Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [CDO][0.8.0] EAnnotation
[CDO][0.8.0] EAnnotation [message #94172] Sat, 25 August 2007 12:47 Go to next message
In my model(.ecore), I have information in my annotations that I would like
to send to my Store.
Right now, EPackages, EClass, EStructuralFeature etc.. are converted in
CDOPackage, CDOClass, etc...
Store receive these classes.
Unfortunately CDOPackage and CDOCLass doesn't have that kind of information.
Right now to get around that problem... CDOServer needs to know in advance
which package it will need so it can use EAnnotations.
Do you think it will be good to have such feature ?
Re: [CDO][0.8.0] EAnnotation [message #94193 is a reply to message #94172] Sat, 25 August 2007 14:15 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
Hi Simon,
CDOPackage has a method String getEcore() to receive the serialized
string of the associated model.
You can use this method on client-side and on server-side.
Formerly this method returned null for non-dynamic (generated) models.
But now that you need this information I have changed the code to always
store, transfer and return the model XML string.
If you deploy EMF to your server you should be able to deserialize the
XML model string to an EPackage instance which you can use to query
annotations.
Does that help?
Cheers
/Eike
Re: [CDO][0.8.0] EAnnotation [message #94202 is a reply to message #94193] Sat, 25 August 2007 14:24 Go to previous messageGo to next message
Eike Stepper schrieb:
> Hi Simon,
> always store, transfer and return the model XML string.
Sorry, this change caused an exception at another location which I have
to track down ;-(
I've reverted the change in the meantime but I'm working on getting it
in again.
Cheers
/Eike
> annotations.
> Does that help?
> Cheers
> /Eike
>> would like to send to my Store.
>> in CDOPackage, CDOClass, etc...
>> information.
>> advance which package it will need so it can use EAnnotations.
Re: [CDO][0.8.0] EAnnotation [message #94211 is a reply to message #94193] Sat, 25 August 2007 14:43 Go to previous messageGo to next message
Perfect!
I will try that thank you!
"Eike Stepper" <stepper@sympedia.de> a
Re: [CDO][0.8.0] EAnnotation [message #94236 is a reply to message #94202] Sun, 26 August 2007 03:35 Go to previous message
Hi Simon,
The exception occurred only with EcorePackage.eInstance because EMF does
some setter/getter magic (see EMF newsgroup thread "eGenericSuperTypes").
Currently I have no solution to this problem so I've disabled getEcore()
only for EcorePackage.eInstance. It should work for all other models.
Cheers
/Eike
>> Hi Simon,
> have to track down ;-(
> in again.
> Cheers
> /Eike
>> the XML model string to an EPackage instance which you can use to
>> query annotations.
>> Does that help?
>> Cheers
>> /Eike
>>> converted in CDOPackage, CDOClass, etc...
>>> information.
Re: [CDO][0.8.0] EAnnotation [message #609524 is a reply to message #94172] Sat, 25 August 2007 14:15 Go to previous message
Hi Simon,
annotations.
Does that help?
Cheers
/Eike
Re: [CDO][0.8.0] EAnnotation [message #609525 is a reply to message #94193] Sat, 25 August 2007 14:24 Go to previous message
> Hi Simon,
to track down ;-(
in again.
Cheers
/Eike
> annotations.
> Does that help?
> Cheers
> /Eike
>> information.
Re: [CDO][0.8.0] EAnnotation [message #609526 is a reply to message #94193] Sat, 25 August 2007 14:43 Go to previous message
Perfect!
Re: [CDO][0.8.0] EAnnotation [message #609529 is a reply to message #94202] Sun, 26 August 2007 03:35 Go to previous message
Hi Simon,
Cheers
/Eike
>> Hi Simon,
> in again.
> Cheers
> /Eike
>> query annotations.
>> Does that help?
>> Cheers
>> /Eike
>>> information.
Previous Topic:Valid Fetch Types
Next Topic:[CDO][0.8.0] Handling Large Collection
Current Time: Tue Jul 22 02:40:34 EDT 2025
Powered by FUDForum. Page generated in 0.12019 seconds
