Home » Eclipse Projects » Remote Application Platform (RAP) » RAP and Common Navigator
Re: RAP and Common Navigator [message #140685 is a reply to message #140663] |
Sun, 19 July 2009 06:48   |
Hi Timo,
Without any guaranties, I think it's doable to create a RAP version of
the Common Navigator plug-in, but I doubt someone here will find the
time do that in the near future.
Maybe you'd like to try this yourself? You'd need to import the source
code into your RAP workspace, change the dependency from org.eclipse.ui
to org.eclipse.rap.ui and comment all compile errors due to unsupported
API. This will be mostly DnD, C&P, and the Help system.
Of course, you're also free to file an enhancement request.
Cheers, Ralf
Timo Schmid wrote:
> do you know why? Is there a problem integrating it, or is it just
> because nobody is interested to do so. I'm very, very interested in
> seeing this feature, beacause i think it's just great.
> Frank Appel schrieb:
>> sorry to say so, but currently there are no plans for providing the
>> Common Navigator Framework in RAP.
>> Ciao
>> Frank
>> -----Ursprüngliche Nachricht-----
>> Von: ilan@razlee.com [mailto:ilan@razlee.com]
>> Bereitgestellt: Montag, 23. Juni 2008 07:53
>> Bereitgestellt in: eclipse.technology.rap
>> Unterhaltung: RAP and Common Navigator
>> Betreff: RAP and Common Navigator
>> Does anybody know if the Common Navigator Framework is planed to be a
>> supported by RAP?
Re: RAP and Common Navigator [message #531357 is a reply to message #140685] |
Tue, 04 May 2010 11:27   |
--------------010303060500080207040605
Content-Type: text/plain; charset=UTF-8; format=flowed
I'm also very interested to use CNF in RAP.
So I started to port org.eclipse.ui.navigator to RAP.
But I have problems and don't know how to get them solved.
I removed all compile error and now I can open the view.
But I can't get it working with navigatorContent.
Can somebody maybe look at this and maybe give me a hint.
I added a little sample project to test it.
Roland
Am 19.07.2009 12:48, schrieb Ralf Sternberg:
> Hi Timo,
> Cheers, Ralf
> Timo Schmid wrote:
>>> Hi,
>>> Ciao
>>> Frank
>>> supported by RAP?
Content-Type: application/octet-stream;
name="rap_cnf_test.zip"
Content-Disposition: attachment;
filename="rap_cnf_test.zip"
UEsDBBQACAAIAJKKpDwAAAAAAAAAAAAAAAAeAAAAZGUudGVjaGphdmEucmNw LmNuZi8uY2xh
c3NwYXRolZBNawIxEIbPFvwPS+7O1kvxsKuUsoUuVIu7epU0Gda06SSdJFL/ vR8oigeht3mH
Zx6Gt5j8/dhsgxyMo1IM4VFkSMppQ10pFu3rYCQm4/5DoawMwcu43ofeJSFF 3mbfhnQplCOR
HZalcNwBKmt8QPjSEaxMpNZ7J9TzavUym7bPb9Nqnt9yhiIySQsaP1MHyZwu kaGJkrRkvXxv
tx7zWm5kUw2G8CTyf7/kNYJyjMD4mwyj/rCpMxTuqQKrs+ow3iFdij7FM3xE jniRX5e4A1BL
BwjOpHS+0AAAAHoBAABQSwMEFAAIAAgAkoqkPAAAAAAAAAAAAAAAABwAAABk ZS50ZWNoamF2
YS5yY3AuY25mLy5wcm9qZWN0vZLPTgMhEMbPmvgOzd4FvfVAt4k2vWlMqg+A w3TLZhkIsI2P
X0BWs9mYeDDe5vuYj9/wR2w/zLA6ow/a0qa5Z3fNCgms0tRtmrfX/e262bY3 18J52yPEHQbw
2sXUndwrQdJgq5BFhFMvz5J5cAzoKHhZyS1gjUGKreBTld26XyiCz9T7qAd1 cAhZVfmYopJU
cSrV+o4hDNoFZL2KDKxPRZqhBNB/j5AS0ndjZoeq+dwQfEH5Fdeloz9J0kcM 8eF/sQc4oZF/
Aq3OdOWJF0ePtftTLPAvw9hpei6LmV6afgrMnocWmanOxK+/MP9pF1BLBwi4 gEd77gAAAKgC
AABQSwMEFAAIAAgAkoqkPAAAAAAAAAAAAAAAADgAAABkZS50ZWNoamF2YS5y Y3AuY25mLy5z
ZXR0aW5ncy9vcmcuZWNsaXBzZS5qZHQuY29yZS5wcmVmc5WOsQrCMBiEd6Hv EHAPbRWLQgfB
xUHo4AvE9loiSf5wSX1+u3S2wnHccB93+4cEdY1UdaOqw+XYLFLd7anqsjwX O/TOxgQdiRFE
6JH0B0xWQlsVO+Gk18p7yLoXYjEfrQOXMGBC0NlwQu6cyaPQt5U+/SZ9dNYs c1vakfJy8Nqk
BOb7gJDtaMEWpHArjTD7f9kkM9ePX1BLBwgPVwLNlgAAAEoBAABQSwMEFAAI AAgAkoqkPAAA
AAAAAAAAAAAAACgAAABkZS50ZWNoamF2YS5yY3AuY25mL01FVEEtSU5GL01B TklGRVNULk1G
dZFBT8JAEIXv/RUbznZCxXgo4aCmHkwgRIwHb8t2qCPb2Tq7bcBfb5tSMALn 9703b2bmmmmD
PsTvKJ4cpyqBcfRYc24xnh/Eo3Y7KAtdYqreWk09LZ7V0tZFTDyoq325dpZM T+UIAc3nl240
iKnA8GbqiQuLoc2cBalxMP4tcarxYAI1Oji5mAXEAYW1hbbJET0lct4ZV1Q6 Vh+6XItr/Jai
V/yuSTDuuVQ5KQCNpcojGCcIUnOgEm+icwl3laDvmvrpup/T9M1nowncQTIe j/75RFdQ0xmd
wASusMC6oaLb5YprWPGwSZ7t0NShBTJuSByXyCFVL+2pVlmcwP2/c7bgsnvS PlVW/+yjbFc5
CfFSm60uLr8Nch109AtQSwcIRFvpnhwBAAAzAgAAUEsDBBQACAAIAJKKpDwA AAAAAAAAAAAA
AAAkAAAAZGUudGVjaGphdmEucmNwLmNuZi9idWlsZC5wcm9wZXJ0aWVzK84v LUpO1dNTsFUo
LkrW5+XKLy0pKC0BCyTnJBYXA4WSMvP0MvOSc0pTUouBwr6uIY66nn5u+jox vFwKqEAPi1hB
Tmk60ISK3BxeLgBQSwcIqCVl8U0AAABvAAAAUEsDBBQACAAIAJKKpDwAAAAA AAAAAAAAAAA+
AAAAZGUudGVjaGphdmEucmNwLmNuZi9jbGFzcy9kZS90ZWNoamF2YS9yY3Av Y25mL2RhdGEv
Q2hpbGQuY2xhc3OFUdlOwkAUPcPSSq2gCC6oLNEoS2ITXzW8kPBEkATD+1BG KCmFlOJ3aaIx
8cEP8KOMtwOCQQiZZHqXc889Z/r1/fEJ4AZZFQGGdEcYnjB7ff7EDdccGabz aHS4x41Kz7I7
KkIMu7Jpc6dr3Lf7wvQYQg4fCIZ4bdFqeq7ldG8ZlBF3hUOgXG0teUNCfPCd 5VhemSGZ/89V
aNGmyrAjNASxoyOCKEMwX2hFQKp0hKEwxGqWI+qTQVu4D7xtS1VDk9st7lp+ PiuGvJ41Zsiu
1yQNkyS1K7y6tJfIF1YZVMe/gAhFjZnbi/xGu1PhJzpUbNFwdzF8Tps2P5bW HE5cU1Qt35Am
9V77cOSINkh/NUCHHkVGtIO+YepEoNG9TVlVIgCt+A69WHpD7EVi9+iOSoY4 QtiniQRFwMEU
TZUEICOfndFJUm/KacicNhVfEXue0ymyeCxp9ClgRsNwOBdUnglSlsRospqm mcwfIcpciDIX
ckQ7VnCllrkuaeJqDZf/VD7XKc5WmEotmyqtNJWWqMwPUEsHCErrwjOQAQAA YAMAAFBLAwQU
AAgACACSiqQ8AAAAAAAAAAAAAAAAPwAAAGRlLnRlY2hqYXZhLnJjcC5jbmYv Y2xhc3MvZGUv
dGVjaGphdmEvcmNwL2NuZi9kYXRhL1BhcmVudC5jbGFzc42UXW/SUBjH/4dC GVDQ4YYbw704
pm1RmkwvTKa7ITPR4DRiuPGqlCN0QiGl8xP4RbzyVhPfYuIuvfDreGvU55x2 DBcmC6Gn55zn
eX7/5yX98fvrEYBtWEnEGNba3Aq40z2wX9mW7wwtx3thte3Atp7YPveCJOIM q2ca1bpur80w
54iV7Bk2ntf/b73DkPEHg2Cvx/sEYMjXpWXP9jrW49YBdwIyUe+6nhvsMizq E9eNwHe9zo7R
ZIjXBm2ehoKshhTSKTBc0JCASmvd9fj+Yb/F/Wd2q8cFYuDYvabtu2IfHcaD rjsiwWfrDUtA
auKe3ef/Ko2kUDIjHtTG6Zf1mfkbzTSJXdZQxArFnHAfhUCGPX2mqHNgGLKN wHZePrKHMmVR
rVUNa1hnSBH2mFaeTRPB1GFkz1z6P6DMO5OZb+rGOVqfJO5T6v6pxkZ9N5qi j4aGJOZIfQgc
D0qyc+y7oBvThibdGBz6Dr/vivZmQulVYYcNCqvQ2MfoRzMi34hBq0o3ND/0 zNDuobQAcmbl
MzRT+QblI3Lvpf1FcS6jzFOMFLLI0xtQCD1odwmQbwtYpHiMbi5HcTtR3GLl OzLM/IDcFyyZ
FYptRhvBUCSjQNHFM44liCGZxwqWUZpgFcesosyG0a3wZholQlMVQftkLOQW lHtvka2Uts1P
uPI6xkqVozd/fp4A84QCtijUdQJukXhDwtZDbypeCCtEsBjtr2KTVoGlz8gv JJhoXJmcQ7Ql
8wcSIrt34/Kp8rAqo2uhQZQKwzWih867UbFUUSD9pPhpeXqLfG5PFEMdF0OF SS0V4ApuTBGi
nxZyZ6qQm9Kq+hdQSwcItUAjknECAAApBQAAUEsDBBQACAAIAJKKpDwAAAAA AAAAAAAAAAA9
Um9vdC5jbGFzc31Ou07DQBCcTRybmEAQPUJUPApWogXRIFFZJAKU/nzekIts X3Q5819USBR8
AB+FuDPU7EqzO6MZ7X59f3wCuMJBhgHhqBL2oldr9arY6Q3rdsmV8oofrfUZ EsKpdS8sujab
rbC2Tth1rTeN8LxWfmldMyvXoj0hvTGt8beE4dn5gpDc2UpyDDGeYISUMC1M Kw9dU4p7VmUt
hMPCalUvlDOR/4mJX5kt4bj497drQv5kO6fl3sTUOIqX0YsThBcQi0KH0wGz wLjnwOjiHTtv
YRkgD5j2Yo7dgJNfQ5h7fXy/d01/AFBLBwibXkdf5AAAADYBAABQSwMEFAAI AAgAkoqkPAAA
AAAAAAAAAAAAAEkAAABkZS50ZWNoamF2YS5yY3AuY25mL2NsYXNzL2RlL3Rl Y2hqYXZhL3Jj
cC9jbmYvaGFuZGxlci9SZW5hbWVIYW5kbGVyLmNsYXNzlVNrTxQxFD2FhYF1 eMhbEQFR3OVV
34+sIVGD0WR9BJTEj7Pdy1IyO7PpdBD/lfoBjCb+AH+U8XZ2QXQ1WfuhvW3P PT29p/3+48s3
ADdw30OXQLFK0pLa3Qv2A2lUQ6poR+4GUTUkIzcpCur0tDnzkGN4bGqSVKgb CUkVG9fV6wxI
5MNKYk2gbAsu0PtAR9quC3QXitsCucdxlfLoRr+PHvQKDJV1RC/SeoXM66AS ksBIOVZBuB0Y
7eatxZzd1YnAcrljpSUBjw5IpZbT1wvlf2veyFA6jjb2KbKlYjkjD4OoJl9W 9khZpspvHChq
OFDiYURgpRO645Q8xjDhYVxg4XRaqo+VJ7Il+o3VoY9JTAmM1sg+To1hSVsU sgomEtj8r4uc
hu7tBIrkvqZ37rxnJ5ylfpzHBQ/TAsO/Lr71PrFU9zGDi2xdnFqB8WZddCxf Gc2irKGgXvIw
JzB5KtHyZu1RqsMqmT5cYheatszlMYvLzvUrzFUo/5lSKm47xFUfBRT53QSN BkVVgdVCux/F
tuzWgSVHsexjBasCfTZubgqMFdpTGCtx3cM1rvVfbubz72ClXsMthVz6HnJV FVjq3AEuqWqz
cLEzW/jNbcWpUfREZ7/it8e95gRjHuwNXOviiL8T9x7PJI+Cx56lI/R9zLbz 3PdmiwM4w73f
BPA4wKPAIIYYNcxxjmdnMxrFsaOfWf6M0eefcO4rZt+OzB9hYeUQi4dYOsSa +HBCP5iBJ5h0
EtP8cNwxc02C1jEuuolbmdYp3MadTPfdjOHeT1BLBwietLVNTQIAAJMEAABQ SwMEFAAIAAgA
koqkPAAAAAAAAAAAAAAAAEoAAABkZS50ZWNoamF2YS5yY3AuY25mL2NsYXNz L2RlL3RlY2hq
YXZhL3JjcC9jbmYvaW50ZXJuYWwvQXBwbGljYXRpb24kMS5jbGFzc41T227T QBA9W7sxTZzW
hARaCrSFUBInrZu+gpCggFQpBURRK/G2sZdkW7O2bKcRv8JfIBEQPPABfBRi 1gmiPEBjaXcu
