y3QR
a0cMnLd0TWjhk5builRBEJWEkXIIFyHAjL7VzeFaPzjj6xG4j+y20n+jS/V5 f7Bb0bGGkiu1
vye5dK1jGZcr2ttFaovCtH5x/Kf0TwrR+cfyn9F14GcDfuTAzgb9yYp/aZ9T mPv5cnhWj84/
lP6J4Vo/OP5T+iOraZukxQOjIldGJA7CMJzOV+/xSfsUtLNDVRvfHHYMkfGc TRvaSD/ZMU/s
/wDk5j7+UXhWj84/lP6J4Vo/OP5T+i6J3QU8Ek0oa2ONpc44b2AzKyTCGB5w BptYkW37kxT+
zPqcx9/Lm8K0fnH8p/RPCtH5x/Kf0XXgZwN+5MDOBv3Jin9mfU5j7+XJ4Vo/ OP5T+ieFaPzj
h6zG4D+y68DOBv3KGsYwUktmt+T3KxFJnHVm1vUrEz0+/lOCCAQbg9q01rbk DE6xscLSf7KL
R/6vpvom/wBgpoPJf6ne8Vzno7xOWNaOGTlu6JrRwyct3RSooqLWjhk5buia 0cMnLd0W8sgi
ifI65DAXG3qWkcrngEwSMBP+Yt+/IoGtHDJy3dE1o4ZOW7opHEhpIaXEdg7V rJIIonSOBs1p
cQN6DXWjhk5buia0cMnLd0UgNwD3rKCLWjhk5buia0cMnLd0UqII2Pa8Xab5 2PqWktRHE8Mc
XF5F8LGFxt32AWzPKzfOHuhRsyr5/oo/7vQNrj83Uf7eTom1x+bqP9vJ0U90 ugg2uPzdR/t5
OibXH5uo/wBvJ0Ur5Gxsc97g1rRck7gFzUtcal+VJURxOF2SyBoa77L4h9oC CTa4/N1H+3k6
Jtcfm6j/AG8nRT3S6CDa4/N1H+3k6Jtcfm6j/bydFPiUNHVMrKSKpjDgyVoc 0O32Pegxtcfm
6j/bydE2uPzdR/t5Oinul0EUVRHK8saXB4F8L2Fpt32IUqgfnXwfRSf3Yp0F cxv+DmP8U3vu
Xlq9Raf8JMP45vfcvLrrpbthyr3z+P29KjH/AOAZ9SH4auVURj/9eZ9SH4at 1LeG6o6iIT08
sRNhIwt+8WVfWzx1DaWGqLY8MgMzHvwg2Hr+UL9g9StEWYnCzDmjdtFWJ2NI ijYWMJFsVyL5
d2QXSiKKIiICIiAiIgIiICIiAiIgIiIC1Z5eT5rf7uWy0Ie2UvYGuBABBNt1 +qCVFHjl82zm
HomOXzbOYeiDci4IuRftChpoXQBzSQ4HPH/mPt7/AG/0W+OXzbOYeiY5fNs5 h6IK2WSMVkv5
xjXaxpDjM3CLAXu2+/I9ikFNUOqJXtbq3Oa9uMYQM/knLM/au7HL5tnMPRMc vm2cw9EHHJTP
fDG2CDZnB9yfF4SL5H/yuyABsLQItUAPkZZfcmOXzbOYeiY5fNs5h6IJEUeO XzbOYeiY5fNs
5h6IOfSf6NN9Xl/sFHSvIpoxc7lPNE6oa9smFjXRuZ4pvv3n+i4W0mkI2hjX U5AyBLiP+y7U
mNcTLz+rFtotEZdmsPefvTWHvP3rl2fSXfTfzn4U2fSXfTfzn4VrFeWdr/8A mf8AP+q2vnpD
pWpFRXU8DxBGGOfM0OY8Oc4G179o9oKr2U82kqOF7gKiITTmWOlkhlAc51wf Hu05ewi/tX0W
z6S76b+c/Cmz6S76b+c/Cs615Xe//mf8/wCqeo0ZPUMqWOpS+KSJzY2SuaS2 TCPzhztdxyy3
Wv8A5iraJhGi2wRU0cILMOokAwgHfcNuD25dq22fSXfTfzn4U2fSXfTfzn4V cV5Ta/8A5n/P
+s0ED6On1RnfLnfPc31NHY3uBJsunWHvP3rl2fSXfTfzn4U2fSXfTfzn4VcV 5Nr/APmf8/66
tYe8/eoqp5NNILncotn0l30385+FaupNISNLHOpwDkSHE/8AZWNYnOWbbzWY 1n/P+u3R/wCr
qb6Jv9gpoPJf6ne8ViCMQwRxA3DGhoPsCwzWx3aGsc25IJcQczfuK88/L1x8 JkUeOXzbOYei
Y5fNs5h6KK0rbbFNdzW3YRdxAFyLbyoGNjk1Ip5BLgeHP/O48PikdpXVjl82 zmHomOXzbOYe
iDgbRPZTtDIgHmBzH2Izdla/9VtJTSF02CG5fGQXuDb3tYAG97e1duOXzbOY eiY5fNs5h6II
qen1FQ4tYGscxt7drs7/AG7s10qPHL5tnMPRMcvm2cw9EEiKPHL5tnMPRMcv m2cw9EGGeVm+
cPdC5nuLa2a3m4/7vXTG1wxOfbE43sNwyt/2UE8ExqDJEGODmBrmucW2sTYg 2PeUGNYe8/em
sPefvWmpqfMxc8/AmpqfMxc8/Ag0rYzV0U9Pjw62MsvvtcLlNVXy0ksRoSyY RkAve10b3W3D
O5B9YC7dTU+Zi55+BNTU+Zi55+BB8/S6KlwMikpnCn2sSmOTVjxdWQbtZ4u/ sG/tUooZY4oY
5aLaqWKSYClBYQAXXY6ziBYC4t2XV3qanzMXPPwJqanzMXPPwIKU0Mx05tUk U5biaYnx6q0b
cIBab+MBe+TTY39qstEslptF0sEoLZI42tcL3sbLo1NT5mLnn4E1NT5mLnn4 EG+sPefvTWHv
P3rTU1PmYuefgTU1PmYuefgQbMcXVsN/Nyf3YuxcsEEwqBJKGNDWFrWtcXXu Rck2HcF1IKnF
anlH8cvvuXmF16bh/MSn+OX33LzGy6W7Ycq98/j9vUIv2dZ9SH4atlV6PwVO hYYw7IwCJxHY
cOErpvV+fh5B+NJiZaiYh1ouJ76tv76HkH41EaqqH72HkH41nWV2hZIqk11U D5WHkH41sysq
nfvYeQfjTWVzC0RVMlfUs/ew8g/GtRpKoP72LkH401lNoXCKnOk5x++h5B+N Y8Jz+eh5B+NN
ZNoXKKnGk5z++i5B+NZ8Iz+ei5B+NNZNoW6KqbXVDt00PIPxrfaqq19dDyD8 aaybQskVQ/SF
S021sPIPxreOsqX/AL2HkH41dLG8LRFVPrqhm+aHkH41gaQnP76HkH41NZNo WyKpOkJx++h5
B+Na+Ep/PQ8g/Gmsm0LhFUjSE5/fQ8g/GpG1dS7dNDyD8aaybQskVYauqH76 HkH41rttTfys
PIPxprJtC1RVu1VVr66HkH41E7SFQD5aHkH401ldoW6KoGkZz++h5B+NZOkK gfvoeQfjTWU2
hbIqgaRn89DyD8aHSM4/fQ8g/Gmsm0LdFTjSU5/fQ8g/GtvCE/noeQfjTWTa Fsiq21lS7dND
yD8aSVlUweVh5B+NNJNoWiKm8JVPnYeQfjUjK2qcL62HkH41dLG8LVFWbZU+ eh5B+NYNdUD9
9DyD8amsm0LRFVbfP56LkH40NfP56HkH401k2haoqjwjP56HkH41KyrqH7po eQfjTWTaFkir
XVVSP30PIPxoKupP76HkH401k2hZIq/X1XnoeQfjQVFV56HkH401k2hYIuDX VVvLQ8g/GtHV
VS399DyD8amsrmFkirW1NW799DyD8aw6rqW75oeQfjSImTMLNFViun8/DyD8 abbUefh5B+NX
WTaFoiqzW1A/fQ8g/GtmVdS7dNDyD8aaybQskVeZqofvoeQfjWu01fnoeQfj TWU2hZIq4VFU
R5aHkH41o6sqWm2uh5B+NNZNoWiKsFZUn99DyD8abZUefh5B+NNZXaFmiq9t qPPw8g/GsbdU
eeh5B+NNZNoWqKrFbUefh5B+NbNqql26eHkH401k2hZIq909UBfXQ8g/GtBV VZNtdDyD8amJ
NoWaLhEtWRfXQ8g/Gon1dU0210PIPxq6ybQs0VYKup89DyD8aztdR5+HkH40 1k2hoB/hZT/H
L77l5gvTJJ2QUcmN4sA9znWsLkkn+6808Tzsf8y1bpEOdetp/H7fR6QrKjR8 pNJK6LFmQN33
Lh/+QaV9Nf8AcOiIpFpjy1NKzPWGHflBpU76x/3DotPD2k/Snfyt6Iiu1uU9 unDU6d0l6Sf5
G9Fkad0l6Uf5G9ERTa3J7dOB2nNJHfUk/wChvRa+G9I+kf8ABvRETa3J7dOG p03pD0gctvRP
DekPPjlt6Iiu1uT26cHhrSHnxy29Fnw3pH0j/g3oiJtbk9unDI05pEbqn/g3 opPDuk7fpTv5
W9ERNrcnt04aO05pE76n/g3otm6d0kN1UR/pb0RE2tynt04hq/TmkjvqSfax vRajTekfSP8A
g3oiJtblfbpwHTekfSP+Deix4b0h6QOW3oiJtbk9unDI03pH0j/g3ot26d0k N1UR/pb0RE2t
ye3Thk6d0n6Uf5W9Fr4d0l6Sf5G9ERSbW5Pbpw28PaTt+lH+VvRaHTmkTvqf +DeiIkWtye3T
hr4b0j6R/wDW3os+HNI2/SP+DeiIrtbk9unDHhvSPpH/ANbeiHTekPSBy29E RTa3J7dODw3p
D0j/AOtvRZ8OaR9I/wCDeiIrtbk9unDZundJDdUkf6G9Fs7TukyM6on/AEt6 IibW5Pbpwi8O
aRv+kf8A1t6KRundJAZVJH+hvREVm1uU9unAdO6S9KP8jei18OaS9J/4N6Ii m1uV9unDHhzS
PpH/AAb0Tw5pH0j/AIN6IibW5PbpweG9I+kf8G9FuzTukhuqiPYxvRETa3J7 dOGx07pP0p38
reiwNO6T9KP8reiIm1uT26cNvD2lPS3fyjonh7Sfpbv5W9ERNrcnt04PD+lP S3fyjotDp7Sd
/wBKP8reiIptbk9unDZuntJjdVu/lb0Wr9PaTO+qJ9rW9ERNrcnt04aeHNJe k/8ABvRBp3SX
pP8Awb0RE2tye3Thnw7pL0k/yN6LZuntJjdVEf6W9ERXa3J7dOGx0/pT0t38 o6LHh/Snpbv5
W9ERNrcnt04Z8P6Ut+lu/lb0Wh07pM76o/yN6IibW5PbpweHdJelH+RvRa+H dJekn+RvREU2
tye3Tg8O6S9J/wCDeieHdJek/wDBvREV2tye3Tg8O6S9J/4N6LZuntJjdVEf 6G9ERTa3J7dO
G/h/Slv0t38rei1GntJ3/Snfyt6IibTye3Thv/8AINK2/TH/AHDotDp7SZOd Uf5W9ERNrcnt
04YOntJ+lH+RvRYOntJ+lH+RvRETa3J7dOGYdI1ddOyKpmL47E4bAA7u5UNh 3Ii53mcvR6NY
iJxD/9k=
name="screenshot02.jpg"
Content-Disposition: inline;
filename="screenshot02.jpg"
CAJjAjkDASIAAhEBAxEB/8QAGwABAAIDAQEAAAAAAAAAAAAAAAMEAQIFBwb/ xABPEAABAwIB
BwULCAgFBAIDAAAAAQIDBBGTBRITFCHR0jFRUlSyFSIzNEFTYXN0krMyNTZx coGRlAYjQkNi
oaKxJERkgsEWo8LwJmMlg/H/xAAZAQEBAQEBAQAAAAAAAAAAAAAAAgEDBAX/ xAAoEQEAAgIB
AwMFAQEBAQAAAAAAAQIRElETMkEhMfADIoGRwWHhBKH/2gAMAwEAAhEDEQA/ APo8m5Op5aSO
oqYmTyzNR6rImciIu1ERF5Nha7m0HUaXBbuM5M+aqP2ePsoc/Kc73tljRFvd URUa5bfgh1rG
U+66/J1D5KGlwW7jVuTqLqVLgN3Hz2TZKumylC1HuWJ70a5qxyW27PK2x38t o/uTMkcr4nOz
Wo+N1nNu5Euii8ashL3NoupU2C3cZ7nUPUqbBbuOU7KslNVRpVrJn0kE2nYz 95m5ma5E8t0X
ZzXVOcs02XJXqms0L4GZ7WukdntaiKi2VM9jVVboiKlv2k2kZhuFzubQ9Sps Fu4dzaLqVNgt
3EWTMrd0HsYlOsTsxz5Gud30ffWaipbypdfuKtJny5ar1fHWvSOfNZIlQqRM TRtWysz9u1V/
ZXlNML/c6i6lTYLdw7nUXUqbBbuOBQ11Yv6PJRPqHOr5WN0UyqquzHtV2f8A W1Een+1OcmoX
y1GUIElZXVCJR077xVKsaxy513OTPTOvZPIvIbyT6Ox3OoupU2C3cO51F1Km wW7inlp7EyjR
RzPq0hdHKqtpVlzlVMyyqke3yr6DSHKlVSRaGqplkdTUzJZpFkRHKrs5ESyJ ZVu1PKibV++c
kxhe7nUXUqbBbuHc+i6lTYLdxVqsoSxsdDW0qRyXjc1IahyoqK9G/Ks1UVFX ktZfxIm/pB+v
lV1FNqsekvMjH7MxFuq3ajbLZUSzl8mzltuYMSvrk+i6lTYLdxqtBRdSpcFu 4rVtXlRkNO9t
NTRrJOxubrCrdq+Re82fdc6LuTaI9WK2o0PUqXBbuNkoKDqVLgt3GXONUkUv Cctu59B1KlwW
7h3PoOpUuC3cZSRQsijBlr3PoepUuC3cO59D1KlwW7iRj1UzI6yDBlDqFD1K lwW7jGoUPUqX
BbuM6RQr1sVqzLXUaHqVLgt3GNRoupUuC3cFkU2jcqqNTLXUaPqVLgN3GNRo +pUuA3cWAZiD
Mq+pUfUqXAbuMalR9TpcBu4sGBiDMq+p0nU6XAZuGp0nU6XAZuJzAxBmUOp0 nU6XAZuManSd
TpcBm4nAxBmUSUdH1KlwG7jZKKi6lS4LdxuZRRiDMtUoKLqVLgt3GdQoupUu C3cSIpuijEGZ
QahRdSpcFu4ahRdSpcFu4sAYgzKvqFF1KlwW7hqFF1KlwW7iwBiDMq+oUXUq XBbuHc+i6lS4
LdxYAxBmVfufQ9SpcFu4dz6HqVLgt3FgDEGZQdz6HqVLgt3DufQ9SpcFu4sA zEGZV+59D1Gl
wW7h3Poeo0uC3cWAMQ3KDufQ9RpcFu4dzqHqNLgt3FgDEGVfudQ9RpcFu4dz qHqNLgt3FkDE
GVfudQ9RpcFu4dzqDqNLgt3FgyZhuVbudQdRpcFu4dzqDqNLgt3FkDBlQqMn 0LZqW1HTIiyq
i2ibtTMevN6EJ+5+T+o0uC3caZQumrKi2tNy/Wx6J/NSBc/SIsiSvZZdjHWW +y3lT0k4bErX
c/J/UaXBbuI6igoEjbaipkXSMTZC3pJ6CGRWrG5I4qlr7LmqsuxF8n7Qk0ma 26r4Rnl/jaMN
SVFJRRuiZFk6jfJK/Najo2tT5KrtXNXm5ivFHSTSJHFR5FkevI1srVVfuzDM umbLBKjHyaN6
uVqKl/kuTyr6SCBj4HQroq57YfkNcsVk2KnkXmUYIWJaaglyS+oZQ0zFdAr0 tE26d7flsQPZ
SJI5NUpdiqngGbjSVksWRZI3KqKymc1UvzMOVPHPrMtpH2z18vpOX1Jmr0/Q pFs5dZ6UjY3O
SipXKiKqNSBm3+RsynR7WPZk/J7o3sV6TI1ujaicucqtui+i39ltxtHU5q2e 5V8m0uxysZSL
SLTzPhk76V6uRHq/ZZUS9tlk/wDeWKWz7uv1fp641j/4sxapJGj1oqRL3/cN /Ha1P7GytpOq
UuAzccjR1Fvlv+9bGixVKrZHv/EjecunRph2m5Np58lySRxsimbJKrXsS3I9 1kW3KlksfMd2
H9NT6/JqOTIb86986df+4881uerHpEvm5++YerZL+aqL2ePsoVcqZEhyjdVk WJ/SRLk1HIsO
QIJUS6x0jXIi+WzEUt6vV9YgwHcZUWwyM+HByV+i1Pk2rSqlndUSt+Rduajf Ta6naljjqIli
lbnMVUVUvbkW/wDwbrTVa/5inwHcZqlJVp/mKfAdxi1tvcxKOahpKip1iaBr 5ViWFXL5WLyo
vOaLkujdRyUkjJZYJLZzJZ3ycnJZXKqp9xZ1ar6xBgO4xq1X1iDAdxk5hvq1 hpKenqJ6iGJG
Sz5ukcn7Vksn8iNMn0zat9S3TNke7OejZ3o1y2RLq2+auxE8hNq9X1iDAdxj VqvrEGA7jNzB
iUMdBSRrErIURYYlhYt12MW10/khvT0tPTPzoWZrtG2K+cq962+am3mupvq1 X1iDAdxjVqvr
EGC7jGYMSw6ON9RHO5t5Y2ua1112Itr/ANkNH01PI+Z0kSPWdiRyZ21HNS9k tyftL+JvqtV1
iDBdxjVarrEGC7jGYPVzajJSIxsVK1Ea97Fllmne96NY5HIjc6902LsuiJe+ 0tMoaWOZ8rWv
TSXVzNK7Rrfl7y+bt+osLSVS/wCYgwXcZjU6rrEGC7jGYPVUTJlI2mWnRJtH dqoi1EiqxU5M
1Vddv3WLTl2WM6nVdYgwXcY1Op8/Bgu4zcwzEolbc1zEJ9TqesQYLuMalU+f gwXcY2hmsoUQ
2RqKb6lU+fgwXcZnU6nrEGC7jN3g1lq1ljLm3Q21Wq6xBgu4xqtV1iDBdxje DWUWiMLHsJtV
qusQYLuMapVdYgwXcZu8M0lXSI2bHYm1Sq6xBgu4xqlV1iDBdxjqQaSjMEmp 1XWIMF3GNTqe
sQYLuMzeG6yjMEup1Pn4MF3GNSqfPwYLuMbwayhBLqVT5+DBdxjUqnz8GC7j G8GsoTBPqNT5
+DBdxjUajz8GC7jG8GsoAT6jUefgwXcZjUKjz8GC7jG8GsokU3RTfUajz8GC 7jGpVPn4MF3G
N4NZEUyNTqusQYLuMzqlV1iDBdxjeDWWAZ1Wq6xBgu4xqtV1iDBdxjeDWWAZ 1Wq6xBgu4xqt
V1iDBdxjeDWWAZ1Wq6xBgu4xqtV1iDBdxjeDWWDI1Wq6xBgu4xqtV1iDBdxj eDWQDVarrEGC
7jGq1XWIMF3GNoNZDJjVarrEGA7jGq1XWIMB3GNoNZZA1Wr6xBgO4xq1X1iD AdxmbQayyDGr
VfWIMB3GNWq+sQYDuMbQay2Brq1X1iDAdxjVqvrEGA7jG0N1kljZNGscrEex eVFTYQ6lD0p/
zEnETavV9YgwHcY1er6xBgO4zMwYlDqUPSn/ADEnEFoYHbHLOu2+2ok4ibV6 vrEGA7jGr1fW
IMB3GMwYlFqUPSn/ADEnENSh6U/5iTiJtXq+sQYDuMavV9YgwHcYzBiVaTJ8 EjHMdpnNcllR
aiTanvEfculvtSf8zLxF3V6vrEGA7jMLTVa/5iDAdxmfa2No9lPuZS//AH/m ZeIdzKX/AO/8
zJxFzVavrEGA7jGq1XWIMB3GPt4bm3Kp3MpV8/8AmZeIx3KpOaZfQtRIv/kW 9Wqk/wAxBgu4
zVYqlOSogX/9DuMYrwZty1mY1lHIxjUa1saojUSyIluQ8nPVc90tDK59s5Ek atksi2VU/wCD
ykq3tDnXun5y9Ri+jLPYk+Gdo4kX0ZZ7Enwzo5UbA/JVY2re6OndA9JXt5Ws zVuqbF8noJl0
hrBlbJtTM2GnyhSTSu+SyOZrnL5diIpcPk7pS0mQo65IK/J7padlHNEj4ZGS Zq5jnNVVRyWt
5U5V2KV58s5YezKlTTvkbqla6GNHLAymRrXNSz1eqPuqKvIvKqWsS19gyeGS aSFksbpYraRj
XIrmX2pdPJckPico5QnyXXfpdWUqtSaNKRGq5L2u3Nvb0XL3dLKlFUV6SrI6 KHJ76hjKx0Gl
SRqr+zEvyF518qcqAfUA+RrHVUv6LpPPlt2fV5OfI6nkjiRZF0aOXMsiKltq L8rYvkWynUyZ
MtD+hdNUOkc5YaBJc5zUdazL2slr25OVOTl8oHaI3zwxzRwvljbLLfRsc5Ec +21bJ5bHyuSs
pZYblHIbK2dssOUoHvVFc1eRiORURI25v1Xdy+i5r+m2uJljIj8n7aqLTysb t7/Na1yt2bVu
iKlvLewH1j54Y5o4Xyxtllvo2OciOfbatk8tiQ+DpcpTZZ/TXJGUkbJHQv00 VMyRFRy5sd3u
VLqm1XWui/s2XkLVHlnKT8mZGyo+rc9a+vSCSnWNmjaxznp3tkztlktdy+m4 H1088NNC6aol
jhib8p8jka1PJtVSQ8//AEkrKuv/AEfyzLNX6KODKC0rKZGMzZGtVtkRVTOz v2uXyLstydTK
OU8qSZVyzT0sk7GUMTFiWHQIxquYrs6RZNtr9HyIB9Rp4dY1fSx6fMz9HnJn Zt7Xty2vsuNP
DrGr6WPT5mfo85M7Nva9uW19lz5vJ80lR+mVNNNo0lkyIx79Gt23WRFWyoq3 T71I8sTyU36V
V1RC7NliyFI9jrXsqPVUXaB9YD4VuVMtJGjXZVcqrkjukr9BHfO76zE2WRNr bqqKq5uy1y9D
lOvyjlzJtN3R1KKpyYyqcyKNiq+Rb3RqvRbc/l2NX6wPrAfH5Py3lHKNP+js TqjQvr9Pp5Ym
Nzl0aLa2ciol+Vdn1WI5ssZVfQ6GKt0c6ZbXJ6VCxNc5Y9tlVLWvtTkROQD7 QHwdVU1eRqz9
K6uCqklnhZStR0rWLdXIiZyoiIl0RVt5OdFOlJlDKtLJlJj5JWsjyc+oj1p0 CzNkbeyo2Nfk
/WnKn4h9UDm/o86qkyJSz1tU6pmnjbKrlY1mbnIio1ERPJ/7zJ0gAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAABFNUwwIqyyNbZL28v4ASgoNrm1j9HRy pmol3yZq97zI
l/Kv/BurJU/zz/dZuIm8NwuFeqq2UuZnNe5X8iNt/wAkLllYiqlcjlTkR6Ns v12KNdlKnlWB
zXWVucjmqnIuzYVS0WnDYqxWZYnhlR0UTljcqNRHo3Yq7OcljyykEF6tkmcl 1VUzVRE+5dpx
8o11O9rLSsukjVtfyXQgrquB9NIkcrXKrVRERbnp6cTEL1/x9grs5LouxTUx FtiZ9lDJyhxl
RZ4hN9qbtuPKz1RniE32pu248rNn2hzjun8f16hF9GWexJ8M7ZxYvoyz2JPh naJlcKcGScm0
0zZqfJ9JDK35L44Wtcnk2KiGz8m0ElUlVJRUz6hFR2ldE1X3TkW9r7LIWivF W0k1Q+niqoZJ
4/lxtkRXN+tOVCVNlpKZXTuWniVahEbMuYn6xES1nc+zZtNaSgo6LP1Okgp8 +2doo0ZnW5L2
+tSwAKtLk2go5FkpKKmgeqZquiia1VTmuiegmgghpoWw08UcMTfksjajWp5d iISGAKUeRclR
SNkjyZRsexUc1zYGorVTkVFsWnwQyTRzPijdLFfRvc1Fcy+xbL5LmY5GSxtk ie17HJdrmrdF
T0KbAQR0FHDodFSQM0Gdos2NE0ed8rN5r+WxqzJtBHVLVR0VMyoVVdpWxNR9 15Vva+26maXK
FFWOc2kq4J3M+UkUiOVPrspZApz5JybUzOmqMn0k0rvlPkha5y+TaqobVWTa CskSSroqad6J
mo6WJrlROa6p6S0AI9BDrGsaKPT5mZpM1M7Nve1+W19tjWSkppZHSSU8T3vj WJznMRVcxeVq
rzejkJgBX1Cj6pB4LQeDTwfQ+z6OQ5836O0c+WWVs0UEkEdIlMymfCitbZ10 cl9ibNlrHVkk
ZE3Oke1jbol3LZLqtk/mZkeyKN0kjmsY1FVznLZETnVQIZqCjnp2U81JBJBH bMjfGitbZLJZ
F2Js2BtBRthihbSQJFC/PjYkaZrHct0TyLtXanOSuljbmZ0jU0i2ZdflLa9k 59iKbgQyUlNL
I6SSnie98axOc5iKrmLytVeb0chHDk2gp45Y4KKmiZMmbI1kTWo9NuxURNvK v4loAaxxsijb
HGxrGMRGta1LI1E5ERDY0jkZIirG9r0RVaqtW9lRbKhuABhVREVVWyJ5SJ1V TtjbI6oiRjmq
9rlellaiXVUXmttuBMCJ1RCyn075Y2wo3O0iuRG2578ljZksciuRkjXKxbOR q3tsvt+5UUDc
EE1ZS08scU9TDFJKto2PejVevoReUlkeyKN0kjmsY1FVznLZETnVQNgYRUVL ot0UyAAAAA1c
9jM3Pc1ucual1tdeYDYESzwtSRVljRIvCKrk7zZfbzbFQjWvo0mlhWrgSWFq vkZpEzmNTyql
9iAWQVoMoUVRDJNBWU8sUe172Stc1vl2qi7CwioqXRbooGQAAAAAAAAAAAAA AAAAAAAAAAAA
AKWUoo9VkkViK5Vaiqv1oXSnlRbUEn1t7SGx7hZjHORrWt27bJYrvq6Rrla6 WK6LZUumwjyk
+0aol89X5rE53LsT7vL9xbgiipaaOLyNS31nD6f04vEzKrW19FVamgd8p0K/ WiFStmpv1egW
O226NsnMVFypXySz6OZjWRyOaiKxPIdTJdbJU5Nhmlsr3XutrftKn/B6a/8A nik7OUfXy41W
9r42I2y2kauz0KhBWyOdA9GNVVVq2sfVaUw6dGNVzls1qXVTvFv8b1mYKiOS NEje1ytREWy8
hvnKVaeDOVKmTOSV65ypfkTyJ+BZOWMGVSPxCb7U3bceWHqcfiE32pu248sM n2hEd0/j+vUY
voyz2JPhnaOLF9GWexJ8M7RMukKuU2TPyZVMplVJnRORllst7bLKc1+U6BuR Z0ybNC2empnu
ZE1Ez4VRq8reVtl50O4CVcPma2ur6aup6dcoQxM0TZEkqZGRJM5XLdvyFRbJ ZLIrV28q8pWr
8oVNY/KdNHVO0K01QmizmOkYrLJZWozvUXbyq5VRb7D68Bkej5WfKdTHPSRU +U6dtPoWvZNP
MxiTrnKipdGKjrWRLNVq7eXm6GUkzf0jybI+rdC10crEb3iNc67O92pe68yL fZs8p2gJ9SPR
8nk6pr6HJdJopVqNJk+SSOFY0s1zEbm2ttW99t1W/ktyHT/R6rmqqeZ01dT1 drKixTNkVt05
HZrGW+q1+XadkCfXJL5XJOUpI/0aZoa+klfFFGitib39Oy6I5z0zlvZNvInI WqivaxKRrcuZ
tJIkiurrxLd6Wsy+bmJyu8l+9PoAJ9R86ldlN6SSI92khye2dIEiRNJIuem1 LZycibEW5a/R
6rmqqeV01dT1dlRWrFM2RW3TkdmsZb6rX5dp2AB81QzZSqW5PSTKciLWUzpX K2KNFYrc22bd
F5c7be/osRuyvUyU0EktclI91GyWJqMausyre7bKiqvI3vW2XvvqPqQGvlsr VskkskM9YkMj
Z6dGUea3v2q5iq7kzl2qqXRbbLcpFVZQrJ0ytFPVU7WtiqGaqsqJIjUauaqM zEdtSy3zlSy8
nN9cAROHDy49I6fJb3VCUzUqG3mVE7xNG/bt2feuw59dlmqiyZG6KttKumdF O9WMbO1q2b+w
7OVbpZGol0ut0PrAGR4fOzZUqY6ysbHUJUTNgdJDTRKxzW2Yi9+22ei35Nqo t/IQU+VKhaNr
psr02hfM1r6mKVkiworVWyrmNa26oibWryr6D6kAcHJk80X6O1tRT/4iZslQ +PvflrnuVNic
/MV1yjUatMtFlTXGIsCJUKxi5jnSI1ze9REXZ5OVL8u1D6YAc3Js8rX18NVU LM2mlRElkRrV
zVY122yImy67bHFlc1lFlFZGuZHUUcrqLOXkZZVc1Oa+x31Kifsn1gDYnD5L KEb3ZHqsluY7
Q08D6jOVNiszVVjb+h1/uZ6To5KrKWLKldTy1MLJ5JY8yNz0Rzv1TOROVTuA 3LPDh5VqIqHK
KzRzwuqJWsjfRyfKmbnLbM8t++XyKn1cpWrKxaiiyuyeuzahkM7Uoe8TNaiL mutbOW6WW97b
T6UGNifXL5qprcoUEFVG2o0ytghla97EakSOcrXLsRe9REvtR1vLczS1VfVy UlO3KkSpI2ZX
TUzmTKuarLd9mI26Zy/s8np2n0gEsj0fNU+U6uKCnqqmokmZUUUk7o2RtTMc 3N+Rs/iX5SqX
P0eraiqgqtPUR1OiksyRj2vRUVqL8pGtRdqryIdkAfLRZWq1opZo6/TTpRyy zRZjP8LIiXRN
iXTbdLOuq29CnWrI5e4ivdI+eaJGzo5URFVWqjrWRETyW3nTAHyzLyVEFkcr crvSVVt+yxyu
27PKyybeYxW1EUNNlCipp4aqJ0NTIrW+EpnWVVzvQqqqbURfr8n1QH+NifXL 5fKM1PW089RR
SRzNjydMyaWJUc3aiZrVcnl2KtvJ9+3vZPrKWsp2rS1MM6MREcsT0dZbci2L QNZwAAwAAAAA
AAAAAAAAAAAAAAAAAAAClldbZOk+tvaQunOy8rkyROrEu9M1U95Cq+swyfZU z0kynLMu1lMq
tanO9eX8E2fibumVy3Vbqc2OqhjibGkjnW2q5Wr3zl2qv4mdch6S+6p6afSi sYhwtabTlUny
V/i2aOrmYlRK5XI1bW71zv8AguLJ3HoYIGsdL3ytS65qrdVXm9JXqJaeokp2 vRHsR6qqOaqp
8hxXq4YnJG6ijijkY+6/q1S6fchcxn3c8Y9nSpcpunqNC+BYlzVddX3/AOCx nazUMg/YTv5P
qTkT71/spw4FnbVaeoWOyRq2zGv/AOUO1kyKTQrI5qo+Vc5b+RPIn/vOpFvt h0pEz7uorkF7
mrY7cu1TY4OyrGl8nTfam7bjys9Vi+bpvtTdtx5UJ9oRHdP4/r1GL6Ms9iT4 Z2jixfRlnsSf
DOprMfRlwn7iZdITAh1mPoy4T9w1mPoy4T9xLUwIdZj6MuE/cNZj6MuE/cBM CHWY+jLhP3DW
Y+jLhP3ATAh1mPoy4T9w1mPoy4T9wEwIdZj6MuE/cNZj6MuE/cBMCHWY+jLh P3DWY+jLhP3A
TAh1mPoy4T9w1mPoy4T9wEwIdZj6MuE/cNZj6MuE/cBMCHWY+jLhP3DWY+jL hP3ATAh1mPoy
4T9w1mPoy4T9wEwIdZj6MuE/cNZj6MuE/cBMCHWY+jLhP3DWY+jLhP3ATAh1 mPoy4T9w1mPo
y4T9wEwIdZj6MuE/cNZj6MuE/cBMCHWY+jLhP3DWY+jLhP3ATAh1mPoy4T9w 1mPoy4T9wEwI
dZj6MuE/cNZj6MuE/cBMCHWY+jLhP3DWY+jLhP3ATAh1mPoy4T9w1mPoy4T9 wEwIdZj6MuE/
cNZj6MuE/cBMCHWY+jLhP3DWY+jLhP3ATAh1mPoy4T9w1mPoy4T9wEwIdZj6 MuE/cNZj6MuE
/cBMCHWY+jLhP3DWY+jLhP3ATAh1mPoy4T9w1mPoy4T9wEwIdZj6MuE/cNZj 6MuE/cBMCHWY
+jLhP3DWY+jLhP3ATAh1mPoy4T9w1mPoy4T9wEwIdZj6MuE/cNZj6MuE/cBM YW3lItZj6MuE
/cY1lnRlwn7gJFROZDConMhHrLOjLhO3GNYZ0ZcJ240VMpRTLNSTU8OlWGRX OajkbdFaqeX6
zjfpBPLIlK2ppVp2LJ8pZGrf8D6NZ29CXCduIKmOlq2tbUUzpUat0R0Llt/I 2s4nLnaszE4f
O5F0Lctxshej2rG5Vs6+0+pUpwUlDTSaSCjWN/JnNgci/wBiwsqdCXCduKtb M5KVmsYlspg1
WVOhLhO3GNJ/BLhO3DMKQxfN032pu248qPVYduTZl2ptm5Ut+248qE+0Ijun 8f16jF9GWexJ
8M6RzYvowz2JPhnSJl0gBVXKEKZUTJ6o5Jli0qLbvVS6pb69imIMoQz5QqaK NH6SnRqvVU73
vvIiktWwCGlqWVUb3xo5EZI6Nc7naqov9gJgV2VbZH1LGMe59O5GuTZ3yq1H bNvpTlsZoapt
dRRVTGPjZK3Oa19r2+5VQCcAAACOnnjqYI54XZ0cjUc11lS6feBIAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApR/ N8/2pu248pPV
o/m+f7U3bceUnSe2HKO+fx/XqMX0YZ7EnwzpHOi+jDPYk+GdEiXSHIrqKpky jNVwRor44Y1h
VXIiOe1z7t9F0da/pKs2SapEnRrNJnwxaSzkTTOSRzpG/ei227Ntj6EGKy+e XJ0mgu3JtqVa
hHrQZzNrc23JfM+VZ1r22X5StLkaqfTQMkpZVhbLO51PEsT3JnOuxf1l2rZL pzpf6z6oBjl0
Ub6FtfPO1zY1zXosj25yo2JqKqreyLdF9H3HHpMmOrsl6XQslcmT2xQOSVrk SVqv2tVFVLot
rL5L/WfWAEej5nKeTtUhqVip0ZDKlMioxyNz5El75dnlsqbSRcmy6FVbk7Np VqUkWguzvm5l
uS+Z8qzrXtsvyn0EkbJW5sjGvbdFs5LpdFun8zYDgw5H0stIlVRxrTMbMuhk s5sWc5qsbbk2
Ii8l0T8CiuRZlydQQOoZGxwtc2aGFIFVz7JaSz7tXkXbsdt+s+sAHz78k50d bJLSSyvkdFme
DdI5qNZdFzlzbXbtTy2+ov5Kgki2y0UdO9YY2qsSojVtnd6jUVc21+deXlWx 0QAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAFKP5un+
1N23HlJ6tH83T/am7bjyk6T7Q5x3T+P69Si+jDPYk+GdE50X0YZ7EnwzokSu EWmer3tjp5JM
xbKrVaiXsi+VU5xpJuqTe8ziN6PwlV61Ow052UcqQwZRWKRs7kSzVzJMxE71 XKqbUvytGJn2
hURle0k3VJveZxDSTdUm95nEaUsrkfC9jldT1Nlaj3Krm97flX6uQS1tT3UW jpqaF7Wxtke+
SZWKiOcqbERq3+TzoTE59CYw30k3VJveZxDSTdUm95nETa5S60tNrMOsNTOW LPTPROe3LY0j
ylQywvmirad8TFRrntlarWqvIirfZymsaaSbqk3vM4hpJuqTe8ziJG19G6aK FtXAssrc+NiS
JnPbzol9qekzNW0tPIjJ6mGJ7lREa+RGqt722Lz2X8AItJN1Sb3mcQ0k3VJv eZxErK+jkjlk
jq4HshukrmyIqMty5y+T7zCZQolpFq0rKdaZFss2lbmctvlXsBHpJuqTe8zi Gkm6pN7zOI0g
yxSupHVNRNDTRaZ8TXSSojXZrlS6KtuW1yemq9YqauHMzdXejM69867Udf0c oEekm6pN7zOI
aSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKW km6pN7zOIaSb
qk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6 pN7zOIaSbqk3
vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7 zOIaSbqk3vM4
i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOI aSbqk3vM4i6A
KWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSb qk3vM4i6AKWk
m6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3 vM4i6AKWkm6p
N7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4 i6AKWkm6pN7z
OIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6A KWkm6pN7zOIa
Sbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKLpnssslNKxquRucqt2XWyci+k mMV/i6esj7aG
QKcfzdP9qbtuPKD1eP5un+1N23HlBc+0Ocd0/j+vUovouz2JPhnROfF9F2ex J8M6BMrhrR+E
qvWp2GnCytkhH5UdJGmayRc9bUqvRFVFRdqcq3RF225bndo/CVXrU7DTaaeV kjmxwo5rWI5V
Vypz7EREW/J/MRaa+sKiZj2c+iY2JaGnhilRsTtqrA5ifIdt2pbaq/zFZk2W TLba5KOiqWpE
xjVneqOiVHOW7e8dzp5U5C3RZRjqnK3Y111RLKtltyptRFRU5lQknyhRU0zI airp4pX2zWSS
Na519iWRV2mZzOWZzCh3Nqlpa6gXQpT1OlVs6PXSIr7rtbay2va+dyIhHLkq rq2PfUMpYpFS
FiMjermq1kiOVVVWp6URLbOfbs7gEeg4q5JlTLUlVmNlhllZLdaqSNWKiIny ERWv5EXbYkyj
kp9XNXyIkV6ii1Ziu5UW7l27OTan4HWNHyMYrEe9rVeua1FW2ctr2T8FH+Nz 5cisyPNNJK+J
Re: Persist EObject from BPEL20.XSD [message #96028 is a reply to message #95685] Thu, 06 September 2007 10:07 Go to previous messageGo to next message
--------------080401060109030201010901
Hi Martin,
i used your bpel.hbm.xml. Now it works to persist my TProcess-EObject in
the datebase. But if i want to retrieve this object, to update or to
delete it, i get the following error:
0 [main] INFO org.hibernate.tool.hbm2ddl.SchemaUpdate - Running
hbm2ddl schema update
0 [main] INFO org.hibernate.tool.hbm2ddl.SchemaUpdate - fetching
database metadata
3126 [main] INFO org.hibernate.tool.hbm2ddl.SchemaUpdate - updating schema
3205 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tactivity
3205 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, name, tsources_sources_e_id,
ttargets_targets_e_id, suppressjoinfailure]
3205 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkcc4e3f83df98cfbb, fkcc4e3f8397bbcbf4, fkcc4e3f83775bd0f1]
3205 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tactivity_pkey]
3237 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tactivitycontainer
3237 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tvalidate_validate_e_id, tassign_assign_e_id, textensibleelements_e_id,
tif_if_e_id, tthrow_throw_e_id, twait_wait_e_id, e_container,
econtainer_class, texit_exit_e_id, tscope_scope_e_id, tpick_pick_e_id,
textensionactivity_extensionactivity_e_id, treceive_receive_e_id,
tinvoke_invoke_e_id, e_container_featureid, tflow_flow_e_id,
tcompensatescope_compensatescope_e_id, treply_reply_e_id,
tsequence_sequence_e_id, trepeatuntil_repeatuntil_e_id,
trethrow_rethrow_e_id, twhile_while_e_id, tempty_empty_e_id,
tcompensate_compensate_e_id, tforeach_foreach_e_id]
3237 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk275ed05edda276b5, fk275ed05eecb09a54, fk275ed05ebc773fdf,
fk275ed05e9b2eccdb, fk275ed05ef1b7f950, fk275ed05e9613b7a0,
fk275ed05e3aea3f49, fk275ed05eea5c86e6, fk275ed05e9c0ab34d,
fk275ed05eaf7c3bfa, fk275ed05e97bbcbf4, fk275ed05e33facaeb,
fk275ed05e7196e053, fk275ed05ee7d7d5fe, fk275ed05e729f7902,
fk275ed05e2816e85, fk275ed05e74b91116, fk275ed05ec60985c9,
fk275ed05e8844eb0c, fk275ed05e269e02d2, fk275ed05ec8c92a9e,
fk275ed05edccc970]
3237 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tactivitycontainer_pkey]
3283 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tassign_group
3283 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, tassign_group_idx, tassign_group_e_id,
group_textensionassignoperation_extensionassignoperation_e_i d,
group_tcopy_copy_e_id, e_version, fme_feature]
3283 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk9bfe1da37925cf12, fk9bfe1da39bdce2b4, fk9bfe1da34022b516]
3283 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tassign_group_pkey]
3315 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
3315 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tactivity_e_id, e_container, e_container_featureid, econtainer_class,
validate]
3315 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fka4635a636250d1f4]
3315 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tassign_pkey]
3346 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tbooleanexpr
3346 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[texpression_e_id]
3346 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkf27c129992aff94]
3346 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tbooleanexpr_pkey]
3377 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tbranches
3377 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[texpression_e_id, successfulbranchesonly]
3377 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk2d7e9e44992aff94]
3377 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tbranches_pkey]
3408 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcatch
3408 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[faultname, tinvoke_catch_idx, tactivitycontainer_e_id,
tfaulthandlers_catch_idx, tfaulthandlers_catch_e_id, faultvariable,
faultelement, tinvoke_catch_e_id, faultmessagetype]
3408 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkcb9316c72c245058, fkcb9316c75d83a398, fkcb9316c7508dbab4]
3408 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcatch_pkey]
3440 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcompensate
3440 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tactivity_e_id, e_container, e_container_featureid, econtainer_class]
3440 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk4beb38ab6250d1f4]
3440 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcompensate_pkey]
3471 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcompensatescope
3471 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[target, tactivity_e_id, e_container, e_container_featureid,
econtainer_class]
3471 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk28a7b8896250d1f4]
3471 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcompensatescope_pkey]
3502 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcompletioncondition
3502 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tbranches_branches_e_id, textensibleelements_e_id, e_container,
3502 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk554d43cbccdbafcd, fk554d43cb97bbcbf4]
3502 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcompletioncondition_pkey]
3533 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcondition
3533 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[texpression_e_id]
3533 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk7df0af27992aff94]
3533 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcondition_pkey]
3565 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcopy
3565 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tfrom_from_e_id, ignoremissingfromdata, textensibleelements_e_id,
keepsrcelementname, tto_to_e_id, e_container, e_container_featureid,
econtainer_class]
3565 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk69155e9ba4c2a18, fk69155e95854a3e7, fk69155e997bbcbf4]
3565 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcopy_pkey]
3596 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcorrelation
3596 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, set, initiate,
tcorrelations_correlation_e_id, e_container, e_container_featureid,
econtainer_class, tcorrelations_correlation_idx]
3596 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fke235848e97bbcbf4, fke235848e49b4e4d1]
3596 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcorrelation_pkey]
3627 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcorrelations
3627 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, e_container, e_container_featureid,
econtainer_class]
3627 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk647b0da597bbcbf4]
3627 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcorrelations_pkey]
3658 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcorrelationset
3658 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, tcorrelationsets_correlationset_e_id, name,
tcorrelationsets_correlationset_idx, e_container, e_container_featureid,
properties, econtainer_class]
3658 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk31ee451497bbcbf4, fk31ee45147be3cc13]
3658 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcorrelationset_pkey]
3690 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcorrelationsets
3690 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
3690 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkbda5ddf97bbcbf4]
3690 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcorrelationsets_pkey]
3721 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcorrelationswithpattern
3721 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
3721 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk274e594597bbcbf4]
3721 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcorrelationswithpattern_pkey]
3752 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcorrelationwithpattern
3752 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tcorrelationswithpattern_correlation_e_id, pattern, tcorrelation_e_id,
tcorrelationswithpattern_correlation_idx]
3752 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk943da6bc49545091, fk943da6bcbdc1b8d4]
3752 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcorrelationwithpattern_pkey]
3783 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tdeadlineexpr
3783 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[texpression_e_id]
3783 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk946e9ac1992aff94]
3783 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tdeadlineexpr_pkey]
3830 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tdocumentation_any
3830 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, fme_mixed_comment, fme_mixed_cdata, any_source, fme_mixed_text,
mixed_tdocumentation_any_e_id, any_lang, e_version,
mixed_tdocumentation_any_idx, fme_feature]
3830 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk556114f399beabff]
3830 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tdocumentation_any_pkey]
3862 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tdocumentation_mixed
3862 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, mixed_lang, fme_mixed_comment, mixed_source, fme_mixed_cdata,
any_tdocumentation_mixed_idx, any_tdocumentation_mixed_e_id,
tdocumentation_mixed_idx, fme_mixed_text, e_version,
tdocumentation_mixed_e_id, fme_feature]
3862 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk8216814288d2a072, fk821681429ddf46d8]
3862 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tdocumentation_mixed_pkey]
3893 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
3893 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[mixed_tfrom_documentation_idx, any_tto_documentation_e_id,
any_textensibleelements_documentation_e_id,
mixed_tfrom_documentation_e_id, e_container,
any_tfrom_documentation_e_id, econtainer_class, e_id, lang,
any_tfrom_documentation_idx, any_tto_documentation_idx,
textensibleelements_documentation_e_id, mixed_tto_documentation_e_id,
source, mixed_tto_documentation_idx,
textensibleelements_documentation_idx, e_container_featureid, e_version,
any_textensibleelements_documentation_idx]
3893 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkb71d3ec69dab47b9, fkb71d3ec640621a79, fkb71d3ec6ee86ac59,
fkb71d3ec697c8ee99, fkb71d3ec663da4499, fkb71d3ec6a7463939]
3893 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tdocumentation_pkey]
3924 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tdurationexpr
3924 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[texpression_e_id]
3924 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fka00a0ffd992aff94]
3924 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tdurationexpr_pkey]
3955 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.telseif
3955 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
tif_if_e_id, tif_elseif_idx, tthrow_throw_e_id, twait_wait_e_id,
e_container, econtainer_class, texit_exit_e_id, tscope_scope_e_id,
tpick_pick_e_id, textensionactivity_extensionactivity_e_id,
treceive_receive_e_id, tinvoke_invoke_e_id, e_container_featureid,
tflow_flow_e_id, tif_elseif_e_id, tcompensatescope_compensatescope_e_id,
treply_reply_e_id, tsequence_sequence_e_id,
trepeatuntil_repeatuntil_e_id, trethrow_rethrow_e_id, twhile_while_e_id,
tempty_empty_e_id, tcompensate_compensate_e_id, tforeach_foreach_e_id,
tbooleanexpr_condition_e_id]
3955 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkaad4098aecb09a54, fkaad4098a74b91116, fkaad4098a9b2eccdb,
fkaad4098ac60985c9, fkaad4098adda276b5, fkaad4098aea5c86e6,
fkaad4098a269e02d2, fkaad4098a97bbcbf4, fkaad4098ac8c92a9e,
fkaad4098a7196e053, fkaad4098a9c0ab34d, fkaad4098ae7d7d5fe,
fkaad4098a9613b7a0, fkaad4098abc773fdf, fkaad4098ab404e6f8,
fkaad4098a3aea3f49, fkaad4098a729f7902, fkaad4098adccc970,
fkaad4098af1b7f950, fkaad4098a8844eb0c, fkaad4098a33facaeb,
fkaad4098a2816e85, fkaad4098a83793a1, fkaad4098aaf7c3bfa]
3955 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[telseif_pkey]
3987 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tempty
3987 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
3987 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkcbb4ad596250d1f4]
3987 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tempty_pkey]
4018 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.teventhandlers
4018 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4018 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fke2fe270f97bbcbf4]
4018 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[teventhandlers_pkey]
4065 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.texit
4065 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4065 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk6925f926250d1f4]
4065 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[texit_pkey]
4096 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.texpression_any
4096 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, fme_mixed_comment, mixed_texpression_any_idx, fme_mixed_cdata,
fme_mixed_text, any_expressionlanguage, mixed_texpression_any_e_id,
4096 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk68d955399b0ed047]
4096 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[texpression_any_pkey]
4127 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.texpression_anyattribute
4127 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, texpression_anyattribute_e_id, mixed_texpression_anyattribute_idx,
mixed_texpression_anyattribute_e_id, texpression_anyattribute_idx,
any_texpression_anyattribute_e_id, any_texpression_anyattribute_idx,
4127 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk42f82583c723fe7d, fk42f825832792c697, fk42f8258330d08735]
4127 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[texpression_anyattribute_pkey]
4159 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.texpression_mixed
4159 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, fme_mixed_comment, fme_mixed_cdata, any_texpression_mixed_idx,
texpression_mixed_idx, any_texpression_mixed_e_id, fme_mixed_text,
texpression_mixed_e_id, e_version, mixed_expressionlanguage, fme_feature]
4159 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk987fc808521ee5f8, fk987fc80822062718]
4159 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[texpression_mixed_pkey]
4191 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
4191 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[e_container, e_container_featureid, expressionlanguage, e_version,
econtainer_class, e_id]
4191 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
4191 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[texpression_pkey]
4222 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.textensibleelements_any
4222 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_any_idx, id, fme_mixed_comment, fme_mixed_cdata,
textensibleelements_any_e_id, fme_mixed_text, e_version, fme_feature]
4222 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk9276229367bd99e7]
4222 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[textensibleelements_any_pkey]
4253 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.textensibleelements_anyattribute
4253 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, textensibleelements_anyattribute_e_id,
any_textensibleelements_anyattribute_idx,
any_textensibleelements_anyattribute_e_id, e_version, fme_feature,
textensibleelements_anyattribute_idx]
4253 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkda43bd692f8d54d1, fkda43bd69b02312eb]
4253 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[textensibleelements_anyattribute_pkey]
4284 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
4284 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[e_version, e_id]
4284 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
4284 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[textensibleelements_pkey]
4316 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.textension
4316 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
mustunderstand, econtainer_class, textensions_extension_idx,
textensions_extension_e_id, namespace]
4316 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk8cc45e4b1c423854, fk8cc45e4b97bbcbf4]
4316 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[textension_pkey]
4347 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.textensionactivity_any
4347 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, fme_mixed_comment, textensionactivity_any_idx, fme_mixed_cdata,
fme_mixed_text, e_version, fme_feature, textensionactivity_any_e_id]
4347 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fke4a4c2876d0e0467]
4347 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[textensionactivity_any_pkey]
4378 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
4378 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[e_container, e_container_featureid, e_version, econtainer_class, e_id]
4378 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
4378 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[textensionactivity_pkey]
4409 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.textensionassignoperation
4409 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4409 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk8a1ad3ad97bbcbf4]
4409 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[textensionassignoperation_pkey]
4441 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.textensions
4441 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4441 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkbc76b8897bbcbf4]
4441 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[textensions_pkey]
4472 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tfaulthandlers
4472 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, tactivitycontainer_catchall_e_id,
4472 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk95a6e69797bbcbf4, fk95a6e697b6630ceb]
4472 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tfaulthandlers_pkey]
4503 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tflow_activity
4503 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[activity_tscope_scope_e_id, activity_trethrow_rethrow_e_id,
fme_feature, id, tflow_activity_e_id, activity_treply_reply_e_id,
activity_textensionactivity_extensionactivity_e_id,
activity_twhile_while_e_id,
activity_tcompensatescope_compensatescope_e_id,
activity_tcompensate_compensate_e_id, activity_twait_wait_e_id,
activity_texit_exit_e_id, activity_trepeatuntil_repeatuntil_e_id,
activity_treceive_receive_e_id, activity_tassign_assign_e_id,
activity_tforeach_foreach_e_id, activity_tpick_pick_e_id,
activity_tthrow_throw_e_id, activity_tsequence_sequence_e_id,
activity_tvalidate_validate_e_id, activity_tif_if_e_id,
activity_tinvoke_invoke_e_id, activity_tempty_empty_e_id,
activity_tflow_flow_e_id, e_version, tflow_activity_idx]
4503 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk5fa3f30cb681542a, fk5fa3f30c567e8a1d, fk5fa3f30ce80d6eca,
fk5fa3f30c9aa22d24, fk5fa3f30c5a4e840, fk5fa3f30cba625b23,
fk5fa3f30c881615bb, fk5fa3f30cca7bd985, fk5fa3f30c1b91d555,
fk5fa3f30ca4d05db6, fk5fa3f30c2d134fd2, fk5fa3f30cdc3e820,
fk5fa3f30c751e4ddc, fk5fa3f30cf55e1619, fk5fa3f30c912d5fe6,
fk5fa3f30c7ab94da2, fk5fa3f30c1194a56e, fk5fa3f30c76eb16af,
fk5fa3f30c3bf320ce, fk5fa3f30cef4a17ab, fk5fa3f30cb21fa670,
fk5fa3f30ce2157499]
4519 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tflow_activity_pkey]
4550 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tflow
4550 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tlinks_links_e_id, tactivity_e_id, e_container, e_container_featureid,
econtainer_class]
4550 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk692a7a2a4e47a, fk692a7a26250d1f4]
4550 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tflow_pkey]
4581 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tforeach
4581 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[countername, parallel, tscope_scope_e_id,
tcompletioncondition_completioncondition_e_id, tactivity_e_id,
e_container, e_container_featureid, texpression_finalcountervalue_e_id,
econtainer_class, texpression_startcountervalue_e_id]
4581 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fke9a3b756cff03b28, fke9a3b756bc773fdf, fke9a3b7566250d1f4,
fke9a3b75696018c54, fke9a3b75638f4edbc]
4581 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tforeach_pkey]
4613 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tfrom_any
4613 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[any_endpointreference, any_property, any_tliteral_literal_e_id,
any_expressionlanguage, fme_mixed_text, any_part, mixed_tfrom_any_e_id,
fme_feature, any_partnerlink, mixed_tfrom_any_idx, id,
any_tquery_query_e_id, fme_mixed_comment, fme_mixed_cdata, any_variable,
e_version]
4613 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fke4d7284b65231871, fke4d7284b6572bdd8, fke4d7284b9ef01207]
4613 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tfrom_any_pkey]
4644 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tfrom_anyattribute
4644 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, any_tfrom_anyattribute_e_id, mixed_tfrom_anyattribute_e_id,
tfrom_anyattribute_idx, mixed_tfrom_anyattribute_idx,
tfrom_anyattribute_e_id, any_tfrom_anyattribute_idx, e_version, fme_feature]
4644 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fka901a6b14c4b3621, fka901a6b14b0aa659, fka901a6b12a2f1afb]
4644 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tfrom_anyattribute_pkey]
4675 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tfrom_mixed
4675 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[mixed_endpointreference, any_tfrom_mixed_idx, any_tfrom_mixed_e_id,
fme_mixed_text, mixed_tliteral_literal_e_id, fme_feature,
tfrom_mixed_idx, tfrom_mixed_e_id, id, mixed_partnerlink,
fme_mixed_comment, mixed_part, fme_mixed_cdata, mixed_variable,
mixed_tquery_query_e_id, e_version, mixed_expressionlanguage,
mixed_property]
4675 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkc551e9afa0b2ff8, fkc551e9aa32347d8, fkc551e9a477e0a27,
fkc551e9a7d01a540]
4675 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tfrom_mixed_pkey]
4706 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tfrom
4706 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[endpointreference, partnerlink, e_container, property,
e_container_featureid, part, expressionlanguage, e_version,
econtainer_class, variable, e_id]
4706 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
4706 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tfrom_pkey]
4738 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tfrompart
4738 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tfromparts_frompart_idx, textensibleelements_e_id, tovariable,
tfromparts_frompart_e_id, e_container, e_container_featureid, part,
econtainer_class]
4738 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fke4dee31197bbcbf4, fke4dee311c40fa8fc]
4738 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tfrompart_pkey]
4769 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tfromparts
4769 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4769 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkb6fd7f8297bbcbf4]
4769 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tfromparts_pkey]
4800 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tif
4800 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tvalidate_validate_e_id, tassign_assign_e_id, tif_if_e_id,
tthrow_throw_e_id, twait_wait_e_id, e_container, econtainer_class,
trethrow_rethrow_e_id, twhile_while_e_id, tactivity_e_id,
tactivitycontainer_else_e_id, tforeach_foreach_e_id,
4800 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk1c0912816e85, fk1c091269e02d2, fk1c091ecdd3c18,
fk1c091dda276b5, fk1c0919b2eccdb, fk1c0916250d1f4, fk1c091c60985c9,
fk1c091e7d7d5fe, fk1c09133facaeb, fk1c091f1b7f950, fk1c091af7c3bfa,
fk1c0918844eb0c, fk1c091b404e6f8, fk1c0917196e053, fk1c091bc773fdf,
fk1c0913aea3f49, fk1c091ea5c86e6, fk1c091ecb09a54, fk1c091729f7902,
fk1c0919c0ab34d, fk1c091c8c92a9e, fk1c0919613b7a0, fk1c091dccc970,
fk1c09174b91116]
4800 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tif_pkey]
4847 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.timport
4847 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, location, importtype, e_container,
e_container_featureid, tprocess_import_idx, econtainer_class,
tprocess_import_e_id, namespace]
4847 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkb1b44d1956120046, fkb1b44d1997bbcbf4]
4847 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[timport_pkey]
4878 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tinvoke
4878 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tcorrelationswithpattern_correlations_e_id, ttoparts_toparts_e_id,
tactivitycontainer_compensationhandler_e_id, operation,
tactivitycontainer_catchall_e_id, tfromparts_fromparts_e_id, porttype,
tactivity_e_id, inputvariable, partnerlink, e_container_featureid,
outputvariable]
4878 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkb1c51dec60a9400e, fkb1c51decdcbc374e, fkb1c51decb6630ceb,
fkb1c51decb6e0161d, fkb1c51decf25c1d63, fkb1c51dec6250d1f4]
4878 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tinvoke_pkey]
4909 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tlink
4909 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, tlinks_link_idx, name, e_container,
e_container_featureid, econtainer_class, tlinks_link_e_id]
4909 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk695566e330b0425, fk695566e97bbcbf4]
4909 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tlink_pkey]
4941 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tlinks
4941 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4941 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkcc1577c597bbcbf4]
4941 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tlinks_pkey]
4972 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tliteral_any
4972 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, fme_mixed_comment, fme_mixed_cdata, mixed_tliteral_any_e_id,
fme_mixed_text, mixed_tliteral_any_idx, e_version, fme_feature]
4972 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fke41dc9687a8d60df]
4972 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tliteral_any_pkey]
5003 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tliteral_mixed
5003 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, fme_mixed_comment, fme_mixed_cdata, tliteral_mixed_idx,
fme_mixed_text, tliteral_mixed_e_id, any_tliteral_mixed_e_id, e_version,
fme_feature, any_tliteral_mixed_idx]
5003 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk5477ec77ea11cbb8, fk5477ec778b04f892]
5003 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tliteral_mixed_pkey]
5034 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
5034 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
5034 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
5034 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tliteral_pkey]
5066 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tmessageexchange
5066 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tmessageexchanges_messageexchange_idx, textensibleelements_e_id, name,
tmessageexchanges_messageexchange_e_id, e_container,
5066 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkd87c2036cb4b5609, fkd87c203697bbcbf4]
5066 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tmessageexchange_pkey]
5097 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tmessageexchanges
5097 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
5097 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk3707e6fd97bbcbf4]
5097 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tmessageexchanges_pkey]
5128 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tonalarmevent
5128 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tdurationexpr_repeatevery_e_id, tscope_scope_e_id,
textensibleelements_e_id, teventhandlers_onalarm_idx,
teventhandlers_onalarm_e_id, tdurationexpr_repeatevery1_e_id,
tdeadlineexpr_until_e_id, tdurationexpr_for_e_id, e_container,
5128 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk2afc387c180835d3, fk2afc387c7fb4f30a, fk2afc387c91083a95,
fk2afc387c2038ad3e, fk2afc387cbc773fdf, fk2afc387ce416e1e1,
fk2afc387c97bbcbf4]
5129 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tonalarmevent_pkey]
5176 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tonalarmpick
5176 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
tinvoke_invoke_e_id, e_container_featureid, tpick_onalarm_e_id,
tflow_flow_e_id, tcompensatescope_compensatescope_e_id,
treply_reply_e_id, tdeadlineexpr_until_e_id, tdurationexpr_for_e_id,
tcompensate_compensate_e_id, tpick_onalarm_idx, tforeach_foreach_e_id]
5176 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkd81d75ff9613b7a0, fkd81d75ff2816e85, fkd81d75fff1b7f950,
fkd81d75ffea5c86e6, fkd81d75ffc60985c9, fkd81d75ff3aea3f49,
fkd81d75ffdda276b5, fkd81d75ff9c0ab34d, fkd81d75ff74b91116,
fkd81d75ff7196e053, fkd81d75ff9b2eccdb, fkd81d75ffe7d7d5fe,
fkd81d75ff729f7902, fkd81d75ffdccc970, fkd81d75ff8844eb0c,
fkd81d75ffc8c92a9e, fkd81d75ff97bbcbf4, fkd81d75ff91083a95,
fkd81d75ff269e02d2, fkd81d75ffecb09a54, fkd81d75ff33facaeb,
fkd81d75ffa772ef81, fkd81d75ff7fb4f30a, fkd81d75ffaf7c3bfa,
fkd81d75ffbc773fdf]
5176 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tonalarmpick_pkey]
5207 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tonevent
5207 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[teventhandlers_onevent_e_id, tonmsgcommon_e_id, element,
tscope_scope_e_id, teventhandlers_onevent_idx, messagetype, e_container,
5207 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkc3578d2761f1a7b4, fkc3578d2757c6af38, fkc3578d27bc773fdf]
5207 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tonevent_pkey]
5239 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tonmessage
5239 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
trethrow_rethrow_e_id, tpick_onmessage_e_id, tonmsgcommon_e_id,
tpick_onmessage_idx, twhile_while_e_id, tempty_empty_e_id,
5239 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkd69fab5461f1a7b4, fkd69fab549c0ab34d, fkd69fab548844eb0c,
fkd69fab54e7d7d5fe, fkd69fab54dccc970, fkd69fab549b2eccdb,
fkd69fab54c8c92a9e, fkd69fab54ea5c86e6, fkd69fab547196e053,
fkd69fab5433facaeb, fkd69fab542816e85, fkd69fab54ecb09a54,
fkd69fab54dda276b5, fkd69fab543aea3f49, fkd69fab5474b91116,
fkd69fab54c60985c9, fkd69fab54269e02d2, fkd69fab5485588d4b,
fkd69fab54729f7902, fkd69fab54bc773fdf, fkd69fab54f1b7f950,
fkd69fab549613b7a0, fkd69fab54af7c3bfa]
5239 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tonmessage_pkey]
5270 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tonmsgcommon
5270 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[messageexchange, operation, textensibleelements_e_id, porttype,
tfromparts_fromparts_e_id, partnerlink, tcorrelations_correlations_e_id,
variable]
5270 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkc66278b997bbcbf4, fkc66278b98dcf990e, fkc66278b9b6e0161d]
5270 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tonmsgcommon_pkey]
5301 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tpartnerlink
5301 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tpartnerlinks_partnerlink_e_id, partnerlinktype, initializepartnerrole,
tpartnerlinks_partnerlink_idx, textensibleelements_e_id, name,
partnerrole, e_container, e_container_featureid, econtainer_class, myrole]
5301 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkb6a2d7ce97bbcbf4, fkb6a2d7ce13cac171]
5301 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tpartnerlink_pkey]
5332 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tpartnerlinks
5332 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
5332 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk1db8226597bbcbf4]
5332 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tpartnerlinks_pkey]
5364 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tpick
5364 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
createinstance]
5364 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk69726956250d1f4]
5364 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tpick_pkey]
5410 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tprocess
5410 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tvalidate_validate_e_id, tvariables_variables_e_id,
tassign_assign_e_id, textensibleelements_e_id, tif_if_e_id,
tthrow_throw_e_id, twait_wait_e_id, teventhandlers_eventhandlers_e_id,
tmessageexchanges_messageexchanges_e_id, texit_exit_e_id,
tfaulthandlers_faulthandlers_e_id, tscope_scope_e_id, tpick_pick_e_id,
textensionactivity_extensionactivity_e_id, name,
textensions_extensions_e_id, treceive_receive_e_id, tinvoke_invoke_e_id,
suppressjoinfailure, expressionlanguage, querylanguage, tflow_flow_e_id,
trethrow_rethrow_e_id, targetnamespace, tpartnerlinks_partnerlinks_e_id,
exitonstandardfault, twhile_while_e_id,
tcorrelationsets_correlationsets_e_id, tempty_empty_e_id,
5410 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkff95737b9b2eccdb, fkff95737b3aea3f49, fkff95737b8daa7cbc,
fkff95737b997bb551, fkff95737bdda276b5, fkff95737b7196e053,
fkff95737b8844eb0c, fkff95737bea5c86e6, fkff95737bf1b7f950,
fkff95737b74b91116, fkff95737b862505ae, fkff95737bc8c92a9e,
fkff95737b729f7902, fkff95737becb09a54, fkff95737b9c0ab34d,
fkff95737b269e02d2, fkff95737bdccc970, fkff95737be7d7d5fe,
fkff95737bc60985c9, fkff95737b33facaeb, fkff95737b85e4c1c8,
fkff95737bada21a46, fkff95737bbc773fdf, fkff95737b9a508780,
fkff95737bbdef8950, fkff95737b97bbcbf4, fkff95737b2816e85,
fkff95737b9613b7a0, fkff95737baf7c3bfa]
5410 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tprocess_pkey]
5442 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tquery_any
5442 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, fme_mixed_comment, fme_mixed_cdata, mixed_tquery_any_e_id,
mixed_tquery_any_idx, fme_mixed_text, any_querylanguage, e_version,
fme_feature]
5442 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk459960016868553f]
5442 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tquery_any_pkey]
5473 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tquery_anyattribute
5473 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[any_tquery_anyattribute_idx, tquery_anyattribute_idx, id,
mixed_tquery_anyattribute_idx, tquery_anyattribute_e_id,
mixed_tquery_anyattribute_e_id, e_version, any_tquery_anyattribute_e_id,
fme_feature]
5473 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk7603bbbbc6a0b20d, fk7603bbbb664c99cd, fk7603bbbb3428ac2d]
5473 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tquery_anyattribute_pkey]
5504 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tquery_mixed
5504 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, fme_mixed_comment, fme_mixed_cdata, mixed_querylanguage,
fme_mixed_text, tquery_mixed_e_id, any_tquery_mixed_e_id,
tquery_mixed_idx, e_version, fme_feature, any_tquery_mixed_idx]
5504 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk456840d0e1d1218, fk456840d0232171b2]
5504 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tquery_mixed_pkey]
5535 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
5535 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
querylanguage, e_id]
5535 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
5535 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tquery_pkey]
5567 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.treceive
5567 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[messageexchange, operation, porttype, tfromparts_fromparts_e_id,
tactivity_e_id, partnerlink, e_container,
tcorrelations_correlations_e_id, e_container_featureid,
econtainer_class, variable, createinstance]
5567 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk528ac7ef6250d1f4, fk528ac7efb6e0161d, fk528ac7ef8dcf990e]
5567 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[treceive_pkey]
5598 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.trepeatuntil
5598 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
5598 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkdcea89afbc773fdf, fkdcea89af9613b7a0, fkdcea89afecb09a54,
fkdcea89af8844eb0c, fkdcea89afe7d7d5fe, fkdcea89aff1b7f950,
fkdcea89af6250d1f4, fkdcea89af74b91116, fkdcea89afaf7c3bfa,
fkdcea89af729f7902, fkdcea89afdda276b5, fkdcea89afdccc970,
fkdcea89afea5c86e6, fkdcea89afc60985c9, fkdcea89afb404e6f8,
fkdcea89af9c0ab34d, fkdcea89af9b2eccdb, fkdcea89af3aea3f49,
fkdcea89af7196e053, fkdcea89afc8c92a9e, fkdcea89af33facaeb,
fkdcea89af269e02d2, fkdcea89af2816e85]
5598 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[trepeatuntil_pkey]
5629 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.treply
5645 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[messageexchange, faultname, operation, ttoparts_toparts_e_id, porttype,
econtainer_class, variable]
5645 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkcc683af68dcf990e, fkcc683af6dcbc374e, fkcc683af66250d1f4]
5645 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[treply_pkey]
5676 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.trethrow
5676 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
5676 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk537bd59f6250d1f4]
5676 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[trethrow_pkey]
5707 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tscope
5707 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
tassign_assign_e_id, tif_if_e_id, tthrow_throw_e_id, twait_wait_e_id,
e_container, teventhandlers_eventhandlers_e_id, econtainer_class,
tfaulthandlers_faulthandlers_e_id, texit_exit_e_id, tscope_scope_e_id,
tflow_flow_e_id, isolated, tcompensatescope_compensatescope_e_id,
tactivitycontainer_terminationhandler_e_id,
tpartnerlinks_partnerlinks_e_id, exitonstandardfault, twhile_while_e_id,
tcorrelationsets_correlationsets_e_id, tactivity_e_id,
tempty_empty_e_id, tcompensate_compensate_e_id, tforeach_foreach_e_id]
5707 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkcc756660dccc970, fkcc7566609b2eccdb, fkcc756660bdef8950,
fkcc756660862505ae, fkcc756660af7c3bfa, fkcc756660ecb09a54,
fkcc7566602816e85, fkcc7566609a508780, fkcc7566606250d1f4,
fkcc75666033facaeb, fkcc756660dda276b5, fkcc7566607196e053,
fkcc756660729f7902, fkcc756660ada21a46, fkcc7566609613b7a0,
fkcc756660c8c92a9e, fkcc75666085e4c1c8, fkcc756660c60985c9,
fkcc756660ea5c86e6, fkcc756660f25c1d63, fkcc756660f1b7f950,
fkcc7566608844eb0c, fkcc756660643a236b, fkcc756660e7d7d5fe,
fkcc7566608daa7cbc, fkcc756660269e02d2, fkcc756660bc773fdf,
fkcc7566603aea3f49, fkcc7566609c0ab34d, fkcc75666074b91116]
5707 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tscope_pkey]
5739 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tsequence_activity
5739 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[activity_tscope_scope_e_id, tsequence_activity_idx,
activity_trethrow_rethrow_e_id, fme_feature, id,
activity_tinvoke_invoke_e_id, tsequence_activity_e_id,
activity_tempty_empty_e_id, activity_tflow_flow_e_id, e_version]
5739 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk314f4bd9567e8a1d, fk314f4bd9912d5fe6, fk314f4bd9ba625b23,
fk314f4bd91194a56e, fk314f4bd9f55e1619, fk314f4bd95a4e840,
fk314f4bd9a4d05db6, fk314f4bd9ef4a17ab, fk314f4bd9881615bb,
fk314f4bd9dc3e820, fk314f4bd97ab94da2, fk314f4bd9e2157499,
fk314f4bd976eb16af, fk314f4bd9b21fa670, fk314f4bd91b91d555,
fk314f4bd9e80d6eca, fk314f4bd93bf320ce, fk314f4bd9ca7bd985,
fk314f4bd92d134fd2, fk314f4bd99aa22d24, fk314f4bd9b5fc9010,
fk314f4bd9751e4ddc]
5739 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tsequence_activity_pkey]
5785 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
5785 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
5785 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk7f72c4356250d1f4]
5785 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tsequence_pkey]
5817 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tsource
5817 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tcondition_transitioncondition_e_id, textensibleelements_e_id,
tsources_source_idx, e_container, e_container_featureid,
tsources_source_e_id, econtainer_class, linkname]
5817 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkc2e3418fbc5fbaa2, fkc2e3418fe2e1adad, fkc2e3418f97bbcbf4]
5817 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tsource_pkey]
5848 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tsources
5848 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
5848 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk9984f0c497bbcbf4]
5848 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tsources_pkey]
5879 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.ttarget
5879 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, ttargets_target_e_id, e_container,
e_container_featureid, ttargets_target_idx, econtainer_class, linkname]
5879 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkc3d14b05bc21d680, fkc3d14b0597bbcbf4]
5879 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[ttarget_pkey]
5910 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.ttargets
5910 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
tcondition_joincondition_e_id, econtainer_class]
5910 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkb658160e6d8bb6c2, fkb658160e97bbcbf4]
5910 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[ttargets_pkey]
5942 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tthrow
5942 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[faultname, faultvariable, tactivity_e_id, e_container,
5942 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkcc85cef26250d1f4]
5942 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tthrow_pkey]
5973 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tto_any
5973 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[mixed_tto_any_e_id, any_property, any_expressionlanguage,
fme_mixed_text, any_part, mixed_tto_any_idx, fme_feature,
any_partnerlink, id, any_tquery_query_e_id, fme_mixed_comment,
fme_mixed_cdata, any_variable, e_version]
5973 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkc48ddb9c6572bdd8, fkc48ddb9cd9f64d67]
5973 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tto_any_pkey]
6004 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tto_anyattribute
6004 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, mixed_tto_anyattribute_idx, mixed_tto_anyattribute_e_id,
tto_anyattribute_e_id, any_tto_anyattribute_e_id,
any_tto_anyattribute_idx, e_version, tto_anyattribute_idx, fme_feature]
6004 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkbb611e8097ada71d, fkbb611e804a794b83, fkbb611e8012d999fb]
6004 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tto_anyattribute_pkey]
6035 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tto_mixed
6035 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tto_mixed_e_id, fme_mixed_text, fme_feature, id, any_tto_mixed_e_id,
mixed_partnerlink, any_tto_mixed_idx, mixed_part, fme_mixed_comment,
fme_mixed_cdata, mixed_variable, mixed_tquery_query_e_id, tto_mixed_idx,
e_version, mixed_expressionlanguage, mixed_property]
6035 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkd92c41ab168c6b38, fkd92c41ab2258e398, fkd92c41ab477e0a27]
6035 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tto_mixed_pkey]
6067 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tto
6067 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[partnerlink, e_container, property, e_container_featureid, part,
expressionlanguage, e_version, econtainer_class, variable, e_id]
6067 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
6067 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tto_pkey]
6098 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.ttopart
6098 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, ttoparts_topart_e_id, fromvariable,
ttoparts_topart_idx, e_container, e_container_featureid, part,
econtainer_class]
6098 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkc4959662ab692129, fkc495966297bbcbf4]
6098 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[ttopart_pkey]
6129 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.ttoparts
6129 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
6129 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkce1d365197bbcbf4]
6129 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[ttoparts_pkey]
6161 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tvalidate
6161 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
variables]
6161 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkda4b658a6250d1f4]
6161 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tvalidate_pkey]
6193 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tvariable
6193 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[element, tfrom_from_e_id, tvariables_variable_e_id,
textensibleelements_e_id, tvariables_variable_idx, name, messagetype,
e_container, e_container_featureid, type, econtainer_class]
6193 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fke4871ef05854a3e7, fke4871ef097bbcbf4, fke4871ef04689dadf]
6193 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tvariable_pkey]
6224 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
f
Re: Persist EObject from BPEL20.XSD [message #96077 is a reply to message #96028] Thu, 06 September 2007 10:16 Go to previous messageGo to next message
Afaics there is a postgresql exception in there:
Caused by: org.postgresql.util.PSQLException: ERROR: target lists can have at most 1664 entries
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorRespons e(QueryExecutorImpl.java:1548)
This seams to be the cause (afaics), can you check the postgresql manual and see what it means.
