CVS operations in background? [message #94359] |
Tue, 15 July 2003 16:59  |
Originally posted by: jared-eclipse.mn.rr.com
In the latest planning notes, the Team/CVS section says that Synchronization
is now performed in the background and other operations can be put in the
background via preferences.
However, in the I20030715 build, synchronizations still block the UI. They
don't pop up a dialog anymore, but while the synchronization is processed
(minutes), I can't click on anything.
Is this just a bug that I should file or is the run-in-background behavior
not in today's integration build?
- Jared
Re: CVS operations in background? [message #94569 is a reply to message #94359] |
Wed, 16 July 2003 03:54  |
Select Preferences... in the view's view menu to enable it.
HTH
Dani
FUDForum. Page generated in 0.04410 seconds