O2cuZ+QfP799B7CLXQtzDG4gvEz4gxN+xr3Ejz1fvfWkykSieOg9iuNQ+jyT kap3LJgMTh4Y
ctX3XvROhJ9ZKDBU/nhfDZXivVAwFLKBTOs7VKM7a5H7DKUzHtYDmcYhf8+w 0Y2Svif8UMap
8NJR5o1k0BdZ6j2ZhBCirBGjKDntCeUPGFb/wgylt3/8+5GiCw+kktlDBtmY va0Lu/hPyeYR
g7kXBWIBDJdtWLiktSs2FlDUWs1GCXYRBq7ZKGOZwWho0FJXKvF8+K4nktcT RivdyOfhEU+k
tqdOU9PM0J55mnqHaDCSoSpiDRsW1hnWLpjPxm3cYSjKVDuiVAR5k29KuIt7 FjYZVv5JgI2G
xs77IeFoW4cZ908PeDxtv3gYDRNfPJPacM61ua0HIRaeKo2Uqn8gskEUWNhm aMw6q40dTaiZ
ZlHMYO8rJZK9kKepSLFO3Bt05mE4jl4L4FT0UnJJK6HfZI5OGYsUtUTaY7JN klW3NYbjtseo
uFtjMr/g6sc8eoXuYo7SiE1cJ80mnTBYxY3cfxPL03wvSeq3mvsJlc+49QFl 0qpfUWc41gmN
POEiSaBJiV1K0zqXtDZN2sxjWZUuN++jhTZJE1vw0Ml7mlSi7xdQSwcIkxmt aRoCAAABBAAA
UEsDBBQACAAIAJKKpDwAAAAAAAAAAAAAAABIAAAAZGUudGVjaGphdmEucmNw LmNuZi9jbGFz
cy9kZS90ZWNoamF2YS9yY3AvY25mL2ludGVybmFsL0FwcGxpY2F0aW9uLmNs YXNzlVRtVxNH
FH6GbBgJa8EXioEgRiLmBVxFay2xlIioW4MvEGn91DNsRlhdd7e7G8FP/Sv9 CcUPQttz2o89
p7+hP0Vt7yx7SMRzSjg5mTuzc+c+z3Pvnfn7w29/AJjBA44ehmJTGpG0Np6L V8IILN+w3GeG
7UYycIVj1HzfsS0R2Z7LoTEMxm6OcNeNh2vPpRVx9DIUvGDdkJZj+6E05I8t 2/W2DOH7htlx
nqH3pu3a0RxDqlhaZdAWvKbMIIV+HRzHGAbqtisftF6uyaAh1hzJcLLuWcJZ FYGt1slHLdqw
Q4ZyvVvmVYZ0GIkgYqgV691wXfAozFZULdUP6q1mcApDHKcZsp2RWrbxyBHR My94+cTU8TmG
GY5bgRSRvG2HviNeM0wUSx+hh5uRsWk312UUGolTlSPLcKNbZd95wYs16Vob teYrO/SCDM6g
XzHM6RjDWYahPQo1t7ncanszPC4eyqR+QJ5owxoHcaslsw9pnNORx3kGffF7 s/HD8uJKo7bc
YDjVkUWTVKzLgNJYwCTHBYbxQ4jouKiagzdp6YVS4ZR0lBUOj3Ee3qeZtVcx hukjFTiJG5cn
f2hKGDKBjFqBqzqXgZlU45VIWC+WhB83J8dVhsoRCHB8Qflpp6exEXibSZuH keerWt7Q8RVm
KavEpaOEYwe6iUpk7m9X+3ETcxxff9qmbScd36g2zVDcRCFHjS5Wt91XuJLB PBbU7b3NYBe7
v5BHbr4OZaVV1Tt3dNzFPYZj4WvXWtySFsNwsaPPqN1dlceqemn6NttpG/2f 0JSLFa8VWPKO
rSow2EH5kgpNNTBdVwYLjghDGVKz01tG/zS9p8rSK0ZjH60MsoxsuryDzDZN eqDT2Bt/1HE8
HmMHfIYBsoSGE8nhfyhYL9nruzi5NPU7zjzdwcguRufGtJ8x8Abjs+mpt5jI pn95g+L+fFaL
J9qfhKVhBNMUIY/J2KZi9Jl4PEG7pwltiH7D5JfDWbJ5ZMk3R/cqSydGSUAO V+kNUUzLdILY
JEzVrIIp4qpRxGlcIrxB8jRwmXCu0H4OPe+R5yiwf9GPFAfjmKGlstfo3PX9 NP1EOlNkx3fx
Zb3yF7Ttyq+gMijV80/LU5Ud3HqLxe19CSNxYs4T9AQFKVCQCwQ+SRKmY6rn 9sIlVDUSYuLb
OLkDCVVFkODfoY/TFenB/bg4dSyRzZDnfCwR/wFQSwcIu/idtIMDAAAmBwAA UEsDBBQACAAI
AJKKpDwAAAAAAAAAAAAAAABYAAAAZGUudGVjaGphdmEucmNwLmNuZi9jbGFz cy9kZS90ZWNo
amF2YS9yY3AvY25mL2ludGVybmFsL0FwcGxpY2F0aW9uQWN0aW9uQmFyQWR2 aXNvci5jbGFz
c51PTUvDQBScjTHRWO3HwbPe1IKL4qFYKcSCIAQvSu/bzbZ9EnfDJun/8iR4 8Af4o8RNlAoe
CroPhvceb2Zn3j9e3wCcoxfCYxikipdKLh7FUnArcy71jJMuldUi43GeZyRF SUbHssZrYeN0
SYWxIXyGvrFzrmRGeaF4RVz83PPfBIbgijSVI4aLo2QN8XbFHBs9o3lllR0e Txj8sUlVhA1s
t7CJgKGdkFZ31dNU2QcxzRRDLzFSZBNhqZ6/l365oILhMvlv1iFDJFdeGM7+ bN8J3JvKSnVD
taODNZ+d1vZwCOaC1o+5cmkdhm4awXMFBCf9F2w9u85D5DBqth132cWO6/a/ rtDCbqMSYA/t
RqvTcLqfUEsHCMnAkusTAQAACAIAAFBLAwQUAAgACACSiqQ8AAAAAAAAAAAA AAAAWAAAAGRl
LnRlY2hqYXZhLnJjcC5jbmYvY2xhc3MvZGUvdGVjaGphdmEvcmNwL2NuZi9p bnRlcm5hbC9B
cHBsaWNhdGlvbldvcmtiZW5jaEFkdmlzb3IuY2xhc3OdUl1rE0EUPdOkSbNW 28ZYqza2vqUt
7qAoitFCKQiBRYRKi4+T2elm2u3sMtlE8FfpU0HBH+CPEu9+uI1Bgs0+zJ25 c8/Zc+ben7++
/QDwFNt1LDC89BVPlBycibHgVsZcmlOuTaKsESE/iONQS5HoyJxE9ryvjBwc +GM9jGwdVYa9
yAZcyVDHQ8VHmourej4NYKi91kYn+wyVzs4xQ/Uw8pWDChrLWESNYcXTRr0b XfSV/SD6oWJo
epEU4bGwOj0XyWoy0EOGV9680rsMTqpEi1B/JsJnHW+Gj14JP4zMqQ5GVtlu qt+R5ZnhybUp
GDalVSJR5eWJNn70qXyu8D9l5bBJcbNw//5bt447DPvXftG/SBy0cDft5QZ1 Z27x9LIv5sQy
tAOV9PLW5rfvlR3GSiZ6rHo+Q6uz42XuQmECfpRYbYLuEtoMW75y/3h3ybtL 3t34Ck39PopG
Vqq3Oh3C7Rnz5aYceAQadKRflXY04LTW6cQpMoqLu5dY+kqbBTi01rLkCm7Q upwXULxJkeEW
5XPw86yectPAVgZczy8LYLpbxVr2vyZuFxRvSFVa1fiO1se9S6x/maLamKBq lFQNorqXUd3H
g4LqcWGl0tycJmlPGKmURh5mVVu/AVBLBwiHTwJg3AEAAIQEAABQSwMEFAAI AAgAkoqkPAAA
AAAAAAAAAAAAAF4AAABkZS50ZWNoamF2YS5yY3AuY25mL2NsYXNzL2RlL3Rl Y2hqYXZhL3Jj
cC9jbmYvaW50ZXJuYWwvQXBwbGljYXRpb25Xb3JrYmVuY2hXaW5kb3dBZHZp c29yLmNsYXNz
pVPtThNBFD3TlpYuBWz5EFFKAcV+ICMIglaJSELSpEFiSQn+ctkO7ei620y3 kPgUPor+kVQS
H8CHMt5pm1KrqYo7yc5Hzjn3zpl7v33/8hXAKjZD8DFslQT3hFV5Y56aXFlV bjknXDqeUI5p
8+1q1ZaW6UnXOXTV22PhWJVD6ZTcs+3Sqay5KoQAw4qrylxYtqzWBK9Lbl6y +O9pDMEn0pHe
FsPjZL4PPdfD33GdE1muK6GyqSJDYMctCQN+hCMYQJBhNC8dsVd/dyzUgXls C4ZY3rVMu2gq
qfftw4BXkTWGZ/n/u32WwbA6GTFsXPEqDJOWEqYnti0NfW6qjk+v+9vTIXQb 04/RGyEbwhjD
5t/60Es3EMOE9n6SYe0KqdIbrvwzi2G4qkTLxRdV4TD4k6miAYabEdzCDMNY WXi9LjM8Sva1
ps8DhTDLEO/m1s48XlZmtSKtGt93ySsDccxpK+YZBpK5XKo4hNtYDOEOw/qV wkZwF0mGkZrw
ctQs0rQL8j1V78LPRv+aSrYVOx1BBkstgUJFK7s2OUnln3zVQixHwDUi2kYU PNOr13QPDWKF
bHy5s5/Y2dtNdFWApj2IYA3rDINEO5Ce7qiJZL5ZPLbplHnBU9IpN1/XKLh1 ZYldqUGLf+yo
ZS2COXpKP/TnpxU1Nv1DtNuCjwYQTGfOMfiJVj4Y9Deap2OEHMcQrSZbKEQw 3FQJYgSjpMFw
DdG21lPS1qjwBWJHJDf+sSOnwwFTXVLhjlSYpK43paZwoy11RoE1iqc/Yzqf uUD8KMo+RNnS
ORINLPiQ8TeQoinQwD2aYvcbWPXhMv9pCgnMkEycZGdpJLBILixjvisJ3k5i AOnOfR42NTZ+
AFBLBwiulX8xiQIAANUFAABQSwMEFAAIAAgAkoqkPAAAAAAAAAAAAAAAAEkA AABkZS50ZWNo
amF2YS5yY3AuY25mL2NsYXNzL2RlL3RlY2hqYXZhL3JjcC9jbmYvaW50ZXJu YWwvQ05GQWN0
aXZhdG9yLmNsYXNzlZJdTxNBFIbf6SddFxCwIKIWEEg/YjeRS4wJFmuaNA0J 0lsz3U6X0WV3
MzuL/Cw/Lki88Af4o4xnphWMF6g3O+ecOfOc9z3Z7z++fgPwDHtl5BgaY+Fp 4Z+94xfcU37i
+dHEk5EWKuKh1xl0D30tL7iOVRkFhr1YBZ7wQ5mkwsukl4RZICPvcJRqxX19 2ju2BYbKcf/0
dW/wtnfEsNy39JBHgXeilYyCA4b5Thylmkd6yMNMzKHCsDIW7V9a2qSlTVoY SskM2er/s1bi
l57LSOoXDPl6Y8hQ6MRj4SCPuy5czDMs9mUkBtn5SKg3fBQKIzP2eTjkSpp8 VizoM5kyFEmq
0gy79b7ZQJwG0psofi4+xOq99zKLxqEgQ1pc6gMzznl16YtES/JYxn2ydrOB 6xuj5oGLe6hW
wPDQhYM7DGV/imHY/vso0pfqODGkLRc1VGlyIPSRmPAsJMTTeuO/luacxJny RVca60u/X7bN
e2yR0Dz9PTmso4gSZWWbzZF2Uk9xgWq0X/ouULZPJ6Oz2LzC4ifbukRfh06g Ss1rWKbInTZh
xSKYWQl1rM5waxbVpYp55TRbV1hvfsHGDW/BiqoRYRMVEmmYq9PuGdNEj/DY yqndRmcENhM2
/6Q3qLtJ9Nat9Aq28WRmfse6oimfsfHxmlay1X1LyVm3Ozba/QlQSwcIVYzC dAACAACZAwAA
UEsDBBQACAAIAJKKpDwAAAAAAAAAAAAAAABOAAAAZGUudGVjaGphdmEucmNw LmNuZi9jbGFz
cy9kZS90ZWNoamF2YS9yY3AvY25mL3BvcHVwL2FjdGlvbnMvRGVsZXRlQWN0 aW9uLmNsYXNz
lVRbUxRHGD0NKwPLoHjFoIGVi+6uwCDESwLihYtuXBFdC0vfmtl2t3F3Zmqm B8v8k/iUqvwC
UwmWWmWZlzz4o1L5umdcEBDNw0x/fTnnfJfu7+O/b98DmMJDC20ME1XhKOHW 1/kGd0I3cFzv
qRP4QRw43FXS9yJnQTSEEjfMzEKGodccbnCv5txbWxeustDBMOKHNUe4DRlE womlU0r2Epzm
qHElGDJVrjhDrryXsN5z5uuyUZ1h6JiVnlRzDO35wioB5/2qyKIdPTa6kGU4 VJaeWI6bayJ8
yNcaxH2k7Lu8scpDqefpYkbVZcQwuafglyMlB3oiYdzfECs8VAwL+fL2GNef clekWKeUoso7
s/DID5+tCc+ta44ZHUhHAmEY+jodQ1bxsCZU4sHgV+gpV2FMzKPf4GlhtQsM p2xY6OzC9xi0
MPBZbSsvIiWaNnI4Q7x+TPrHy2Zb+s5KKD1VUaHgzRkLwwx924CKNms3Yyqj CDsxSkEkmc35
Xi6LIZzTFcwTXb68E0VuZVHEmIXzDAP73xEb45hgsCg9y7xJpT6WL+wm1IKT Ni5gSqc+CIRX
ZRjfS3nXUhqCofjBxkWt1qn8ZDOLy/jRwhWGo3skxcZPOkIr0EsNKklPRXH3 2V0epNeyN6KU
mErM10lRkFN3/u/9Sk5sSPFchJFTqnxipCR24xpuWLi+411+CWHjJubJXRkt NgP1wry5JxYW
qUHsB1dh7Ko4FNUWUTcWcMvGbZTo5UXyF2GoSnr5jo0y7tK7pXotyTBSiw3R FJ7aWbekb9Bd
7mqliOHstwVOVy2qbKEm90Xt9l7jK34cumJJ6iId3t4RJrSLOEOPpp2+A/S1 6bdDzTRDNrUk
+nfTbJpGRuOB4mvYr8how0H6Z2kETtDhPhwiy04OoReHaaTmhaMpwTX62vXa FrjDHB4wwFyy
mQK1dQzHzT4j+j5CMJzEdymZJEEtPFL8E/3/YPAPnH6HocdHRl7jrF7aRGET ziamN3HplRHW
egeNxijFdw7DKBjdEwlPS3ck1Z0xKDZM5iyuprK/0+EMjXNjb0At/CUuj33A wvL4GyzRxfgN
ebJ+ZvgbxV9xepvdW0wmH1D8C/1bDvVTCoBJSvMUzadJ/BLNrpDerHGumKi1 nJtrJWUOy7hn
0uhgBfeJL3VYu/rAZLjyH1BLBwiI6Zf0cAMAABUHAABQSwMEFAAIAAgAkoqk PAAAAAAAAAAA
AAAAAF4AAABkZS50ZWNoamF2YS5yY3AuY25mL2NsYXNzL2RlL3RlY2hqYXZh L3JjcC9jbmYv
cHJvdmlkZXIvQ05GQWN0aW9uUHJvdmlkZXIkT3BlbkNoaWxkQWN0aW9uLmNs YXNzlVVbbxNH
FP4mdlnbWWjiEKC3xEAAx0m8Kb2CIQHcBFycSzFNCi206/XgTFjvrvYSlD7x N+hTpb7yQtUE
pZUq+sIDvwkhzoxNGuw0jWXJnjlzLt/3zZnjF6/+/BvAWVgaehimatwIubWy aq6Zhm95huXc
MzzfXRM17hvF+dnLVihcZ7FlGVnwuFNcEXatadcQZxh2/brBLVt4ATdW75kW N0x1ajSdGBJv
MjLky53ea4I/4H5glCrc5m/VKzDEa2ZoMmTKuyGVZ4bCQ54HwhURjEwyTO7q +9+sZOwF4Yhw
iuFhttvgtwhFwigtu/79KneslUWzzgvd8R1dIsZFt8aTYHhXRxKpBPoZklL4 jAh5I4UYBnT0
4jDDYLasUNqmUzcqoS+cOmWQoUd0vIMDlKIsHD4fNarcv2lWbc6QLruWaS+Z vpD7ljEupWO4