gr. Martin
Daniel Gerlach wrote:
> Hi Martin,
> database metadata
> schema
> [tactivity_pkey]
> fk275ed05edccc970]
> validate]
> [tassign_pkey]
> [texpression_e_id]
> [tbooleanexpr_pkey]
> [tbranches_pkey]
> [tcatch_pkey]
> [tcompensate_pkey]
> econtainer_class]
> [texpression_e_id]
> [tcondition_pkey]
> found: public.tcopy
> econtainer_class]
> [tcopy_pkey]
> [tcorrelation_pkey]
> econtainer_class]
> econtainer_class]
> econtainer_class]
> [texpression_e_id]
> [texpression_e_id]
> [telseif_pkey]
> [tempty_pkey]
> econtainer_class]
> found: public.texit
> [texit_pkey]
> keys: []
> [texpression_pkey]
> [e_version, e_id]
> keys: []
> [textension_pkey]
> keys: []
> econtainer_class]
> econtainer_class]
> [textensions_pkey]
> fk5fa3f30ce2157499]
> found: public.tflow
> econtainer_class]
> [tflow_pkey]
> [tforeach_pkey]
> e_version]
> [tfrom_any_pkey]
> fme_feature]
> mixed_property]
> fkc551e9a7d01a540]
> [tfrom_mixed_pkey]
> found: public.tfrom
> keys: []
> [tfrom_pkey]
> econtainer_class]
> [tfrompart_pkey]
> econtainer_class]
> [tfromparts_pkey]
> found: public.tif
> fk1c09174b91116]
> [tif_pkey]
> [timport_pkey]
> outputvariable]
> [tinvoke_pkey]
> found: public.tlink
> [tlink_pkey]
> econtainer_class]
> [tlinks_pkey]
> [tliteral_any_pkey]
> keys: []
> [tliteral_pkey]
> econtainer_class]
> fk2afc387c97bbcbf4]
> fkd81d75ffbc773fdf]
> [tonalarmpick_pkey]
> [tonevent_pkey]
> [tonmessage_pkey]
> variable]
> [tonmsgcommon_pkey]
> [tpartnerlink_pkey]
> econtainer_class]
> found: public.tpick
> createinstance]
> [tpick_pkey]
> [tprocess_pkey]
> fme_feature]
> [tquery_any_pkey]
> fme_feature]
> [tquery_mixed_pkey]
> keys: []
> [tquery_pkey]
> [treceive_pkey]
> [trepeatuntil_pkey]
> [treply_pkey]
> [trethrow_pkey]
> [tscope_pkey]
> fk314f4bd9751e4ddc]
> [tsequence_pkey]
> [tsource_pkey]
> econtainer_class]
> [tsources_pkey]
> [ttarget_pkey]
> [ttargets_pkey]
Re: Persist EObject from BPEL20.XSD [message #96145 is a reply to message #96077] Thu, 06 September 2007 12:42 Go to previous messageGo to next message
I looked in the PostgreSQL documentation and i googled around but i
didn't find anything that would help me.
So i changed the database to MySQL 5.0.41 but there is also an error:
[main] ERROR org.hibernate.util.JDBCExceptionReporter - Too many
tables; MySQL can only use 61 tables in a join
So in the query there are too many tables for a join, but how can i
reduce the amount of tables. Is there something i can do?
Perhaps i should go with
BPEL1.1(http://schemas.xmlsoap.org/ws/2003/03/business-process/). The
XSD is a lot easier and think it work out-of-the-box with teneo. I'll
try this tomorrow.
Thanks in advance
Daniel Gerlach
Whole Error-message:
3943 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
3943 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk5fa3f30cb681542a, fk5fa3f30ce80d6eca, fk5fa3f30c567e8a1d,
fk5fa3f30c9aa22d24, fk5fa3f30c5a4e840, fk5fa3f30cca7bd985,
fk5fa3f30cba625b23, fk5fa3f30c881615bb, fk5fa3f30c1b91d555,
fk5fa3f30ca4d05db6, fk5fa3f30cdc3e820, fk5fa3f30c2d134fd2,
fk5fa3f30c7ab94da2, fk5fa3f30c1194a56e, fk5fa3f30c3bf320ce,
fk5fa3f30c76eb16af, fk5fa3f30cef4a17ab, fk5fa3f30ce2157499,
fk5fa3f30cb21fa670]
3943 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
fk5fa3f30c9aa22d24, fk5fa3f30c5a4e840, fk5fa3f30c881615bb,
fk5fa3f30cca7bd985, fk5fa3f30cba625b23, fk5fa3f30c1b91d555,
fk5fa3f30c751e4ddc, fk5fa3f30cf55e1619, fk5fa3f30c912d5fe6, primary,
fk5fa3f30ce2157499]
3957 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tflow
3957 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
3957 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
3957 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk692a7a2a4e47a, primary, fk692a7a26250d1f4]
3968 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tforeach
3969 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
3969 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
3969 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fke9a3b756cff03b28, primary, fke9a3b756bc773fdf, fke9a3b7566250d1f4,
3982 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tfrom_any
3983 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
e_version]
3983 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
3983 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fke4d7284b65231871, fke4d7284b6572bdd8, primary, fke4d7284b9ef01207]
3994 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tfrom_anyattribute
3994 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
3994 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
3994 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fka901a6b14c4b3621, fka901a6b14b0aa659, primary, fka901a6b12a2f1afb]
4006 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tfrom_mixed
4006 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
mixed_property]
4006 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
fkc551e9a7d01a540]
4006 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkc551e9afa0b2ff8, fkc551e9aa32347d8, fkc551e9a477e0a27, primary,
fkc551e9a7d01a540]
4017 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tfrom
4017 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4017 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
4017 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary]
4028 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tfrompart
4028 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4028 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4028 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fke4dee31197bbcbf4, primary, fke4dee311c40fa8fc]
4040 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tfromparts
4040 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4040 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4040 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkb6fd7f8297bbcbf4, primary]
4058 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tif
4058 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4058 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk1c0912816e85, fk1c091ecdd3c18, fk1c091dda276b5,
fk1c091269e02d2, fk1c0919b2eccdb, fk1c0916250d1f4, fk1c091c60985c9,
fk1c091b404e6f8, fk1c0918844eb0c, fk1c0917196e053, fk1c091bc773fdf,
fk1c091c8c92a9e, fk1c0919c0ab34d, fk1c091dccc970, fk1c0919613b7a0,
fk1c09174b91116]
4058 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk1c0912816e85, fk1c091269e02d2, fk1c0916250d1f4, fk1c09133facaeb,
fk1c091af7c3bfa, fk1c0918844eb0c, primary, fk1c091c8c92a9e,
fk1c091dccc970, fk1c09174b91116, fk1c091dda276b5, fk1c091ecdd3c18,
fk1c0919b2eccdb, fk1c091c60985c9, fk1c091e7d7d5fe, fk1c091f1b7f950,
fk1c091b404e6f8, fk1c0917196e053, fk1c0913aea3f49, fk1c091bc773fdf,
fk1c091ea5c86e6, fk1c091ecb09a54, fk1c091729f7902, fk1c0919c0ab34d,
fk1c0919613b7a0]
4071 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.timport
4071 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4071 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4071 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fkb1b44d1956120046, fkb1b44d1997bbcbf4]
4084 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tinvoke
4085 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
outputvariable]
4085 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4085 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkb1c51dec60a9400e, fkb1c51decdcbc374e, fkb1c51decb6630ceb, primary,
4095 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tlink
4095 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4095 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4095 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk695566e330b0425, fk695566e97bbcbf4, primary]
4110 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tlinks
4110 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4110 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4110 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fkcc1577c597bbcbf4]
4123 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tliteral_any
4123 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4123 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4123 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fke41dc9687a8d60df]
4136 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tliteral_mixed
4136 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4136 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4136 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk5477ec77ea11cbb8, primary, fk5477ec778b04f892]
4148 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
4148 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4148 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
4148 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary]
4160 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tmessageexchange
4160 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4160 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4160 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkd87c2036cb4b5609, primary, fkd87c203697bbcbf4]
4172 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tmessageexchanges
4172 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4172 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4172 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fk3707e6fd97bbcbf4]
4187 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tonalarmevent
4187 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4187 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk2afc387c180835d3, fk2afc387c91083a95, fk2afc387c7fb4f30a,
fk2afc387c97bbcbf4]
4187 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk2afc387c180835d3, fk2afc387c91083a95, fk2afc387c7fb4f30a, primary,
fk2afc387c97bbcbf4]
4202 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tonalarmpick
4203 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tvalidate_validate_e_id, tassign_assign_e_id, textensibleelements_e_id,
tif_if_e_id, tthrow_throw_e_id, twait_wait_e_id, e_container,
econtainer_class, texit_exit_e_id, tscope_scope_e_id, tpick_pick_e_id,
textensionactivity_extensionactivity_e_id, treceive_receive_e_id,
tsequence_sequence_e_id, trepeatuntil_repeatuntil_e_id,
trethrow_rethrow_e_id, twhile_while_e_id, tempty_empty_e_id,
4203 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
fkd81d75ffea5c86e6, fkd81d75ff3aea3f49, fkd81d75ffc60985c9,
fkd81d75ffbc773fdf]
4203 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
fkd81d75ff7196e053, fkd81d75ff9b2eccdb, primary, fkd81d75ffe7d7d5fe,
fkd81d75ffbc773fdf]
4215 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tonevent
4215 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4215 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4215 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fkc3578d2761f1a7b4, fkc3578d2757c6af38, fkc3578d27bc773fdf]
4231 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tonmessage
4232 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
tinvoke_invoke_e_id, e_container_featureid, tflow_flow_e_id,
tcompensatescope_compensatescope_e_id, treply_reply_e_id,
4232 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkd69fab5461f1a7b4, fkd69fab54e7d7d5fe, fkd69fab548844eb0c,
fkd69fab549c0ab34d, fkd69fab54dccc970, fkd69fab549b2eccdb,
fkd69fab54ea5c86e6, fkd69fab54c8c92a9e, fkd69fab547196e053,
fkd69fab54dda276b5, fkd69fab543aea3f49, fkd69fab54c60985c9,
fkd69fab5474b91116, fkd69fab54269e02d2, fkd69fab5485588d4b,
fkd69fab54729f7902, fkd69fab54f1b7f950, fkd69fab54bc773fdf,
fkd69fab54af7c3bfa, fkd69fab549613b7a0]
4232 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkd69fab5461f1a7b4, fkd69fab54e7d7d5fe, fkd69fab549c0ab34d,
fkd69fab548844eb0c, fkd69fab54dccc970, fkd69fab549b2eccdb,
fkd69fab54dda276b5, primary, fkd69fab543aea3f49, fkd69fab54c60985c9,
fkd69fab5474b91116, fkd69fab5485588d4b, fkd69fab54269e02d2,
4243 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tonmsgcommon
4243 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
variable]
4244 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4244 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkc66278b997bbcbf4, primary, fkc66278b98dcf990e, fkc66278b9b6e0161d]
4255 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tpartnerlink
4256 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4256 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4256 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkb6a2d7ce97bbcbf4, fkb6a2d7ce13cac171, primary]
4268 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tpartnerlinks
4268 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4268 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4268 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk1db8226597bbcbf4, primary]
4281 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tpick
4281 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tactivity_e_id, e_container, e_container_featureid, econtainer_class,
createinstance]
4281 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4281 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fk69726956250d1f4]
4302 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tprocess
4302 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4302 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
fkff95737b8844eb0c, fkff95737bf1b7f950, fkff95737bea5c86e6,
fkff95737b862505ae, fkff95737b74b91116, fkff95737bc8c92a9e,
fkff95737b85e4c1c8, fkff95737b33facaeb, fkff95737bc60985c9,
4303 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
fkff95737b729f7902, primary, fkff95737b9c0ab34d, fkff95737becb09a54,
fkff95737b33facaeb, fkff95737bc60985c9, fkff95737b85e4c1c8,
4315 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tquery_any
4315 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
fme_feature]
4315 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4315 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk459960016868553f, primary]
4327 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tquery_anyattribute
4327 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
fme_feature]
4327 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4327 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk7603bbbbc6a0b20d, fk7603bbbb664c99cd, primary, fk7603bbbb3428ac2d]
4339 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tquery_mixed
4339 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4339 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4339 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fk456840d0e1d1218, fk456840d0232171b2]
4360 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
4361 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4361 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
4361 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary]
4376 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.treceive
4377 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4377 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4377 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk528ac7ef6250d1f4, fk528ac7efb6e0161d, primary, fk528ac7ef8dcf990e]
4392 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.trepeatuntil
4392 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4393 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
fkdcea89afe7d7d5fe, fkdcea89af8844eb0c, fkdcea89aff1b7f950,
fkdcea89af729f7902, fkdcea89afdda276b5, fkdcea89afea5c86e6,
fkdcea89afdccc970, fkdcea89afc60985c9, fkdcea89afb404e6f8,
4393 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
fkdcea89afc60985c9, fkdcea89afea5c86e6, fkdcea89afb404e6f8,
fkdcea89af9c0ab34d, fkdcea89af9b2eccdb, primary, fkdcea89af3aea3f49,
4404 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.treply
4404 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4404 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4404 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkcc683af68dcf990e, primary, fkcc683af6dcbc374e, fkcc683af66250d1f4]
4415 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.trethrow
4415 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tactivity_e_id, e_container, e_container_featureid, econtainer_class]
4415 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4415 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fk537bd59f6250d1f4]
4433 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tscope
4433 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4433 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
fkcc756660f25c1d63, fkcc756660ea5c86e6, fkcc756660f1b7f950,
fkcc7566608844eb0c, fkcc756660e7d7d5fe, fkcc756660643a236b,
4433 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkcc756660dccc970, fkcc756660bdef8950, fkcc7566609b2eccdb,
fkcc75666033facaeb, fkcc756660dda276b5, primary, fkcc7566607196e053,
fkcc756660ada21a46, fkcc756660729f7902, fkcc7566609613b7a0,
fkcc756660c8c92a9e, fkcc756660c60985c9, fkcc75666085e4c1c8,
4453 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tsequence_activity
4453 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4453 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
fk314f4bd9ef4a17ab, fk314f4bd9881615bb, fk314f4bd9a4d05db6,
fk314f4bd9dc3e820, fk314f4bd9e2157499, fk314f4bd97ab94da2,
fk314f4bd9b21fa670, fk314f4bd976eb16af, fk314f4bd91b91d555,
fk314f4bd9751e4ddc]
4453 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk314f4bd9567e8a1d, fk314f4bd9912d5fe6, fk314f4bd91194a56e,
fk314f4bd9ba625b23, fk314f4bd9f55e1619, fk314f4bd95a4e840,
fk314f4bd9a4d05db6, fk314f4bd9881615bb, fk314f4bd9ef4a17ab,
fk314f4bd9e80d6eca, fk314f4bd93bf320ce, primary, fk314f4bd9ca7bd985,
fk314f4bd9751e4ddc]
4464 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
4464 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4464 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4464 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fk7f72c4356250d1f4]
4475 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tsource
4475 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4475 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4475 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkc2e3418fbc5fbaa2, fkc2e3418fe2e1adad, primary, fkc2e3418f97bbcbf4]
4486 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tsources
4486 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, e_container, e_container_featureid,
econtainer_class]
4486 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4486 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fk9984f0c497bbcbf4]
4498 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.ttarget
4499 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4499 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4499 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkc3d14b05bc21d680, fkc3d14b0597bbcbf4, primary]
4511 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.ttargets
4512 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4512 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4512 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fkb658160e6d8bb6c2, fkb658160e97bbcbf4]
4524 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tthrow
4524 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4524 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4524 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkcc85cef26250d1f4, primary]
4536 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tto_any
4536 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4536 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4536 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkc48ddb9c6572bdd8, primary, fkc48ddb9cd9f64d67]
4547 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tto_anyattribute
4547 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4547 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4547 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkbb611e8097ada71d, fkbb611e804a794b83, primary, fkbb611e8012d999fb]
4571 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tto_mixed
4571 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4571 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4571 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkd92c41ab168c6b38, fkd92c41ab2258e398, primary, fkd92c41ab477e0a27]
4585 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tto
4585 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4586 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
4586 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary]
4596 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.ttopart
4596 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4596 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4596 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkc4959662ab692129, fkc495966297bbcbf4, primary]
4607 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.ttoparts
4607 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4607 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4607 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkce1d365197bbcbf4, primary]
4619 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tvalidate
4619 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
variables]
4619 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4619 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkda4b658a6250d1f4, primary]
4634 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tvariable
4635 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4635 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4635 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fke4871ef05854a3e7, fke4871ef097bbcbf4, fke4871ef04689dadf, primary]
4648 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tvariables
4648 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4648 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkac5cbf8397bbcbf4]
4648 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fkac5cbf8397bbcbf4]
4662 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.twait
4662 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tdeadlineexpr_until_e_id, tactivity_e_id, tdurationexpr_for_e_id,
4662 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk69a37e96250d1f4, fk69a37e991083a95, fk69a37e97fb4f30a]
4662 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk69a37e96250d1f4, fk69a37e991083a95, primary, fk69a37e97fb4f30a]
found: bpel20.twhile
tempty_empty_e_id, tcompensate_compensate_e_id, tforeach_foreach_e_id,
tbooleanexpr_condition_e_id]
4676 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkccaff33df1b7f950, fkccaff33d9c0ab34d, fkccaff33d9b2eccdb,
fkccaff33d9613b7a0, fkccaff33d33facaeb, fkccaff33ddda276b5,
fkccaff33dc60985c9, fkccaff33dc8c92a9e, fkccaff33d7196e053,
fkccaff33d729f7902, fkccaff33decb09a54, fkccaff33d3aea3f49,
fkccaff33d8844eb0c, fkccaff33ddccc970, fkccaff33d2816e85,
fkccaff33dea5c86e6, fkccaff33d269e02d2, fkccaff33de7d7d5fe,
fkccaff33daf7c3bfa, fkccaff33dbc773fdf, fkccaff33d74b91116,
fkccaff33db404e6f8, fkccaff33d6250d1f4]
4676 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
fkccaff33dc60985c9, fkccaff33d7196e053, fkccaff33dc8c92a9e,
fkccaff33d8844eb0c, primary, fkccaff33ddccc970, fkccaff33d2816e85,
4710 [main] INFO org.hibernate.tool.hbm2ddl.SchemaUpdate - schema
update complete
7734 [main] INFO org.hibernate.transaction.TransactionFactoryFactory -
Using default transaction strategy (direct JDBC transactions)
7736 [main] INFO
org.hibernate.transaction.TransactionManagerLookupFactory - No
TransactionManagerLookup configured (in JTA environment, use of
read-write or transactional second-level cache is not recommended)
7739 [main] INFO org.hibernate.hql.ast.ASTQueryTranslatorFactory -
Using ASTQueryTranslatorFactory
10362 [main] DEBUG org.hibernate.transaction.JDBCTransaction - begin
10362 [main] DEBUG org.hibernate.jdbc.ConnectionManager - opening JDBC
connection
10362 [main] DEBUG org.hibernate.transaction.JDBCTransaction - current
autocommit status: false
10362 [main] DEBUG org.hibernate.jdbc.JDBCContext - after transaction begin
10419 [main] DEBUG org.hibernate.hql.ast.QueryTranslatorImpl - parse()
- HQL: FROM TProcess as proc WHERE proc.name = ?
10430 [main] DEBUG org.hibernate.hql.ast.AST - --- HQL AST ---
\-[QUERY] 'query'
+-[SELECT_FROM] 'SELECT_FROM'
| \-[FROM] 'FROM'
| \-[RANGE] 'RANGE'
| +-[IDENT] 'TProcess'
| \-[ALIAS] 'proc'
\-[WHERE] 'WHERE'
\-[EQ] '='
+-[DOT] '.'
| +-[IDENT] 'proc'
| \-[IDENT] 'name'
\-[PARAM] '?'
10431 [main] DEBUG org.hibernate.hql.ast.ErrorCounter -
throwQueryException() : no errors
10467 [main] DEBUG org.hibernate.hql.antlr.HqlSqlBaseWalker - select <<
begin [level=1, statement=select]
10480 [main] DEBUG org.hibernate.hql.ast.tree.FromElement -
FromClause{level=1} : TProcess (proc) -> tprocess0_
10486 [main] DEBUG org.hibernate.hql.ast.tree.FromReferenceNode -
Resolved : proc -> tprocess0_.`textensibleelements_e_id`
10488 [main] DEBUG org.hibernate.hql.ast.tree.FromElement - handling
property dereference [TProcess (proc) -> name (class)]
10488 [main] DEBUG org.hibernate.hql.ast.tree.DotNode - getDataType() :
name -> org.hibernate.type.StringType@dd725b
10489 [main] DEBUG org.hibernate.hql.ast.tree.FromReferenceNode -
Resolved : proc.name -> tprocess0_.`name`
10490 [main] DEBUG org.hibernate.hql.antlr.HqlSqlBaseWalker - select :
finishing up [level=1, statement=select]
10490 [main] DEBUG org.hibernate.hql.ast.HqlSqlWalker - processQuery()
: ( SELECT ( FromClause{level=1} `tprocess` tprocess0_ ) ( WHERE ( = (
tprocess0_.`name` tprocess0_.`textensibleelements_e_id` name ) ? ) ) )
10496 [main] DEBUG org.hibernate.hql.ast.HqlSqlWalker - Derived SELECT
clause created.
10500 [main] DEBUG org.hibernate.hql.ast.util.JoinProcessor - Using
FROM fragment [`tprocess` tprocess0_ inner join `textensibleelements`
tprocess0_1_ on tprocess0_.`textensibleelements_e_id`=tprocess0_1_.e_id]
10500 [main] DEBUG org.hibernate.hql.antlr.HqlSqlBaseWalker - select >>
end [level=1, statement=select]
10503 [main] DEBUG org.hibernate.hql.ast.AST - --- SQL AST ---
\-[SELECT] QueryNode: 'SELECT' querySpaces
(`tprocess`,`textensibleelements`)
+-[SELECT_CLAUSE] SelectClause: '{derived select clause}'
| +-[SELECT_EXPR] SelectExpressionImpl:
'tprocess0_.`textensibleelements_e_id` as e1_0_'
{FromElement{explicit,not a collection join,not a fetch join,fetch
non-lazy
properties,classAlias=proc,role=null,tableName=`tprocess`,ta bleAlias=tprocess0_,origin=null,colums={,className=TProcess} }}
| \-[SQL_TOKEN] SqlFragment: 'tprocess0_1_.e_version as e2_0_,
tprocess0_.`textensions_extensions_e_id` as textensi2_67_,
tprocess0_.`tpartnerlinks_partnerlinks_e_id` as tpartner3_67_,
tprocess0_.`tmessageexchanges_messageexchanges_e_id` as tmessage4_67_,
tprocess0_.`tvariables_variables_e_id` as tvariables5_67_,
tprocess0_.`tcorrelationsets_correlationsets_e_id` as tcorrela6_67_,
tprocess0_.`tfaulthandlers_faulthandlers_e_id` as tfaultha7_67_,
tprocess0_.`teventhandlers_eventhandlers_e_id` as teventha8_67_,
tprocess0_.`tassign_assign_e_id` as tassign9_67_,
tprocess0_.`tcompensate_compensate_e_id` as tcompen10_67_,
tprocess0_.`tcompensatescope_compensatescope_e_id` as tcompen11_67_,
tprocess0_.`tempty_empty_e_id` as tempty12_67_,
tprocess0_.`texit_exit_e_id` as texit13_67_,
tprocess0_.`textensionactivity_extensionactivity_e_id` as textens14_67_,
tprocess0_.`tflow_flow_e_id` as tflow15_67_,
tprocess0_.`tforeach_foreach_e_id` as tforeach16_67_,
tprocess0_.`tif_if_e_id` as tif17_67_, tprocess0_.`tinvoke_invoke_e_id`
as tinvoke18_67_, tprocess0_.`tpick_pick_e_id` as tpick19_67_,
tprocess0_.`treceive_receive_e_id` as treceive20_67_,
tprocess0_.`trepeatuntil_repeatuntil_e_id` as trepeat21_67_,
tprocess0_.`treply_reply_e_id` as treply22_67_,
tprocess0_.`trethrow_rethrow_e_id` as trethrow23_67_,
tprocess0_.`tscope_scope_e_id` as tscope24_67_,
tprocess0_.`tsequence_sequence_e_id` as tsequence25_67_,
tprocess0_.`tthrow_throw_e_id` as tthrow26_67_,
tprocess0_.`tvalidate_validate_e_id` as tvalidate27_67_,
tprocess0_.`twait_wait_e_id` as twait28_67_,
tprocess0_.`twhile_while_e_id` as twhile29_67_,
tprocess0_.`exitonstandardfault` as exitons30_67_,
tprocess0_.`expressionlanguage` as express31_67_, tprocess0_.`name` as
name32_67_, tprocess0_.`querylanguage` as queryla33_67_,
tprocess0_.`suppressjoinfailure` as suppres34_67_,
tprocess0_.`targetnamespace` as targetn35_67_'
+-[FROM] FromClause: 'FROM' FromClause{level=1,
fromElementCounter=1, fromElements=1, fromElementByClassAlias=[proc],
fromElementByTableAlias=[tprocess0_], fromElementsByPath=[],
collectionJoinFromElementsByPath=[], impliedElements=[]}
| \-[FROM_FRAGMENT] FromElement: '`tprocess` tprocess0_ inner join
`textensibleelements` tprocess0_1_ on
tprocess0_.`textensibleelements_e_id`=tprocess0_1_.e_id'
non-lazy
\-[WHERE] SqlNode: 'WHERE'
\-[EQ] BinaryLogicOperatorNode: '='
+-[DOT] DotNode: 'tprocess0_.`name`'
{propertyName=name,dereferenceType=4,propertyPath=name,path= proc.name,tableAlias=tprocess0_,className=TProcess,classAlia s=proc}
| +-[ALIAS_REF] IdentNode:
'tprocess0_.`textensibleelements_e_id`' {alias=proc, className=TProcess,
tableAlias=tprocess0_}
| \-[IDENT] IdentNode: 'name' {originalText=name}
\-[PARAM] ParameterNode: '?' {ordinal=0,
expectedType=org.hibernate.type.StringType@dd725b}
10504 [main] DEBUG org.hibernate.hql.ast.ErrorCounter -
10514 [main] DEBUG org.hibernate.hql.ast.QueryTranslatorImpl - HQL:
10514 [main] DEBUG org.hibernate.hql.ast.QueryTranslatorImpl - SQL:
select tprocess0_.`textensibleelements_e_id` as e1_0_,
tprocess0_.`targetnamespace` as targetn35_67_ from `tprocess` tprocess0_
inner join `textensibleelements` tprocess0_1_ on
tprocess0_.`textensibleelements_e_id`=tprocess0_1_.e_id where
tprocess0_.`name`=?
10514 [main] DEBUG org.hibernate.hql.ast.ErrorCounter -
10529 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - about to open
PreparedStatement (open PreparedStatements: 0, globally: 0)
10529 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - preparing statement
10541 [main] DEBUG org.hibernate.type.StringType - binding
'loanapproval' to parameter: 1
10568 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - about to open
ResultSet (open ResultSets: 0, globally: 0)
10569 [main] DEBUG org.hibernate.type.LongType - returning '43' as
column: e1_0_
10575 [main] DEBUG org.hibernate.type.IntegerType - returning '0' as
column: e2_0_
10575 [main] DEBUG org.hibernate.type.LongType - returning null as
column: textensi2_67_
10575 [main] DEBUG org.hibernate.type.LongType - returning '1' as
column: tpartner3_67_
column: tmessage4_67_
10575 [main] DEBUG org.hibernate.type.LongType - returning '5' as
column: tvariables5_67_
column: tcorrela6_67_
column: tfaultha7_67_
column: teventha8_67_
column: tassign9_67_
column: tcompen10_67_
column: tcompen11_67_
column: tempty12_67_
column: texit13_67_
column: textens14_67_
10575 [main] DEBUG org.hibernate.type.LongType - returning '16' as
column: tflow15_67_
column: tforeach16_67_
column: tif17_67_
column: tinvoke18_67_
column: tpick19_67_
column: treceive20_67_
column: trepeat21_67_
10576 [main] DEBUG org.hibernate.type.LongType - returning null as
column: treply22_67_
column: trethrow23_67_
column: tscope24_67_
column: tsequence25_67_
column: tthrow26_67_
column: tvalidate27_67_
column: twait28_67_
column: twhile29_67_
10576 [main] DEBUG org.hibernate.type.StringType - returning
'urn:oasis:names:tc:wsbpel:2.0:sublang:xpath1.0' as column: express31_67_
'loanapproval' as column: name32_67_
'urn:oasis:names:tc:wsbpel:2.0:sublang:xpath1.0' as column: queryla33_67_
'http://loanapproval' as column: targetn35_67_
10577 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - about to close
ResultSet (open ResultSets: 1, globally: 1)
PreparedStatement (open PreparedStatements: 1, globally: 1)
10577 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - closing statement
10588 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - about to open
10588 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - preparing statement
10588 [main] DEBUG org.hibernate.type.LongType - binding '1' to
parameter: 1
10600 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - about to open
10601 [main] DEBUG org.hibernate.type.IntegerType - returning '1' as
colum
Re: Persist EObject from BPEL20.XSD [message #96178 is a reply to message #96145] Thu, 06 September 2007 12:51 Go to previous messageGo to next message
You can also try the single table persistence strategy to reduce the number of tables. Although it
depends on the model (everything can end up in one table if there is one single root class).
Another thing you can try: if there is a single root type and all ereferences are pointing to more
specific types (than the root type) then you can 'get rid of' the root type table by setting the
root type as a mappedsuperclass.
gr. Martin
> try this tomorrow.
> Thanks in advance
> Daniel Gerlach
> [activity_tscope_scope_e_id, activity_trethrow_rethrow_e_id,
> fme_feature, id, tflow_activity_e_id, activity_treply_reply_e_id,
> activity_textensionactivity_extensionactivity_e_id,
> activity_twhile_while_e_id,
> activity_tcompensatescope_compensatescope_e_id,
> activity_tcompensate_compensate_e_id, activity_twait_wait_e_id,
> activity_texit_exit_e_id, activity_trepeatuntil_repeatuntil_e_id,
> activity_treceive_receive_e_id, activity_tassign_assign_e_id,
> activity_tforeach_foreach_e_id, activity_tpick_pick_e_id,
> activity_tthrow_throw_e_id, activity_tsequence_sequence_e_id,
> activity_tvalidate_validate_e_id, activity_tif_if_e_id,
> activity_tinvoke_invoke_e_id, activity_tempty_empty_e_id,
> activity_tflow_flow_e_id, e_version, tflow_activity_idx]
> fk5fa3f30cb21fa670]
> fk5fa3f30ca4d05db6, fk5fa3f30c2d134fd2, fk5fa3f30cdc3e820,
> fk5fa3f30c7ab94da2, fk5fa3f30c1194a56e, fk5fa3f30c76eb16af,
> fk5fa3f30c3bf320ce, fk5fa3f30cef4a17ab, fk5fa3f30cb21fa670,
> fk5fa3f30ce2157499]
> found: bpel20.tflow
> [tlinks_links_e_id, tactivity_e_id, e_container, e_container_featureid,
> econtainer_class]
> keys: [fk692a7a2a4e47a, fk692a7a26250d1f4]
> [countername, parallel, tscope_scope_e_id,
> tcompletioncondition_completioncondition_e_id, tactivity_e_id,
> e_container, e_container_featureid, texpression_finalcountervalue_e_id,
> econtainer_class, texpression_startcountervalue_e_id]
> keys: [fke9a3b756cff03b28, fke9a3b756bc773fdf, fke9a3b7566250d1f4,
> fke9a3b75696018c54, fke9a3b75638f4edbc]
> [any_endpointreference, any_property, any_tliteral_literal_e_id,
> any_expressionlanguage, fme_mixed_text, any_part, mixed_tfrom_any_e_id,
> fme_feature, any_partnerlink, mixed_tfrom_any_idx, id,
> any_tquery_query_e_id, fme_mixed_comment, fme_mixed_cdata, any_variable,
> e_version]
> keys: [fke4d7284b65231871, fke4d7284b6572bdd8, fke4d7284b9ef01207]
> [id, any_tfrom_anyattribute_e_id, mixed_tfrom_anyattribute_e_id,
> tfrom_anyattribute_idx, mixed_tfrom_anyattribute_idx,
> tfrom_anyattribute_e_id, any_tfrom_anyattribute_idx, e_version,
> fme_feature]
> keys: [fka901a6b14c4b3621, fka901a6b14b0aa659, fka901a6b12a2f1afb]
> [mixed_endpointreference, any_tfrom_mixed_idx, any_tfrom_mixed_e_id,
> fme_mixed_text, mixed_tliteral_literal_e_id, fme_feature,
> tfrom_mixed_idx, tfrom_mixed_e_id, id, mixed_partnerlink,
> fme_mixed_comment, mixed_part, fme_mixed_cdata, mixed_variable,
> mixed_tquery_query_e_id, e_version, mixed_expressionlanguage,
> mixed_property]
> keys: [fkc551e9afa0b2ff8, fkc551e9aa32347d8, fkc551e9a477e0a27,
> fkc551e9a7d01a540]
> fkc551e9a7d01a540]
> found: bpel20.tfrom
> [endpointreference, partnerlink, e_container, property,
> e_container_featureid, part, expressionlanguage, e_version,
> keys: []
> [primary]
> [tfromparts_frompart_idx, textensibleelements_e_id, tovariable,
> tfromparts_frompart_e_id, e_container, e_container_featureid, part,
> econtainer_class]
> keys: [fke4dee31197bbcbf4, fke4dee311c40fa8fc]
> econtainer_class]
> keys: [fkb6fd7f8297bbcbf4]
> found: bpel20.tif
> [tvalidate_validate_e_id, tassign_assign_e_id, tif_if_e_id,
> tthrow_throw_e_id, twait_wait_e_id, e_container, econtainer_class,
> trethrow_rethrow_e_id, twhile_while_e_id, tactivity_e_id,
> tactivitycontainer_else_e_id, tforeach_foreach_e_id,
> fk1c091e7d7d5fe, fk1c09133facaeb, fk1c091f1b7f950, fk1c091af7c3bfa,
> fk1c0913aea3f49, fk1c091ea5c86e6, fk1c091ecb09a54, fk1c091729f7902,
> fk1c09174b91116]
> fk1c0919613b7a0]
> [textensibleelements_e_id, location, importtype, e_container,
> e_container_featureid, tprocess_import_idx, econtainer_class,
> tprocess_import_e_id, namespace]
> keys: [fkb1b44d1956120046, fkb1b44d1997bbcbf4]
> [tcorrelationswithpattern_correlations_e_id, ttoparts_toparts_e_id,
> tactivitycontainer_compensationhandler_e_id, operation,
> tactivitycontainer_catchall_e_id, tfromparts_fromparts_e_id, porttype,
> tactivity_e_id, inputvariable, partnerlink, e_container_featureid,
> outputvariable]
> keys: [fkb1c51dec60a9400e, fkb1c51decdcbc374e, fkb1c51decb6630ceb,
> fkb1c51decb6e0161d, fkb1c51decf25c1d63, fkb1c51dec6250d1f4]
> found: bpel20.tlink
> [textensibleelements_e_id, tlinks_link_idx, name, e_container,
> e_container_featureid, econtainer_class, tlinks_link_e_id]
> keys: [fk695566e330b0425, fk695566e97bbcbf4]
> econtainer_class]
> keys: [fkcc1577c597bbcbf4]
> [id, fme_mixed_comment, fme_mixed_cdata, mixed_tliteral_any_e_id,
> fme_mixed_text, mixed_tliteral_any_idx, e_version, fme_feature]
> keys: [fke41dc9687a8d60df]
> [id, fme_mixed_comment, fme_mixed_cdata, tliteral_mixed_idx,
> fme_mixed_text, tliteral_mixed_e_id, any_tliteral_mixed_e_id, e_version,
> fme_feature, any_tliteral_mixed_idx]
> keys: [fk5477ec77ea11cbb8, fk5477ec778b04f892]
> [e_container, e_container_featureid, e_version, econtainer_class, e_id]
> keys: []
> [primary]
> [tmessageexchanges_messageexchange_idx, textensibleelements_e_id, name,
> tmessageexchanges_messageexchange_e_id, e_container,
> keys: [fkd87c2036cb4b5609, fkd87c203697bbcbf4]
> econtainer_class]
> keys: [fk3707e6fd97bbcbf4]
> [tdurationexpr_repeatevery_e_id, tscope_scope_e_id,
> textensibleelements_e_id, teventhandlers_onalarm_idx,
> teventhandlers_onalarm_e_id, tdurationexpr_repeatevery1_e_id,
> tdeadlineexpr_until_e_id, tdurationexpr_for_e_id, e_container,
> fk2afc387c2038ad3e, fk2afc387cbc773fdf, fk2afc387ce416e1e1,
> fk2afc387c97bbcbf4]
> fk2afc387c97bbcbf4]
> tinvoke_invoke_e_id, e_container_featureid, tpick_onalarm_e_id,
> tflow_flow_e_id, tcompensatescope_compensatescope_e_id,
> treply_reply_e_id, tdeadlineexpr_until_e_id, tdurationexpr_for_e_id,
> tcompensate_compensate_e_id, tpick_onalarm_idx, tforeach_foreach_e_id]
> keys: [fkd81d75ff9613b7a0, fkd81d75ff2816e85, fkd81d75fff1b7f950,
> fkd81d75ffdda276b5, fkd81d75ff9c0ab34d, fkd81d75ff74b91116,
> fkd81d75ff7196e053, fkd81d75ff9b2eccdb, fkd81d75ffe7d7d5fe,
> fkd81d75ff729f7902, fkd81d75ffdccc970, fkd81d75ff8844eb0c,
> fkd81d75ffc8c92a9e, fkd81d75ff97bbcbf4, fkd81d75ff91083a95,
> fkd81d75ff269e02d2, fkd81d75ffecb09a54, fkd81d75ff33facaeb,
> fkd81d75ffa772ef81, fkd81d75ff7fb4f30a, fkd81d75ffaf7c3bfa,
> fkd81d75ffbc773fdf]
> fkd81d75ffea5c86e6, fkd81d75ffc60985c9, fkd81d75ff3aea3f49,
> fkd81d75ffbc773fdf]
> [teventhandlers_onevent_e_id, tonmsgcommon_e_id, element,
> tscope_scope_e_id, teventhandlers_onevent_idx, messagetype, e_container,
> keys: [fkc3578d2761f1a7b4, fkc3578d2757c6af38, fkc3578d27bc773fdf]
> variable]
> econtainer_class]
> found: bpel20.tpick
> createinstance]
> fme_feature]
> fme_feature]
> keys: []
> [primary]
> tpick_pick_e_id, textensionactivity_extensionactivity_e_id,
> treceive_receive_e_id, tinvoke_invoke_e_id, e_container_featureid,
> treply_reply_e_id, tsequence_sequence_e_id,
> trepeatuntil_repeatuntil_e_id, trethrow_rethrow_e_id,
> fk314f4bd9751e4ddc]
> fk314f4bd9751e4ddc]
> econtainer_class]
> found: bpel20.tto
> keys: []
> [primary]
> econtainer_class]
> econtainer_class]
> variables]
> econtainer_class]
> found: bpel20.twait
> 4675 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
> 4675 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
> update complete
> 7736 [main] INFO
> connection
> begin
> \-[QUERY] 'query'
> | \-[FROM] 'FROM'
> | \-[RANGE] 'RANGE'
> | \-[ALIAS] 'proc'
> \-[WHERE] 'WHERE'
> \-[EQ] '='
> +-[DOT] '.'
> | +-[IDENT] 'proc'
> | \-[IDENT] 'name'
> \-[PARAM] '?'
> clause created.
> non-lazy
> non-lazy
> inner join `tex
Re: Persist EObject from BPEL20.XSD [message #96452 is a reply to message #96145] Tue, 11 September 2007 10:58 Go to previous messageGo to next message
I solved the problem with the MySQL problem: (Too many tables; MySQL can
only use 61 tables in a join )
I changed the max_fetch_depth to 0 in the hibernate.properties.
Code:
hibernateProperties.setProperty(Environment.MAX_FETCH_DEPTH, "0");
A 0 disables default outer join fetching. Now it works.
Greetings
Daniel Gerlach
Re: Persist EObject from BPEL20.XSD [message #96468 is a reply to message #96452] Tue, 11 September 2007 12:59 Go to previous message
Hi Daniel,
Thanks for the update on this.
gr. Martin
> Code:
> Greetings
> Daniel Gerlach
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Persist EObject from BPEL20.XSD [message #609587 is a reply to message #94853] Thu, 30 August 2007 08:12 Go to previous message
Hi Daniel,
It will take a few days (in/after the weekend) before I can look at this further.
gr. Martin
> i want to persist an Object of the following XML-Schema:
> http://docs.oasis-open.org/wsbpel/2.0/OS/process/executable/ ws-bpel_executable.xsd
> So, i generated the Ecore-model. Then i loaded an BPEL-XML(the xml file
> is added) into EMF and i want to persist this file in my database with
> Teneo.
> I use the newest Teneo 0.8 build, eclipse3.3, Java 1.6u2 and hibernate
> 3.2.4SP1.
> The generation of the hibernate-mapping and the database schema was
> successful.
> But if i want to persist an Object of the loaded BPEL-file, especially
> the TProcess-object because it comes right after the DocumentRoot. But i
> always get an hibernate-error. I have tried to change the mapping-file
> manually but it didn't work.
> My Code:
> package org.teneo.test;
> import java.io.File;
> import java.io.FileWriter;
> import java.io.IOException;
> import java.util.Properties;
> import org.eclipse.emf.common.util.EList;
> import org.eclipse.emf.common.util.TreeIterator;
> import org.eclipse.emf.common.util.URI;
> import org.eclipse.emf.ecore.EObject;
> import org.eclipse.emf.ecore.EPackage;
> import org.eclipse.emf.ecore.resource.Resource;
> import org.eclipse.emf.ecore.resource.ResourceSet;
> import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
> import org.eclipse.emf.teneo.PersistenceOptions;
> import org.eclipse.emf.teneo.hibernate.HbDataStore;
> import org.eclipse.emf.teneo.hibernate.HbHelper;
> import org.hibernate.Session;
> import org.hibernate.SessionFactory;
> import org.hibernate.cfg.Environment;
> import org.open.oasis.docs.wsbpel._2._0.process.executable.Document Root;
> import
> org.open.oasis.docs.wsbpel._2._0.process.executable.Executab lePackage;
> import org.open.oasis.docs.wsbpel._2._0.process.executable.TFlow;
> import org.open.oasis.docs.wsbpel._2._0.process.executable.TProcess ;
> import
> org.open.oasis.docs.wsbpel._2._0.process.executable.util.Exe cutableResourceFactoryImpl;
> import org.w3.xml._1998.namespace.NamespacePackage;
> public class Test2 {
> public static void main(String[] args) {
> // initDB();
> // createDatabase();
> persistResource();
> // persistRootFromXML();
> // loadBPELFileFromDB();
> public static void createDatabase() {
> HbDataStore dataStore = initDB();
> dataStore.initialize();
> public static HbDataStore initDB() {
> final String dataStoreName = "bpel20";
> final HbDataStore dataStore = (HbDataStore) HbHelper.INSTANCE
> .createRegisterDataStore(dataStoreName);
> Properties hibernateProperties = new Properties();
> hibernateProperties.setProperty(Environment.DRIVER,
> "org.postgresql.Driver");
> hibernateProperties.setProperty(Environment.USER, "postgres");
> hibernateProperties.setProperty(Environment.URL,
> "jdbc:postgresql://127.0.0.1:5432/bpel20");
> hibernateProperties.setProperty(Environment.PASS, "XXXXX");
> hibernateProperties.setProperty(Environment.DIALECT,
> "org.hibernate.dialect.PostgreSQLDialect");
> dataStore.setHibernateProperties(hibernateProperties);
> Properties persistenceOptions = new Properties();
> persistenceOptions.setProperty(PersistenceOptions.INHERITANC E_MAPPING,
> "JOINED");
> PersistenceOptions.FETCH_CONTAINMENT_EAGERLY, "true");
> PersistenceOptions.SET_CASCADE_ALL_ON_CONTAINMENT, "true");
> persistenceOptions.setProperty(PersistenceOptions.USE_MAPPIN G_FILE,
> "true");
> dataStore.setPersistenceProperties(persistenceOptions);
> dataStore.setEPackages(new EPackage[] {
> ExecutablePackage.eINSTANCE,
> NamespacePackage.eINSTANCE });
> return dataStore;
> public static void persistResource() {
> TProcess process = loadProcessFromFile();
> // init Session
> final SessionFactory sessionFactory =
> dataStore.getSessionFactory();
> final Session session = sessionFactory.openSession();
> // start Transaction
> session.beginTransaction();
> session.save(process);
> session.getTransaction().commit();
> session.close();
> public static TProcess loadProcessFromFile() {
> TProcess process = null;
> // Create a resource set to hold the resources.
