Re: COnfiguring Visual Editor [message #93791] |
Mon, 13 June 2005 16:19 |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Also, ve 1.0.2.1 only works on Eclipse 3.0.x. It does not work on
Eclipse 3.1. You need VE 1.1M2 (and the correct versions of GEF 3.1 and
EMF 2.1) to work on Eclipse 3.1RC2.
Jeff Myers wrote:
> Alfredo,
> Did you also install the required versions of GEF and EMF, listed on the
> download page for VE 1.0.2.1? You may also try resetting the Java
> perspective by going to the Window menu and selecting Reset perspective.
> Hope this helps,
> - Jeff
> Alfredo DS wrote:
>> Hello:
>> i want to use Visual Editor in Eclipse 3.0.2. I downloaded Visual
>> Studio 1.0.2.1 and unzipped the files in my Eclipse folder. Then, i
>> started again Eclipse with the option -clean and the VE is installed
>> (I see it in Help->About->FeatureDetails). When I want to start a new
>> Project I don't see ther new file types from VE. It is required to
>> activate the VE inside Eclipse? How?
>> Best Regards
>> Alfredo
Rich Kulp
FUDForum. Page generated in 0.03160 seconds