1CX39nYgIQ8+2MmemuN/5GHoD9pVYIj5EbVNLNskc1yHhkQSJ3FKwwhD3w7S 6wFpouM0zpC/
G4UkSlMT4RqLJEhIsnCzUdAwynC0Xa0rEWHnfgJjDNqNyMm4TiaFLAZSyGNS g8EwtHff6fgY
Zym4zsN5s0GED2dHOy9F5vxUx2f4nFrN9Ei1GsPEbrfXYWpBVCm+1HFOVkuE bvMwhQIuarjA
MLALaR1Tsks0T5psR3bOJR1DGKZrqoSmdX/O9FoNkBTBjCOXNSX77V7M4KqG WYbxbvpXxzWU
GHRSY/uMIUuS7CdLoRfXMaehzDCyH38d8ygSP8Le8MJ1DYs0X/YKDP3ICiOf 17ZT9GIBN3RU
cJMeQSB+5op+SZqXdCzjO3pCRGZW+EE4Y/MGd8L2K16orlIuauRk8C/l0/sj zJAKdgg1uWdU
J3oZX3Ej3+KzQt7ikY4Xmpc46UJKjsP9om0GAQ80kCXf3UsnGdreOjL0MmP0 VxJDj5w1tOqR
zxTo65NjS50wmlM6fR+k3TKdx+m3Pze2gUO5dN9TpHMTGxh8okKP0vchlfAu pfuBAu/gGO0y
ytaP9/A+oFYf4EPyl6uPqKwsQi3dKlKnEox+s7k/kHmO4d9x4i9kb6VzTzEu TZuY2MQnm/hi
E+fJNv1EwZS10wocJwp1GjQCZ7Cq6uvNfK36l5u0TpLxCoqtor8RHAlymioM buErhvLYFr5m
+AUTY8+wMDe+hW+ov37FEK2+ZfgH+UdEvrl5hvwGMvHHscfbWIYIBeCSiB4G 4BOOgOZRRI99
DRexvkOX6RauFM2WW7hNgI7hFL4n/XoU1gTYSzkhrtP+jtL5Ln5U/ow+P6EK vAZQSwcIca68
fssDAAASCAAAUEsDBBQACAAIAJKKpDwAAAAAAAAAAAAAAABOAAAAZGUudGVj aGphdmEucmNw
LmNuZi9jbGFzcy9kZS90ZWNoamF2YS9yY3AvY25mL3Byb3ZpZGVyL0NORkFj dGlvblByb3Zp
ZGVyLmNsYXNzpVXfUxtVFP5ukmYhWUCxBorUFi0lCZDFUiw2FSkp0NiEosHU dny5bC5h281u
ZneT9tG/wbf+Gc6oDDrj1Ff/Jsfx3Js0pYQfSX1I9u7dc77vO+eec+7f//7+ J4AbeKIhxJCp
CCMQ5v5T3uSGZ9YN09kz6p7btCrCM3JbG3fNwHKd7faOhgjDvOtVDWHaVt0X RsMyHN60qjxw
yd6t1VznbReGmFsX7U2G1UJ/jNceknNu37Irrf0sQ/SO5VjBCkM4mSozRHJu RcQQRlyHhgGG
kYLliK1GbVd4O3zXFgyjBdfkdpl7lnxvb0aCfctnWOhTEAmISH6G5WTh1Ezk j6Zi/UUgHJ8W
JSsQ2VQ5jg/woYaLDIvvAKAjgTGGeFUEZUs8l1t0jsnUuWKktfCUBg2XeiBv OTxyvWe7wjH3
paeGjxhW/t8RxjGOyzo+xhUGjaLY5lWKYKo7gnyHWppkpd+Ujk/wKcNF8isJ WxwrtYVjIE/3
uCmMporDN/JdHtkYJjAt6+Y6w4/JfkvhHMH9SUmVB8GQ1HEBUaoxX53r0juV GMNAs1Mac/0U
BsPQ86Pn3YuCE8pE4pQCbj4r8rpqNw2fMaR7F8Kge8KnT4Jg5OtkV7Pli6Im nMClxMnuX9Jp
qC1SRdVa2wyXTvVgGPR5swUtfW/rWJa+w3uWbbcSusY9Gg5XulnffFbEE1jR 8RVWCdLy1x0Z
a0VNpicDWGO4TO6ZtnumYWU6IWdkU8RxDxsa1hkmTqfRsYn7DAlfBJu2u8vb Au9zp2LLmr+V
LKh6tblTNUqBZznVkyqPK6/XwFk5OWP8SKiTZ0VKQ1WmJuc6gXgRFIXToNNM nsEiTYrcoS6Q
hT2ALWKrem6jnnFV3Nv4VsM3DNM9QegoyRQM8To5V3bcTYlEPVJTQmZ61EES Sm7DM8WGJed/
oqufMzKPVHl5xxFezua+LygxI8fGF6aoTcN0hzKEZK/SKkprunrof5DeFunJ 6HkhfYDYz7QI
Qaf/GD1BUy9CAEO00ltGGMaIAnsP77cBfiLACD3nZg8xylCc+wvjL3F17hXG t9J/YOJxev4Q
k3QRH+IqwwGu/YoZyRNWPAnCBK6ToBnCTtFdk8Ys5hRnuoXb5pSrFO1J8dPK JkTW45hHhrAM
+k4h/YNZDQtkc0MFJvWtkJ2MJZqePcDN4xHeJP4lxZZoWXXYovgct1Rylk/G +uI41m3Cyp6D
lcWdNtYPpFpajaV/wcxv+PIlRmZH78qXQ+TCeJOiYXV+q0SyRsD3jhCMdQjG kMfXBGwoL5ag
5QMUzmIqtpgedjPliekBMRRPYdrBd0eZQiirPDzC9yoTNB7o9xj4D1BLBwgx XUxF6wMAAL0J
AABQSwMEFAAIAAgAkoqkPAAAAAAAAAAAAAAAAE8AAABkZS50ZWNoamF2YS5y Y3AuY25mL2Ns
YXNzL2RlL3RlY2hqYXZhL3JjcC9jbmYvcHJvdmlkZXIvQ05GQ29udGVudFBy b3ZpZGVyLmNs
YXNzhVTLUhtHFD2NBo0Qw0u8YgO2BI7QIzDBdhwTsB1QgCgRDyNCjElCBqkN Q2RJNRK4Kpt4
4R/IJlX2zitvvMB5iKpQdiWrVOUP8impyut2zzAoQgaqRPd038e559zbv//z 8ysAl5FV0cCg
Z7le5pntHWPP0K1MUc/k7+lFq7BnZrmlJxZmE4V8mefLS86RCoWhXVrnjPyW vri5wzNlFV6G
0YK1pfNMziyWuL5zz8hwfc/kD7hV0pMrFuc1kRiaZ+aXVtY2ppaXp9YYOtdT tWEnGNSiYZFT
iWFwPVUPa9YoG/qSNCJz3yTlz5vlmwyeSHSVQUkUsrwJDG0aVPhoTZl5vrB7 f5NbK8ZmjjME
UoWMkVs1LFN8O4feSRnGDw+6NASgUajytkk4xurCOIUygtW8xcuJbTOXJZgM w5GTlUbrVK/i
PMPAa4teLhTKorJ+DU3w+2l3QcNFBBk6BHbTyJlf86Uj+rrrJV1VMchw8Qxe /QjhkoZevMkw
FImeooOskXAPE5bTjRhabGVncvw+LUKGOvK3pMtG5qt5o+jI0kRE2qAYwvUq OnnkRxijGuLQ
Jfozm0hUO6bRgFyh7qN0gmaGrkid0GTAj+A3bxulY4nrsn3XbgSn4pJQbFzQ +gaDZuaLu8dc
qFmzVCyU+NFFYpvicCItGUm9fspW5TpxMnM95anFbT+arLNj0mQVctmkwELb PH8gtyoSDL3H
wdNly8xvTe8SC9zyYYYKsUkN+jGNOTFHH9ZwY7sQHmHxkYaPkSJkRrHI81Ru fyQZPWHsxJ8Q
HgsaFrFEkMoF+7JWKSe+EHVO/EtrWBEjopZsZX0QTEjhgqJTpNGahrtYJ7VK 1WN7KXJm5wta
mUm/JEHKuJ6hMx3JZUfFBoM/Xdi1MnzWFN3ee/IxGRURCCK9b/RrRAPOi3eN XvQG8QrQ2kRf
zdDotoW+3qJV/Pk8L+H5Aa0vpGU7/ffTClJERRs65CnINuB66rQK38bYATqP 3bzy0HbRbAN0
o0c6Uys7zt+RtQh4Lf4rzj1GV+xH9P0GXyx+gAGx36fz0GM0x39BqIIh8Rl+ DPV7tO6LH3l6
ZLYwlQOKq+IcWtGHTgxQjgvimcMw0TCKIZrUsETTY2d00IhdBFHCE5OolU6l VUxcXFIiMOZp
FR5BO7nAEq5g5P/Q3t5nx2h6qFZBqUp524igHowRlitV2YNu9iCuutkVNLS1 0v4dwmTnXnRy
BwQ/T6CJnE/Q6HmuPHez2Uxfr4oecKMHqqJTI7TT9l2X/Pcc8r2xeAXX92uk u1EV0OsG9JJX
VCo+4XbAVbJhMg77CX21nTNNZCSq2sDrtsEk5bAjJGXxdFbbP3PSMWZfuiAY buKWvGd4n+DY
LTlFOw/theYyLOsgBYQSD2PelwgRNs+NZ8iJvuo/RGjtENNrgQ8OMNtfQbKC +QPcTsvLy8TH
MrmEFzzXlGcIj3Qrhwjb9p849t3KkdOn6UcK61ZGXj399w/bfaSCO48aWL/4 otNvX7hajdLI
AQs0eouE8DZVtkz0pTFOr80trGKDVhN3UKL7b+hx6ZD0yhrc6h86/erHLj7D 51TxOInyBfl6
iNIRfElnilS8A8pfaGF/Y0yFwQb/pLFg2JQUZ/4DUEsHCE3pxo6/BAAA4AkA AFBLAwQUAAgA
CACSiqQ8AAAAAAAAAAAAAAAARgAAAGRlLnRlY2hqYXZhLnJjcC5jbmYvY2xh c3MvZGUvdGVj
aGphdmEvcmNwL2NuZi9wcm92aWRlci9DTkZGaWx0ZXIuY2xhc3ONUk1v00AQ fZs4ceumNA0J
TcNHPyjFQSqrIk4EcamohBQCUqocuG2caerg2GbjhDM/g//QC5cicUBw5Uch xuuAKohUbGne
7M6btzM7++Pnl68AHsG1kRPYH5BMyDsbqZmS2oulF57KWEczf0BaHnWOj/0g IW3DYm6kh5K8
wI8nJEenyiM58+k96YnsGcy4AsWnfugnzwTybrMnYB1FA3KQx3IJBRQF1tp+ SJ3puE/6RPUD
Eqi0I08FPaX9dD3ftJIzfyLgtv+vxhYfPKGAvETghdu+qthW2+gFKhzKV/0R py3Yab6xsS6w
taiCgUqUfK00hYmDMq6XUEVNwB5S0lFjrr/qNi8pdhPth8PWEjYElrO07cND B5u4aaMhUP6b
WsIt3Oae6N1UBXwPNXdRfUzI+hLYvbpngdXYHP08oDFDevP/iHIP9DtczOgC OwuncOkOUu1u
ory3L1U8H6DTjabaIx4PL679GdTDVAI74PeB9Muxx++Crc0rySgYCw8+Y+mT CTtsi2azhBVj
DYFxlZGlsTZP/sDsAmPj4DvKH1E9+IbyE2vTukClcuMC9XPrnKN5o1iBxbbG eRusU+e/YdQf
Zwpz9dS7gy1zYgPbXHbOeLvs5ZmxgrvYY6V7RlfUmbhvir7/C1BLBwjwv1BJ 5QEAAGoDAABQ
SwMEFAAIAAgAkoqkPAAAAAAAAAAAAAAAAE0AAABkZS50ZWNoamF2YS5yY3Au Y25mL2NsYXNz
L2RlL3RlY2hqYXZhL3JjcC9jbmYvcHJvdmlkZXIvQ05GTGFiZWxQcm92aWRl ci5jbGFzc5VU
XXPTRhQ9a4fItUWgTmInhQRB+JBjghJKW1pTSvNFRZ044BAaMgyzlte2gix5 ZNn0qb+hr/yL
9MVAmWHa1/6oTq9k1TG20w4zntXu9b33nHPv3f3r79/fA7iJAwkRhqWy0Dxh 1A55m2uu0dAM
u6I1XKdtloWrrW1v5nlJWDuhQcIYwzXHrWrCsMxGU2iHFW4IrW2Kl8JtagPO 4wzqyc76gHeM
2PR7t0zN5m2zyj3H1fR10TRcs+GZjv1vCMP4HdM2vbsMUTWzxzC25pRFHFGc lvEJ4gxn8qYt
tlv1knB3eckSDMm8Y3Brj7umfw6NY17NbDJo+Y8qRo5BqgpvV/zsMVxV80GU xe2qVigdCsPL
ZfpMRc817WpOwjTDhVEwZe5xbYe7wvYkpBnSg7GrLdMK6jTLMH9ihrUaecUx g3MyzmOuS3Gb
10nllDqCUBwXcFGCwnB28D8ZlzBJCdrcaolCJY4ULvt1vcIwrQ5nyuzFcI06 oRwovmtGxiKy
1CLeaAi7TL0dFTNkClUSryksybgBjSFBEgJdVByGBTVzMLJRx/pzPoEVn8BN hvOqfjJMDLcY
IsozP+BLGV/5FYt5TteJtAtL1Kkj/twMtZfhdNHjxost3gjnaIKI9s1pHAzf ykhiMobvGGZ3
acoU+nGlfOykOBXFn8BgipLDJSI+lFWv8yoB3Bo5Zf2XpvnS06oub9RMg26Y H0XF2MB9CZvE
YOB67Vjcqzhu/bEu4wfoDDJBPXHcFyVhGzWGOfXD5BSi9/7OJfAjtiTkh/Me O8nYRoHuIeUt
1mi4ywElumvKiNT9HtSZh1RQfev+88Lqg+ebhfz6xqMEingsYZea+l+xMlax N1Cs3sD9T7Fi
+InK0IPV8xsM8aLTcg2xafo9nh58Bm74ILhIvY4iglOQ6HUdoxM9QLQm6KTR l9H31OJryL/R
JoIJWscDYxJnaJW7DjiLT+nL/JkJg38N0gKr2T8x9QpL75Daz/6BmQ4+e4P5 11hIXu1AJctU
B9ffd7Cc/JzOHXxxRAEzr5AInY/YEWWJBsgpQvJXid6JFcziNs7hHuYCJqku WsjE393G18Tl
m0BWZGWC9rkeu33KGKVvejHbwZ0tn1zyLpG6HnLoiY0HaS+R6IUARumG9WDS Icw4ne/he/Jm
BL0WwvxCZz9+uVuEyTdYf4sHVKadt3gUQSj12Pykax6SrJLkRcLKYh5L/uPS J3m5x2X5Q8np
FO33AyVP/wFQSwcIMpYIsqADAAA+BwAAUEsDBBQACAAIAJKKpDwAAAAAAAAA AAAAAABJAAAA
ZGUudGVjaGphdmEucmNwLmNuZi9jbGFzcy9kZS90ZWNoamF2YS9yY3AvY25m L3Byb3ZpZGVy
L0NORk5hdmlnYXRvci5jbGFzc41PTUsCQRh+RldXN8uP7NihmxY04NXoIgjC YlAhdBxnp3Vk
nVnGWX9XnYSCfkA/KprdLCQ6NAPv8348z/vx/vHyBmCAEx8lgn4kqBV8sWQb Rg1PKVePNDV6
IyNh6Gg6nrKNjJnVxodH0NMmpoInMl0Lmkmqvqt0pFcrrX7YBNUrqaS9Jij3 +jMCb6QjEaCM
egMVVAmaoVRimq3mwtyzeSIIOqHmLJkxI/N4l/TsQq4JLsJ/Lzp0vWNhJ266 ZMlEpZkl6Pb6
YSFNmIrpzXwpuB36aBOc/tU4YpbRW61tgBbqBMGdzgwXY5mv1N6fdpnrcAZ3 J/JXcp67z1nf
RdQhcVg536L2XJQDZ6tF8sB9oPFFcHjo0MMRmjvxoGgG1F7Retii8/RL39zT 13Z6guOC1f0E
UEsHCDacjQ0xAQAA6AEAAFBLAwQUAAgACACSiqQ8AAAAAAAAAAAAAAAAQgAA AGRlLnRlY2hq
YXZhLnJjcC5jbmYvY2xhc3MvZGUvdGVjaGphdmEvcmNwL2NuZi91aS9QZXJz cGVjdGl2ZS5j
bGFzc4VSTW/TQBB966RxSN0ktKXQUigfPaStZEtci5BQSKQICyJS+cCl2qyH dCvXjux11f6s
nlA58AP4UYixHZRKCDjMzH689+btaH/8/PYdwCvs27AEXoTkGVJn5/JSeqma eyr+4uXaG1Oa
zUkZfUk26gLdEhDJeOZ9nJ7zhY0Gs5N05pGK9DyjgjW6QxtKZZL0WqA9Hnya jAf9k1EwOB29