> ResourceSet resourceSet = new ResourceSetImpl();
> // Register the appropriate resource factory to handle all file
> // extensions.
> resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap()
> .put(Resource.Factory.Registry.DEFAULT_EXTENSION,
> new ExecutableResourceFactoryImpl());
> // Register the package to ensure it is available during loading.
> resourceSet.getPackageRegistry().put(ExecutablePackage.eNS_U RI,
> ExecutablePackage.eINSTANCE);
> // Demand load resource for this file.
> File file = new File(
> "c:\\eclipse\\workspace\\BPEL20\\bpel20Example.bpel");
> URI uri = URI.createFileURI(file.getAbsolutePath());
> Resource resource = resourceSet.getResource(uri, true);
> System.out.println("Loaded " + uri);
> // Validate the contents of the loaded resource.
> for (EObject eObject : resource.getContents()) {
> System.out.println("Klasse des EObjects: " +
> eObject.getClass());
> DocumentRoot docuRoot = (DocumentRoot) eObject;
> for (TreeIterator<EObject> it = docuRoot.eAllContents(); it
> .hasNext();) {
> EObject eObject2 = it.next();
> // System.out.println("Alle Klassen des rootObjekts: "
> // + eObject2.getClass());
> if (eObject2 instanceof TProcess) {
> process = (TProcess) eObject2;
> return process;
> The following error occurs:
> 15548 [main] DEBUG org.hibernate.type.LongType - binding '91' to
> parameter: 3
> 15548 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - Executing batch
> 15579 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - about to close
> 15579 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - closing statement
> 15579 [main] ERROR org.hibernate.util.JDBCExceptionReporter -
> Batch-Eintrag 0 update "texpression_mixed" set
> "texpression_mixed_e_id"=87, "texpression_mixed_idx"=0 where id=88 wurde
> abgebrochen. Rufen Sie 'getNextException' auf, um die Ursache zu erfahren.
> 15579 [main] ERROR org.hibernate.util.JDBCExceptionReporter - ERROR:
> insert or update on table "texpression_mixed" violates foreign key
> constraint "fk987fc8082ce0ea45"
> Detail: Key (texpression_mixed_e_id)=(87) is not present in table
> "texpression_any".
> 15579 [main] ERROR org.hibernate.event.def.AbstractFlushingEventListener
> - Could not synchronize database state with session
> org.hibernate.exception.ConstraintViolationException: Could not execute
> JDBC batch update
> at
> org.hibernate.exception.SQLStateConverter.convert(SQLStateCo nverter.java:71)
> at
> org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExce ptionHelper.java:43)
> at
> org.hibernate.jdbc.AbstractBatcher.executeBatch(AbstractBatc her.java:253)
> at
> org.hibernate.jdbc.AbstractBatcher.prepareStatement(Abstract Batcher.java:92)
> at
> org.hibernate.jdbc.AbstractBatcher.prepareStatement(Abstract Batcher.java:87)
> at
> org.hibernate.jdbc.AbstractBatcher.prepareBatchStatement(Abs tractBatcher.java:222)
> at
> org.hibernate.persister.collection.AbstractCollectionPersist er.recreate(AbstractCollectionPersister.java:1119)
> at
> org.hibernate.action.CollectionRecreateAction.execute(Collec tionRecreateAction.java:26)
> at org.hibernate.engine.ActionQueue.execute(ActionQueue.java:25 0)
> at
> org.hibernate.engine.ActionQueue.executeActions(ActionQueue. java:234)
> at
> org.hibernate.engine.ActionQueue.executeActions(ActionQueue. java:145)
> at
> org.hibernate.event.def.AbstractFlushingEventListener.perfor mExecutions(AbstractFlushingEventListener.java:298)
> at
> org.hibernate.event.def.DefaultFlushEventListener.onFlush(De faultFlushEventListener.java:27)
> at org.hibernate.impl.SessionImpl.flush(SessionImpl.java:1000)
> at org.hibernate.impl.SessionImpl.managedFlush(SessionImpl.java :338)
> at
> org.hibernate.transaction.JDBCTransaction.commit(JDBCTransac tion.java:106)
> at org.teneo.test.MainTest.persistResource(MainTest.java:171)
> at org.teneo.test.MainTest.main(MainTest.java:38)
> Caused by: java.sql.BatchUpdateException: Batch-Eintrag 0 update
> "texpression_mixed" set "texpression_mixed_e_id"=87,
> "texpression_mixed_idx"=0 where id=88 wurde abgebrochen. Rufen Sie
> at
> org.postgresql.jdbc2.AbstractJdbc2Statement$BatchResultHandl er.handleError(AbstractJdbc2Statement.java:2534)
> at
> org.postgresql.core.v3.QueryExecutorImpl.processResults(Quer yExecutorImpl.java:1317)
> at
> org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecut orImpl.java:350)
> at
> org.postgresql.jdbc2.AbstractJdbc2Statement.executeBatch(Abs tractJdbc2Statement.java:2596)
> at
> org.hibernate.jdbc.BatchingBatcher.doExecuteBatch(BatchingBa tcher.java:48)
> at
> org.hibernate.jdbc.AbstractBatcher.executeBatch(AbstractBatc her.java:246)
> ... 15 more
> 15579 [main] DEBUG org.hibernate.jdbc.ConnectionManager - registering
> flush end
> With kind regards
> Daniel Gerlach
The Netherlands
Re: Persist EObject from BPEL20.XSD [message #609593 is a reply to message #94995] Thu, 30 August 2007 12:03 Go to previous message
thank you for looking at it. I hope you can help me:)
Daniel Gerlach
Martin Taal schrieb:
> Hi Daniel,
> further.
> gr. Martin
>> file is added) into EMF and i want to persist this file in my database
>> with Teneo.
>> 3.2.4SP1.
>> successful.
>> i always get an hibernate-error. I have tried to change the
>> mapping-file manually but it didn't work.
>> My Code:
>> import
>> import
>> // initDB();
>> persistResource();
>> "JOINED");
>> "true");
>> "true");
>> return dataStore;
>> // init Session
>> session.close();
>> // extensions.
>> .hasNext();) {
>> return process;
>> parameter: 3
>> batch size: 2
>> close PreparedStatement (open PreparedStatements: 1, globally: 1)
>> statement
>> wurde abgebrochen. Rufen Sie 'getNextException' auf, um die Ursache
>> zu erfahren.
>> "texpression_any".
>> 15579 [main] ERROR
>> org.hibernate.event.def.AbstractFlushingEventListener - Could not
>> execute JDBC batch update
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 15 more
>> flush end
>> With kind regards
>> Daniel Gerlach
Re: Persist EObject from BPEL20.XSD [message #609616 is a reply to message #94853] Sun, 02 September 2007 06:02 Go to previous message
Hi Daniel,
In the test code you use the org.w3.xml._1998.namespace.NamespacePackage, where
Where can I find the ecore/xsd for this epackage?
Or can you provide the generated java code.
gr. Martin
> Teneo.
> 3.2.4SP1.
> successful.
> My Code:
> import
> import
> // initDB();
> persistResource();
> "JOINED");
> "true");
> return dataStore;
> // init Session
> session.close();
> // extensions.
> .hasNext();) {
> return process;
> parameter: 3
> "texpression_any".
> JDBC batch update
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 15 more
> flush end
> With kind regards
> Daniel Gerlach
The Netherlands
Re: Persist EObject from BPEL20.XSD [message #609619 is a reply to message #95438] Sun, 02 September 2007 08:50 Go to previous message
--------------090208090303020303020103
Martin,
I would have expected the Ecore plugin's XMLNamespacePackage to be
reused for this and in any case, for the generated package will look the
same as it. The schema is here:
<http://www.w3.org/2001/xml.xsd>
Martin Taal wrote:
> Hi Daniel,
> gr. Martin
>> database with Teneo.
>> hibernate 3.2.4SP1.
>> successful.
>> especially the TProcess-object because it comes right after the
>> DocumentRoot. But i always get an hibernate-error. I have tried to
>> change the mapping-file manually but it didn't work.
>> My Code:
>> import
>> import
>> // initDB();
>> persistResource();
>> "JOINED");
>> "true");
>> "true");
>> return dataStore;
>> // init Session
>> session.close();
>> // extensions.
>> loading.
>> .hasNext();) {
>> return process;
>> parameter: 3
>> batch size: 2
>> statement
>> zu erfahren.
>> "texpression_any".
>> 15579 [main] ERROR
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 15 more
>> registering flush end
>> With kind regards
>> Daniel Gerlach
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Martin,<br>
<br>
the same as it.
Re: Persist EObject from BPEL20.XSD [message #609622 is a reply to message #95487] Sun, 02 September 2007 17:46 Go to previous message
the namespace-XSD is an import in the
In line 19 you can find the imported XML-Schema:
<xsd:import namespace="http://www.w3.org/XML/1998/namespace"
schemaLocation="http://www.w3.org/2001/xml.xsd"/>
So i created a normal EMF-project with eclipse3.3 and generated the
EClasses from the XML-schema mentioned above:
This generated all needed packages, including the EClasses for the
namespace-XML-schema: http://www.w3.org/2001/xml.xsd
With kind regards and
Thanks in advance for looking at my problem
Daniel Gerlach
Re: Persist EObject from BPEL20.XSD [message #609623 is a reply to message #95532] Sun, 02 September 2007 18:18 Go to previous message
--------------090700050606070407020503
Daniel,
On the last page of the import wizard, there is the option to reuse the
XMLNamespace package that already exists in the Ecore plugin. It would
seem better to reuse that rather than generate a duplicate of it.
Aren't you getting a warning in the Error log indicating more than one
package is registered for the namespace
"http://www.w3.org/XML/1998/namespace" because of you duplicate
registration for the following registration in the Ecore plugin.xml?
<extension point="org.eclipse.emf.ecore.generated_package">
<package uri="http://www.w3.org/XML/1998/namespace"
class="org.eclipse.emf.ecore.xml.namespace.XMLNamespacePackage "
genModel="model/XMLNamespace.genmodel" />
</extension>
> With kind regards and Thanks in advance for looking at my problem
> Daniel Gerlach
Content-Type: multipart/related;
boundary="------------070002080408090805080902"
--------------070002080408090805080902
<html>
<head>
</head>
Daniel,<br>
<br>
Re: Persist EObject from BPEL20.XSD [message #609626 is a reply to message #95545] Mon, 03 September 2007 03:42 Go to previous message
--------------050106090405080900020509
i don't have any warning or any error. I added a few screenshots of how
i generated the Ecore-model. But i didn't see an option to reference an
existing generator model at the last step of the wizard.
But I don't think that's the problem. The Ecore model seems fine because
i am able to load and parse instances of the XML-Schema. I can write
them in a normal file, too. Only the database doesn't work.
For me, the problem lies in the generated hibernate-mapping-xml, because
i get a "foreign constraint violation error"(see my first posting) when
i want to persist an EObject of the
and the error is thrown for an EObject of the BPEL-XSD and not of the
Namespace-XSD.
Daniel Gerlach
Ed Merks schrieb:
> Daniel,
> </extension>
Content-Type: application/octet-stream;
name="pics.rar"
Content-Disposition: attachment;
filename="pics.rar"
UmFyIRoHAM+QcwAADQAAAAAAAAD8MXQgkDUA61IAAGZ2AAACqOBb0HtKIzcd MxAAIAAAAHNj
cmVlbnNob3QwNC5qcGcA8Py0bBAdkNEM1VFYDVnstoosIsoko2WUegkXkWEe jbPQll9FFhFl
HoGz06i+i0j0Cikj0AmCykSiSvY0tazOb1pJWmNbze85mcjmexnN8jkbu7gV VASJEyBIkTIE
1f8p4JZEuR5+limIA+FfAVHlCK+Of8fQAGEtHSkcAGBgD/XC/QHx0gCJ+5ig qLivXGBcWFxo
ZGBsfLCAfHR0fNCcpIiw9Nj8+PDY7Ou8krif3kVYRjo7UWxSWF9iZ2hnQE5w 8DeyOy4ys7H9
hIGDI0ND/ZHzMgIDNjQztDY/+t8+NyAGesGsYaeBwYTAA0ZDA7/W+N6AAhSk Df3EMAf6dA0P
/exASEQtIoDH76HBoZ1v6US64gH/YG+wWH/QkQGxztqUZG5BohKark9kmVGE JN1hqxuLm+1v
pJzY3ODlEYnByjhEoQ5yrRWR+uh2dKrv2FL+FGO0Gfj5/ZZgZ+wIBaIuGQo6 +dYcHfez/+l/
OlSGzVC7Zp7A5hfbommydTyA9w+OiAFf4CFM99QACCA5z6VjaPYnomcoCpQM MXsFSFBgHR8D
NvLp/Acv9lk+xbwWcq8NJO8/je+sudFD3dTQYwGprhpBrNl06UzLMumdr7pH SEC8KeAssStS
75cvB3gM5jBrFbKZSwER6w3qEGzJa9hbLrZWevYqviAKMQnj/aeZ4IkA02z5 rlcHPG1Relr6
JlsJ103FMyVqPuLm35jmSpWU0dmKULWlR6klXlq5nx3j+KPm9ZHtguRFJinK 5H67Sbmb7JaO
ck77Y0B4EZiIgo0wCNcZZxTMw8KTCdN+pV0x3hUCrI7/2FRitGxf4ELfYKE0 7odMk656z1BP
cUPW6Zc6YWnKjxxzPA8ulSM+WACdd+JmDFrs+tI7Zk+kc9x0jC94OWu4Uq/a iV9XPwTdzN1F
Mg+n0ovPBHturnRwaFFqHaK7Fc1cJRXQj5lpAcOWy9YPpqiiDYmX90LPVdM4 X3fO2MfqWHLd
+zrzKQx/7xYoGJ+/lmQkG27emUSpraWy3qTdMSK78/lo0Mho1ZKHWakkvJut TMmG8D3iFMqw
BgIQlqkLJB5dKWjR9e4XQecaD0WITwIENZqjet4KtSYQ1f4CJ8xCcJ7bOcII IYQnZuwq1JJZ
iGWfWCleol6PHP5ao0Ve0Z9xj5GAR1/NN2BySrWBSrCdUMF7Uy0yjadHZGOv ONBZax5mIeOP
atHx0XkadTRamjEjauyc35tyst5xV9lzkbzEGSfqS2hBb3PGO8KmODhFhSP1 PTDJxg4un9Mt
P6/OL7CZ9VyjhehJxnwpN+SLm4ugFZ392I/lfY+U5+AErSemGxEE59f70BTE BsFZqf2RgdqP
j0AarhHot+Ae/fwpP3b5KBQ58DCFtHHOZAgfw+5+QIxX6AcFZRjQRZV9DnQp GCPCs49F8Jcz
DPp5AeK97Ue9C8bZ5Ps7WCbnqftfxJnKbZhChNCiT3qc/knH9Nzu/IlpDjTU KTahxzevqK+a
iWhwsN9yFTmQc+YEcjCA99yDxn35VYBtB12IVw0f8+Up+aaqhIM2Luf8+DQO Lv2uOS7sqJcS
l2/1pK+vpl9zkYRsYZlbomUT712YUPxeErjIUlp3B4z/8hJH8qCkCPeyvH93 2ynFcbtvER9s
FPEmoex/pF/8p3SPW/I1ZV/By/75xl/QX/AQyppkreOXQtNp+1vJ816jf9FL uMqHO/Omwalt
SygDKS6JVvD5G6u7959f6U/cHm44yN2IWpzpQ4mO590fNa2MHEsfv1eXgLPn VrTAp2cUGq/+
Qivy1FR62k1FzA5Q5BNtzQ7yEmKJraM3ynnZ/pKl3vcj3RlGMwtmD0ax78QE RRwDXRT05EZB
qYS6PzFPhHYJHzYoIn1vi38+lviIoyetqzvkrD7jOKyujeVgWpE+0GCONOFm 1FwF1rjBb95A
r5wRQBJDclbytaD26g0WWonot8tfh0poJqRKLf6Xm+IZPnjBFWn4LHcrMflU xMhN0tdRYrEN
gnippAwhihtKB1UPJ5fYx4udtrJZa6KsDbO3ly3nsVemZtJsHHePlM5OjtSU 7J8SWh9lOnCT
aHsAyPEmY3zAc9eKhZtbJpz1SmxEsxu95zrM263yp/e8gNYY4+HnjeBmGe8K 5cvw3zweGlGD
NsVyT6y/wqQ8trU5nO76yz1SDFkFEOfZCmKef3C3np53qHIZp7s+FSPSJOdK TdIfwuu0O9fK
ac/+e2Y/Bh0KPJOsrGtO1guKUQtcKzYJaDzzHH9yyBc4YUM5LhvPgyvXhThf tC3vqXlUmerA
qTi05GPJKeJy6NkjpwnzJVlJ6XkHxF1mqEyJHNqbAlfK+WnmSO3BEqEWDxpk nFyR2vc7LckU
vrGG8i1gUMwk6AQkMf1DtDg17FSLXmUi/wo2l4jrOBx+jIHe6TGiXpppQNGb a/vfSWyjVW/N
tSULnvxCKpq0VzwvhDvG0g2z1MQLZm56io8kqfamOvWEyP2s/JeBRPDKIy3F TScFlfkxiZK2
3T4mGHhpIz6bbzHrVFwtWnVb3QZ2L+2m2R7MH2kt3N0rooElwWe8lm8KXcBB WYPtIEnXt1G2
+CsP8+YA928XGsQw27xbod+45G78L0hEnbKR/wXqx3Pn6xzU9D3q11hEfhzA 6PZJscPV13Pj
ruPy3wp3LU5z6mDmTixuzjfs1TIpP7Kwu6ybdQjDkX/PB7Tk3GDY5At6X72j 8+/YOEicoE+y
5xglJ55PGjtVsw2etzvSkO8xDK2oS+i1v5QxWHZ/fvWQM3YWDmdKQF/fJeOQ e6qwzDKtvWLM
b++NpfptR7UALbkpU2bn4lnws3xs5kuYm9Ws3SgMvs3upLup6kQeT7W2s4+7 a/Qwe/TuO9IK
yaTosaeH6FrXPjUUFPic2Epzm7QZWnAVpBz+ZftEhDUN/4Y9H3yMzEKimisN 07DfPN5YW7wy
9tBAKm56ApKyqGDMSUtEX6hm1Xndgs/Tbbof6ouKeNq9YjWQy0yyJz6UxGpP ueicO0vjQrrv
xB0/rTVimA/yGOj+TQ0R67+K+E56lg46VIpDgGvwEG6X+CD3UKer6YxlCL8h v5sDcKUwWdtC
JQoflKsgTHyGnxkGGl/unZ+WS7881l/cr1A/qX4Li6pq4m/Yd/uWzR2SP+Ql RLmCj2zj8eX5
NWg9gMlLy2bzO/B/c4vwWPsFdatnPxOUH5wlCjWqhj3+TYr//WD1kp8sfJCf 7w+hU0MXkHyh
8+VhUwq75oFn8bX/xN/hNZqbBGswjBo/vTjoMcGWk0TELAUUd2/lDj8VDYKU wS/wZ00wrnlI
4tHn6FDgq9B9w07SHAR1PjQguWBu72/tEgzUODYRKf5o4vHueBPNpfv5ykVw n9cg35zihUy2
rHm+BQ6b2YKPz1KbX80ad+RkFFIJNmQ+HciKYclwwQqKNWeWQuCnJ86zM/CT eUv1RX4KFU00
nl6UUKOcvqLwKRWTMaW+F7C06Vr4S/M9WyoDVnOZn4NWGVvuHTOBAYtmq8LK W8fxAaeHqrPC
rFWDFUWWkvfTH2xBRPeX9kQ0W+Uz0uJUH+AXWob3zsbNqlJxDKQw7GiAs/yC wbcijmZla9Sx
GTj4W1pDA0b56yBGkHj8c+1amPtL25zYeWxdMmz5cF5qi9CGpZ5iiKBj9yub R3nm4uES9ZG+
Br5aPsWqv82b0krdBQ3QnQIMy726wVp41qZms35kMI0rvCtEOK5RS9Ndeyt1 eVK87Ye/Zspc
/GR2Xx8ESJm8Cm7Sbj5r8KCIwQa1EvbNzMR6gWsvjqyJAV8I3rxbI2wZsGRN 3kUVUMLb5G00
u7X+kLwEe9Vmbg+n5sdtkq7RZp5ZjXBSTemLWpN5+3aTCxK2Qab9TdA83Gb5 9xWRlnRsUhpm
DA6WWjzfLUGcc1FoUpuZJwFQhVa/sT3Z7SGcv2fftXofG0A4ZkHpnPP629/9 Yy8zCxhLStmc
zLXdk8sqxs7pGkSmkNYB7z5/Q9B1PKn7UnYVfoIdhICx5Zn8Vghtnw1cQSn0 Wca1xKHrZRc+
O9KZnCTuHZq9KV/OqC0peP4c4gfzb0MiGkMBVcsfEJVKwFuomv9YXy81Vycu F2jjywM/7arV
iPLcmHe8IaCITNiELQYBTJeyaLTLiyOoz0Cr9FAlGwL051MNfT+NMBzLWm0E JsFRNnA3b2Ew
zW50/v/DENb/v2MrnZWbMKcvzI78/lNhUHo3G9pSAlt6tY4mGTd+poz4RAvU 7/RpE2oE8nYD
hv9Blt2yJbxd6r5UXtTGG1mmkaqU1mfenu+cFbTuvVe5F2bOorWx4rozHONK o6SLrnhmYbEL
aNcmubXkAqyw/IRa+xY6PHa1KXsBd3dzqcp+WIGQDlHZgupiQO+KKFWY6DIT AmhTjmVPm0QW
jhX+wl0bjatC0lL22PkhCzDF/IRR76O6u+Xnga393cXpOXk/ysxdPHnxAe0j iioqqtVp5kid
Uj2pbJSnpxLUJvfo4lbHScaa4yqyrck0F+IM5UHoSrkQbPYPdYdtZXQvMxlI a+QNacpdVyU6
+n3GTzEOAnsTSDw/ZqbOdYqCFb28YyEjRBwfWg3z/qyQyrmdy5E5BHsLvl3t N/ai4WqGxj4n
NxhyVd4WFAbbkzzXvjoFos+mtQ91mMmDbsuGRdyKzXP3UJUuD33my45a6ywr lJqBcnmj45wO
bQUqjCVeGSIc5ZsRhySds9rzFTyGm7vlmmwxu8LHNSO7/VIA68dBulatIjWh hCd7BKg1wJ3I
sSz3SoQP4zQvC00rTgTp1TmN9csK1zztIe4197XPgZacfHqsQHO3/gG76H6N 0uLxkHCTKKYV
CjrFxh0hrdPnV/sbAPM7XOH+dLbojDwsyZaHKJ3Ojw6k2Pb+GgTyBwOrJEBL /b12NewH7OOL
v03PG/DxGZ6Eg9JL1o8Bhht8O4VhZpELWFzzkGbXLJuLvgbSoCVg15setUPM pRvUcygEHbPA
pVrtrZQASjkOp2mfpaCmh8FKUhzfEb7IPjsOrPSy0FHWJ6dMiLwV5KVKsDGa XeVATs0KRCJl
2JAlsW5ptOqVTQjiN/YwgBiztmZSgtOqdBSO7JVgnhy89rf+cRU2PsPgCieO xL4ZHHYU6ldj
JuYH+3Q0GDTQpCsrR+MR9Pb3BuJHXYqWq00cJYPSqwoBrcfXPvHy8hV9qkcK 3juPC6oU7PeS
u0DV21v4kKSvlH28yKAjW7nqdbJk2HjGUh5/z/iR+V4VoCiAj3kAWBYarOu0 uRHnCITJQraD
y0jPfq7mKyrLxNykNXooybXYQEkFtEdOyQFZUP0TYiMmlCCOKenGvySB6Tm4 4RRrcTVo0ihQ
B5/pdbOg9ERNT39P3k1uB3JTPV2pegRh+DQkkeiXXdn2hEKqWDuFghlq1OGr Lr60qx0hVap2
coGVCKdDNvcf4TEa8L67hV0GXXH7ylKpdPfo9d7t6Gci5PwiX/9FZ+jdss85 pJ8cWeqfL4/H
fikNK0dB8EhS3VtkjIw6HIoGB+sOswuLWf7rR/yiEdHDjkz1tdFoKDBd2F7j lJeFPMbDdtKr
+9PmFNT+MR9woclm/flzaAgDkJWdYm9GmOdpGEyhkTr4n0b/TFLLPXJXsO6A s6zkQe6vn9oU
Qjm9bHgWtH1CN1EIjoumpn9M2XNrEQGDVe6jmiYmDSbMFkU4DL8TnY40vokw b3SWPUKxBC1F
97Or+vBpyFQjaRMi1+x3poI8FinSGWHoveRVFrh3iYzbaochaWDLNpr+Tfy0 MTnAopJSb+sh
ctJZZxrRQYCF7XDT3JLCsfUTYhFfE3XvZim+tH9oRr6fOqLvCtd3cINXOTOz dVY8QSHjnvgj
963NegwArjp2K2p31f0QpcCaNXdaLHiXECZyoa9xK8GD26RqaCLhlxPqYC6P rVTwqHcY7C1g
c9rVhdVqQi1xORpTRKQbht1l2kmZWCXLSork59tnWdfcZaR1SNBcc2rG1sc9 PNlmNwPWYGyI
nmnM3e20U8ZjPvpiCiQlVp6V3RhyoE3s7/FaLMv8a3v2zMwUUSk3MRwODQAz +Mt1S6nPh+Do
40Yj9oZHtsiRHGss2MRVif+c5cNl63890KoVxoRZXv6bZH/nN+MjBfrTDni/ hX6K1IpKvhGl
4cqHzan9iLQDoTIxaqsNHC9GDH690Ptj13WLsmMJyeyvsiPE0opduSa8XfJ7 oDj3kZGLy4oo
XjDfX5N1mzNb4yp0f6fmtJalXNFqUcLPnYVIwhBkqWtD72UzeC+iW2rcsczB wxlAHDlsYS1S
U02Q9gMk6R2w+5lhtymPrfawHqPslAS+CnU/KOGUJWd0Tj/ePmCd5mJsshwk OI2IdF1EpNBX
4lXolRS5MWYa3rhYwbaoP9rMbcZQ+vZYiH6a3OXbjcXxDr4tsNP5/L2fcXnH CanqwPZaBLHd
e/I4BcEyUUXBnJ722tksBHew1H4CSuSAN/jKBzN5NhZnDs77fCPlC3Sh9oPo /5bbqu74Pjzf
iv+XLGxXmQ3aHOwINeRHjR91q66PmXQe4M9it2izhlq3rhi3HOZoUnzicZrG 5wUbtHPqD2rM
olnmwxwaVcrLRfvXEd2lxcR0c6L1OW29XmsLFYBc6L9NzOYw1pHamubPkQsh VHCV8Eb7hvJs
lrfjLhUcpBA20hm1XRSqmx72nQ7gNwg9ihctJ4ksOoAwXZqW47tM6yrOCwj4 inelkyxkA5v0
hWfSh5Rm5RkcLLV7ehJkotpskGbRcmWeq/2V+XbpVgNBZ38eq7jZZsQsG4ub bC3AspDR/n4Y
/m2c0vF46dhBPL1AhntOZnSIpIcLsezsqq+LEGytePVx03EHefq4ifmmeb6W 9rMa9Ck0+25K
+n8KjOUJhjV9VimwJZEPZai4po3IGRGWPIy+66HiCl0bJGqyexMej7U/uQLE RB/NZWjpx0tE
djWJuhXZqPcp2imEhmn21v2dNdYG5iyPE/5DeZ9ELUoCk8prGx4XvH9FR5+/ onTSprnmuCv5
xyhhpEQPcyBIzL1bBUExL2svrlSYSteVoUJv3I3J3n1xAWejZZOw78SYoQNo WSXMztNJH4sB
QilNdOOAGODkDXNKhbsrLu+bVuiJNrvVbe29IFDh4n0j2CAuSdujWg9Gxhaz MvBayyVZleal
FIkM5lf79qiykfrFxbrDKPmyWoRk99tDLifaqEHvVJa8NgojbKTA/3pzMJkW NIyzv/SJCj+K
GeWLYcGS8bXz1yGSGy/HNVGXUZKytJr4U7JE0wDL9h6iR2BXc0e2zGwqJdqr WrdLDV5xH7xs
Z4ho6bzTF+zEC5wifb8R0M2FZknG7Wc/GhYEhaJNxeRFGEoDryd5t8PaIFpx 3hJjMbxsoRa0
dC5VVpNDslK8oZLDvkc8YgZGuvvALEsg+47u3w2+vpcGgIdwXJypGY0aCLYe z7p3n3gHqYdf
ujGaZ0l4qNaN6nQy1FGlkIEJITci5vfb3w33wjdK9W92K90GSh5tmVGa+Mau jenxlRKFXFBA
Vs8bHN/o3GSGWPtL02mpoGqU7SbymCoGWN4BEPKPpm+1gNzeAGXCS8zTSeZa jJjaZRkpWpAV
2DQVrzatp8zxAOBIWJZ3kVsrt5vaLFNOViiJgU0Vkq+b9A6ceZDzg+Yn8pF9 r7wrSBWmgRxZ
DLCv5QOG62PEjp1ScfSRnHSFwn0t5HOop05dYPiA7CIpRRsp8QwZXWRCcAli n5BFIe+TTuzP
U1Rw6VFLxxNAQ5ixrZhDsgSurl300BtB6cw/CF9T2Es6K0cedgoRhYGSxKym S5962RhngxmY
jSydI1iMmzJt74cWMVVZRWa0WudUcKQtTViY0QBi1x5TGXhMCjPXIt0fD1CW p+kqKUIEl7NX
JihrvspUPTyEu1phhgA8PxXO7n7vnZJMT7TS4z1eIwSbUjhjITB4QI4judgr xmzT7CPToi/L
T8a4wDJzOLRQ0lCDWyiHyE2aSSDsSiJ3BIGOnV6jRSP5ZpGeYqTi8tTxZAqf qjve5WubqEh+
3N6FXWsNjrU7XKWlAQcxKeIV27T0RF5R5D2yJ1m0rl1g/Ms3SDIKdn3oaLQ7 aAqUcUSB00+o
GzU8hKijEzyV1E3o0gLEqDl16or3GYrKZkLrN9yS6jxMRhMc7tscsBbz3kF4 DORfbAcUjgrC
rb0JXiE+F6qOgiMdJ3YGD6MBnELrt2TWIS4NcW1qrrPPL0T9SWlJMVVoc5ip XVxxPJpDn6KU
c57b3NLgX02Fu0BS5lssE6yMOI722g6oQMl5NPWb3+AuoCR3RHYvRh3OXTeZ piKJmdOTIeYb
TzTv+aIcoErWRRqD+PfznoHRV+KBn4TEZKmAwJvfARnRUdb3Fvo4eaErK9ba drEZRFM/hGgM
UvgYw5ZYxezb2FtsWq3GjjkdE9L35rn8GuzKUV0V/Wohd8NUdJ9C/k6vmYIG GzxZ6HV3dICp
SNe8UBFjC4v/Ako5XaztEGY4DLEkOuf9oXU6bwr+IFNEwS7IjdFE3UR8/NBM 2QGtZx71bBJC
Pox54r2Ar/QGlS3/wIeUIVEAj7WJSQiHQe9bQEJnUzUvrkGgLaVISDzUk5eu FLnVndfdQR0B
fw6eDc6tQibZ1le13lvSW1YyZi55nNxhCVSLo2FX4razsTt87121pCSR1E5b wgwwsoyGDIx2
TCobI2e6mz3v1pZ6DtZMkJhiGp3IzgEKTnxCj4FzGNMp4zHugmpgI58fH6iC xo7Ri+kTasHJ
7RMcJVwhDvAzIxQHKJrO/TbkXyxVYsUEyll4/BCgJsPFWZKXuVZm2oZuvCLi 4QNjccY3xAZP
zd4T8VGDiJkcYxHjsKroZ6dYopCYnEt18YlVHwQhyUjyONSsCqeM2kKdzsZF WfRJjxIwLcl5
bWYNN/cU9g6UFKTeREn8Vpse4KKquGSqJkJNsjeZnyOfYrguwFrh2K8FJ5cs f3ycxrSD+n6Y
DRwYxKkzU8nkBUg/PROnY/crCPhnsfc55N+FpAXRm6DuA2y7KlN7qrQ6+Vp3 HQe/T8dO70y/
S0HOqPLavKsbwCqQ59SC3KUNyssypkjrapkN+XG10N5L4GvsmcELsDNKXbTz GrU7reVmJH86
eVmqlQXm764CpCCwOapIQFF165zijI2grnU6cDbMQPNbEHOPPaVFVpmJ9Eb+ OkgCw4RAkN+b
7brKFybGSjzqGgu24t9C6jOn93Vzshtn6LAPpNTlraPxqJlB6fD7OjDWoD0+ J7oM0x286xBc
4sVIGJ4yvhTv0RfZzNTQD1512o5CkBP3vTaq0mFEO8VOUQR5fTws9k13o88i xlEmIqNMD45M
QwfKmS4N0suabiuJ0F7DdQKi3iY0kZl4b5ir9CXThk//Ppj5brVNmbXtJpys vpQQl+Exvsgy
hVT7VGAwciFSlM4UCszBpFd/Du++UoybPjl+1JVH6caSZDJyRH9tFEne6gcR 1EswtCBe1NKd
3RWZLPJlPWHt4nBvpgUOnKA9BWFfXjmNHG+mJIes3ONfLJ65wLUlLIHfJtlb kNZkM+w0xF7o
Z2bbz1I3qajlJUs/Q9/1Q6c+3PxAXdUykUI7J+vXg2ZxU61ZvZ5XHE2dqzMT 05A2mboL0je5
lJv9cvNsrkXgOWOmBys8t9P/BmItEyVHt+8+UOcgy5IeirSkMjAyMhn/dSKc VyPP01++w2rF
Kkc9u9/dyrL57lvI7v+XW5eQfuGbtcnb9wOes8jw4htuonqzkZiXe2vO/Oet MqK8jejF/BAR
UWcY1vT96lFNqs8bkmRwMFd5QZOw6fiB9tiXvw9J1l964UrTEs0tEBfNNcIP R774/LBYmdvI
0mWaaEciDEbwXt6/tsvH1rIZzctOBMXZxhu08BO9E4LDvh+2mchwx8pyb27I pipOl8v6TejO
TBZKCLLTLIR2ntl1cFVy6NZ7y0MPUH7f65zmuo9kZT9U0o43kr1w6lqyIO3G Y1WPVYAWRdMa
EcyDNZb1z1Bk8L+0zjxsA6TRWmIFvHFlLaZ7fYvshtJTJ9uVJyPar6kHLXjO AbQTY9PBx2Sn
ix1W3PrVXwE1ioXPEPMcgcqjFrMTkX6FYUFaPd2utVig4buy2GjDCcEXIeTb INqL31kFj9Yg
8h3TtjJNc8cvmZkrUrWN7JfoGBjSNaHR7FMLMMOe7F1AWnmpPek52XY30czd k3h5UtRipx7o
jk4IH2kh76m8xD7C5Btle/0nkQIAdlCvaLJrwvB/CnMtskJ3yOelSfAd15lD +z7Ui/+7IQ0R
bO0lLHYfikAms6ml71KV4tHRzWmOOI1tMF3qKiomkmGsvFHHCwz5kwb64kjc lviZUka+enlE
pv8ps3ZusD4/Crp9L8QG29mzYCrK6rOItOKVxVrPpmWT0jrsVWOnRPRTFUot sEVfUAhcTTfj
/EGkJNBwUUdLt4777v3WfMZFo9j/QOn4QRliiDnP4Z1iXQuLtu45fIpNNKcc UHs0F4Yn4q3Q
lYGGD7ERl9f+gavHCiAhuVtNvis0OklO2Q9kZVEgpTkpzyT7uLh9oWUtnC3f Ks3ObY4k72nH
gLxxIga97L6oz3t/qRPliqS/16IRAxe8C90CYut50ETsoVz0r7SQvmKMxzcy WWEn7wRNCmA7
JDvnHzIPl+/X2ANS8mZTz31aFcAtkvLJwyzxNucGcJwtrvIDzqcQ5cfIOInw ShWajbSQscDd
57dDYuZj/Tjyo9KlmEuk6zN5MEU6wv2qKKVE+1Ola5QNDqAt5EYZdcrRacmG BAjAcOX7bDgF
jTeo48RxbvymVglR0LTTeRUI71lDCXYRJ6kguU7Yq2mTXCu00dJJXzKeKznq eGXpPtp2nmJN
0TklC7WnksTOsqgWpaceNnA6+Q9bHvBuM0z9fUusWoo9K6qdIXer90hUk4YS KMPuiYW9tl9k
FiEBk9ye4XOCpr82q11V0mFDaPA8+/i3uM68CuUkSJ7ZRKI6QBLq+z9VURsf OlLmjC6FHOTD
uPVhA7ylU5XsCbipBqCYN8ELvOJX97XchfSptS9yX4RvwFmCnIQ24JSglhdp DtDl9C7VVvQQ
iqzKZOslf7U6WYA09aSd1NtrwY1qhE6jm6QMSVo8s4Y9dZQPHSURGmxdnjnP eXxutp7K7IBR
IV6z1U7TtdbntuvFWip7JXBNy5A3FC7biniq9h5mgZdwHHdmSNzNYfyGksdX aJ3IIHVHV6hW
+3l5dYzKKfp124s6MZE95irRNjryQ6V8MiuMElehyOyxi/ZJCYj4ciMnNsAP VIaokaw9G+bw
/EmePZN2oiK+YUqHVZojZMEB+gCT9R4wlYa5GzEIfvgyIobVykpKMrnGCTn6 1GRFYciHSo6w
sQcFKs1fwUmI/b+dYug82ybeYOUdc4cljDJu8Dom1c94MXFUFw8ApmEvwsaX BMMCmLUjntPy
suzJ3pXUHJldZx+vmS9TcH6pnA4N1S/lZhynOmS+/DEQt7YhpMWTmQupRE6E NdWWfBEq/pcG
OGXfGY7b9TlShAxmfOPSJEkKDH0QRCbtfaGKcmJSxNwEobksFfG4pEzwwn5l wZ9Soi9miotJ
HwH0oCW6RI4JR4mJw290A5gDgXn2X/rL/XFBMRZFfKvlvXRg8BBqLrgwJCJb I+sv0qsis1KI
ukbY9iced/cr+pMRufndRag816hX75bj8qBY4uudLg+4sx6ZZE/MtM53ZKUX ViDiYbQCc9T1
RU/ZNmZmopDGG9pUjJEPVpTyL/SSJjfpURVIq2qTznKyW4VSdO7jaBdHSMEi hOMqW9SEbfwX
pY/dEjJCikTn8x2g9u2kzOkCqdedbgfMusiFfSXlPnYPbQ+vu7oIDKbDcMWi vwdzPOFzd3Vd
H3GjaiH71PLa0EdYO66F5KSJLrsiKpLDXHy6N3W30yIvHMe8ToY5avNC52MJ 6/mgwL1DVUGe
aGRWLwfMDmNEBPYUeyohSXaZ0fBdhp2VD05TLmNu7Qsf5eXAlPoSvSm7egZh qh19ucF3lkwV
IADKK0jXto9OjcMgLymF7EyfibruHVUTO4ne2z8CHyO30wWFD7trs22vU3jd 2h9vwd45frN/
7bfFkLnvuGXQ+2qPNVpjeJrhb+Bn/hpoThxGQByI2cKFvCTVoTiDbeWz+ic8 chKHnnfQ1bTK
m0K0nKypJOh3AyknW2dZ3JFA2LmuOztbVHRqPcKF29uK9bl6meAN0j3WfuNr uqcYjutTHQ+F
0CJXC4IvoyWx4YrADnkSwrNTjiAjaenr7ttdXWjc43sIu7NN3vAPVG46WKO5 P8NP4SfpThnp
9T1ieynU2WFO9zjftxNOic7zyPZ3dw6Dtf6SDyRTlWGOdxQkwjEROtdGAZbH XWslshQNbThf
zX9tg+r3IGy7KiK9vEy5HxeM7BctNUum4Hj8mSjcTaLFDm+bzCUNYjzxN8zj CEv/gELfwd/s
sYwmoQg9fi2aD8CZWh0I0D+zx/g0Sn4JtX/cb0YWMgk1NrT8vXaPweSzejf/ 4wtQOXJ+1HVw
ZgxD8FwoU7/fYyQYMqRkZmTd6Nolo6bnWeTmHOrwXjAfbPB3Y7zx2nhSTEyV aZCzdWgirLZI
UHcUHPzhlveNwL/dhvTKewXAsCzqj/1GI9ZxGKLgQSTWwVMuGTG4793Klp6s 6zXVCcuoUWhw
MJOvW8X3raw8Xc3Wj+5DucNY4NdpqL8mgyBwtqt7Cc2z/TwPKJK3qpa3oRI1 ex9lOJ7yVhLJ
g8BmRMs12D3zOu3vVgzu1/5Sx+T8zeipRdPO2Fz0l6JorQGWDlBElu9xIWi2 Z1Wuf4u/9/94
WqdFCpI/nQsmu7VctXVgS2Qdjn4N3gHDxmPVOoBzRzVCPbuh1R3nAyMcZrMN yNf4be8HN2tD
8KP0sv1mJ8ox1yylnv35Qkr+IK/DjrMBhAdBzOiDmEgcrwhqun2gqJ8wdz7k xgyfsQ41d5w3
BjeRlepb3JOJS5k7isLkehGn5pmW79qEhddKjK2TXFhAWfM0mkNeeABeQXWe uQ6qLlznaw+C
Ml5Gs1HEcdPck4aTEJBnBzOQguQUXAyvdOJBO/X3yker6awLSKpy+x1fQ+yr 7MRS8J29ASkK
8ACRAQ+u9+/lAySPa2Lzl+dj1yxlYxdxgmkpeGaY7RHi9nNH0xtcrgqzW5Hr XTUviSfjdDoH
M+59rr5NVBi9eprDxzWu1HLSOlyHXWDj1vHtIGGYENHyYy/Oa/I5tS79Zmfa IvVryf4L1dMv
x2M3hcNT1JI8mf20ghk/W/mwHizKvvNvrnafcESv1kl/+hV2LnwOFB51rE6N a205AVdW8f81
R8DwlqSk5cixCVonQkD+SbMqGF7X4gNb1q0yEf95OQpVSohv03lYfDtt1aVR If2WOLq6R5OD
BRYHrqemdguVUEUtG5GJ2QHX0TqtGCCOmzEakmDyESicpBulb2jodt6tnGcH 8YZFH3tuLcOi
EeaLCzk4DVHx5YwPCKGwuMfDdbl2nybHJZLYChdFgYjQkicLZC+90493mQOT I+9VjTbiifc4
oV0Sem/N8o7PZBYvBRhdY1LKA830x3mua7eP2elYvWum3+1jR/k/uuqS//iX rf9nVy/NJPJY
88P79Gwp3SHvOtxQnROnrZpNWe/Ty/SlyB9sxsbUqrH5JqWdGL7M4tfZxSS5 QnUqBeOuPTPQ
v/lG7UKq/Ww/6ZinqEFIbvctSdVF7yCzrOsi0J5KMxX5G3ZN41nPeknovot/ OuJPq0auqwHV
lCo/gNj0bQok2sISbndVYdnzATipGskXEQ41jSbrEY6IxeIZV/B0R+nWk85O x++LmTWoE4nV
kRB1Y0eWemOShDWiIy9dBGyl1lJDteIpXRVJpuS+ZSYmLmU4N6tCQ+ww+2Ko 6JrrT5pMW+It
3Xv83PznEfyKauQJYl5ZNymNqriIeLPtphADdMLM61nctJcdHhkQMsxFAwIj ZfwUnR04c5zr
O1QBOvAsbJA64pu7df9ej2p8M/cUbRY1rrXLY+p+FYo2OVDqKdyYfVGrpBk6 eAus+q1M0Cgk
NiXpu7JLc3XKmKo7faKu/jWqJUJjZkOsqD06dGjaMmGYG/4WONPSH3WeMZ1b ZglW0pWFx0lw
cUW2gzHstiKN4Q1EjizCRI2T8gIQZTW2CUL2w4sT1IA6yWy+QavlBL0PEMQl AZSIhKJVU2zr
lszEqLxANM4cucaYYsvKOaCHKAqGMRMECELWFqxZpkfrG2t+aM4XiTGxXsC0 I/dwCT3LkJc6
6x7XYVKnJdadw15KJU6OlohDP2GSMr6l2IwYIRKuMa61lbb8WXzPtG6vMkFH ybZbpFo0tawy
y+tyf+sHvxkQqCPTyLQX7NFRhd25k6o/q6xX9MaRaO8+vSHgYuacfEAa1m/H ou1jb+nNJ5CU
MbLFmmfAQl2LgZf6zAtAxECjymQQmXAV/G99z/eJWynhqlHVcIlaKcXoxPtO YtI93aYmy+w2
yiXaGmmIhL8b3qiZQ2J/XPmYlwDTEcvYf1DgP1CyLQFS6wQo6VD+atgEuiER idTVMplzVudb
JRDPxDdSsj2aFNhkdx9Z5UXQ0IinaTGY73ox20Ad1AC47yEtcy1iOYRGDmeN NByRhZvywcEe
Xeri7Y7Zt7YFRpwTV9Zk1lVFoh8saKLOfP3uAeXoYz6U5tUHnYhWRRx/6aph Fn5/tSC/R3zE
oijsDxxtTPecFdYKqVFaOwHa6BY0ByqYCejKj3W2Cdbn1tF3ntJdQXUll5wD 0mx6dCncPgHP
nwRIkPdGAfUErnuMvMcLKwmN+IEcgwO0HTrznrOmHiRChT0uyLawvqeman4C E9sHPcWoUGeN
cEfcMYYi9oc2LFpG8K6N+iFMNOIGRpZ2UnlPhvK2g0hbs6pXwXWvI4ojS3BS ihSRR84HktE8
9ENAtM5Mc4G/8pi47EDfKZK5lYxMm+93dewxa3nPTLlirHLsUr+IlTzFR9ak sjDDwWKTyhAj
RD6ciPmYr5LTZf6zT7l6bWgh0Xi74aCPRKl5oh4i1aCMEBqkifESBxUrRtkk FPJ+GpdP4tLN
YYTeiGpFpBMMvK13YopKHA6k7KNNkHaId+/ODVmPG6dIFq5mV5RFsufKchhu z4Ktrh7xC0Ps
P03FRhS1mLyB9MqggONrIEVLfrcQQ/xWAnmg1PGXhe8xynq5/0qMqZJScOY1 HOXROs4F7fpK
8vEe+SgTn0eegueeoq0xfP2ZTnDVGKT/Wlj02hxIYWmNnOJ7j5H3Np0YIWSq cUGcJ5RqvnE1
ueImofBM6AETFm2KnIhNvEdiPBnh8kIteUSJYzsO24pWcwVMdAWcoRCmjtSB u/98SWX3o548
hhc5mKnYIz5VuptPFjOUu/XlPo+Qq11+i8UpCzk8gTFA0EiH7ATEyGbH7OQV YfiAw6UFnmrm
M3+QMx1udM5O58OCZD3pJSQ8zq+EzHQRlqDOVVhTye0ywpXgFESaJOyNLfiD HBj6pzw33WrJ
are4ItB68Hil+h2dHrNpNq5D1L99biA+PbLyO2IlrKvbKO3nDG2cF6rhTrrb zOWiZTCP7Ksb
SYq2MfmlGHcDg4jImFtia4g80furPpDJyKSzgNFQ17NlsUvKthuO9n0I6rx/ EcY0+DaSQ2mm
ucW7gbbRMxsUbRd8Hby6YKqV7YqLRGvWJu25anuO7fPbUool0fRyT6XSCJao 2RPGh4eWwMMi
RSY/t35yvTVJv1peasdY/7gGSdmF8OUPauBkMspQDSzzmxIE+Istnp6LzsAW DGPq/1y/riH6
9DGLbuijzqPbsatXv0qbGMUXakQcuC42J8NHteac5W23xYvXtEg0h/BSPCzv 95AoFgOyMrv+
C8WEKyQ1jLIuHS5aSJwXMzBv80UHaT2JbgYkTv8nJL+ZLzaCQAdYAsks3H8N bWPMXeCxtSFU
ceXU0fPgEH0QNlyRNK75tCy6elQjWTbQPWTkV8tVmJzmmvt1I6Hd2rzsh4zH NVzKA6TdA0v0
8Sv/df7PnocZpEcBizTVlGCiSXNVwYjNyllwhAdvOPb58y3UWg6Rv+rGxCTW OeR40kk8JFGb
GROsiuWe+05ZA3M0xT0rzzKaWwqpVQtrjKRaqdmqY/PPrNwIv5U605xzSCNE AeP2YLxPpxb5
SJ4brbd2mVHnqvFRYI4cGANmZPKGn2h0V0i5Op358b4NsISOh24z7GyYTin+ Q2UbacGGV09Q
LJA0filfPSbOzc9mjk1eoqKSBS2piI+VVOPYgLBpIg5QySmzl0eC3t32nc9f Bc1O0WD08MzI
hWWR4dLDNJsBSHSC/tksX8mWIRlidF7k7Ya5gzwOBJhTx+hupoiiPMAxkEwx bRNd+cZKYPg0
8+4/xd24Xa98T6h/x7QY2ENxTczMN8lEkhdyk4C5ixDkYgaV8O8tr8aWL4Gd +lVztyomG6uK
0lM011Z+TgjYqyTcBspRjKcvhBJGDs2mfBSyddVSNwz4itzCzKCwdJqRQ/Hc lw8ppnNLphzF
/LoVBytO7o2GXsJdEve/SSCGKfhk47w3FkAtydz08UVKO7fyGNPgm6HLXTVB JDfs6tFGX33j
tPPQ8SzLoVr7WfsODH3FzDKdTzRWdtRX201pxDpuZ0yOvZiBkWMBgxrhGmTH ugZCH7c9pY2d
kujUIL2DXuKvk7TLQufYFzExb2/4I5VXaXM+BMdTS8KBShcqyxjcEbZkABnI MsORVtdA/Hqz
WuEnLaWpwpPML+4aUW5Ghope17Lk9SFHLIWVMC+Ha/7ia7IXaBjXz7ptrNQS A8H8uje1Y8Zb
bx3yJAzVG7bVHr/RHRmYLpjpC6t65mWtjkz0M37MxO8ZJq/W036Zq1YwO7EE m0XXFIgCNJ6q
eZAvhhzJ4DreuiO4nHz6ZS6nGl+zMf1820XDI3jxlINmR2MXi5sjJ180iHlo zJq26mzXPCP6
Jn7Immp9cy2l4lZbgB4zHmQ2MPMotexGOY7xzbWzVHihbuX3ZPhq/4cDwZ64 LYw8uesuxld8
Vcm3KxHQ33JCdssXpXjk6YW/OUHn1pa1L2QJ7Q3NrgIni8/Sv4Pf1o+ruiiN SQJD+7bVpdTm
dmpfMiRhW5hBUciBdgDM/FtOc4c+oUuFJFanFjmqEZsRWHeWwmxDsUSW2oqT nUCsw1QfkRjU
0FKvKc3kQCfKp0k4EqZLto0kK3rbZ2zSVhTII1PLpryvwZDHZouQ0Qun5BnH lmazgKS3WdrF
Y1LG7c5O7Oa62GIQgbtTXH2HW0Fel0TEYhjnIfBlMtJTMKjvxGnnOli1bePW 9suikaN7/OkK
AoaMcgc+klPfUG3vGHdHq+vM+vnBCaqAf3PKOEsn9Ex450d8RG3JtnEhXzFe hKMvN8mAq4Io
ixb6ok9tDxAkJtnO+uB7yiAnWKy5XNcBj5KB35E/zEdIErv3ETbFYtvNgwbd 3kLQc8irxQeu
DXPYmAtUMOdzTruZLggK1QZWq94La6WLrNOgPPQupGVMLwIFaWI7Tp7YEY8J UgrxeI8YzkUw
TsewIe8jVKk+H3S8iJy29jza6M0olEWCytriAzep6STK1Lu9wDOXkpCoRIuh TOHk6zTd7TnD
efX43fMwAmaeXU/rikDDLnPX1CpWLmopHAs5sMDVKoLZ5Rj0H66de4x4MIXg zXrweu6MwwRS
lDHXq4kNwmAd+eNucwjV5AEcn8c+KqUo87qi8zWZZO8E9AtXm8v3t8Enr0df E87OC7obCm7K
MtXDiQ7F+c6xkAHFK80c0WBG0sQH/ONTU/JtKp6zMNNGSTgd2npupEPXtG0d ONzMTV7gl7dZ
lQ5O3nlskxRK3hJvdVc7gYzxDvVki1ySOQ7itUz4RNL1Vab7VnEN8h67UEJl Mhl+ZjXefSpQ
VqfuhSbXhcXTUB6q+VKH2e1OXc0mOzci2sRfZsHOLAyxwEPNFEXHKpYRHIsg WejYC1zE6ju4
qOl0lK2Le6btfSjAKG1bvEg4xXPL4vV2Y0RH5rHKzRaJp6jVMnfmmk2WivOx 9Y3g9NxgCwGA
Mipm0JrjX18FNdEitlSvAzi0P++biz+exOlEDG0h81Vqa8skL1qWqLIzqfMd DbB8QBem++Z8
TnZ57pEL07bCXz00UldFGWkgImVVULJAMnP3XdIQ7nCHEbh7iuqSN73oyzv/ N4pUA6budRt+
h1ElHDqeqM43aTCEaNkyQGO5G0zCRt+djpCxTmsuRKqqcJzkwthfswx0GR3k ydbuFErXDr+9
xricrdPruvRPoU5uAmw5ink8095vX2X1g6NMXUrrQeGrB7E3YsikiKDsWNDR uOvg6CGj4ZL3
MAo4oLDFVbsMBiK3Yi4U4vbXJ+G9Iob9o5rSs9k8g5mGIt0A+b4Tyy7gRtyv Fqe49iLQRriJ
HzMpAo8umooDMFR5zQvRbTrSRH7G76llZoJRhpUdMl+foE5rgk5Tkz1lepVg 1Z5nTQ3nzbVJ
8H8772hecxuGqUf7db8OWQboMtaLk4Vu5c9ayNfGdM3n2TqmQLQIeMUJyKJy lV9/eEoh8QHk
dKdWHEdr+o6miCnbiUeL9Urai1Pyh1s4i6LhCPXLu+mAZyhiRlh7uiQbJ76u LvVvqAWBlDOZ
QL5VZHhxHsoFhJ1DAZOSbTiE0BGnTkIkoqUpyFk48aV1SsEzg1WEvHznsneO yhn0TynokMi2
gvlKpE4++67u5xStmryvbVV4rrQ72Jh5i9eT+hVYgjHFJGbgwuAMHyE1qZVM 6yeWA5G85Vzo
DJMgZityd5N0jru0hwmRhk/1VxG+VS/SXtd50I/Pb5l9hDhwq5Z4hYjW3qZA lGlXW2ia24ue
BPJzNsUk94KZfnQbi6PMXbq7Rx8I/9eoeBSDc8iDo6b2zSb2swFrCcPan+Pp s+2Km8W6SfwJ
0dhY/zViN+eBtKMiFuKmk3gESpIlh+WOX3JR5yzHLMusINUxRtgkGiXONYIz +muib55ZZ6RF
AWuDs1ThTdYwSldZwWOQR0tuWCc2bRYO1wyA6R4P0BJTd7Rq8BPEu8GxPNBk V/rFjPugD8/L
aBT3EeVSoJJaL1ivzR9sPMcrkLTRq0qLBEq4kCzoAjgG7ZSSAi/CZ0PoV6cS 6foby345VVaQ
dELsipl7SYz9g8uV9yp7Crr+B5XQBNzL0UWqOGKbMLYS/t7kDZ8EfP05XNDb 0ul5jUzrnkIe
jZCtZYkLWNCqg245nTO+carkesK+BbzcdVpKKYCsRsYpiyPt6EBH7AKNWlUq sSlRzLRl1Ucr
LLHhNPMSu0wgOxFhgPnDM5lVLyug4X8xrt/ukpV/mkPiAUpkCqxwP+usGLvD 2hyv34Mhi5Dn
qgDr78WXfZPmqthe5ubDymPpl/vxYVZr33wPQvqHS6ymPptJ1JMylQ5Ei5zG a8zrZXnejYWP
t4NLDQGB+8ZIWaZRhiCy/sZqkI/s9RYo/tj96amoX5mz4KKX/xgf6v1WpHYC 4y2e/zDgg+ID
E++1XTz/MefH+8EXLNsnXE394XBVudi1nixb+Fx48+4Z1r7cS/prM08ONW/b kblpMdm2iyV8
8VG5LQBGlPeUW3a/8skKVMFjSpYNSU/ct4sfyD/w7gXwrIP9nu6Ve/SonTko 6Lu7FjwIRi8C
PHnVTctIo/+wnfsuSOQoj9vhKdvzSHnyQuSeUiHvZW+lHeWxTQvL/VqvL1B/ XCO0W7AhpfOg
nju1/y1RLjtFfEBFffBlh/QYKKOz6dv3kFNqgUOnSObCqd2KfaTJvE1i/pgv 7CJb/t1xV8kY
Tgr/jpgsCGlis7yoo9/DbtF+WYHHkv1QXCyDbBP9UKFj+P/szfp/wCI7n9Xt Cqrcv5ebJnOl
D+6qSPvorkFECgQOB1jv7HCelS6cr/oXTS4QrgzWsddTG+EYLPAW/0E1/juv 21/cwvIp8Kqc
tPKCE5y+icmQ7qWK/s16+Z8QEm3cna9telIdxxGOc94X2TwLuShzfl2UqU4H cdvudR54TozN
f6uypUg5ZhzyXwr9FcaP48o/dO+y/KMj8uvddSZPhcaFW/ey4Lfwdd3r3ib8 7sa7kf6AV/xv
X7qYlOzz1VK4tKi5JqUMFzfLXKqmsL9WtP/trHy/5HmV+j7vgeu+8wnFe3DC pshOOCPoPXJM
Azv9jZsV0rCqV0HGeySxoEjngPtF1BfEEm6OhXxGjv0bcLZhB++Kz2qvIsrx 4L+e2QIP/VA/
v/A1FDf/twy0hK9xxfh+0LM7qZfvpaFBCznXD9F9aR1nHiTDNNQZON3PsYsp vNue4VLz0bG4
