no .exe file for installing eclipse [message #94746] |
Sun, 14 August 2005 14:54  |
Originally posted by: juan.juan808.freeserve.co.uk
Hi there
I'm a newcomer, both to java and to eclipse but am keen to learn as much
as I can.
I've downloaded the lateste eclipse sdk and never got a .exe file as the
readme file said I should.
What I do have however is a jar file called "startup.jar" (an executable
jar file the description underneath tells me) and also something that
looks like it could / should be a .exe .............it's an icon showing
the eclipse sphere. When I click on it ....it brings an alert box with
loads of details on it. The top line of these details says "JVM
terminated. Exit code = 2".
I'd be grateful for any suggestions as I'm keen to get to know eclipse.
Juan
Re: no .exe file for installing eclipse [message #94761 is a reply to message #94746] |
Sun, 14 August 2005 16:13   |
Originally posted by: weconsul.ptd.net
Juan wrote:
> Hi there
> as I can. I've downloaded the lateste eclipse sdk and never got a .exe
> file as the readme file said I should.
> Thanks
> Juan
Under you Eclipse base directory you should see this in 3.1:
08/14/2005 03:02 AM <DIR> .
08/14/2005 03:02 AM <DIR> ..
08/09/2005 12:47 PM <DIR> configuration
07/28/2005 12:33 PM <DIR> features
07/28/2005 12:33 PM <DIR> plugins
07/27/2005 07:40 PM <DIR> readme
06/27/2005 03:13 PM 59 .eclipseproduct
06/27/2005 03:13 PM 110,592 eclipse.exe
06/27/2005 03:13 PM 25 eclipse.ini
07/07/2005 02:07 AM 15,551 epl-v10.html
07/07/2005 02:07 AM 6,487 notice.html
06/27/2005 03:13 PM 31,420 startup.jar
If you do not see this than it is possible that the Eclipse install zip
was bad. I would try to download another copy and install this after
deleting your currently installed Eclipse..
Also install JDK 1.5.0 before Eclipse.
https://sdlcweb3a.sun.com/ECom/EComActionServlet;jsessionid=F4FA17CDB3EE6094F1A86EC0B390DA47
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA http://weconsultants.servebeer.com
____________________________________________________________ ______________
'If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: no .exe file for installing eclipse [message #94805 is a reply to message #94791] |
Sun, 14 August 2005 19:07   |
Juan wrote:
> IchBin wrote:
>> Juan wrote:
>>> Hi there
>>> much as I can. I've downloaded the lateste eclipse sdk and never got
>>> a .exe file as the readme file said I should.
>>> executable jar file the description underneath tells me) and also
>>> something that looks like it could / should be a .exe
>>> .............it's an icon showing the eclipse sphere. When I click
>>> on it ....it brings an alert box with loads of details on it. The top
>>> line of these details says "JVM terminated. Exit code = 2".
>>> Thanks
>>> Juan
>> zip was bad. I would try to download another copy and install this
>> after deleting your currently installed Eclipse..
> https://sdlcweb3a.sun.com/ECom/EComActionServlet;jsessionid=F4FA17CDB3EE6094F1A86EC0B390DA47Hello
> there
> thanks for the reply..........I definetly don't have the eclipse.exe or
> eclipse.ini as you have listed. I'm imagining then the mirror I
> downloaded it from has a bad copy or something.........
> But I just wanted to check that I would definetly need jdk 1.5 as you
> say.......I'm pretty sure what I have is 1.4..........in other words it
> would definetly make a difference or is just something you would
> recommnend generally?
> thanks again.
> Juan
As a beginner you have no requirements NOT to use the latest JDK.
FUDForum. Page generated in 0.13476 seconds