E1j3l2ITk+p4diyw1k/izMjYBDLKqYlVgb2Q3N/eXPbmsjd3vuwg0HitY23e CNR6B4FAvZ+E
1EINXQcO1gQ6vo7pQ34xpfRETiMqeidKRoFMdbFfHNbNmc4E9v3/D4OdbqiU pKERd9Yy8uV1
khs22/P/GIacUXV9fBCs4hF2bGwL7Pwd5+AxdgU2MzKDUPP43nKrQGe6stn7 XOk8dbBX4JqM
G+orCnkS0cLH7r9sCLQmSZ4qGupCsHvnYW7xaDwHz5JjhWMbNppc7/F3sdDi EMVUObf5xOMq
uK4cfkXnpoTc59woDxtY5+xUAGxgk6vAA2wtyO8ZbXHtHNVu8dDCUf0WTyws ZdrsAtzL5lUb
nVJuq6Is5IrVs9Ivf8OS9/IXUEsHCKHxZ/u+AQAA2wIAAFBLAwQUAAgACACS iqQ8AAAAAAAA
AAAAAAAAKwAAAGRlLnRlY2hqYXZhLnJjcC5jbmYvaWNvbnMvYWx0X3dpbmRv d18xNi5naWYB
fQKC/UdJRjg5YRAAEADmAACLgRrW15h+lU3K6KcxVwpUlzHj7bnZ86vN6Jrz 87nl76rm4ZXh
66ano1bNxoaZnViIfBXt+rvV4aOltHOizGeco1ONgiWhq2To/Ifz88ust3UE DACls3yksm2r
un2uuJqepl2ShyTC3aDf5I2ntIa6zJuFdwuDcwbG5o69xKa3xXmqsWj19dBb Wgmmr3exvZyY
kEK2rWeboUyuwIlKcztJaRii8IV3ZgLQ7p3f4ZXC5ofL5Yy0w4i6zYOjr2jH 15qHeQ/n/3/K
07X//+Oerm7k8q+uyX222njS5qjR7aXW6KrZ4qfc5qnY6qTb6qu66XGRhz2f mj2vwJKonWOy
uobE34OmuHzcxYGOila+0oiQjkOVwGeGpGHb5rKfvmRnWQJFZDK3v65GfCRW Zy/AwHbU3X/L
0qjR3aegtWPGw5SuvG+4s126w4P//8nT55uJjWRffjHV54PY4YS2rHPL4oDg 9LW1woPi3a3H
zaj+/5G6xIi/tHm6wb6prWXB2pO0xG8h+QQAAAAAACwAAAAAEAAQAAAH2oB/ goOEhYIBOSNy
ZXF0VTsIbk1OZ4ILIxhBTxQURzooOAcHSpYYaGBiNQJqKj1+CAdIgld5NBsb DTF9Kxp2fkkD
gmReBRtYUw8gFx0aPCLBfwk2BFoOD8kXPhMeJSKCJyc3JkAm40AQ6BYhgltw LWsNMhXzyi5U
eoIhAF8Q+gD/FixAgRHlkAcCAupM6DCBA4kPfIRIEDTnThICREpYcfghDB4J lf5kGMJmDBwu
M6S8SGGGSZGJf1g4eNMmiwAjP84sURAhQhdBafZkSMCAgYKjCgwoDWmoqaBA ADtQSwcIOJtr
X4ICAAB9AgAAUEsDBBQACAAIAJKKpDwAAAAAAAAAAAAAAAArAAAAZGUudGVj aGphdmEucmNw
LmNuZi9pY29ucy9hbHRfd2luZG93XzMyLmdpZgGoBFf7R0lGODlhIAAgAOYA ANb0qcfWp8rS
ucbUmOz6tWBdE7TKdtPmitPaya2xdeTtl7O6fMPJh+bxsdv2s2+TTOv4uvD8 vKWnbhQaFrvG
irXAhNzoj8rol42FIqepVpCIKfP+xLzJlLbDisLLqpeSO97rrLb8k8vbi/r8 u5SNM+PurL67
fLnCgamtcbK6d9fdi7S+f77JobfEkpuXRaGdT83lpOP6tNfznLnFlrjlf/L9 y+P6rYyCGL3J
jsHMlWR8Q5O2YcTlhej1s+vvob3LnavUdMHijczpjun0uaO5ZrjbebvGm8jj gqGfbOH1qtzh
pdrfnfb7ttzmndPcutHrq+PssrfWheH0o+z9sNHvk4GKTsnWf/DwqZmyWH57 HMbOsNXdpn+g
U9TpppmXZf79xeb3t+L3t87woT04Da7Bba+0ca+2eM/msO77w///yZaeWNbt mICWTtPkppzH
ZMTpiuDckqDcbMr/ltD4jYyVOJOQLLzOeqK/dLO6brGtbq7Jg7DBaPb0t/jz vuPomrTEbyH5
BAAAAAAALAAAAAAgACAAAAf/gH+Cg4SFhoeFV1c+PgqOFhYHkpMHVGsyUplJ NgSdERAQgouN
CpCSR6g8qjxCVFQysACbMTEEEGCCjI+nR0VFNMDAPG8XxWsAAA60MWC4f42R B1Z2BgZAQL7X
QFFB3UEXYsgO42FhuaUHdmREOztubjtcOwZ2DAwD+MXh4g7mf36RRJDhokPH gwc62OAxYa/h
vQEBLsCAkayfIDiRihDRMaFjATUmTCxYsOLECQYUGOSAOIAiuYsqRBjYwbFj FQkoEiQwM7Lk
CQo4VgaA8WScA0EqVFj5E6+jDi9IcOrkuaJkB6BCXR79Y6WaARoPxlSBGlUq T5IVKlzlkCNA
gCfJ/wQdiHKHSJwxWVBI2Ls3pxmqK9RihfgWgKA1QniAHUPEhF6+fgGrXfvD LYwuh4W8kVMg
iwETZVCIFr0zBcnAgjlwsIz5z43XGDpjmE0bg4bbt0noJvGhtwsXL15kyDwn xBgsDFKUWb78
r+mqqNeuFhCgjaDbdWJj+LB7d+/vH37/Di48Q57hf0SIEELjOIMTKeLLP101 bYcOLYywCCBg
i3XXsHWmwWy4Fdgdb74BFxx6UsAyxRh0iECBSdDVl9ZkLczAggdaCIDAFiAI kokMTDxQQBAo
mXShfffhpyGHHjqxRIh/TLHGCUjcMcYeAeBAAQUtBpmhfh54IICHINIowf9N F6TBRQEXDICD
jy22kOEMRBoZoxIg0GiCFFMAYMODGTwxgGocWDkDllkeiQACS0BRQgmCjEDA FEkAMIINjJ0x
QA5ocvADCxt26CECXDbQAJ1/MNHJFDYAsEAUH50RwAA/ZLqhlm/CCcUQPSha p6MENODFAF/E
wEYVHTjhlltuvulEE5+CMkQDdY4wQg9VDBCBDTZEoAcXWJwQgBPIIuCEEkqU MAQEEUQLwRC5
MiHBABt0QkASXcQAAAwHNCGuHyU00AO00W6wARqh/PEFH3ks8QUTpJYAQg+d gNHDvucSEG0E
6m5QQw1oCNLHCUqkoesI9JaAr7b+/gtwwANXjMgFxRgbEggAO1BLBwjX37ua rQQAAKgEAABQ
SwMEFAAIAAgAkoqkPAAAAAAAAAAAAAAAACUAAABkZS50ZWNoamF2YS5yY3Au Y25mL2ljb25z
L2Zhdmljb24uZ2lmAW8DkPxHSUY4OWEgACAA1QAA5OPjt7i209PT+vr6ioqI GSQZlJSSwsLB
y8vLrKuq3t7ea3Bso6Oi+woPkzw69fX1tw0QRkpIm5uZdIB3t8S7sYaJunBy hJaIeExDNXhE
fwYI3sjLwdTRmqSbpMGswLa3kZGPNT0ylJqVvcvGl5eWpLm4oKCe6fPxzNTP vb29yMjIpqWk
VFxV19fWr6+uz8/OeaeGnbajjo6N13yB9ThG0dzU2tvb5PTnxsbF7Ovr8fHx o6qnqqiqp6em
AAAA////IfkEAAAAAAAsAAAAACAAIAAABv/An3BILBqPSCTAxWzaktCiSmYg kQygVPQ4ELSE
noAsBQAcZIehTTDYnkGvn6dD+P5ahB7gJzAQUm1JZwaEKyYmKypCNiRUPSQg jYBcByAGAn0E
LgsyIRNCZgwyIAgtJmOBRAIyJAJCLQIXPrM+F0M5Kq4/ORIyCEarBnZCLLSz FydGClYLISw6
RAiECkPFtBoOIRREACQmIrMFPkU9BLo/xQUsDjMbNBoBQy0yHQvhMNzeOdUL BCocI0pUsIBh
iI4VIqxt+/EAwYsEaKIFWAChgcUZJdIMUWFgRQAXe364kEESBDUhDzZFcGDR ooUd+4TkuCIB
xAohLgy4SCHgwRD/AStYDEDgAIJRCy7iDFm2ABFOCSGjkRFy4sCHJy80CtFR YEEABk9jSo0w
7FYIEShqoBAXwwVYkQYOCDgpREGCAlqFDMBhbZanFiTeurAEIsGQGhNcTIBG ZICLFSEY8Ejw
FctNkZEMSDhZIEKAX0UEMMix4AZDE1VA9AD14mHEET4KdOCBwCfDFxK+gMjw A4GMHq3pyvQ2
IESBCwIA9Fhx4MDyJ3cIPEgAomyRFWMKEAhA7QEAFTgA2P4xYDMBE6kaH+hI oKthKAO415wU
mpUCez4ig0aiwgUvGTgAE8kLEfiwwAIsGKDXAwwydMALNpgAQC+KFDGACjZF MAEPJpDgjIIC
beQAgAIpmECATgyYAMIB6RGBgyWBuSCBATLYYIMMDNQkQQI1EeJCCwoAkANj RGAowwKwUCcK
DpWYoMULVnyUAgIqqLAfES0cwN0PL5rwAgApgBAACDYMMGEPVFJp5REm2AHm iYSAQMABNtQx
AAkJrCGADeIdEQBwKqSgQHOEHkDNEkw+MMCiQwQBADtQSwcIWQaKDHQDAABv AwAAUEsDBBQA
CAAIAJKKpDwAAAAAAAAAAAAAAAAhAAAAZGUudGVjaGphdmEucmNwLmNuZi9s YXVuY2gubGF1
bmNonVdbb+I4FH5faf8DYkb7MNqaUNpO58JOmSntjNQCorQvqxVykkMwdeyM Y4ei0fz3PQ5p
SEtIQ1X1Zs75/J3bZ/vzl4eQNxJQMZOi22wTp9kA4UmfiaDbvJ1cHJw2G7Gm wqdcCug2hWx+
+efPPz5zaoQ3/ybFjAVGUY3uDb2K0EKqgIDHWRQDUTQihpG1MRn3RlfpX6Ca FsOVkgMVPa0V
c42Gxj2suk0aRSB8QlUQNxsJ5QYxtTLQbFX4GC1DJOH1fD93mlEe1/O6o5z5 VEOZa4wuInjm
iXgaP6BR7lFhjPF697Dh9e9gOOj/V0XMwzW1zm1tSl5qfiW9tBa529tfS6nu 44h6MOXS+90i
IWiKwdIWibgJmIhbxYpFPhBPKmita1bF0ocZNVxPbRqn2CNKl9SLCb3DLfWY ckiA535HVfsx
4XHjwzCyAVJeuzmK4fngmiANkKz7rC8SpqQIQeg7qhh1OZS1XWnKi8ALX2dt jnZkNB5ejnvX
09748va6P5jc5JAHMm68/YWhB6CJjH83DpaFhaVdoMqbb5bsf7go+GZJcFzA escYbf4Hl8Gr
qN4Mb8ff+tNRb/J9irTvfpz3xznb552Bs2zbyQU7+5zG2Fd6PlIyYT7O9Gu2 vytN0rmMA0aE
vJkb7cul6NpKNA7OHzFYILCEvShKP/jrTbvzCX84n9CxsBP8NEzIBzLXOiIL 0HpFMEsk1khW
ET1XEM8l97tMzGRN8lbQMjVzlVzGoK6lv9GNH4NJfzzoXe2Phv2nViOJ45KD ZYOyPxZnrqJq
lfZzAe+8//X28hVoMrh6MqTDi4u641aAkThtX9cpqyUTO2AiWZCZtuOcOvtH hBQSDnpAw03l
rJbvxySG2B6aExaCNBtOzityo0GFTOABNFKQMGnqH3w7AE0M11QYykfFdL14 IO5GuykP9qVD
yWpGdrnIfTqkU8UBR3I5jYGDp8GfSsFXtXdby+PUNcIvqngxqlT57ennMmHv OES6thus7J9l
8/Yx+/33lt8CjbesPBkS5uK3Z0oRQqyAS1eZ/hjN+JbZgib04bEr3x2SY+KQ 5NBxPrSdjtPu
dDovU0MWIV7StulVBu9i+stdnrK21EDV5n3qnDid9olzvBebSuMnUp7tWMsh UjADhecVVOdm
DjyqNLAn0tlB+6OdyN3U0nzVj0RBwLCVqz3SRMEDRpLOYHkcCyNYvYzgvWe/ LokUarfaERbF
m+V83X9IzR4WeKUM3rWJ/Uqb2DlyTg4Pj6ub4ZFcrYSklwPbBOylqmazITQe r/Z1UovDOpaz
w+1Sp3DKCI0ymEPlVjtT4ZCjJ6n48JxGlR7iK8NDmPoijmp9voZdvyB6Cmjd G+3mrVAlotmr
TtCEBVTLbWF4bqyW1a1pbRYz3PZFK9w2YbCsrnpmmN9U6xjPpAq3UfH40uDN rdAR5UXEE7M6
wZKfzvvcLi1YyZblTdAqeVjj+v9QSwcIZgg2GUkEAACoDwAAUEsDBBQACAAI AJKKpDwAAAAA
AAAAAAAAAAAeAAAAZGUudGVjaGphdmEucmNwLmNuZi9wbHVnaW4ueG1szVlb b9s2FH4fsP+g
6T1Umr0Mg5SgTRoswNYZWbs9M9KRzYIiCZJykv36kaJskaKk2HC6VC+JeDmX 79zl/OqpockW
pCKcFek7dJ4mwEpeEbYu0i+fb89+Sa8uf/whv4KSEqFgOPszunBbgrZrwsx/ SZLk8KSB2QPd
q3tIVaQV1LilOvWWBSdMFymXa9QTRyWXgGTLNGkAYSEoKbE2xFR6ubuYe8uX HrXcXPNe3VNS
rJRljjSUm694i5EsBSpZjQxvkAxT9H6glwYEM0NxYJtFfPNsr+yC8hNatgQJ g6KAUpMt+Lp5
y6EuDDdQpKthOw33FxQ13ObvOdPElzxBPPEyb3kGg2OB2BJ49BGw7werJiTf kgokuv50+wlv
yRprLg/U0DJKp0D+m0jdYpoYmqN9CcrQxw/UnNKyDZCx5F4JErbTpJMR5Agd kKFUbu1uSc3A
rQUXrfgDWBtFC6aUP6oVxbrmsrnmTEvy0Hbx1yscXVlCF3WcAuaWP2EKpCW6 stpHFPd2WEve
CsQiK7lHgcDSglSkNaYKIjZZyOc0KbgA9h2IARXRL4kROubrSoErI0CXjt9Q CAeFCX1hj8Or
y2Ky3C5CRvENchyJNkaA6Q+E2YJ5WlwSVtK2AjUWtXQ8Pk7kj/1D1D3neueD UycE1rbeTQvT
s0B96uu1ikEbixLCFimwQy1E6fTiOSTI/X+RyPl4K9QFdzXsw/ONa0sm01uv 7aovMi+XoOvw
woGFaAb88DLFD0APl+R3//hilSsn2QlJuCT6uUiZqQSYhp5qwTOB05M/puny ZXwfUJkuLTbv
Xm8IrfbHQpcLJQn2gNlC3UCcaLi8jJjZ7KMxK4HXU9Fjni2mLUxrVWGN0QrL iZhJ+lzT0/4W
jDt83oCvzTjHsc2zEHqTA2Ij5dk4coetkjcNZ7eE6rHbHehz7urI10zKKiUR uptq/mT0OVEb
0wclegOJs+r5xYGxXHf0FRLdtQtuiE1GnyObnF8kvUSe+r6Srzpo7NP2zMQx U2E0lmvQdzdH
DArJZCPfmYkrcA30TKk6ol03T0MYaci/UM3Sa/h2maG0E52bfOM9oG783BBR pBTqie7LndlC
hLxt1rhUE/2Jda/PRO/HiPiAiZ8KU85mT2yJIhNzSBKOIsloZhsV7lP8ysRs 6/uRffcnhlH5
