Home » Eclipse Projects » Equinox » please verify wiki change
please verify wiki change [message #94616] Wed, 08 August 2007 13:08 Go to next message
Originally posted by: jacek.pospychala.pl.ibm.com
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
<title></title>
</head>
Hello!<br>
<br>
There was an outdated FAQ:
<a class="moz-txt-link-freetext" href=" http://wiki.eclipse.org/FAQ_What_is_the_minimal_Eclipse_conf iguration%3F"> http://wiki.eclipse.org/FAQ_What_is_the_minimal_Eclipse_conf iguration%3F</a><br>
<br>
Which stated that: <br>
<i>startup.jar. This file contains a single class used to bootstrap the
platform. Its sole purpose is to find and invoke the plug-in
responsible for starting the platform.</i><br>
<br>
I've updated to:<br>
<i><tt>org.eclipse.equinox.launcher</tt>. This plug-in contains
essential
classes to bootstrap the platform. Its purpose is to launch Eclipse
from command line, webstart or by native launcher.</i><br>
<br>
I hope it's correct, but please let me know if I missed something.<br>
<br>
thanks<br>
<br>
</body>
</html>
Re: please verify wiki change [message #94854 is a reply to message #94616] Tue, 14 August 2007 11:05 Go to previous message
I added the following in addition to the changes you made:
org.eclipse.equinox.launcher.[ws].[os].[arch]. The platform specific fragments
of the org.eclipse.equinox.launcher bundle contain an eclipse native shared
library which is required by the native launcher. This shared library is also
used to display the splash screen. If the native launcher is not being used, and
a splash screen is not required, then this fragment can be excluded.
startup.jar: In Eclipse 3.2 and earlier, the launcher plugin and fragment did
not exist. Instead the startup.jar in the root of the install was responsible
for bootstrapping the platform.
-Andrew
Jacek Pospychala wrote:
> Hello!
> Which stated that:
> /startup.jar. This file contains a single class used to bootstrap the
> platform. Its sole purpose is to find and invoke the plug-in responsible
> for starting the platform./
> I've updated to:
> /org.eclipse.equinox.launcher. This plug-in contains essential classes
> to bootstrap the platform. Its purpose is to launch Eclipse from command
> line, webstart or by native launcher./
> thanks
Previous Topic:Example ant build - Content Provider not set for site?
Next Topic:App server from within RCP
Current Time: Mon Jul 14 23:44:22 EDT 2025
Powered by FUDForum. Page generated in 0.05183 seconds