4dU192ETC1vqC+/Kjn2bi+WBXAijsvusfekCG/Lsw/0wX9+wM1RV+q/U/x0w WRZpYqP68o9z
Jfsv1PE1if6r9Y/Zm/T7sGjuf4f1wQiSLkfxfjj3nuQ/HdC/+V/V3rYHwQPu sagJV2c6mOaT
OWo7GfJA5Wl3hH2EqBdmSSrDvUzrgYMouuijcWgmKY8NLjol+gdmBkK/gAxq 9kWat5cx36zt
gXcnz1KF2B/3qILOrm1OC1pYQVbb7esSddn3bYPPmP0oQMKFHH8Sj1zpWJqC h3ktmaTjGPbF
QAhT/qtf9RWcuRefiM09lB+B8ODv+fD35XsDby2Zp7zx7z+KIvEWoIhYiJS7 QWltv/3Ta/03
gN/qz/ZBpRS9ODnISdG0omQ3QSDsiCy7Ga2PiAycPj2ArcxdO8F0mFwnr8Rh 4ecmOt5HvG1t
GaZDcr191dopFD2/8Pt7uQOWMDva6KjQPi/C0z/uJELEJJzF+5E2zu+dI03U IXQ82N6ftWHC
tuLikZ++/nP5gfySnXW7x04ak/eiI3xYF3siaP5bvA8hBtL6vNK0BxaC8eT+ EcU7C0vmRflb
MGr2yxPXsld0lX6LzI2gh0DXVMELadYl4g9Oc6cXj4lo4pQUFydxbGcFrLOl FCyZcCvsxiFh
jwgid199EiN65v7bX1bzHOis5rQ8UX3ZY/z6xGwARQ2GWOCWtweOdxX2qmpb EBRomVMXZM0N
Jt8ZtEhzR5BHRprMkk9vrRCROxOI3Fl5hxXqE++2aeakehDUFA5FJWJsvj3w C/jIO5t8m8p0
GE4qpAYmVkpHIJ212kfEXrX5sW1fdvMogfFF9/LRYc1H7zShwGrpbwDjAvUA 86zjQKOTvPeI
qa0Me9pJ3BFBOfekxQBwtn23Juse2yuam+JMmCqgHvAeWhuvx9a8KGZsvg0f pXH31J54nGO2
i1EH6jxxNI8qamwN0lckUFSavKI6+9bz6vKl2x2mjXjMzL1WcfuoM/qXkyNT ieHWBpaKsnWi
udXwSRRoEVS/Ut0j+TLjFDrUoekK+fEJt9TXN4PutYPgjiVX+wv6NgiL6p38 ExZnUsLL3GyG
8+SW32t++e8gZjgLLQoxVAfR7yWFQ7xicUp6mGnZe/ouRbnRzfkzpagBJaJ5 pz0lqrXeu782
vhduBrOIggr/nMDHolmLle0ft0RvpypCvVT/44aIUFRVQbusWEpT3C4iTdx/ hgQcngYYAg7O
7XpugjjK01znCwT3Z72zJ0+o6aWRwvPn2qmfHuxOfXqHYWh40cnigJqVYj85 AwvpTo5nytdo
pcVL0CdrN3YE5YnbsXWrg+O1WSUVPefNkcy0eaNLzs1jk4+paZ67EWsR8Zvx r6zV2ZydZcJr
Gc7/u96AZxkLb1FZCbNJSS/qNUNdDmUQ9vdPdJ+0xYxIgWHaV9RAICi5Um1C ps/3zlmhr/tF
DYIcorlmhxgTWrbWiEhvRFr/9bJqIAqeIjOPI8a7FSOM3Kj4DiIrRDaylVgK YluqT4eDb7FB
NRQu4zEfJSxBpqVcuTD4ftHOCH8/awU5NvzddxnNsAC1Cp6uxCT9LSm/tU8N AYibev1nuJPr
CPO0Lvgn8FZco4+ZVkIyPafs1M4ZNayhY3jghI6WbOvtBCJtZzAtdvzp0brM DxubgLJ716xt
BByCB/+I0iecZSqHjTYQlN3KxoDi2qij+yknBzX6DV9Gkp8FqX5Ncd2iiHIv i5qGbgcbThCO
n4VS8EEY2moSMHkkFvi144Pt/f+Y9uVfMOkqWkI6Jh+DAquRwEjfwwh1lBWa Lh2N0n4zy3jr
gDIyJlIcEEXe7y4y9I/yqeC/xK/L+m+WtwtnYU9zHPXhJcv16QX76SyqtMBl PQG1oEPcK+IM
u3NBkJfYHAVrXUypQ7/LTb9QA7sgy5mo5hc0DKJK2EVYSbOHWgrVr+sd1a9/ F/7//8itSoj5
Aemob2SRdRlxDAcBwZ2T2Y5CvZQJMeBNinRvcNwVdEQR9LAO+9EJYNHxSWuc x7AL8bhEy+i/
84v2v02PGBGsTDTY9TlOuXeH1w9ud5x2yb93OuM8/LnhT/l/jMf6udxl/NzB kfL9b9ovcz1P
UA1MhJazzw+XqYkcRPjcRgdLXf80XzK38RCL/s1pJdp/bE3VKkv1R/bFoZdk ktL/dEq9dBl3
90X005N1/8+Eny/AcDKUHtjtRx+o8CEsBYhR8Pw7NsTBY6olBoyS/HVFylec c+38xJhrFFBP
qV3N7AC+hDZy62f86UYXlKN7Y66Gix5yH9Sq5vQjSncUw6mwvRXFHr+YFb/Z +BjL14F/cVE+
f37NKGEgZ3+7pyX2AFCEQpFV63FiP4J4jowPcCO8tsGD5SL1KaKM/58G/LS9 kHCG+tik/DGc
fSc0f+2MTgLmGnKmwTp1pGUBr08QCxhge/7M6l3h19D7/+ZpWHQu/KcyHGXK UqOIlsJChjtV
bES9B61bb+IA8VulS9hwCWWkha+A6d2NnabXLCkLW13m3PsHgpaX+Nld+gOX WVtv0A91O1JL
Q0W3k/T/Pg35aVXs8U31b0kwkjHe4ikTOz8QE7FbqR7YCOIap7w07jn/u4c9 /pN/0xFj5Zt0
R/21kfmKfacujnztFzc940S/t3GcLVyc2uiXixRCnYjnPCN3Bao5YUTJokMr 9TITQ4HbTj8k
zr42d+uVAGj62iaCFnoArvAOfaviz/Pqj5eob/znLVQcoIHe50a70V/bh0R/ xAJxn9mYLi7O
5/RceT0/bdTu58uTJByxX7rv36ybfLi3Uv68a8qz1u40F72MKJjOgWV2vqyu /4ftjmcvbTa3
A5W/BO83vCkLodNB6uhT8vAdd/VCk8z8sra+1MQa7zecKXERM6Lb674w+1fl n+fVb5Pv7EI6
to1df7KHkGIpEk8OujxTv3X4wXdsuO2W/nfc//6ASJYdvJwh0JHV3ioIHEBE bQGmUBNPEANw
IAmyI1wowKia11xpcBSXimlNKuiFEC4fQMKJqW0qCm1AjcFuUKIBooIwIQrK iyszBs+V2Z5n
RdXDQBVUfw+gfd+KIakCAAxP+y9+dHnUdebmO8fEkSXWty0gZoWHa/t+9IU9 KeGv3JbpLlnn
AbTSBg7CjJW4n2wd085XPthTbzvfrh8NS/Xu/35t1vs1zeqaCV1OgeRK3HDb KqKVMQ4yB4G4
fV3zJpLb1af8s/7h/89I1V4TP3e1jqc4y3KwXf41vL7LGd0GtnLdGuvZgUKi p4E/NeM8ir5H
NYZy6NYyyUOFnbl3CecSc2rLdJBPqd1hUgwR9Z70wHBNtvE/9+YtbF7qmznP VVSHJnJ0aNnG
uKq7w9c+8+sayale8934OBHUNK7W8f5tpuG/7PUvLDWgTW1RPL9qlbjJazXf 8ME73UkajR2w
U2q1nijw+o4dBn8t5PmjaR395fEypHgv+cobMhHbe1r2FGlr/+0BbaJrVgT3 CP++UTLbnLJP
to28QSkZk43huYn8/gDhiXflAZiu2m0y/qaM7DrGa9cPMjKxu2X4rNsAPidB zZJBH4k/qU/+
TeUTL+/MWtnLFlpOBVdCgB2h+QoEE/6EbUEGBl1AOFudLWtYIr8QtBtnaHxk I9qG1V8MtBWZ
fKK49VLnRfBHbU870kBvCBPpMddvk6qRjlBTP3QWfEuotbYX6uYXYsYJKMsj 9msUxzfzHMP3
+UthqnJNH9V8E8uxP2D1WaAgKulL+TQ3jf2QzA+dSbFj1z5k1d60Wh1TVU+Q 4OEQE5UXNWji
xWnJetrtMLOdgV5WVm57A3wkItwTDF84yC+D8qeKJok1wwOEsxolxO+OxLHj NHYPzckRmKhw
b9bCKyiipw2rz6YalxPNx0Vscx6XCZWHhxTH2IOQ0xCVyBoVDjMxCwKmyOm+ fyUc76GDQMhR
BfzedLkOpkzS3cVEr9KIY11Khd8/9pUlSvzWnvOV1vuX00gOxH1hjONsBtFw r8ZSSKJnH99Z
UPBzYwdfF69Blz+PeoLfnXT2wqK5z3dtcTGlkny4r3TEDTy9zcKZcnN9jKjS smdEdOruz4Hm
hfDf3NzjUd1NGB2N8j/HR1T2eCwp82l8pDcr6sRJDyHZVeihqfMa1dKv9aAG 427mfV8AYcrh
yzecLfJG9mmCJPF2o/CCHGihIoz3b3pfdibPBH7sgXLHft6G26ZMQZNU40e5 fdM7REB4nfUb
pkpiMSbeaK1hxoWQyqb8yCvflDuGouSiTl9W4It3dM9KhBcQtH1n8vZ6BJyO mgTfqHY4NLyX
cFCuo/8V3UfRoFHaDk1LJS8bHWs8Md1qK4WE4pyRKsWgNwpiYcKXYOBOmpF1 VlXG228KxKFz
NWZVd7i1EXxmNG/RjHvfv4h80bCMKxeA4zTdleuzuvlusjUTcbSAjQoXrdME UcOih2yd+pub
YkROhLVELlq/rakuIYISfIFukdxDXpuOAnQtB2owV8Fjge+gD9MW6Jy939LS U+LIRqEcrJW2
e5cFR6TGmODgjkF7gUBHvOkXN0RZhdV0zJ5xaZfSAy4oLUpGmzf++45F51PT /kQk7Crv+irL
irAp+pPPNNdEd/oTsQqhG0wXjqLmkskL9ZjLLnNF9u90VbieDqJBSEqQv1kH 17T+qlT/RFRS
XJsC6pLxi5M80VtbwEgxpj/W4PEp8ufP2IIZgfbp6Uw8U7eN78GYH33TfbHr omuL840xUgCe
eiByF/PPMAtaSs+/GwAzSzsSzRfx03lfZvrNmcXaw7aIshP3ZttYeXlAv5sW SbltrXFiPw+T
QdWcxreyNVBsZZc/hOB2a+qpt8jm1NDoI3lg5WAQklhe2u+kQr/c2hvBPcCc hi6rpZqK/Kcf
o9+/n9vJlqT0z3kDWdVsTIPOLmH298bxTfgOTpu2O4SZ+3OqkzNZIoRH1sv/ BUTuWt140eY0
ONT+CKFqBgaaPCVrF0imI2xYU/cnZ7XjteVlEFxXRnbONjBM2E5ZsI2D1zP1 RRewOiMmviAl
Zh00ynr9NUm7wEjBecs1/jX3Xv3X4SrN4TiYMThw4Xr96wgZA1UrKTKmXWCy o4Y7rkvGQKKO
rjSZsaBHt4VVp1MEk5JlXeXg83Laep1+AxuntWLBajoCD62+SYZcCH5qmOqL 0FnvQzMIzUbS
gzEZaONq252eMpC6QkYKC7amVF9huky+uxVft2Qp8EtnITnZdreZv+gsKfOM FdBx+OBoEGRE
tApQvK+R98lT05w6GRlg5cQ2wrcjk7OmtrbBobz782sKBrF8a7HuqlMhjSlg otQrCdXfVCSq
zmNPLFvoVbqk4zeRsJOn2U95/J8dSUmRtqN7/Xuz+kb3oTer7mRMDj0dz4Jz VIMg1cIcnqau
qfSxRw+fi8K3o+21BsQEw7H+nIzEC1aXM9VTbiJ+n9vISD1mibPyPwg6SuuZ pL7C8Be9DLCF
Ih383uxzaOyQzBR/wd3jZ3V7mNsKdKlbepB8l5GACw92FFSAx+DosY8wL6WT qtDL0e5kKd6W
T0TS8InuEoaFc7A9lHVShBAmNVeNGPW/yM7F5fTY+xMrUjUtX3sNROybllHw yEh6bKpPJgBA
R6JvHpq9FB3B2NPU1uJmx74ww4g28SWp/+RgimFGiscAVNS3bhTxSTB5jWZ5 vIp6T1qbFgaE
o3pXQGbbk/fHSGIg6bi3aK8qVvR+V/dZktNCGSbg7ohFsDO/x36QXdtXxYHl P4RtiYOlW4cI
Jn59znn8QiolKxXthx75GRLlo7qHo+ImMqrdv3BXC/PGT/8gsM/GtyxOeLFx HWFqbXMYrqhb
7AhTHLZh0j9Zjts8ZkPuAaS7xHOJRqTJWCxzhTvQD7LP+ZMweR9bFjAuwrIS dsUmruuk/8rJ
7QugEmiHk1RNvXw01EJ1wnfev3+Dd3U1j4Wv0TLeteS4owKTQ00KOkt8fere uVpU5ix1OB3i
hJSu0MbYsM2lvTKoO0or/pt6IV+xXOp1+Ff6LrRea8KagbazWlqEK3dDrs67 wAqMFHWgMsju
R31PmIL0yGd84bCGGC5+/+BK6sStvbxsgOv0PF4kPY8Qfz4eqOm4RRThVd2S RKSrrnzUe+c/
BfEprnZfnyPf363z+YT3DNM4JP2aGgC3DiiL2P08IXuiV1Cf6UVENKKSVuJi UMV0+sImFO94
xf4dKn6A+KbnHUuAZzOMTdEg95+k+q4Tax7Jpn+PF2xsWknMU4xXa0hEsxxK 7Sibf4B8aGNG
QMVapoLHelzC/kUvfMhVv1PninpptgJsOgK3iuS6RNItglIcSaAbpL32R5cA VWriYMjqzzcS
yh+EvBpuS54ziYeoXJReY1E8Y7xZOJXA9AXw2w/q9Xe+qGLT9RqT+PkdC2oN D15nBguojBVD
Q8QHQ1MLJHWilWI1tzCDubfd8ZZDnJb2Uj72es2TIxlG67wtLJCyPd1Dg9Xw V/6adNRbdea3
csc7Fei+wPAbpkQsiQnBJtG1YUd9aPrY0JVllx/tBGVlDtWdZuWw6jQzW7WY fwsi38H+OA80
bEBW3GI9DadevIN8NOPF+dvOUBbBuFMywnLZQPR5effmqixylwvokm1gDfxI f5420LgjPdmr
Oxw0OdgqUiDE1dF2qgRAAkdc7MnF5rpp44DZPo4ySvi0l5/qpXozsobVgqBJ amxmXbi+TH4u
QFYKV5AHc0s1pcTECPTJznmUBkB3UOB24BnxN/2tp5RVa3lc4gcytRB5EAfT yxTuuSNbJrB7
rQiS4nZUzvXmf4rvB7xhXf1VmFf8+lckXKrTqW/UN+uy2cRnc3NDevPeaR6W TkOJXLoDT4F7
IItvnGSu2WiIkN8RszdjKh/V8pftNwKYHBIET84MjtX/4z2DsFVdXOTN3hJ/ OXRO4HlYwTk4
LtP/v+5N7jjTy7gZ4Wm5ZGeRqFXfZ7P2EZGiK9LVaKalph42iCol8kNaooDg qv8NyciPxO5k
aqYB2hEeQtagBsdgDIWB7Bv5m1El1oZAflOtpEPCoSMBGtMvtkNLCdGT2vLJ gVmxtkCPTtuK
MK7atxG0EagUWPzsJIWrErnZhGX0RrqisdIShMElyG5W9bKVcXTxtGkVOI8u BWKo1t2Trn8z
o7T6Jwv1esiJNQgEv4+P48wb6RGn08mjJaTuiPSMnG8rikDpTEttUqagZKJ/ U7mcEdOCyPKL
CfIhVmrPMP1fHpG2Ml25gcw3zJvxsEyyBgp2ecVV9Sx92JBUFnib+tgRZ6iw vl5DFVmpnEAi
CfEPXu0CtV7ilJpk8izNlM8nL+JQF5aNCXqUeCHo90JR6P8N+GW+IluuAWxI eJEJtQI5ED5o
fzWfyM6wsCTVZaym7nMVd+jznYs9t+rpoat5eFqwX0j4Q0NKLJYlOJ48dqoc TkdfredhPl/s
SZTgsxiTsTw/LScCghbIUOhOr9LMwg3OrfDyLV8U2OtOI+UAtk+IeD28ztqM 7To4Tvrydyes
yN7sdPqkuAtH6dN29wXtevwMMSvkXnqKxBuceOWf/ndiPLr7QI5oQnySIWq1 3feqaI45R2hb
wIGgh3qq09n0JRbEpWBVr47L6jd3sYluVZXUS1SAmijh+sAXqzWVaeogDwgo LRyuxD9fYFW0
p0PI2KFgPM3UiLq32kRh4hPjmEdirlBkAvfsEqTvQHazFoWJRyF+nD7ysKw1 aa+1yvCUqd6R
B/Zg92zULQGg2+JD1bKXObQ7rkegJscqrqv97XrtiD3lIGIho1sW/u4DckxN oDQZkAPZb34N
mD/Bd3YVW+v4AD8n00ANTQlQtUrvADo/oPx0fe4n1MmyIDr9Yub9WJf1VfyJ L9o6/XMsAUcd
HaL2RSz5+ILG4cd7WeVda89qJDi3lNriUR+dHSRHKvKTvViZSQ+n/7iiUxd7 EjpR6eJxKPDT
XbLHrnyDEjeKUhBaEKzYMv/B0Ymc8GRLnelPbKJbtGU2Y61kxgKidtAxEDNI ercobpPB68Q3
v+p8MH+S8alyiJwdxE6riaktf33vgwZt0a2Myr/cD5861NEH48NSf9v+JGxU h7/2G/aSx9pF
UQOjFsu1IkAsgJA8Eaabn9N/MRSpwSQGXXDoVrNHysJqbizSnSEnwbOoAE4j 0PZRpshZIlCP
GgP5a+ZN3WgN2O/q1EL2q66WIx2VLrcl55/3/7QFsZCivYN6+PplRJX/ivp5 bXCzVy7SgwdT
geImzm5jMyp+gIzFD53XMqlRwQXzuv+kMpp0IJA1AIVfAAAldgAAAuCZ+dcr SiM3HTMQACAA
AABzY3JlZW5zaG90MDEuanBnAPCs85EQAVEVCNVZFBEd5LiRdRakwAixJZQS X0W0IEjB0mAE
iwgQJGAJMAowegRhdGAECLisebq73v3e8SXBLi52qr1ebzVXa+r8vgGjczEO 0biw8O+n08H8
rp4sO+nttq08Ptm3vf7b2zfPL+emAGfAkJaQADAwB/x9n6A+ecARf2MUFRcV 7YyLiwuNjQyO
EHdIiAeHiA2Kiwk7p73kA/PO8dnSGlLSchoyqjnR342pPVV1gZWZlQU1u8ra xeRaY2Vh/F3g
waGxsgHSA0IiI0Ye+d99h/978+dmAGhMNYQ08DgwpABo0GB3/F87cAB7MXg3 9hDAH99BwgGB
oeJCPZaeIZ/bQ4NDRIN7Ql2xAPDfyjf4A/7klAgOdw2UInERE8dKe8oqS+3U +Kbt7g4+eIqB
EqODkGisAWWpivvvcVLo1pqe4emCwtYXzitey8EIZ/H5/3erDP7EQ7LIwGuy +Q37XB/59fDv
7z7Up5QbogcOG3u89oUr8tiKBU3U3zzQAr9RdmRP3AAIQDqQAMxPa8zCy82W +IywBgtRH8A4
f1FgWZGnmjCJNa1ZL4MH8VNJ5fJ8cOg5JLhdmODDnaHEwkJZadfkm+FfVXUe v1O+xoXRglTa
3DTv/V51L9O+BLFsGF9MtwGyBqUbPCpjLGhGmk5Mt5e2QaveiS3gQxCZLg16 Zn21w5Skz7Sf
Wk3/U4T4zPHbkfsNAz2aqeBonbhXiSQrHAmXhaK/aemzc88jsKNJddubxgvr hJv0+7vAVjbJ
ISiAPjAbU0zIvQnWdL6EIfTbVFpUrnpTbxsR3yYnfsZG/QggM16yfmNVGOk/ PhRFG6QhNCMj
2CzTPzXC9p0JVBWnIgviZ9XI3ueBiWUONZxHIdn8kawtPq/GRfujaYnJ9jUz 6HFgHwzW3t+w
57ygtqREP4SE743ypo9M2Ky5x3P4T0I+wX5QTflpU/VKDWPXvHh9Q6aFliPW r2+fmwpoP1Q9
A+AvWTIm0peuM5PEJYbr+bdG9Ir6TVjpHza/ONID7ek30cRDFjIkqxaKy2X3 f7uCA/r27Kre
P15gRSvlt9/jClNS4n5uIzdqmJWhZCPCf5/Z7JR9ADIkL87GbSObCLHhUyf+ q0wQkX6NW8KJ
HuG84yj8mXbKjZe2gC8bD4MC5ei3IYo+JC6WxeMhxGFhmeQ9XEU9L8TsuAzM THIYf5jqC9I6
P/nAzXT9tgFb5PREf85MV/vNY/RQKGqac2T3/q/X2gKVP/OGh/vlv7JXc3b/ jVdp/Wn3DgH/
vGbw9/xpmUGJfs9BMdTP0fjCehBfv1Wy300ifzo15P1a141/KSz/SkX0nf1x Ls1QI/R7hN+V
z+0jfu19VHv0ov/SK+wEahPk7/XBj6RXURSNOv2VA+nXbRrSNEEiGlmnHq5i bAXqJUpt+veX
g5RD6+5Hn1YvZoozzJmDYBaiB/MAEJRLlMA6GVhV7Vae6LT256VmpdcltpjO kEtr9s/N1Qsu
9vSRnJ6iHUK9ej3EMKD738YD6G5SquY7S40ndkK/ChDWr1ulIc/q4Co9sLLh YE6RrupcgOtF
9CwSAVhBSzySLrCucLgkK8UT1ZjDpz/gCMbOXb1nUGddT2ndYdbI9dbUjTyF 1M14aBMg6CTt
ZCqgUvwfa24X4gkfq2bE3FMTUQzgHhF7rPHLYZ5P3IreJssr0Sp4dK1KdQ1k rjFdqpiwtxLM
UJbvd6ynEFzmyn4iPr8NXEc1y7PASNnu8qzmHMrJ4sn6gDOjtPUK16Smbzx/ 3oR6gvts26qE
na50jmH4B8WaBmA8Q3nPm5WcwObyMfUBu0BvYDndGJClM4sf4T74iJVjQHH8 KFDsael+u9Do
mqjj3dzqdfarf5hIbNIVIJWaeEOHrffj01Lyx0zUXS6h2LIUmjcBcelzSIIV UyvLQPqh1uff
G+Jk/cI6SMbCl9YKd5ncwAqhlUqy4aC81etWV3e6fSa5Vcraw9T1aUDz3B59 Ybzr71mkVD1G
smt5krbIqV3cnzSguuD0300cFZ6ka12wPIyPqKfdr+GM+AQv3GEbRKrvxBy3 uXzRAkUaRFjr
PaIfdLYi6Fx+oHQqaYfT5Y2Xdg2vvVvt9HNQp6/wahWDnaD4LObvZ8YzYkKH 7V46jxknFRI5
Z2ZROzmsfe1MWWyJG4VoIvBAycuzEXT4Ugb9ubbesl5Zx72tBJLCuDjFYrqy 37La2hX5cAVb
y2fHK7Mol26XMj+vNRHLlEvzM5OTspL918LJUXprb4ZI8TYng8GMy0HI/ngv 0YzJ9JkX5aWR
fozJ/4lIui2RxmNH0Zy5vg3a2uDfKe2Mt63xTf0zDCGQ79uLkLO9mLES8+0l Vl7lj9XJn1tm
izHPYDMrTf8/f/G7/AjjXdnqS2nfA1eUd5yQfN+a6f/o0cIjT+gQpWYxeIGc wrTsuaopsfqR
vwm+sivlSnvjNqtc5jn+zDZn95f58+Q5iliafCXwNUZQYpPrWHtTQv0ir5E0 swSlZBnxfV+C
kSnwLwwgP6VAuziKCdtNhf72FnP6tR8i2xkVrGsM97/d+MqXCjs6f4tdPJ8c vGsH/nWUJfzE
UqhCRZpETSckv5yd0f3qDf7GG+jubRP/lITw2sEGylx/L0fjFf83P7ghOYl9 NkOv4y0EPixV
mfxp/kbShpYI+Bfr6Av9msp/68/rp//8qtEoYIxA/2V3/a3f0dPAU+R2a2Pz uz1Cn+fLQ1CN
PemTTkfwtn+uf3OYPWH/6VVke/uldNTs1+30qA/eQqLBe4GO58wHAV9EVnIH 6Qf3s2vW8tly
2rK/G3lRsiICSJg9k+2U8ut5vM3P0rH+tvyCKWe4fqP2ErYnVTYElL/8jPS+ Ivq3X2JT5D9m
5P973hEswC2Ge0g8hco8ox4nx0uO+TGTPe22R32fv/YN7/6uo5fE1Uedwn7O HSj0ULUTC6EI
qH2O+HZh1j6Im0ivZ/kIXXHoJZmfznv/G6/R/DyLWdGlz4X+KV+oXA0t6bTn 07bhp3HSnn/O
msqoUxjq/CwMmbMIivlw7+w5Ps74VV8B69DfhO7rMJERZNyhsw8AWW/jctyt 0AQrRvFMGFSb
6fPTFXyvr1UouIXcuCV9dikGmZGPCV5iKvUojzX9RuIvuyIWKaRjEU4Sgdpi ccRgbsbDNvy3
WYnZATDfbFl7FzQc2yW3imS8ti9IsiL/KO+bWDFuC1uAvZzjuOVr2/iS7bPm JJwie67vDWSF
3BLKLXJ3wOCjuGFNuNtmTRgz6RU5+DKRSBu88VaUTgjyi4i8CIfQvGCY4t4f C59S5n0hbnbY
KumhG0zY/ePkkaoGkBinvfeB9b6VtX8CwWwagIxopm79s7OtHYessmu7PmNv NpKOLwzwikKt
tHMukRPyVoa7QNmpbBNBlh+7yT2fXbxuP+pqy9zkcNZyP4i3FX5UI21WDQUc hGJVltKnNwcd
h/JHxlI9STu2Qyy32H5Yv7GhBOzXonTZvojj+6biqBcYW+34tF1FWrOMUMeU QwD6OIxMNB6n
Mt53xVVHzKm28F0tPlDwBYpQwrZMPbqp897hnr7xvNw44MnNmCWL4j84w69o gGF9LfhOXenk
wt/efuehE0VINbx2pkJTJaVuCcu9VWIce2Suw7SkUeEpwW9b2UDNut58wBfM S/qo4uhfwbRS
q4GYYToTuoJ/PM73ttLfrtKaRDunfdd1YD14BTLO0AajDyWgOJPTMFNmiNYa nMWzBumW1reM
zginA73Sh82R9i33Eit8KesIFtrrkp3tBpVK08Ds72GIz1JOEKuCSKa/22vn hZI9Mj62RpPm
mZXRzxFiNpRTz9oMfbElKydWcsNjyhETfao0q1EUlt9nawHinDSknKSn/Zo1 aLFDQqeQww7n
O2rTi+OprhE2dj2eO8QsdX/+K/J6pHWR6LyZEGTdPpsN1bMdDxDIrGZlbYaz 5nbvyvfDbu9C
kLdm9mYmUL1c2nO/iadTspycqHlL1nyTyrcKPj+8oRkEOEDRsjdUrmIpQC49 5vOdYMjpN/HV
bkH8Q1skzqy19dowrc2JMbo+Nj3/0viwUqb+mLf1gudnCdCTcfUKO11JTG2X ju21VGSR4yPY
WJUjan257uz0r4xNz7NqrL2t1jSRb3uLXEqYqb4+ryT8sF8nyWmqHHzrNOvT GSJF4GDbz2fV
LfUI37aMYIAEyumvGBFjwds9MnYkK+50b8EpkDIYtdjYzTiUi6wtgURJKAoW BkBKI9Ff3ZDF
SXKz5S/1PZEzLIsfp9sOeZMKmYIktaGXjQkKuo+jo5UxQyQn028UYDgvMwIq bhG+n2YolRH6
47AkECOzRcfFrddbuWe+rD6d7ugK0teFDu5hXRUKsIpoWWs5yT6y1zR8fteW eOf/pH8oB+CL
Y4mcB0BzelWM5qhhmJPr0sjyTb1Rp5c2Yvx+NvwpdxavDgyEwk/vGY2Sjrem jbt6/h5t77By
mC5IH3bHxGquQYjnnCv6s6tYj6K++RmLWiuiXQjAYlTjA2h4JksVouk0hR6q tqgpDd5GQ0ZY
STJvqa8uqtMbxVhsYBZ/68Nrf38TpW8fMUQ/LZVmG7lftoZXf/8Gk8ZKIUmQ aJ1p0IMYYNN4
sXIbGFKFvwsT+OFRzRWADSbnehfKLuJ076Yrq574Cvi1xQmYZV8Nlu92FiJY d78VkqMC+BEZ
ja+873KrXi8z+fZKisPueb1hqwmJu8iUwmdI8wxMOfzVW+4RzTpi18m0kq5o wLDGhr7WDP9v
ZtU2bcaM2n283VWLnzso1mqrrQ0MGmTOXlCnnIAfsoZkrwRgBhtqFHKNmcEY xsDpPNwbW2cp
i3DiRp1VAffMAlR8t3Y7dqqcO5PSndQnJko9nnbvGrmvOesyXlA1Ypqgw4Ll RU0U9D66vp0t
b9t5gzc5qONI4xCv3iCGDxkrlQ2aUWZwWHu30ZWwI76dpfvCbaHHfbsec0Ml yc/18kvofSqv
eSasnbjrN8KeGLZV8EZ/Ld+rxqU37YPw/EhUr1gRsGAtIwGdVaoYVXUneevH m6YZPTUYyigX
8B6mH7fye/o5xL7qQaY6Mm7yytrqat+JOcfQbd5SzA+LNzco70FCZ3GJgx4e EJxA2XXYpMUd
OYbFccTIPlBnnxGgHCQqFDIyWCHVfJTj1USyTN3EGz1BVHguUSPkiFHbPXPG 3FjmTT+/XpLV
J4J9Gd1WFDip2fZYVnHKpWAijgFNT52KpuM4rt8It+gYHwZ3W7PGj0kovrku lkg7IeBogz1A
h05eORx9QMBmLcsjb60qpTB1oi+ZKnuU7yv3CpZP2yfj99/O6bmZiumwA+Ck VZczBqueFgn6
dnb8F3MgneDcF4FOx+8AqbVDIQLXXeUSeI6vOPRwfMBq+8irKqox7PYqpuzj a0jMg77qNlMt
S41it/TXOPp8T7qS77QKWc/ro5JWum5MWqEbVzKq2PJrSm+dNtYfvGmn2u4n r7V9oTtcMtMw
zBM20GzXx8RwF3SSyN3FLN789pBchya4+knYCJX4urbTtuXz56Pn1zAc5moz M/Bjm9mpSlDX
64vXKwXV6HlGqs6OYGI0bJ9o5OLcYlRSloh7xHdD3CAgmKZYUUgIjoMYuNB8 zRuRwTWetsS7
WqFBovh2DflFSitlG+u0d7OXjXg0a7dcaJ2WQKOtKV+4/tPevea3xPPzBG4e O2v2MeBWc/xP
4Q0hMAJoEJTab9Vnbo+HvGokpPhvfA52t0eZJZcYR5XW4VL5gqepp6olp61t GBxIs7Fa4gqn
jyw2qwuDjTiNFNHJ1MBnllsxeSuYOKotZ/bBGOodkYld3bxH7Mh7EZHFgcTP z1BCULpsNEkW
ejUHxoH0WXWddOQlyCXpz07PUTnVzCK/Cd2vDYFB5h6yWeNAsckU3xoeLu3J kJZ4XLjxcLxs
rNOQqoFuaztFln51+wuB6xwqGfrqnAXMqZOR0qDi/cI8vP2DziQIwBGPoqgV YfX+2ueFAr5U
ran8Snx6xKwE1PUNx93CqOHzaitVpaEx4OMvTSOG6YS1Uh7WAdeEJPdr5gB5 HNSaTJe9UFw9
w8lJQo0XCwwXFGrHNJaBHroXHxrPqg0ZiV/RGA/lOLu8y0SttTePJl65tbHp pe0VXN0jJkNs
R9dlvRM3Kr/RqNrBJmQqXSms1GRHK6YkGAcHtTmXLfSNpHtfj5lz0lpUx2qx 5FSZKLFFlI33
VsC2CbtfLiGG5IBdPs3M0Hgb7tJJHvgSMb5VNiQzw10IoobtYpJb75rq9bRN O/Ytp0lKaIki
i9QwInNTs8Zz0XvwE1aoq+6G1mua2ba813SU6Mjp3pcJVTmVzZNsFxpgrCdM 57NtaBe5n6ZW
//5QPgc54K/E4pvy4FtoEg3NiS0C92aFPbkfaQdZaxypX8Op8qA93fmAieqb v9zBHYcypSV2
WV/fWRxtbIdQylagD2WQhNjXZyvmiQGg+/uuveBVv6GnVBvnR8iNMmDqPf4e xCZDB8Vv+Hvk
zKv7AfTnF1usGu1Bl1Q/wOXGe/a49lx37UoE2bQSHy+LaqDOHj+4feF3N+OV xAcd0MeuhS97
No4vjEwr65zk/Sde2Lx75t7r69eUbNYdSNivk/lv/XkH0/SWLVRA2Pm7qMxx yHUQzW0Lf8It
NU1D6uKPUT4j686KNhU183rQinwXWqA4xt+unRHhJaSN+OTxE1eZufIeYiIh mfxn1qH/LZ6q
OJPvIx659L2kn6xvst1tevodEUNtu8CsIUWrRvqMQ7piw97yFn9zj3p3+fDA NUyssR6SH/d9
xVsl5/qli/KSD2Kqb75vnz/XPOtCebWZCsJ5WQTzJ/bcL5ih/4JW639w2/Qh YLRQXMvyqgTP
tDGMeKH/uPtifqHUffeNuOJdMQvvPY0WlWwzR29hA3mJPvC93YF0ezDiHDDo qyfNa09H2AfE
cU3Fa9rZ5/czxW2amEyWqkedjtsQf2AlUb/laES4Jtzp+Tjo9cbFUipDcrv8 wB62PH9wqpe+
/d3h/WQ976Oj+mKhZi9w9XJuLkFyTpKKZhK4HNU6dc10tMoFcOPHS8zzen1U X41K08SemH9F
IFA4USfYUGaweRwqze9TolETUyyshavNPc1LamXzojlUvZO+GlI7t7cO1IWU om8D0PyQSSb6
Yj406eS1yqU6p85J2oBW6ihP8XTWnOvL+ESDHDNV4lvslt7tb3rWOzZywlwn ZsmscUT3trNP
Udn8SQrVJuML9aFSGCP2RiDM3AtujpZyaFxTTKHryothoWVFCsItX5lainp8 7Clj4OxtN7es
YuU/OCEbJhe15Wva9HK1wSazacbGcEBREY3x6GII7VT/FjIYloaAtAZ/69bf T7EEyVp2tLu+
PIkV+F2CNP+VHK7Kbw13l8HKzfMAq+L88rJpxlX9whdv4ebRmh/etkGZQhZW n9r2MhDylHQ0
XDAs+g5kO/IpChIQM8HFRucvQURZLap+NlZqqK0bcqMxcWNHpvp4fu9yIXGK 7Yt+322do5Hb
VfBGlSrqsIScjMwlClCOdYRpkNb5E0d+6udphqag2fhlp5rYJ1PrnzEuQb0H dMZ4wJdhEUw+
kCIslkpRGhn0BWMCOtpKAfbL7P9pfhejWYnqqqx86KigL06A/L7NJhxWB5Hu UBQHEkdF4Zt0
OKRooKNef2q7gVSIlgVhK1sq3+wn3QWs2uLrhf+DBv8wpM8l3svni7XIs0Gb euBLPpaxc463
rHAcwGus4YTxT6TlkJs2zNDFPQlUNVWPZKnC2QJl2j7nFMuJze3p+b0TznCz c4MQRGpG+Md5
+cOPiGVAswdqlR+n5A92pDafC5xUKbNujjVXmWBaTMMtOPz1tlrqbJoFXf2E bmyVGMv2oD6K
KowN+M8uwhrEIXJTjI8jnXPc1BjAIzAwnHVcLaIfH0GZ6SD5kcxWQMQJ3ysC 0is7vrRq9TW/
uF9iLq4fEqMhTU15xan2fiWVwgoUtJiK3FGQ/a+KuRn5pIu/AzIcIMZ/6goj 2ljdiI/PdjPu
KR6sQSUpeIQBIzfZBodS2M3q2eercGDo5Ck4kiljvoldCpmVnmK1N+CnDKGS nd2By4L4BUlo
qJabnnuro1dZE4X1VXyKrwE2sKwj0sHT6TzTJ68/wP6IZv92jukmuSb/zAU8 mh8Pd4Wz4w6/
+AnwSI3mgnOnGduBc8diuIWRjfD8QtndWf+5Yaw+k6PYx5n0VoyLL0NmjCEo fa6Db2QEJ/VC
KSl6t2AtiqQAWuNWkyxGsD9ZNbh1TtFTWEAbf8QSmRdI6PPipOFslpo0FZyx hEmeT+PjTYTP
S/6JnpqNrZq96McPupzJRuQxMfvBjlVwokcHlHFdhIGT6f2ZTKWB1RPaC4vz dDg89Goq05FT
VOb1Sc9l867ratfGHqwzsLTEJZVl6jnXVQwTwyfXy/ha9Xs/lje8fPgYLypZ ctwyMl8p0Hc8
BX9AWUdwMO+fs8vYZ09Ndhbj40/9eSP6fTzLIXFdvBc/+KT3ZgKFLQxhM2XC Qp/KZIKyXHDq
9UePnHuqwZzvOMtab2kY4POGVsqsbaJdD+5mfwC2NFaC5Wn+l5k7Opg/mArk l2nv/ol6f1W7
9r9vhJJEZ/zGaoNc9MWEIvU+SYz2jcWqnzKFBtpNbkY8vAyFjp/LxqF0as8E pJgdCq3v+srW
uWsipNVVGKpOsprBaNwSDNFpvgTBtie/jx9seSCZTE3quuQemdrm7CZO+Q6z t2+pkuSqCD2D
JIXZVEAb9MzMfURqCk1OZNqod6OqnIaAsjqFIYqPEJFKvIqOAim3x3hW1UbZ F+e3CCsjn6p1
IyXE8T82LFyAcksA+ynqSEY1H7nnOO0HSbD6a1Mk192zMCrWcrLKc7xSDmFk Mje90z30qU7X
mqwSk1XTST6lgutND1wX3yTLECdz2J7v3rMbbLE3GWrYah1L7gvHIp8h+/v7 1/xCf/xUPZfz
nWbQNErMwjT34zu3B93ojCbfXHtZJZunP1VmWpoQcrskaN7oA6kooRZax4P3 zfbFLt0hOb1k
MSru60R7emHzH9h8XFyrptark+sYKiEitdoDBB/G3sTSKTDd+qSc2D8mtVdC w+yOfD8biOK7
UQf9Gifl/jJfmHtUwWpP1Uxxxa74EC5o5q+Sdcwsop2hFtMBCmyhF9TGYSiL GMFbllbokDSt
ydE80zwRUOL1FlekqZUtZOENcSZnQEy6DNZt36PXwMhXF5wtuE8VLxNIle72 qYrGsxr+YBdn
9D2JWW/zeQgcDdbMGmlIS/ooPX1ZB8cAk1NaXIiTlZcYToNB7G6111LeLdjL bzgLb2owsCJ1
3OvI5Ndfu97r+9xPWCbjUa1ApzRVHHhn5BXaBcpFzHN0wruudbra7XuwFM+5 JKotbwnfVQ3E
aa3rY0RVlYH06tdoo+8GKg0zQJAz6AcUHtZbTrabnehH67e2fJgqC2BmIrAh SlG3xaIr7pWz
ckHY+ceIYPj0YnjO5jGOXAgKYJJ85/L99GxUEG9Z55B+G3RLi17xM0as1i5B EhcfmkJtm5o/
ZX4/f713zjQSNAEDSgK5wtMshYvyTjWfRo4hjKkDaEmY/jGSQJBVsoMy8ai+ NMD/Ggj/2Ag7
nDzFzSGeFnpr9iNzpPE6DXnaCIh0O2DysGrkxQE84IXqFgMskZsKEWW5Lbkm JJNI4e3ViYDn
5WZbZK1hmlhrRowsbvueDWfHQTTBxQAX7S1k1+YKpojg9aIrTGJj46c3TY2a k3GEXFbP4dWp
kTreDBgXqf4gyP9+gjyFxUkdsYr9cQVNOcn+Op0kp4yu6YVgeRxHm9+cMapi cq4/woFL8imo
RP3aw5v8vnytYpvslv4hyaZxrGk8VbLzcfJl+xlV/w+IzFK46z38GhapfA/d oLGJ0+CkmiX2
qqhr/6WPxnpDtyXaYaDJiGMunZ6xNHwSajtq9uc+KE4BUcRsl+PxU8H13zJP kvsrmoICV8+E
mK5tORdyrrWBLoZKIlIv5Ej451Fot99V8cnwBRFA0w3Ud4Vd6/mArDCEC2vR zMxhJe7TWCl/
SZPrABxY5AS5qMx/wYyBDQqy2jDJ38qszHlQWIlZTZy9VGBgKLYejWEvYpSl PKJi47qBO1z3
EV0NOisBYjqREMkxnoJrK/ZsuSEV6RM6fHhr8zgU1N5iX2fi4evly4mwY85p WFndsC+zc9cL
xHmPMsdz9AgArtTuwoqAaLOs2QT8Sdfu1pe9dWjaMJoL3YN7St5azClxZLnm JzsUg4VfVMZn
PbpUSaM44HtonmfNuUhFznwdkk4pGLzCKLFMluQ6fC0KomXicYiq9F0Lhu6N tx3n6rdZMfiR
Jee2pmQZPvNOyCTY4wnZ+UXczIr4Qd9wIk7jRQu9nkeV0jFG2j32iPZAGaUz NV2PkOboQTZ2
sYSQUVTAywzT+MitU2SSg8astZWAGjy0eeQKWjyd30glkhQDItI29FgKRnqv h49Rhc4XItzg
+MU1NNckGPIvcBBWZvdsvnO5IrFU2uH6tI2LgdaHGqIPSFYI26bmaDQ/eWXP zADeX7Jxm4Va
WxW7JycjGBl6sz54GAxK6WzA7NAAed4sI04WCVobhWKp09Rwh426Z/v5cEth Huz69HfIdBzU
MS88Syo/f6FY0QJBHLEM6eHnaPXQnSzvozn+REv+9QLtFJ+43I/aDe90Dao5 HlWGyZQd2KHV
l7F0r2eXffuIdkKGC55TLeRpX9VI2bSj+j+5N/6Xnr1mrI6DSQvK6tLzUUP4 asNM+wfGT+jY
wWpX/TuFhRLY2IyF4jJEMBmB75WGfFKWaNNLQyX8hugeqHzzIWLe/w9w6uQ9 kSiboRLiY5Le
JyFNJURmAiD81GRi9NAQdWeZb0LLIbbJMSK7BpIkc2IJVJwkyLCSpqpiGQSD T2rLgKPgmbms
3MTW4K2zD9oWaqPh8dklFMzPsa02O6/Zm6TctzpVW5NvTi6XzJwmuSRCtKyU N0RjYDJuQWq7
aDm9rraIQFc1ugbcK9O9+pVXjZ8S39Sz4jXamkHweyE83IWNtAvYw1gKRQcY 1zleDoV+97tN
2znbzso2dEmm1rS7E446cVTkOeJOXhxIv02pTWeHH2C1IcyOpnLCdZVJZo2n ZcJTMpwW8OLc
doFZ56c5ScPY7zsl6VcIWuGgXKhgLL4hh6EYkyp2crU7I97czMqjh7WxgS+c pXeq2ykcvHUU
+5myNCwMBBaOr0gi3E5QpvLxEKZydSpb/kCWhmGpIXOsCptE79W5tZPXVKXh fJNRitl7tkPi
PrVtZKEusZsvMgD216pwJUuSOmlRIWmB56AD8BV7SiKT4UPgXyOcrzQfqai2 LpIrxgxo8CZh
isWkYPPefCcLanbrriElTFwlA72p3rCsBsIDDQh12DB4PSNNNnymcX74hmLa vusBwav/wKCu
nNRF6YeK2az5HgkeM5M0GyM5Pzp+pH1QxEctbI9N3gb2B0QqPL26sv8oeXcP V1CGAuqmaRKq
d0aROLhEUqqyla08QJDnUpypKL0oAEDMZyijkLNNuDQ+P7a4fBaO6jiovasv FgZV7LL0DzrU
SAVaoXwRgMjaWl6O9RwS6ij71KeaA/e6Moq4Ay7w6WHQ3SVgit5Lyrqoph2l MVb+xxPEMqyf
8+sncqKno5/1n0t6p1hKRJavYDN57+/Q9y8ud3iZHYFXXCSWwc6LwHWL2Spj 3/NAB7ZAUTjG
26I2k+carLefImfAajwSKJaAs8rwaDDMOHpfQ3FRLHfzQUXj7uyzciZtzMJE dmohI7bDhmPQ
lco0clU1krPVN2zBqElFNS04vlmkdF5YKX6JKGG4znnRV3ggEj3pV5uLpVxq NbsiYTgSYCsv
hJv6vWaaWdvKZ6LlqTNtGd9Y2uTjIwqdM9NYdCWTdbfC+rFuLmlQQwtxqQZa Pg7lVxbQxJZJ
NBVH8v8XA9sgyYJJkgWysWf70USGtmH7sCYP/IUDiT3p4gY3JpuVUCN7S3C2 fPU6FkacigoM
22wfALIeeKYO2+J3RfCIZQ+YCwVoPC9eXzznphpIyZql6oIjiPZRo8qtk+wP rWvsmlJqFPhh
o23a+TAEJhC4Msq+Jv0Wt5quekk2uFoDiqIp9X9rZsLRTOxyWVZ90/AT4coT IyDHKkd35pxM
VUTV2psovDqsii7JNviooeWRoMrbN5L+QUeasU1sEbyJRz1SaXIiz6ZA/Y8U nNQpMyjVQ3bC
xxxtFL7fJagDOmq2Ij84l8wB4aSsii5EmQXZZiZ3hsAD6VULLsFdNZe+L4O8 1c6trV+C+uwg
4S8zCU6aoh2bsPr3sVNytytSd/XHyoNdjdEtSva3R6LZ6YoaD1eEI/oWYnWS pWIqn4cu3pUw
yDXV+Pe7VGbpB9dNkhd/QeVb2VTwcnyYX6rPdNtmL0r3+xVd78rg/K/hM/+q aGYCnrs9lD9d
H41Nr7br+mtc85NIVSQH1WSmmFZg0hMwAPSr/u5iB/8gXqxaMvgQoE0t1RKM c7q7ml+IIa+H
56s5C+y/AtyMM4zffjDnwtFckR/e3fxHzrJhHfyBcTPI10TN8JpVxYZuoJ5v +nLbv5H71ES1
7V4evaRLPQama6l0W0PRVlvTr7nCqFXe9EfbUXLSm0tcXR9rIgjZrUiS2Y+i rRHh7EOsI9oB
gZe3/ykjukbX2oHp4R6++okrSaufeVOSOc0r3PZ+tcAv8tD9nWqv5KJD0BCQ pWEWZnTACVeq
im4umFVAe8GUIi/vYYzXxRMp088d4zjkyBvzeHfcAZB7YJISyNgOo09Q9h8d FoUWRfe55LKa
epb5Ll1dFKmiQk9bjUiwG1gAbg6pWrBBuMokbQvUWTGvCnRtSOywuNtSONKR lUvDdjvv3sVw
sPAikuiKw1A7qCgvNmxlh3u5mAfpTou+9NhuGFBMPAnHxHf22htPKZLoRdrE iTXl8yG27HxE
I9BQJfyMZyw7ZRGBTCPJID3U2AEz9U0b9DWzFTaaK/KvJjQUVTbuGMxmnBMI sO6OhCiX3n3g
dH5gGTXo8BPV5px9Bk0gnpTtirXNDvNWLkCc1dW5hvPvnhjC+zyk3fqTe5LG lH3xs7G8kcjw
7yh2+KbOktqmWK1CrXkC6slZpGhwB7Bxucbgo8WH3K5eNvUPea1thTmiZ2ed 2UB8PkG54v+7
vsY/Pvbye3ZQxMI/HyZqhM4gkmTRfJimwEYp6BVEpeZ2dBOn/Jq9YAZi1G11 7NBIXSWm0zoH
zHMQd04Ek3TPG+yQWd5lv45Pa1z9j835hdqp2AlRHdVJ5RjwIp04XXpyd7/f qQhe8SFh/4zW
RjLezw/E8Pcn/qXJ/9egSOVWLm+pF4K5uTfDkn/sWfHq7I+rX+6KSdm6Geb/ 2A3ES8Ia6K+Y
DuLr/Q5DEu+vmtuiBwBB2ee/I/k1VYOUH8vT/Euu3GLoUuuudPXfY3+gJviG vrjl5uzoHlao
aIGg/8438ZcZ6d0xqG7yGATayHQuClxVMQTSs5BNsQ+DTWM8US/UtFqRdPUx H3EqJB0qecdv
lM06H5I6RQqYl/pO6zyngUT0GzcqAm2Qq1HoEM5iUqNfJRzg75oPknSMM6D6 +ejqzaIqTmEF
mbPIjIdWQmtBnAkgpD8ARJvzGR1hIXj+WhP3JfmHBFlwDg4VaM13zdzGWTyy V//gXzA0lZiP
mLTIixihCrGkBAlp7GBcVtHmCqehG3OqjvOL9xhUtnXfGcONaLhw7xVhA4Wy PfRwh8F5vMyW
qxiUhV+hCHXAwm5+UalczgS5fFYOICQRwORBUbulHkJYOTjJQup1hC4mqdGW j2u0yzlkdwud
LX5PyJPmAdQoLvGQVfcjFfYS+3469nFDVk1Ag9pOzpIsTY1249tdgAsEcuNS 6QHJgtTXRb4h
pn7RJcPvOZvOrIW45BMUj6leVSKsvirQeqaDcqW5FqQIKbK/65O+mv/Dfb/4 FJ0RTrS/c9dE
dYpM5XvborQSK/0oaqI/XhNKE/0OGq/6Z4NFH/QnpbBZwup8Mr67EwNMf8zb pvnmH49/Cnoa
2VfAs2zkE/QmZRTSWrPyCCcBH20/YN55vH+mgVLju8uOXN3LGTcf0WmlxCNq gPPBjwY3ZLNz
qSlVs2wKnaKmLV+h5YUX4tF5nG/fCSHM/HD3jRxQiH/CONEvaibM3OHp5woA N9tbzdhQcH8l
h6Tlat+RD0CY2bRvHqr/fFYOplawap+AIsXL7UiNSKABB6FIuqo2ZmkB97Wg L+Pal/lknPvk
3StsT12j57ioFGeR2pzfMtN21Pnc+jb0JaYH2fWaFzEa3hKI21F2U1PvE65K AMI4EjuUkng4
ffXK7XhCi0thRsZNgR0x6p72UqAzCwtCQymBxgMm6J7WemUi87NT9kebIjGe fEqtJ7UkBAkh
Q3QlmeUWjsBT9eQn34wU5bdouxIqLIsBiSONKLDMJn5QkAAE742tIKLh2a98 I2c4ldqpVUaG
6VsxpvrZYVs+TDKcpBjOp/bGU235KO/ELi1tacDZx8he3ZITF+a2pNOZBgLa pquyTXVfqljS
rI7vym/meq/PTCFDcW70VrMOZbCi8Isy23PCpZ4BZLBVGsWKlY8M40DGFU0I UO0kIb7oAM8/
jwdCglIbw3Sy9VncJtVbESFfeYZpVKYnVuis36v2yAopKe9jKQw0wo4dgwZ7 3/aBenBZscAr
8lm8i3X3Md178hXYTUfZ+yahqLHbGs6DTaZi0I/3gkoGHgai5W3LvluZPDTV MEfK13duzawV
EBbonSeax1Ry053SQPcDdLXLw0fA8bPMEAtQ+HnQ5n3qqwGflGd2eLMZf5cV H8RiQpo6Z4e3
+8vSRIgjbjS+vCHW2Vqs915DNR140XCIQFMXEXVBCYLhwXNgWwQVwPn3Te8A fI3VOjFeYgTp
K57vD1H0f+y7ZxwlDoXRU1X1N/yfD5NfSSdsUvgU00XZf+COyUBUPZK05/lq W4eLo/XD/SJo
T2Gxr8jx45zQ3/1w1LUL6GO+gcZ6Y+iGLZVMPptQx6rhgcR6WiPFDAeeiJ6f /WKqWTikSxvs
RaD016Bx0O40+pVrnF7i2mSefclw7YXDVd1+js9MjMvF5QPD63QmaKjx4Hjy 5ID6LHmsh6Ih
+E6J3nhnaF1i4JVG8hkYHUwke/s1p1aX8L8wGy7KyH1hlfVzk5CyknS3J+kc /NpOuKe5vlMg
+/CXlWJHYku1965SqdF0lrm5MrFvBYIJpaQEKpdJ/eLbnaeTvJ5jolMVZ3zs 6sqnA6RPAzYB
lVQjj4Zx4Px6BuPPa5Td7INDDnKw82DVs5sYwUtMz0YGOydh54uVVo+wIGVV WLngFeLyU2Mi
+PV31qmIfOG8y8AC+b3G++Y0CCnqbNCS6qhLr8OFDHSrt57CZ5a+FQhbBDp6 b3oGKjbKDLVF
VUd8rXijzxjg2e0UWuZzdDHt+B+xza58CvPSQxeRotd8Nglk2Q4lPfnxYfQD Kmvkw5Mi5UKo
uEmyk6AJZAsEmrKkHNJ7WAM813nqYsbG89ygmaFurkX+tLLy+x4fddofy9Z9 U0cMkYsXNeWq
NlKCiOwWeoErdK5Jwyv0PYyu5wsT+ypbppAiKK+55Zc8/ZMieRbZnx7fEdRx Es4wIUqTziGd
psaeuMj3lZL0WqNz/UyP8hKdsoTFS58SZ2n4jh9UJmtTz3DtW0JiqWSntyoa cIieOFxOmpBe
17GfDRftdfkqb0U5PMTvTw2PpY5JMrFgNOHAELcQMclnbAnXaIKNb69GHTZm gCqdmoinULXL
R5Ivnr9H9qEPl0Q/IFuS5DT/vHCnbjDneCLmHqPFutolPjdR+u3Y/4euR31g n2ZQ79r3iU1C
IpXySqzpza/uHK4jPBX5utSuzBD+FvddGv2FtV46osojN4x7Y3Sb/es0cT2L 4ldlChs7GKv5
XjIIX6cfJr1nSp/ID/VMwjJarWW6rVcUjc/gv9DOF+ZOKKIplhM4eJEv/Pl9 rf+YDSaKPFOV
k58ofVSF3I+nCvK4fXUHOWmPd/e9rqQqt9gi9cyRTN4AatymNSwnbRUQCfuy JsEKqMKq6ohQ
r6+VvjdmbnM6UEcVRSiI+ItPBM7khCKom1wRZBED1oazYJBlZykv+whl6FRm +9KWKnA3iH9W
PP9wirmAsyAikZVuLWBrw79W0ER72vU8MlfH09rckE97a09u7wzKj9992cSj rCmTPdoCPYxV
O0Po/j9CgJDW/TKCYnipKsM3t4kz1ugZqwmzlmY+qEawSmD+jaqVsPsqM49w f+fhXqvyvbfZ
ajg2bVDGBn3KAvdO9QSuS3cw4hTyhYUQzcIR6JNaiJE8UL+XhjAdqBglZaDm rs7Y9MPpGjpI
LWz56qa2RREB27U7DFb6tAeCpV3IwKTVQlaPt1LXAybIKow8WFsczfd2mcEd UwjbvG0dI3jx
8jGT7krn52BERxe21wiNOwQ4xLCKcOFvmL8QFSNRzsYUPGtwoa/4UZgki7uq 7fCZuya5lmBj
JFdQd5/WfV/7hXOJzmfpNGI2IOx1qj+UT/GVbZVz5s348jyjXJEde+ok824P JyUflpScU/Jb
azF08fXwLjJX51WRhPwVurTzO/mfqa6ik9Xn7OlfaNUatTFsv5NvVQ4lId+S E9Bn/VJArsMs
bfgFDj+ZQPS4sxxtiX4ppmm52dFSaVBLy9dg8A+63AuOQS1qmHOuaz/I+gOl GPKDs5f53WLC
7M7Lzk7DpZiLmpq/HNxN6GUHrbDj0OabCyowF0/TYMghElExL9GMIWqutXOe LGZs89AzFbvU
77vEbklpu6zo6F73eR4OGwJbLiYm3Jetajyvg1tMJZMErSc02M0q/Xu1JlhW 8xPhx8rF8HRL
wY9b6X7XGhmD5LdsX5TUrktbU6DIUsVnFqbExFM8ix9hqCA7Q2tcuOS+DLS1 3yeCzizNZaA2
QG/prjiaQ8UcSDh6aaGQHrZM88bFHlCZ71cQxLcEc9aqlUxTRx6IyFOA2IC2 Bnp0jigpv+s6
HFoC3twdX9OxZPfbVERARsAzM53yO3nzxNma11e7bijhkosQ14gE/TP+qfbX 3xlb6nk5V2ru
HyYLrAby0e986sEXIZqw2zZDyEye/wcEahbnSx934wfLSUSMrSSC3ppR4726 RjFyUKbiN+2f
gj3mGc6wNn/hc156NdnNl3hhnMXHhAtQR39G7JpaPQnjFfIz6DvcQl5TWSZu DQ5ckxIPQ9BR
S3loKCcdoOHPMffiiEoc66sEPPCAiSPjWshoBPcoJ/c1ZxqCaYu8eMzYmktv 4cR87akIfO5L
vff6SJncZTQRdi4aTuBd4N8kgVM+VeMLxp6OSQi2VhFjPNcuKLdxfiIOLyCd +QPTZkizzvST
zrbl1ITYRVxhOMQuPBSD3Pt2fIhZNZnBd+nLNx5T7lUOqbaqY4SfXGGbmGnB Yho4YW40D4NV
Km29+Mpne7E2yLqfUkTpGGC3UZY6L4ssBVHucGzyYlu9gxo2U13CZATFVczC 9dLPrz7A6804
sgMBp4fWfFDuud2yc+UQvpjksXD1BZ+Xq5PNpcwunGmEcYgVVPIZWYohh/CZ nQcg/MBQIxMe
nEZE5GDh36jcDm4imq5vgvW1UvKFPsEQIcU5AnGcSxWcQ+QBO2dt58GHOcDi QxIzvlpdyR/G
KRiSmpBWOPipn8WLwo53jTvPjZ3uXwhj8YinDdinMrvBF/7x1CBeMDmoh738 DZVMz2RUhSgh
UJ4n2MWVYgmSyayyDftvaEbGmF+G9hzt5P34Fv4+Y7k6FL7fxEcYvt+KH+W+ e3KIWZ/ERlXr
H7wdP8g6ltMjIa9U3ju85FXxhF2BaEVTiyvSNtLM8MtQYMYqPZseegUkVrML TdBdWjERwQQI
IlsAir5sjH61BVmWLXEvlWXW6UEmB7kGElPgCEcAVXyvyeoH0yqouUXTwUVD NSjfzoiegHkR
qcAs7Anc7diMYXt+snllQQKF67RHk1tdc3FsY1spcNn35ZAQ1kSGlb3tXQEc rFV8wSNNNVie
eHjoiDNY2y4G25zuAkfm97fkrATKzd0dumwC+bF24rrUpXenWyR7GcrljxJK OnqRgulWcasz
X3dxdJLMrekVaDL+T3V9LQzXyU0mtUcfWOW973aV3FEbx80mPk5ogp3b3CZd WNPq9XEIIkJg
goj1DbdWFEoq76pm+XIMnvz1LYFPE1DqG6VJb/y2vtd7QnXXXfgZB9IZEy8g dmriJcunre+D
RxQ0KqY3h2pMqjvaOcVLq1UmwGnONx0VmoXxUVLbEshnTQII4wmoqYgzUm7V JPTo9ussAD+R
oobUMnIXjzZCB8Pc47Pb1DKNHJLDDKj0+mAD2srdcphZ+6Qf8GXIEJjNtUm2 Eejs/JHSReFx
If2ioRMXLW1yr1ayanhCIhWcEuovw/hS45VvJpond0wmqGcBApx+Dxq9Ymdw lNM6B8+g7HEl
T2XgaFjp3TiLGgpeX8JHqYkkvHb3fATyiLnlmJJ9zZqIeu9dkI2BUET+8PpR KEfabpY8XGeu
f9yp8aCdVaSecT8I16XoFAZk2TWXegtFpbNglSuox8J5+Ydp4H/s54/5t0eo PmAmo3ZvuwkI
e+UY6lfzO9l1xsbR/yX1xo/vdf0S0YeT2MuZ/TU+hsv/5mJ199CMhrVUoRwe FfWEyXgdjT11
fuLSwiQwUhy7R0sikiPsEIpsmCdbYlTz1MQvJ7xOd0Eq8zmzsd0iHZzL9owJ i9tLOBeDrnyU
1w03PvznlfvkG9QARHQ5GOmdzDHqmEYVjtdKbSlZG+stS50CAL5lUwKr9GWR B7rHJsKct68L
yLFZNEMEjVA/twBhySURtzeJ2709ZCDL9xazmkPGnavZHfYu8dfGzxPdpM22 Vi+U48XDd2bN
2RTra8b4j3HiZHkSsjGx0az2s4DmFZZzgImIFx7pW7hH02SJIXGj4mV3m8Cr B12XSkyn7vjo
1RrUGvtZJWgcXGw8PIcDEXjP1e5xpwPHYDE9tYf9fWOzcPQT0BFNM2FGixGl +8VZa1nL7hRg
G3g4U9RZqgQWS7JjV5xucsE8ML5YdYLmnnF9hoZK3t+TonduTKEydg58+CgC Yd/2ZcdtMvNi
w3hSOj1NSjRJ5jpEA0bYIS+JPRWrHMBhXayuKbGUm9FNn2YDGJrh0D3eztM2 jscFyJe6V4Kt
yFHOf8qsHt1oOao1VVY85kmhk2s/P8jjj5pzhnqrjiNn1NCokpzWbCgqxDmW A9kCdTY8Wj6C
OTY6CnDc7u2ntDVgJla0G7qsOZ6b7yTdkKTxYyInbcuxYxzTm0a0m6+dOVGS Pt1WOlRVIZwV
LMzCKzV3uKMrs3NaW84ehKB64M8DMtwWRYdUdPffmiDuCUWRMcjTbXTSDQDc 54iqeEr8GiXP
1jDD4Zflxqib2j25NwRIICi3ZmKnb+PD99TOM8xzr/BAv9vo8hTKuDxQI/r/ I719oLuGmYbS
aI9FU9ZJxUnhqvC90vmgjr8NscfLuB3Il2X/xL0p6d0TEHZLxq9oV88bF6p4 EyLVLkn8EB8w
GXQExSPqRtM1uKGDOENDwPhph4mZ9CxZArNONzDLv5+A4R7BHiclwmzO9brW +2NEPC+nSQrc
8HxCnMR1jcS/K4xJgmFJ9oAp2wPCJr0PumBsPskTMcVHVbgOYhUuAU1VI3Lr I3Ebwfdc2ODB
pBFZpYb0SQwv5/b3se42Mz4SylkYyZqcSnT/dAemwdVhpxAHPkknFEJWvrDS 0bJtGShdFdTC
OGgsmM2Zk+r6cu7Ej/NS2e2+J1QDhXk9j4PJ7P4u+kEnhaFtOIsAIrEqy/OC WTk20q4F4izs
/LzcqkkU7I1Q8oiQPLFM1ZiX9qeiopb+vuYbMUl33bMRTWl2JImq1LgUjVwd bV0PQHSt5gd5
CLaXqBKS41St6OpWN3PakHyUlzE+VTdQmLWxcpls/htmd8/NmOLM1MXJg0cn CNOQDQTPTwzL
DQFnC6otTHoWfZPSxlEvQQrJXhvvOUN2Fx+pkiohtocubfDgpT/qNi2to6KL H9OkwlUNgzv3
GoGNa0G4gfBW7mzERG10rI4S9F/gjWmWTdzbDwL21yrfS7RftcMHLV75Spq7 ouS+JWyq2VXg
DzOZNg4p0KcYUozuWBF++908Y+gjWu1nx96EhU3q9GkLkhc4x97d4X8yvIkb ebl2CHHLU4PR
OTAR/perGwU5CcZIF3zVCnaIBj7nBJhTcZWXvv5IO314IuFsoDWGaTtP1WG8 /jq3dTp0w/Om
rZg43UIZECwC9MhZCPdDHqNG2LoRqtqXtMuKFAST7smx+4r+l+8eO/IqaJ5k 08HKfAR3wf3C
P9C011lAUZlcwSKNfDoyzS084sDJZNCW5ucA+jZ/47442EQ7oncoEsSA1Tkz nBf4bvZtswxP
0SlPxkSk3QvItS06gqU25MBhWgJAa1o//hJcND4myuW//ouXtETS6b7/xGOV zq//EXbJM0st
fXvpqwX72x9/PGzVx1oP6CXDT+nYes0kZ/PWxq79RiJ/wS+oMQOrirWI3Zjo ApcVjmQt0ON3
g5qVcym6nxZBVTB4uFrm0tnCxX27IwSmkcuBKgK1DPNhbbUCrJnSeYObJN8h hN6YI+SBH+JQ
NC46lRuOJ0b4QqFm3y/MAN9f793uThIVisohVrzgTWhlLZDtXR5uBXnKDs5N 4+ReEipA0Dts
Ps/GKvfNkro2BITJKOm0I1sb5Lb7ZQpF6axoOG6I9E196L51zrjb/EVbfhvO 0X6UyzTURjyE
76oIvIvvuHeKDa07ftGRXbWc9r2XxB0BPzjndiWzKIrDgTfX6aN3XLaO0T5h oyCNyikpfEUC
KwkPTTW+HnNuyBmkw8wxXMDMwTsBieIcLITSL4ZmbftepP74AAGQg9K/6l94 cL/3UZy2FIM4
yjLnmqRI9zqN2Up1//+m0zXeyWwPx1FuqdYn+ZJw0bbXlt9I7/HX227zYX4/ yJbWcguZ4+io
+5WPu7r0RNFT/Un8By4oEJEemkZnBO9yqgfqqTD+FhTLwgLAZADjVrDHXQnE S564gjjqAjPa
WrN3n9B5RggfBWlO4lMbTRFa0MtOxJ76BcN+QmfIoxLLv3eYQeZOBaKcxPZ0 s9VCuMBVQKeC
6lcMk4yRzes51qnPYIvBH+YcY8efWV0rX/UecZwdhot3uJfsvL1P3Nvqif4b zUG0ZLZ60P+v
gLWYnFUyIUDml16jLpUnMrzrWzGEqfQOYE6Iy6wF+HklMNMSO81fG2ddzFPe /Ly8ZEUyVtMc
CraCnQA6bJEV77SQW82UTndLRr1f1CF+3nLhkbvtxQ8h2GSwCNsLaawAiJm5 fjbwDGpz09G5
hACtUNnzNGG1FJ8YDJ9fnXtV2EeXtLMv0yZUccFHGE7RNMmjctHqjrnV0Efe Fy3LXUDUccrE
qFeYMuracqgT0cCnQ23cz2lp61zTZfNgbVPYo6vOLxKITzsxSh1aB2kBmJPe J32RWns05tBo
vJNHBDvcGq9bdiQqmZCWt6kVOsDKLtdrRliXlmzXHL4wF7klYDbcviXeN372 CZPXQnNnrRLy
lcg0S/dmhtQRryWkVMocdlStHo7O/YIWdMHA4PDWynp2t3cYKLFU+8apRCVt qHcqVbV8AtS1
T0Pmdc5stQfGc5tusYeUp7AoE7glBkOdEfS1p8PAc227HXZQ1wMbbKadES0U KmTwi7cw3SmU
7NzIkEciySXvQZixZ1HpQ+g4dmgGqV/j2wJWGcDcQdoXBWts3Rnv9DIZ98Ux 1IlG583ypB/k
NzyT6+xKxaCbbh7yqhIXDnBZbBzCT4IEZRNTvUXcpJPDN1tshoCsHwVX399A meC8EJ8wPXg+
TzI2vfiSochH5AzVnjdXZbU5xD8aRQIJ8ekxBEykEL0ajx88KJvqiVI9gZoZ 1wj3Yfh/51oi
j/mUkglyXJRArtqwj7DyqNW3L9denrf5A4Uf5aNCgP3aDv+upkz03DLJKKo9 d2F5rC89fd/l
o75WJp8Jo5bwmQinCDVmaFB29ncigCt3Th2/fZZOHARIyiao2QnaUsS8nChY 1c51WA7dhfln
vxn1SjpAVSevh5wd11r13gAMbs92eeKC3Tb4SFGwOpO1w0dW9poWNhzfUhY8 Wc/5joc0QRFW
A5YEHoNsxC9zco4OE0UtDMWtxRt2GkX6+aG+FHUV3gRyns4nmpCMxNxOe4M7 itmQa4CjuqAI
8nUJ4IN9rTZ5835oaZ81f7qv3pWYVlOnXYFWOcy/27BFZ5OjiIsdU8dvITUO JD9k4jzOfIUu
WT+oDjnPcaIqRjM0iQ+3EUue8wc4L7osWuy5YLoKUAu/k8D9bNIK1I+c/gon 2nefK+uZ7nEo
02BAVqLKbMlecUk1+LRVQNTsQw3XoDhBSGyb/tOxwtfNBCuhGakq0X1TkBzD 6erZiDVuhKKA
4HClkTtfDeckl8rSz1Ihc36XcRZ/p1kGmszbJ6nY4p9tkVRFX8b14hSMZObT hzNCFN+kj1fq
GuK8/WTuW7OPWsqXou7ZKzWbYaYQPjWBw9L95tReEOBSiz1HshKfopuuNbfn Eb26OH44HGDG