4m5w/nJ/V6Rde/Xr8tRwhWvj/oXX9gY62hgxEMX+5dZt0zVhDVQBBT3jdJ0z W9ZWk9mTXR0u
0puZ7YaBiV1SmhNTVn22FhOt2ows1ov9GiqavGIyzCEqzp3sVbyf2R5UvD9F xTwbe8z/40ve
3HAi3CbXw+IYEkNuT08c7BFfLdAaUL/7Fqifkgk2hgE1OcZLBv3SwSW6P4+c z/3m3qJu/BC/
j/rULfyzATZuRCTUYG6UEGGZ2H6gNmXFgjM3vIHrWf4yf0sNUfOVZ3v6cbsa C9S3qtV3JOiU
RHnWm+lEl+m+8cKTkKC6ZgQNavg+NKwe1notqZo/Er2JayiWxLUGqrs0/gBs LxKTObCeRJ/U
HxthR6T5odvGs/sIweVUq/wWvb/ZcjqFFrcIeaYe0J+z9k9nZ8kRbejuk4pv Yv7w1cA+n+lx
hYWeb96WBuodwXejOz3L+VQ0A2s/8x4161qVkbunkOsY3Mwb+4qLN3VrXWUs 8oKm1SLRl3oV
Y40HLFdYb5a/L2rOqbYNsKOU4KSM8elHcc+FYutGrnR2Zn8/yvY/IP0HUEsH CN8AJFkQBQAA
jhoAAFBLAwQUAAgACACSiqQ8AAAAAAAAAAAAAAAAOwAAAGRlLnRlY2hqYXZh LnJjcC5jbmYv
c3JjL2RlL3RlY2hqYXZhL3JjcC9jbmYvZGF0YS9DaGlsZC5qYXZhhVExboQw EOyR+MMWV3AU
8AAU6aRUaaJI16XbMxtwDmxrbWii/D3G5gjouGQLQDNmZnZsUFyxIaipcCTa TxyxYGEKoT6K
Gh1WaZImZZ6nCeTw3MquBuqoJ+UCcsLBtZrhLHut4B37C+vRXmUkR2IrPX54 qQ8TUqaJGS6d
FCA6tDbqpcmX5/wYliM6grNjqRpQ2FO1Zd6QvTGY8ArJJjamm8Yn1Mo6HoTT fMPKWSMaB8ts
ZXGM9JxhGjsY4uxY/SKulbaYDsPTOtb3kqCEhpzz2wKqGmz43tjOhv7Uq/8/ uzdlcgOrXfVZ
YtQySAeBPxf4N+6qsJMvE/u50v3Kbsax/WxzCQ/MI+ntl6va22hWahbph7Xc y/jHD1BLBwhv
CYfUGAEAALsCAABQSwMEFAAIAAgAkoqkPAAAAAAAAAAAAAAAADwAAABkZS50 ZWNoamF2YS5y
Y3AuY25mL3NyYy9kZS90ZWNoamF2YS9yY3AvY25mL2RhdGEvUGFyZW50Lmph dmF1U01vpDAM
vSPxH1yp0tJpBb1PK1Ua9dBTq85tqzlkggfSQkCJYVdazX9fA+FrGHIgwXl+ fnbsUsgfkSDE
GBLK9FvUIjSyDKU+hbEgsfU934s2G9+DDbyIitLCwF7lhYbfIj+aorY/qrus 0VjF9tu3+Lax
RL5XVsdMSZCZsBY+hEFNgH8JdWxhl6os9r1/DOVVGlULws76dQDZ7IyHZ9D4 x5kfD9s5+v34
jZLAFAW9Zpgzfau3gXSam7WBXaEtmUoSa++NkWPqFHbagj0ZpRPQIse77t7J a5atSjRBe+dk
nPtgjqUuVAwWaefEB5fZLEnVCYIh1xtOtsqyu/F6gmwljNzWSW4cHoBSZcMh ynb0Oo/HGYbr
2h8n6Cv8jdcK//larfdIdqD+ZaFsaYbrF/4XubP2GxVwxCb4JWxQOxwYyjjW gxfM0bwzLAm6
8iJ9Vh/T+A+Lrlu+04lbJ1Dsorhyj1vengZ0mKFOKGXj/f362/XoL3UIWZET 0im48mJjcSNI
kAgNCN3mwsdZ1/Xik0njLRMwSJXRl4++1sGfPFGBm65OopuvJXHbGpMJ5PrM PFYiOfLExVoV
PJ/tgYk//wFQSwcIJ5atAr8BAAC7BAAAUEsDBBQACAAIAJKKpDwAAAAAAAAA AAAAAAA6AAAA
ZGUudGVjaGphdmEucmNwLmNuZi9zcmMvZGUvdGVjaGphdmEvcmNwL2NuZi9k YXRhL1Jvb3Qu
amF2YVWNsQ7CMAxE90j5Bw+dOoQPYGFlAsHG5jqmDTR15LgVEuLfgTKxnd7p 7hWkO/YMkYMx
DTdcMCiVQNM1RDTceuddykXUQLQPTGMqlQOJctB5spQ5HEe0q2g+dDcmWyeb tvUOWjiJ2Bp2
ONsgCueUZYIL5k5lqff0KxfWmj682cfmSzbelbkbEwGNWOt6A/wwnmKFf513 z6/w5d0bUEsH
CKW6kFibAAAAzAAAAFBLAwQUAAgACACSiqQ8AAAAAAAAAAAAAAAARgAAAGRl LnRlY2hqYXZh
LnJjcC5jbmYvc3JjL2RlL3RlY2hqYXZhL3JjcC9jbmYvaGFuZGxlci9SZW5h bWVIYW5kbGVy
LmphdmGVUctuwjAQvEfKP6woB5qqzgegSlQVUukFqaiX3hxnIQbHjtZ2oEL9 9zokQAt94YO1
3uzMZGcqLlZ8gZAjcyiKJa85I1Exoees4DpXSMM4iiNZVoYcGFowFEpWFpkw 1FxlGcYsu8+s
Iy7c4wH0J2S8QeGdNHpco3aXITYCq6b4HrWcc4GslrhGsmwyQ4Xi52kv96ta 1v3+i5Nqt3ea
JHEECYy4d4UhmMnSaHjlZUamtivZfqwDNNBDf5L3m04aR5XPlBQgFLcWnlHz EjtuwI3DsA2c
WBZH20YRwkkTGGijb59CHLkR1223UbKIv/gz6aiucGcUDv5r/kEhbYvRNKxE Msf22S0zzZbB
R9iTf6UA3BGBK8isLZxH1VJtO6VwjrmA8EQBfWzcwack2ALdw8nEoJUbHulm b9ZhyYx3rCKp
ndKDXms89ODmTOIz9PKK0HnSoL1SHc97E164PgBQSwcIg5FoMFwBAABSAwAA UEsDBBQACAAI
AJKKpDwAAAAAAAAAAAAAAABFAAAAZGUudGVjaGphdmEucmNwLmNuZi9zcmMv ZGUvdGVjaGph
dmEvcmNwL2NuZi9pbnRlcm5hbC9BcHBsaWNhdGlvbi5qYXZhlVPLbtswELzr K7anSkbBfICR
g9H4YBRoClVBeytoamUzoUmWpPxA4H/vUpb1cBS03YNIgDs7O7Mry8UL3yCU yAKK7TPfc+aE
ZUJXTOqATnM1TxK5s8YFMG7DUChpPTL8XUttjoxby1YLa5UUPEij5/+T/NkQ xzFMYvwhsIMs
Nxg8e5DeKn6azKslW/0w7mWNWmzfy/imeKiM2z2tSM3dbJbADIqt9CAU9/Sl PpxRHrhSwL1F
ETyYCsIWgfftfvSARxR1vFOFu8TWa3priwx0AXWhcIeaygz1Jq9JAhQt7nH9 TEzgA3chnfCl
6YvOrAG9Nt8YrR1Qtuc99PqYcMgDtilpNu9QwZ26e18rBk0aHIbaEXGJU+UW usxr3dmctsyf
QONhKLzLWJR76Y1Ls0EDDVUF6ZBqxJUvi6f86698+b1Y5EU2Ao47jnEpM/KX LX+uiit+THxO
/gn7+KWHnaGStP/qPdtaE1g8jceh1xe282jaeyNLmrWx6e08GxrotxgO3W3k D/0L/QgGbNHU
AeQedK1UNiF4fkP5dpG6MpFsYomumv1JiyX9C2lcAFoNzdeKHLhxaKjc1Tr9 20ijkA9XCukf
LsaWtEVvUmP0zQp1M4B+CM2tfTkn5+QPUEsHCPQvc7jaAQAA8wQAAFBLAwQU AAgACACSiqQ8
AAAAAAAAAAAAAAAAVQAAAGRlLnRlY2hqYXZhLnJjcC5jbmYvc3JjL2RlL3Rl Y2hqYXZhL3Jj
cC9jbmYvaW50ZXJuYWwvQXBwbGljYXRpb25BY3Rpb25CYXJBZHZpc29yLmph dmGNj7FuwzAM
RGfxKzhkSD0oH+AlbqfM3brRMuOwsSWBkowCQf69dlMkRVsEmUjcw92RkdyR esaObWZ3eKeJ
rLpond9b8ZnV01ADyBiDZgzaW3aDxMS2iKUYB3GUJXjbuGU8kzbdJClo/YBn dzW9BL+XvijP
PthUFWCFF4gtKdIlc1G3VPIhKL7KOMM3GlsNUzrKF5tY0+JZ7brVLGwglnZu QzdQStjcqn9f
i/yR2XcJ/wA4AZjvmDsB6/9+QXddnxDMCYxJJbKuf+g1mDOc4RNQSwcI/YWA h88AAACIAQAA
UEsDBBQACAAIAJKKpDwAAAAAAAAAAAAAAABVAAAAZGUudGVjaGphdmEucmNw LmNuZi9zcmMv
ZGUvdGVjaGphdmEvcmNwL2NuZi9pbnRlcm5hbC9BcHBsaWNhdGlvbldvcmti ZW5jaEFkdmlz
b3IuamF2YZVRvW4CMQze8xQeGChDeACWInrDbahURepShcQchrskcnJHVcS7 N3DtFdAx4CGK
bH8/tr3SO1UgGJQR9WarGiVZe6ntWpKNyFaVEyGo8o4jOC4k6pJ8QFmTVN6X pFUkZ2W+dLxb
odWbmbNrKmpGnjyEW5I1bv8YugNPTUPBPYZpBTvkH7RvFYlijhw86kgNpt7x aCRgBB0XqJbm
lHxWddw4hgVVzsKHqlbsmrCjc61JNMkFDHIzSImx8PUqWQNdqhBg+u/zdjTA r4jWBLgtiIMQ
kOKXqHFkgCxFUiV947DvMKC779MZezi/xyui/j2BZlQR+4vD+9e8I3kKxliz BYv73vmvFS5o
Jj2mF5HJFlBgzNsVtOiL4+VmeMfARZOcZ6+LeTZ7y9+zz/ylUzqKH1BLBwjl wrH6LwEAADED
AABQSwMEFAAIAAgAkoqkPAAAAAAAAAAAAAAAAFsAAABkZS50ZWNoamF2YS5y Y3AuY25mL3Ny
Yy9kZS90ZWNoamF2YS9yY3AvY25mL2ludGVybmFsL0FwcGxpY2F0aW9uV29y a2JlbmNoV2lu
ZG93QWR2aXNvci5qYXZhlVPfS+NAEH7fv2IQH9Yia0HfimCvcFAQleuB4Nt0 M03mmu4us5v0
UPzfL0ml1thqbx6S8M33Y2eWBLRLzAkyMols8QdrNGKDsW5h2CUSh+VIKV4F Lwm85IZsySGS
ietkcsFQsI3mwTfk0T5axQZDKNliYu/M2LavHyjjrObo5RjNdCuaeLfgvBI6 TvfoZTknZ4tH
dplf/5+6J96eV10MBgoGsIEBN3iL3GCVCi8w45V38ISrufg6Lrnr1SSxsYXT aXbaABcqVPMm
C2yJMcL4PXh/LtDfRC6LsL+tXpSCpt5Mv7XTh3cDdvt51nm+dM+2YhVI9E5/ 1LVeP2b3bhis
ECbqw3rfrX6RLZQqceBovTvdJ9dvDld7ziAIbYa+D+R0P+iozcA15JT6BP2W 2dY710RKU8eJ
sZzxM+l2hO5/0VfD4TlcDodnB3WzovX3ZTOhXmAZ6UvmLGGq4i070kmqw9zf nErSJ78mDzC5
+7m7z5Pt1l7VP1BLBwj31M/pdQEAABsEAABQSwMEFAAIAAgAkoqkPAAAAAAA AAAAAAAAAEYA
AABkZS50ZWNoamF2YS5yY3AuY25mL3NyYy9kZS90ZWNoamF2YS9yY3AvY25m L2ludGVybmFs
L0NORkFjdGl2YXRvci5qYXZhtZPbTtwwEIbvI+UdRvRmdyWcB4iQSllAW1UI FbiujDPJGoxt
+bBQId6dcU4026itipiLRBqPv5n5Z2y5uOcNQoUsoNje8R1nTlgmdM2kDug0 V2We5Zl8sMYF
MK5hKJS0HlmUzKrYSM2Ob31wXISbzWXrKCfxxjeS1Y4/4KNx9+xL1JXCE0P0 p9Cyi9Uqz2AF
11sEosgdD8aBUNx7EBTnjPIQ6DClO5QalKwRxE+hMN0r8szGWyVFf+Xk4ux4 pFAO1JWH/RLz
7DmlBrKiaDMP8M26c/dMH3igXy1JCbgKTuoGLr/dnG8ufmzWcAQHM9IdlHts v+UOK5CaaFpg
n8ClGnHIMCnbDjr2mFahZJ1KpAq1EwWFDv5iUvWvsMWyO3rufi9v0JG50EYf fqUOKiOWo/ez
R/zHiX+iJlxY/G3cy/lqd0ZW0BEm4e300zWavjOPHk6fBNogjZ50lMxHi451 jOFW+XbclU3j
Clvpy48Vwth36kCA/5Vh7FNHpcrf5SH0njovczv2HUN0unt0s7ubRHFt0J9i irmXNNnzBsMa
ax5V2NvSZH2C8S2M5dLnFVBLBwgAW8VNrgEAALkEAABQSwMEFAAIAAgAkoqk PAAAAAAAAAAA
AAAAAEsAAABkZS50ZWNoamF2YS5yY3AuY25mL3NyYy9kZS90ZWNoamF2YS9y Y3AvY25mL3Bv
cHVwL2FjdGlvbnMvRGVsZXRlQWN0aW9uLmphdmGVU01r4zAQvftXTLtQ7GxR 6dkEdsm20Mvu
Qg89K/LYUWrLQh9euiH/vbLk2EmjmFZg/DFv3rx545GUvdIKoUBikG22tKNE MUmYKIlspZWE
MsNbofMk4Y1slYFWVQRZzaVGsi0pwwFCnn76e34Z2HH8h0qTp2es8fNgoywz VmExn2b5QcIv
h6uowYuwP+utI/ok+KVVr2sUbPOXKjP5ELOsoIaS1YbXhcNJu645A1ZTraGv YjBUBMdQY4PC
aIhKSXZJAu5IxTv3Cp4RevI8BO4WC3+HBazccLxBrYLSXYHpngzxu0AUpByL SDMf2QWcO9pK
VGmW+w/7szo/NGJc7TeN/kuHvUHpMINbODUuiwnqWl5ANB1olAUMVRWaiXA3 K/eDUGXFgf+y
nCPQIOKjU7yEtB8GXC1B2LrOxsiE6c/zmzbYkNYa4iYpTC3S6zACcNzX8N2P lLh+ftMG02zw
PjT0hbb0YS1WGyoqLI5GMG7MnP3x7GkCI8mEjVlyNUYJ1w+NNG+upQvWxJYa 9PS4hDQGySYF
+QlfX39KJ5r/d37Ccgn3cHNzRNyb/ciVNg9hAR2Iu/2hgmFbhj3LToiHTZyp 9VXGczMOx/9T
rvOQNKs6PyPYJ/G38U/aJ+9QSwcIQN4ldNoBAADtBQAAUEsDBBQACAAIAJKK pDwAAAAAAAAA
AAAAAABLAAAAZGUudGVjaGphdmEucmNwLmNuZi9zcmMvZGUvdGVjaGphdmEv cmNwL2NuZi9w
cm92aWRlci9DTkZBY3Rpb25Qcm92aWRlci5qYXZhrVZbT9swFH6v1P9wQAg5 DBntuUKCIWB9
4CK6MWkvk5u4YEjsyHbK2NT/vuOkuTgXWtD80NjNuX7nnM9JWfjMHjhEnFoe Pj6xJaM6TGko
FzTVaikirifj0XgkklRpC0o/UB7GIjWcPi1YyCkLrVCSnuaPyWbB6RWX2RWT 6FW/Jb4U/IVr
Q6czHvONxrvSt3X0W2hZnYU20zza4C0TdFqk+oVpMyxzxRMurRoW+KH085zL 8PEWgRgUk2wp
HphVmp6pJFHydIvUPLVpU+9MSWOZtMNxDyie/7ZcGtzMhN0m2LWyq/QHfN7n VXmfq0KnAnWt
