Home » Archived » Test and Performance Tools Platform (TPTP) » NoClassDefFound while opening ProfileLaunch Configuration Dialog
NoClassDefFound while opening ProfileLaunch Configuration Dialog [message #94510] Thu, 29 March 2007 14:54 Go to next message
Hi there,
after switching to eclipse 3.3 M6 and TPTP 4.4i2 (JDK1.5) i get the
following exception while trying to open ProfileLaunch Configuration Dialog.
Any ideas?
Thomas E.-E.
!ENTRY org.eclipse.jface 4 2 2007-03-29 20:45:38.299
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
java.lang.NoClassDefFoundError
org.eclipse.hyades.trace.ui.internal.launcher.ProfileTab.get Image(ProfileTab.java:142)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.showInstanceTabsFor(LaunchConfigura tionTabGroupViewer.java:816)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.displayInstanceTabs(LaunchConfigura tionTabGroupViewer.java:752)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer$7.run(LaunchConfigurationTabGroupVi ewer.java:642)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.inputChanged(LaunchConfigurationTab GroupViewer.java:660)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.setInput(LaunchConfigurationTabGrou pViewer.java:621)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.handleLaunchConfigurationSelectionChanged( LaunchConfigurationsDialog.java:975)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog$4.selectionChanged(LaunchConfigurationsDia log.java:569)
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:842)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:850)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:45)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:15 3)
org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:840)
org.eclipse.jface.viewers.StructuredViewer.setSelection(Stru cturedViewer.java:1660)
at org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer .java:903)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationView.handleConfigurationAdded(LaunchConfigurationV iew.java:285)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationView.launchConfigurationAdded(LaunchConfigurationV iew.java:260)
org.eclipse.debug.internal.core.LaunchManager$ConfigurationN otifier.run(LaunchManager.java:193)
org.eclipse.debug.internal.core.LaunchManager$ConfigurationN otifier.notify(LaunchManager.java:180)
org.eclipse.debug.internal.core.LaunchManager.launchConfigur ationAdded(LaunchManager.java:1992)
org.eclipse.debug.internal.core.LaunchConfigurationWorkingCo py.writeNewFile(LaunchConfigurationWorkingCopy.java:276)
org.eclipse.debug.internal.core.LaunchConfigurationWorkingCo py.doSave0(LaunchConfigurationWorkingCopy.java:231)
org.eclipse.debug.internal.core.LaunchConfigurationWorkingCo py.doSave(LaunchConfigurationWorkingCopy.java:209)
org.eclipse.debug.internal.ui.launchConfigurations.CreateLau nchConfigurationAction.performAction(CreateLaunchConfigurati onAction.java:79)
org.eclipse.debug.internal.ui.launchConfigurations.AbstractL aunchConfigurationAction$1.run(AbstractLaunchConfigurationAc tion.java:103)
org.eclipse.debug.internal.ui.launchConfigurations.AbstractL aunchConfigurationAction.run(AbstractLaunchConfigurationActi on.java:106)
org.eclipse.ui.actions.BaseSelectionListenerAction.runWithEv ent(BaseSelectionListenerAction.java:168)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3673)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3284)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.open(LaunchConfigurationsDialog.java:1133)
at org.eclipse.debug.ui.DebugUITools$1.run(DebugUITools.java:38 7)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:391)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:333)
org.eclipse.debug.ui.actions.OpenLaunchDialogAction.run(Open LaunchDialogAction.java:81)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2337)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2301)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 76)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:463)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:458)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:101)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:146)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:356)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:171)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 476)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:416)
at org.eclipse.equinox.launcher.Main.run(Main.java:1141)
Re: NoClassDefFound while opening ProfileLaunch Configuration Dialog [message #94541 is a reply to message #94510] Fri, 30 March 2007 03:58 Go to previous message
Previous Topic:Problems with 4.3.1
Next Topic:Agent-2-Agent Communication
Current Time: Fri Jul 18 03:06:27 EDT 2025
Powered by FUDForum. Page generated in 0.08236 seconds