YEKXdzS/r9l9PX8re2TVhUiMO1zKD1aiW0wUmoVVN+GEhWFNwU0HW/LzqCZN /Ur7KTZ7IGGn
02xWcbxOcy3pwSYFonL98h9ja4oKCL0VMTslBPJPpypHo9VVcVfNqITpRFg3 cSzMUM4QobhI
BxTTtQkDccCkk9ID4WFfUbxjw1mxi5UYxEqvezH/UtpQbN6Uha1p5iepOTSw BGeDNL5RWI9p
nzmVG8TD63D4veAIxxvv9ayskH2GvkxE4pgJJZ34hIjaSw1LUVS8gVCdoeCG mN94AASXJ6Hq
qsK1gGFKCBpay087Jb1EYLc8QTWlnR4BZfmAY7ZEm+FDvHGCcnIXCpDR6oTj Jh23I5DtXxjJ
3v25nC+eZmKMIUYKROiaSR2zV5IMzKm0u9cFLEZ8BRPDnj0FreHbzv/ySJYB ncAgGVDNVdEE
BlKmgSkLUAtYAXglIEIHAaWQtgIBUgEuShKEqE4HhUBFQShL4UKUs4BEglrB i6EhAmSiZujf
sDoydR06/8gvzMyUDr+0hn38UeBCMdbk9zonX51+ZJLI6Px4ybPg0PypTsV0 68tNaI2Lxuga
zNk1BayN09ftGs6kANZ5tR0C3HQ2YP3T3J6XJQoHls5TK/eN5N0U9b243cl2 E0AN/R1CkTdd
I1dmZ1mO/AyjrDoV3VaxAQjjDQw94NAqBogixEUTlJUUpVZ1oB5Hv3Bgx7Sn uq2tXzeQlsNZ
joGju1sG6G7GCgnMBEinHZzMgtwRzUrWJlh8SqUYa/G/Ef9xrpttdFEwhE7E MDp1+i4/vQOE
aXg/KDhql5IoJQirPMiqXDx+m2YJziy8tLQEOaKZV7Kc162qbNxfSw6YiM+P O3t9fXVZpsWq
6tjCTEbyk1Vw40DB8IauQrCBbDFhljD5D5+sT4AsVwwEXyRX8Mng6x2NjuDb 7Q+jVSF3gO0W
z+Xhic1ZJft1htHuQUh41MeBzBioualsUlkAlDi4fMULWfTExNJu6GTq9EXZ zFlB+GiDUVFR
6UNBTBaUAB+hZdJt7+pamr1LZ/oY82G1fVPwR+YgxpGHa/yYJLqxdBRdGANT A6li1RBEtBDn
nZskvjJQvQFq7VMIHGfPFwIDHEAEnoxndn1xFqOewtHpdqOsgaP6IxYVtTvY LZpDN6MvDeuR
AIL33Q1Zv+CJ0IH3NJ5bMbpP0qN//lSOFVIRLj6cR4Una6fPqrddn9T9upfB szUKokqzUoAW
H4SyLjWSsSzokWPL9BEjRe4toT/p/3eu4wfv8nU0TV3bniLo+y3KR9qsOr1e fwuYcSqQKuDJ
R5nV0Y8CP4Sr6Ny2iJw2MzCpkvh4hl9iSaQ6J+2w2oat3rJu2Zw7G78cf/ZU JuM0ZAMjHddv
F+HdgLKaVwrcaKrIXyc1Smro9OpLZ6vC5BfJ0qEBOM/gIwQovwSxPfoJcBkl 6IPKoR84oC7B
Jccmd9EwDOyInBdtaWWXLTx19myQ0qgMnRkZgjgCMbmDMJGHjy3SGSZeKUkk VMUDPpRs2YHZ
V4iG9xLf16OJMEMAl0IEj+FI36r0mDL/G4M0YkwpHrOHHHiq1cM6q+/ACxbf o8FEYhmadJJK
5XlRV3ZKIriBEIXhkQuGWsi6EnPvVSaYgWiKWzY3XrabWeBcFLFXPTkmCt7q jf9ibPK0DUCy
Xt2YG2C2BRoDyo38KdZGhzkHOJLjEmRYJNHEq4/Qdh+YQal0IhfUe+7rw9wK 3ZU2xfbsuN9n
Ar37N2Z/b+K8AW87EIyvLhAvw0AJa8KksuI5gYF01CntGQH2oOYqKQ2gxuN0 GUKRrbhb6vKp
jzJeIt9GLIlv4AKj6NiyjekjEvEBciZUSarUarRr/MNSYImUOU84Kuf1+uwz EP3t85s8HDRS
cwKY6SVU07WUkZ/Xjtpgp+LE5tZB5tMzVM1O188ZKUdI/Q5GLJ0JNFDhZwKd qiyjxkXcY71A
sJmHZVimscBAIBTQrSirDTymOTbDOLyWKBYKDox/CYEsnz08+QT0Wfo0jAHZ otEaAvHHqhck
G0wlgkPT53vHIcPuJd0ZUk7bMGhxULUFSWsIZsfrXbgjgSgixvBsmRJAWNeo EvQMC2KS8YsW
bVlfMAjhpKCIUW2a6eaIUNUHLruMnmO53CJ1tZzWiaR8oGJdIe2iJvFKHMqi y7aSQkNCXcW3
HuNC0ZJD8EaUfxHlt0xmhWznPHyZ3tCYm7WqN/gVwY/HPCsKbP/r2SbAT88e tEZYUu4vzs6/
8KC1g4ToXMPj6WpkunwvpN3emx7xlu383nJcCote4UFiWJeDy1FfCkz6dtb8 hu/StKdHG7fq
m7+Wj23pTFe5HG29SWSuWEhmZDimSfWcLmZY1IAosrTpt0BpCqV4nn4qxTA7 MCx7PwKxnDai
Bfmnz06+TDPK279Z6+OteJdyUm+pc4dPApIWNHqo7vGDoEyh4CDSC6VWGH/X OeXsvlpKYrON
QZSe76Kd2GaExMlkC/MEpt6TnGRUNsV4CeVlvx1vaH3WRPOgi7ONVBuo4mc9 KPkuU49ork91
p45P9T8ZIXdOIQSoWTZX7kEIlQSNue0osNJdAk3rY4fOoLs5U3+O6LCvtOxu v6PJ2KWQ0Qhx
W1wQGF0/fVDhMWrKaz4CTg/PIM4TsXmv3jXXfn1ZwmLpTyvJlP9pQKqF4rwW vLB/U09jm5cB
1XIa87WtsrJvfr4l0zdU2Tef1Kuqgr0yR/0lNqrf+gkCP9RHP9OQVliU/tvt R8hbymSfcDNq
73C/YF+8X0/6CXHlVpd+03+V+YZoK2shRC7KXHXeam6LnXRUqrxMYeMKWdFc 2aKjCYb6fu4L
Im7jrJU+0+6dhKpMXn4gonvyQ45ZMs5hYs/3oRQ7hGgxmUU/JtIFEL7LcdBi o82pTP77mYz9
HXPlpaQ+odUsTbO8JMG9uRSn0KDlk6BgrkiL9EefTD1OavfZIe7uyAupY5+f nucSLpU3QtiV
mzSGEvzzcWvd2q5KmPYo1a79z0tKwoceqiqJUUH/HRCiDb73Tzxkuv9KEnZj ql+0XJOTiPEQ
6ai4sOu5KOydEzo5KG0gF6cVfkIG6woaLbDypJvXjN1o4Xuc/lU2+TVLkUmn eoWswEN+gEz3
q1YGOcs1jaEpYlNCVi2CZl/PlPqZNOi26eMDsrWkuM0le5vX2Gm6GRNalKax sk8lamrB05FF
COMei3GScBPlMl12qXl/n/k9lTDmzEzBRWhG2n5Uw0tWJ8N2twlOMXflZq55 axKs34ZJhVO8
pK0xev7ckujMW94Etbbs7QzQSahApI6cRIhFxuTaCe61QZrWVjvLO79Im+5A Lg+q2ZLZzQHt
w3c28uZDHTV2OmZ6NLDhKmrnUjgnErOgPOVzuEdN3ohEsqZn5DQK4atPBZxW YOUlnjId/9Ut
8XjVwSEWUOL29TrHSvzh87i+DHfA19MVd+uKvXA1y8Wjpe5Ns/fZI2Qkxev6 1iXBZM33gGXU
4GrTtabnQy35YtxOfTeqbAsoJ30p6GzJwAnBYxdRcaBKUWiEhpini27sXY/3 Zo7t35GAK+dm
hBNtCP4qdQOqA1lyG7t4jqO7GTXeYtWtPloiHXKl1TL0pfzT1a3uZPrYMsye 3CJkJi8scNMD
panB7QwbLA4Z5qCuW4kPim+tKeCZmLJAOghX5KnHirb4ukHrFfyuPrl4dbLD wTARPC64jI+S
FEGSkcYgD70/cU6aElkFyvUytzf8BqGYXUMVXWuBGJN8/LJgFvu3FpBAjSCh UzoIhBhDy/JQ
Xb3VPtOuTsNTDnyjsuId++Mj+D+h1osLCNJOv5NuyJn/h9KYmya9S3Vazqr8 vj59RHr6MNx9
LQe8ZuTEaRbBXdrqPERGocu8l3YphtSZ40V2gftu2y31dI+y4bGrF3mznf2m fag3QfJRRYyg
T/0Epfmorf+ZJXw+gRult7BFGgLCJX7U8W+soNr77m4Gas1RpVfiUOec9I+D hESzsvp1q9Ff
lXC8qlf9XmsCOgJDRGoSfbuq6UDf2gXtE7nsaPj06HerO3Zf6ZKVok8syXb8 z0g8hKkJ/plg
yykHx1G7r4/CXRuLDSjRcGXBrVB2jQsu9i7rKAc8JoeEUsEe+DyYTiZ7rgFd 2Pkr65/TQTNt
XduhHS060lWsHNekytm695O3nqLxqg1qjGXStxGXBiglWFeMjQU14dPtwPum CDVodReRYGcG
Si0MfSBgXkmqodyShpq6hXc+W+1SLG1BncHliPeSvr/5lS3/hys2X/XiM8zw Sh3R+c2BU+Z1
Re: Persist EObject from BPEL20.XSD [message #609628 is a reply to message #95599] Mon, 03 September 2007 05:20 Go to previous message
Hi Daniel,
After some testing: the issue is related to that multiple types/join relations are stored in the
same table (check the hbm for all the types ending on _mixed). It is somehow related to the fact
that the model has multiple types with both a mixed and an any typed element. This goes wrong.
Although I know what goes wrong I do not yet have an easy workaround or solution. I will look at a
solution further today.
gr. Martin
Daniel Gerlach wrote:
> Hello,
> http://docs.oasis-open.org/wsbpel/2.0/OS/process/executable/ ws-bpel_executable.xsd
> Namespace-XSD.
> Daniel Gerlach
> Ed Merks schrieb:
>> Daniel,
>> the XMLNamespace package that already exists in the Ecore plugin. It
>> would seem better to reuse that rather than generate a duplicate of it.
>> one package is registered for the namespace
>> </extension>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Persist EObject from BPEL20.XSD [message #609630 is a reply to message #95633] Mon, 03 September 2007 08:06 Go to previous message
--------------070701090607040704090106
Hi Daniel,
I have solved this issue. This will be available in the next release (late this week). In the mean
time I have attached the hbm which I created using the new mapping logic for mixed/any typed
elements. You can use this hbm to workaround this issue.
gr. Martin
Martin Taal wrote:
> Hi Daniel,
> relations are stored in the same table (check the hbm for all the types
> ending on _mixed). It is somehow related to the fact that the model has
> wrong. Although I know what goes wrong I do not yet have an easy
> workaround or solution. I will look at a solution further today.
> gr. Martin
>> Hello,
>> how i generated the Ecore-model. But i didn't see an option to
>> reference an existing generator model at the last step of the wizard.
>> because i am able to load and parse instances of the XML-Schema. I can
>> write them in a normal file, too. Only the database doesn't work.
>> because i get a "foreign constraint violation error"(see my first
>> posting) when i want to persist an EObject of the
>> Namespace-XSD.
>> Daniel Gerlach
>> Ed Merks schrieb:
>>> Daniel,
>>> On the last page of the import wizard, there is the option to reuse
>>> Aren't you getting a warning in the Error log indicating more than
>>> "http://www.w3.org/XML/1998/namespace" because of you duplicate
>>> registration for the following registration in the Ecore plugin.xml?
>>> <extension point="org.eclipse.emf.ecore.generated_package">
>>> <package uri="http://www.w3.org/XML/1998/namespace"
>>> class="org.eclipse.emf.ecore.xml.namespace.XMLNamespacePackage "
>>> genModel="model/XMLNamespace.genmodel" />
>>> </extension>
The Netherlands
Content-Type: text/xml;
name="bpel.hbm.xml"
Content-Disposition: inline;
filename="bpel.hbm.xml"
<!DOCTYPE hibernate-mapping PUBLIC "-//Hibernate/Hibernate Mapping DTD 3.0//EN" "http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd">
<!-- Generated by Teneo on Mon Sep 03 14:02:00 CEST 2007 -->
<hibernate-mapping auto-import="false">
<typedef name="executable.BPELVariableNames" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="epackage">http://docs.oasis-open.org/wsbpel/2.0/process/executable</param>
<param name="edatatype">BPELVariableNames</param>
</typedef>
<typedef name="executable.BPELVariableNamesBase" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">BPELVariableNamesBase</param>
</typedef>
<typedef name="executable.QNames" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">QNames</param>
</typedef>
<typedef name="executable.QNamesBase" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">QNamesBase</param>
</typedef>
<typedef name="executable.TBooleanObject" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">TBooleanObject</param>
</typedef>
<typedef name="executable.TInitiateObject" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">TInitiateObject</param>
</typedef>
<typedef name="executable.TPatternObject" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">TPatternObject</param>
</typedef>
<typedef name="executable.TRolesObject" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">TRolesObject</param>
</typedef>
<typedef name="namespace.LangTypeMember1Object" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="epackage">http://www.w3.org/XML/1998/namespace</param>
<param name="edatatype">LangTypeMember1Object</param>
</typedef>
<typedef name="namespace.SpaceTypeObject" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">SpaceTypeObject</param>
</typedef>
<class name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TEx tensibleElementsImpl " entity-name="TExtensibleElements" abstract="false" lazy="false" table="`textensibleelements`">
<meta attribute="eclassName">TExtensibleElements</meta>
<meta attribute="epackage">http://docs.oasis-open.org/wsbpel/2.0/process/executable</meta>
<id type="long" name="e_id" column="e_id" access=" org.eclipse.emf.teneo.hibernate.mapping.identifier.Identifie rPropertyHandler ">
<meta attribute="syntheticId">true</meta>
<generator class="native"/>
</id>
<version name="e_version" column="e_version" access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler ">
<meta attribute="syntheticVersion">true</meta>
</version>
<list name="documentation" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`textensibleelements_documentation_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`textensibleelements_documentation_idx`"/>
<one-to-many entity-name="TDocumentation"/>
</list>
<list name="any" table="`textensibleelements_any`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`textensibleelements_any_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`textensibleelements_any_idx`"/>
<one-to-many entity-name="TExtensibleElements_any"/>
</list>
<list name="anyAttribute" table="`textensibleelements_anyattribute`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`textensibleelements_anyattribute_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`textensibleelements_anyattribute_idx`"/>
<one-to-many entity-name="TExtensibleElements_anyAttribute"/>
</list>
</class>
<class entity-name="TExtensibleElements_any" lazy="false" table="`textensibleelements_any`">
<meta attribute="featureMap">TExtensibleElements</meta>
<id type="long">
</id>
<version name="e_version" access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler ">
</version>
<property name="fme_feature" type="java.lang.String"/>
<key update="true">
<column name="`any_textensibleelements_documentation_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`any_textensibleelements_documentation_idx`"/>
</list>
<list name="anyAttribute" table="`any_textensibleelements_anyattribute`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`any_textensibleelements_anyattribute_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`any_textensibleelements_anyattribute_idx`"/>
</list>
<property name="fme_mixed_text" type="java.lang.String"/>
<property name="fme_mixed_cdata" type="java.lang.String"/>
<property name="fme_mixed_comment" type="java.lang.String"/>
</class>
<class entity-name="TExtensibleElements_anyAttribute" lazy="false" table="`textensibleelements_anyattribute`">
<id type="long">
</id>
</version>
</class>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TAc tivityImpl " entity-name="TActivity" abstract="false" lazy="false" extends="TExtensibleElements" table="`tactivity`">
<meta attribute="eclassName">TActivity</meta>
<key>
<column name="`textensibleelements_e_id`"/>
</key>
<many-to-one name="targets" entity-name="TTargets" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`ttargets_targets_e_id`"/>
</many-to-one>
<many-to-one name="sources" entity-name="TSources" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tsources_sources_e_id`"/>
</many-to-one>
<property name="name" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`name`"/>
</property>
<property name="suppressJoinFailure" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`suppressjoinfailure`"/>
<type name="org.eclipse.emf.teneo.hibernate.mapping.ENumUserType" >
<param name="enumClass"> org.open.oasis.docs.wsbpel._2._0.process.executable.TBoolean </param>
</type>
</property>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TAc tivityContainerImpl " entity-name="TActivityContainer" abstract="false" lazy="false" extends="TExtensibleElements" table="`tactivitycontainer`">
<meta attribute="eclassName">TActivityContainer</meta>
<key>
</key>
<many-to-one name="assign" entity-name="TAssign" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tassign_assign_e_id`"/>
</many-to-one>
<many-to-one name="compensate" entity-name="TCompensate" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tcompensate_compensate_e_id`"/>
</many-to-one>
<many-to-one name="compensateScope" entity-name="TCompensateScope" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tcompensatescope_compensatescope_e_id`"/>
</many-to-one>
<many-to-one name="empty" entity-name="TEmpty" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tempty_empty_e_id`"/>
</many-to-one>
<many-to-one name="exit" entity-name="TExit" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`texit_exit_e_id`"/>
</many-to-one>
<many-to-one name="extensionActivity" entity-name="TExtensionActivity" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`textensionactivity_extensionactivity_e_id`"/>
</many-to-one>
<many-to-one name="flow" entity-name="TFlow" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tflow_flow_e_id`"/>
</many-to-one>
<many-to-one name="forEach" entity-name="TForEach" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tforeach_foreach_e_id`"/>
</many-to-one>
<many-to-one name="if" entity-name="TIf" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tif_if_e_id`"/>
</many-to-one>
<many-to-one name="invoke" entity-name="TInvoke" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tinvoke_invoke_e_id`"/>
</many-to-one>
<many-to-one name="pick" entity-name="TPick" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tpick_pick_e_id`"/>
</many-to-one>
<many-to-one name="receive" entity-name="TReceive" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`treceive_receive_e_id`"/>
</many-to-one>
<many-to-one name="repeatUntil" entity-name="TRepeatUntil" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`trepeatuntil_repeatuntil_e_id`"/>
</many-to-one>
<many-to-one name="reply" entity-name="TReply" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`treply_reply_e_id`"/>
</many-to-one>
<many-to-one name="rethrow" entity-name="TRethrow" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`trethrow_rethrow_e_id`"/>
</many-to-one>
<many-to-one name="scope" entity-name="TScope" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tscope_scope_e_id`"/>
</many-to-one>
<many-to-one name="sequence" entity-name="TSequence" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tsequence_sequence_e_id`"/>
</many-to-one>
<many-to-one name="throw" entity-name="TThrow" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tthrow_throw_e_id`"/>
</many-to-one>
<many-to-one name="validate" entity-name="TValidate" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tvalidate_validate_e_id`"/>
</many-to-one>
<many-to-one name="wait" entity-name="TWait" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`twait_wait_e_id`"/>
</many-to-one>
<many-to-one name="while" entity-name="TWhile" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`twhile_while_e_id`"/>
</many-to-one>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TAs signImpl " entity-name="TAssign" abstract="false" lazy="false" extends="TActivity" table="`tassign`">
<meta attribute="eclassName">TAssign</meta>
<key>
<column name="`tactivity_e_id`"/>
</key>
<list name="group" table="`tassign_group`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`tassign_group_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`tassign_group_idx`"/>
<one-to-many entity-name="TAssign_group"/>
</list>
<property name="validate" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`validate`"/>
</type>
</property>
</joined-subclass>
<class entity-name="TAssign_group" lazy="false" table="`tassign_group`">
<meta attribute="featureMap">TAssign</meta>
<id type="long">
</id>
</version>
<many-to-one name="copy" entity-name="TCopy" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`group_tcopy_copy_e_id`"/>
</many-to-one>
<many-to-one name="extensionAssignOperation" entity-name="TExtensionAssignOperation" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name=" `group_textensionassignoperation_extensionassignoperation_e_ id` "/>
</many-to-one>
</class>
<class name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TEx pressionImpl " entity-name="TExpression" abstract="false" lazy="false" table="`texpression`">
<meta attribute="eclassName">TExpression</meta>
</id>
</version>
<list name="mixed" table="`texp_mixed`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`texpression_mixed_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`texpression_mixed_idx`"/>
<one-to-many entity-name="TExpression_mixed"/>
</list>
<property name="expressionLanguage" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`expressionlanguage`"/>
</property>
<list name="anyAttribute" table="`texpression_anyattribute`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`texpression_anyattribute_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`texpression_anyattribute_idx`"/>
<one-to-many entity-name="TExpression_anyAttribute"/>
</list>
</class>
<class entity-name="TExpression_mixed" lazy="false" table="`texpression_mixed`">
<meta attribute="featureMap">TExpression</meta>
<id type="long">
</id>
</version>
<list name="any" table="`mixed_texpression_any`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`mixed_texpression_any_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`mixed_texpression_any_idx`"/>
<one-to-many entity-name="TExpression_any"/>
</list>
<column not-null="false" unique="false" name="`mixed_expressionlanguage`"/>
</property>
<list name="anyAttribute" table="`mixed_texpression_anyattribute`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`mixed_texpression_anyattribute_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`mixed_texpression_anyattribute_idx`"/>
</list>
</class>
<class entity-name="TExpression_anyAttribute" lazy="false" table="`texpression_anyattribute`">
<id type="long">
</id>
</version>
</class>
<class entity-name="TExpression_any" lazy="false" table="`texpression_any`">
<id type="long">
</id>
</version>
<list name="mixed" table="`any_texp_mixed`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`any_texpression_mixed_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`any_texpression_mixed_idx`"/>
</list>
<column not-null="false" unique="false" name="`any_expressionlanguage`"/>
</property>
<list name="anyAttribute" table="`any_texpression_anyattribute`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`any_texpression_anyattribute_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`any_texpression_anyattribute_idx`"/>
</list>
</class>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TBo oleanExprImpl " entity-name="TBooleanExpr" abstract="false" lazy="false" extends="TExpression" table="`tbooleanexpr`">
<meta attribute="eclassName">TBooleanExpr</meta>
<key>
<column name="`texpression_e_id`"/>
</key>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TBr anchesImpl " entity-name="TBranches" abstract="false" lazy="false" extends="TExpression" table="`tbranches`">
<meta attribute="eclassName">TBranches</meta>
<key>
</key>
<property name="successfulBranchesOnly" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`successfulbranchesonly`"/>
</type>
</property>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCa tchImpl " entity-name="TCatch" abstract="false" lazy="false" extends="TActivityContainer" table="`tcatch`">
<meta attribute="eclassName">TCatch</meta>
<key>
<column name="`tactivitycontainer_e_id`"/>
</key>
<property name="faultElement" lazy="false" insert="true" update="true" not-null="false" unique="false" type="javax.xml.namespace.QName">
<column not-null="false" unique="false" name="`faultelement`"/>
</property>
<property name="faultMessageType" lazy="false" insert="true" update="true" not-null="false" unique="false" type="javax.xml.namespace.QName">
<column not-null="false" unique="false" name="`faultmessagetype`"/>
</property>
<property name="faultName" lazy="false" insert="true" update="true" not-null="false" unique="false" type="javax.xml.namespace.QName">
<column not-null="false" unique="false" name="`faultname`"/>
</property>
<property name="faultVariable" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`faultvariable`"/>
</property>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo mpensateImpl " entity-name="TCompensate" abstract="false" lazy="false" extends="TActivity" table="`tcompensate`">
<meta attribute="eclassName">TCompensate</meta>
<key>
</key>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo mpensateScopeImpl " entity-name="TCompensateScope" abstract="false" lazy="false" extends="TActivity" table="`tcompensatescope`">
<meta attribute="eclassName">TCompensateScope</meta>
<key>
</key>
<property name="target" lazy="false" insert="true" update="true" not-null="true" unique="false" type="java.lang.String">
<column not-null="true" unique="false" name="`target`"/>
</property>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo mpletionConditionImpl " entity-name="TCompletionCondition" abstract="false" lazy="false" extends="TExtensibleElements" table="`tcompletioncondition`">
<meta attribute="eclassName">TCompletionCondition</meta>
<key>
</key>
<many-to-one name="branches" entity-name="TBranches" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`tbranches_branches_e_id`"/>
</many-to-one>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo nditionImpl " entity-name="TCondition" abstract="false" lazy="false" extends="TExpression" table="`tcondition`">
<meta attribute="eclassName">TCondition</meta>
<key>
</key>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo pyImpl " entity-name="TCopy" abstract="false" lazy="false" extends="TExtensibleElements" table="`tcopy`">
<meta attribute="eclassName">TCopy</meta>
<key>
</key>
<many-to-one name="from" entity-name="TFrom" cascade="all" lazy="false" insert="true" update="true" not-null="true">
<column not-null="true" unique="false" name="`tfrom_from_e_id`"/>
</many-to-one>
<many-to-one name="to" entity-name="TTo" cascade="all" lazy="false" insert="true" update="true" not-null="true">
<column not-null="true" unique="false" name="`tto_to_e_id`"/>
</many-to-one>
<property name="ignoreMissingFromData" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`ignoremissingfromdata`"/>
</type>
</property>
<property name="keepSrcElementName" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`keepsrcelementname`"/>
</type>
</property>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo rrelationImpl " entity-name="TCorrelation" abstract="false" lazy="false" extends="TExtensibleElements" table="`tcorrelation`">
<meta attribute="eclassName">TCorrelation</meta>
<key>
</key>
<property name="initiate" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`initiate`"/>
<param name="enumClass"> org.open.oasis.docs.wsbpel._2._0.process.executable.TInitiat e </param>
</type>
</property>
<property name="set" lazy="false" insert="true" update="true" not-null="true" unique="false" type="java.lang.String">
<column not-null="true" unique="false" name="`set`"/>
</property>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo rrelationsImpl " entity-name="TCorrelations" abstract="false" lazy="false" extends="TExtensibleElements" table="`tcorrelations`">
<meta attribute="eclassName">TCorrelations</meta>
<key>
</key>
<list name="correlation" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`tcorrelations_correlation_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`tcorrelations_correlation_idx`"/>
<one-to-many entity-name="TCorrelation"/>
</list>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo rrelationSetImpl " entity-name="TCorrelationSet" abstract="false" lazy="false" extends="TExtensibleElements" table="`tcorrelationset`">
<meta attribute="eclassName">TCorrelationSet</meta>
<key>
</key>
<property name="name" lazy="false" insert="true" update="true" not-null="true" unique="false" type="java.lang.String">
<column not-null="true" unique="false" name="`name`"/>
</property>
<property name="properties" lazy="false" insert="true" update="true" not-null="true" unique="false" type="executable.QNames">
<column not-null="true" unique="false" name="`properties`"/>
</property>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo rrelationSetsImpl " entity-name="TCorrelationSets" abstract="false" lazy="false" extends="TExtensibleElements" table="`tcorrelationsets`">
<meta attribute="eclassName">TCorrelationSets</meta>
<key>
</key>
<list name="correlationSet" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`tcorrelationsets_correlationset_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`tcorrelationsets_correlationset_idx`"/>
<one-to-many entity-name="TCorrelationSet"/>
</list>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo rrelationsWithPatternImpl " entity-name="TCorrelationsWithPattern" abstract="false" lazy="false" extends="TExtensibleElements" table="`tcorrelationswithpattern`">
<meta attribute="eclassName">TCorrelationsWithPattern</meta>
<key>
</key>
<key update="true">
<column name="`tcorrelationswithpattern_correlation_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`tcorrelationswithpattern_correlation_idx`"/>
<one-to-many entity-name="TCorrelationWithPattern"/>
</list>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TCo rrelationWithPatternImpl " entity-name="TCorrelationWithPattern" abstract="false" lazy="false" extends="TCorrelation" table="`tcorrelationwithpattern`">
<meta attribute="eclassName">TCorrelationWithPattern</meta>
<key>
<column name="`tcorrelation_e_id`"/>
</key>
<property name="pattern" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`pattern`"/>
<param name="enumClass"> org.open.oasis.docs.wsbpel._2._0.process.executable.TPattern </param>
</type>
</property>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TDe adlineExprImpl " entity-name="TDeadlineExpr" abstract="false" lazy="false" extends="TExpression" table="`tdeadlineexpr`">
<meta attribute="eclassName">TDeadlineExpr</meta>
<key>
</key>
</joined-subclass>
<class name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TDo cumentationImpl " entity-name="TDocumentation" abstract="false" lazy="false" table="`tdocumentation`">
<meta attribute="eclassName">TDocumentation</meta>
</id>
</version>
<list name="mixed" table="`tdocumentation_mixed`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`tdocumentation_mixed_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`tdocumentation_mixed_idx`"/>
<one-to-many entity-name="TDocumentation_mixed"/>
</list>
<property name="lang" lazy="false" insert="true" update="true" not-null="false" unique="false">
<column not-null="false" unique="false" name="`lang`"/>
<type name=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">AnySimpleType</param>
<param name="epackage">http://www.eclipse.org/emf/2003/XMLType</param>
</type>
</property>
<property name="source" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`source`"/>
</property>
</class>
<class entity-name="TDocumentation_mixed" lazy="false" table="`tdocumentation_mixed`">
<meta attribute="featureMap">TDocumentation</meta>
<id type="long">
</id>
</version>
<list name="any" table="`mixed_tdocumentation_any`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`mixed_tdocumentation_any_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`mixed_tdocumentation_any_idx`"/>
<one-to-many entity-name="TDocumentation_any"/>
</list>
<column not-null="false" unique="false" name="`mixed_lang`"/>
</type>
</property>
<column not-null="false" unique="false" name="`mixed_source`"/>
</property>
</class>
<class entity-name="TDocumentation_any" lazy="false" table="`tdocumentation_any`">
<id type="long">
</id>
</version>
<list name="mixed" table="`any_tdocumentation_mixed`" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="`any_tdocumentation_mixed_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`any_tdocumentation_mixed_idx`"/>
</list>
<column not-null="false" unique="false" name="`any_lang`"/>
</type>
</property>
<column not-null="false" unique="false" name="`any_source`"/>
</property>
</class>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TDu rationExprImpl " entity-name="TDurationExpr" abstract="false" lazy="false" extends="TExpression" table="`tdurationexpr`">
<meta attribute="eclassName">TDurationExpr</meta>
<key>
</key>
</joined-subclass>
<joined-subclass name=" org.open.oasis.docs.wsbpel._2._0.process.executable.impl.TEl seifImpl " entity-name="TElseif" abstract="false" lazy="false" extends="TExtensibleElements" table="`telseif`">
<meta attribute="eclassName">TElseif</meta>
<key>
</key>
<many-to-one name="condition" entity-name="TBooleanExpr" cascade="all" lazy="false" insert="true" update="true" not-null="true">
<column not-null="true" unique="false" name="`tbooleanexpr_condition_e_id`"/>
</many-to-one>
Re: Persist EObject from BPEL20.XSD [message #609632 is a reply to message #95599] Mon, 03 September 2007 08:56 Go to previous message
Daniel,
I can't find a tool that will view the *.rar file. Posting a GIF or
JPEG would be easier to use. I guess I should have asked what version
of EMF you are using. The registration of .genmodel files was added in
EMF 2.1. The complaints about duplicate nsURI registrations was added
in 2.2. You might find the code you're using isn't actually even using
the XML namespace package you generated... Does your generated model
have a generated_package extension with the same namespace as I showed
below? That's definitely something to avoid long term...
> Hello,
> i don't have any warning or any error. I added a few screenshots of
> But I don't think that's the problem. The Ecore model seems fine
> For me, the problem lies in the generated hibernate-mapping-xml,
> and the error is thrown for an EObject of the BPEL-XSD and not of the
> Namespace-XSD.
> Daniel Gerlach
> Ed Merks schrieb:
>> Daniel,
>> </extension>
Re: Persist EObject from BPEL20.XSD [message #609635 is a reply to message #95716] Mon, 03 September 2007 13:43 Go to previous message
--------------050202070407040201020302
Hi Ed,
i added for you the pics again. I use Eclipse3.3, so i suppose it is EMF
2.3.
In my plugin.xml there isn't the
org.eclipse.emf.ecore.xml.namespace.XMLNamespacePackage, only the one i
have generated:
<package
uri = "http://www.w3.org/XML/1998/namespace"
class = "org.w3.xml._1998.namespace.NamespacePackage"
genModel = "model/ws-bpel_executable.genmodel" />
</extension>
For now, i work with the solution from Martin.
Daniel Gerlach
Ed Merks wrote:
> Daniel,
>> Hello,
>> Namespace-XSD.