XKn3tXfELKNnjyKOcsmjg4PxCA7ghGX2UWmYCTQLP1kyR7TNsyheLrFdEAfY m0Z77p+j8SjN
5rEIIYyZMXB2feHXCLjDLsI3PQUcj/4614Ar1WLJLIeblMs8qEISFJ6r2aqE C5cdZyQo3ldW
V+Xm5AYj1yjjGVgqEYGQwpLhcoPBn9ourFenVuCGKd8c5yr0gdv79V8kmNSa YgGkkhV5d4Rc
LWC4kgHU2o0QOmF4SvDinY6BvOWgDGjim6/RRwOSv7TLQzwnLmU3ziQ4hM6L DjGRoInKqiqY
e/i/G0uoucFZ4DOLHURK7oGkeHZrZ7KUa+oplbKT7fvGsOU7PdYaH3C3EHFc My9psDCwatv1
7LqtriIV5lyyecwjRH+wqWp71HB7Gas5W7v+ymQUY+n6aZXe3J5fHzaaZlOB N6SLhi3Sh6NR
0rw2EWeZ/Z9UnSXKUtSKvqlLrbKU9JE3vby7+X77a7v8mhkWrOrWAQxvjopN QaFtBiwJtDh2
si6Js3vzQ+MDpi2dOwB3BUzKgBsVaE+5f1vXs+1Oh32eTfuf4Qrko0F2nUtA qkh2gxYHlVk4
Xu35uGnhX0Bf71st1m4znUkyHJt/cv3lEIMd5MIsjgP/dUvXrdmrwYyoyix+ TAppY0l27zK8
1CTswqccfkeN1yzhPhvmCUEPUDQP2E97m2TnSsWcIcL1UAzfKVU9a8AR/LIO HpmTdtQOpJ1K
zQ1hktpXbwQHwOr7CAUza0RA+kSCOshJ16gLp7ZBjfiDSMPxMXyG/f2GdZfU hdDGnsc5NaNQ
42rOZyGArvmeNNzKuwTjLfTe8tITsluaY5ISMNv2jezWqtUo/nGtu2Cx4UON 0t6tim8rfPwD
UEsHCI2TQLl4AwAAEQ0AAFBLAwQUAAgACACSiqQ8AAAAAAAAAAAAAAAATAAA AGRlLnRlY2hq
YXZhLnJjcC5jbmYvc3JjL2RlL3RlY2hqYXZhL3JjcC9jbmYvcHJvdmlkZXIv Q05GQ29udGVu
dFByb3ZpZGVyLmphdmGdVVFvmzAQfo+U/3Cq+kDSzam0R1ZpVdRJedhWddWk LoomBy7BlNjI
dlJtbf/7jA0EU0jaIiUGc9999x0fR06je7pGiJFojJKU7iiRUU4iviK5FDsW owyHg+GAbXIh
NQi5JhhlLFdI0hWNkOwYPqBUZHYrEaeCa+T6eo88ivtl1yZHVy0x1ZRME5bF 4fG4aypNEa8I
vBFCW+bJeDwcwBjK+qGSDishQScIuU0JUVEBcME/SlRiKyOEJVUYw/T7V3CK bJ4vdKsTA/3J
NoLDb7pZmoTqnrmbO6Obmf3TWXxa7EyGg3y7zFgEUUaVKpK1GglGSYYbs6Og q9HDwWMhA8yR
S7ajGkFpqk3GFeM0gx/LFCM9X8DVt+vbuz+XNzeXd3ABHB+qW+eL0Me7JhqI k67CmsCVWqdc
o7YPxkQFbrOEXLmKRw726JbiYCsIvBBg3JTLIxQrKJ7JaB/bgPlQBRdGwDbL Rn5EC2BBnGlG
M/YPnSjls49CH/LsX0rUW8kbbajjADOFh9U4wn49ZfIgKANbrSPN5o7eyG2B R6kbjniR/51Y
d/rcaZjCLk5rZRY8ZBN8r6wgcHF1erIn7mlkB9ebH1+TrXCyz7U/LYGFf8Pu di2FyJBySKhq
v169HavK6VBSFANPT9AvsqeO5ntemkxVhTCeb/tf87KapoU9QA/hTrAYYqZy oTB4mVUnTJF6
BBzqoE1kGacJ5WuMA/etKQf1h8qRIotnRVS9Ycai3ajIYTIGQogd1B6R+2wU xxhmZshAJGK0
3wzc5PovbMxlVkVM/PlaVteeTK+boO0mmDlezutPi4bhikpMz82DMkHnoVk+ e1CSIV/rxNw4
O+s3eRMxZwuPLzhxK5zAGbD2JG0hiSpfioPj15rF+C0qTVPyuW1PnicxdRJT I7FC1vJST16H
xOKoUPN00aQMTuziBJpfeuRz0aG5tn9F0TEUrKfM339QSwcI5cmCg9ACAACR CQAAUEsDBBQA
CAAIAJKKpDwAAAAAAAAAAAAAAABDAAAAZGUudGVjaGphdmEucmNwLmNuZi9z cmMvZGUvdGVj
aGphdmEvcmNwL2NuZi9wcm92aWRlci9DTkZGaWx0ZXIuamF2YY1RXUvDMBR9 L/Q/XOYe2qIp
ex7CQBzowyYIPviWprdbtjSpSVqFsf9u2sTZqeDuQz5Ozj3n3tyGsj3dIJRI LLLtjnaUaNYQ
JivSaNXxEvU8juKI143SFpTeEGSCNwbJrqIMScfxHbUhL8M+v5i55MKea/9V Q0ktJU9Uo7QD
Nc+yOIIMFrS1W6XhmddKwiutC1es2XP/2Dkb7vDpQzntkTyOmrYQnAET1Bi4 Wy29PeCHRVka
GNcUR4feClzkGSRSyZtHV1OpWOrR3sIgXtjilUGBzCb/sa9h6FxQuSHrYudS fiOnAnJ/WKxd
q9oNyV9Dk4VSAqmEYOzloQsuXgma4VPvBdZuO6Ho78HnEOxc8AqS8AhcGksl Q1WBH00K38RR
Th+eENzgFpKvjCA2P6drtK2WkHg+2aBd0RqTlOBbS4VJJkFvNpuk6Sj36PQM /jQPala3OOb6
47Efsls+AVBLBwitY4OoXAEAAAMDAABQSwMEFAAIAAgAkoqkPAAAAAAAAAAA AAAAAEoAAABk
ZS50ZWNoamF2YS5yY3AuY25mL3NyYy9kZS90ZWNoamF2YS9yY3AvY25mL3By b3ZpZGVyL0NO
RkxhYmVsUHJvdmlkZXIuamF2Ya1U7WrbMBT9H8g7XEJ/2OmmPkAYjH4Nj6wJ S8dgZRRZvrGV
2JKR5HQw+u69lp06Zg4ZW4VDjHzOuUfnXrvkYstThASZQ5Ft+I4zI0om1JqV Ru9kgmY2Ho1H
sii1caBNylDksrTINmsukO0kPqGxLJrzGPNlxznJ+AuCfXIsNbzMpKAKBTkd xlWSRauMG0w8
yB5FLXPu1toU36KjEMV3MuVOGxZdoxVGlk5qtRwIYyi0hDvOrjKZJ7PTuCU5 Vs5LXkyn4xFM
wYcC++iBvILLEEqPBFELg9LqvUGrKyMQYm4xgau7W2hy9SofeeUyoq5koRX8 4EVMgnYrm4c7
Sp+OBGdRclbvXIxHZRXnUoDIubW1WK83gL8cqsRCf5dOl2NBtiz0m/8OhpIb j35TMVptrZUz
UqWQorsn/WARb1A4wEYybKAto15yDUH7EKSyjiuBeg1NhGGHO6DUy6CrjIIg 8D0J9/KMyt7x
AoMQzmECD/Q7D4JW7BDkabQbhCxHlbrM439OZl2ZZzJt8ZjBpi78u8Fepe6+ 5akqz1vEcz1H
gwEfdONkzi3LUU/gw2t39vDZHwYm95m0QBenOX8tA3RyitTLdPbqv55F/7bW RfzNf87AyYy7
l79O97s22xiVyAIf9uHno9lpPPW+Kyz68ulxcfn58XYxv775Gr71FLylw2h+ 0/N3YnToegFQ
SwcICmUnaggCAAANBgAAUEsDBBQACAAIAJKKpDwAAAAAAAAAAAAAAABGAAAA ZGUudGVjaGph
dmEucmNwLmNuZi9zcmMvZGUvdGVjaGphdmEvcmNwL2NuZi9wcm92aWRlci9D TkZOYXZpZ2F0
b3IuamF2YW1PwU7DMAy9R8o/+LDD1kP2AbsgTULqZZPgxs1NTOetTSLHLUiI fyelgEDC8sF+
fs9+zuhv2BMEckr+csUZnfjsfHx2WdLMgeRgjTU85iQKSXpHfuBcyE3sIs7c oyZxxzSOKZ6+
+9+a/3YHVHQPKekncd801kADdzjpJQk8ct0FTzh21UK58TqcSQpXfNOGzYLs rclTN7AHP2Ap
cDzd/9wHelWKoYJ/fVnzVqU16nPVlFKAc3etBfSkbWRlHNqYJ93uVt4XfQkh nSRCpBdYnG93
h3X2bk3ND1BLBwhZAa1o2AAAAEoBAABQSwMEFAAIAAgAkoqkPAAAAAAAAAAA AAAAAD8AAABk
ZS50ZWNoamF2YS5yY3AuY25mL3NyYy9kZS90ZWNoamF2YS9yY3AvY25mL3Vp L1BlcnNwZWN0
aXZlLmphdmF1j8FqwzAMhu9+CtFTevELhB3GlkJgh7COXoeqKJlW1zG2ElZK 331eurEOMh0k
kP7/Q39AOmDP0LJVprd3nNBGCpZ8Z0cpjZFjGKLCEHvL5CQkzntbN9n0hKdh 1PJfCccUmFQm
3iDpEE8ZF8a9EwJymBLcKCBDHB/Za4IFpzkbA7m+7UlR8+jEo4OtRvE9NNXz tqkeXupd9Vo/
wh2sljKFX/Sq/MOcBmmBIqNy7UUF3TVfcZMV3DzWs+8896+6bm1irVrJ795n yk6S7B0XHbrE
63JBu5EPbguN48/5YszFfAJQSwcIFHUhv+EAAACRAQAAUEsDBBQACAAIAJKK pDwAAAAAAAAA
AAAAAAAtAAAAb3JnLmVjbGlwc2UucmFwLnVpLm5hdmlnYXRvci8uYXBpX2Rl c2NyaXB0aW9u
pZZNb9pAEIbv/ArLp+YQLxAiJeIjQqGoSFBFpU2P1WJPnSnrXWt3cZN/nzEG 82HAYLgZ+X1m
5p3Z8Xae3iPhJKANKtl1G17ddUD6KkAZdt1fP4e3D65jLJcBF0pC15XKferV Or6KYnqW1pE8
or+VDj3wBcYGvAV6kicYcqv0nzuv5TW8SbNef6w/Nhq3jft7CrEVsOn2ag79 OrFYhCgdDC6l
sTWA+3MeQklGFBwNzlCg/aD4q+hLgP2I1+pnFUVKDrSK+wGPLei+MZj6YF1H g7EafUsFmK5b
3yIsKRHYNxWsOAZsAbVPaLbIYgwltwtNki9jSp2tUmcLZHnqrIBq37yuy1/G ZmkJpyr6vrHh
kjJCsD+UshMVQFn2N6PtjA6ifis9p/magh3zGYhS4vgfTzgTXIZsSu/JsH06 hDk/29GugQdZ
F6ZbzLZykyZc0kAXetXawRXkrwj/i6LTDfY1cAtDTQ9jmvPSlpS4Rk0+n7U/ 7yhpsiUXW4P/
N4UJgrEc2z7X01HmSn8Z/5lSSE+x2c/q7pinO/Kv7xZkurmmaAuzVYag2KS2 VzGGKMicARhf
Y3zgGJfpJyAXlT3IBmvC4/jAEjtLW6XkTJkewhl9md4uQ2zMtjTf6UYonN/j 4vwcrjpXxfZ9
Rp5QdcQUdIL+BSbkgIEcVBdno1dd/4IxHWEJ1QlTngCfCTBXIJS+qohsGCsM whjl/BuI+Gjw
o0s9j52toCPy0u93pn7RKsEA9Gi5AoqYh9NXkQOrmWdStr0m11E2PrULW37/ VrOrPLrdO2x1
zaNLKMtvob3aJ1BLBwhJW/V6XAIAAMkKAABQSwMEFAAIAAgAkoqkPAAAAAAA AAAAAAAAACcA
AABvcmcuZWNsaXBzZS5yYXAudWkubmF2aWdhdG9yLy5jbGFzc3BhdGiVkMFK AzEQhs8KvsOS
eydWPHjYtYisYKFV2tWrpMmwHY2TdJKU9u1dxaJ4KHibf/jmY/jrye7dV1uU RIEbNYZzVSHb
4Ij7Rj11d6MrNbk+O62tNylFk9dDOPlJyFn21Ruxa5QNrKrPZaOC9IDWU0wI ry6DN4XtenDC
dNG+3D7Mu5v7ebvQfznijMLGg8NV6aHQ9yUKLLNhZ8Q9z7p9RD29WLajMVwq /e+HokOwQRAE
N4UE3aMvPXE6pkpiD6ph1MfQUHIs+UCviL/gWv9u8ANQSwcILuQ66c8AAAB3 AQAAUEsDBBQA
CAAIAJKKpDwAAAAAAAAAAAAAAAAlAAAAb3JnLmVjbGlwc2UucmFwLnVpLm5h dmlnYXRvci8u
b3B0aW9uc4WQwU7EMAxE7/0KS3tvF3HeE+UIQgs/kG3dNCgbR7az5fNJWpUi waqXHBzPmxkf
oMVLstYFCxTVURAYiEFHBGJbY+ddFKyTq4O5OWs0f0afsqCuqgN8JA5AAfof yn/qv9J77GYG
nQbjBQu/ZWPBhB56pgg7sqYP/SZ9/lIMkhsBo5BPpdweYNvcOO8jTTJXYjR9 qVjyCGqKQMP8
gauV7BnMsl9sYt2V5J1N8WJitjQKRoQ6ZxQF6PKJnQq4ADeHEzJMTkd4XUFP FHI+bVE6djEP
dmMumKvZop4x5hzLHdRd80PQ5YMozqPIVDLkS0RPnBMUwn2XiDw0626zcN4M a0nK5E8Pj8dj
VX0DUEsHCFExTXEKAQAAnQIAAFBLAwQUAAgACACSiqQ8AAAAAAAAAAAAAAAA JQAAAG9yZy5l
Y2xpcHNlLnJhcC51aS5uYXZpZ2F0b3IvLnByb2plY3S9ks1OBCEQhM+a+A6b uQt688DOJmq8
aUxWH6CFlmUzNISfiY8v4IxxMpp4MN66iio+Aojdmx02I4ZoHG27S3bRbZCk U4b0tnt+uju/
6nb92anwwR1RpluMMhifSrq4J4LAYu+CZigH4yOyAJ5lwwhGoyG5IHiL1Kx0 1iKlXvB5qu60
cWyCL9RLNoPae5RVTfKmVIFUc77BH1Vi0oUywAitgF+OUBoQdK7sOGm+NARf UX7F9QrZPZB5
xZiu/xe7lwe08CfQyZmvvPBSDjilP8QK/zhkbeihLVZ6C/1UWDwPrTrzXImf f2H55d4BUEsH
CGy+GDTrAAAAsQIAAFBLAwQUAAgACACSiqQ8AAAAAAAAAAAAAAAAQQAAAG9y Zy5lY2xpcHNl
LnJhcC51aS5uYXZpZ2F0b3IvLnNldHRpbmdzL29yZy5lY2xpcHNlLmpkdC5j b3JlLnByZWZz
lY7LCsIwFET3hf5DwH1o+gApdCUuXAiC/YHYTkMkL25Sxb83CK6rm2EW5zCz G1ews3yxqmWi
7bt93zXscLyOrK5EVRaYjA4RPBAWENyEyB+gqL0bRFl4UvyL3OfEJ0/IYYM2 oFxmKDieJCmk
i5Fp8WQHwett0wajZZ7LdLtFB/I3A8tljKB0muGSXjRoeEpy2qlffbjV/m9H v9LnZ1MWb1BL
BwiGaz7IoAAAAE8BAABQSwMEFAAIAAgAkoqkPAAAAAAAAAAAAAAAADEAAABv cmcuZWNsaXBz
ZS5yYXAudWkubmF2aWdhdG9yL01FVEEtSU5GL01BTklGRVNULk1GtX1Zk6Jq 1u59R/R/2NFR
5+KEvQsFRdgdfQGIMsukKOfiC+ZB5knx1x9Mc6pMNCVrf1EXlSLwTmt41lrP +8obSeA6ZfXn
1inKIE3++mPyc/zPf+B1YkfOn5hVBY1RddfFNAqs9q8/IuPcvn69dRI7Lf76 4/+IUe0Fyc+s
