Home » Archived » M2M (model-to-model transformation) » [QVTO] Programmatically launch an QVTO transformation
[QVTO] Programmatically launch an QVTO transformation [message #94546] Wed, 05 November 2008 09:06 Go to next message
I had a look at the simpleUml2rmdb example and asked myself whether it is
possible to run a qvto transformation programmatically in headless mode
without having to run any ui stuff.
Hence I tried the QvtLaunchConfigurationDelegateBase.doLaunch() method which
calls hierarchally "QvtOperationalEnv.registerMetamodel(..)". There
" ResourceSetProviderRegistry.getResourceSetResourceSetProvide rPair(cFile) "
is called which tries call PlatformUI.getWorkbench().
thanks in advance
dawid
[QVTO] Programmatically launch an QVTO transformation (reviewed) [message #94574 is a reply to message #94546] Wed, 05 November 2008 10:34 Go to previous messageGo to next message
is called which tries to call PlatformUI.getWorkbench() and throws a
IllegalStateException.
Caused by: java.lang.IllegalStateException: Workbench has not been created
yet.
at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:92)
org.eclipse.m2m.internal.qvt.oml.common.resourcesetprovider. ResourceSetProviderRegistry. <clinit>(ResourceSetProviderRegistry.java:65)
... 36 more
thanks in advance
dawid
Re: [QVTO] Programmatically launch an QVTO transformation (reviewed) [message #94589 is a reply to message #94574] Wed, 05 November 2008 11:08 Go to previous messageGo to next message
Originally posted by: Alexander.Igdalov.borland.com
Hi Dawid,
Unfortunately, QVTO transformations in headless mode are not supported
yet. However, there are plans to do that sooner or later.
Regarding the programmatic launch, there is an API for automatic
transformation execution. See Sergey Boyko's reply to a similiar
question "Re: [QVT] Call QVT from Java code/command line" (6/4/2008).
Best,
Alex.
Dawid wrote:
> which
> created yet.
> at
> ... 36 more
> thanks in advance
> dawid
Re: [QVTO] Programmatically launch an QVTO transformation (reviewed) [message #94604 is a reply to message #94589] Wed, 05 November 2008 11:23 Go to previous message
There are Ant tasks, if that would be helpful.
- Rich
On 11/5/08 11:08 AM, in article gesgen$c4f$1@build.eclipse.org, "Alexander
Igdalov" <Alexander.Igdalov@borland.com> wrote:
> Hi Dawid,
> Best,
> Alex.
> Dawid wrote:
>> which
>> created yet.
>> at
>> erRegistry.<clinit>(ResourceSetProviderRegistry.java:65)
>> ... 36 more
>> thanks in advance
>> dawid
Previous Topic:[ATL] Where can I find a UML metamodel in Ecore?
Next Topic:[QVTO] SimpleUML to RDB Example
Current Time: Mon Jul 21 20:52:50 EDT 2025
Powered by FUDForum. Page generated in 0.04036 seconds