>> Daniel Gerlach
>> Ed Merks schrieb:
>>> Daniel,
>>> </extension>
Content-Type: image/jpeg;
name="screenshot01.jpg"
filename="screenshot01.jpg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDABALDA4MChAODQ4SERATGCgaGBYW GDEjJR0oOjM9
PDkzODdASFxOQERXRTc4UG1RV19iZ2hnPk1xeXBkeFxlZ2P/2wBDARESEhgV GC8aGi9jQjhC
Y2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2Nj Y2NjY2P/wAAR
CAJjAjkDASIAAhEBAxEB/8QAGwABAAIDAQEAAAAAAAAAAAAAAAMFAQIEBwb/ xABPEAABAwIC
BwIJBwoFBAICAwEBAAIDBBESIQUTFDFSk9FBURUiM1NUYXGy0jJyc3SBkbMG IzQ1NkNikqGx
JEKClKJEweHwFqMlJmOD8cL/xAAZAQEBAQEBAQAAAAAAAAAAAAAAAQIDBAX/ xAAqEQEAAgIB
AwQCAwEBAAMAAAAAAQIRElEhMkEDEzHwgcEiYaHRUiNxsf/aAAwDAQACEQMR AD8A+j0bo6nl
pI6ipiZPLM0PJkGIAHMAA7sl1eDaD0Gl5Leizoz9VUf1eP3Qq/Sc73tljAN7 kAhrjb7gutYy
z8u1+jqHsoaXkt6LVujqL0Kl5Dei+e0bJV02koWh7jE94a5pjktnl2tsr/TY f4JmEcr4nOwt
D43Wc27gLgpeNUhL4NovQqbkt6LPg2h9CpuS3oqp2lZKaqjFWZMdJBNr2M/e YcGFwHbcHLuu
R3rpptOSvI2mhfAzG1rpHY2tAINiMbGkm4AIt/mGaxmFw7PBtF6FTclvRYOj qH0Kl5Leii0b
pbwg9jBTmJ2Bz5Gud40fjWaCLdoufsVg4Kwji8H0PoNLyW9E8H0PoVLyW9F1 FarWEc/g+i9C
peS3osHR9F6FS8lvRdKJgy5dgofQqXkt6JsFD6FS8lvRTv3LVt75pgyiNBRe hUvJb0WNhovQ
qXkt6KZ5sFHiITCZYFDQ+hUvJb0WwoKD0Kl5LeixjKCQq4MtvB9B6FS8lvRP B9B6FS8lvRZE
hQyFMGWvg+h9CpeS3ong+h9CpeS3opGPJWZHWCYModgofQqXkt6LGwUPoVLy W9FnWFC82WtU
y12Gh9CpeS3osbDRehUvJb0QyFbRuJKamWuw0foVLyG9FjYaP0Kl5Dei6EUx BmXPsVH6FS8h
vRY2Kj9DpeQ3ouhYTEGZc+x0nodLyGdE2Ok9DpeQzop1hMQZlDsdJ6HS8hnR Y2Ok9DpeQzop
0TEGZRCjo/QqXkN6LYUVF6FS8lvRbrIKYgzLUUFF6FS8lvRZ2Ci9CpeS3opA VuCmIMyg2Ci9
CpeS3omwUXoVLyW9F0ImIMy59govQqXkt6JsFF6FS8lvRdCJiDMufYKL0Kl5 LeieD6L0Kl5L
ei6ETEGZc/g+h9CpeS3ong+h9CpeS3ouhExBmUHg+h9CpeS3ong+h9CpeS3o uhFMQZlz+D6H
0Gl5LeieD6H0Gl5Lei6ETELlB4PofQaXkt6J4OofQaXkt6LoRMQZc/g6h9Bp eS3ong6h9Bpe
S3oulExBlz+DqH0Gl5LeieDqD0Gl5Lei6FlTC5c3g6g9BpeS3ong6g9BpeS3 oulEwZcFRo+h
bNS2o6YAykG0Tcxgee71BT+D9H+g0vJb0WmkLjZiDa02/wBrHgf1KgOPWAyC V7LHJjrG+Vu0
etZwsS6vB+j/AEGl5LeijqKCgEbbUVMDrGDKFvEPUoZC0xuEcVS19jhJlyB7 P8ySazC25PlG
dv8AG1MKkqKSijdEyLR1G+SV+FodG1o+STmcJ7u5c8UdJNII4qPQsjzua2Vp J+zAsy65ssEo
Y+TVvLi0EX+S4dp9aggY+B0J1Vc9sPyGuMVhkR2HuKYIdEtNQS6JfUMoaZhd AXi0Tbjxb77K
B7KQSOGyUuRI8gzotJWSxaFkjcSCymc0i/cxVU8c+0y2kfbGe31rl6kzV6fQ pFs5WzxSNjc4
UVK4gEhogZn/AEWzKcPax7NH6PdG9heJg1uraBvxEtuD6rf2NqbV1OE2e4ns zXbHKxlIaQ08
z4ZPGleXAPL8rEC9srD/AN34pbPy6+r6euNY/wAdMWySRh5oqQXv+4b9+bR/ ZbFtJ6JS8hnR
VGrqLfLf9pstDFUk2D3/AHrG85dPZphdN0bTz6LkkjjZFM2SUtewW3PdYG28 WFl8x4YfxlfX
6NDhoN+K98U5/wDsevNbr1Y6RL5uf5zD1bRf6qovq8fuhculNCQ6RuTIYn8Q F1NRyGHQEEoF
zHSNcAe2zAV17PV+kQch3xrUWwkZ8KHRX5LU+jasVUs7qiVvyLtwhvrtcq6l jjqIjFK3EwkE
i9txv/2W5pqs/wDUU/Id8a1FJVj/AKin5DvjS1tvkxKOahpKip2iaBr5TEYS 49rDvB71p4Lo
3UclJIyWWCS2Jks75N262Ikj7F07NV+kQch3xps1X6RByHfGs5herWGkp6eo nqIogyWfDrHD
/NYWH9FKStNnq/SIOQ7402ar9Ig5DvjVzCYllYTZqv0iDkO+NNlq/SIOQ741 doMSwsLOy1Xp
EHJd8abLVekQcl3xptBrLBWMlsaSqP8A1EHJd8a12Oq9Ig5LvjTaDWWpzWhY ptjqvSIOS740
2Op8/ByXfGm0JrKDAmBT7HU+fg5LvjTYqnz8HJd8au8GsoQFsGgrfYqnz8HJ d8azsdT6RByX
fGm8GstWsssubcLbZar0iDku+NNlqvSIOS7403g1lFqlgx5KbZar0iDku+NN kqvSIOS741d4
TSXOIls2Oym2Sq9Ig5LvjTZKr0iDku+NPcg0lGsKTY6r0iDku+NNjqfSIOS7 41N4XWUawpdj
qfPwcl3xpsVT5+Dku+NN4NZQopdiqfPwcl3xpsVT5+Dku+NN4NZQrCn2Gp8/ ByXfGmw1Hn4O
S7403g1lAin2Go8/ByXfGsbBUefg5LvjTeDWUQK3BW+w1Hn4OS7402Kp8/By XfGm8GsgKymx
1XpEHJd8azslV6RByXfGm8GssIs7LVekQcl3xpstV6RByXfGm8GssIs7LVek Qcl3xpstV6RB
yXfGm8GssIs7LVekQcl3xpstV6RByXfGm8GssLKbLVekQcl3xpstV6RByXfG m8GsiJstV6RB
yXfGmy1XpEHJd8abQayLKxstV6RByHfGmy1XpEHId8abQayyibLV+kQch3xp s1X6RByHfGpt
BrLKLGzVfpEHId8abNV+kQch3xptBrLZFrs1X6RByHfGmzVfpEHId8abQusk sbJozHKwPYd4
IyUOxQ8U/wDuJPiU2z1fpEHId8abPV+kQch3xqZgxKHYoeKf/cSfEhoYHZOM 5zvnUSfEptnq
/SIOQ7402er9Ig5DvjTMGJRbFDxT/wC4k+JNih4p/wDcSfEptnq/SIOQ7402 er9Ig5DvjTMG
Jc0mj4JGOY7XOa4WINRJmP5lH4Lpb5if/cy/Eu3Z6v0iDkO+NYNNVn/qIOQ7 41P4rG0fDj8G
Uv8A/P8A7mX4k8GUv/8AP/uZPiXZstX6RByHfGmy1XpEHId8afx4XNuXJ4Mp T5//AHMvxLHg
qk7pj6jUSH//AKXXs1UP+og5LvjWpiqRuqID/wD0O+NMV4M25azMayjkYxoa 1sZAaBYAW3Ly
deq43S0Mrn2xASNNhYGxI/7Lylat8Q517p+8vUYv2ZZ9SH4aulSRfsyz6kPw 1Y6UbA/RVY2r
e6OndA8SvbvazCbkZHs9SzLpDWDS2jamZsNPpCkmld8lkczXOPbkAV2L5O4p aTQUdcIK/R7p
adlHNEHwyMkwnA5zSSHC1u0bzkVzz6Z0w9mlKmnfI3ZK10MYcYGUwa1zRZ5e Q+5BO47yLWWV
fYMnhkmkhZLG6WK2sY1wLmXzFx2XUi+J0jpCfRdd+V1ZSlomjFIGlwva7cN7 eq67vCWlKKor
xKZHRQ6PfUMZWOg1okaT/liPyD3ntG8IPqEXyNY6ql/JcTz6bdjq9HPkdTyR xAyHVhxwWAIt
mD8rI9hsVaaMmND+RdNUOkc4w0AlxOaHWsy9rC17bt43b+1BdIvkdFaS0w3S Og2Vs7ZYdJQP
eQXNO5gcCAI24fZd2/1XU35W6X0noaohfRtkniq4nQRxtYPzc9xhfexxE3Nm 9tkH0k88NNC6
aoljhib8p8jg1o7MyVIvPx+Umm59CaRrsUlI6giigLXRNOOcyAPfm0WNsi3s xL6KpnrJ/wAp
o6KgrpWsiDZqsFkbo2M3CMeLiDnb83CwzF+wL5F8TpLTemI6fS2kaWobs9DW agMdhaMiwEFu
Ak5k54x32G5d02ktIs0z+UD21f8AhtGU7ZI6YxtwucYi7N1sVrg5A9u/KxD6 R88Mc0cL5Y2y
y31bHOAc+2ZsO2ykXxNPJUTflH+S09TpB1S+emklMTmsBjLorkjCBkdwvwnN fbICIiAiIgIi
ICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIi ICIiAiLirdIC
klEZjxXbe+KyDtRVXhpvmf8AmE8NN8z/AMwgtUVbFpXWmzYf+YW7610r3U8Q DJbZuLvkg9vr
/spMxHysRl3Agi4IIWC5cDXt0eC0505OVjmw+ztH9V2OFxfsUpaLExhq5xK1 WSsLqw4WfoE3
zpvfcvK16oz9Am+dN77l5WrPxDEd0/j9vUIv2ZZ9SH4au1Sxfsyz6kPw1dLM tw44NE6Nppmz
U+j6SGVvyXxwta4dmRAWz9G0ElUKqSipn1AIdrXRNL7jcb2vlYLqXPFW0k1Q +niqoZJ4/lxt
kBc32jeFlpsaSmLp3GniJqAGzHAPzgAtZ3fllmtaSgo6LHsdJBT47YtVGGYr br29pXQiDlpd
G0FHIZKSipoHkYS6KJrSR3XA9SmgghpoWw08UcMTfksjaGtHbkApEQcMehdF RSNkj0ZRsewh
zXNgaC0jcQbLqmghnwa6KOTVvD2Y2g4XDcRfcfWpEQc7qCjdDLC6kgMUz8cj DGML3b7kdpyG
Z7lq/RtBJVCqkoqZ9QCHa10TS+43G9r5WC6lrI9kUbpJHNYxoJc5xsAO8lBy z6J0bUzOmqNH
0k0rvlPkha5x7MyQpoKSmpnOdT08URcGtcY2Btw0WaDbuGQ7lKCCLg3BWUHH BonRtNM2an0f
SQyt+S+OFrXDsyIC7ERARFpHLHK0uie14BLSWm9iDYj70G6IiAiwchcrQTwm n2gSxmHDj1mI
YcPffdZBIiwCCLg3BWUBEXINJ0BlkiFdTGSIEyM1rbsA33F8rIOtFE6ohZT6 98sbYQ3FrC4B
tu++6yiOkaEVQpTWU4qDa0RlbjN8xle6DqREQERaRyMkBMb2vAJaS03sQbEI N0WjZGPc9rXt
c5hs4A3LTa+fdkQt0BERAREQEREBERAREQEREBERAREQEREBERAREQEREBER AXBVaOpq2rLp
2uJaxoFnEdpXeqysjEuk2NcLgRg2v6ykJM4PANBwP5hTwDQcD+YVIKaMbm/1 K3ETRuC1qzv/
AEiZoSiY67WyA/SFTvoInR4W3Dh8l17lp7wsYFIwZKWr0Iv1Q00LhIZ6hjdc 7cN+Aer2rpcc
lj/MfYsPOWa5VjFsQ6TOYyjLlriKFYXoYckf6BN86b33Lyxepx/oE3zpvfcv LEn4hiO6fx+3
qMX7Ms+pD8NXSpYv2ZZ9SH4aulmXSHLpNkz9GVTKYkTOicGWNje2Viq1+k6B uhZxo2aFs9NT
PcyJoGOEhp3t3tse8K8RZa4fM1tdX01dT050hDEzVNkElTIyITOLjdvyCDYW FgWnPed65q/S
FTWP0nTR1TtSaaoGqxMdIwssLFoZ4oOe8uJBvkvr0RI6PlZ9J1Mc9JFT6Tp2 0+pa9k08zGCc
4iCLhhDrWAs0tOe/u7fyn0jNQxMbTVGolLHyNLnta12EDxc2OLjn8kWvnmFe okkdFZpKaow6
PZBOYDUThj3NaCbYHHK4I7Aqeq0ppCOCnjNZFCNbPG+qme2IOLH2aCSxzQSL m1he2RG5fVog
+efpSsikLXyMc2AtqJnsALTCQBkbbrl5B32YujSE7v8A4vMat7Wz1MDmtabA l7gcLAO052+x
XKIR0nL5uXSFT4bhooarVNuIXxOcwuB1ZOJrcF7XtmXWuCLLd+lah1BNO+V0 Ooa2CQjC0CYu
Ac4ucDZoyzscicivoUQUVNpCqd+S1XVuma+oiZNhlbZwOHFhO4A7hnYA9y5T pKqME+zaSFSP
zF5gxlonukDXMFh3dhuR3r6Grp2VdJNTSFwZMxzHFu8Ai2SkY0MYGjcBZPI+ fmrqmGvkgOkH
CeKSNkNM5jL1DCG4nnK53uzbYDDu3rnrdK17WxtFXFTMdPUMM8r2xNGB9mtx Fjhuv2XNt/f9
PI0vjc1r3Rkiwe212+sXBH3hR0dMykp2wsc51iXFzzm5xJJJ9pJRVVFWSVFc 6Co0m2lkwtEM
URZacFgONpc0lwve1uHNaaFdK38kozS1JmnjiyvhOBwHyMh9meeav0RFDTaT qqmrjax35mqc
JYThFxE2+L77N/nVSZpJ4Kmoqa12tqNDhwjIYBIbPvYWvlvyPb3WC+0RFicK nRklTHXy0s9Q
Z2injlaSxrcJJcCBYbvFFr3PrKq5tM1e16Q1FSMDKeoc2NzmOfE9lgCWhgw9 tgS647l9UiT1
SOiq0bLUt0jNTVFS6obqI5gXMa3CXFwIFgMsha9z6yqhtUDozTdMa6kJ/wAW RTAfnR4zsycW
7/SvrESVjo+S0hG92h6rRbmO1NPA+oxEZFmEljb+p1/sZ61Y6KbUnSle6OaF sAkjxsdES4/m
mbnYgB9xV4iuU8KLS9VWx1Vbs9WYWUtGKgMEbXYnXfkSRuOHO2fcR2xVFbXU m1RmrdINVDLr
XRtvCHvLXkAC1gBfO9rZ3X0SKK+cOkpG0/60vRmpEfhDCzJuC5ztg+VZuK1s 7b1wN0hVQUcL
YKyKCKWoqS6ple2JpcJDYXcxwF7k2sL2yK+yREVOhXOfVaRe5zHOdLGSYzdp OqZuPcrZEQER
EBERAREQEREBERAREQEREBERAREQEREBERAREQEREBcb230kT3RN/u5dagcC 2pMmG4LAP6nq
mcGMt8KYVrrv4f6rOuv/AJP6pszqzhWQLLAee1th7VsTcG+QUtdYqwRnmo3m 5Wkk9pMA3Ybr
XWBKV8ysslYS90XVlyxi+jpvnTe+5eVr1WL9XTfOm99y8qSfiGI7p/H7eoxf syz6kPw1dKli
/Zln1Ifhq02mPhl5T+izLpCZFDtMfDLyn9E2mPhl5T+iyqZFDtMfDLyn9E2m Phl5T+iCZFDt
MfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+ iCZFDtMfDLyn
9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDt MfDLyn9E2mPh
l5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn 9E2mPhl5T+iC
ZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPh l5T+iCZFDtMf
DLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iC ZFDtMfDLyn9E
2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMf DLyn9E2mPhl5
T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E 2mPhl5T+iCZF
DtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5T+iCZFDtMfDLyn9E2mPhl5 T+iCZFDtMfDL
yn9E2mPhl5T+iCVcs4q9fihEZZhAs49ual2mPhl5T+ixtLOGXlP6INGGf95E z7HLclwGUYv7
VjaWcMvKd0WNoZwy8p3RTWBo99V/kZGPaVA7wgT+5/qukzt4ZeU7osGdvBLy ndFdYMuQQVLp
cUpYBa3iroZEGesrYzN4JeU7otTKOCXlO6LUYhGxWFqZRwS8p3RY1n8EvKd0 WswiGL9XTfOm
99y8qXqsOejZjmM5t4t/ncvKkn4hiO6fx+3qMX7Ms+pD8NWSrYv2YZ9SH4as lmXSBFyz6Qig
FUXtfemYHuAFy4G9rd+4j2oK5j3sZFHJKXxiXxbZNJABNyPWfsKyrqREQEUL 6ljKuKmIdjlY
57SN1m2vf+YKZAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQERE BERAREQEREBE
RAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQcUf6vn+dN77l5Sv Vo/1fP8AOm99
y8pXSe2HKO+fx+3qMX7MM+pD8NWSrov2YZ9SH4asViXSFDpeppWaXp2vraSN uTalsk7GuaGk
PbkTffl/qXJRtZVQVMFPUUs8rZohEyGdjjqI5AQcjlvK+ndIGm1nn5rCf7LG tHBLy3dFI6K+
fNBIRXvj0MIZZyGmzYSHRh2dhisXEXd4wtewN7LbR+iJWPohUU/5uDXlokwH AXPaWZNyvl2C
wsr7Wjgl5buia0cEvLd0QfNwaKmuwP0dJFamlinkjkZimecPjC5zJsc3W9as dE0skLojJo+O
nwska1zMLMILhYFjSRc2vcHs7L2VnrRwS8t3RNaOCXlu6IT1botNaOCXlu6J rRwS8t3RBui0
1o4JeW7omtHBLy3dEG6LTWjgl5buia0cEvLd0QbotNaOCXlu6JrRwS8t3RBu i01o4JeW7omt
HBLy3dEG6LTWjgl5buia0cEvLd0QbotNaOCXlu6JrRwS8t3RBui01o4JeW7o mtHBLy3dEG6L
TWjgl5buia0cEvLd0QbotNaOCXlu6JrRwS8t3RBui01o4JeW7omtHBLy3dEG 6LTWjgl5buia
0cEvLd0QbotNaOCXlu6JrRwS8t3RBui01o4JeW7omtHBLy3dEG6LTWjgl5bu ia0cEvLd0Qbo
tNaOCXlu6JrRwS8t3RBui01o4JeW7omtHBLy3dEG6LTWjgl5buia0cEvLd0Q botNaOCXlu6J
rRwS8t3RBui01o4JeW7omtHBLy3dEG6LTWjgl5buia0cEvLd0QbotNaOCXlu 6JrRwS8t3RBu
i01o4JeW7omtHBLy3dEG6LTWjgl5buia0cEvLd0QbotNaOCXlu6JrRwS8t3R Bui01o4JeW7o
mtHBLy3dEG6LTWjgl5buia0cEvLd0QbotNaOCXlu6JrRwS8t3RBui01o4JeW 7otmuDhcX+0W
QZREQEREHFH+rp/nTe+5eUr1aP8AV0/zpvfcvKV0n4hzjun8ft6lF+zDPqQ/ DViq6L9mGfUh
+GrFYluENZpCm0ZSmoqpAyMyNYCSBmbDtP2+wFdDaumfEJWVEToy4NDw8EEn K1+9cukKaWr0
e+KDBrBIx7cZIBwua6xIBtu7lywR7RpqQsfG6GO0szGHEGz2w2v6hnb2HtUy qygrqSoe5kFV
BK9rQ5zWSBxAO4m3YkVdRz0754aqCWGO+ORkgLW2FzcjIZL53Rei56/QlM14 gp4tifFG+Mku
cZALlwsLbtwJue5XGh6KWkjk18TWSODQXNq5J8Vh/GLt9guk9Mjng08J9Fur 2spzHqpJWsbU
XeQ0A2Iw5HPPfbLfddVNpmhqZKmNtRG11L5W72+KLAk79wvYk9oK4H6EqXaO pqcPixxUMtM4
3NsTg0AjLdkVtVaHqpo66Jrogyd0UrHaxzTiYGeKbC4BwfKBuL7lVWbdI0Lm RPbWU5bMbRuE
rbPN7ZZ55kBajSdIdJv0drmCpYwPLS4bjfK173AF/YQuOh0XLDWU1Q+KOPVi XENpfOSXYLHE
8A7mlbaQ0bPVVVVgdG2GqpNnc4uOJh8axAtmPG7xuUSHbBpCiqQDBWU8oJIG CVrrkZncey4U
VDpai0hUTwUtRHK+AgOwvabiwNxY7s7e1VR0HVTUhgfHDC4kOdJtcs5OEEAe OMgb2Iv8kkdq
s6GmqYK2rllbCI6gtf4jyS1wY1pFsIyy33+xUWCIigIiICIiAiIgIiICIiAi IgIiICIiAiIg
IiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICgd5R3t /wCynUDvKO9v
/ZBhERAREQccf6un+dN77l5QvV4/1dP86b33Lyhbn4hzjun8ft6lF+y7PqQ/ DViq+L9l2fUh
+GrBZluAEi9ja6zjdxKCGBk8tQZHSeLIAMMjmgDC07gfWpdih75uc/qorbG7 iTG7iWuxQ983
Of1Uc8NJTRGSaSVjB2md/VBNjdxJjdxLhbPo57bslnP/APZIMhmTmewBdbaO BzQ5rpSCLgid
+f8AVSJiekHjLfG7iTG7iXN/+OFXshqxtNr6nanY91/k4rqWOlppY2yRSSPY 4Xa5tQ8gj1G6
okxu4kxu4lrsUPfNzn9U2KHvm5z+qDbG7iTG7iWuxQ983Of1TYoe+bnP6oNs buJMbuJa7FD3
zc5/VNih75uc/qg2xu4kxu4lrsUPfNzn9U2KHvm5z+qDbG7iTG7iWuxQ983O f1TYoe+bnP6o
NsbuJMbuJa7FD3zc5/VNih75uc/qg2xu4kxu4lrsUPfNzn9U2KHvm5z+qDbG 7iTG7iWuxQ98
3Of1TYoe+bnP6oNsbuJMbuJa7FD3zc5/VNih75uc/qg2xu4kxu4lrsUPfNzn 9U2KHvm5z+qD
bG7iTG7iWuxQ983Of1TYoe+bnP6oNsbuJMbuJa7FD3zc5/VNih75uc/qg2xu 4kxu4lrsUPfN
zn9U2KHvm5z+qDbG7iTG7iWuxQ983Of1TYoe+bnP6oNsbuJMbuJa7FD3zc5/ VNih75uc/qg2
xu4kxu4lrsUPfNzn9U2KHvm5z+qDbG7iTG7iWuxQ983Of1TYoe+bnP6oNsbu JMbuJa7FD3zc
5/VNih75uc/qg2xu4kxu4lrsUPfNzn9U2KHvm5z+qDbG7iTG7iWuxQ983Of1 TYoe+bnP6oNs
buJMbuJa7FD3zc5/VNih75uc/qg2xu4kxu4lrsUPfNzn9U2KHvm5z+qDbG7i TG7iWuxQ983O
f1TYoe+bnP6oNsbuJMbuJa7FD3zc5/VNih75uc/qg2xu4kxu4lrsUPfNzn9U 2KHvm5z+qDbG
7iTG7iWuxQ983Of1TYoe+bnP6oNsbuJMbuJa7FD3zc5/VNih75uc/qg2xu4l jtJ7SsbFD3zc
5/VNih75uc/qgyijkpImAWMuZ88/qtdmi75ec/qgmRc08LY2Nex0ocHs3yvO 9wG4n1rpQccX
6tn+dN77l5QvWIv1bP8AOm99y8nW5+HOO6fx+3qcX7LM+pD8NWCq4nH/AONM HZsQ/DVoszDc
S1o/KVX0o9xq6ly0flKr6Ue41dSiipq94P5QUscwaYtUSwOOWPP/AMK5XNW0 MFdEI523sbtc
Mi0+pSYyzaMx0fPy1OkWRh9VCIC5xjbgOF7rjdbtGeR7CvpmxiOLBGLWGXtX BTaHpKSZs5c+
R7TZplcDhPqyGaslmKxGZK7RHVS6Gq6JlHBQySRtrm+VgcRrDJvc4jebnPF9 qqYNJz01HomG
nqBGRDAXxvc0CQOdY4W4S51he9nNtlvX2CLbT5p2kprV7PCkQkieCX62LVRt x2wg4btfbKz7
i/8AS70bOKnR8EwdK8PYCHShuI+s4cvuyXUieDyIiICIiAiIgIiICIiAiIgI iICIiAiIgIiI
CIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgin3 N9qrap+kjWxC
lijFOzORz3C8mW4dwHf3+rfYVT8DWWaXEusAN5yUBme3fTyD7W9UCq8gMreP Hl/raplySztl
iIDS0tfHcG3GO72LrQckX6sqPnTe+5eTr1RjyKCcdmKb33LytbmOkOcT/Kfx +3p0X7OM+pD8
NWqqov2cZ9SH4atVLeGqtaPylV9KPcaupctH5Sq+lHuNXUstC+c/KbSWz1MN K4vEJbjeGGxd
na1/sX0arNL6JbpHVSNc1s8R8UvbiaR3ELfpzEW6ipq5KTRdc6kjYB+bJOsJ sSQR2W7/AF+q
3b9I2Iim1T3uccNi4Eg/Yd4++/rVOzQtTU1sdRpOWF5jNwI25utuubDJXb2h 7HMN7OFjYkH7
xuWb1rnMfMrl83Q6YqaXRMIbTmq1NEyqmllqDiIOK9rgknxe+3rC6PDNVTv0 nLPCySCGVjIG
scS4lwZYWDb54rneRewBVhFoihhp3QMhOrfDqHAyON2Z5XJv/mKzJoqjlM2O IkTtDZG6x1ja
1ja9gRYZjPLek/I4o9M1cxgii0eBPKJCRNI+NoDcOYxMxEHFwjMfauKl0tUa P/J+mqZo9pnn
YZntM8j3EWuXABhsPVk0XGeavYdH08D43tErnxhwa6SZ8hAda4u4nhCil0NQ SwRQPhdq4ozG
0Nle3xDvabHMZDI3UQir5airkZBAwwQkNlkfIWuBLQ6zWgG+RG8hQ6H0w/Sj nE0ckMRYHxvc
19nD1lzQL7vklw9a6/B9MKoVLWyMlAAOCVzWutkMTQbO+0FYo9HU1E5xphIw H/JrXljc7+K0
mzfsAQ8OtERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQEREBE RAREQEREBERA
REQEREBERAREQEREBERAREQc1V5Wm+kPuuUFVuCnqvK030h91ygqtwQckX7z 2w/iKzVZF+89
sP4is0Fe39Cm+dN77l5YvU2/oU3zpvfcvLF0t2w5V75+8vTYv2dZ9SH4atlU xfs6z6kPw1bL
NvDdWtH5Sq+lHuNXUuWj8pVfSj3GrqWWhQPqomyPjB8Zlsd7gNHeSp1T6VnE NU+N7gwTRNaH
PAw5F19+R3jL1/ariZ+Bz0tZMaeVxllczaJAHgYiDnhG/dut3nLLtvKd7pIG PeAC4XyOX/v/
ALcqjZLC+PZoKpzw4FoiiEed+wADJXUbJ20uF0rTPY+OW3APZkLXt9l/UlqT W02nylZiYiHD
FpdjKWSesDmtZPLHijhe8BrHEXdYG2Q3mwXWK6mLbiS/53U/JN8fd/3vutnu VVV/k4aqlZC6
oicfzpk1sGNpe83L2txeKQb2OdgV3N0YG1+0644MAGrAt+cthx378OSiynpq 6CqlkiiMgkjs
XNkidGbG9iA4C4yOYVbTaTrHVkeuNO6Caqlp2sZGQ9uDFZxOIg/JzyG9S6H0 N4MmklMsT3SR
tYTHDgLrEnE43OJxvmVPQaKp6KSaZscRqJpHvdMIwHkOdiwk7zbL7kGo05QO gjmZJK9kl8GC
CRznAC5IaG3IFxna3YtvCdMHPkNVG6EQslAawk2cSAQRvuRYAC9/aoGaImp4 KIUtWxk9LCYc
ckOJr2m1/FDhY3aO1cQ0OytNTTDWNhZDFC2SaHJ72Pc4nCQMTbkXtkbmxRVq dLUYhZJil8dx
aIxA8yXG/wAS2L+naO9YodJx1tbV0zYpWGncG4nRuaHZA9oAG/d9u5c0Wh5q cQyUslFTzxYx
+apC2Itda4LA+97tGd12UtHJT1tTOZmOZUFrizVkEODQ2977rDdb7UR2IiIC IiAiIgIiICIi
AiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIi AiIgIiIOaq8r
TfSH3XKCq3BT1Xlab6Q+65QVW4IOSL957YfxFZqsi/ee2H8RWaCvb+hTfOm9 9y8sXqbf0Kb5
03vuXli6W7Ycq98/eXpsf7Os+pD8NWyqYv2dZ9SH4atlLeG6taPylV9KPcau pctH5Sq+lHuN
XUsNC0llZCwOkdYFzWg27SQB/Uhbrk0mAaJ4Mj2gkNwsDSZC7xQ3xgRmSB/4 QcWj9MST1VVH
UxCJkTwwEA/KLy0Dt35d3b7VcL5LRrnOr5MT5otXIGukDQdW4ktAGJpsCb7u IfxL6uRxZG5z
WOeQCQ1tru9QvkgipKplXG98YcAyR8Zxd7XEH+ynXymkNE11Ro5sWyFxkdPN ZuqL4nvddoJf
cAWJuW53AsVZsoKgV2Axg0mIVNyR5W1sNu6/jX70JXCrYNMRzVQhNNPG10r4 WTPw4Hvbe4Fn
Ejcd4G5cX5PUFTS1dRNPTmATRsxNtE1pkBdiwhnZmLF1z3qfR2iXsmfPVSyn DUzSxQktwNxO
dZ2Qvex7Sd+5BcLQPcZSzVuDQAQ/Kx9W+/8ATtXzcWhnU9Do5s2i21TI4nCe mGA3lIbZ5xEN
NgCL3uL5LSbR9ZIyopGOLp20VO14a8EuAkeS27sjcAjMWPbkUV9Uoo54pZZY 2Ou+Fwa8WORI
B/sQvn49Fuigp2u0dUVNIx0mKjmEAIcbWcGtIjsLOy3+Ndd+jKBtJpWvlFA2 ETlr2StawZYW
gtyN73BO63rRHbSVjat8wjjkDInmPWOsA8g2Ns75EWzA9S6V85FoJrYoYjQw iPwhJLIwBoBj
8cNuO0WLRZb02jZmaSD3UeGZtQ+R9bib+cjN7M34jkWixFhh9QQn7/r6Bc1f VtoaV0743yAO
a0MjtiJc4NFrkDee9UdD+T0bG6PbU0UZaKZzaoOIcHP8XDiz8a3jW327LLpn oqt/5K09I+KS
SpY2HGxsgDjhc0mzrjOwOd0Xyt6eV80QfJBJA4/5JC0kfykj+q2je57SXRuj IJFnWzz35E71
Q1FFPPs7oaCoYyIHXMqJ2vfMzEDqycbr8WZ7LbnFRyaMqA6J+w6+VtTM9okE b4mtdJfEQXAg
2zBbcjtB3InhfR1TJgDA10rdY6NzhYYC0kG97dotldTr52j0S+mkjZFQNhEd e+Zz2YAHxkSY
SLG+WICxCiptB1NNSU4poWwVDqGSKd4eATIQ3DcjM2sbHOyff8XHV9OuXb4f CIofG1uDHe3i
+y/f2+xVOg4mR6Zq2xUOwtbTRAw3abG7+Ekf+3KOoNLFxrA+ASbTrxBq/Hwj xcOPHb5Hq7U8
ov1zOr4Box2kGF0kDYjKC0ZuaBfIGyqI9CETRzOpGGV1bMZXGxLoXY7A97Td vi/0UlJo6WL8
kpqBlGIKg074ywYBrH4bYrg2z7zY96eFj5wsaLSAq5HxOp5qeVjWvwS4blpv YjCSOw9q6XvL
SwCNzw42Jbbxct5uf7X3r51ujqs0tRqqWeNv5lwiqJhJI9zHhxs7E6wsLAF1 r3yHbNHSVk1f
tL6V0LXVrZcL3tJDBCWXNiRv7En+khZt0jC7RHhINfqdSZsNhiw2v32v9qxH pES1EsMNNPJq
sON4wgAusbZkHIEH/wA5L5+bQ9WdGMgl0dtMuwCGI6xn5iSxvvOV7jNt91jk us6GewVzoqSN
sk1TA9rmhoLmtMZdn7Q4/wD+q+Vld0lUyrje+MOAZI+M4u9riD/ZTr5Wt0NV TNjEsEssAnqH
Oii1LneM+7HWku3df1i/tX01O0sp4mnHcMAOsILt3bbK/sU8JPykREQEREBE RAREQEREBERA
REQEREBERAREQEREBERAREQEREBERAREQc1V5Wm+kPuuUFVuCnqvK030h91y qXVsklQ9hlhI
bI5oAhkuADbfuv8A0QSRfvPbD+IrNVrBZ0o/ii/EVkgr2/oU3zpvfcvLF6m3 9Cm+dN77l5Yu
lu2HKvfP3l6bF+zrPqQ/DVsqmL9nWfUh+GrZS3hurWj8pVfSj3GrqXLR+Uqv pR7jV1LDQtXv
axpc42AWyq9JOjZVMOHHJqz4tib55ervViMzhJnDrfWwMaHFxzvkQQbAXJse wBdDXBzQ5pBa
RcEbiqLEHNBGKBxuCYr57xbLO+RI32337Fb0mHZI8II8XO4O/t3571y2/lMZ +GsdIlpDpKgq
GyOgraaVsQxSFkrXBg7zY5bl0ggi4NwV8jT01RJ+TO1zNhjji0ZJHGI3lzpA 5oN3XAtbDuz3
nNds+l30xnp3VLGTa6nEEZtiMbsAcQO0XLs+xdcdcJL6JaPljjcxr3taXnC0 E2xG17DvyBXz
7NJzu0pDHt4Mj6t8UlJgb+bYA/D2YhewNyc75LvqKqujfQiZkULpanA5sUms Dm4HHeWi2Y/p
vU8ZFouKKfRlNWPpIZaSKpkdifCxzWvc4i9y3eTZVuhqutfJo91TVunFZSul c0sa0Mc3Ba1h
f/Mb3v8AZuWuzVFZpXSELGwtgFXDI+UvONpaxhs1trZ2AvftOSuOv3kfQrQy xiVsRe0SOBLW
E5kDeQPtC+ffXVbYDLNXuhhfWyQvlwMAgjaX2zItmQ0XdcZ96eE69sLDC/aT qKl8ZwD8/gLc
DrDvv2WB7OxRcdcPo0Xy9NpSpNEHS6UpnQvma2SpilZIYGlpPjeI1rbkAC4N rm66aIs/+SYx
pN07ZaOMx3MdprF97WaL235d/dYJ5TxlfoiICIiAtXsbIxzHtDmuFi0i4I7l siCClpKajjMd
JTxQMJuWxMDQT32CnREBERAREQEREBERAREQEREBERAREQEREBERAREQEREB ERAREQEREBER
AREQEREBERAREQc1V5Wm+kPuuXFNTNY8v1tQ4ucXWMzrC53Ady7arytN9Ifd coKrcEHJGbmU
/wAUX4is1WRfvPbD+IrNBXt/QpvnTe+5eWL1Nv6FN86b33LyxdLdsOVe+fvL 02L9nWfUh+Gr
ZU8R/wD19n1Ifhq4Ut4bq1o/KVX0o9xq6ly0flKr6Ue41SzyOjixMALsQABN t5A/7rDSVQVN
JDUtcJGDEW4Q8ZOHsK3hlbK0kXBBs5p3tPcVy1Uv+IdG+QsjZGH5OLd5OZII 3W/qs2vpGViu
3Rmn0bBEy0g1zu0vFx35D2k+vPeutjGRtDWNDWjcGiwVW2vkjDQHPkaHAEGm fiw3zz9Q/t2q
xinZNBrYiXNztkRuy3H2LNb1nMws1mEqL5+jmaPB1ZUPrJJa3xsbJjqWktJw FmK1gAbEN7Mz
dIfykklpX1A0dLgOAxXxtxhzw0XLmAX8YHIuHrXTHhlZ+D8Vcyqmqp5tWS6K J2EMjJFrizQT
kSMyd67VSTadlp4nslo/8W2oEGrje6RpJZjvdrC61v4d/wB6ki0zLJJhdSth YynE8rppCzBm
4WsW33t3m2RvbsQW6L5+PS01dLR3ifTObW6t7QXgPGqc7/M1ptu3jsX0CAuZ tGBXGrfLI92A
sYx1sMYNr2sL52G8nculEBERAREQEREBERAREQEREBERAREQEREBERAREQER EBERAREQEREB
ERAREQEREBERAREQEREBERAREQEREBERBzVXlab6Q+65QVW4Keq8rTfSH3XK Cq3BByRfvPbD
+IrNVkX7z2w/iKzQV7f0Kb503vuXli9Tb+hTfOm99y8sXS3bDlXvn7y9Ki/U LPqQ/DVyqWP9
Qs+pj8NXSlvDdWtH5Sq+lHuNU00etjwYi3MG47LG/wD2UNH5Sq+lHuNU8sjY mF7r2BAyF95s
sNEcbYmBjBYBcdZo91RUtmjmDDhDS1zMQNiSDvHef6dy7Wua9oc0gtOYIUE8 7xNqosIIaHFz
hfeSAALjuPb/AOMX1mP5NVzE9EDdHzFwEtS1zO0MjLSftxGy7mtaxoa0BrQL AAWAC5W1rmho
mheCXBuIFuHM2B337R/5XWSACTuClIpEfxW02n5cceiqOKpE7I3BzXFzW6x2 BrjvIZfCDmcw
O0961j0PRRscxkcgjJDtXrnljSHBwwtvZuYG4Ba0M9dWNiq7wR0soxNiLHGT CdxLr2B7bYfV
ftWWaaoHtkcJnBsbHSFxjcA5rd7mkjxgP4b9i6fDCSfRlJUazWRG8kglLmvc 1wcAACCDcGwt
lZBoykwSNdG54ki1LzJI55cy5NiSb/5jnvUY03o8wyymctZFhxl0bm5ONmkX GYJ7Rkthpeid
TmYPksJNWWal+sxWvbBbFe2e7dmgzDoqjgLSyN5c2TWhz5XPJdhw3JJJORtm u1cR0pSfmQHy
PdMMTWshe5wF7XcALtzyzt2rno9Mx1uAtxQf4l0GGWF/j2xWsSBY+LfttuOa C1RV7NNUD2yO
Ezg2NjpC4xuAc1u9zSR4wH8N+xTUekKauc9tO9znMAJDmObkdxFwLg2NiMkH UipKbSdY6sj1
xp3QTVUtO1jIyHtwYrOJxEH5OeQ3rqGnKB0EczJJXskvgwQSOc4AXJDQ25Au M7W7EP6WKKkl
02H10kVPKxlNFS7Q6Z1O+RpBBsQRYWAF+2+4WIK6GaWYyWrFQRgilZHHq43O c+7GuyaLknM7
huCCzRccek6WWaOKN0j3yNDhhheQ0G/yjazdxyNty7EBERAREQEREBERAREQ EREBERAREQER
EBERAREQEREBERAREQEREBERAREQEREBERAREQEREBERBzVXlab6Q+65QVW4 Keq8pTfSH3XK
Cp3DIoOSL957YfxFZqsjFtZcdsP4is0Fc0/4Kb503vuXlq9Na78xMP45ffcv Ml0t2w5V75+8
vSY/1Cz6mPw1dKmj/ULPqQ/DVypbw3VrR+UqvpR7jVLUte+K0YBcHNIBNtxB UVH5Sq+lHuNX
SSALk2WGkcEWpYQTdziXO7Bc9w7Fw6QgqnVeOGNz4nxhrsDgHCxPeRvvvHcf arNQzVDYnBuE
vfa+FpGQ7zcgf++orHqVi1cS1WZieiqbQue4N8HMjv8A53tYQPsBuranp46e nbDGPEb39t96
0jraeSwEzGvJtgc4B1+6ynWfTpWvwtrWn5V9JQVNJhgZVsdRMybG6H841vY3 HitYfNvbt7Vz
N0FKaM0stY10TKd9PBaKxYHC13G/jEADdbt+zrZpMSuLoaSplgF7TtDcDiO4 F2I917W9ds0k
0vSx00NQ4u1csRmBAvZgAJJ+8DLtK6s+UVVojaJXP1+HEyFlsF/Jvx9/bu9S jrtAsrHzPdJE
5z6hs7WzQiRgIYGWc2/jC1z2dncrCkqH1DHGSlmpnA/Jlw3I77tJH9V0IkKq DRc9LLHLSzUs
J1YjlY2mIjcASRhaHeKfGPad6M0Q9sjcVQ0xMqn1LWiOx8YOu0m+eb99huVq iClboKU0ZpZa
xromU76eC0ViwOFruN/GIAG63b9nfDRaqudU6y+KBkOG3CXG9/8AV/RdaIOC g0VT0Uk0zY4j
UTSPe6YRgPIc7FhJ3m2X3KBmiJqeCiFLVsZPSwmHHJDia9ptfxQ4WN2jtVsi Cp8CNEFREycg
TUYpbubcj5Xjev5W7JR1f5PsqRIXSROcZ2TNbNCJGXEYZZzb5gi53i2XcrpE FTFoiSOopZGy
UsLYRZwpqcxF4z8XJ5GHPcQe1WyIgIiICIiAiIgIiICIiAiIgIiICIiAiIgI iICIiAiIgIiI
CIiAiIgIiICIiAiIgIiICIiAiIgIiIIKljXsa17Q4X3EXUGy0/o8X8gXTPub 7Vog554444LR
sawGSP5It/nauhQ1XkR9JH77VMgqQPzEx/jl99y8yXpDnkRyD+OX33LzW66T 2w5Vn+c/j9vT
I/1Cz6kPw1cqmj/ULPqQ/DVypbw3VrR+UqvpR7jVtWgGnOJuJuJtxa9xiC1o /KVX0o9xq6lh
pDStkbFaS+/xQcyB2Ant/wDfaq7SNVs1eQS1msibhc/JuRdfPttcZese1W60 kljibile1gva
7jZY9Su0Yzhqs4lR65sxayOuklfiBaxhYSSDcdnq9nermCOUUwZPJjkIOJwF lK1wc0OaQQRc
EdqLPp+nr8zlbWz4VmjDV0kMNBLRPLYWiMVDXs1bmgZG18QNuzDv7bZqGjoJ oH1mupmywsYY
qeO4OsjJLiM8hvDbHhVjS6Qoqxzm0lXBO5nyhFIHEe2xUktRDB5aaOPxS7x3 AeKN59guF1Yc
Wh4qiETiSOaGnxDUxTyB72C2eYJyvuFzb+islgEEXBuCsoCLWR7Io3SSOaxj QS5zjYAd5K0d
UQsp9e+WNsIbi1hcA23ffdZBKiwCCLg3BWr5GMLA97Wl5wtBNsRtew+4oN0W kkjIm4pHtY24
F3GwuTYf1SOWOVpdE9rwCWktN7EGxH3oN0RQ1NXTUcYkqqiKBhNg6V4aL91y gmRaQzRzxNlh
kZJG4Xa9jgQR6iFugIiICIiAi0bIx7nta9rnMNnAG5abXz7siFugIiICIiAi IgIiICIiAiIg
IiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiIIp9zfatFvPub7Vogh qvIj6SP32qZQ
1XkR9JH77VMgpnN/NSH+OX33LzSy9MPkZPny++5eZrrbthxr3z95elx/qBn1 Ifhq5VNH+oGf
Uh+GrlZt4dK+WtH5Sq+lHuNWNJ6Qh0ZRPqqgnC3IAb3E7gs0flKr6Ue41dSw 0qPyb0lPpWim
qKgMH58tYGDINs07+3MnNS1c4ir3XuSIm4QDnmXXA9th93qVkueooqeokEkr DjAwhzXFpt3X
BF1j1KzaMQ1WYieqsc6aPx2tZGGuDz/iX233OVrZ5/eraCR8tO18keqc4Hxb 3t3KKPR9NG9r
w15LTcYpXOF/YTZdSx6dLVidpW9on4fK6J0lJH+TTNTX0kr4oowWxN8enZcB znjEb2Ge4blJ
XVWr1VTSaQ2x0dFVOZUXY7MYOEBuXsX0ywHBwu0gi9sl2merMT1y+bk0pUDS E0Y0gGysmhbD
S4GXlDmsLuy5GZNxa3bktZ9LVUUWkdVVieaJwzY6N0ULC+28NxNcG3JxA7r5 5r6CClZBPUTN
Li6oeHuB3Ahobl9gCnRFAZ5aj8k9IPmqoKpwhlAkhlEgIwnIkNaL+wDsXDpC N7tD1Wi3Mdqa
eB9RiIyLMJLG39Tr/Yz1r61EWJw+ck0hUMrHRCt1UrHxMgo8LTr2ENu7MYjv dmCAMOfaon1j
p9LUjZKzHMyue00mFo1QDHhp3XzFjcmxvkvqERPGHx0WkKutoXmrq6d7jJA5 1O2UGSF2ubcF
gY0tHZmXbhmrCOqrqurip21r4A59UC5kbCbMkAaBcEZA93VfQoivk6jTVT4O ZO+vFJLsAnia
I2nXyWN94N7WGQ3XzyVppfXSDRRhkYyV1SCHPYXAHVv3gEf3XXX6P28auSqn ZA4Wkhjwhsg7
QSWl2e7IhdgyFlUUtRVVcFbUa6peY6ajbM5kETRjcS8EjFcjcMr9ntvw0eka +oZHCK9ji+tE
WvjLJbsMRcbOwNaTcb8P3r6lFB89S1de2SlfJWOma6rlpXRmNgDg0Ps7IXxe KL529QXLo/S9
c6CSqqK2ndqw2SenbI10kQxWeCzAC0AE7y43Az7/AKtEHzo0lpPVztDMU8UT 6kMwXu0tvG2w
9ZI7zgUZ0jUbNNselNsZeACowMOBzpA1zfFABy7LXF/WF9MiD5ylmlg0/VU8 lQ6OEzMvM4Nv
M/VMAYcrC+/IC/ZZfRoiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIi AiIgIiICIiAi
IgIiICIiAiIgin3N9q0W8+5vtWiCGq8iPpI/faplDVeRH0kfvtUyCoI/MS/P l99y8zXp1v8A
DS/Pl99y8xXW3bDjXvn7y9Lj/UDPqQ/DVwqeP9n2fUh+GrhZt4dK+WtH5Sq+ lHuNXUuWj8pV
fSj3GrqWGhERAUNVlSTfMd/ZTKGrzpZWgjE5hAubXNkmMj56atFFLWtrBiaJ Q2ExRDxci7fY
DcWi1777d6udGxSMa578LQbNDGEkeKA2+Z9WXq357q2spZ5y90FRPTmR4e4N ey18OHscD2Dt
t6lbUj2sgAkc1ri5xsXDK7iexW/p1mYtEdWa38TKtqscn5S6ox1ssbYI3AQV BjYwl77ucMbb
7h2HcoKHSM1Lt+ve6bHNKaYOcSS4SFmAer5Fvae5Wk9HRVFUKl8j2zBobijq Xx3AJIBDXAHM
nethSUAweLGdXK6Zt3Xs83uf6lMS1NofO05qi6jp6h9fWuD6oPEFQY3OLZGg EnG3IZ5X7Vba
edUsgoG0b5I5TUCzcZ8ezHnC43zBIF967YqahhmbLHgD2l5Bxne8gu7e0gKS VtNM6J0jmOMT
8bDitZ1iL/cSmJTaP/1TVOkH1WlNGy00z20jZAHhpsJHOjc6x9gANv4vUuiP Tj9Q2pqKTBTy
wOnhLJcTnNABs4WFiQRuJHrXY2koGBgY2JoZK6ZtnW8c3uf+RUcOjtGQ4wxr S17CwtfKXNa0
72tBJDQe4WGQTEmYV8mlaqjrKqWspy0tp4cEEcpkaXOe4Dc29917NJyyvkpq WvnrNJURkikp
7xzh0ZxgOILLGzmtJ39oHap2aK0WyOVmHGJWBjzJO55IBuMySRYnLuU8FLRQ Pje2Rznxhwa6
Sd0hAda+bieEJg2h2otWua4Xa4H2FbKKIiICIiAiIgIiICIiAiIgIiICIiAi IgIiICIiAiIg
IiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiCKfc32rRbz7m+1aIIaryI+kj 99qmUNV5EfSR
++1TIKv/AKWX58vvuXmC9Q/6WX58vvuXl66W7Ycq98/eXpcX7Ps+pD8NXCp4 v2fZ9SH4auFL
eG6+WtH5Sq+lHuNXUuWj8pVfSj3GrqWGhERAXLVSmASShmMsYDa9srm66lxa QY+SGdjBd74i
GjvOa1VmzjfpB7KpsRl/OvF2x2u22fbb1HeRe3Yp6CofKXAl7mADxnixxWzG 89t/Ycs+yj0t
HKzV1EsU0Ba0jWNaCflNsCQchme0dqs9Dtm1YleHlr4Y8L3Wu7Im+894Wrel GYtEsxfpiSr0
nJHpptEKyjpmGNjwJmkvkJc4Wb447h2HelBpkyiv2sNYKZ7y0tB8aNrnC/tu 0/0W8tHVeEjV
09REwOjbG9kkJfcAk5EOFvldxUXgZpMZdK7xZ3ymzbY2udiwH1Xw/d61MLMw 42afq3R0u0z0
NA+V04e6dpc0FjgA0eO3PPv7FaaQq6mJlGymkhElRKIzI9hc22FzrgBw7u9R U2izBVsn1pdg
dMbYLX1jg7v7LfapdIaPj0js7Z2tfHFLrCx7A4P8Ui1j7b/YmOhn9tKPTEb4 oG1TrVEr3xgR
Mc5ryx2EuFr2G457vsWx01RyQzGGowFkbpA98L8JaN7m7sYH8J/utnULdqp5 WARxwRPiEbW2
FnYd3dbCqqr0dNTaNdA6V9QGwPpqVkdObjELDGQT2AC/ijemFiYXPhOmFS2n MjjIbAkRuwgk
XALrWBPcTfMd65qvT9NBTumiZNM1sjGXbDJhN3WuHYbHt3eztUA0I1ukjVht M/GWudrabHI0
gAeK+4w5AdhzWw0VU+Dth2qMxR4NQdQcTcLgRi8bxtwGVkwkSt4nh72PFwHM JzBB7N4KnXNB
ixtDyC4MOIgWF8uxdKllqIiLLQiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgI iICIiAiIgIiI
CIiAiIgIiICIiAiIgIiICIiAiIgin3N9q0W8+5vtWiCGq8iPpI/faplDVeRH 0kfvtUyCsH6L
N8+X33Ly9eoD9Em+fL77l5eulu2HKvfP3l6XF+z7PqQ/DVwqeL9n2fUh+Grh S3huvlrR+Uqv
pR7jV1Llo/KVX0o9xq6lhoREQFFO+KOMvmAwgj/LfebKVc2kDbR1Ue6J/wDY qx8iF1QxpLjS
ARDPERY277EWH2ndvWaSaKdxY6KIPADvFs4WIB7Pb9u8erjjlwVMhjdGWPeM 8Qv2HLdxHv7F
0aMfC6pqG07mFgYw+IbgG7v/AB9llJi2cxPRI14bTVccdfscdBLO8Ma9zoxG GsBJAvicD2Hc
CuzUxebZ/KFU1dNL4fFVslXNFqY2tdBOGAODnE4hjbiGY7CuZugsUscktI1z 3Vsrpi4g4oXY
yAc82klpw/03qxMk1j7/APS/1MXm2fyhRh1Mal1OGs1rWB5bh3NJIB/oV83J Q6iqoqafRxqo
m7UWUwc22AvaW5OIbYAjInL7FNBoIicbTSsL5KJkRqW4SYpG4s7k4t2EA5/J zTM/JrD6LVRe
bZ/KFUjTFONGO0hJo6ojprNLXObGS8OIAsA49/bZdGhtZPTOrp2NbNU2Pi7g 0CzQPVvP+pVV
Fo6qZoVlIaKrjma6AvM1QHsOF7ScIxnDkCdwTM5IiOFvXV1FQw08skeNtRI2 OPAwG5duPsWK
Srjq55GR6PlbEx74zM4R4CWmxsMWLeO5V8uiasxujwNcynkjbSgOHk9Y17if YAB/p9a7dE6O
NM+eaXXNlfPK4NM7izC55IOG+EZW7LpEmsYZdpaGCskp9lmbHHIyJ84DNW1z gCAfGxf5gL27
VZqnZop82lKyaollFO6dkjIQW4JC1jbE5YsnDdcbty5H6Ie2AvdQtnxVsks8 N23njJfhGZsb
Yg6xP9VFxw+gL3CVrBG4tIJLxaw9Rzv/AE7FuvmHUNSHQ00I2aV9NVGJmPyI c5mEXG63qyHZ
uWKbRMsVEGihqXRiZr5qSXZ2iYYSPFDLNOZBOK18IQfRieI1LqcO/OtYHltj k0kgH+hUqpaT
R8cOm21cei2wMfTNY1wbGDC4F1wbHtBA8W+5XSAiIgIiICIiAiIgIiICIiAi IgIiICIiAiIg
++1TIK0fok3z5ffcvLl6iP0Ob50vvuXly6W7Ycq98/eXpcX7Ps+pD8NXCp4v 2fZ9SH4auFLe
G6+WtH5Sq+lHuNXUuWj8pVfSj3GqSqLhD4ri0lzRcdl3ALDSZaSSxxNxSvaw XtdxstKaV0sW
Jw3GwcNzvWFx1c4ir3XuSIm4QDnmXXA9th93qWL21jLVYzKxa4OaHNIIIuCO 1FSudNH47Wsj
DXB5/wAS+2+5ytbPP71bQSPlp2vkj1TnA+Le9u5Zp6sWzhbU1ckdVoqre+aG qpZXQjFI+OYH
CB2usd2Xb3Kc6QohVClNZT7Qd0WtbjOV9177l8zRV8TvyQkp36RopZHUmqig iyka4tIDT4xu
Tu3BZllwaTq6Z08DiaqndsgH555DY82m+4WufF7DmN47Y64Yl9ciIoNDGwyN kLGl7QQ1xGYB
32P2D7liaGKoidFPEyWN3ymPaHA+0FSIgwAALAWAWURAREQEREETKeCOaSaO GNsslsb2tAc6
2657VKiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICI iAiIgIiICIiA
iIgIiICIiCKfc32rRbz7m+1aIIaryI+kj99qmUNV5EfSR++1TIK5v6HN86b3 3Ly1epN/Qpvn
Te+5eWrpbthyr3z95elxfs+z6kPw1cKni/Z9n1Ifhq4Ut4br5a0flKr6Ue41 dD2NkYWvaHNO
8Fc9H5Sq+lHuNUs8jo4sTAC7EAATbeQP+6w0k3blBUUVPUSCSVhxgYQ5ri02 7rgi6khlbK0k
XBBs5p3tPcVy1Uv+IdG+QsjZGH5OLd5OZII3W/qsXmIjq1XOeiSPR9NG9rw1 5LTcYpXOF/YT
ZdSqW18kYaA58jQ4Ag0z8WG+efqH9u1WUUzJ4RJESWm4BII3G24rNLVmP4ra J8pEXyNOZ3/k
w2VrtIQTzagGolqS/Hie0EtGM239w3rq0jpCoqKWkbFI6GWKWN1Vqzax1gZg 9hOL7G+tdsdc
MPpEXz+iojVz1evj0gQZ5ma7a3COweQAGh9xYZfJG5dOgIAyKokMtRI7aJYx rZ3yANa8gWDi
ewb1CVui+Z0jNO6uliBqpWbexmqgmMbi3UXsDibYXz3hdNfRs1mjLProdbMI 3s2yQHDq3Gxs
+17gZ37N6LK9RVmnYB4FqXtknjfBA98bo53sIIabXIIv9t1qyZ1FLRUUEbpd ex0jpJqhxLQM
N83XJ+VuRFqioW/lE8sqDsYeYjHqyx7sMoe/CCC5jfbcXB71JJpqoiilElJE yaGbVSF051TB
gDg4vwXAsQM2jNBdIvno6+pirdJVMzBIGSRwQMZUuLbuDbC1gBcuuXZnszsu p+l6ljmwOoo9
qM4hLBP4mbC4OxYb2sO7/wAhboqXw1VOkaGUDCx9Q+mjcZ7Xe3FmRhybZpzz PqO9aVP5QPg0
e2o2VrpQ6RskAe5xGAkOLcLDcZbzhGYuQgvUVB4SqjLXmoia6niqYWRYJi1w xYLXs0ZeNc5n
u3Zrqi0tLJO07K0Ur53QMl1vj4m3Fy22Qu09pO7JBaoqOn07USwxyv0eQJqZ 1RC2OXG52G12
kYcvlC1r/fkrLR9UaylErtTckgiGUyNFuy5AN+8WyQdSIiAiIgIiICIiAiIg IiICIiAiIgIi
ICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgin3N9q0W8+5vtWiCGq8iPp I/faplDVeRH0
kfvtUyCub+hTfOm99y8tXqIeBSTDtxze+5eXXXW3bDlXvn7y9Li/Z9n1Ifhq 4VPF+z7PqQ/D
Vws28N18taPylV9KPcappo9bHgxFuYNx2WN/+yho/KVX0o9xqnlkbEwvdewI GQvvNlhojjbE
wMYLALjrNHuqKls0cwYcIaWuZiBsSQd47z/TuXa1zXtDmkFpzBCgnneJtVFh BDQ4ucL7yQAB
cdx7f/GL6zH8mq5ieiBuj5i4CWpa5naGRlpP24jZdzWta0NaA1oFgALABcra 1zQ0TQvBLg3E
C3DmbA779o/8rrO5SkUiP4rabT8uCHQ1FBDqWNmMXi2Y+okc1uEgiwLjbMDc pn6PpH668Lbz
SNkkIuC5zbYT9mEKu0Npna6RlRVV1HIZMAMdPGbxOduDjidbPLMDNdx0rSNE Li+TBMQGSal+
A3Nhd1rC53XOdwurDoggip2ubC3CHPc8i5PjONyfvKQU8VOxzYm4Q57nnMnx nG5P3lcbtOaP
Ero9c4ua5zLNiebvbvaLDN2W4Z9qy7TVA2OF+ueRMHGNrYnuc7CbOGEC9x2i 19/cVBl2h6J0
DYiyWzZNaHCd4fjta+O+I5G2/cp9jhwQNcHv2d2OMvkc4g2IuSTc5E71yDS8 W1SEyMNI2mjm
bI0El2JzhYd+4WAF7lSVOkW+B6qtprkwxPcGysc0hzQTYtNiP6J8L8y654Y6 iCSCZuKORpY4
XtcEWK1dSwuljlcy742OY03OTTa4/oFSS6bnhoaepjqaKuD5wyQ07CA1oYXO Hy3eNYf+F2Vu
lJItKUNLTtY+OZ3515v4oLXFtvbhP3etJRLFoWghaWshcQcA8aV7rBhxNAuc gD2DJST6MpZ9
bjErda4Pk1cz2Yjhw54SMrAZblx/k/pOTSUAlkraKZ5YHOhp22dET2O8c/2C zQaYMu37W1sY
pXvLS0Hxo2uc2/tu0/0SR2O0bSOimiMIwTkF4BIzAABHdYAWtbckWjaSIRhs biY5NaHPkc5x
fYtuSTc5G2f/AGXDQabvQMl0i3V1DpJGaqCN8h8VxByaCcsrncpNJacpqWhk lhlEkhp3TR2Y
57bWNi4jcCe8i6EcOxtBTNwWi+RM6dvjHJ7r3P8AyP3qCbQ1BO3DJC6xLycM r24sZu4GxzBP
YcluNJ02vZTue7XOAvaNxa0kXALrWB9RN8x3qGHSch0FT1z4mvmmYy0bcgXu IAF87C59aHyn
doujfJI90bryFhcNY7CS0gtNr2uMIz9SM0ZSR1ZqWxuEhcXW1ji0OO9wbfCC c8wL5nvWm0T0
MD59KVFOYhhAMULm4STYDe6+ZGeS3bpSkdUMgDpMbrb4XgNJFwHG1mm3YbHM d6ANGUjY4o2R
uYIYjFGWyOaWtNrgEG/YM96mpaWKki1UIcG3LiXvL3EntJJJP2rgrNPU1NC9 7WTvfG9jHRmC
RrrOda9i25G/PcSLbypjpSniEzpZrhsjWNY2B+MEtDg3DmXGxvkMh7Cg70Ve /TVAyOJ5leda
HFjWxPc44SA4YQLgi+YIuM+5b1NaG0cNXTlkkL3x3d3scQLj7wUHaipnaXmx 1rGxsuyRjKck
HxsTsGfscHbuyy6DpemgZeeR77yujDoqaQtBDsOE2Bzvl6+xBYouKTSlJFJN HK+SN0LHSOxx
PaC1u8tJFnWuN11zaQ07TU9BLNE5zpdS6WNroX2yvYuy8UEjIm1+xFwtkXJB XwzzGBuMytAL
yInYAbA2xWw3zGV7rrRBERAREQEREBERAREQEREBERAREQEREBERAREQEREB ERAREQEREBER
BFPub7Vot59zfatEENV5EfSR++1TKGq8iPpI/fapkFIcWrk7tZL+I5eaZr1I NBpZj/HL77l5
hZdrT/GHKvfP3l6XF+z7PqQ/DVwqeL9n2fUh+GrhYt4br5a0flKr6Ue41S1L XvitGAXBzSAT
bcQVFR+UqvpR7jV0kgC5NlhpHBFqWEE3c4lzuwXPcOxcOkIKp1Xjhjc+J8Ya 7A4BwsT3kb77
x3H2qzUM1Q2JwbhL32vhaRkO83IH/vqKx6lYtXEtVmYnoqm0LnuDfBzI7/53 tYQPsBurangZ
TQNhjFmt/wD9K0jraeSwEzGvJtgc4B1+6ynWfT9OtfhbWmflTw6Hqhotujai shkpQxsZDKcs
c5g3gnGd4yuAo59ASVEsD5qqKTUhgBfT3c3A692nF4pIsDYZ27Ny74NJComa 2KkqHQOcWtqb
N1Zt/qxWyte1l3Lr/bEq1misGp/PX1VW+p+TvxY/F39mPf6lxyaOq4NJU2yT BpO0yGV8Je1u
N7XYSAR67Z9ivlBS1TKqN742uAZI+Mg2zLXEH+oRVXL+TsctM+Ez3aYIohjY HZscXYiNxBJz
C6Y9F4dD1FB/hYtcx7b01PqmDELXw4jn9q743F8bXOjdGSLljrXb6jYkf1Wl XUMpKSapkDiy
FjnuDd5AF8kI+XGNH1MuzbXUwyGnlEjdXAWXGFzbG7jxb1pBoRkAgDZ3HVVG uu5tyW4S1rPY
AR93rXRW6SgoY6eSYPwzyNjaQB4pIJufVks1WkYKWtpKSQPMtU5wZhFwLC5J 7kTw30dS7Do+
npcePUsDMVrXt22XH4EYTGXTO8SokmdZtsbXOxYD6r4fu9atVA2qY6tfSAO1 jI2yE9liSB7p
Tzk8OAaImhkbNS1bGTtfMbyQ42lsjsRFg4ZggZ3+xRz6ClNO+ClrdVHLTbPL jixlwF7OGYsf
GN949isaisbDURwCKSSWSN8jWstnhtcZkZ+MF0DMbrepFz5VDdBMZpQ1rNke XFrna6lD5GkA
DxH3GHIDsOa6I9FsGhotHPlcdUxrWytFiHNsQ4A3zBAKsFwz6RMdfskdHUTv DGyOdGWBrQSQ
L4nA9h3XT+kRyUFZU0xhrKyJ/jxuaY4Cz5Lg7O7je9vUon6Db4XfXM2UmRzX uMtMHyNIAHiP
uMOQHYc1bog+fg/Jt0MMzRUwiSQR+Oynw3cx+IOf413EnebhdUmiJXTPqGVT G1JnbO1xiuwE
R4CC3Fcgi/aLZfbbIgrabRZhqYah8+ORglx+JYPc8tJIzyAw7s/at4tGtZoR ujXSYgIdUXgW
7LXsu9YTwKuPQobJo95qC40gOPxANcTnc93jZrXwTVRyRugrIQxk0k2CWnLg XPcTfJ43AkD2
37rWFHUsraOGpiDgyVge0O3gHvU6Chd+ThdNVSOqIsU8c0eMQfnCH8TsXjYd wGWS6K/RM1SJ
mwVjYWz0+olDosZIF7EZix8Y9/2K2RDKug0dJFpLatdG2PDhLI4y0vNgLvOI h1rZZA+tWKIg
IiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiIIp9zfat FvPub7Voghqv
Ij6SP32qZQ1XkR9JH77VMgqwf8NN86X33LzBenf9NL8+X33LzFdLdsOVe+fv L0uL9n2fUh+G
rhU8X6gZ9SH4auFLeG6+WtH5Sq+lHuNW1aAac4m4m4m3Fr3GILWj8pVfSj3G rqWGkNK2RsVp
L7/FBzIHYCe3/wB9qrtI1WzV5BLWayJuFz8m5F18+21xl6x7VbrSSWOJuKV7 WC9ruNlj1K7R
jOGqziVHrmzFrI66SV+IFrGFhJINx2er2d6uYI5RTBk8mOQg4nAWUrXBzQ5p BBFwR2rKz6fp
6/M5W1s+FDS0lcx+jqcwzRij8R8zZgIpWBpA8UOuSThObcrHPvr6nQdT4Do6 OOgaXiFxkMYi
L2zWABLn3sN+bc8hZfSyV9HFg1tXAzG8sbikAxOBsQM8zfsQ6Qom1eyOrKcV J/cmRuPdf5N7
7l1ZfPmjfU6VrA2jL521EJbVFzbQ2ZGXbze5HcDfccl00+iJIaqGqbThs+3T PfJiF9U7HYXv
uzabd+dla0dZo+qkl2Koppnkh0mpe1x7gTb2W+xdaJ/T5yj0bNAKAVujtsbH TxxtbdjtnkBz
dZxAzuMxc+KoJtFV0tXpCYUhY+enqIyW6prJCbYLW8Y5DMvOR3WX1SIueuVZ pGhdWR0ETo8c
bJfzwuMmmN7T/Uhccejq501LPU2fNHUAFwcMomse0O9pLr29fqV+iJ4w+Ypd E1bIHMipNkqR
TPjlqNY0bTIQLOu0knO5u6xF/atH6IqZIqzZNHGgjkghaIg+O78LyXjIluYN s8jfPtX1SIZf
LnRFQKMx09NOxuzVMYZMYWkOeG4QBH4oBIP9bqaXQ0j5qmp2ZpqdogfDJcYm taIw+xvludfv
t25L6JFcj5d1M6HTVGJaPDUPrZHmqxtOtZheQN+LIECxAAtkrSTRxn06+qk1 zYhBG1jo53MB
cHOJBDSL7xvyXZFQ0kNS+pipYGTvvjlbGA53tO8roUjwT1fNz6Il2KVmwtkd PWSPmwtie8sx
OLCNZ4vaN+4E5XUXgKolo3iop8c7NHMihLnglszce43yIuLO9eXavqURc9c/ eXzdZoadsdZH
QwiKOaGEuawtGse15LxncXLbC5FjfNYh0PM2CKKGCeOKXFDOyYxNLYyQSQI/ FtkRYZ+MSvpU
RHzj9G1j6aN9XT7VhmaJafE062NjC0bzhPjHHYn+oUlLol+00L5qVohhEzmx OIcIcTmljfss
d2Qtl2K/RBR/k5o+poImMrYMU2qaBPdpwtFvze/sOeWR371eIiAiIgIiICIi AiIgIiICIiAi
IgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiCKfc32rRbz7m+1aIIaryI+ kj99qmUNV5Ef
SR++1TIKr/ppfny++5eYr0//AKaX58vvuXmC6W7Ycq98/eXpcf6gZ9SH4auF TR/qBn1Ifhq5
Ut4br5a0flKr6Ue41SVRcIfFcWkuaLjsu4BR0flKr6Ue41dD2NkYWvaHNO8F YaR00rpYsThu
Ng4bnesLjq5xFXuvckRNwgHPMuuB7bD7vUrHduUFRRU9RIJJWHGBhDmuLTbu uCLrHqVm0Yhq
sxE9VY500fjtayMNcHn/ABL7b7nK1s8/vVpFOTSa+oaIAAXOxOyaB2km1ss8 9y0j0fTRva8N
eS03GKVzhf2E2XUs+nS1fmVvaJ+Hyjq2jGj30c09NFt8s7tZM8NGpMh8YE77 g5ffuC66KqZH
+UFdCK+kY18rLQPzkk/NNsWnFu+w7l9Ai6sKH8kqoTaLgh26kndHC20UIs+P 1O8Y3+4K+RFZ
nIIiKAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgI iICIiAiIgIiI
CIiAiIgIiICIiAiIgIiIIp9zfatFvPub7VoghqvIj6SP32qZQ1XkR9JH77VM gqb/AJiUfxy+
+5eZL0235iU/xy++5eZLrbthyr3z95elR/qBn1Ifhq5VNH+oGfUh+GrlZt4b r5a0flKr6Ue4
1TyyxwROlle1kbBdznGwAUFH5Sq+lHuNW1dRU+kKcwVTC+MkGwcW5jdmCsNI NE6Ui0tDNNCx
7WRymMYt7sgb+res1Uv+IdG+QsjZGH5OLd5OZII3W/qpaGgptHQGGkj1bC7E RiLrnvuc+wKG
s0e6oqWzRzBhwhpa5mIGxJB3jvP9O5c/Ui01/i1XGeqBtfJGGgOfI0OAINM/ Fhvnn6h/btVl
DMyeISRElpuLkEbjY5FcbdHzFwEtS1zO0MjLSftxGy7TEwwmIAtYW4bMJbYb siN32LPpReO5
q+vhQHTMtBQyyFm0vFRUeIXPLgxrzuDWuyGQzsBlmrFulMUmqEIEuuDMJfbx MOLHu3W/rldZ
l0LQSwxxPhdgY1zBhleCQ75QcQbuucze66BRU4qdp1Q1ur1WK5+Te9rLs5y4 9FaWOkKmeF0I
YI2teyRpcWyNJIuC5rb7t4uM96tFx0WjKWgc51MxzSWhl3SOfZo3AYibAXOQ XYgIiICIiAiI
gIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiI gIiICIiAiIgI
iICIiAiIgin3N9q0W8+5vtVfPpWjpqrZpXyCawIaIXm4PrAsgnqvIj6SP32q ZQ1JvA0i+b4z
mLf52qZBV/8ASy/Pl99y8wXqA/RZfny++5eXrpbthyr3z95elR/qBn1Ifhq5 VNH+oGfUh+Gr
lS3huvlrR+UqvpR7jV1LidTsL3PvI0uNzhkc0HK24H1LGzM45+e/qsNO5Fw7 Mzjn57+qbMzj
n57+qDuUFZUClpnzFpcW2AaO0k2A+8hQbMzjn57+qbMzjn57+qDj2qp2jBtc hf4xAbGwRkt+
UATnl6yPb2rs0bNLM1xJc6Ows94scVhcDM9t/Ycs+xszOOfnv6pszOOfnv6q WjMxJHSMNNK6
QkotUIWNec5JAb5RttiI9eYst6vS9DRy6ueZwcGCQ4Y3ODWkkYiQDYZHM7k2 ZnHPz39U2ZnH
Pz39VQfpehjqzTOmdrQ9rHWjcWtc4AtBdawvcWuc0Ol6ITvh1jy9pc3KJ5a5 wFy0OtZzsjkC
TkU2ZnHPz39U2ZnHPz39UENNp2ml0VDXzRzxMkbdw1EjgzK5uQ3d/FuWo01F JNVxDFDs0zI9
Y+F7mvxYd2QzJdYZnv3Lo2ZnHPz39U2ZnHPz39VfI2ZpSjfV7M2V2sxFgOrc GFw3tDrYSRnk
DfI9y1otLUVfIGU0rnlzNY28bmhzcrkEgA2uL23JszOOfnv6pszOOfnv6qDu RcOzM45+e/qm
zM45+e/qg7kXDszOOfnv6pszOOfnv6oO5Fw7Mzjn57+qbMzjn57+qDuRcOzM 45+e/qmzM45+
e/qg7kXDszOOfnv6pszOOfnv6oO5Fw7Mzjn57+qbMzjn57+qDuRcOzM45+e/ qmzM45+e/qg7
kXDszOOfnv6pszOOfnv6oO5Fw7Mzjn57+qbMzjn57+qDuRcOzM45+e/qmzM4 5+e/qg7kXDsz
OOfnv6pszOOfnv6oO5Fw7Mzjn57+qbMzjn57+qDuRcOzM45+e/qmzM45+e/q g7kXDszOOfnv
6pszOOfnv6oO5Fw7Mzjn57+qbMzjn57+qDuRcOzM45+e/qmzM45+e/qg7kXD szOOfnv6pszO
Ofnv6oO5Fw7Mzjn57+qbMzjn57+qDuRcOzM45+e/qmzM45+e/qg7kXDszOOf nv6pszOOfnv6
oO5Fw7Mzjn57+qbMzjn57+qDuRcOzM45+e/qmzM45+e/qg7kXDszOOfnv6ps zOOfnv6oO5Fw
7Mzjn57+qbMzjn57+qDpm3N9qidHG57XuDS5nySd4UezM45+e/qmzM45+e/q gVfkR9JH77VM
odmjJF3SusQbOlcRcG4yJUyCsH6LL8+X33Ly9eoD9Em+fL77l5eulu2HKvfP 3l6VH+oWfUh+
GrlU0f6hZ9SH4auVLeG6iIiw0IiICIiAiIgIiICIiAiIgIiICIiAiIgIiICI iAiIgIiICIiA
iIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiA iIgrR+iTfPl9
9y8uXqI/Q5vnS++5eXLpbthyr3z95elR/qFn1Ifhq5VNH+oWfUh+GrlS3huo iIsNCIiAiIgI
iICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgI iICIiAiIgIiI
CIiAiIgIiICIiAiIgIiICIiAiIgIiIK0H/CTD+OX33Ly5emtJ2eb58vvuXmS 627Yca98/eXp
Uf6hZ9SH4auVTR/qFn1Ifhq5WbeHSoiIsNCIiAiIgIiICIiAiIgIiICIiAiI gIiICIiAiIgI
K1rf8JMf4pvfcvLl6m39Cm+dN77l5Yulu2HKvfP3l6VH+oWfUh+GrXXN4JeU 7oqmP9Qs+pD8
NXSlvDdUeubwS8p3RNc3gl5TuikRYaR65vBLyndE1zeCXlO6KREEeubwS8p3 RNc3gl5TuikR
BHrm8EvKd0TXN4JeU7opEQR65vBLyndE1zeCXlO6KREEeubwS8p3RNc3gl5T uikRBHrm8EvK
d0TXN4JeU7opEQR65vBLyndE1zeCXlO6KREEeubwS8p3RNc3gl5TuikRBHrm 8EvKd0TXN4Je
U7opEQR65vBLyndE1zeCXlO6KREEeubwS8p3RNc3gl5TuikRBHrm8EvKd0TX N4JeU7opEQR6
5vBLyndE1zeCXlO6KREEeubwS8p3RNc3gl5TuikRBHrm8EvKd0TXN4JeU7op EQR65vBLyndE
1zeCXlO6KREEeubwS8p3RNc3gl5TuikRBHrm8EvKd0TXN4JeU7opEQR65vBL yndE1zeCXlO6
KREEeubwS8p3RNc3gl5TuikRBHrm8EvKd0TXN4JeU7opEQR65vBLyndE1zeC XlO6KREEeubw
S8p3RNc3gl5TuikRBHrm8EvKd0TXN4JeU7opEQR65vBLyndE1zeCXlO6KREE eubwS8p3RNc3
gl5TuikRBHrm8EvKd0TXN4JeU7opEQR65vBLyndE1zeCXlO6KREEeubwS8p3 RNc3gl5TuikR
d0TXN4JeU7opEQVzDehmOebpd4t/ncvLV6ew/wCFmH8U3vuXmC6W7Ycq98/e XpMf6hZ9TH4a
ulSx/qJn1Mfhq6Ut4bqItXvEcbnuNmtBJ9irampqm+OW1DWiPWuEbWAMb6y7 efUFmIy1laIu
alnc8tY848cYkY8C2Jp9XYRkulQEREBERAREQEREBERAREQEREBaOka1wabl xF7AEn+i3WrP
LyfNb/dyDGtHDJy3dE1o4ZOW7opUQRa0cMnLd0TWjhk5builWLjFa4vvsgj1 o4ZOW7omtHDJ
y3dFo6ra2VzDG/C1waX5WBNrdt+0di6EEWtHDJy3dE1o4ZOW7otpJWxuYCD4 7sIt7Cf+y3QR
a0cMnLd0TWjhk5builRBEJWEkXIIFyHAjL7VzeFaPzjj6xG4j+y20n+jS/V5 f7Bb0bGGkiu1
vye5dK1jGZcr2ttFaovCtH5x/Kf0TwrR+cfyn9F14GcDfuTAzgb9yYp/aZ9T mPv5cnhWj84/
lP6J4Vo/OP5T+iOraZukxQOjIldGJA7CMJzOV+/xSfsUtLNDVRvfHHYMkfGc TRvaSD/ZMU/s
/wDk5j7+UXhWj84/lP6J4Vo/OP5T+i6J3QU8Ek0oa2ONpc44b2AzKyTCGB5w BptYkW37kxT+
zPqcx9/Lm8K0fnH8p/RPCtH5x/Kf0XXgZwN+5MDOBv3Jin9mfU5j7+XJ4Vo/ OP5T+ieFaPzj
h6zG4D+y68DOBv3KGsYwUktmt+T3KxFJnHVm1vUrEz0+/lOCCAQbg9q01rbk DE6xscLSf7KL
R/6vpvom/wBgpoPJf6ne8Vzno7xOWNaOGTlu6JrRwyct3RSooqLWjhk5buia 0cMnLd0W8sgi
ifI65DAXG3qWkcrngEwSMBP+Yt+/IoGtHDJy3dE1o4ZOW7opHEhpIaXEdg7V rJIIonSOBs1p
cQN6DXWjhk5buia0cMnLd0UgNwD3rKCLWjhk5buia0cMnLd0UqII2Pa8Xab5 2PqWktRHE8Mc
XF5F8LGFxt32AWzPKzfOHuhRsyr5/oo/7vQNrj83Uf7eTom1x+bqP9vJ0U90 ugg2uPzdR/t5
OibXH5uo/wBvJ0Ur5Gxsc97g1rRck7gFzUtcal+VJURxOF2SyBoa77L4h9oC CTa4/N1H+3k6
Jtcfm6j/AG8nRT3S6CDa4/N1H+3k6Jtcfm6j/bydFPiUNHVMrKSKpjDgyVoc 0O32Pegxtcfm
6j/bydE2uPzdR/t5Oinul0EUVRHK8saXB4F8L2Fpt32IUqgfnXwfRSf3Yp0F cxv+DmP8U3vu
Xlq9Raf8JMP45vfcvLrrpbthyr3z+P29KjH/AOAZ9SH4auVURj/9eZ9SH4at 1LeG6o6iIT08
sRNhIwt+8WVfWzx1DaWGqLY8MgMzHvwg2Hr+UL9g9StEWYnCzDmjdtFWJ2NI ijYWMJFsVyL5
d2QXSiKKIiICIiAiIgIiICIiAiIgIiIC1Z5eT5rf7uWy0Ie2UvYGuBABBNt1 +qCVFHjl82zm
HomOXzbOYeiDci4IuRftChpoXQBzSQ4HPH/mPt7/AG/0W+OXzbOYeiY5fNs5 h6IK2WSMVkv5
xjXaxpDjM3CLAXu2+/I9ikFNUOqJXtbq3Oa9uMYQM/knLM/au7HL5tnMPRMc vm2cw9EHHJTP
fDG2CDZnB9yfF4SL5H/yuyABsLQItUAPkZZfcmOXzbOYeiY5fNs5h6IJEUeO XzbOYeiY5fNs
5h6IOfSf6NN9Xl/sFHSvIpoxc7lPNE6oa9smFjXRuZ4pvv3n+i4W0mkI2hjX U5AyBLiP+y7U
mNcTLz+rFtotEZdmsPefvTWHvP3rl2fSXfTfzn4U2fSXfTfzn4VrFeWdr/8A mf8AP+q2vnpD
pWpFRXU8DxBGGOfM0OY8Oc4G179o9oKr2U82kqOF7gKiITTmWOlkhlAc51wf Hu05ewi/tX0W
z6S76b+c/Cmz6S76b+c/Cs615Xe//mf8/wCqeo0ZPUMqWOpS+KSJzY2SuaS2 TCPzhztdxyy3
Wv8A5iraJhGi2wRU0cILMOokAwgHfcNuD25dq22fSXfTfzn4U2fSXfTfzn4V cV5Ta/8A5n/P
+s0ED6On1RnfLnfPc31NHY3uBJsunWHvP3rl2fSXfTfzn4U2fSXfTfzn4VcV 5Nr/APmf8/66
tYe8/eoqp5NNILncotn0l30385+FaupNISNLHOpwDkSHE/8AZWNYnOWbbzWY 1n/P+u3R/wCr
qb6Jv9gpoPJf6ne8ViCMQwRxA3DGhoPsCwzWx3aGsc25IJcQczfuK88/L1x8 JkUeOXzbOYei
Y5fNs5h6KK0rbbFNdzW3YRdxAFyLbyoGNjk1Ip5BLgeHP/O48PikdpXVjl82 zmHomOXzbOYe
iDgbRPZTtDIgHmBzH2Izdla/9VtJTSF02CG5fGQXuDb3tYAG97e1duOXzbOY eiY5fNs5h6II
qen1FQ4tYGscxt7drs7/AG7s10qPHL5tnMPRMcvm2cw9EEiKPHL5tnMPRMcv m2cw9EGGeVm+
cPdC5nuLa2a3m4/7vXTG1wxOfbE43sNwyt/2UE8ExqDJEGODmBrmucW2sTYg 2PeUGNYe8/em
sPefvWmpqfMxc8/AmpqfMxc8/Ag0rYzV0U9Pjw62MsvvtcLlNVXy0ksRoSyY RkAve10b3W3D
O5B9YC7dTU+Zi55+BNTU+Zi55+BB8/S6KlwMikpnCn2sSmOTVjxdWQbtZ4u/ sG/tUooZY4oY
5aLaqWKSYClBYQAXXY6ziBYC4t2XV3qanzMXPPwJqanzMXPPwIKU0Mx05tUk U5biaYnx6q0b
cIBab+MBe+TTY39qstEslptF0sEoLZI42tcL3sbLo1NT5mLnn4E1NT5mLnn4 EG+sPefvTWHv
P3rTU1PmYuefgTU1PmYuefgQbMcXVsN/Nyf3YuxcsEEwqBJKGNDWFrWtcXXu Rck2HcF1IKnF
anlH8cvvuXmF16bh/MSn+OX33LzGy6W7Ycq98/j9vUIv2dZ9SH4atlV6PwVO hYYw7IwCJxHY
cOErpvV+fh5B+NJiZaiYh1ouJ76tv76HkH41EaqqH72HkH41nWV2hZIqk11U D5WHkH41sysq
nfvYeQfjTWVzC0RVMlfUs/ew8g/GtRpKoP72LkH401lNoXCKnOk5x++h5B+N Y8Jz+eh5B+NN
ZNoXKKnGk5z++i5B+NZ8Iz+ei5B+NNZNoW6KqbXVDt00PIPxrfaqq19dDyD8 aaybQskVQ/SF
S021sPIPxreOsqX/AL2HkH41dLG8LRFVPrqhm+aHkH41gaQnP76HkH41NZNo WyKpOkJx++h5
B+Na+Ep/PQ8g/Gmsm0LhFUjSE5/fQ8g/GpG1dS7dNDyD8aaybQskVYauqH76 HkH41rttTfys
PIPxprJtC1RVu1VVr66HkH41E7SFQD5aHkH401ldoW6KoGkZz++h5B+NZOkK gfvoeQfjTWU2
hbIqgaRn89DyD8aHSM4/fQ8g/Gmsm0LdFTjSU5/fQ8g/GtvCE/noeQfjTWTa Fsiq21lS7dND
yD8aSVlUweVh5B+NNJNoWiKm8JVPnYeQfjUjK2qcL62HkH41dLG8LVFWbZU+ eh5B+NYNdUD9
9DyD8amsm0LRFVbfP56LkH40NfP56HkH401k2haoqjwjP56HkH41KyrqH7po eQfjTWTaFkir
XVVSP30PIPxoKupP76HkH401k2hZIq/X1XnoeQfjQVFV56HkH401k2hYIuDX VVvLQ8g/GtHV
VS399DyD8amsrmFkirW1NW799DyD8aw6rqW75oeQfjSImTMLNFViun8/DyD8 abbUefh5B+NX
WTaFoiqzW1A/fQ8g/GtmVdS7dNDyD8aaybQskVeZqofvoeQfjWu01fnoeQfj TWU2hZIq4VFU
R5aHkH41o6sqWm2uh5B+NNZNoWiKsFZUn99DyD8abZUefh5B+NNZXaFmiq9t qPPw8g/GsbdU
eeh5B+NNZNoWqKrFbUefh5B+NbNqql26eHkH401k2hZIq909UBfXQ8g/GtBV VZNtdDyD8amJ
NoWaLhEtWRfXQ8g/Gon1dU0210PIPxq6ybQs0VYKup89DyD8aztdR5+HkH40 1k2hoB/hZT/H
L77l5gvTJJ2QUcmN4sA9znWsLkkn+6808Tzsf8y1bpEOdetp/H7fR6QrKjR8 pNJK6LFmQN33
Lh/+QaV9Nf8AcOiIpFpjy1NKzPWGHflBpU76x/3DotPD2k/Snfyt6Iiu1uU9 unDU6d0l6Sf5
G9Fkad0l6Uf5G9ERTa3J7dOB2nNJHfUk/wChvRa+G9I+kf8ABvRETa3J7dOG p03pD0gctvRP
DekPPjlt6Iiu1uT26cHhrSHnxy29Fnw3pH0j/g3oiJtbk9unDI05pEbqn/g3 opPDuk7fpTv5
W9ERNrcnt04aO05pE76n/g3otm6d0kN1UR/pb0RE2tynt04hq/TmkjvqSfax vRajTekfSP8A
g3oiJtblfbpwHTekfSP+Deix4b0h6QOW3oiJtbk9unDI03pH0j/g3ot26d0k N1UR/pb0RE2t
ye3Thk6d0n6Uf5W9Fr4d0l6Sf5G9ERSbW5Pbpw28PaTt+lH+VvRaHTmkTvqf +DeiIkWtye3T
hr4b0j6R/wDW3os+HNI2/SP+DeiIrtbk9unDHhvSPpH/ANbeiHTekPSBy29E RTa3J7dODw3p
D0j/AOtvRZ8OaR9I/wCDeiIrtbk9unDZundJDdUkf6G9Fs7TukyM6on/AEt6 IibW5Pbpwi8O
aRv+kf8A1t6KRundJAZVJH+hvREVm1uU9unAdO6S9KP8jei18OaS9J/4N6Ii m1uV9unDHhzS
PpH/AAb0Tw5pH0j/AIN6IibW5PbpweG9I+kf8G9FuzTukhuqiPYxvRETa3J7 dOGx07pP0p38
reiwNO6T9KP8reiIm1uT26cNvD2lPS3fyjonh7Sfpbv5W9ERNrcnt04PD+lP S3fyjotDp7Sd
/wBKP8reiIptbk9unDZuntJjdVu/lb0Wr9PaTO+qJ9rW9ERNrcnt04aeHNJe k/8ABvRBp3SX
pP8Awb0RE2tye3Thnw7pL0k/yN6LZuntJjdVEf6W9ERXa3J7dOGx0/pT0t38 o6LHh/Snpbv5
W9ERNrcnt04Z8P6Ut+lu/lb0Wh07pM76o/yN6IibW5PbpweHdJelH+RvRa+H dJekn+RvREU2
tye3Tg8O6S9J/wCDeieHdJek/wDBvREV2tye3Tg8O6S9J/4N6LZuntJjdVEf 6G9ERTa3J7dO
G/h/Slv0t38rei1GntJ3/Snfyt6IibTye3Thv/8AINK2/TH/AHDotDp7SZOd Uf5W9ERNrcnt
04YOntJ+lH+RvRYOntJ+lH+RvRETa3J7dOGYdI1ddOyKpmL47E4bAA7u5UNh 3Ii53mcvR6NY
iJxD/9k=
name="screenshot02.jpg"
Content-Disposition: inline;
filename="screenshot02.jpg"
CAJjAjkDASIAAhEBAxEB/8QAGwABAAIDAQEAAAAAAAAAAAAAAAMEAQIFBwb/ xABPEAABAwIB
BwULCAgFBAIDAAAAAQIDBBGTBRITFCHR0jFRUlSyFSIzNEFTYXN0krMyNTZx coGRlAYjQkNi
oaKxJERkgsEWo8LwJmMlg/H/xAAZAQEBAQEBAQAAAAAAAAAAAAAAAgEDBAX/ xAAoEQEAAgIB
AwMFAQEBAQAAAAAAAQIRElETMkEhMfADIoGRwWHhBKH/2gAMAwEAAhEDEQA/ APo8m5Op5aSO
oqYmTyzNR6rImciIu1ERF5Nha7m0HUaXBbuM5M+aqP2ePsoc/Kc73tljRFvd URUa5bfgh1rG
U+66/J1D5KGlwW7jVuTqLqVLgN3Hz2TZKumylC1HuWJ70a5qxyW27PK2x38t o/uTMkcr4nOz
Wo+N1nNu5Euii8ashL3NoupU2C3cZ7nUPUqbBbuOU7KslNVRpVrJn0kE2nYz 95m5ma5E8t0X
ZzXVOcs02XJXqms0L4GZ7WukdntaiKi2VM9jVVboiKlv2k2kZhuFzubQ9Sps Fu4dzaLqVNgt
3EWTMrd0HsYlOsTsxz5Gud30ffWaipbypdfuKtJny5ar1fHWvSOfNZIlQqRM TRtWysz9u1V/
ZXlNML/c6i6lTYLdw7nUXUqbBbuOBQ11Yv6PJRPqHOr5WN0UyqquzHtV2f8A W1Een+1OcmoX
y1GUIElZXVCJR077xVKsaxy513OTPTOvZPIvIbyT6Ox3OoupU2C3cO51F1Km wW7inlp7EyjR
RzPq0hdHKqtpVlzlVMyyqke3yr6DSHKlVSRaGqplkdTUzJZpFkRHKrs5ESyJ ZVu1PKibV++c
kxhe7nUXUqbBbuHc+i6lTYLdxVqsoSxsdDW0qRyXjc1IahyoqK9G/Ks1UVFX ktZfxIm/pB+v
lV1FNqsekvMjH7MxFuq3ajbLZUSzl8mzltuYMSvrk+i6lTYLdxqtBRdSpcFu 4rVtXlRkNO9t
NTRrJOxubrCrdq+Re82fdc6LuTaI9WK2o0PUqXBbuNkoKDqVLgt3GXONUkUv Cctu59B1KlwW
7h3PoOpUuC3cZSRQsijBlr3PoepUuC3cO59D1KlwW7iRj1UzI6yDBlDqFD1K lwW7jGoUPUqX
BbuM6RQr1sVqzLXUaHqVLgt3GNRoupUuC3cFkU2jcqqNTLXUaPqVLgN3GNRo +pUuA3cWAZiD
Mq+pUfUqXAbuMalR9TpcBu4sGBiDMq+p0nU6XAZuGp0nU6XAZuJzAxBmUOp0 nU6XAZuManSd
TpcBm4nAxBmUSUdH1KlwG7jZKKi6lS4LdxuZRRiDMtUoKLqVLgt3GdQoupUu C3cSIpuijEGZ
QahRdSpcFu4ahRdSpcFu4sAYgzKvqFF1KlwW7hqFF1KlwW7iwBiDMq+oUXUq XBbuHc+i6lS4
LdxYAxBmVfufQ9SpcFu4dz6HqVLgt3FgDEGZQdz6HqVLgt3DufQ9SpcFu4sA zEGZV+59D1Gl
wW7h3Poeo0uC3cWAMQ3KDufQ9RpcFu4dzqHqNLgt3FgDEGVfudQ9RpcFu4dz qHqNLgt3FkDE
GVfudQ9RpcFu4dzqDqNLgt3FgyZhuVbudQdRpcFu4dzqDqNLgt3FkDBlQqMn 0LZqW1HTIiyq
i2ibtTMevN6EJ+5+T+o0uC3caZQumrKi2tNy/Wx6J/NSBc/SIsiSvZZdjHWW +y3lT0k4bErX
c/J/UaXBbuI6igoEjbaipkXSMTZC3pJ6CGRWrG5I4qlr7LmqsuxF8n7Qk0ma 26r4Rnl/jaMN
SVFJRRuiZFk6jfJK/Najo2tT5KrtXNXm5ivFHSTSJHFR5FkevI1srVVfuzDM umbLBKjHyaN6
uVqKl/kuTyr6SCBj4HQroq57YfkNcsVk2KnkXmUYIWJaaglyS+oZQ0zFdAr0 tE26d7flsQPZ
SJI5NUpdiqngGbjSVksWRZI3KqKymc1UvzMOVPHPrMtpH2z18vpOX1Jmr0/Q pFs5dZ6UjY3O
SipXKiKqNSBm3+RsynR7WPZk/J7o3sV6TI1ujaicucqtui+i39ltxtHU5q2e 5V8m0uxysZSL
SLTzPhk76V6uRHq/ZZUS9tlk/wDeWKWz7uv1fp641j/4sxapJGj1oqRL3/cN /Ha1P7GytpOq
UuAzccjR1Fvlv+9bGixVKrZHv/EjecunRph2m5Np58lySRxsimbJKrXsS3I9 1kW3KlksfMd2
H9NT6/JqOTIb86986df+4881uerHpEvm5++YerZL+aqL2ePsoVcqZEhyjdVk WJ/SRLk1HIsO
QIJUS6x0jXIi+WzEUt6vV9YgwHcZUWwyM+HByV+i1Pk2rSqlndUSt+Rduajf Ta6naljjqIli
lbnMVUVUvbkW/wDwbrTVa/5inwHcZqlJVp/mKfAdxi1tvcxKOahpKip1iaBr 5ViWFXL5WLyo
vOaLkujdRyUkjJZYJLZzJZ3ycnJZXKqp9xZ1ar6xBgO4xq1X1iDAdxk5hvq1 hpKenqJ6iGJG
Sz5ukcn7Vksn8iNMn0zat9S3TNke7OejZ3o1y2RLq2+auxE8hNq9X1iDAdxj VqvrEGA7jNzB
iUMdBSRrErIURYYlhYt12MW10/khvT0tPTPzoWZrtG2K+cq962+am3mupvq1 X1iDAdxjVqvr
EGC7jGYMSw6ON9RHO5t5Y2ua1112Itr/ANkNH01PI+Z0kSPWdiRyZ21HNS9k tyftL+JvqtV1
iDBdxjVarrEGC7jGYPVzajJSIxsVK1Ea97Fllmne96NY5HIjc6902LsuiJe+ 0tMoaWOZ8rWv
TSXVzNK7Rrfl7y+bt+osLSVS/wCYgwXcZjU6rrEGC7jGYPVUTJlI2mWnRJtH dqoi1EiqxU5M
1Vddv3WLTl2WM6nVdYgwXcY1Op8/Bgu4zcwzEolbc1zEJ9TqesQYLuMalU+f gwXcY2hmsoUQ
2RqKb6lU+fgwXcZnU6nrEGC7jN3g1lq1ljLm3Q21Wq6xBgu4xqtV1iDBdxje DWUWiMLHsJtV
qusQYLuMapVdYgwXcZu8M0lXSI2bHYm1Sq6xBgu4xqlV1iDBdxjqQaSjMEmp 1XWIMF3GNTqe
sQYLuMzeG6yjMEup1Pn4MF3GNSqfPwYLuMbwayhBLqVT5+DBdxjUqnz8GC7j G8GsoTBPqNT5
+DBdxjUajz8GC7jG8GsoAT6jUefgwXcZjUKjz8GC7jG8GsokU3RTfUajz8GC 7jGpVPn4MF3G
N4NZEUyNTqusQYLuMzqlV1iDBdxjeDWWAZ1Wq6xBgu4xqtV1iDBdxjeDWWAZ 1Wq6xBgu4xqt
V1iDBdxjeDWWAZ1Wq6xBgu4xqtV1iDBdxjeDWWDI1Wq6xBgu4xqtV1iDBdxj eDWQDVarrEGC
7jGq1XWIMF3GNoNZDJjVarrEGA7jGq1XWIMB3GNoNZZA1Wr6xBgO4xq1X1iD AdxmbQayyDGr
VfWIMB3GNWq+sQYDuMbQay2Brq1X1iDAdxjVqvrEGA7jG0N1kljZNGscrEex eVFTYQ6lD0p/
zEnETavV9YgwHcY1er6xBgO4zMwYlDqUPSn/ADEnEFoYHbHLOu2+2ok4ibV6 vrEGA7jGr1fW
IMB3GMwYlFqUPSn/ADEnENSh6U/5iTiJtXq+sQYDuMavV9YgwHcYzBiVaTJ8 EjHMdpnNcllR
aiTanvEfculvtSf8zLxF3V6vrEGA7jMLTVa/5iDAdxmfa2No9lPuZS//AH/m ZeIdzKX/AO/8
zJxFzVavrEGA7jGq1XWIMB3GPt4bm3Kp3MpV8/8AmZeIx3KpOaZfQtRIv/kW 9Wqk/wAxBgu4
zVYqlOSogX/9DuMYrwZty1mY1lHIxjUa1saojUSyIluQ8nPVc90tDK59s5Ek atksi2VU/wCD
ykq3tDnXun5y9Ri+jLPYk+Gdo4kX0ZZ7Enwzo5UbA/JVY2re6OndA9JXt5Ws zVuqbF8noJl0
hrBlbJtTM2GnyhSTSu+SyOZrnL5diIpcPk7pS0mQo65IK/J7padlHNEj4ZGS Zq5jnNVVRyWt
5U5V2KV58s5YezKlTTvkbqla6GNHLAymRrXNSz1eqPuqKvIvKqWsS19gyeGS aSFksbpYraRj
XIrmX2pdPJckPico5QnyXXfpdWUqtSaNKRGq5L2u3Nvb0XL3dLKlFUV6SrI6 KHJ76hjKx0Gl
SRqr+zEvyF518qcqAfUA+RrHVUv6LpPPlt2fV5OfI6nkjiRZF0aOXMsiKltq L8rYvkWynUyZ
MtD+hdNUOkc5YaBJc5zUdazL2slr25OVOTl8oHaI3zwxzRwvljbLLfRsc5Ec +21bJ5bHyuSs
pZYblHIbK2dssOUoHvVFc1eRiORURI25v1Xdy+i5r+m2uJljIj8n7aqLTysb t7/Na1yt2bVu
iKlvLewH1j54Y5o4Xyxtllvo2OciOfbatk8tiQ+DpcpTZZ/TXJGUkbJHQv00 VMyRFRy5sd3u
VLqm1XWui/s2XkLVHlnKT8mZGyo+rc9a+vSCSnWNmjaxznp3tkztlktdy+m4 H1088NNC6aol
jhib8p8jka1PJtVSQ8//AEkrKuv/AEfyzLNX6KODKC0rKZGMzZGtVtkRVTOz v2uXyLstydTK
OU8qSZVyzT0sk7GUMTFiWHQIxquYrs6RZNtr9HyIB9Rp4dY1fSx6fMz9HnJn Zt7Xty2vsuNP
DrGr6WPT5mfo85M7Nva9uW19lz5vJ80lR+mVNNNo0lkyIx79Gt23WRFWyoq3 T71I8sTyU36V
V1RC7NliyFI9jrXsqPVUXaB9YD4VuVMtJGjXZVcqrkjukr9BHfO76zE2WRNr bqqKq5uy1y9D
lOvyjlzJtN3R1KKpyYyqcyKNiq+Rb3RqvRbc/l2NX6wPrAfH5Py3lHKNP+js TqjQvr9Pp5Ym
Nzl0aLa2ciol+Vdn1WI5ssZVfQ6GKt0c6ZbXJ6VCxNc5Y9tlVLWvtTkROQD7 QHwdVU1eRqz9
K6uCqklnhZStR0rWLdXIiZyoiIl0RVt5OdFOlJlDKtLJlJj5JWsjyc+oj1p0 CzNkbeyo2Nfk
/WnKn4h9UDm/o86qkyJSz1tU6pmnjbKrlY1mbnIio1ERPJ/7zJ0gAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAABFNUwwIqyyNbZL28v4ASgoNrm1j9HRy pmol3yZq97zI
l/Kv/BurJU/zz/dZuIm8NwuFeqq2UuZnNe5X8iNt/wAkLllYiqlcjlTkR6Ns v12KNdlKnlWB
zXWVucjmqnIuzYVS0WnDYqxWZYnhlR0UTljcqNRHo3Yq7OcljyykEF6tkmcl 1VUzVRE+5dpx
8o11O9rLSsukjVtfyXQgrquB9NIkcrXKrVRERbnp6cTEL1/x9grs5LouxTUx FtiZ9lDJyhxl
RZ4hN9qbtuPKz1RniE32pu248rNn2hzjun8f16hF9GWexJ8M7ZxYvoyz2JPh naJlcKcGScm0