SJvAdgrBiJ3Xm7jUMqLg/PSWv/7Inu58/VJ28jooHJs8OVZ9uYNMmqBIk9hJ qr/+YECF/HPy
c/p6++XFb80l75tR2ti89PF6S1p4Px0rCrLS+VkY2c866O5uAs+o0uI/ZZB4 kVN13flvVdTO
x9FeRvT++e7ZIKmcIjGit5f8FF7+Ep9H9DyUP68v+/UVVlp0/aiTKoid/5jX 1prrhP/3X/8P
+gn+HP97+nP8c/x///Xvf/7j86POKSuc8nJ7OfDx6+A/PTT5Cf0c/+vdQr4u fnf9Z153K+YG
TvHPf5CnLC2qP0XDOhie88DE/Of0p1sEnWCUf/33Xy93d516fuBtAjtB+feH t7192Y02rQvL
Kf/1yz3de/pXw7Cqp8npa7yn5e49wxvvaflpsn/aif1owzda7d4zrOHuZudU OUn566i793yr
/Y+Nd+/5sn03iLpr96e8e8/Axj/eUnW2qbys++u9j8yNW3RWIArK6kPvuvf8 1tS83NK959cO
Dupd2WnUdeYu73n+/mqLHnj62NnSwr48/fboRX56nn596FXR+Wdz/6rw4D// 8c9/vNpM4Plh
oA6Al7cDr28BnpccINLuu6RaOKVVBFn3zdOFyyJV4rML+GlFRtnJo0Jhkz8X gde1+dcfygon
cN8HLMPx1naIs57RHuA5NEUP/x3Sj07huj7EcZosijR760Y3us5IXYT3x9vX mG1k3Rtkx+vk
oWh7O0bOqCguQG+0rq1gNt8KhzkrkNi6XmKDOvY2QZfWl9dPqmH2Nro6bjHZ PYzRNBnzwRRN
PCrfZBCUasigRt8MAaB0UmBVdedQt4FzdC4TclFBzyl+fPwKszp5Ln9w3aQ4 yY31ciBoz0Cy
ttY1xkVSmTqxDSoaomQM66HadRF7stCUcRHD4ododM0+X7r08Olq/yzJRxjG oAkelKGghmHp
ZawVZfCkHtaHV5MArFI6qdJr471Nnmx6tZ/Q56O1tG3FSliIU7Z7Nl4evb9F Gn5MLs12w/7U
8nJx5GINataxA0+OPOEQueivKr1yhinIe5EwXGfhRE73hXPtCHeZcNOJ7qoq tGk2k/mMiaeT
HauJnGMRkxhkERPkb/fkrQMv6md4z+rX20hW8NI4Oe4n7vlIGmnJTRE+rc7e CNwMGu7F/BSB
WXd/q0WHVDp8pzhVvwmSGQkIt+rSXO+W661Vc3Xhj5r6GFiPj+sqO3fnrx4r SXIi0DVM0ypx
rOZF6K4mpDre09+SITX1Osx6laE30e2TISuy62jXNPTJCoQmMc9Koe2PIBXG w2ToFeAqQeWQ
dtD99WPWO1am5Md8EisefjZb/bxJTgq2nBXw7HRnrG8N0e/1482Y9zY1W4AI RCqrdcwDcRNx
sjdbxDo9dZf77w3u2ZUpTtEElvPc+sWdfrXA/gwt1ksHB3YKE2UqCEtH5LBW OPueIN2dZqNx
DDNyyue+/AB/PgGNz00nFnacr0Z2ULgAs1nyPnPwrbzeSJthTb+zElyQHCgn ypxnH1r84J6w
yfPFu86zBSZS13N0sjkLDc7LsyRcK9uJz6MPLf+6C0qKbpqvEWZvCwkSqLSn Mw6BY264YMPT
DiUl8eidvynSv646d7WGFzD/tN5X+/ypF3uWjSAbcBrELpd5xjjnExXm7KYC 7/Tik5hflbfr
QFkZSYcce/1u7a4D1d256lnbx9RBOc+qyDo5Wvldn6cWjrO8fOptL4CYECVn ozOPHpAMFhBZ
LT0EyMRCetwoXmHFjblDp6nlhlshGSdT7+CXKaHPNvuMKU/DRnRjBZ8/dSv4 orM/LiMWjcrv
OpcFt8DFaT4WS7astyMOlQokXRTgoeJYgpwMGPg7L4d1MfrTuva2Zs7MYDyP kAWw8hobrNQR
jBukNzrlw3DFO739OB+dAesm4Rc4XPzouen5jrt6zWJNsRRRpMYTUCdOmauM ioNblulygKt8
bfulM1C/xDsUpxK+Z6gysrUL3vOXCuYv1hv/21PzZtJex3uJDPoNTKlncjme zxJMl+UwMvAR
3Bhq58neA5HAurzXraMIsCIrmsBA2SaWY//0AvcjsjFUMmoQJD6ha32mGgk1 WWpAliq/jOfz
CzOj7kK3z+9D0JZxuTkZz5kjJwiK5jILig0xmdz3v8/5ooMrP0QVyWDghgkR Xyay+BhgLrWc
1MPwyYc02A315w6VIkQRpQMqv9dJBNF3+mJO8rgzCE2+BnO9jWAHZM8JozOu Fu1qY1WqRZr+
QcJN7w6avCmvT+63RykyvNrVJa5H+0AdmzqfniFs45EB+X2EPjRo6+2YzDYO ul4GCbilXUTU
IsjNsKUEHIj0kdGLQdZ5isSxFd/IHD61AzewjJshkrdbw2c+0ROvQnSwcisT ME8akmjiN8Vn
4Vhp0bWXeNxbbHJJ010moY0cm3sfstwTg2pOyBIfHzCjXs5JYnvOaOy0FLpe DAsq3q0Q/RkL
3zQl6cyezJJFzhUMvg0U3CMWMIMd4iM9/abvfvLbd8LVitCmSwOPE2WsrfRF lh9zJD7AXLEd
/y+IZL+CB+o0aFxMN5aIWDHSoa7BziTsFvB6mDw853GfjPc15rgO/Mf0Vrgz 38l7/gws3Go2
jjNgez66KNThw832+N3Rv3hF2TFe0GAvDncA5gy0oOif+GxztK19OkLnyER2 mjtW7Z4SXEOg
Z0zTO89zu4KEaMLGh0m9dljepiVsWnIa4Hx/rQ/OUzHkXVDbjfZW2MPD4tFw 1V2+PgrSlOaP
uZkAzPYYBXfMzJDcCHxrofmDvkvcLcw5Y1bTs422oKF4BfoMNGy2b+RGLnix w0eX0M95S2Pe
EHdwdoIykwXJtagtx4XLScAGy0nKMobZmOdM8PMsKE+f3tBZ15fe1u1oK+ME b8ErJLU3Xm7k
PEFaYRC6d8D0u0DkDRn12xM2XmMqGeOOUp+37EZkg3Z6JAkCGLbEd2Aqebpg 9eu3N6ZYY8Il
6IZZZvpbgphrIZ+p7llK6HRYLx6M+Xr7gPOrYOUp1FIRdpuKB3MlCuZBFisL clAfZKcuL6H9
1Zg+Nd2fNIIlMwcNlzJYqZFSYjqZGyreCng+zJb1pW764QzPCpNkq/iUJ3UW 1GLr5KyQ3GQP
58Ps9iUj/+bLk8U9G5aHx7FhCOYxi/ZHLSAzPjfd1Y5M1w+BwVekcp3NTWZ3 2tufohlvRznm
ZAt/BSdnQj7P3LysIjdy70znOz25JTr3UuZIAUyCmgd0nzqB+xA4FPnCEHK9 CB9KEvTlF28o
SLpArGmo4nbeVBoy9nOJQ2aSvGrRh6aRfrEzXyW6NvExSXn3LEIcRqXNkqB8 kjd4LYoHZsN/
BTSXWexXguPYh8Edu1olKg6FDXPi9io9z8lgGMLeBmVgBlFQtfej8qZY7TWr RDZH2G2jVMJP
CD9Z6DzAfi/bfxXIJy6BQ76awM7QrDuDextRH09G19VNm+ymu307a7L1qF6B WxMS79iaPmG9
qsUXeVSEbwuse8vSgjAmr2OOX5wznMar7E7i43Hr2tumKHNreidBen7qvG3s uVKIGNNC4zbl
b2S1rsN9EinlUqS9+JX+CQ4CZU1LgbkVx5AOm3Z4oI/b8sDfS3LdgahEGkVG dxsWRe/A+QW5
fPKn/A5jgh3qK3atMZHJgJ5hQhBcPqaot9M3/UUVZjebWkm2pPxwpSX2qNGO DUgtUOGhnJb2
VF6+jmhVpHXW7xkP6xN6HOvgTpnqXLocrYwah+bJejNMSW/i/Zslsp3jl/6m 3aTNlNkVhXzE
zBLzuYjnhmUSn8vozxb3OupfoNdzwqp3+ON6MSKMYJcHdcgLoyU4k8Ag3JCM OcxRX9zmC/5+
l+R4tlcXLNrbfAd8g+xgbblJgUvbY9nCdUkjeI3A3y4AvAOFndESqysUvpOj bjIa7EKPArRG
zAQQRLmkCKLKiCocFom8aTNuWIc7YW5ocSEYRnne2S34WM73vkSJAruI0L8t e/oelvb2QU+J
o2xuWUCPFHGbURCC7ke72b4Wvll+up326G1/Oj3XcyaRJyxMM5KSr9YVOhJY Y+t802y/AcTe
9gh1hFSwvN4JqGfO4Ha5j+ksbc+T5fdM1z33sOOnJatLjFgnygqeOeL5fJwt YqdZDBOoN/v8
BqX6FPvHryjrJej/gdn2y7VLfCjXyS2sp7HhcitjbbmTFooGWBRCBhMxk/Tj MGm4GQtDt4yg
eUJNRN4bhcj4HCm7rGcsrb12Xs2/nYXEg8TuxLB3oFta0niONlIImIQMczjP 98qsBEHi/H2m
yrPVexeLXgoXfaml9uRRq6m4PoSWSUgrXZlljbCfjZL3Mv85le489aTsyX1H o0JLLNJqFSXB
GPZoRqLBF4F/toZZ78+0lv4gS0CCYy6EEwWHIB0/28iKdAU8HqHTYZmLl2zB y9xdoc81a/Dz
Anz6kuKSO2sxvm3KFpFzQADjvUcxNlJPhgV4H6s5Tll2StTvGkYgMwKPaSGf JLaIrHJKjzCC
W2Mk9VBB+IbRWHaKnd4oVWlbSNiMJz5+atKGl1nwTK053ipB5v2K8qSK/UkL y5dmfwbJR9Fg
WxVdLufEvEJgIcVTAzzoKqQz+NCQ8boq9+zdYix0ESnJpsFo5q8Wjc6Jkn1Y IHJ2Bw73F137
0ziGlECV487HzNyG5N0C93yMWGCMMIzT9lbheQ687w0qOhoUCR4s27OW4Kkx Z7qKqajJFgPL
Ix/E7QMc7TOJ1EmPQ9A8CFGOw7ikxexZnY2W6CL6tkl8qLhKNkZUP4V1hGH5 /bNi24mewbhM
sKS0DDCWK+CyiRJCnj5Um3m/1BeHfU8Twsrwl6Ch0eO9aSJwc85GBWUxU3b2 Xqp+pk9x/6fM
jMXMKEppxmUzK7QVv+OLKDAitV09RuR5NAPEl/WWhvZrGTGcFTmip461m3tZ o0vDcntf80D7
Mxqe6uKxn86DaWvoS4E7pai6I61mPQw+v/jtX+3x1X/fssd4MHODlVtYln+y fFQdT2BkT7Uy
nwwrD70T03cshJdER9f2F1GiNTec1EKlw3Scis5ihs9akyVIffdLmepzQdm6 qkKPV2323rKG
VCWfxWg1syfiOl9ZnMJl2B18foMe85o3uYh7v49hLRodByMlS8HslOrjEye1 R6s0/QHW863Y
O+1tBGZTXl9s1GrtCFsuLVnD97fGaCGB38Y9byOrjOpSZ3WiW2n+Y7wyFw4x GzGFnuDrUWBr
OJU6QLj+u/MlNzKMc784LVfYYSceSw0XvDTaCvvgOOPih+b4eUXfYqsvltRB Ndcx4+VK4bfj
6ATBIa+W47gh+fcimb1uNeowYxU4n9hoqFcyJOUT6SRZzAV6SstoMAZI+jxM wT6Du8uVJ6Zp
Gj2R4+5kgafL6HCgkzFoisK43JMtJ+cHWBZw/yGD/0oFvJuYRZZjMF7gSRlZ 9STbOSdAxpzc
zHRxWED8eaRKZ8+s6prYuoz09Zt+3kWBOwtTKg5RmLfjdH3AFM8UC58C9p/X 7RRHH/F9sslq
E1g7+5024ukzB+zPxtoOQua3Y9obaj2ejlfFSGMoG9wQR3CbcBGIHgrktP1m 3fYTdfNmyTg8
O/F+UczrSXNAc2UuYwg6nXfOYH9HOj+pFO8k9X0GYWJq22p2XIxmKXFsjZUN HCqb21gxMMxy
EXVZpTGW2OTrDrTe9tYRSWFxigtsU6ZnYBYtOCFzyokHPjauV+vwtuPwbpkF 1mFl5KjOwZdW
dAvR7c4lUIdcK8xj2fL3kEpLi4PpJJZ/0zJVjWdVx83YHx23VLvd2Dpv7riU I5YD+Zi3An31
Ij0X9qJRXR56gRA9XVnGbtVuYVdGrSMXnSUJG/mgopfTZGDaracrX1eeVaeW cRkGTdSDRH45
sYOlZlFxthkNJez/imhfivD9lKsNFe0FntJbL8tkBsIZUZuPRek4EK69qisd 3wxdaxSOy+q8
2BiHBb0j95ODrYEyLAjwAELoJ85jf1oAbneTcU2pKM1qcjzf8b68h1k4GePD 0hB9S/nsdDv/
0S3lbReyz1snO6FkZE1DOo9INdclx8ln3D06/Ts1eq3FPrMn3lMn+ue3LBtm wloFBQSjXJqa
ZFuZsOXV/rC17EvyvTS8uGjSXfCLyjXRTNCZp81DIJxPxxFU8bMgR/FhSvSR /MilHpP2b/YS
VkE4UxxP3a8YO9iY7LkppCSpNXoAA/INr/YDNmdxkh16nGo5Hp8t9MQUhLS0 aVtCv10X+BgD
y453xT4v9Kh+K4V4EDJy3W3jLMPaVcQugveZ/KwOhCY3UkHPw++ptbm7hB/v IjMKomPpC3Jr
6pQOQidOGZaSvVmXupmSPVO5KAfUQcoC2mcMdZkgk2293IMDk4o9Zesfb9e6 lu/6RQK3Q3cO
Vv5EcOg2HisoTo6FAgCXw2KGT+HlL/D9lntIaH/JlM4pqlx84efMcrOHziHD h8Qw9/BE7zSu
I95UT//1tmdE5maBQZNtsAYlc7eWhcTjXI+u0jt6fAMF8EZ2ixAVcKOE3Czd WYtANrXM6QXK
nbFjzILDaEC/kGR+lWi1uAhVUro3urBowXbr8wTAxdVypEw2uDb2K6zkjYcM 9YdE2r3cDH52
YF4GTVXM/TyZJvzJg9CWZYVy2GBvg2MucC8SZLVWdJ9Lo+zGZR6fAqxmPBSp ISNVsk1jjuF7
PLeHApwL3njZf9p15V50A0/bKpGkwMvXErMeAYtqFh2bkcr6w2T6Jvab3WS2 no7W/oiG85EV
uda8pOHWQ3eO4x0echlvlZV7yx3o/O4QnqZcENh8FymzJED7W0WJhMe4hB+R XD83Pc6gUMeC
wKm3aJP7ZMJw/thYKOJDzPy3vOLXBNlc2iRgtcGZKUNRgdWuaBcnclTzfqEH 9OW1rmwOI4p6
cls7UNkfiJUigmExCtbRHuc2EzQk7enASt8bByotjq88i/7wnt5oQDYVIwAe T2bJxD9Ba0Br
DuZjtdd+lb8BRUeJAu7JJkUwtqIhji9V8OAcz+Ve/iad/10M3g9VylrdIoG/ GpFVtQjigoG4
XLNNxDgOi8Ff1eopUH0+ZubWjvuRMyaMqU1O0FRCTqa+wc2RGZuS8RsU4g/s DcPDnnT5DuEM
Zcc6niRQE6AM6UjrUyApsqJ01n0Y+lSqIkg83qgs/5bt0gojaueGqpd1fLIn I6C2mCkFq8Cw
mshrovspL/Rsu15FtzfRUYmHZm4HLN4UG0ddnUZ6UpBRGbPH39g81h8eAvgs K/HQtmWNEJYL
tDjM6SwQ9fFDIZtYBGlxC2BIZ2ZuEWOe89vxeW0vRnj3r7GaTBw4ga96H78U Tm8mMBmcECFv
