Home » Eclipse Projects » Subversive » "Restore from Repository" feature missing?
"Restore from Repository" feature missing? [message #8441] Mon, 06 August 2007 08:39 Go to next message
One thing I find invaluable with the Eclipse CVS integration is the
ability to right-click on a Project and select "Team -> Restore from
Repository...". This invokes a dialog where I can view all deleted
files in the CVS repository and restore them.
I have not found such a feature in either Subclipse or Subversive. Is
this because,
a). I haven't found the feature, or
b). The feature is simply not implemented (yet), or
c). SVN itself does not allow this kind of thing?
Thanks in advance,
PB
Re: "Restore from Repository" feature missing? [message #9031 is a reply to message #8441] Wed, 19 September 2007 16:02 Go to previous message
Originally posted by: mk.nospam.org
You should try the following:
- Right click on the folder where the file(s) was(were)
- Select Team -> Revert...
=> Then you get a list of files, that were deleted, modified etc. and
you can select the changes you would like to "undo".
HTH,
Martin Klinke
Previous Topic:Subversive support for Buckminster
Next Topic:Are Subclipse still involved?
Current Time: Sat Jul 26 05:15:20 EDT 2025
Powered by FUDForum. Page generated in 0.04972 seconds