0zZqfJ9JDK35L44Wtcnk2KiGz8m0ElUlVJRUz6hFR2ldE1X3TkW9r7LIWivF W0k1Q+niqoZJ
4/lxtkRXN+tOVCVNlpKZXTuWniVahEbMuYn6xES1nc+zZtNaSgo6LP1Okgp8 +2doo0ZnW5L2
+tSwAKtLk2go5FkpKKmgeqZquiia1VTmuiegmgghpoWw08UcMTfksjajWp5d iISGAKUeRclR
SNkjyZRsexUc1zYGorVTkVFsWnwQyTRzPijdLFfRvc1Fcy+xbL5LmY5GSxtk ie17HJdrmrdF
T0KbAQR0FHDodFSQM0Gdos2NE0ed8rN5r+WxqzJtBHVLVR0VMyoVVdpWxNR9 15Vva+26maXK
FFWOc2kq4J3M+UkUiOVPrspZApz5JybUzOmqMn0k0rvlPkha5y+TaqobVWTa CskSSroqad6J
mo6WJrlROa6p6S0AI9BDrGsaKPT5mZpM1M7Nve1+W19tjWSkppZHSSU8T3vj WJznMRVcxeVq
rzejkJgBX1Cj6pB4LQeDTwfQ+z6OQ5836O0c+WWVs0UEkEdIlMymfCitbZ10 cl9ibNlrHVkk
ZE3Oke1jbol3LZLqtk/mZkeyKN0kjmsY1FVznLZETnVQIZqCjnp2U81JBJBH bMjfGitbZLJZ
F2Js2BtBRthihbSQJFC/PjYkaZrHct0TyLtXanOSuljbmZ0jU0i2ZdflLa9k 59iKbgQyUlNL
I6SSnie98axOc5iKrmLytVeb0chHDk2gp45Y4KKmiZMmbI1kTWo9NuxURNvK v4loAaxxsijb
HGxrGMRGta1LI1E5ERDY0jkZIirG9r0RVaqtW9lRbKhuABhVREVVWyJ5SJ1V TtjbI6oiRjmq
9rlellaiXVUXmttuBMCJ1RCyn075Y2wo3O0iuRG2578ljZksciuRkjXKxbOR q3tsvt+5UUDc
EE1ZS08scU9TDFJKto2PejVevoReUlkeyKN0kjmsY1FVznLZETnVQNgYRUVL ot0UyAAAAA1c
9jM3Pc1ucual1tdeYDYESzwtSRVljRIvCKrk7zZfbzbFQjWvo0mlhWrgSWFq vkZpEzmNTyql
9iAWQVoMoUVRDJNBWU8sUe172Stc1vl2qi7CwioqXRbooGQAAAAAAAAAAAAA AAAAAAAAAAAA
AKWUoo9VkkViK5Vaiqv1oXSnlRbUEn1t7SGx7hZjHORrWt27bJYrvq6Rrla6 WK6LZUumwjyk
+0aol89X5rE53LsT7vL9xbgiipaaOLyNS31nD6f04vEzKrW19FVamgd8p0K/ WiFStmpv1egW
O226NsnMVFypXySz6OZjWRyOaiKxPIdTJdbJU5Nhmlsr3XutrftKn/B6a/8A nik7OUfXy41W
9r42I2y2kauz0KhBWyOdA9GNVVVq2sfVaUw6dGNVzls1qXVTvFv8b1mYKiOS NEje1ytREWy8
hvnKVaeDOVKmTOSV65ypfkTyJ+BZOWMGVSPxCb7U3bceWHqcfiE32pu248sM n2hEd0/j+vUY
voyz2JPhnaOLF9GWexJ8M7RMukKuU2TPyZVMplVJnRORllst7bLKc1+U6BuR Z0ybNC2empnu
ZE1Ez4VRq8reVtl50O4CVcPma2ur6aup6dcoQxM0TZEkqZGRJM5XLdvyFRbJ ZLIrV28q8pWr
8oVNY/KdNHVO0K01QmizmOkYrLJZWozvUXbyq5VRb7D68Bkej5WfKdTHPSRU +U6dtPoWvZNP
MxiTrnKipdGKjrWRLNVq7eXm6GUkzf0jybI+rdC10crEb3iNc67O92pe68yL fZs8p2gJ9SPR
8nk6pr6HJdJopVqNJk+SSOFY0s1zEbm2ttW99t1W/ktyHT/R6rmqqeZ01dT1 drKixTNkVt05
HZrGW+q1+XadkCfXJL5XJOUpI/0aZoa+klfFFGitib39Oy6I5z0zlvZNvInI WqivaxKRrcuZ
tJIkiurrxLd6Wsy+bmJyu8l+9PoAJ9R86ldlN6SSI92khye2dIEiRNJIuem1 LZycibEW5a/R
6rmqqeV01dT1dlRWrFM2RW3TkdmsZb6rX5dp2AB81QzZSqW5PSTKciLWUzpX K2KNFYrc22bd
F5c7be/osRuyvUyU0EktclI91GyWJqMausyre7bKiqvI3vW2XvvqPqQGvlsr VskkskM9YkMj
Z6dGUea3v2q5iq7kzl2qqXRbbLcpFVZQrJ0ytFPVU7WtiqGaqsqJIjUauaqM zEdtSy3zlSy8
nN9cAROHDy49I6fJb3VCUzUqG3mVE7xNG/bt2feuw59dlmqiyZG6KttKumdF O9WMbO1q2b+w
7OVbpZGol0ut0PrAGR4fOzZUqY6ysbHUJUTNgdJDTRKxzW2Yi9+22ei35Nqo t/IQU+VKhaNr
psr02hfM1r6mKVkiworVWyrmNa26oibWryr6D6kAcHJk80X6O1tRT/4iZslQ +PvflrnuVNic
/MV1yjUatMtFlTXGIsCJUKxi5jnSI1ze9REXZ5OVL8u1D6YAc3Js8rX18NVU LM2mlRElkRrV
zVY122yImy67bHFlc1lFlFZGuZHUUcrqLOXkZZVc1Oa+x31Kifsn1gDYnD5L KEb3ZHqsluY7
Q08D6jOVNiszVVjb+h1/uZ6To5KrKWLKldTy1MLJ5JY8yNz0Rzv1TOROVTuA 3LPDh5VqIqHK
KzRzwuqJWsjfRyfKmbnLbM8t++XyKn1cpWrKxaiiyuyeuzahkM7Uoe8TNaiL mutbOW6WW97b
T6UGNifXL5qprcoUEFVG2o0ytghla97EakSOcrXLsRe9REvtR1vLczS1VfVy UlO3KkSpI2ZX
TUzmTKuarLd9mI26Zy/s8np2n0gEsj0fNU+U6uKCnqqmokmZUUUk7o2RtTMc 3N+Rs/iX5SqX
P0eraiqgqtPUR1OiksyRj2vRUVqL8pGtRdqryIdkAfLRZWq1opZo6/TTpRyy zRZjP8LIiXRN
iXTbdLOuq29CnWrI5e4ivdI+eaJGzo5URFVWqjrWRETyW3nTAHyzLyVEFkcr crvSVVt+yxyu
27PKyybeYxW1EUNNlCipp4aqJ0NTIrW+EpnWVVzvQqqqbURfr8n1QH+NifXL 5fKM1PW089RR
SRzNjydMyaWJUc3aiZrVcnl2KtvJ9+3vZPrKWsp2rS1MM6MREcsT0dZbci2L QNZwAAwAAAAA
AAAAAAAAAAAAAAAAAAAClldbZOk+tvaQunOy8rkyROrEu9M1U95Cq+swyfZU z0kynLMu1lMq
tanO9eX8E2fibumVy3Vbqc2OqhjibGkjnW2q5Wr3zl2qv4mdch6S+6p6afSi sYhwtabTlUny
V/i2aOrmYlRK5XI1bW71zv8AguLJ3HoYIGsdL3ytS65qrdVXm9JXqJaeokp2 vRHsR6qqOaqp
8hxXq4YnJG6ijijkY+6/q1S6fchcxn3c8Y9nSpcpunqNC+BYlzVddX3/AOCx nazUMg/YTv5P
qTkT71/spw4FnbVaeoWOyRq2zGv/AOUO1kyKTQrI5qo+Vc5b+RPIn/vOpFvt h0pEz7uorkF7
mrY7cu1TY4OyrGl8nTfam7bjys9Vi+bpvtTdtx5UJ9oRHdP4/r1GL6Ms9iT4 Z2jixfRlnsSf
DOprMfRlwn7iZdITAh1mPoy4T9w1mPoy4T9xLUwIdZj6MuE/cNZj6MuE/cBM CHWY+jLhP3DW
Y+jLhP3ATAh1mPoy4T9w1mPoy4T9wEwIdZj6MuE/cNZj6MuE/cBMCHWY+jLh P3DWY+jLhP3A
TAh1mPoy4T9w1mPoy4T9wEwIdZj6MuE/cNZj6MuE/cBMCHWY+jLhP3DWY+jL hP3ATAh1mPoy
4T9w1mPoy4T9wEwIdZj6MuE/cNZj6MuE/cBMCHWY+jLhP3DWY+jLhP3ATAh1 mPoy4T9w1mPo
y4T9wEwIdZj6MuE/cNZj6MuE/cBMCHWY+jLhP3DWY+jLhP3ATAh1mPoy4T9w 1mPoy4T9wEwI
dZj6MuE/cNZj6MuE/cBMCHWY+jLhP3DWY+jLhP3ATAh1mPoy4T9w1mPoy4T9 wEwIdZj6MuE/
cNZj6MuE/cBMCHWY+jLhP3DWY+jLhP3ATAh1mPoy4T9w1mPoy4T9wEwIdZj6 MuE/cNZj6MuE
/cBMCHWY+jLhP3DWY+jLhP3ATAh1mPoy4T9w1mPoy4T9wEwIdZj6MuE/cNZj 6MuE/cBMCHWY
+jLhP3DWY+jLhP3ATAh1mPoy4T9w1mPoy4T9wEwIdZj6MuE/cNZj6MuE/cBM YW3lItZj6MuE
/cY1lnRlwn7gJFROZDConMhHrLOjLhO3GNYZ0ZcJ240VMpRTLNSTU8OlWGRX OajkbdFaqeX6
zjfpBPLIlK2ppVp2LJ8pZGrf8D6NZ29CXCduIKmOlq2tbUUzpUat0R0Llt/I 2s4nLnaszE4f
O5F0Lctxshej2rG5Vs6+0+pUpwUlDTSaSCjWN/JnNgci/wBiwsqdCXCduKtb M5KVmsYlspg1
WVOhLhO3GNJ/BLhO3DMKQxfN032pu248qPVYduTZl2ptm5Ut+248qE+0Ijun 8f16jF9GWexJ
8M6RzYvowz2JPhnSJl0gBVXKEKZUTJ6o5Jli0qLbvVS6pb69imIMoQz5QqaK NH6SnRqvVU73
vvIiktWwCGlqWVUb3xo5EZI6Nc7naqov9gJgV2VbZH1LGMe59O5GuTZ3yq1H bNvpTlsZoapt
dRRVTGPjZK3Oa19r2+5VQCcAAACOnnjqYI54XZ0cjUc11lS6feBIAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApR/ N8/2pu248pPV
o/m+f7U3bceUnSe2HKO+fx/XqMX0YZ7EnwzpHOi+jDPYk+GdEiXSHIrqKpky jNVwRor44Y1h
VXIiOe1z7t9F0da/pKs2SapEnRrNJnwxaSzkTTOSRzpG/ei227Ntj6EGKy+e XJ0mgu3JtqVa
hHrQZzNrc23JfM+VZ1r22X5StLkaqfTQMkpZVhbLO51PEsT3JnOuxf1l2rZL pzpf6z6oBjl0
Ub6FtfPO1zY1zXosj25yo2JqKqreyLdF9H3HHpMmOrsl6XQslcmT2xQOSVrk SVqv2tVFVLot
rL5L/WfWAEej5nKeTtUhqVip0ZDKlMioxyNz5El75dnlsqbSRcmy6FVbk7Np VqUkWguzvm5l
uS+Z8qzrXtsvyn0EkbJW5sjGvbdFs5LpdFun8zYDgw5H0stIlVRxrTMbMuhk s5sWc5qsbbk2
Ii8l0T8CiuRZlydQQOoZGxwtc2aGFIFVz7JaSz7tXkXbsdt+s+sAHz78k50d bJLSSyvkdFme
DdI5qNZdFzlzbXbtTy2+ov5Kgki2y0UdO9YY2qsSojVtnd6jUVc21+deXlWx 0QAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAFKP5un+
1N23HlJ6tH83T/am7bjyk6T7Q5x3T+P69Si+jDPYk+GdE50X0YZ7EnwzokSu EWmer3tjp5JM
xbKrVaiXsi+VU5xpJuqTe8ziN6PwlV61Ow052UcqQwZRWKRs7kSzVzJMxE71 XKqbUvytGJn2
hURle0k3VJveZxDSTdUm95nEaUsrkfC9jldT1Nlaj3Krm97flX6uQS1tT3UW jpqaF7Wxtke+
SZWKiOcqbERq3+TzoTE59CYw30k3VJveZxDSTdUm95nETa5S60tNrMOsNTOW LPTPROe3LY0j
ylQywvmirad8TFRrntlarWqvIirfZymsaaSbqk3vM4hpJuqTe8ziJG19G6aK FtXAssrc+NiS
JnPbzol9qekzNW0tPIjJ6mGJ7lREa+RGqt722Lz2X8AItJN1Sb3mcQ0k3VJv eZxErK+jkjlk
jq4HshukrmyIqMty5y+T7zCZQolpFq0rKdaZFss2lbmctvlXsBHpJuqTe8zi Gkm6pN7zOI0g
yxSupHVNRNDTRaZ8TXSSojXZrlS6KtuW1yemq9YqauHMzdXejM69867Udf0c oEekm6pN7zOI
aSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKW km6pN7zOIaSb
qk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6 pN7zOIaSbqk3
vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7 zOIaSbqk3vM4
i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOI aSbqk3vM4i6A
KWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSb qk3vM4i6AKWk
m6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3 vM4i6AKWkm6p
N7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4 i6AKWkm6pN7z
OIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6A KWkm6pN7zOIa
Sbqk3vM4i6AKWkm6pN7zOIaSbqk3vM4i6AKLpnssslNKxquRucqt2XWyci+k mMV/i6esj7aG
QKcfzdP9qbtuPKD1eP5un+1N23HlBc+0Ocd0/j+vUovouz2JPhnROfF9F2ex J8M6BMrhrR+E
qvWp2GnCytkhH5UdJGmayRc9bUqvRFVFRdqcq3RF225bndo/CVXrU7DTaaeV kjmxwo5rWI5V
Vypz7EREW/J/MRaa+sKiZj2c+iY2JaGnhilRsTtqrA5ifIdt2pbaq/zFZk2W TLba5KOiqWpE
xjVneqOiVHOW7e8dzp5U5C3RZRjqnK3Y111RLKtltyptRFRU5lQknyhRU0zI airp4pX2zWSS
Na519iWRV2mZzOWZzCh3Nqlpa6gXQpT1OlVs6PXSIr7rtbay2va+dyIhHLkq rq2PfUMpYpFS
FiMjermq1kiOVVVWp6URLbOfbs7gEeg4q5JlTLUlVmNlhllZLdaqSNWKiIny ERWv5EXbYkyj
kp9XNXyIkV6ii1Ziu5UW7l27OTan4HWNHyMYrEe9rVeua1FW2ctr2T8FH+Nz 5cisyPNNJK+J
Re: Persist EObject from BPEL20.XSD [message #609650 is a reply to message #95685] Thu, 06 September 2007 10:07 Go to previous message
--------------080401060109030201010901
Hi Martin,
i used your bpel.hbm.xml. Now it works to persist my TProcess-EObject in
the datebase. But if i want to retrieve this object, to update or to
delete it, i get the following error:
0 [main] INFO org.hibernate.tool.hbm2ddl.SchemaUpdate - Running
hbm2ddl schema update
0 [main] INFO org.hibernate.tool.hbm2ddl.SchemaUpdate - fetching
database metadata
3126 [main] INFO org.hibernate.tool.hbm2ddl.SchemaUpdate - updating schema
3205 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tactivity
3205 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, name, tsources_sources_e_id,
ttargets_targets_e_id, suppressjoinfailure]
3205 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkcc4e3f83df98cfbb, fkcc4e3f8397bbcbf4, fkcc4e3f83775bd0f1]
3205 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tactivity_pkey]
3237 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tactivitycontainer
3237 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tvalidate_validate_e_id, tassign_assign_e_id, textensibleelements_e_id,
tif_if_e_id, tthrow_throw_e_id, twait_wait_e_id, e_container,
econtainer_class, texit_exit_e_id, tscope_scope_e_id, tpick_pick_e_id,
textensionactivity_extensionactivity_e_id, treceive_receive_e_id,
tinvoke_invoke_e_id, e_container_featureid, tflow_flow_e_id,
tcompensatescope_compensatescope_e_id, treply_reply_e_id,
tsequence_sequence_e_id, trepeatuntil_repeatuntil_e_id,
trethrow_rethrow_e_id, twhile_while_e_id, tempty_empty_e_id,
tcompensate_compensate_e_id, tforeach_foreach_e_id]
3237 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk275ed05edda276b5, fk275ed05eecb09a54, fk275ed05ebc773fdf,
fk275ed05e9b2eccdb, fk275ed05ef1b7f950, fk275ed05e9613b7a0,
fk275ed05e3aea3f49, fk275ed05eea5c86e6, fk275ed05e9c0ab34d,
fk275ed05eaf7c3bfa, fk275ed05e97bbcbf4, fk275ed05e33facaeb,
fk275ed05e7196e053, fk275ed05ee7d7d5fe, fk275ed05e729f7902,
fk275ed05e2816e85, fk275ed05e74b91116, fk275ed05ec60985c9,
fk275ed05e8844eb0c, fk275ed05e269e02d2, fk275ed05ec8c92a9e,
fk275ed05edccc970]
3237 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tactivitycontainer_pkey]
3283 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tassign_group
3283 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, tassign_group_idx, tassign_group_e_id,
group_textensionassignoperation_extensionassignoperation_e_i d,
group_tcopy_copy_e_id, e_version, fme_feature]
3283 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk9bfe1da37925cf12, fk9bfe1da39bdce2b4, fk9bfe1da34022b516]
3283 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tassign_group_pkey]
3315 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
3315 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tactivity_e_id, e_container, e_container_featureid, econtainer_class,
validate]
3315 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fka4635a636250d1f4]
3315 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tassign_pkey]
3346 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tbooleanexpr
3346 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[texpression_e_id]
3346 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkf27c129992aff94]
3346 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tbooleanexpr_pkey]
3377 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tbranches
3377 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[texpression_e_id, successfulbranchesonly]
3377 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk2d7e9e44992aff94]
3377 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tbranches_pkey]
3408 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcatch
3408 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[faultname, tinvoke_catch_idx, tactivitycontainer_e_id,
tfaulthandlers_catch_idx, tfaulthandlers_catch_e_id, faultvariable,
faultelement, tinvoke_catch_e_id, faultmessagetype]
3408 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkcb9316c72c245058, fkcb9316c75d83a398, fkcb9316c7508dbab4]
3408 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcatch_pkey]
3440 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcompensate
3440 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tactivity_e_id, e_container, e_container_featureid, econtainer_class]
3440 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk4beb38ab6250d1f4]
3440 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcompensate_pkey]
3471 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcompensatescope
3471 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[target, tactivity_e_id, e_container, e_container_featureid,
econtainer_class]
3471 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk28a7b8896250d1f4]
3471 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcompensatescope_pkey]
3502 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcompletioncondition
3502 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tbranches_branches_e_id, textensibleelements_e_id, e_container,
3502 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk554d43cbccdbafcd, fk554d43cb97bbcbf4]
3502 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcompletioncondition_pkey]
3533 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcondition
3533 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[texpression_e_id]
3533 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk7df0af27992aff94]
3533 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcondition_pkey]
3565 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcopy
3565 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tfrom_from_e_id, ignoremissingfromdata, textensibleelements_e_id,
keepsrcelementname, tto_to_e_id, e_container, e_container_featureid,
econtainer_class]
3565 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk69155e9ba4c2a18, fk69155e95854a3e7, fk69155e997bbcbf4]
3565 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcopy_pkey]
3596 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcorrelation
3596 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, set, initiate,
tcorrelations_correlation_e_id, e_container, e_container_featureid,
econtainer_class, tcorrelations_correlation_idx]
3596 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fke235848e97bbcbf4, fke235848e49b4e4d1]
3596 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcorrelation_pkey]
3627 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcorrelations
3627 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, e_container, e_container_featureid,
econtainer_class]
3627 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk647b0da597bbcbf4]
3627 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcorrelations_pkey]
3658 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcorrelationset
3658 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, tcorrelationsets_correlationset_e_id, name,
tcorrelationsets_correlationset_idx, e_container, e_container_featureid,
properties, econtainer_class]
3658 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk31ee451497bbcbf4, fk31ee45147be3cc13]
3658 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcorrelationset_pkey]
3690 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcorrelationsets
3690 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
3690 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkbda5ddf97bbcbf4]
3690 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcorrelationsets_pkey]
3721 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcorrelationswithpattern
3721 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
3721 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk274e594597bbcbf4]
3721 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcorrelationswithpattern_pkey]
3752 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tcorrelationwithpattern
3752 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tcorrelationswithpattern_correlation_e_id, pattern, tcorrelation_e_id,
tcorrelationswithpattern_correlation_idx]
3752 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk943da6bc49545091, fk943da6bcbdc1b8d4]
3752 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tcorrelationwithpattern_pkey]
3783 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tdeadlineexpr
3783 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[texpression_e_id]
3783 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk946e9ac1992aff94]
3783 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tdeadlineexpr_pkey]
3830 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tdocumentation_any
3830 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, fme_mixed_comment, fme_mixed_cdata, any_source, fme_mixed_text,
mixed_tdocumentation_any_e_id, any_lang, e_version,
mixed_tdocumentation_any_idx, fme_feature]
3830 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk556114f399beabff]
3830 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tdocumentation_any_pkey]
3862 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tdocumentation_mixed
3862 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, mixed_lang, fme_mixed_comment, mixed_source, fme_mixed_cdata,
any_tdocumentation_mixed_idx, any_tdocumentation_mixed_e_id,
tdocumentation_mixed_idx, fme_mixed_text, e_version,
tdocumentation_mixed_e_id, fme_feature]
3862 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk8216814288d2a072, fk821681429ddf46d8]
3862 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tdocumentation_mixed_pkey]
3893 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
3893 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[mixed_tfrom_documentation_idx, any_tto_documentation_e_id,
any_textensibleelements_documentation_e_id,
mixed_tfrom_documentation_e_id, e_container,
any_tfrom_documentation_e_id, econtainer_class, e_id, lang,
any_tfrom_documentation_idx, any_tto_documentation_idx,
textensibleelements_documentation_e_id, mixed_tto_documentation_e_id,
source, mixed_tto_documentation_idx,
textensibleelements_documentation_idx, e_container_featureid, e_version,
any_textensibleelements_documentation_idx]
3893 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkb71d3ec69dab47b9, fkb71d3ec640621a79, fkb71d3ec6ee86ac59,
fkb71d3ec697c8ee99, fkb71d3ec663da4499, fkb71d3ec6a7463939]
3893 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tdocumentation_pkey]
3924 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tdurationexpr
3924 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[texpression_e_id]
3924 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fka00a0ffd992aff94]
3924 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tdurationexpr_pkey]
3955 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.telseif
3955 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
tif_if_e_id, tif_elseif_idx, tthrow_throw_e_id, twait_wait_e_id,
e_container, econtainer_class, texit_exit_e_id, tscope_scope_e_id,
tpick_pick_e_id, textensionactivity_extensionactivity_e_id,
treceive_receive_e_id, tinvoke_invoke_e_id, e_container_featureid,
tflow_flow_e_id, tif_elseif_e_id, tcompensatescope_compensatescope_e_id,
treply_reply_e_id, tsequence_sequence_e_id,
trepeatuntil_repeatuntil_e_id, trethrow_rethrow_e_id, twhile_while_e_id,
tempty_empty_e_id, tcompensate_compensate_e_id, tforeach_foreach_e_id,
tbooleanexpr_condition_e_id]
3955 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkaad4098aecb09a54, fkaad4098a74b91116, fkaad4098a9b2eccdb,
fkaad4098ac60985c9, fkaad4098adda276b5, fkaad4098aea5c86e6,
fkaad4098a269e02d2, fkaad4098a97bbcbf4, fkaad4098ac8c92a9e,
fkaad4098a7196e053, fkaad4098a9c0ab34d, fkaad4098ae7d7d5fe,
fkaad4098a9613b7a0, fkaad4098abc773fdf, fkaad4098ab404e6f8,
fkaad4098a3aea3f49, fkaad4098a729f7902, fkaad4098adccc970,
fkaad4098af1b7f950, fkaad4098a8844eb0c, fkaad4098a33facaeb,
fkaad4098a2816e85, fkaad4098a83793a1, fkaad4098aaf7c3bfa]
3955 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[telseif_pkey]
3987 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tempty
3987 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
3987 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkcbb4ad596250d1f4]
3987 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tempty_pkey]
4018 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.teventhandlers
4018 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4018 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fke2fe270f97bbcbf4]
4018 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[teventhandlers_pkey]
4065 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.texit
4065 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4065 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk6925f926250d1f4]
4065 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[texit_pkey]
4096 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.texpression_any
4096 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, fme_mixed_comment, mixed_texpression_any_idx, fme_mixed_cdata,
fme_mixed_text, any_expressionlanguage, mixed_texpression_any_e_id,
4096 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk68d955399b0ed047]
4096 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[texpression_any_pkey]
4127 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.texpression_anyattribute
4127 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, texpression_anyattribute_e_id, mixed_texpression_anyattribute_idx,
mixed_texpression_anyattribute_e_id, texpression_anyattribute_idx,
any_texpression_anyattribute_e_id, any_texpression_anyattribute_idx,
4127 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk42f82583c723fe7d, fk42f825832792c697, fk42f8258330d08735]
4127 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[texpression_anyattribute_pkey]
4159 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.texpression_mixed
4159 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, fme_mixed_comment, fme_mixed_cdata, any_texpression_mixed_idx,
texpression_mixed_idx, any_texpression_mixed_e_id, fme_mixed_text,
texpression_mixed_e_id, e_version, mixed_expressionlanguage, fme_feature]
4159 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk987fc808521ee5f8, fk987fc80822062718]
4159 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[texpression_mixed_pkey]
4191 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
4191 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[e_container, e_container_featureid, expressionlanguage, e_version,
econtainer_class, e_id]
4191 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
4191 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[texpression_pkey]
4222 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.textensibleelements_any
4222 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_any_idx, id, fme_mixed_comment, fme_mixed_cdata,
textensibleelements_any_e_id, fme_mixed_text, e_version, fme_feature]
4222 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk9276229367bd99e7]
4222 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[textensibleelements_any_pkey]
4253 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.textensibleelements_anyattribute
4253 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, textensibleelements_anyattribute_e_id,
any_textensibleelements_anyattribute_idx,
any_textensibleelements_anyattribute_e_id, e_version, fme_feature,
textensibleelements_anyattribute_idx]
4253 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkda43bd692f8d54d1, fkda43bd69b02312eb]
4253 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[textensibleelements_anyattribute_pkey]
4284 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
4284 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[e_version, e_id]
4284 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
4284 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[textensibleelements_pkey]
4316 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.textension
4316 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
mustunderstand, econtainer_class, textensions_extension_idx,
textensions_extension_e_id, namespace]
4316 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk8cc45e4b1c423854, fk8cc45e4b97bbcbf4]
4316 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[textension_pkey]
4347 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.textensionactivity_any
4347 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, fme_mixed_comment, textensionactivity_any_idx, fme_mixed_cdata,
fme_mixed_text, e_version, fme_feature, textensionactivity_any_e_id]
4347 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fke4a4c2876d0e0467]
4347 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[textensionactivity_any_pkey]
4378 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
4378 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[e_container, e_container_featureid, e_version, econtainer_class, e_id]
4378 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
4378 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[textensionactivity_pkey]
4409 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.textensionassignoperation
4409 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4409 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk8a1ad3ad97bbcbf4]
4409 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[textensionassignoperation_pkey]
4441 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.textensions
4441 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4441 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkbc76b8897bbcbf4]
4441 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[textensions_pkey]
4472 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tfaulthandlers
4472 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, tactivitycontainer_catchall_e_id,
4472 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk95a6e69797bbcbf4, fk95a6e697b6630ceb]
4472 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tfaulthandlers_pkey]
4503 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tflow_activity
4503 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[activity_tscope_scope_e_id, activity_trethrow_rethrow_e_id,
fme_feature, id, tflow_activity_e_id, activity_treply_reply_e_id,
activity_textensionactivity_extensionactivity_e_id,
activity_twhile_while_e_id,
activity_tcompensatescope_compensatescope_e_id,
activity_tcompensate_compensate_e_id, activity_twait_wait_e_id,
activity_texit_exit_e_id, activity_trepeatuntil_repeatuntil_e_id,
activity_treceive_receive_e_id, activity_tassign_assign_e_id,
activity_tforeach_foreach_e_id, activity_tpick_pick_e_id,
activity_tthrow_throw_e_id, activity_tsequence_sequence_e_id,
activity_tvalidate_validate_e_id, activity_tif_if_e_id,
activity_tinvoke_invoke_e_id, activity_tempty_empty_e_id,
activity_tflow_flow_e_id, e_version, tflow_activity_idx]
4503 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk5fa3f30cb681542a, fk5fa3f30c567e8a1d, fk5fa3f30ce80d6eca,
fk5fa3f30c9aa22d24, fk5fa3f30c5a4e840, fk5fa3f30cba625b23,
fk5fa3f30c881615bb, fk5fa3f30cca7bd985, fk5fa3f30c1b91d555,
fk5fa3f30ca4d05db6, fk5fa3f30c2d134fd2, fk5fa3f30cdc3e820,
fk5fa3f30c751e4ddc, fk5fa3f30cf55e1619, fk5fa3f30c912d5fe6,
fk5fa3f30c7ab94da2, fk5fa3f30c1194a56e, fk5fa3f30c76eb16af,
fk5fa3f30c3bf320ce, fk5fa3f30cef4a17ab, fk5fa3f30cb21fa670,
fk5fa3f30ce2157499]
4519 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tflow_activity_pkey]
4550 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tflow
4550 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tlinks_links_e_id, tactivity_e_id, e_container, e_container_featureid,
econtainer_class]
4550 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk692a7a2a4e47a, fk692a7a26250d1f4]
4550 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tflow_pkey]
4581 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tforeach
4581 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[countername, parallel, tscope_scope_e_id,
tcompletioncondition_completioncondition_e_id, tactivity_e_id,
e_container, e_container_featureid, texpression_finalcountervalue_e_id,
econtainer_class, texpression_startcountervalue_e_id]
4581 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fke9a3b756cff03b28, fke9a3b756bc773fdf, fke9a3b7566250d1f4,
fke9a3b75696018c54, fke9a3b75638f4edbc]
4581 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tforeach_pkey]
4613 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tfrom_any
4613 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[any_endpointreference, any_property, any_tliteral_literal_e_id,
any_expressionlanguage, fme_mixed_text, any_part, mixed_tfrom_any_e_id,
fme_feature, any_partnerlink, mixed_tfrom_any_idx, id,
any_tquery_query_e_id, fme_mixed_comment, fme_mixed_cdata, any_variable,
e_version]
4613 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fke4d7284b65231871, fke4d7284b6572bdd8, fke4d7284b9ef01207]
4613 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tfrom_any_pkey]
4644 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tfrom_anyattribute
4644 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, any_tfrom_anyattribute_e_id, mixed_tfrom_anyattribute_e_id,
tfrom_anyattribute_idx, mixed_tfrom_anyattribute_idx,
tfrom_anyattribute_e_id, any_tfrom_anyattribute_idx, e_version, fme_feature]
4644 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fka901a6b14c4b3621, fka901a6b14b0aa659, fka901a6b12a2f1afb]
4644 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tfrom_anyattribute_pkey]
4675 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tfrom_mixed
4675 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[mixed_endpointreference, any_tfrom_mixed_idx, any_tfrom_mixed_e_id,
fme_mixed_text, mixed_tliteral_literal_e_id, fme_feature,
tfrom_mixed_idx, tfrom_mixed_e_id, id, mixed_partnerlink,
fme_mixed_comment, mixed_part, fme_mixed_cdata, mixed_variable,
mixed_tquery_query_e_id, e_version, mixed_expressionlanguage,
mixed_property]
4675 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkc551e9afa0b2ff8, fkc551e9aa32347d8, fkc551e9a477e0a27,
fkc551e9a7d01a540]
4675 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tfrom_mixed_pkey]
4706 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tfrom
4706 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[endpointreference, partnerlink, e_container, property,
e_container_featureid, part, expressionlanguage, e_version,
econtainer_class, variable, e_id]
4706 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
4706 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tfrom_pkey]
4738 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tfrompart
4738 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tfromparts_frompart_idx, textensibleelements_e_id, tovariable,
tfromparts_frompart_e_id, e_container, e_container_featureid, part,
econtainer_class]
4738 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fke4dee31197bbcbf4, fke4dee311c40fa8fc]
4738 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tfrompart_pkey]
4769 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tfromparts
4769 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4769 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkb6fd7f8297bbcbf4]
4769 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tfromparts_pkey]
4800 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tif
4800 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tvalidate_validate_e_id, tassign_assign_e_id, tif_if_e_id,
tthrow_throw_e_id, twait_wait_e_id, e_container, econtainer_class,
trethrow_rethrow_e_id, twhile_while_e_id, tactivity_e_id,
tactivitycontainer_else_e_id, tforeach_foreach_e_id,
4800 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk1c0912816e85, fk1c091269e02d2, fk1c091ecdd3c18,
fk1c091dda276b5, fk1c0919b2eccdb, fk1c0916250d1f4, fk1c091c60985c9,
fk1c091e7d7d5fe, fk1c09133facaeb, fk1c091f1b7f950, fk1c091af7c3bfa,
fk1c0918844eb0c, fk1c091b404e6f8, fk1c0917196e053, fk1c091bc773fdf,
fk1c0913aea3f49, fk1c091ea5c86e6, fk1c091ecb09a54, fk1c091729f7902,
fk1c0919c0ab34d, fk1c091c8c92a9e, fk1c0919613b7a0, fk1c091dccc970,
fk1c09174b91116]
4800 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tif_pkey]
4847 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.timport
4847 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, location, importtype, e_container,
e_container_featureid, tprocess_import_idx, econtainer_class,
tprocess_import_e_id, namespace]
4847 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkb1b44d1956120046, fkb1b44d1997bbcbf4]
4847 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[timport_pkey]
4878 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tinvoke
4878 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tcorrelationswithpattern_correlations_e_id, ttoparts_toparts_e_id,
tactivitycontainer_compensationhandler_e_id, operation,
tactivitycontainer_catchall_e_id, tfromparts_fromparts_e_id, porttype,
tactivity_e_id, inputvariable, partnerlink, e_container_featureid,
outputvariable]
4878 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkb1c51dec60a9400e, fkb1c51decdcbc374e, fkb1c51decb6630ceb,
fkb1c51decb6e0161d, fkb1c51decf25c1d63, fkb1c51dec6250d1f4]
4878 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tinvoke_pkey]
4909 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tlink
4909 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, tlinks_link_idx, name, e_container,
e_container_featureid, econtainer_class, tlinks_link_e_id]
4909 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk695566e330b0425, fk695566e97bbcbf4]
4909 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tlink_pkey]
4941 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tlinks
4941 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4941 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkcc1577c597bbcbf4]
4941 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tlinks_pkey]
4972 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tliteral_any
4972 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, fme_mixed_comment, fme_mixed_cdata, mixed_tliteral_any_e_id,
fme_mixed_text, mixed_tliteral_any_idx, e_version, fme_feature]
4972 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fke41dc9687a8d60df]
4972 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tliteral_any_pkey]
5003 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tliteral_mixed
5003 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, fme_mixed_comment, fme_mixed_cdata, tliteral_mixed_idx,
fme_mixed_text, tliteral_mixed_e_id, any_tliteral_mixed_e_id, e_version,
fme_feature, any_tliteral_mixed_idx]
5003 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk5477ec77ea11cbb8, fk5477ec778b04f892]
5003 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tliteral_mixed_pkey]
5034 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
5034 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
5034 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
5034 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tliteral_pkey]
5066 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tmessageexchange
5066 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tmessageexchanges_messageexchange_idx, textensibleelements_e_id, name,
tmessageexchanges_messageexchange_e_id, e_container,
5066 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkd87c2036cb4b5609, fkd87c203697bbcbf4]
5066 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tmessageexchange_pkey]
5097 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tmessageexchanges
5097 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
5097 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk3707e6fd97bbcbf4]
5097 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tmessageexchanges_pkey]
5128 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tonalarmevent
5128 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tdurationexpr_repeatevery_e_id, tscope_scope_e_id,
textensibleelements_e_id, teventhandlers_onalarm_idx,
teventhandlers_onalarm_e_id, tdurationexpr_repeatevery1_e_id,
tdeadlineexpr_until_e_id, tdurationexpr_for_e_id, e_container,
5128 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk2afc387c180835d3, fk2afc387c7fb4f30a, fk2afc387c91083a95,
fk2afc387c2038ad3e, fk2afc387cbc773fdf, fk2afc387ce416e1e1,
fk2afc387c97bbcbf4]
5129 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tonalarmevent_pkey]
5176 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tonalarmpick
5176 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
tinvoke_invoke_e_id, e_container_featureid, tpick_onalarm_e_id,
tflow_flow_e_id, tcompensatescope_compensatescope_e_id,
treply_reply_e_id, tdeadlineexpr_until_e_id, tdurationexpr_for_e_id,
tcompensate_compensate_e_id, tpick_onalarm_idx, tforeach_foreach_e_id]
5176 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkd81d75ff9613b7a0, fkd81d75ff2816e85, fkd81d75fff1b7f950,
fkd81d75ffea5c86e6, fkd81d75ffc60985c9, fkd81d75ff3aea3f49,
fkd81d75ffdda276b5, fkd81d75ff9c0ab34d, fkd81d75ff74b91116,
fkd81d75ff7196e053, fkd81d75ff9b2eccdb, fkd81d75ffe7d7d5fe,
fkd81d75ff729f7902, fkd81d75ffdccc970, fkd81d75ff8844eb0c,
fkd81d75ffc8c92a9e, fkd81d75ff97bbcbf4, fkd81d75ff91083a95,
fkd81d75ff269e02d2, fkd81d75ffecb09a54, fkd81d75ff33facaeb,
fkd81d75ffa772ef81, fkd81d75ff7fb4f30a, fkd81d75ffaf7c3bfa,
fkd81d75ffbc773fdf]
5176 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tonalarmpick_pkey]
5207 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tonevent
5207 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[teventhandlers_onevent_e_id, tonmsgcommon_e_id, element,
tscope_scope_e_id, teventhandlers_onevent_idx, messagetype, e_container,
5207 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkc3578d2761f1a7b4, fkc3578d2757c6af38, fkc3578d27bc773fdf]
5207 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tonevent_pkey]
5239 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tonmessage
5239 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
trethrow_rethrow_e_id, tpick_onmessage_e_id, tonmsgcommon_e_id,
tpick_onmessage_idx, twhile_while_e_id, tempty_empty_e_id,
5239 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkd69fab5461f1a7b4, fkd69fab549c0ab34d, fkd69fab548844eb0c,
fkd69fab54e7d7d5fe, fkd69fab54dccc970, fkd69fab549b2eccdb,
fkd69fab54c8c92a9e, fkd69fab54ea5c86e6, fkd69fab547196e053,
fkd69fab5433facaeb, fkd69fab542816e85, fkd69fab54ecb09a54,
fkd69fab54dda276b5, fkd69fab543aea3f49, fkd69fab5474b91116,
fkd69fab54c60985c9, fkd69fab54269e02d2, fkd69fab5485588d4b,
fkd69fab54729f7902, fkd69fab54bc773fdf, fkd69fab54f1b7f950,
fkd69fab549613b7a0, fkd69fab54af7c3bfa]
5239 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tonmessage_pkey]
5270 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tonmsgcommon
5270 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[messageexchange, operation, textensibleelements_e_id, porttype,
tfromparts_fromparts_e_id, partnerlink, tcorrelations_correlations_e_id,
variable]
5270 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkc66278b997bbcbf4, fkc66278b98dcf990e, fkc66278b9b6e0161d]
5270 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tonmsgcommon_pkey]
5301 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tpartnerlink
5301 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tpartnerlinks_partnerlink_e_id, partnerlinktype, initializepartnerrole,
tpartnerlinks_partnerlink_idx, textensibleelements_e_id, name,
partnerrole, e_container, e_container_featureid, econtainer_class, myrole]
5301 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkb6a2d7ce97bbcbf4, fkb6a2d7ce13cac171]
5301 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tpartnerlink_pkey]
5332 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tpartnerlinks
5332 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
5332 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk1db8226597bbcbf4]
5332 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tpartnerlinks_pkey]
5364 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tpick
5364 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
createinstance]
5364 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk69726956250d1f4]
5364 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tpick_pkey]
5410 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tprocess
5410 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tvalidate_validate_e_id, tvariables_variables_e_id,
tassign_assign_e_id, textensibleelements_e_id, tif_if_e_id,
tthrow_throw_e_id, twait_wait_e_id, teventhandlers_eventhandlers_e_id,
tmessageexchanges_messageexchanges_e_id, texit_exit_e_id,
tfaulthandlers_faulthandlers_e_id, tscope_scope_e_id, tpick_pick_e_id,
textensionactivity_extensionactivity_e_id, name,
textensions_extensions_e_id, treceive_receive_e_id, tinvoke_invoke_e_id,
suppressjoinfailure, expressionlanguage, querylanguage, tflow_flow_e_id,
trethrow_rethrow_e_id, targetnamespace, tpartnerlinks_partnerlinks_e_id,
exitonstandardfault, twhile_while_e_id,
tcorrelationsets_correlationsets_e_id, tempty_empty_e_id,
5410 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkff95737b9b2eccdb, fkff95737b3aea3f49, fkff95737b8daa7cbc,
fkff95737b997bb551, fkff95737bdda276b5, fkff95737b7196e053,
fkff95737b8844eb0c, fkff95737bea5c86e6, fkff95737bf1b7f950,
fkff95737b74b91116, fkff95737b862505ae, fkff95737bc8c92a9e,
fkff95737b729f7902, fkff95737becb09a54, fkff95737b9c0ab34d,
fkff95737b269e02d2, fkff95737bdccc970, fkff95737be7d7d5fe,
fkff95737bc60985c9, fkff95737b33facaeb, fkff95737b85e4c1c8,
fkff95737bada21a46, fkff95737bbc773fdf, fkff95737b9a508780,
fkff95737bbdef8950, fkff95737b97bbcbf4, fkff95737b2816e85,
fkff95737b9613b7a0, fkff95737baf7c3bfa]
5410 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tprocess_pkey]
5442 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tquery_any
5442 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, fme_mixed_comment, fme_mixed_cdata, mixed_tquery_any_e_id,
mixed_tquery_any_idx, fme_mixed_text, any_querylanguage, e_version,
fme_feature]
5442 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk459960016868553f]
5442 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tquery_any_pkey]
5473 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tquery_anyattribute
5473 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[any_tquery_anyattribute_idx, tquery_anyattribute_idx, id,
mixed_tquery_anyattribute_idx, tquery_anyattribute_e_id,
mixed_tquery_anyattribute_e_id, e_version, any_tquery_anyattribute_e_id,
fme_feature]
5473 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk7603bbbbc6a0b20d, fk7603bbbb664c99cd, fk7603bbbb3428ac2d]
5473 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tquery_anyattribute_pkey]
5504 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tquery_mixed
5504 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, fme_mixed_comment, fme_mixed_cdata, mixed_querylanguage,
fme_mixed_text, tquery_mixed_e_id, any_tquery_mixed_e_id,
tquery_mixed_idx, e_version, fme_feature, any_tquery_mixed_idx]
5504 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk456840d0e1d1218, fk456840d0232171b2]
5504 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tquery_mixed_pkey]
5535 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
5535 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
querylanguage, e_id]
5535 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
5535 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tquery_pkey]
5567 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.treceive
5567 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[messageexchange, operation, porttype, tfromparts_fromparts_e_id,
tactivity_e_id, partnerlink, e_container,
tcorrelations_correlations_e_id, e_container_featureid,
econtainer_class, variable, createinstance]
5567 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk528ac7ef6250d1f4, fk528ac7efb6e0161d, fk528ac7ef8dcf990e]
5567 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[treceive_pkey]
5598 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.trepeatuntil
5598 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
5598 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkdcea89afbc773fdf, fkdcea89af9613b7a0, fkdcea89afecb09a54,
fkdcea89af8844eb0c, fkdcea89afe7d7d5fe, fkdcea89aff1b7f950,
fkdcea89af6250d1f4, fkdcea89af74b91116, fkdcea89afaf7c3bfa,
fkdcea89af729f7902, fkdcea89afdda276b5, fkdcea89afdccc970,
fkdcea89afea5c86e6, fkdcea89afc60985c9, fkdcea89afb404e6f8,
fkdcea89af9c0ab34d, fkdcea89af9b2eccdb, fkdcea89af3aea3f49,
fkdcea89af7196e053, fkdcea89afc8c92a9e, fkdcea89af33facaeb,
fkdcea89af269e02d2, fkdcea89af2816e85]
5598 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[trepeatuntil_pkey]
5629 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.treply
5645 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[messageexchange, faultname, operation, ttoparts_toparts_e_id, porttype,
econtainer_class, variable]
5645 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkcc683af68dcf990e, fkcc683af6dcbc374e, fkcc683af66250d1f4]
5645 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[treply_pkey]
5676 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.trethrow
5676 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
5676 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk537bd59f6250d1f4]
5676 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[trethrow_pkey]
5707 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tscope
5707 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
tassign_assign_e_id, tif_if_e_id, tthrow_throw_e_id, twait_wait_e_id,
e_container, teventhandlers_eventhandlers_e_id, econtainer_class,
tfaulthandlers_faulthandlers_e_id, texit_exit_e_id, tscope_scope_e_id,
tflow_flow_e_id, isolated, tcompensatescope_compensatescope_e_id,
tactivitycontainer_terminationhandler_e_id,
tpartnerlinks_partnerlinks_e_id, exitonstandardfault, twhile_while_e_id,
tcorrelationsets_correlationsets_e_id, tactivity_e_id,
tempty_empty_e_id, tcompensate_compensate_e_id, tforeach_foreach_e_id]
5707 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkcc756660dccc970, fkcc7566609b2eccdb, fkcc756660bdef8950,
fkcc756660862505ae, fkcc756660af7c3bfa, fkcc756660ecb09a54,
fkcc7566602816e85, fkcc7566609a508780, fkcc7566606250d1f4,
fkcc75666033facaeb, fkcc756660dda276b5, fkcc7566607196e053,
fkcc756660729f7902, fkcc756660ada21a46, fkcc7566609613b7a0,
fkcc756660c8c92a9e, fkcc75666085e4c1c8, fkcc756660c60985c9,
fkcc756660ea5c86e6, fkcc756660f25c1d63, fkcc756660f1b7f950,
fkcc7566608844eb0c, fkcc756660643a236b, fkcc756660e7d7d5fe,
fkcc7566608daa7cbc, fkcc756660269e02d2, fkcc756660bc773fdf,
fkcc7566603aea3f49, fkcc7566609c0ab34d, fkcc75666074b91116]
5707 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tscope_pkey]
5739 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tsequence_activity
5739 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[activity_tscope_scope_e_id, tsequence_activity_idx,
activity_trethrow_rethrow_e_id, fme_feature, id,
activity_tinvoke_invoke_e_id, tsequence_activity_e_id,
activity_tempty_empty_e_id, activity_tflow_flow_e_id, e_version]
5739 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk314f4bd9567e8a1d, fk314f4bd9912d5fe6, fk314f4bd9ba625b23,
fk314f4bd91194a56e, fk314f4bd9f55e1619, fk314f4bd95a4e840,
fk314f4bd9a4d05db6, fk314f4bd9ef4a17ab, fk314f4bd9881615bb,
fk314f4bd9dc3e820, fk314f4bd97ab94da2, fk314f4bd9e2157499,
fk314f4bd976eb16af, fk314f4bd9b21fa670, fk314f4bd91b91d555,
fk314f4bd9e80d6eca, fk314f4bd93bf320ce, fk314f4bd9ca7bd985,
fk314f4bd92d134fd2, fk314f4bd99aa22d24, fk314f4bd9b5fc9010,
fk314f4bd9751e4ddc]
5739 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tsequence_activity_pkey]
5785 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
