Home » Archived » DSDP - Real-Time Software Components (RTSC) » recommended way to put XDC paths in a file?
recommended way to put XDC paths in a file? [message #760] Tue, 13 January 2009 13:07 Go to next message
hello,
What's the recommended way to put a big long XDC path in a file? I've seen
a few diff't ways hence thot I'd ask i.e.
1. TI DM6437 EVM DVSDK CCS 3.3 pjt files use: -
--xdcpathsfile="xdcpaths.dat"
where xdcpaths.dat contains
xdcpaths = "a/packages" + "b/packages" + "";
What's nice here is that cos its Javascript can set a var at top-level and
dodge hardcoded paths
But OTOH --xdcpathsfile is not documented in
http://rtsc.eclipse.org/docs-tip/Command_-_xdc hence is it only a CCS 3.3
Built Tools Interface thing?
2. Use xs @paths.txt
where @paths.txt =
--xdcpath
/all/pkg/paths/in/1/big/long/line
Disadvantage here is hardcoded paths & "1 big long line"
Don't see any options in the BTI in CCSv4 Beta 2.1 for this so not sure
what the recommendation is.
Thanks.
Re: recommended way to put XDC paths in a file? [message #767 is a reply to message #760] Tue, 13 January 2009 13:47 Go to previous message
Alan Campbell wrote:
> hello,
> seen a few diff't ways hence thot I'd ask i.e.
> where xdcpaths.dat contains xdcpaths = "a/packages" + "b/packages" + "";
> and dodge hardcoded paths
> 3.3 Built Tools Interface thing?
It seems to be, yes. I'm not aware of a --xdcpathsfile option.
> where @paths.txt =
> --xdcpath
Yep, the syntax of "@" files is very primitive and can certainly be
improved.
It is relatively easy to enhance the syntax of the lines supported in
"@" files. One obvious enhancement is to define a '\' at the end of a
line to be a "line continuation" character.
The other enhancement I've always wanted is to support environment
variable expansion. So a line such as "$(TOOLS)/packages" would expand
into the current value of the TOOLS environment variable followed by
"/packages".
Bugzilla enhancement requests are welcome;
https://bugs.eclipse.org/bugs/enter_bug.cgi?bug_severity=enh ancement&bug_status=NEW&component=Core&contentty pemethod=autodetect&contenttypeselection=text%2Fplain&am p;form_name=enter_bug&op_sys=All&priority=P3&pro duct=RTSC&rep_platform=All&version=unspecified
> Thanks.
Previous Topic:preserving package/info/*.js in xdc clean
Next Topic:Async errors
Current Time: Fri Nov 21 21:08:52 EST 2025
Powered by FUDForum. Page generated in 0.03921 seconds
