Home » Language IDEs » Java Development Tools (JDT) » ANT rmic task failing from Eclipse
ANT rmic task failing from Eclipse [message #94636] Thu, 11 September 2003 11:55 Go to next message
Originally posted by: mewing4.csc.com
Hi:
I'm trying to set up a project so that RMI *_Skel and *_Stub files are
generated automatically as part of a build, but I'm having a problem.
My environment is: OS - Win2000, Eclipse v. 2.1.1. I've created a test
project and defined the following build.xml file in it:
<project name="HELLO.makeremote" default="makeremote" basedir=".">
<target name="makeremote" description="Build _Skel and _Stub
files">
<rmic classname="examples.hello.HelloImpl" base="bin"/>
</target>
</project>
I've set this up as a project builder and it is being invoked as
expected, however I get an ant error from the rmic task. Here's the
output to the console
Buildfile: C:\Tools\eclipse\workspace\Hello\build.xml
makeremote:
[rmic] RMI Compiling 1 class to
C:\Tools\eclipse\workspace\Hello\bin
[rmic] BUILD FAILED:
file:C:/Tools/eclipse/workspace/Hello/build.xml:5: Cannot use SUN
rmic, as it is not available. A common solution is to set the
environment variable JAVA_HOME or CLASSPATH.
Total time: 671 milliseconds
My JAVA_HOME and CLASSPATH environment variables look okay to me and
if I invoke ant from the Windows command prompt everything works just
peachy. It only fails when ant is lauched through Eclise.
Can anybody tell me what's going on here?
Mike
Re: ANT rmic task failing from Eclipse [message #94682 is a reply to message #94636] Thu, 11 September 2003 12:18 Go to previous messageGo to next message
Do you have a tools.jar on your Ant runtime classpath?
(Window>Preferences>Ant>Runtime)
Starting eclipse using the -vm arg will allow Eclipse to automatically add
the tools.jar to your Ant runtime classpath.
The JAVA_HOME etc message is coming through from Apache Ant and are a bit of
a red herring.
HTH
Darins
"Ewing, Mike" <mewing4@csc.com> wrote in message
news:bjq5mp$ftj$2@eclipse.org...
> Hi:
> files">
> </target>
> </project>
> makeremote:
> Mike
Re: ANT rmic task failing from Eclipse [message #95237 is a reply to message #94682] Fri, 12 September 2003 10:04 Go to previous messageGo to next message
Many thanks Darins. You nailed it and saved me a ton of time.
Mike
Re: ANT rmic task failing from Eclipse [message #95462 is a reply to message #94636] Sat, 13 September 2003 16:31 Go to previous messageGo to next message
An even better idea would be to use the RMI Plugin which automatically
runs the RMI compiler when needed.
You can download it from http://www.genady.net/rmi/
Genady
Ewing, Mike wrote:
> Hi:
> files">
> </target>
> </project>
> makeremote:
> Mike
Re: ANT rmic task failing from Eclipse [message #95893 is a reply to message #95462] Mon, 15 September 2003 14:40 Go to previous message
"Genady" <eclipse@genady.org> wrote in message
news:3F637EA9.8090108@genady.org...
automatically
> Genady
Thanks Genady. I will check this out.
Mike
Previous Topic:Plug-in needs to load the class which source it's called on, got ClassNotFoundException
Next Topic:Eclipse
Current Time: Mon Jul 21 22:02:18 EDT 2025
Powered by FUDForum. Page generated in 1.08999 seconds
