Can't see a Form created with VE [message #94738] |
Wed, 22 June 2005 16:39  |
Originally posted by: etchua.uchicago.edu
I create a form that extends JPanel in VE. I didn't type any code. All of
it is using the form designer. Once I save it and go back in, I can't see
the form anymore. Only the source code is available. The design screen is
blank??
Is there a setting I must set up so that I can use the designer again?
Re: Can't see a Form created with VE [message #94753 is a reply to message #94738] |
Wed, 22 June 2005 17:31  |
Originally posted by: myersj.nospam.gmail.com
Eric,
You most likely have a conflict between VE 1.0.1 and the EMF Examples
Plug-in. Please try upgrading to VE 1.0.2.
Hope this helps,
- Jeff
> of it is using the form designer. Once I save it and go back in, I
> can't see the form anymore. Only the source code is available. The
> design screen is blank??
Re: Can't see a Form created with VE [message #608055 is a reply to message #94738] |
Eric,
Hope this helps,
- Jeff
FUDForum. Page generated in 0.54971 seconds