5785 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
5785 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk7f72c4356250d1f4]
5785 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tsequence_pkey]
5817 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tsource
5817 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tcondition_transitioncondition_e_id, textensibleelements_e_id,
tsources_source_idx, e_container, e_container_featureid,
tsources_source_e_id, econtainer_class, linkname]
5817 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkc2e3418fbc5fbaa2, fkc2e3418fe2e1adad, fkc2e3418f97bbcbf4]
5817 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tsource_pkey]
5848 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tsources
5848 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
5848 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk9984f0c497bbcbf4]
5848 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tsources_pkey]
5879 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.ttarget
5879 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, ttargets_target_e_id, e_container,
e_container_featureid, ttargets_target_idx, econtainer_class, linkname]
5879 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkc3d14b05bc21d680, fkc3d14b0597bbcbf4]
5879 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[ttarget_pkey]
5910 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.ttargets
5910 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
tcondition_joincondition_e_id, econtainer_class]
5910 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkb658160e6d8bb6c2, fkb658160e97bbcbf4]
5910 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[ttargets_pkey]
5942 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tthrow
5942 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[faultname, faultvariable, tactivity_e_id, e_container,
5942 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkcc85cef26250d1f4]
5942 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tthrow_pkey]
5973 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tto_any
5973 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[mixed_tto_any_e_id, any_property, any_expressionlanguage,
fme_mixed_text, any_part, mixed_tto_any_idx, fme_feature,
any_partnerlink, id, any_tquery_query_e_id, fme_mixed_comment,
fme_mixed_cdata, any_variable, e_version]
5973 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkc48ddb9c6572bdd8, fkc48ddb9cd9f64d67]
5973 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tto_any_pkey]
6004 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tto_anyattribute
6004 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[id, mixed_tto_anyattribute_idx, mixed_tto_anyattribute_e_id,
tto_anyattribute_e_id, any_tto_anyattribute_e_id,
any_tto_anyattribute_idx, e_version, tto_anyattribute_idx, fme_feature]
6004 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkbb611e8097ada71d, fkbb611e804a794b83, fkbb611e8012d999fb]
6004 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tto_anyattribute_pkey]
6035 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tto_mixed
6035 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tto_mixed_e_id, fme_mixed_text, fme_feature, id, any_tto_mixed_e_id,
mixed_partnerlink, any_tto_mixed_idx, mixed_part, fme_mixed_comment,
fme_mixed_cdata, mixed_variable, mixed_tquery_query_e_id, tto_mixed_idx,
e_version, mixed_expressionlanguage, mixed_property]
6035 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkd92c41ab168c6b38, fkd92c41ab2258e398, fkd92c41ab477e0a27]
6035 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tto_mixed_pkey]
6067 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tto
6067 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[partnerlink, e_container, property, e_container_featureid, part,
expressionlanguage, e_version, econtainer_class, variable, e_id]
6067 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
6067 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tto_pkey]
6098 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.ttopart
6098 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, ttoparts_topart_e_id, fromvariable,
ttoparts_topart_idx, e_container, e_container_featureid, part,
econtainer_class]
6098 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkc4959662ab692129, fkc495966297bbcbf4]
6098 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[ttopart_pkey]
6129 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.ttoparts
6129 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
6129 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkce1d365197bbcbf4]
6129 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[ttoparts_pkey]
6161 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tvalidate
6161 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
variables]
6161 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkda4b658a6250d1f4]
6161 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tvalidate_pkey]
6193 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: public.tvariable
6193 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[element, tfrom_from_e_id, tvariables_variable_e_id,
textensibleelements_e_id, tvariables_variable_idx, name, messagetype,
e_container, e_container_featureid, type, econtainer_class]
6193 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fke4871ef05854a3e7, fke4871ef097bbcbf4, fke4871ef04689dadf]
6193 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[tvariable_pkey]
6224 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
f
Re: Persist EObject from BPEL20.XSD [message #609651 is a reply to message #96028] Thu, 06 September 2007 10:16 Go to previous message
Afaics there is a postgresql exception in there:
Caused by: org.postgresql.util.PSQLException: ERROR: target lists can have at most 1664 entries
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorRespons e(QueryExecutorImpl.java:1548)
This seams to be the cause (afaics), can you check the postgresql manual and see what it means.
gr. Martin
Daniel Gerlach wrote:
> Hi Martin,
> database metadata
> schema
> [tactivity_pkey]
> fk275ed05edccc970]
> validate]
> [tassign_pkey]
> [texpression_e_id]
> [tbooleanexpr_pkey]
> [tbranches_pkey]
> [tcatch_pkey]
> [tcompensate_pkey]
> econtainer_class]
> [texpression_e_id]
> [tcondition_pkey]
> found: public.tcopy
> econtainer_class]
> [tcopy_pkey]
> [tcorrelation_pkey]
> econtainer_class]
> econtainer_class]
> econtainer_class]
> [texpression_e_id]
> [texpression_e_id]
> [telseif_pkey]
> [tempty_pkey]
> econtainer_class]
> found: public.texit
> [texit_pkey]
> keys: []
> [texpression_pkey]
> [e_version, e_id]
> keys: []
> [textension_pkey]
> keys: []
> econtainer_class]
> econtainer_class]
> [textensions_pkey]
> fk5fa3f30ce2157499]
> found: public.tflow
> econtainer_class]
> [tflow_pkey]
> [tforeach_pkey]
> e_version]
> [tfrom_any_pkey]
> fme_feature]
> mixed_property]
> fkc551e9a7d01a540]
> [tfrom_mixed_pkey]
> found: public.tfrom
> keys: []
> [tfrom_pkey]
> econtainer_class]
> [tfrompart_pkey]
> econtainer_class]
> [tfromparts_pkey]
> found: public.tif
> fk1c09174b91116]
> [tif_pkey]
> [timport_pkey]
> outputvariable]
> [tinvoke_pkey]
> found: public.tlink
> [tlink_pkey]
> econtainer_class]
> [tlinks_pkey]
> [tliteral_any_pkey]
> keys: []
> [tliteral_pkey]
> econtainer_class]
> fk2afc387c97bbcbf4]
> fkd81d75ffbc773fdf]
> [tonalarmpick_pkey]
> [tonevent_pkey]
> [tonmessage_pkey]
> variable]
> [tonmsgcommon_pkey]
> [tpartnerlink_pkey]
> econtainer_class]
> found: public.tpick
> createinstance]
> [tpick_pkey]
> [tprocess_pkey]
> fme_feature]
> [tquery_any_pkey]
> fme_feature]
> [tquery_mixed_pkey]
> keys: []
> [tquery_pkey]
> [treceive_pkey]
> [trepeatuntil_pkey]
> [treply_pkey]
> [trethrow_pkey]
> [tscope_pkey]
> fk314f4bd9751e4ddc]
> [tsequence_pkey]
> [tsource_pkey]
> econtainer_class]
> [tsources_pkey]
> [ttarget_pkey]
> [ttargets_pkey]
Re: Persist EObject from BPEL20.XSD [message #609654 is a reply to message #96077] Thu, 06 September 2007 12:42 Go to previous message
I looked in the PostgreSQL documentation and i googled around but i
didn't find anything that would help me.
So i changed the database to MySQL 5.0.41 but there is also an error:
[main] ERROR org.hibernate.util.JDBCExceptionReporter - Too many
tables; MySQL can only use 61 tables in a join
So in the query there are too many tables for a join, but how can i
reduce the amount of tables. Is there something i can do?
Perhaps i should go with
BPEL1.1(http://schemas.xmlsoap.org/ws/2003/03/business-process/). The
XSD is a lot easier and think it work out-of-the-box with teneo. I'll
try this tomorrow.
Thanks in advance
Daniel Gerlach
Whole Error-message:
3943 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
3943 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk5fa3f30cb681542a, fk5fa3f30ce80d6eca, fk5fa3f30c567e8a1d,
fk5fa3f30c9aa22d24, fk5fa3f30c5a4e840, fk5fa3f30cca7bd985,
fk5fa3f30cba625b23, fk5fa3f30c881615bb, fk5fa3f30c1b91d555,
fk5fa3f30ca4d05db6, fk5fa3f30cdc3e820, fk5fa3f30c2d134fd2,
fk5fa3f30c7ab94da2, fk5fa3f30c1194a56e, fk5fa3f30c3bf320ce,
fk5fa3f30c76eb16af, fk5fa3f30cef4a17ab, fk5fa3f30ce2157499,
fk5fa3f30cb21fa670]
3943 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
fk5fa3f30c9aa22d24, fk5fa3f30c5a4e840, fk5fa3f30c881615bb,
fk5fa3f30cca7bd985, fk5fa3f30cba625b23, fk5fa3f30c1b91d555,
fk5fa3f30c751e4ddc, fk5fa3f30cf55e1619, fk5fa3f30c912d5fe6, primary,
fk5fa3f30ce2157499]
3957 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tflow
3957 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
3957 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
3957 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk692a7a2a4e47a, primary, fk692a7a26250d1f4]
3968 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tforeach
3969 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
3969 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
3969 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fke9a3b756cff03b28, primary, fke9a3b756bc773fdf, fke9a3b7566250d1f4,
3982 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tfrom_any
3983 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
e_version]
3983 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
3983 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fke4d7284b65231871, fke4d7284b6572bdd8, primary, fke4d7284b9ef01207]
3994 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tfrom_anyattribute
3994 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
3994 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
3994 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fka901a6b14c4b3621, fka901a6b14b0aa659, primary, fka901a6b12a2f1afb]
4006 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tfrom_mixed
4006 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
mixed_property]
4006 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
fkc551e9a7d01a540]
4006 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkc551e9afa0b2ff8, fkc551e9aa32347d8, fkc551e9a477e0a27, primary,
fkc551e9a7d01a540]
4017 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tfrom
4017 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4017 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
4017 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary]
4028 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tfrompart
4028 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4028 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4028 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fke4dee31197bbcbf4, primary, fke4dee311c40fa8fc]
4040 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tfromparts
4040 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4040 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4040 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkb6fd7f8297bbcbf4, primary]
4058 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tif
4058 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4058 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk1c0912816e85, fk1c091ecdd3c18, fk1c091dda276b5,
fk1c091269e02d2, fk1c0919b2eccdb, fk1c0916250d1f4, fk1c091c60985c9,
fk1c091b404e6f8, fk1c0918844eb0c, fk1c0917196e053, fk1c091bc773fdf,
fk1c091c8c92a9e, fk1c0919c0ab34d, fk1c091dccc970, fk1c0919613b7a0,
fk1c09174b91116]
4058 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk1c0912816e85, fk1c091269e02d2, fk1c0916250d1f4, fk1c09133facaeb,
fk1c091af7c3bfa, fk1c0918844eb0c, primary, fk1c091c8c92a9e,
fk1c091dccc970, fk1c09174b91116, fk1c091dda276b5, fk1c091ecdd3c18,
fk1c0919b2eccdb, fk1c091c60985c9, fk1c091e7d7d5fe, fk1c091f1b7f950,
fk1c091b404e6f8, fk1c0917196e053, fk1c0913aea3f49, fk1c091bc773fdf,
fk1c091ea5c86e6, fk1c091ecb09a54, fk1c091729f7902, fk1c0919c0ab34d,
fk1c0919613b7a0]
4071 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.timport
4071 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4071 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4071 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fkb1b44d1956120046, fkb1b44d1997bbcbf4]
4084 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tinvoke
4085 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
outputvariable]
4085 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4085 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkb1c51dec60a9400e, fkb1c51decdcbc374e, fkb1c51decb6630ceb, primary,
4095 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tlink
4095 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4095 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4095 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk695566e330b0425, fk695566e97bbcbf4, primary]
4110 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tlinks
4110 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4110 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4110 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fkcc1577c597bbcbf4]
4123 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tliteral_any
4123 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4123 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4123 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fke41dc9687a8d60df]
4136 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tliteral_mixed
4136 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4136 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4136 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk5477ec77ea11cbb8, primary, fk5477ec778b04f892]
4148 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
4148 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4148 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
4148 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary]
4160 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tmessageexchange
4160 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4160 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4160 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkd87c2036cb4b5609, primary, fkd87c203697bbcbf4]
4172 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tmessageexchanges
4172 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4172 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4172 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fk3707e6fd97bbcbf4]
4187 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tonalarmevent
4187 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4187 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk2afc387c180835d3, fk2afc387c91083a95, fk2afc387c7fb4f30a,
fk2afc387c97bbcbf4]
4187 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk2afc387c180835d3, fk2afc387c91083a95, fk2afc387c7fb4f30a, primary,
fk2afc387c97bbcbf4]
4202 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tonalarmpick
4203 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tvalidate_validate_e_id, tassign_assign_e_id, textensibleelements_e_id,
tif_if_e_id, tthrow_throw_e_id, twait_wait_e_id, e_container,
econtainer_class, texit_exit_e_id, tscope_scope_e_id, tpick_pick_e_id,
textensionactivity_extensionactivity_e_id, treceive_receive_e_id,
tsequence_sequence_e_id, trepeatuntil_repeatuntil_e_id,
trethrow_rethrow_e_id, twhile_while_e_id, tempty_empty_e_id,
4203 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
fkd81d75ffea5c86e6, fkd81d75ff3aea3f49, fkd81d75ffc60985c9,
fkd81d75ffbc773fdf]
4203 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
fkd81d75ff7196e053, fkd81d75ff9b2eccdb, primary, fkd81d75ffe7d7d5fe,
fkd81d75ffbc773fdf]
4215 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tonevent
4215 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4215 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4215 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fkc3578d2761f1a7b4, fkc3578d2757c6af38, fkc3578d27bc773fdf]
4231 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tonmessage
4232 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
tinvoke_invoke_e_id, e_container_featureid, tflow_flow_e_id,
tcompensatescope_compensatescope_e_id, treply_reply_e_id,
4232 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkd69fab5461f1a7b4, fkd69fab54e7d7d5fe, fkd69fab548844eb0c,
fkd69fab549c0ab34d, fkd69fab54dccc970, fkd69fab549b2eccdb,
fkd69fab54ea5c86e6, fkd69fab54c8c92a9e, fkd69fab547196e053,
fkd69fab54dda276b5, fkd69fab543aea3f49, fkd69fab54c60985c9,
fkd69fab5474b91116, fkd69fab54269e02d2, fkd69fab5485588d4b,
fkd69fab54729f7902, fkd69fab54f1b7f950, fkd69fab54bc773fdf,
fkd69fab54af7c3bfa, fkd69fab549613b7a0]
4232 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkd69fab5461f1a7b4, fkd69fab54e7d7d5fe, fkd69fab549c0ab34d,
fkd69fab548844eb0c, fkd69fab54dccc970, fkd69fab549b2eccdb,
fkd69fab54dda276b5, primary, fkd69fab543aea3f49, fkd69fab54c60985c9,
fkd69fab5474b91116, fkd69fab5485588d4b, fkd69fab54269e02d2,
4243 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tonmsgcommon
4243 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
variable]
4244 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4244 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkc66278b997bbcbf4, primary, fkc66278b98dcf990e, fkc66278b9b6e0161d]
4255 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tpartnerlink
4256 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4256 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4256 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkb6a2d7ce97bbcbf4, fkb6a2d7ce13cac171, primary]
4268 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tpartnerlinks
4268 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4268 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4268 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk1db8226597bbcbf4, primary]
4281 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tpick
4281 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tactivity_e_id, e_container, e_container_featureid, econtainer_class,
createinstance]
4281 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4281 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fk69726956250d1f4]
4302 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tprocess
4302 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4302 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
fkff95737b8844eb0c, fkff95737bf1b7f950, fkff95737bea5c86e6,
fkff95737b862505ae, fkff95737b74b91116, fkff95737bc8c92a9e,
fkff95737b85e4c1c8, fkff95737b33facaeb, fkff95737bc60985c9,
4303 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
fkff95737b729f7902, primary, fkff95737b9c0ab34d, fkff95737becb09a54,
fkff95737b33facaeb, fkff95737bc60985c9, fkff95737b85e4c1c8,
4315 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tquery_any
4315 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
fme_feature]
4315 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4315 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk459960016868553f, primary]
4327 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tquery_anyattribute
4327 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
fme_feature]
4327 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4327 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk7603bbbbc6a0b20d, fk7603bbbb664c99cd, primary, fk7603bbbb3428ac2d]
4339 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tquery_mixed
4339 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4339 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4339 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fk456840d0e1d1218, fk456840d0232171b2]
4360 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
4361 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4361 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
4361 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary]
4376 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.treceive
4377 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4377 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4377 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk528ac7ef6250d1f4, fk528ac7efb6e0161d, primary, fk528ac7ef8dcf990e]
4392 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.trepeatuntil
4392 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4393 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
fkdcea89afe7d7d5fe, fkdcea89af8844eb0c, fkdcea89aff1b7f950,
fkdcea89af729f7902, fkdcea89afdda276b5, fkdcea89afea5c86e6,
fkdcea89afdccc970, fkdcea89afc60985c9, fkdcea89afb404e6f8,
4393 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
fkdcea89afc60985c9, fkdcea89afea5c86e6, fkdcea89afb404e6f8,
fkdcea89af9c0ab34d, fkdcea89af9b2eccdb, primary, fkdcea89af3aea3f49,
4404 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.treply
4404 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4404 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4404 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkcc683af68dcf990e, primary, fkcc683af6dcbc374e, fkcc683af66250d1f4]
4415 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.trethrow
4415 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tactivity_e_id, e_container, e_container_featureid, econtainer_class]
4415 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4415 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fk537bd59f6250d1f4]
4433 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tscope
4433 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4433 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
fkcc756660f25c1d63, fkcc756660ea5c86e6, fkcc756660f1b7f950,
fkcc7566608844eb0c, fkcc756660e7d7d5fe, fkcc756660643a236b,
4433 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkcc756660dccc970, fkcc756660bdef8950, fkcc7566609b2eccdb,
fkcc75666033facaeb, fkcc756660dda276b5, primary, fkcc7566607196e053,
fkcc756660ada21a46, fkcc756660729f7902, fkcc7566609613b7a0,
fkcc756660c8c92a9e, fkcc756660c60985c9, fkcc75666085e4c1c8,
4453 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tsequence_activity
4453 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4453 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
fk314f4bd9ef4a17ab, fk314f4bd9881615bb, fk314f4bd9a4d05db6,
fk314f4bd9dc3e820, fk314f4bd9e2157499, fk314f4bd97ab94da2,
fk314f4bd9b21fa670, fk314f4bd976eb16af, fk314f4bd91b91d555,
fk314f4bd9751e4ddc]
4453 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk314f4bd9567e8a1d, fk314f4bd9912d5fe6, fk314f4bd91194a56e,
fk314f4bd9ba625b23, fk314f4bd9f55e1619, fk314f4bd95a4e840,
fk314f4bd9a4d05db6, fk314f4bd9881615bb, fk314f4bd9ef4a17ab,
fk314f4bd9e80d6eca, fk314f4bd93bf320ce, primary, fk314f4bd9ca7bd985,
fk314f4bd9751e4ddc]
4464 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
4464 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4464 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4464 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fk7f72c4356250d1f4]
4475 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tsource
4475 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4475 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4475 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkc2e3418fbc5fbaa2, fkc2e3418fe2e1adad, primary, fkc2e3418f97bbcbf4]
4486 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tsources
4486 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[textensibleelements_e_id, e_container, e_container_featureid,
econtainer_class]
4486 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4486 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fk9984f0c497bbcbf4]
4498 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.ttarget
4499 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4499 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4499 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkc3d14b05bc21d680, fkc3d14b0597bbcbf4, primary]
4511 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.ttargets
4512 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4512 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4512 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fkb658160e6d8bb6c2, fkb658160e97bbcbf4]
4524 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tthrow
4524 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4524 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4524 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkcc85cef26250d1f4, primary]
4536 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tto_any
4536 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4536 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4536 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkc48ddb9c6572bdd8, primary, fkc48ddb9cd9f64d67]
4547 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tto_anyattribute
4547 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4547 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4547 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkbb611e8097ada71d, fkbb611e804a794b83, primary, fkbb611e8012d999fb]
4571 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tto_mixed
4571 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4571 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4571 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkd92c41ab168c6b38, fkd92c41ab2258e398, primary, fkd92c41ab477e0a27]
4585 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tto
4585 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4586 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: []
4586 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary]
4596 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.ttopart
4596 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4596 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4596 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkc4959662ab692129, fkc495966297bbcbf4, primary]
4607 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.ttoparts
4607 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4607 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4607 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkce1d365197bbcbf4, primary]
4619 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tvalidate
4619 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
variables]
4619 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4619 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fkda4b658a6250d1f4, primary]
4634 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tvariable
4635 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
4635 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
4635 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fke4871ef05854a3e7, fke4871ef097bbcbf4, fke4871ef04689dadf, primary]
4648 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.tvariables
4648 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
econtainer_class]
4648 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkac5cbf8397bbcbf4]
4648 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[primary, fkac5cbf8397bbcbf4]
4662 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
found: bpel20.twait
4662 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
[tdeadlineexpr_until_e_id, tactivity_e_id, tdurationexpr_for_e_id,
4662 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fk69a37e96250d1f4, fk69a37e991083a95, fk69a37e97fb4f30a]
4662 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
[fk69a37e96250d1f4, fk69a37e991083a95, primary, fk69a37e97fb4f30a]
found: bpel20.twhile
tempty_empty_e_id, tcompensate_compensate_e_id, tforeach_foreach_e_id,
tbooleanexpr_condition_e_id]
4676 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - foreign
keys: [fkccaff33df1b7f950, fkccaff33d9c0ab34d, fkccaff33d9b2eccdb,
fkccaff33d9613b7a0, fkccaff33d33facaeb, fkccaff33ddda276b5,
fkccaff33dc60985c9, fkccaff33dc8c92a9e, fkccaff33d7196e053,
fkccaff33d729f7902, fkccaff33decb09a54, fkccaff33d3aea3f49,
fkccaff33d8844eb0c, fkccaff33ddccc970, fkccaff33d2816e85,
fkccaff33dea5c86e6, fkccaff33d269e02d2, fkccaff33de7d7d5fe,
fkccaff33daf7c3bfa, fkccaff33dbc773fdf, fkccaff33d74b91116,
fkccaff33db404e6f8, fkccaff33d6250d1f4]
4676 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - indexes:
fkccaff33dc60985c9, fkccaff33d7196e053, fkccaff33dc8c92a9e,
fkccaff33d8844eb0c, primary, fkccaff33ddccc970, fkccaff33d2816e85,
4710 [main] INFO org.hibernate.tool.hbm2ddl.SchemaUpdate - schema
update complete
7734 [main] INFO org.hibernate.transaction.TransactionFactoryFactory -
Using default transaction strategy (direct JDBC transactions)
7736 [main] INFO
org.hibernate.transaction.TransactionManagerLookupFactory - No
TransactionManagerLookup configured (in JTA environment, use of
read-write or transactional second-level cache is not recommended)
7739 [main] INFO org.hibernate.hql.ast.ASTQueryTranslatorFactory -
Using ASTQueryTranslatorFactory
10362 [main] DEBUG org.hibernate.transaction.JDBCTransaction - begin
10362 [main] DEBUG org.hibernate.jdbc.ConnectionManager - opening JDBC
connection
10362 [main] DEBUG org.hibernate.transaction.JDBCTransaction - current
autocommit status: false
10362 [main] DEBUG org.hibernate.jdbc.JDBCContext - after transaction begin
10419 [main] DEBUG org.hibernate.hql.ast.QueryTranslatorImpl - parse()
- HQL: FROM TProcess as proc WHERE proc.name = ?
10430 [main] DEBUG org.hibernate.hql.ast.AST - --- HQL AST ---
\-[QUERY] 'query'
+-[SELECT_FROM] 'SELECT_FROM'
| \-[FROM] 'FROM'
| \-[RANGE] 'RANGE'
| +-[IDENT] 'TProcess'
| \-[ALIAS] 'proc'
\-[WHERE] 'WHERE'
\-[EQ] '='
+-[DOT] '.'
| +-[IDENT] 'proc'
| \-[IDENT] 'name'
\-[PARAM] '?'
10431 [main] DEBUG org.hibernate.hql.ast.ErrorCounter -
throwQueryException() : no errors
10467 [main] DEBUG org.hibernate.hql.antlr.HqlSqlBaseWalker - select <<
begin [level=1, statement=select]
10480 [main] DEBUG org.hibernate.hql.ast.tree.FromElement -
FromClause{level=1} : TProcess (proc) -> tprocess0_
10486 [main] DEBUG org.hibernate.hql.ast.tree.FromReferenceNode -
Resolved : proc -> tprocess0_.`textensibleelements_e_id`
10488 [main] DEBUG org.hibernate.hql.ast.tree.FromElement - handling
property dereference [TProcess (proc) -> name (class)]
10488 [main] DEBUG org.hibernate.hql.ast.tree.DotNode - getDataType() :
name -> org.hibernate.type.StringType@dd725b
10489 [main] DEBUG org.hibernate.hql.ast.tree.FromReferenceNode -
Resolved : proc.name -> tprocess0_.`name`
10490 [main] DEBUG org.hibernate.hql.antlr.HqlSqlBaseWalker - select :
finishing up [level=1, statement=select]
10490 [main] DEBUG org.hibernate.hql.ast.HqlSqlWalker - processQuery()
: ( SELECT ( FromClause{level=1} `tprocess` tprocess0_ ) ( WHERE ( = (
tprocess0_.`name` tprocess0_.`textensibleelements_e_id` name ) ? ) ) )
10496 [main] DEBUG org.hibernate.hql.ast.HqlSqlWalker - Derived SELECT
clause created.
10500 [main] DEBUG org.hibernate.hql.ast.util.JoinProcessor - Using
FROM fragment [`tprocess` tprocess0_ inner join `textensibleelements`
tprocess0_1_ on tprocess0_.`textensibleelements_e_id`=tprocess0_1_.e_id]
10500 [main] DEBUG org.hibernate.hql.antlr.HqlSqlBaseWalker - select >>
end [level=1, statement=select]
10503 [main] DEBUG org.hibernate.hql.ast.AST - --- SQL AST ---
\-[SELECT] QueryNode: 'SELECT' querySpaces
(`tprocess`,`textensibleelements`)
+-[SELECT_CLAUSE] SelectClause: '{derived select clause}'
| +-[SELECT_EXPR] SelectExpressionImpl:
'tprocess0_.`textensibleelements_e_id` as e1_0_'
{FromElement{explicit,not a collection join,not a fetch join,fetch
non-lazy
properties,classAlias=proc,role=null,tableName=`tprocess`,ta bleAlias=tprocess0_,origin=null,colums={,className=TProcess} }}
| \-[SQL_TOKEN] SqlFragment: 'tprocess0_1_.e_version as e2_0_,
tprocess0_.`textensions_extensions_e_id` as textensi2_67_,
tprocess0_.`tpartnerlinks_partnerlinks_e_id` as tpartner3_67_,
tprocess0_.`tmessageexchanges_messageexchanges_e_id` as tmessage4_67_,
tprocess0_.`tvariables_variables_e_id` as tvariables5_67_,
tprocess0_.`tcorrelationsets_correlationsets_e_id` as tcorrela6_67_,
tprocess0_.`tfaulthandlers_faulthandlers_e_id` as tfaultha7_67_,
tprocess0_.`teventhandlers_eventhandlers_e_id` as teventha8_67_,
tprocess0_.`tassign_assign_e_id` as tassign9_67_,
tprocess0_.`tcompensate_compensate_e_id` as tcompen10_67_,
tprocess0_.`tcompensatescope_compensatescope_e_id` as tcompen11_67_,
tprocess0_.`tempty_empty_e_id` as tempty12_67_,
tprocess0_.`texit_exit_e_id` as texit13_67_,
tprocess0_.`textensionactivity_extensionactivity_e_id` as textens14_67_,
tprocess0_.`tflow_flow_e_id` as tflow15_67_,
tprocess0_.`tforeach_foreach_e_id` as tforeach16_67_,
tprocess0_.`tif_if_e_id` as tif17_67_, tprocess0_.`tinvoke_invoke_e_id`
as tinvoke18_67_, tprocess0_.`tpick_pick_e_id` as tpick19_67_,
tprocess0_.`treceive_receive_e_id` as treceive20_67_,
tprocess0_.`trepeatuntil_repeatuntil_e_id` as trepeat21_67_,
tprocess0_.`treply_reply_e_id` as treply22_67_,
tprocess0_.`trethrow_rethrow_e_id` as trethrow23_67_,
tprocess0_.`tscope_scope_e_id` as tscope24_67_,
tprocess0_.`tsequence_sequence_e_id` as tsequence25_67_,
tprocess0_.`tthrow_throw_e_id` as tthrow26_67_,
tprocess0_.`tvalidate_validate_e_id` as tvalidate27_67_,
tprocess0_.`twait_wait_e_id` as twait28_67_,
tprocess0_.`twhile_while_e_id` as twhile29_67_,
tprocess0_.`exitonstandardfault` as exitons30_67_,
tprocess0_.`expressionlanguage` as express31_67_, tprocess0_.`name` as
name32_67_, tprocess0_.`querylanguage` as queryla33_67_,
tprocess0_.`suppressjoinfailure` as suppres34_67_,
tprocess0_.`targetnamespace` as targetn35_67_'
+-[FROM] FromClause: 'FROM' FromClause{level=1,
fromElementCounter=1, fromElements=1, fromElementByClassAlias=[proc],
fromElementByTableAlias=[tprocess0_], fromElementsByPath=[],
collectionJoinFromElementsByPath=[], impliedElements=[]}
| \-[FROM_FRAGMENT] FromElement: '`tprocess` tprocess0_ inner join
`textensibleelements` tprocess0_1_ on
tprocess0_.`textensibleelements_e_id`=tprocess0_1_.e_id'
non-lazy
\-[WHERE] SqlNode: 'WHERE'
\-[EQ] BinaryLogicOperatorNode: '='
+-[DOT] DotNode: 'tprocess0_.`name`'
{propertyName=name,dereferenceType=4,propertyPath=name,path= proc.name,tableAlias=tprocess0_,className=TProcess,classAlia s=proc}
| +-[ALIAS_REF] IdentNode:
'tprocess0_.`textensibleelements_e_id`' {alias=proc, className=TProcess,
tableAlias=tprocess0_}
| \-[IDENT] IdentNode: 'name' {originalText=name}
\-[PARAM] ParameterNode: '?' {ordinal=0,
expectedType=org.hibernate.type.StringType@dd725b}
10504 [main] DEBUG org.hibernate.hql.ast.ErrorCounter -
10514 [main] DEBUG org.hibernate.hql.ast.QueryTranslatorImpl - HQL:
10514 [main] DEBUG org.hibernate.hql.ast.QueryTranslatorImpl - SQL:
select tprocess0_.`textensibleelements_e_id` as e1_0_,
tprocess0_.`targetnamespace` as targetn35_67_ from `tprocess` tprocess0_
inner join `textensibleelements` tprocess0_1_ on
tprocess0_.`textensibleelements_e_id`=tprocess0_1_.e_id where
tprocess0_.`name`=?
10514 [main] DEBUG org.hibernate.hql.ast.ErrorCounter -
10529 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - about to open
PreparedStatement (open PreparedStatements: 0, globally: 0)
10529 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - preparing statement
10541 [main] DEBUG org.hibernate.type.StringType - binding
'loanapproval' to parameter: 1
10568 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - about to open
ResultSet (open ResultSets: 0, globally: 0)
10569 [main] DEBUG org.hibernate.type.LongType - returning '43' as
column: e1_0_
10575 [main] DEBUG org.hibernate.type.IntegerType - returning '0' as
column: e2_0_
10575 [main] DEBUG org.hibernate.type.LongType - returning null as
column: textensi2_67_
10575 [main] DEBUG org.hibernate.type.LongType - returning '1' as
column: tpartner3_67_
column: tmessage4_67_
10575 [main] DEBUG org.hibernate.type.LongType - returning '5' as
column: tvariables5_67_
column: tcorrela6_67_
column: tfaultha7_67_
column: teventha8_67_
column: tassign9_67_
column: tcompen10_67_
column: tcompen11_67_
column: tempty12_67_
column: texit13_67_
column: textens14_67_
10575 [main] DEBUG org.hibernate.type.LongType - returning '16' as
column: tflow15_67_
column: tforeach16_67_
column: tif17_67_
column: tinvoke18_67_
column: tpick19_67_
column: treceive20_67_
column: trepeat21_67_
10576 [main] DEBUG org.hibernate.type.LongType - returning null as
column: treply22_67_
column: trethrow23_67_
column: tscope24_67_
column: tsequence25_67_
column: tthrow26_67_
column: tvalidate27_67_
column: twait28_67_
column: twhile29_67_
10576 [main] DEBUG org.hibernate.type.StringType - returning
'urn:oasis:names:tc:wsbpel:2.0:sublang:xpath1.0' as column: express31_67_
'loanapproval' as column: name32_67_
'urn:oasis:names:tc:wsbpel:2.0:sublang:xpath1.0' as column: queryla33_67_
'http://loanapproval' as column: targetn35_67_
10577 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - about to close
ResultSet (open ResultSets: 1, globally: 1)
PreparedStatement (open PreparedStatements: 1, globally: 1)
10577 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - closing statement
10588 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - about to open
10588 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - preparing statement
10588 [main] DEBUG org.hibernate.type.LongType - binding '1' to
parameter: 1
10600 [main] DEBUG org.hibernate.jdbc.AbstractBatcher - about to open
10601 [main] DEBUG org.hibernate.type.IntegerType - returning '1' as
colum
Re: Persist EObject from BPEL20.XSD [message #609655 is a reply to message #96145] Thu, 06 September 2007 12:51 Go to previous message
You can also try the single table persistence strategy to reduce the number of tables. Although it
depends on the model (everything can end up in one table if there is one single root class).
Another thing you can try: if there is a single root type and all ereferences are pointing to more
specific types (than the root type) then you can 'get rid of' the root type table by setting the
root type as a mappedsuperclass.
gr. Martin
> try this tomorrow.
> Thanks in advance
> Daniel Gerlach
> [activity_tscope_scope_e_id, activity_trethrow_rethrow_e_id,
> fme_feature, id, tflow_activity_e_id, activity_treply_reply_e_id,
> activity_textensionactivity_extensionactivity_e_id,
> activity_twhile_while_e_id,
> activity_tcompensatescope_compensatescope_e_id,
> activity_tcompensate_compensate_e_id, activity_twait_wait_e_id,
> activity_texit_exit_e_id, activity_trepeatuntil_repeatuntil_e_id,
> activity_treceive_receive_e_id, activity_tassign_assign_e_id,
> activity_tforeach_foreach_e_id, activity_tpick_pick_e_id,
> activity_tthrow_throw_e_id, activity_tsequence_sequence_e_id,
> activity_tvalidate_validate_e_id, activity_tif_if_e_id,
> activity_tinvoke_invoke_e_id, activity_tempty_empty_e_id,
> activity_tflow_flow_e_id, e_version, tflow_activity_idx]
> fk5fa3f30cb21fa670]
> fk5fa3f30ca4d05db6, fk5fa3f30c2d134fd2, fk5fa3f30cdc3e820,
> fk5fa3f30c7ab94da2, fk5fa3f30c1194a56e, fk5fa3f30c76eb16af,
> fk5fa3f30c3bf320ce, fk5fa3f30cef4a17ab, fk5fa3f30cb21fa670,
> fk5fa3f30ce2157499]
> found: bpel20.tflow
> [tlinks_links_e_id, tactivity_e_id, e_container, e_container_featureid,
> econtainer_class]
> keys: [fk692a7a2a4e47a, fk692a7a26250d1f4]
> [countername, parallel, tscope_scope_e_id,
> tcompletioncondition_completioncondition_e_id, tactivity_e_id,
> e_container, e_container_featureid, texpression_finalcountervalue_e_id,
> econtainer_class, texpression_startcountervalue_e_id]
> keys: [fke9a3b756cff03b28, fke9a3b756bc773fdf, fke9a3b7566250d1f4,
> fke9a3b75696018c54, fke9a3b75638f4edbc]
> [any_endpointreference, any_property, any_tliteral_literal_e_id,
> any_expressionlanguage, fme_mixed_text, any_part, mixed_tfrom_any_e_id,
> fme_feature, any_partnerlink, mixed_tfrom_any_idx, id,
> any_tquery_query_e_id, fme_mixed_comment, fme_mixed_cdata, any_variable,
> e_version]
> keys: [fke4d7284b65231871, fke4d7284b6572bdd8, fke4d7284b9ef01207]
> [id, any_tfrom_anyattribute_e_id, mixed_tfrom_anyattribute_e_id,
> tfrom_anyattribute_idx, mixed_tfrom_anyattribute_idx,
> tfrom_anyattribute_e_id, any_tfrom_anyattribute_idx, e_version,
> fme_feature]
> keys: [fka901a6b14c4b3621, fka901a6b14b0aa659, fka901a6b12a2f1afb]
> [mixed_endpointreference, any_tfrom_mixed_idx, any_tfrom_mixed_e_id,
> fme_mixed_text, mixed_tliteral_literal_e_id, fme_feature,
> tfrom_mixed_idx, tfrom_mixed_e_id, id, mixed_partnerlink,
> fme_mixed_comment, mixed_part, fme_mixed_cdata, mixed_variable,
> mixed_tquery_query_e_id, e_version, mixed_expressionlanguage,
> mixed_property]
> keys: [fkc551e9afa0b2ff8, fkc551e9aa32347d8, fkc551e9a477e0a27,
> fkc551e9a7d01a540]
> fkc551e9a7d01a540]
> found: bpel20.tfrom
> [endpointreference, partnerlink, e_container, property,
> e_container_featureid, part, expressionlanguage, e_version,
> keys: []
> [primary]
> [tfromparts_frompart_idx, textensibleelements_e_id, tovariable,
> tfromparts_frompart_e_id, e_container, e_container_featureid, part,
> econtainer_class]
> keys: [fke4dee31197bbcbf4, fke4dee311c40fa8fc]
> econtainer_class]
> keys: [fkb6fd7f8297bbcbf4]
> found: bpel20.tif
> [tvalidate_validate_e_id, tassign_assign_e_id, tif_if_e_id,
> tthrow_throw_e_id, twait_wait_e_id, e_container, econtainer_class,
> trethrow_rethrow_e_id, twhile_while_e_id, tactivity_e_id,
> tactivitycontainer_else_e_id, tforeach_foreach_e_id,
> fk1c091e7d7d5fe, fk1c09133facaeb, fk1c091f1b7f950, fk1c091af7c3bfa,
> fk1c0913aea3f49, fk1c091ea5c86e6, fk1c091ecb09a54, fk1c091729f7902,
> fk1c09174b91116]
> fk1c0919613b7a0]
> [textensibleelements_e_id, location, importtype, e_container,
> e_container_featureid, tprocess_import_idx, econtainer_class,
> tprocess_import_e_id, namespace]
> keys: [fkb1b44d1956120046, fkb1b44d1997bbcbf4]
> [tcorrelationswithpattern_correlations_e_id, ttoparts_toparts_e_id,
> tactivitycontainer_compensationhandler_e_id, operation,
> tactivitycontainer_catchall_e_id, tfromparts_fromparts_e_id, porttype,
> tactivity_e_id, inputvariable, partnerlink, e_container_featureid,
> outputvariable]
> keys: [fkb1c51dec60a9400e, fkb1c51decdcbc374e, fkb1c51decb6630ceb,
> fkb1c51decb6e0161d, fkb1c51decf25c1d63, fkb1c51dec6250d1f4]
> found: bpel20.tlink
> [textensibleelements_e_id, tlinks_link_idx, name, e_container,
> e_container_featureid, econtainer_class, tlinks_link_e_id]
> keys: [fk695566e330b0425, fk695566e97bbcbf4]
> econtainer_class]
> keys: [fkcc1577c597bbcbf4]
> [id, fme_mixed_comment, fme_mixed_cdata, mixed_tliteral_any_e_id,
> fme_mixed_text, mixed_tliteral_any_idx, e_version, fme_feature]
> keys: [fke41dc9687a8d60df]
> [id, fme_mixed_comment, fme_mixed_cdata, tliteral_mixed_idx,
> fme_mixed_text, tliteral_mixed_e_id, any_tliteral_mixed_e_id, e_version,
> fme_feature, any_tliteral_mixed_idx]
> keys: [fk5477ec77ea11cbb8, fk5477ec778b04f892]
> [e_container, e_container_featureid, e_version, econtainer_class, e_id]
> keys: []
> [primary]
> [tmessageexchanges_messageexchange_idx, textensibleelements_e_id, name,
> tmessageexchanges_messageexchange_e_id, e_container,
> keys: [fkd87c2036cb4b5609, fkd87c203697bbcbf4]
> econtainer_class]
> keys: [fk3707e6fd97bbcbf4]
> [tdurationexpr_repeatevery_e_id, tscope_scope_e_id,
> textensibleelements_e_id, teventhandlers_onalarm_idx,
> teventhandlers_onalarm_e_id, tdurationexpr_repeatevery1_e_id,
> tdeadlineexpr_until_e_id, tdurationexpr_for_e_id, e_container,
> fk2afc387c2038ad3e, fk2afc387cbc773fdf, fk2afc387ce416e1e1,
> fk2afc387c97bbcbf4]
> fk2afc387c97bbcbf4]
> tinvoke_invoke_e_id, e_container_featureid, tpick_onalarm_e_id,
> tflow_flow_e_id, tcompensatescope_compensatescope_e_id,
> treply_reply_e_id, tdeadlineexpr_until_e_id, tdurationexpr_for_e_id,
> tcompensate_compensate_e_id, tpick_onalarm_idx, tforeach_foreach_e_id]
> keys: [fkd81d75ff9613b7a0, fkd81d75ff2816e85, fkd81d75fff1b7f950,
> fkd81d75ffdda276b5, fkd81d75ff9c0ab34d, fkd81d75ff74b91116,
> fkd81d75ff7196e053, fkd81d75ff9b2eccdb, fkd81d75ffe7d7d5fe,
> fkd81d75ff729f7902, fkd81d75ffdccc970, fkd81d75ff8844eb0c,
> fkd81d75ffc8c92a9e, fkd81d75ff97bbcbf4, fkd81d75ff91083a95,
> fkd81d75ff269e02d2, fkd81d75ffecb09a54, fkd81d75ff33facaeb,
> fkd81d75ffa772ef81, fkd81d75ff7fb4f30a, fkd81d75ffaf7c3bfa,
> fkd81d75ffbc773fdf]
> fkd81d75ffea5c86e6, fkd81d75ffc60985c9, fkd81d75ff3aea3f49,
> fkd81d75ffbc773fdf]
> [teventhandlers_onevent_e_id, tonmsgcommon_e_id, element,
> tscope_scope_e_id, teventhandlers_onevent_idx, messagetype, e_container,
> variable]
> econtainer_class]
> found: bpel20.tpick
> createinstance]
> fme_feature]
> fme_feature]
> keys: []
> [primary]
> tpick_pick_e_id, textensionactivity_extensionactivity_e_id,
> treceive_receive_e_id, tinvoke_invoke_e_id, e_container_featureid,
> treply_reply_e_id, tsequence_sequence_e_id,
> trepeatuntil_repeatuntil_e_id, trethrow_rethrow_e_id,
> fk314f4bd9751e4ddc]
> fk314f4bd9751e4ddc]
> econtainer_class]
> found: bpel20.tto
> keys: []
> [primary]
> econtainer_class]
> econtainer_class]
> variables]
> econtainer_class]
> found: bpel20.twait
> 4675 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - table
> 4675 [main] INFO org.hibernate.tool.hbm2ddl.TableMetadata - columns:
> update complete
> 7736 [main] INFO
> connection
> begin
> \-[QUERY] 'query'
> | \-[FROM] 'FROM'
> | \-[RANGE] 'RANGE'
> | \-[ALIAS] 'proc'
> \-[WHERE] 'WHERE'
> \-[EQ] '='
> +-[DOT] '.'
> | +-[IDENT] 'proc'
> | \-[IDENT] 'name'
> \-[PARAM] '?'
> clause created.
> non-lazy
> non-lazy
> inner join `tex
Re: Persist EObject from BPEL20.XSD [message #609693 is a reply to message #96145] Tue, 11 September 2007 10:58 Go to previous message
I solved the problem with the MySQL problem: (Too many tables; MySQL can
only use 61 tables in a join )
I changed the max_fetch_depth to 0 in the hibernate.properties.
Code:
hibernateProperties.setProperty(Environment.MAX_FETCH_DEPTH, "0");
A 0 disables default outer join fetching. Now it works.
Greetings
Daniel Gerlach
Re: Persist EObject from BPEL20.XSD [message #609694 is a reply to message #96452] Tue, 11 September 2007 12:59 Go to previous message
Hi Daniel,
Thanks for the update on this.
gr. Martin
> Code:
> Greetings
> Daniel Gerlach
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Previous Topic:[EMF Compare] How to get programmatically the number of differences?
Next Topic:[CDO][0.8.0] eResource
Current Time: Tue Jul 22 00:51:40 EDT 2025
Powered by FUDForum. Page generated in 0.20450 seconds