ybAsVSElFpkHyiBzYhkM3OL8Jbf8JTrtv+Hu1sAiPsZpjVcMVdd+NqKBaZhW drw4esPw/dez
0ZxDzc9Ndo8meslqcEXsaqzccjNvAJ/2VY76ST2sfMwXIiXAXLzNPcvB54iz 5hoh/72kBn01
gKJRVN3HS579bpoDMGkYPatwiTA7lVa0MpYYP4sBffGYJ/7F4F9TaPccpdJU JrbDwkVC6XNA
4miqs8NQYoabh7DzJ5rgj5eNzXFmFK9z3ROiZS6bO2tC9bDzSWUB92gvq810 qVDykDrRI8mG
BSeNFwiUiSshDFM9lgVcDbYqB+2GlQI+LazYyexr2upi/m4sKUQoLlKj8A4M OcuZVE7EyGyw
t+j82/WjHprvpc7Zv9/3IxX4rk6DMrgQ98qER4IjWkwsidxOtnt1kjbf5te9 knwe4bad5ymx
Gsl78xQT+HSNhKayXe9DaH763XIGkWbty5VLlHUT65dKpm0X1cabUpKvA/vC o1EHFyfyQHrf
QA5BP7/ysPNQe6SYvrDP1WDunrO6WjC78DjwSKJX10O/Ff1uWCDssNvwxfyo xaiJeplgWxKt
zP1A/3tOQbqCz75QZ2azu0kdq7IBepUi+1rKWxq1bifksBrQoxPfD7iJFTTW NxRGkrK+atAg
2Plj2GjbewXsO8N/TqoHRpR6V+QUXA/fuRfz4hPABmbkYYOtx4kba2e1qM5n u0VXA7kJr8su
k9iCJz80M0npUQinqnjMqRMPnE1sP4Fm8KnFv63s9NXavLCHXwjM/Xn2hZ1N sDwu6pA65oJZ
4PWMhMwzdzr9vqbdtoz9NQ2Dbpz1OVsZprrj24rIcDthzI2fD0t4fLY7/ZEP tfV3i3mbEVww
EUKmXCzGWxQV8RAd1t5Hxb6kUi7x/pO8ny5TT9s3Jv+cRmMH4XHWdWRzhozx fSepi+h8fKyu
30ObvsOZ3k/8FMxmkjqOtL3AhpSULLKzN+aM720N/jLl/6P/jrez6jqEcssG VNEcKpxk6Rpu
ZbY6hlOnzJuVAQx9szLw1Tkl/QVqpTJl+oBzScsrGRevmIzndIkWVt8mCfUs 2kVEXlX1hp5m
gmHJzYhvONZ2qozPcQrAV0iznf9dpXLoVgRJUQxM0A57pq1lB4eRDRub1mht TdVhJupDCPDB
CfZ5o9ZNlFG6AsSNj53ZEIrFdpN44xORfK+I8E0men9lRTCQ0SxN65YgKIyh VXbHbb2tpujv
/cNPIwv+x37b4Pdx/0htSaWnNn6MudEyPWnimGTZIoCR9/QUw0zr6qdffWJs OOFaL4zxoc1W
nCSBJlOt1N2Io5FqYDrvozD0jtjM8QUWqLa/5KQ2Li232LUuzKmq/c3y7/Pp wb3lE4Op15Mp
XeaIEx/oAyHgaDj2ifj0vW1NX618v841ZrSp+AnDwLPWyTfjUN6z+4Jx2WE6 90t+6IeYlsHN
XCO2caGxvZfk5Yy0plbN4w2yxQ/dk980e7/S3J6X91bZiIPWvCycbNMpacr3 NXhTw3gssvB8
WAD+sqXrGpsqflpUVl295Kn6+ZibYlnC69O0bW3UURuDOKPglJHMhfDYDpfn IxW/PE8x2gqq
bNHOMtrAiKPtl4S+G0+Wcu7dwdZfEgv6+U2TA7nm1zIA6FO5aX2b2LaS24Yr cD0MTd85kY2C
vMjGdsxeJmKEJjE1ILSpDp1H1e9V0PvT0y5ijbi9MDNmynYUwKstWeU6Yayx 87Da6qN7/n68
v+GuOeapVNyN28Lg2gPFotISgKMIbb09P0xX32ziG4S7id+Wjpw26zgUwtmh hdJ0t7UKaJlO
iOo7udUbJ3IJtUHRYXp2HKHIEwyYU9ga7EJh+vi9utf7oyvf9pX25Icodn06 tNGGwfWNhcfm
VBlZllHzCDBssV/yn2/e5v2WjFu2aDpTo4JLW4JNg7aOAfWYzFcaQHOb71K9 CueNO3efG07k
81DXpQ0umtFiOap1YaShDBHv1N8+3OUdP+cr8ClZYM178rpiUiaz9x6vUPuD eSi1exspbiTL
nrcm9UUFELwRlk6ay/NyakXgqDnOU8svdf3bpzR9OsPy1jwjIE91orzal7Ew ynRfX85hMN1i
83s7b77cfvB8JtXXh80ZuDubYyMWm2/AMHJnLu+souTcoNBj50j2UMj72Rgn jiS0EvYXS2fK
V6Yy21kyzlUJNWyK78O1vg3v3BLZguwK9Z2DbxKssInYQ5lsJeL3iW1PeaT5 LeRuwyvfxNjd
OkfQzarlTnl1kgppsraHeb4vHUX/LjTlgPni+ABusFVMxAfR3mZquJDde5vH fvuEon6XuQMD
UEFCTNujq1YH4dx3G2ft7Mx7RONHiEC/xPxXcvjNun/iuv6KMETDnW/JlYFX ES3UHFEoAxWt
72iNZ3FYZ0/7fG6fqxG2klbyoHvO6QSJ5QZcCKG9nB2X3N+W0/3lNKP+5Qjw kiGcunMskLaZ
apqRr3GRmh7IaFgS5NEE543cEzKRR/LhvKT3uQ1oGDEOJXoeifPEGiYVfXX+ fhjRcDNUW1iI
R61zcG66C0VFqGYm7dXf35bXk+jr3+sElHt0FuGA4QTywbZGsYHvubFyJh+j ib2B1Ad2QGpH
xQBUgoibM47CCT877InwZBft9H167zMB5Srj/5P1bVhOPJdZMUB0nhMxcNjN GDeTwcJy2d13
k8K3zwLGM9r1ISDKY8cP1VBEYpU5GrtmeR5wiuY7f4h9cSRuukkmzUJ36LOd z2O1Ogpzebyp
xGElh/c7rC4bMqsngyA7rlM4ye0zYRgDMdwNtq6U2cKEzwaq5ItY2myl+bCN iLe3q14UsR+F
CPOTTmpCFBeT9V4eZwt67MoQcuKQx7IovHP5kaQUOxpF/+CwBMpJ5qDym70u a1wo6eSBd6ND
ID/EGbwRcvYblqNP2TmDLDYVvNhuqhG8PTILyeYBdpiE9hTv6rcLl3MJb9Xu nBowAcBf+oXo
YKPsPEuUUkYjz6u+zXy9fQpmbw9WZgcHGaXBanSK6B7jbg/ouYWkSfBdktgm u8MPI5J8clIE
GwaSCZXqNDsJd5tuneDy28f0/Xrw5S14F0/sLWKZe9QvPJ1i1aQktFQXPDH8 7hGQv1YRrj+Y
0q805HgL2SlLycKuVuDJzt6RMC6Ty+YeXXEIv/tmibKiN5q+YrM5PMezFkWp zRFoy1AlD8Mk
/FFaTn+BGij8KTONmrGd2zWjCi2LoIQlmsy3hfx12l+IUMQlcvmFxPEpQXko XBnLt5CYzRT/
CG5R+KTBG1YauH1iEM7tV3rWZZo1hY3GIzco6JPuh4ZMAZF6b1fFI2an31kt tYM2K8RNiiaQ
uJ1GeO0XmGu35DcDqi8PsSfa7kXW5Rh78mQ52U1bkIyms41TReF8K1hqbSRl qi9QcT+rv7tV
+N2hwzdM/ozkpploC6NcPxQjMgpZcl/BXOplA+uYt6K8m0f+2jmR48Y+rmlS iPVsD6xGbDHD
GZD7rSOWLwXUd+ea9BalNsQuUxdHZqkIcI6hU1Dag6bI2RsG60d31iP04mnh FVoljia2BlHs
AcGCHMgx5JDW34Tld07T7l9MLCnHpyQenVFrpMJCAytoQgdgfBq4c+MTVery 5yNUKfW4vpxv
XqUzp50dADs8QYYBBzxweIgVdoPt3D9YspVAujBNmci43VbVjlOHyXOGkLy/ 6dympwsXptEz
X/1OGmykklG532xFl2qKU0gy6my3TRD63kbxr7aWXHPpTxj8Ch9unKxU5iuX S/J2qULzXDwZ
40OhQBYisenvMh/EK52zJfwnyOTd3+eB6eF2tBj5cSk3Ml+SY/Hkmoq6XI9+ 54cm3pIFaYIb
xQXJ3Nqct56f1HA6OhNn1HHniN0sMH1/kBqJH5Y26hOIV+bP4pIsuXCB+vM1 PgLMs2pd7FLZ
mQnJkkzWlh1H6WPnWVx2hNNJeaHQXn6rNbgRbsXQbJyUKExQ8F6HIcSHMomj DsJQjt2Xu4fv
gZjzqKRYXo6PGH0ynII9b04NutrR5FBndYP6f/vsSHsFocuzqltiKonczpie jNLCCU8F/zfW
+Yb1Ual2ws4aXZrtxiLk6YiJxoiKxmjyzXp2L9+3b/icJsLwlAnzWsimzpZG /clptpmBkfVt
0lfPoS2XI7VvpwQtRoWO3FjkFZ/WleI4YUIN2Zer5m/4bb03X3fnAPsdhe6P pZMnhsZxuDhd
i4VF4DJkFN/7YbavVOBH/w13q4qlh/In3NzupLZpBI20qp06Mo/smvjeUbUf o5z+ypfszc9Z
oZ+XhacZLYUCLMfr0RnUrqj+/wNQSwcI1tnqb08iAAAqegAAUEsDBBQACAAI AJKKpDwAAAAA
AAAAAAAAAAAxAAAAb3JnLmVjbGlwc2UucmFwLnVpLm5hdmlnYXRvci9NRVRB LUlORi9lY2xp
cHNlLmluZlMOKMpPTi0uTk1RKC3OzEtX8EosKoAI5RdxFSQmZxsZGOglFqUX K9gq6LqawIWS
8/NSMksy8/OAOm0VSopKU7kAUEsHCH4Cxq9BAAAATAAAAFBLAwQUAAgACACS iqQ8AAAAAAAA
AAAAAAAAJwAAAG9yZy5lY2xpcHNlLnJhcC51aS5uYXZpZ2F0b3IvYWJvdXQu aHRtbI1U21Lb
MBB9rr9i64deZnBEwrQDJfEMDWFKh0IGQi+Pir2JVWTJSHJM/r4r2eFS0kte Elm7Z8+ec+Lh
y+OL8ezHdAKFKyVMrz+enY4hThj7tjdm7Hh2DN8/zb6cQb+3C1fOiMwxNjmP I6BPXDhXfWCs
aZpes9fTZslml+zOI/V9a/czsaGvl7s8TqNhGHRXSmVHWwD6BwcHbV+oRZ7T V4mOg69N8LYW
q1E81sqhcslsXWEMWXsaxQ7vHPO9h5AV3Fh0o9Ori2R//91B0o8ZITnhJKZH c127IWsP0ZB1
Y+Y6X4PkajmKJ+fJ9VVgMGirYVYIC91c6hikEUTDKv1cK4TBDgx2d98PWZW+ oJa99ExkqCxS
3V4a+bJZgTDJpKgswomuVc6d0ApKfoMW+IoLyecSgUu52QaEAudnVrJeJnR4 8+q21u6wo9Ae
3vYArpVEa0G7Ak0jCD8SKhcZd5jDHKVudggHN9TBIxq9EjldOw1rXQPRQROK HJqS+Kjcs8iF
50jIC38XbehP67kUGXQrwlc01q/iA9JRnEzPHugdEVS17kCArjyDh40j7mBI 5hpcPIkDttNC
JiQuuWRYyWTV3+212fjv0iHjaS860Qaq2lTaon3EZQdaolOjl4aX7QEaQTaU yNVj4Xre3eDl
6SKolosclHZgMEOxwtasjcq5oMdOrmFhdNlOe+b+M1+iOQq1JMBc+L/MvA4W rsmPYC5U3Lj1
RuTLhyptOrmDc7lYLNB4yK1ulnwd8aoiaq37BmpiRZJwRS7NfxJtKs+xzd/D +gDjArOb8OzJ
7NcWZJcFV5CbDadN7iPWCFf8hkP6KQ22zor7RrwjPLsTss+JwLMhW3K+PeZ/ SXAIn3Xe3HsB
/NKWRMhw29KRxwlEH9eQgjSRtHJcKJr+7wT/Ka4hm12umH/7hJcRhTb9BVBL BwjF1fr8uAIA
AJgFAABQSwMEFAAIAAgAkoqkPAAAAAAAAAAAAAAAAFwAAABvcmcuZWNsaXBz ZS5yYXAudWku
bmF2aWdhdG9yL2Jpbi9vcmcvZWNsaXBzZS91aS9pbnRlcm5hbC9uYXZpZ2F0 b3IvQWRhcHRh
YmlsaXR5VXRpbGl0eS5jbGFzc51TW08TQRT+hl6WLuUqCArKTWC7bVlEEKEG g0QTkrZIQEx4
m5axDm53m90pCT8Ff0V9UfTB6Asm/hX/g/HsUpVwCcR9OGdn5jvnfOc7Mz9+ ff4CYBY5DS0M
865XsUTZljVfWHVpSUcJz+G25fB9WeHK9ayVXV5TvCRtqQ5eqtBpiDJ07fF9 btncqVjrpT1R
Vgzxx9KRapkhYqS2GaKr7q7QEUEiiRjiDJ156YhivVoS3hYv2YKhJ++Wub3N PRmsm5tR9Ub6
DAv5/yKXY9ArQoUnwqM0Rv4s09ypnVWb+34udR6joxs3NPQwDJ/mUXY9YXl1 R8mqsFZ8X3gq
iV70MSSkX3RVsW7bDH0XFE1t6+jHLQ0DpMQZAkncxiARl/6a4yvulMUlOXY0 3GEYv5TRWlMR
W7RhCMNJdGCEYcK4bsdjSYzjHo1S+ltePRiGsRMUnWSYurToC5ur165XPcmj w4CpIcUwemVE
EmlkGLr/DazAHV4J5pYxUvkr2vyLzrVhGjMaLAbjujGBNJ00Ne48s0VVOCq4 jec0YWjnTjNw
66BGgnSfkzJI8kd10voq1gGMYuKe8Os2VW3fVLz8tsBrzeuvb7p1ryyey2Ax cMENnw4IYBT0
zh
Re: RAP and Common Navigator [message #531358 is a reply to message #531357] |
Tue, 04 May 2010 11:31   |
me again. ;-)
I think it is a problem with the extension points.
Maybe they will not be loaded correctly.
Roland
Am 04.05.2010 17:27, schrieb Roland:
> Roland
>> Hi Timo,
>> Cheers, Ralf
>> Timo Schmid wrote:
>>> Hi,
>>>> Hi,
>>>> Ciao
>>>> Frank
>>>> supported by RAP?
Re: RAP and Common Navigator [message #531846 is a reply to message #531358] |
Thu, 06 May 2010 07:25  |
Hi Roland,
I hope you are aware of this feature request:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=288761
Benny
Roland wrote:
> me again. ;-)
> Roland
>> Roland
>>> Hi Timo,
>>> Cheers, Ralf
>>> Timo Schmid wrote:
>>>> Hi,
>>>>> Hi,
>>>>> Ciao
>>>>> Frank
>>>>> supported by RAP?
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Current Time: Tue Jul 15 09:53:08 EDT 2025
Powered by FUDForum. Page generated in 0.25005 seconds
