Home » Archived » M2M (model-to-model transformation) » [ATL] 1:M transformations
[ATL] 1:M transformations [message #94633] Thu, 06 November 2008 10:56 Go to next message
Hi all,
Does anyone know how to create x elements in the target model for one in
the source where x is unknown at development time.
For example, below I want to great x number of T, which is the number of
S-1 and the targetModelElementAttrubutes will be different for each of the
generated TargetModelElements.
rule learningResourceModel2LearningResourceModel{
from
s:S!SourceModelElement
to
t:T!TargetModelElement(
targetModelElementAttribute <- ???
Thanks for your help,
Mark
Re: [ATL] 1:M transformations [message #94650 is a reply to message #94633] Thu, 06 November 2008 20:19 Go to previous messageGo to next message
Hi Mark,
I think you can only do this imperatively with a called rule:
rule learningResourceModel2LearningResourceModel(s:S!SourceModelE lement) {
t <- T!TargetModelElement.newInstance();
for (n = s.lower .. s.upper) {
t.targetModelElementAttribute <- T!????.newInstance();
But not sure about the syntax or the newInstance call. Hope it helps though.
Alfons
"Mark Melia" <mark.melia@gmail.com> schreef in bericht
news:7e8814c4a06b0d2a2b156f660b767a64$1@www.eclipse.org...
> Hi all,
> from s:S!SourceModelElement
> to
> Mark
Re: [ATL] 1:M transformations [message #94663 is a reply to message #94650] Thu, 06 November 2008 20:22 Go to previous messageGo to next message
"Alfons Laarman" <a.w.laarman@student.utwente.nl> schreef in bericht
news:gf053q$6lj$1@build.eclipse.org...
> Hi Mark,
On second thought, a called rule is maybe not needed:
to t:T!TargetModelElement
do {
good luck!
Re: [ATL] 1:M transformations [message #94678 is a reply to message #94633] Fri, 07 November 2008 04:09 Go to previous message
I'm not sure what your mean by S-1. I am guessing you mean
S!SourceModelElement->allInstances()->size()-1
If you like a declarative approach, you can try something like this:
helper def : sourceElements : Sequence(S!SourceModelElement) =
S!SourceModelElement->allInstances()->asSequence();
helper def : sMinusOne : Sequence(S!SourceModelElement) =
thisModule.sourceElements->excluding(thisModule.sourceElements- >last());
to
targetModelElementAttribute <- thisModule.sMinusOne
->collect(se|thisModule.Source2Attribute(se));
lazy rule Source2Attribute {
to
t:T!TargetModelElementAttribute()
Previous Topic:[QVTO] SimpleUML to RDB Example
Next Topic:[QVTO] Help Transforming data types?
Current Time: Sun Jul 27 06:45:14 EDT 2025
Powered by FUDForum. Page generated in 0.03510 seconds
